[U-Boot] [PATCH] ARM: tegra210: implement PLLE init procedure from TRM
Implement the procedure that the TRM mandates to initialize PLLREFE and PLLE. This makes the PLL actually lock.
Note that this section of the TRM is being cleaned up to remove some confusion. The set of register accesses in this patch should be final, although the step numbers/descriptions might still change.
Signed-off-by: Stephen Warren swarren@nvidia.com --- arch/arm/mach-tegra/tegra210/clock.c | 179 ++++++++++++++++++++++++++--------- 1 file changed, 132 insertions(+), 47 deletions(-)
diff --git a/arch/arm/mach-tegra/tegra210/clock.c b/arch/arm/mach-tegra/tegra210/clock.c index 6d75d371cb03..df92bdce889e 100644 --- a/arch/arm/mach-tegra/tegra210/clock.c +++ b/arch/arm/mach-tegra/tegra210/clock.c @@ -8,6 +8,7 @@ /* Tegra210 Clock control functions */
#include <common.h> +#include <errno.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/sysctr.h> @@ -1030,6 +1031,59 @@ void arch_timer_init(void) debug("%s: TSC CNTCR = 0x%08X\n", __func__, val); }
+#define PLLREFE_MISC 0x4c8 +#define PLLREFE_MISC_LOCK BIT(27) +#define PLLREFE_MISC_IDDQ BIT(24) + +#define PLLREFE_BASE 0x4c4 +#define PLLREFE_BASE_BYPASS BIT(31) +#define PLLREFE_BASE_ENABLE BIT(30) +#define PLLREFE_BASE_REF_DIS BIT(29) +#define PLLREFE_BASE_KCP(kcp) (((kcp) & 0x3) << 27) +#define PLLREFE_BASE_KVCO BIT(26) +#define PLLREFE_BASE_DIVP(p) (((p) & 0x1f) << 16) +#define PLLREFE_BASE_DIVN(n) (((n) & 0xff) << 8) +#define PLLREFE_BASE_DIVM(m) (((m) & 0xff) << 0) + +static int tegra_pllref_enable(void) +{ + u32 value; + unsigned long start; + + /* + * This sequence comes from Tegra X1 TRM section "Cold Boot, with no + * Recovery Mode or Boot from USB", sub-section "PLLREFE". + */ + + value = readl(NV_PA_CLK_RST_BASE + PLLREFE_MISC); + value &= ~PLLREFE_MISC_IDDQ; + writel(value, NV_PA_CLK_RST_BASE + PLLREFE_MISC); + + udelay(5); + + value = PLLREFE_BASE_ENABLE | + PLLREFE_BASE_KCP(0) | + PLLREFE_BASE_DIVP(0) | + PLLREFE_BASE_DIVN(0x41) | + PLLREFE_BASE_DIVM(4); + writel(value, NV_PA_CLK_RST_BASE + PLLREFE_BASE); + + debug("waiting for pllrefe lock\n"); + start = get_timer(0); + while (get_timer(start) < 250) { + value = readl(NV_PA_CLK_RST_BASE + PLLREFE_MISC); + if (value & PLLREFE_MISC_LOCK) + break; + } + if (!(value & PLLREFE_MISC_LOCK)) { + debug(" timeout\n"); + return -ETIMEDOUT; + } + debug(" done\n"); + + return 0; +} + #define PLLE_SS_CNTL 0x68 #define PLLE_SS_CNTL_SSCINCINTR(x) (((x) & 0x3f) << 24) #define PLLE_SS_CNTL_SSCINC(x) (((x) & 0xff) << 16) @@ -1041,100 +1095,131 @@ void arch_timer_init(void) #define PLLE_SS_CNTL_SSCMAX(x) (((x) & 0x1ff) << 0)
