[PATCH v2] pinctrl: nuvoton: Add NPCM8xx pinctrl driver
Add Nuvoton BMC NPCM845 Pinmux and Pinconf support.
Signed-off-by: Stanley Chu yschu@nuvoton.com --- v2: - drop the WDnRCRB/CORSTCB register access, it is not for GPIO modules reset control --- drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/nuvoton/Kconfig | 6 + drivers/pinctrl/nuvoton/Makefile | 1 + drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c | 1163 +++++++++++++++++++++ 5 files changed, 1172 insertions(+) create mode 100644 drivers/pinctrl/nuvoton/Kconfig create mode 100644 drivers/pinctrl/nuvoton/Makefile create mode 100644 drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 03946245c7..076aff1a8d 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -329,6 +329,7 @@ source "drivers/pinctrl/mscc/Kconfig" source "drivers/pinctrl/mtmips/Kconfig" source "drivers/pinctrl/mvebu/Kconfig" source "drivers/pinctrl/nexell/Kconfig" +source "drivers/pinctrl/nuvoton/Kconfig" source "drivers/pinctrl/nxp/Kconfig" source "drivers/pinctrl/renesas/Kconfig" source "drivers/pinctrl/rockchip/Kconfig" diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index df37c32033..de84f8912b 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -12,6 +12,7 @@ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ obj-$(CONFIG_ARCH_ATH79) += ath79/ obj-$(CONFIG_PINCTRL_INTEL) += intel/ obj-$(CONFIG_ARCH_MTMIPS) += mtmips/ +obj-$(CONFIG_ARCH_NPCM) += nuvoton/ obj-$(CONFIG_ARCH_RMOBILE) += renesas/ obj-$(CONFIG_PINCTRL_SANDBOX) += pinctrl-sandbox.o
diff --git a/drivers/pinctrl/nuvoton/Kconfig b/drivers/pinctrl/nuvoton/Kconfig new file mode 100644 index 0000000000..b490b41a60 --- /dev/null +++ b/drivers/pinctrl/nuvoton/Kconfig @@ -0,0 +1,6 @@ +config PINCTRL_NPCM8XX + bool "Pinctrl driver for Nuvoton NPCM8XX" + depends on DM && PINCTRL_GENERIC && ARCH_NPCM8XX + help + Support pin muxing and pin configuration on + Nuvoton NPCM8XX SoC. diff --git a/drivers/pinctrl/nuvoton/Makefile b/drivers/pinctrl/nuvoton/Makefile new file mode 100644 index 0000000000..a6dfdf3672 --- /dev/null +++ b/drivers/pinctrl/nuvoton/Makefile @@ -0,0 +1 @@ +obj-$(CONFIG_PINCTRL_NPCM8XX) += pinctrl-npcm8xx.o diff --git a/drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c b/drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c new file mode 100644 index 0000000000..4531923cff --- /dev/null +++ b/drivers/pinctrl/nuvoton/pinctrl-npcm8xx.c @@ -0,0 +1,1163 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2022 Nuvoton Technology Corp. + */ + +#include <dm.h> +#include <errno.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <dm/device_compat.h> +#include <dm/pinctrl.h> +#include <linux/bitfield.h> +#include <asm/arch/rst.h> + +/* GCR register offsets */ +#define WD0RCR 0x38 +#define WD1RCR 0x3C +#define WD2RCR 0x40 +#define SWRSTC1 0x44 +#define SWRSTC2 0x48 +#define SWRSTC3 0x4C +#define SWRSTC4 0x50 +#define CORSTC 0x5C +#define FLOCKR1 0x74 +#define INTCR4 0xC0 +#define I2CSEGSEL 0xE0 +#define MFSEL1 0x260 +#define MFSEL2 0x264 +#define MFSEL3 0x268 +#define MFSEL4 0x26C +#define MFSEL5 0x270 +#define MFSEL6 0x274 +#define MFSEL7 0x278 + +/* GPIO register offsets */ +#define GPIO_POL 0x08 /* Polarity */ +#define GPIO_DOUT 0x0c /* Data OUT */ +#define GPIO_OTYP 0x14 /* Output Type */ +#define GPIO_PU 0x1c /* Pull-up */ +#define GPIO_PD 0x20 /* Pull-down */ +#define GPIO_DBNC 0x24 /* Debounce */ +#define GPIO_EVEN 0x40 /* Event Enable */ +#define GPIO_EVST 0x4c /* Event Status */ +#define GPIO_IEM 0x58 /* Input Enable */ +#define GPIO_OSRC 0x5c /* Output Slew-Rate Control */ +#define GPIO_ODSC 0x60 /* Output Drive Strength Control */ +#define GPIO_OES 0x70 /* Output Enable Set */ +#define GPIO_OEC 0x74 /* Output Enable Clear */ + +#define NPCM8XX_GPIO_PER_BANK 32 +#define GPIOX_OFFSET 16 + +/* The lists contain alternate GPIO pins of the function */ +/* Serial Interfaces */ +static const unsigned int hsi1a_pins[] = { 43, 63 }; +static const unsigned int hsi1b_pins[] = { 44, 62 }; +static const unsigned int hsi1c_pins[] = { 45, 46, 47, 61 }; +static const unsigned int hsi2a_pins[] = { 48, 49 }; +static const unsigned int hsi2b_pins[] = { 50, 51 }; +static const unsigned int hsi2c_pins[] = { 52, 53, 54, 55 }; +static const unsigned int bmcuart0a_pins[] = { 41, 42 }; +static const unsigned int bmcuart0b_pins[] = { 48, 49 }; +static const unsigned int bmcuart1_pins[] = { 43, 63 }; +static const unsigned int nbu1crts_pins[] = { 44, 62 }; +static const unsigned int bu2_pins[] = { 96, 97}; +static const unsigned int bu4_pins[] = { 54, 55 }; +static const unsigned int bu4b_pins[] = { 98, 99 }; +static const unsigned int bu5_pins[] = { 52, 53 }; +static const unsigned int bu5b_pins[] = { 100, 101 }; +static const unsigned int bu6_pins[] = { 50, 51 }; + +/* SPI/FIU/FLM */ +static const unsigned int spi0cs1_pins[] = { 32 }; +static const unsigned int spi1_pins[] = { 175, 176, 177, 203 }; +static const unsigned int spi1cs1_pins[] = { 233 }; +static const unsigned int spi1d23_pins[] = { 191, 192 }; +static const unsigned int spi1cs2_pins[] = { 191 }; +static const unsigned int spi1cs3_pins[] = { 192 }; +static const unsigned int spi3_pins[] = { 183, 184, 185, 186 }; +static const unsigned int spi3cs1_pins[] = { 187 }; +static const unsigned int spi3quad_pins[] = { 188, 189 }; +static const unsigned int spi3cs2_pins[] = { 188 }; +static const unsigned int spi3cs3_pins[] = { 189 }; +static const unsigned int spix_pins[] = { 224, 225, 226, 227, 229, 230 }; +static const unsigned int spixcs1_pins[] = { 228 }; +static const unsigned int pspi_pins[] = { 17, 18, 19 }; +static const unsigned int fm2_pins[] = { 224, 225, 226, 227, 228, 229, 230 }; +static const unsigned int fm1_pins[] = { 175, 176, 177, 203, 191, 192, 233 }; +static const unsigned int fm0_pins[] = { 194, 195, 196, 202, 199, 198, 197 }; + +/* I2C */ +static const unsigned int smb0_pins[] = { 115, 114 }; +static const unsigned int smb0b_pins[] = { 195, 194 }; +static const unsigned int smb0c_pins[] = { 202, 196 }; +static const unsigned int smb0d_pins[] = { 198, 199 }; +static const unsigned int smb0den_pins[] = { 197 }; +static const unsigned int smb1_pins[] = { 117, 116 }; +static const unsigned int smb1b_pins[] = { 126, 127 }; +static const unsigned int smb1c_pins[] = { 124, 125 }; +static const unsigned int smb1d_pins[] = { 4, 5 }; +static const unsigned int smb2_pins[] = { 119, 118 }; +static const unsigned int smb2b_pins[] = { 122, 123 }; +static const