[U-Boot-Users] Booting from NAND Flash Problems
I am working on a board that has a mips processor and only Nand Flash.
This creates a problem as u-boot cannot be run directly from Nand Flash as only the first 16K of Nand flash can be read by a processor without a Nand Flash Driver.
This means that a small program has to run first. This small program is < 16K in size and copies U-Boot from Nand Flash into RAM and then executes it.
In theory this should work fine.
bootprom loads micro bootloader. bootloader loads u-boot u-boot starts and relocates itself u-boot starts running.
However i am having loads of issues with running u-boot with cache enabled. If cache is enabled then the Nand Driver (I am using the latest Linux MTD based driver) has problems as it uses a DMA copy to copy to the Nand Flash. If I implement cache flushing I break u-boot.
This is because it starts to flush the cache when reading the environment that is located in Nand Flash the problem is that the relocation seems to have not completed so the stack that is in Cache locked addresses goes wrong (PCI fails to work).
If I try to run u-boot uncached I fail as well.
I was wondering if anyone has any hints or tips on how u-boot is used in a system with only Nand Flash and a Mips processor. I have seen other posts suggesting mips processors should run uncached but this is obviously slower. Has the case been consider where relocation is not necessary i.e a small program just loads the executable to a location and runs it. I know relocation can save memory but in my system it means extra copying and currently extra headaches!!
Hope some people can help cheers dan
-- View this message in context: http://www.nabble.com/Booting-from-NAND-Flash-Problems-t1637982.html#a443634... Sent from the Uboot - Users forum at Nabble.com.
This works fine in practice for a couple of systems.
Then your port of U-Boot is broken.
I don;t see anything in your setup where using NAND flash or a MIPS CPU plays a role; all this is pretty similar on all architectures.
Define "run uncached".
Yes.
Then don't do it.
And BTW: Relocation does not save memory at all.
Cool!
I appreciate the port of u-boot it broken but let me just elaborate a little more. I am using the standard mips code i.e All I have added to cpu/mips is a serial port driver. I then create a board and implement the usual functions checkboard, initdram, low_level_init etc.... I then use an MTD driver that runs perfectly under linux. i.e the same C file with minor structure name changes is used from our linux port that has been stable and used for a long time now. I then indicate that the environment is stored in nand flash.
It loads the environment but always rejects it based on the CRC check. If I cache flush after reading the environment from flash the CRC check completes ok and it uses this environment. problem is all the code that follows (device init, eth_initialise, etc fail) Without a cache flush these work. I think that you need to initialise the NAND flash and env_relocate before the calls to eth_initialise etc so I do not feel my order is incorrect. So I was wondering what ideas people may have. I feel that the most likely is that my linux MTD driver use GFP_DMA flag and kmalloc when it is used in Linux. This may (I am still investigating) result in it using a different KSEG which the mips has set up to be uncached. (using the MMU) whereas under u-boot this is mapped to just malloc and as such is still cached. I will pursue this but any helpful ideas from anyone would be appreciated.
Agreed was just asking for hints and tips!
Caches disabled.
Yes.
Then don't do it.
agreed but as I have indicated throughout I was trying to limit the changes to the cpu/mips bit and this does relocate hence i tried this.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The ultimate barrier is one's viewpoint. - Terry Pratchett, _The Dark Side of the Sun_
Cheers Daniel Laird -- View this message in context: http://www.nabble.com/Booting+from+NAND+Flash+Problems-t1637982.html#a450113... Sent from the Uboot - Users forum at Nabble.com.
Why don't you use the existing NAND flash code in U-boot?
Please note that "runs perfectly under linux" doesn't mean anything here. U-Boot is not Linux.
You probably should make sure to use proper cache policies and/or flushing troughout your port.
That's what I said: fix your port of U-Boot.
Why don't you just use the existing code?
You mention "our driver", "my code" and "my order" - how should we comment on this? If you think you know beter and come up with your own implementation then you will have to debug it yourself. All I can say is that the exsiting code in U-Boot works fine on a couple of boards.
Dump your custome code. Use the existing one.
This is my last comment on this.
Caches disabled.
Instruction cache or data cache or both or what? Yo need to be more specific.
Why don't you use the existing NAND flash code in U-boot? Please note that "runs perfectly under linux" doesn't mean anything here. U-Boot is not Linux.
Unfortunately the chip I am using has a Flash Interface Chip that handles the access to flash, this means that the standard u-boot flash code will not access the flash properly(my problem I know). This is why a custom MTD driver that plugs into the linux MTD infrastructure was written and is used succesfully. U-Boot then took the really good decision to use the same infrastructure hence I use the same driver code. I agree that u-boot is not linux but a driver that works using the same infrastructure is always a good starting point.
As indicated I am using the standard cpu/mips code with a custom serial port driver. This was done to minimise the probability of bugs being introduced by myself. There is obviously an issue in my port regarding cache flushing. I had also seen this discussion http://sourceforge.net/mailarchive/forum.php?thread_id=10170097&forum_id... And was wondering if i might be suffereing with a similar issue hence I asked the community for there wider experience and advice. No point solving a fixed problem!
Obviously a true statement I was just seeing if others has seen anything similar, using the standard cpu/mips code should minimise the bugs I should have introduced
In the current lib_mips/board.c nand_init is not actually called. Hence I questioned if anyone had used the new Linux based NAND driver infrastructure with a mips cpu.
Fair point, I am sure i do not know better however the chip I am using dictates using a different NAND driver, the current lib_mips does not seem to initialise NAND flash and I am using the cpu/mips code to minimise the bugs i will have introduced.
of
boards.
Cool, I never questioned that I only asked if a mips processor was using the new NAND infrastructure and if anyone had had any issue regarding caching etc. When looking throught the code it seems that 3 boards use ENV_IS_IN_NAND and these are 2 XScales and one PPC.
Thanks for all the comments i will see if i can fix my port and feed back the changes Dan -- View this message in context: http://www.nabble.com/Booting+from+NAND+Flash+Problems-t1637982.html#a451860... Sent from the Uboot - Users forum at Nabble.com.
I had a similar problem with the AMD AU1500 SOC (mips32 core). The relocation was copying the code to ram but the instructions were being cached in data cache since it was just a data copy (although the data was really instructions). I solved the problem by invaildating the instruction cache after the copy but before jumping to the relocated code. This fixed my problem. Don't know if this your problem, but it might give you a clue...
__________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Daniel Laird
Frank
