[U-Boot] [PATCH] board: atmel: Enable to use new timer driver
Use the Atmel PIT timer driver which supports the driver model and device tree.
Signed-off-by: Wenyou Yang wenyou.yang@microchip.com --- The patch is based on, [PATCH] timer: Add Atmel PIT timer driver https://lists.denx.de/pipermail/u-boot/2017-August/300788.html
arch/arm/dts/sama5d2.dtsi | 28 +++++++++++++++++++++++++++ arch/arm/mach-at91/include/mach/at91sam9g45.h | 3 --- arch/arm/mach-at91/include/mach/at91sam9x5.h | 3 --- arch/arm/mach-at91/include/mach/sama5d2.h | 3 --- arch/arm/mach-at91/include/mach/sama5d3.h | 3 --- arch/arm/mach-at91/include/mach/sama5d4.h | 3 --- configs/at91sam9m10g45ek_mmc_defconfig | 2 ++ configs/at91sam9m10g45ek_nandflash_defconfig | 2 ++ configs/at91sam9n12ek_mmc_defconfig | 2 ++ configs/at91sam9n12ek_nandflash_defconfig | 2 ++ configs/at91sam9n12ek_spiflash_defconfig | 2 ++ configs/at91sam9x5ek_dataflash_defconfig | 2 ++ configs/at91sam9x5ek_mmc_defconfig | 2 ++ configs/at91sam9x5ek_nandflash_defconfig | 2 ++ configs/at91sam9x5ek_spiflash_defconfig | 2 ++ configs/gurnard_defconfig | 2 ++ configs/sama5d2_xplained_mmc_defconfig | 3 +++ configs/sama5d2_xplained_spiflash_defconfig | 3 +++ configs/sama5d36ek_cmp_mmc_defconfig | 4 +++- configs/sama5d36ek_cmp_nandflash_defconfig | 2 ++ configs/sama5d36ek_cmp_spiflash_defconfig | 2 ++ configs/sama5d3_xplained_mmc_defconfig | 3 +++ configs/sama5d3_xplained_nandflash_defconfig | 3 +++ configs/sama5d3xek_mmc_defconfig | 3 +++ configs/sama5d3xek_nandflash_defconfig | 3 +++ configs/sama5d3xek_spiflash_defconfig | 3 +++ configs/sama5d4_xplained_mmc_defconfig | 5 ++++- configs/sama5d4_xplained_nandflash_defconfig | 3 +++ configs/sama5d4_xplained_spiflash_defconfig | 3 +++ configs/sama5d4ek_mmc_defconfig | 3 +++ configs/sama5d4ek_nandflash_defconfig | 3 +++ configs/sama5d4ek_spiflash_defconfig | 3 +++ include/configs/corvus.h | 3 +++ include/configs/picosam9g45.h | 3 +++ include/configs/pm9g45.h | 3 +++ include/configs/sama5d2_ptc.h | 3 +++ 36 files changed, 107 insertions(+), 17 deletions(-)
diff --git a/arch/arm/dts/sama5d2.dtsi b/arch/arm/dts/sama5d2.dtsi index fbaac0834c..4bdbb70cd5 100644 --- a/arch/arm/dts/sama5d2.dtsi +++ b/arch/arm/dts/sama5d2.dtsi @@ -639,6 +639,34 @@ status = "disabled"; };
+ rstc@f8048000 { + compatible = "atmel,sama5d3-rstc"; + reg = <0xf8048000 0x10>; + clocks = <&clk32k>; + }; + + shdwc@f8048010 { + compatible = "atmel,sama5d2-shdwc"; + reg = <0xf8048010 0x10>; + clocks = <&clk32k>; + #address-cells = <1>; + #size-cells = <0>; + atmel,wakeup-rtc-timer; + }; + + pit: timer@f8048030 { + compatible = "atmel,at91sam9260-pit"; + reg = <0xf8048030 0x10>; + clocks = <&h32ck>; + }; + + watchdog@f8048040 { + compatible = "atmel,sama5d4-wdt"; + reg = <0xf8048040 0x10>; + clocks = <&clk32k>; + status = "disabled"; + }; + sckc@f8048050 { compatible = "atmel,at91sam9x5-sckc"; reg = <0xf8048050 0x4>; diff --git a/arch/arm/mach-at91/include/mach/at91sam9g45.h b/arch/arm/mach-at91/include/mach/at91sam9g45.h index 5c32e24ed0..c3b3a8fdc8 100644 --- a/arch/arm/mach-at91/include/mach/at91sam9g45.h +++ b/arch/arm/mach-at91/include/mach/at91sam9g45.h @@ -137,9 +137,6 @@ #define ATMEL_BASE_CS6 0x70000000 #define ATMEL_BASE_CS7 0x80000000
-/* Timer */ -#define CONFIG_SYS_TIMER_COUNTER 0xfffffd3c - /* * Other misc defines */ diff --git a/arch/arm/mach-at91/include/mach/at91sam9x5.h b/arch/arm/mach-at91/include/mach/at91sam9x5.h index e7224e432d..8f460f016d 100644 --- a/arch/arm/mach-at91/include/mach/at91sam9x5.h +++ b/arch/arm/mach-at91/include/mach/at91sam9x5.h @@ -164,9 +164,6 @@ #define ATMEL_CPU_NAME get_cpu_name() #endif