unsigned int smb2c_pins[] = { 120, 121 }; +static const unsigned int smb2d_pins[] = { 6, 7 }; +static const unsigned int smb3_pins[] = { 30, 31 }; +static const unsigned int smb3b_pins[] = { 39, 40 }; +static const unsigned int smb3c_pins[] = { 37, 38 }; +static const unsigned int smb3d_pins[] = { 59, 60 }; +static const unsigned int smb4_pins[] = { 28, 29 }; +static const unsigned int smb4b_pins[] = { 18, 19 }; +static const unsigned int smb4c_pins[] = { 20, 21 }; +static const unsigned int smb4d_pins[] = { 22, 23 }; +static const unsigned int smb5_pins[] = { 26, 27 }; +static const unsigned int smb5b_pins[] = { 13, 12 }; +static const unsigned int smb5c_pins[] = { 15, 14 }; +static const unsigned int smb5d_pins[] = { 94, 93 }; +static const unsigned int smb6_pins[] = { 172, 171 }; +static const unsigned int smb6b_pins[] = { 2, 3 }; +static const unsigned int smb6c_pins[] = { 0, 1 }; +static const unsigned int smb6d_pins[] = { 10, 11 }; +static const unsigned int smb7_pins[] = { 174, 173 }; +static const unsigned int smb7b_pins[] = { 16, 141 }; +static const unsigned int smb7c_pins[] = { 24, 25 }; +static const unsigned int smb7d_pins[] = { 142, 143 }; +static const unsigned int smb8_pins[] = { 129, 128 }; +static const unsigned int smb9_pins[] = { 131, 130 }; +static const unsigned int smb10_pins[] = { 133, 132 }; +static const unsigned int smb11_pins[] = { 135, 134 }; +static const unsigned int smb12_pins[] = { 221, 220 }; +static const unsigned int smb13_pins[] = { 223, 222 }; +static const unsigned int smb14_pins[] = { 22, 23 }; +static const unsigned int smb14b_pins[] = { 32, 187 }; +static const unsigned int smb15_pins[] = { 20, 21 }; +static const unsigned int smb15b_pins[] = { 192, 191 }; +static const unsigned int smb16_pins[] = { 10, 11 }; +static const unsigned int smb16b_pins[] = { 218, 219 }; +static const unsigned int smb17_pins[] = { 3, 2 }; +static const unsigned int smb18_pins[] = { 0, 1 }; +static const unsigned int smb19_pins[] = { 60, 59 }; +static const unsigned int smb20_pins[] = { 234, 235 }; +static const unsigned int smb21_pins[] = { 169, 170 }; +static const unsigned int smb22_pins[] = { 40, 39 }; +static const unsigned int smb23_pins[] = { 38, 37 }; +static const unsigned int smb23b_pins[] = { 134, 134 }; + +/* I3C */ +static const unsigned int i3c5_pins[] = { 106, 107 }; +static const unsigned int i3c4_pins[] = { 33, 34 }; +static const unsigned int i3c3_pins[] = { 246, 247 }; +static const unsigned int i3c2_pins[] = { 244, 245 }; +static const unsigned int i3c1_pins[] = { 242, 243 }; +static const unsigned int i3c0_pins[] = { 240, 241 }; + +/* Fan/PWM */ +static const unsigned int fanin0_pins[] = { 64 }; +static const unsigned int fanin1_pins[] = { 65 }; +static const unsigned int fanin2_pins[] = { 66 }; +static const unsigned int fanin3_pins[] = { 67 }; +static const unsigned int fanin4_pins[] = { 68 }; +static const unsigned int fanin5_pins[] = { 69 }; +static const unsigned int fanin6_pins[] = { 70 }; +static const unsigned int fanin7_pins[] = { 71 }; +static const unsigned int fanin8_pins[] = { 72 }; +static const unsigned int fanin9_pins[] = { 73 }; +static const unsigned int fanin10_pins[] = { 74 }; +static const unsigned int fanin11_pins[] = { 