[U-Boot] [PATCH 2/2] TRATS: use the generic watchdog timer
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: HeungJun, Kim riverful.kim@samsung.com --- board/samsung/trats/trats.c | 11 +---------- 1 files changed, 1 insertions(+), 10 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 2925cff..f795ff0 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -310,14 +310,6 @@ static void board_clock_init(void) writel(CLK_GATE_BLOCK_VAL, (unsigned int)&clk->gate_block); }
-static void board_watchdog_disable(void) -{ - struct exynos4_watchdog *wd = - (struct exynos4_watchdog *)samsung_get_base_watchdog(); - - writel(~(WTCON_EN | WTCON_INT), (unsigned int)&wd->wtcon); -} - static void board_power_init(void) { struct exynos4_power *pwr = @@ -368,8 +360,7 @@ static void board_uart_init(void)
int board_early_init_f(void) { - board_watchdog_disable(); - + wdt_stop(); pmic_reset(); board_clock_init(); board_uart_init();
applied to u-boot-samsung.
Minkyu Kang.
Minkyu Kang
Minkyu Kang