-/* Timer */ -#define CONFIG_SYS_TIMER_COUNTER 0xfffffe3c - /* * Other misc defines */ diff --git a/arch/arm/mach-at91/include/mach/sama5d2.h b/arch/arm/mach-at91/include/mach/sama5d2.h index 25c85411e5..9fe572621c 100644 --- a/arch/arm/mach-at91/include/mach/sama5d2.h +++ b/arch/arm/mach-at91/include/mach/sama5d2.h @@ -224,9 +224,6 @@
#define cpu_is_sama5d2() (get_chip_id() == ARCH_ID_SAMA5D2)
-/* PIT Timer(PIT_PIIR) */ -#define CONFIG_SYS_TIMER_COUNTER 0xf804803c - /* No PMECC Galois table in ROM */ #define NO_GALOIS_TABLE_IN_ROM
diff --git a/arch/arm/mach-at91/include/mach/sama5d3.h b/arch/arm/mach-at91/include/mach/sama5d3.h index d558f95141..eb9f7e5658 100644 --- a/arch/arm/mach-at91/include/mach/sama5d3.h +++ b/arch/arm/mach-at91/include/mach/sama5d3.h @@ -190,9 +190,6 @@ #define ATMEL_PIO_PORTS 5 #define CPU_HAS_PCR
-/* Timer */ -#define CONFIG_SYS_TIMER_COUNTER 0xfffffe3c - /* * PMECC table in ROM */ diff --git a/arch/arm/mach-at91/include/mach/sama5d4.h b/arch/arm/mach-at91/include/mach/sama5d4.h index 78cc2a7a0a..90e7f01464 100644 --- a/arch/arm/mach-at91/include/mach/sama5d4.h +++ b/arch/arm/mach-at91/include/mach/sama5d4.h @@ -222,9 +222,6 @@ #define cpu_is_sama5d44() (cpu_is_sama5d4() && \ (get_extension_chip_id() == ARCH_EXID_SAMA5D44))
-/* Timer */ -#define CONFIG_SYS_TIMER_COUNTER 0xfc06863c - /* * No PMECC Galois table in ROM */ diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index ed9e9c20b9..e4f8e0c516 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -45,6 +45,8 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index c6e75fd285..6f7a533c1d 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -45,6 +45,8 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 16e9c4cec2..c2d2639b16 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -46,6 +46,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 3407fd3983..86cca59d96 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -46,6 +46,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index eb17acfca8..d960e0c6b8 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -46,6 +46,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index fa1f7dffd9..a60aeba7fa 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -50,6 +50,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 04ff0a21c8..69f7efc33e 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -50,6 +50,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index da983408b7..644b31ea82 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -50,6 +50,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index bc81f7ab50..be57e9751b 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -50,6 +50,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index d90dbe6a83..fe2f329431 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -21,6 +21,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index b4405854ff..d84a16f1db 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -70,6 +71,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index e2b41eab15..c7778fc580 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -68,6 +69,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index a19fc0ba73..5037533c92 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -49,6 +49,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y -CONFIG_FAT_WRITE=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_DM_VIDEO=y CONFIG_ATMEL_HLCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 06448253da..01619d569a 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -49,6 +49,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_DM_VIDEO=y CONFIG_ATMEL_HLCD=y CONFIG_FAT_WRITE=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 734379a889..99d08b8183 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -49,6 +49,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_DM_VIDEO=y