75 }; +static const unsigned int fanin12_pins[] = { 76 }; +static const unsigned int fanin13_pins[] = { 77 }; +static const unsigned int fanin14_pins[] = { 78 }; +static const unsigned int fanin15_pins[] = { 79 }; +static const unsigned int faninx_pins[] = { 175, 176, 177, 203 }; +static const unsigned int pwm0_pins[] = { 80 }; +static const unsigned int pwm1_pins[] = { 81 }; +static const unsigned int pwm2_pins[] = { 82 }; +static const unsigned int pwm3_pins[] = { 83 }; +static const unsigned int pwm4_pins[] = { 144 }; +static const unsigned int pwm5_pins[] = { 145 }; +static const unsigned int pwm6_pins[] = { 146 }; +static const unsigned int pwm7_pins[] = { 147 }; +static const unsigned int pwm8_pins[] = { 220 }; +static const unsigned int pwm9_pins[] = { 221 }; +static const unsigned int pwm10_pins[] = { 234 }; +static const unsigned int pwm11_pins[] = { 235 }; + +/* Network */ +static const unsigned int rg1mdio_pins[] = { 108, 109 }; /* SGMII1 */ +static const unsigned int rg2_pins[] = { 110, 111, 112, 113, 208, 209, 210, 211, 212, + 213, 214, 215 }; /* RGMII2 */ +static const unsigned int rg2mdio_pins[] = { 216, 217 }; +static const unsigned int rg2refck_pins[] = { 250 }; +static const unsigned int r1_pins[] = { 178, 179, 180, 181, 182, 193, 201 }; /* RMII1 */ +static const unsigned int r1err_pins[] = { 56 }; +static const unsigned int r1oen_pins[] = { 56 }; +static const unsigned int r1md_pins[] = { 57, 58 }; +static const unsigned int r1en_pins[] = { }; +static const unsigned int r2_pins[] = { 84, 85, 86, 87, 88, 89, 200 }; /* RMII2 */ +static const unsigned int r2md_pins[] = { 91, 92 }; +static const unsigned int r2err_pins[] = { 90 }; +static const unsigned int r2oen_pins[] = { 90 }; +static const unsigned int r2en_pins[] = { }; +static const unsigned int rmii3_pins[] = { 110, 111, 209, 210, 211, 214, 215 }; +static const unsigned int r3rxer_pins[] = { 212 }; +static const unsigned int r3oen_pins[] = { 213 }; +static const unsigned int r3en_pins[] = { }; + +/* MMC */ +static const unsigned int mmc_pins[] = { 152, 154, 156, 157, 158, 159 }; +static const unsigned int mmc8_pins[] = { 148, 149, 150, 151 }; +static const unsigned int mmcwp_pins[] = { 153 }; +static const unsigned int mmccd_pins[] = { 155 }; +static const unsigned int mmcrst_pins[] = { 155 }; + +/* JTAG */ +static const unsigned int jtag2_pins[] = { 43, 44, 45, 46, 47 }; +static const unsigned int j2j3_pins[] = { 44, 62, 45, 46 }; +static const unsigned int jm1_pins[] = { 136, 137, 138, 139, 140 }; +static const unsigned int jm2_pins[] = { 248 }; + +/* Serial I/O Expander*/ +static const unsigned int iox1_pins[] = { 0, 1, 2, 3 }; +static const unsigned int iox2_pins[] = { 4, 5, 6, 7 }; +static const unsigned int ioxh_pins[] = { 10, 11, 24, 25 }; + +/* LPC/eSPI */ +static const unsigned int lpc_pins[] = { 95, 161, 163, 164, 165, 166, 167 }; +static const unsigned int espi_pins[] = { 95, 161, 163, 164, 165, 166, 167, 168 }; +static const unsigned int clkrun_pins[] = { 162 }; +static const unsigned int serirq_pins[] = { 168 }; +static const unsigned int nprd_smi_pins[] = { 190 }; +static const unsigned int scipme_pins[] = { 169 }; +static const unsigned int sci_pins[] = { 170 }; + +/* VGA */ +static const unsigned int vgadig_pins[] = { 102, 103, 104, 105 }; +static const unsigned int gspi_pins[] = { 12, 13, 14, 15 }; + +/* PCIe */ +static const unsigned int clkreq_pins[] = { 231 }; + +/* MISC */ +static const unsigned int ga20kbc_pins[] = { 94, 93 }; +static const unsigned int clkout_pins[] = { 160 }; +static const unsigned int wdog1_pins[] = { 218 }; +static const unsigned int wdog2_pins[] = { 219 }; +static const unsigned int ddr_pins[] = { 110, 111, 112, 113, 208, 209, 210, 211, 212, + 213, 214, 215, 216, 217, 250 }; + +/* TIP/COP */ +static const unsigned int tp_gpio7_pins[] = { 96 }; +static const unsigned int tp_gpio6_pins[] = { 97 }; +static const unsigned int tp_gpio5_pins[] = { 98 }; +static const unsigned int tp_gpio4_pins[] = { 99 }; +static const unsigned int tp_gpio3_pins[] = { 100 }; +static const unsigned int tp_gpio2_pins[] = { 16 }; +static const unsigned int tp_gpio1_pins[] = { 9 }; +static const unsigned int tp_gpio0_pins[] = { 8 }; +static const unsigned int tp_gpio5b_pins[] = { 58 }; +static const unsigned int tp_gpio4b_pins[] = { 57 }; +static const unsigned int tp_gpio2b_pins[] = { 101 }; +static const unsigned int tp_gpio1b_pins[] = { 92 }; +static const unsigned int tp_gpio0b_pins[] = { 91 }; +static const unsigned int tp_uart_pins[] = { 50, 51 }; +static const unsigned int tp_smb2_pins[] = { 24, 25 }; +static const unsigned int tp_smb1_pins[] = { 142, 143 }; +static const unsigned int tp_jtag3_pins[] = { 44, 62, 45, 46 }; +static const unsigned int cp1gpio2c_pins[] = { 101 }; +static const unsigned int cp1gpio3c_pins[] = { 100 }; +static const unsigned int cp1gpio0b_pins[] = { 127 }; +static const unsigned int cp1gpio1b_pins[] = { 126 }; +static const unsigned int cp1gpio2b_pins[] = { 125 }; +static const unsigned int cp1gpio3b_pins[] = { 124 }; +static const unsigned int cp1gpio4b_pins[] = { 99 }; +static const unsigned int cp1gpio5b_pins[] = { 98 }; +static const unsigned int cp1gpio6b_pins[] = { 97 }; +static const unsigned int cp1gpio7b_pins[] = { 96 }; +static const unsigned int cp1gpio0_pins[] = { }; +static const unsigned int cp1gpio1_pins[] = { }; +static const unsigned int cp1gpio2_pins[] = { }; +static const unsigned int cp1gpio3_pins[] = { }; +static const unsigned int cp1gpio4_pins[] = { }; +static const unsigned int cp1gpio5_pins[] = { 17 }; +static const unsigned int cp1gpio6_pins[] = { 91 }; +static const unsigned int cp1gpio7_pins[] = { 92 }; +static const unsigned int cp1utxd_pins[] = { 42 }; +static const unsigned int cp1urxd_pins[] = { 41 }; + +/* General IO */ +static const unsigned int gpi35_pins[] = { 35 }; +static const unsigned int gpi36_pins[] = { 36 }; +static const unsigned int gpio1836_pins[] = { 183, 184, 185, 186 }; +static const unsigned int gpio1889_pins[] = { 188, 189 }; +static const unsigned int gpio187_pins[] = { 187 }; +static const unsigned int lkgpo0_pins[] = { 16 }; +static const unsigned int lkgpo1_pins[] = { 8 }; +static const unsigned int lkgpo2_pins[] = { 9 }; +static const unsigned int hgpio0_pins[] = { 20 }; +static const unsigned int hgpio1_pins[] = { 21 }; +static const unsigned int hgpio2_pins[] = { 22 }; +static const unsigned int hgpio3_pins[] = { 23 }; +static const unsigned int