[U-Boot] [PATCH V3] imx25: Fix reset
This patch fixes the reset command on imx25. The watchdog registers are 16 bits in size and not 32. This patch also adds the service register codes as constants.
Signed-off-by: Matthias Weisser weisserm@arcor.de ---
Changes since V2 - Using 16 bit constants
Changes since V1 - Corrected whitespace - Leaving reset sequence as it originally was
arch/arm/cpu/arm926ejs/mx25/reset.c | 8 ++++---- arch/arm/include/asm/arch-mx25/imx-regs.h | 14 ++++++++------ 2 files changed, 12 insertions(+), 10 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx25/reset.c b/arch/arm/cpu/arm926ejs/mx25/reset.c index 1e33150..1a43683 100644 --- a/arch/arm/cpu/arm926ejs/mx25/reset.c +++ b/arch/arm/cpu/arm926ejs/mx25/reset.c @@ -43,14 +43,14 @@ void reset_cpu (ulong ignored) { struct wdog_regs *regs = (struct wdog_regs *)IMX_WDT_BASE; /* Disable watchdog and set Time-Out field to 0 */ - writel (0x00000000, ®s->wcr); + writew(0, ®s->wcr);
/* Write Service Sequence */ - writel (0x00005555, ®s->wsr); - writel (0x0000AAAA, ®s->wsr); + writew(WSR_UNLOCK1, ®s->wsr); + writew(WSR_UNLOCK2, ®s->wsr);
/* Enable watchdog */ - writel (WCR_WDE, ®s->wcr); + writew(WCR_WDE, ®s->wcr);
while (1) ; } diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index f709bd8..f5a2929 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -108,11 +108,11 @@ struct gpt_regs {
/* Watchdog Timer (WDOG) registers */ struct wdog_regs { - u32 wcr; /* Control */ - u32 wsr; /* Service */ - u32 wrsr; /* Reset Status */ - u32 wicr; /* Interrupt Control */ - u32 wmcr; /* Misc Control */ + u16 wcr; /* Control */ + u16 wsr; /* Service */ + u16 wrsr; /* Reset Status */ + u16 wicr; /* Interrupt Control */ + u16 wmcr; /* Misc Control */ };
/* IIM control registers */ @@ -308,7 +308,9 @@ struct iim_regs { #define GPT_CTRL_TEN 1 /* Timer enable */
/* WDOG enable */ -#define WCR_WDE 0x04 +#define WCR_WDE 0x04 +#define WSR_UNLOCK1 0x5555 +#define WSR_UNLOCK2 0xAAAA
/* FUSE bank offsets */ #define IIM0_MAC 0x1a
Dear Matthias Weisser,
struct wdog_regs {
- u16 wcr; /* Control */
- u16 wsr; /* Service */
- u16 wrsr; /* Reset Status */
- u16 wicr; /* Interrupt Control */
- u16 wmcr; /* Misc Control */
What catches my ARM-aware eye:
I do not know the hardware, but are those registers really arranged on 2 byte boundaries (00, 02, 04, 06, 08, 0a, .. offsets)? Probably yes, assuming your code is tested ;)
Or should there be a u16 filler between each register?
Best Regards, Reinhard
struct wdog_regs {
Yes, they are. It sounds strange, but they are 16-bit wide.
Stefano
Hello Reinhard
Am 27.10.2010 16:43, schrieb Reinhard Meyer:
struct wdog_regs {
- u16 wmcr; /* Misc Control */ };
Yes, they are. I looked into the datasheet multiple times to confirm that. Not typical for an ARM system, but how knows which IP Freescale recycled here ;-)
If you want to convince yourself take a look at page 1988 of http://cache.freescale.com/files/dsp/doc/ref_manual/IMX25RM.pdf?fpsp=1
Matthias
Changes since V2
Changes since V1
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Matthias Weisser
Matthias Weißer
Reinhard Meyer
Stefano Babic