CONFIG_ATMEL_HLCD=y CONFIG_FAT_WRITE=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index acd74994c4..5fd23da054 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -62,6 +63,8 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index af8d1ef16d..be6ec8dd3c 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -16,6 +16,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -59,6 +60,8 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index bf620e58cd..94be286a65 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -68,6 +69,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 252fd54f5d..ee0ca0cebe 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -63,6 +64,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index d99d1aae9f..e81f52c86e 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -64,6 +65,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index ecc92ba9b3..a29b269dfb 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -66,12 +67,14 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y -CONFIG_FAT_WRITE=y CONFIG_DM_VIDEO=y CONFIG_ATMEL_HLCD=y +CONFIG_FAT_WRITE=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index c88c461244..4b2e8334d0 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -16,6 +16,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -63,6 +64,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index cc0d16586f..e01c1cc8d0 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -65,6 +66,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index c1eefe3f45..5bd20d1155 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -66,6 +67,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index fb18ba8959..cb4fd0214d 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -63,6 +64,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 88357bbcc4..ccc09a539a 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set @@ -62,6 +63,8 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 015072720e..dfb3a686fd 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -32,6 +32,9 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */
+/* Timer */ +#define CONFIG_SYS_TIMER_COUNTER 0xfffffd3c + #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index a14739f282..f5857241b9 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -26,6 +26,9 @@
#define CONFIG_PICOSAM
+/* Timer */ +#define CONFIG_SYS_TIMER_COUNTER 0xfffffd3c + #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index dc4ebeab31..d3340ed67e 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -40,6 +40,9 @@
#define CONFIG_SKIP_LOWLEVEL_INIT
+/* Timer */ +#define CONFIG_SYS_TIMER_COUNTER 0xfffffd3c + /* * Hardware drivers */ diff --git a/include/configs/sama5d2_ptc.h b/include/configs/sama5d2_ptc.h index 401f1987ee..bff9f8eb48 100644 --- a/include/configs/sama5d2_ptc.h +++ b/include/configs/sama5d2_ptc.h @@ -29,6 +29,9 @@
#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
+/* PIT Timer(PIT_PIIR) */ +#define CONFIG_SYS_TIMER_COUNTER 0xf804803c + #undef CONFIG_AT91_GPIO #define CONFIG_ATMEL_PIO4
As-is this breaks: at91sam9x5ek_nandflash sama5d36ek_cmp_spiflash at91sam9x5ek_mmc sama5d4ek_nandflash sama5d3xek_nandflash sama5d3xek_spiflash at91sam9n12ek_nandflash at91sam9n12ek_spiflash sama5d4_xplained_mmc sama5d4ek_spiflash at91sam9n12ek_mmc at91sam9m10g45ek_nandflash sama5d4_xplained_nandflash sama5d3xek_mmc at91sam9x5ek_spiflash sama5d2_xplained_spiflash sama5d2_xplained_mmc sama5d36ek_cmp_nandflash sama5d4ek_mmc sama5d4_xplained_spiflash at91sam9m10g45ek_mmc sama5d3_xplained_nandflash sama5d36ek_cmp_mmc at91sam9x5ek_dataflash gurnard sama5d3_xplained_mmc
Hi Tom,
Will fix in the new version.
Thank you.
Wenyou Yang
Wenyou Yang
Yang, Wenyou
