[PATCH] ARM: meson: stop printing board model after sysinfo update
After the sysinfo update, Model is printed twice, remove the now duplicate Model print from mach-meson/board-info.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- arch/arm/mach-meson/board-info.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/arch/arm/mach-meson/board-info.c b/arch/arm/mach-meson/board-info.c index 95a29da072..d51d9b8f06 100644 --- a/arch/arm/mach-meson/board-info.c +++ b/arch/arm/mach-meson/board-info.c @@ -126,13 +126,6 @@ static const char *socinfo_to_soc_id(u32 socinfo) return "Unknown"; }
-static void print_board_model(void) -{ - const char *model; - model = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - printf("Model: %s\n", model ? model : "Unknown"); -} - static unsigned int get_socinfo(void) { struct regmap *regmap; @@ -172,9 +165,6 @@ int checkboard(void) { unsigned int socinfo;
- /* print board information */ - print_board_model(); - socinfo = get_socinfo(); if (!socinfo) return 0;
--- base-commit: 15e7927b5a2d33666af19879577bf0c30ab088fe change-id: 20240124-u-boot-model-print-fix-cd2e95d67e21
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-amlogic (u-boot-amlogic)
[1/1] ARM: meson: stop printing board model after sysinfo update https://source.denx.de/u-boot/custodians/u-boot-amlogic/-/commit/076529725f1...
Neil Armstrong