#define PLLE_BASE 0x0e8 -#define PLLE_BASE_ENABLE (1 << 30) -#define PLLE_BASE_LOCK_OVERRIDE (1 << 29) -#define PLLE_BASE_PLDIV_CML(x) (((x) & 0xf) << 24) +#define PLLE_BASE_ENABLE (1 << 31) +#define PLLE_BASE_PLDIV_CML(x) (((x) & 0x1f) << 24) #define PLLE_BASE_NDIV(x) (((x) & 0xff) << 8) #define PLLE_BASE_MDIV(x) (((x) & 0xff) << 0)
#define PLLE_MISC 0x0ec #define PLLE_MISC_IDDQ_SWCTL (1 << 14) -#define PLLE_MISC_IDDQ_OVERRIDE (1 << 13) -#define PLLE_MISC_LOCK_ENABLE (1 << 9) -#define PLLE_MISC_PTS (1 << 8) -#define PLLE_MISC_VREG_BG_CTRL(x) (((x) & 0x3) << 4) +#define PLLE_MISC_IDDQ_OVERRIDE_VALUE (1 << 13) +#define PLLE_MISC_LOCK (1 << 11) +#define PLLE_MISC_KCP(x) (((x) & 0x3) << 6) #define PLLE_MISC_VREG_CTRL(x) (((x) & 0x3) << 2) +#define PLLE_MISC_KVCO (1 << 0)
#define PLLE_AUX 0x48c +#define PLLE_AUX_SS_SEQ_INCLUDE (1 << 31) +#define PLLE_AUX_REF_SEL_PLLREFE (1 << 28) #define PLLE_AUX_SEQ_ENABLE (1 << 24) +#define PLLE_AUX_SS_SWCTL (1 << 6) #define PLLE_AUX_ENABLE_SWCTL (1 << 4) +#define PLLE_AUX_USE_LOCKDET (1 << 3)
int tegra_plle_enable(void) { - unsigned int m = 1, n = 200, cpcon = 13; u32 value; + unsigned long start;
- value = readl(NV_PA_CLK_RST_BASE + PLLE_BASE); - value &= ~PLLE_BASE_LOCK_OVERRIDE; - writel(value, NV_PA_CLK_RST_BASE + PLLE_BASE); + /* PLLREF feeds PLLE */ + tegra_pllref_enable(); + + /* + * This sequence comes from Tegra X1 TRM section "Cold Boot, with no + * Recovery Mode or Boot from USB", sub-section "PLLEs". + */ + + /* 1. Select XTAL as the source */
value = readl(NV_PA_CLK_RST_BASE + PLLE_AUX); - value |= PLLE_AUX_ENABLE_SWCTL; - value &= ~PLLE_AUX_SEQ_ENABLE; + value &= ~PLLE_AUX_REF_SEL_PLLREFE; writel(value, NV_PA_CLK_RST_BASE + PLLE_AUX);
- udelay(1); - value = readl(NV_PA_CLK_RST_BASE + PLLE_MISC); - value |= PLLE_MISC_IDDQ_SWCTL; - value &= ~PLLE_MISC_IDDQ_OVERRIDE; - value |= PLLE_MISC_LOCK_ENABLE; - value |= PLLE_MISC_PTS; - value |= PLLE_MISC_VREG_BG_CTRL(3); - value |= PLLE_MISC_VREG_CTRL(2); + value &= ~PLLE_MISC_IDDQ_OVERRIDE_VALUE; writel(value, NV_PA_CLK_RST_BASE + PLLE_MISC);
+ /* 2. Wait 5 us */ udelay(5);
- value = readl(NV_PA_CLK_RST_BASE + PLLE_SS_CNTL); - value |= PLLE_SS_CNTL_SSCBYP | PLLE_SS_CNTL_INTERP_RESET | - PLLE_SS_CNTL_BYPASS_SS; - writel(value, NV_PA_CLK_RST_BASE + PLLE_SS_CNTL); + /* + * 3. Program the following registers to generate a low jitter 100MHz + * clock. + */
value = readl(NV_PA_CLK_RST_BASE + PLLE_BASE); - value &= ~PLLE_BASE_PLDIV_CML(0xf); + value &= ~PLLE_BASE_PLDIV_CML(0x1f); value &= ~PLLE_BASE_NDIV(0xff); value &= ~PLLE_BASE_MDIV(0xff); - value |= PLLE_BASE_PLDIV_CML(cpcon); - value |= PLLE_BASE_NDIV(n); - value |= PLLE_BASE_MDIV(m); + value |= PLLE_BASE_PLDIV_CML(0xe); + value |= PLLE_BASE_NDIV(0x7d); + value |= PLLE_BASE_MDIV(2); writel(value, NV_PA_CLK_RST_BASE + PLLE_BASE);
- udelay(1); + value = readl(NV_PA_CLK_RST_BASE + PLLE_MISC); + value &= ~PLLE_MISC_KCP(3); + value &= ~PLLE_MISC_VREG_CTRL(3); + value &= ~PLLE_MISC_KVCO; + writel(value, NV_PA_CLK_RST_BASE + PLLE_MISC);
value = readl(NV_PA_CLK_RST_BASE + PLLE_BASE); value |= PLLE_BASE_ENABLE; writel(value, NV_PA_CLK_RST_BASE + PLLE_BASE);
- /* wait for lock */ - udelay(300); - - value = readl(NV_PA_CLK_RST_BASE + PLLE_SS_CNTL); - value &= ~PLLE_SS_CNTL_SSCINVERT; - value &= ~PLLE_SS_CNTL_SSCCENTER; - - value &= ~PLLE_SS_CNTL_SSCINCINTR(0x3f); - value &= ~PLLE_SS_CNTL_SSCINC(0xff); - value &= ~PLLE_SS_CNTL_SSCMAX(0x1ff); + /* 4. Wait for LOCK */
- value |= PLLE_SS_CNTL_SSCINCINTR(0x20); - value |= PLLE_SS_CNTL_SSCINC(0x01); - value |= PLLE_SS_CNTL_SSCMAX(0x25); + debug("waiting for plle lock\n"); + start = get_timer(0); + while (get_timer(start) < 250) { + value = readl(NV_PA_CLK_RST_BASE + PLLE_MISC); + if (value & PLLE_MISC_LOCK) + break; + } + if (!(value & PLLE_MISC_LOCK)) { + debug(" timeout\n"); + return -ETIMEDOUT; + } + debug(" done\n");
- writel(value, NV_PA_CLK_RST_BASE + PLLE_SS_CNTL); + /* 5. Enable SSA */
value = readl(NV_PA_CLK_RST_BASE + PLLE_SS_CNTL); - value &= ~PLLE_SS_CNTL_SSCBYP; + value &= ~PLLE_SS_CNTL_SSCINC(0xff); + value |= PLLE_SS_CNTL_SSCINC(1); + value &= ~PLLE_SS_CNTL_SSCINCINTR(0x3f); + value |= PLLE_SS_CNTL_SSCINCINTR(0x23); + value &= ~PLLE_SS_CNTL_SSCMAX(0x1fff); + value |= PLLE_SS_CNTL_SSCMAX(0x21); + value &= ~PLLE_SS_CNTL_SSCINVERT; + value &= ~PLLE_SS_CNTL_SSCCENTER; value &= ~PLLE_SS_CNTL_BYPASS_SS; + value &= ~PLLE_SS_CNTL_SSCBYP; writel(value, NV_PA_CLK_RST_BASE + PLLE_SS_CNTL);
- udelay(1); + /* 6. Wait 300 ns */
- value = readl(NV_PA_CLK_RST_BASE + PLLE_SS_CNTL); + udelay(1); value &= ~PLLE_SS_CNTL_INTERP_RESET; writel(value, NV_PA_CLK_RST_BASE + PLLE_SS_CNTL);
+ /* 7. Enable HW power sequencer for PLLE */ + + value = readl(NV_PA_CLK_RST_BASE + PLLE_MISC); + value &= ~PLLE_MISC_IDDQ_SWCTL; + writel(value, NV_PA_CLK_RST_BASE + PLLE_MISC); + + value = readl(NV_PA_CLK_RST_BASE + PLLE_AUX); + value &= ~PLLE_AUX_SS_SWCTL; + value &= ~PLLE_AUX_ENABLE_SWCTL; + value |= PLLE_AUX_SS_SEQ_INCLUDE; + value |= PLLE_AUX_USE_LOCKDET; + writel(value, NV_PA_CLK_RST_BASE + PLLE_AUX); + + /* 8. Wait 1 us */ + udelay(1); + value |= PLLE_AUX_SEQ_ENABLE; + writel(value, NV_PA_CLK_RST_BASE + PLLE_AUX);
return 0; }
Tom,
Is this patch OK? I assume it can be applied now the merge window is over?
Stephen Warren