hgpio4_pins[] = { 24 }; +static const unsigned int hgpio5_pins[] = { 25 }; +static const unsigned int hgpio6_pins[] = { 59 }; +static const unsigned int hgpio7_pins[] = { 60 }; +static const unsigned int gpio_pins[] = { }; + +struct npcm8xx_pinctrl_priv { + void __iomem *gpio_base; + struct regmap *gcr_regmap; + struct regmap *rst_regmap; +}; + +struct group_config { + char *name; + const unsigned int *pins; + unsigned int npins; + u32 reg; /* Register of setting func */ + u32 bit; +}; + +#define GRP(x, _reg, _bit) { \ + .name = #x, \ + .pins = x## _pins, \ + .npins = ARRAY_SIZE(x## _pins), \ + .reg = _reg, \ + .bit = _bit, \ + } +static const struct group_config npcm8xx_groups[] = { + GRP(smb3, MFSEL1, 0), + GRP(smb4, MFSEL1, 1), + GRP(smb5, MFSEL1, 2), + GRP(spi0cs1, MFSEL1, 3), + GRP(hsi1c, MFSEL1, 4), + GRP(hsi2c, MFSEL1, 5), + GRP(smb0, MFSEL1, 6), + GRP(smb1, MFSEL1, 7), + GRP(smb2, MFSEL1, 8), + GRP(bmcuart0a, MFSEL1, 9), + GRP(hsi1a, MFSEL1, 10), + GRP(hsi2a, MFSEL1, 11), + GRP(r1err, MFSEL1, 12), + GRP(r1md, MFSEL1, 13), + GRP(r2, MFSEL1, 14), + GRP(r2err, MFSEL1, 15), + GRP(r2md, MFSEL1, 16), + GRP(ga20kbc, MFSEL1, 17), + GRP(clkout, MFSEL1, 21), + GRP(sci, MFSEL1, 22), + GRP(gspi, MFSEL1, 24), + GRP(lpc, MFSEL1, 26), + GRP(hsi1b, MFSEL1, 28), + GRP(hsi2b, MFSEL1, 29), + GRP(iox1, MFSEL1, 30), + GRP(serirq, MFSEL1, 31), + GRP(fanin0, MFSEL2, 0), + GRP(fanin1, MFSEL2, 1), + GRP(fanin2, MFSEL2, 2), + GRP(fanin3, MFSEL2, 3), + GRP(fanin4, MFSEL2, 4), + GRP(fanin5, MFSEL2, 5), + GRP(fanin6, MFSEL2, 6), + GRP(fanin7, MFSEL2, 7), + GRP(fanin8, MFSEL2, 8), + GRP(fanin9, MFSEL2, 9), + GRP(fanin10, MFSEL2, 10), + GRP(fanin11, MFSEL2, 11), + GRP(fanin12, MFSEL2, 12), + GRP(fanin13, MFSEL2, 13), + GRP(fanin14, MFSEL2, 14), + GRP(fanin15, MFSEL2, 15), + GRP(pwm0, MFSEL2, 16), + GRP(pwm1, MFSEL2, 17), + GRP(pwm2, MFSEL2, 18), + GRP(pwm3, MFSEL2, 19), + GRP(pwm4, MFSEL2, 20), + GRP(pwm5, MFSEL2, 21), + GRP(pwm6, MFSEL2, 22), + GRP(pwm7, MFSEL2, 23), + GRP(hgpio0, MFSEL2, 24), + GRP(hgpio1, MFSEL2, 25), + GRP(hgpio2, MFSEL2, 26), + GRP(hgpio3, MFSEL2, 27), + GRP(hgpio4, MFSEL2, 28), + GRP(hgpio5, MFSEL2, 29), + GRP(hgpio6, MFSEL2, 30), + GRP(hgpio7, MFSEL2, 31), + GRP(scipme, MFSEL3, 0), + GRP(smb6, MFSEL3, 1), + GRP(smb7, MFSEL3, 2), + GRP(faninx, MFSEL3, 3), + GRP(spi1, MFSEL3, 4), + GRP(smb12, MFSEL3, 5), + GRP(smb13, MFSEL3, 6), + GRP(smb14, MFSEL3, 7), + GRP(smb15, MFSEL3, 8), + GRP(r1, MFSEL3, 9), + GRP(mmc, MFSEL3, 10), + GRP(mmc8, MFSEL3, 11), + GRP(pspi, MFSEL3, 13), + GRP(iox2, MFSEL3, 14), + GRP(clkrun, MFSEL3, 16), + GRP(ioxh, MFSEL3, 18), + GRP(wdog1, MFSEL3, 19), + GRP(wdog2, MFSEL3, 20), + GRP(i3c5, MFSEL3, 22), + GRP(bmcuart1, MFSEL3, 24), + GRP(mmccd, MFSEL3, 25), + GRP(ddr, MFSEL3, 26), + GRP(jtag2, MFSEL4, 0), + GRP(bmcuart0b, MFSEL4, 1), + GRP(mmcrst, MFSEL4, 6), + GRP(espi, MFSEL4, 8), + GRP(clkreq, MFSEL4, 9), + GRP(smb8, MFSEL4, 11), + GRP(smb9, MFSEL4, 12), + GRP(smb10, MFSEL4, 13), + GRP(smb11, MFSEL4, 14), + GRP(spi3, MFSEL4, 16), + GRP(spi3cs1, MFSEL4, 17), + GRP(spi3cs2, MFSEL4, 18), + GRP(spi3cs3, MFSEL4, 19), + GRP(spi3quad, MFSEL4, 20), + GRP(rg1mdio, MFSEL4, 21), + GRP(bu2, MFSEL4, 22), + GRP(rg2mdio, MFSEL4, 23), + GRP(rg2, MFSEL4, 24), + GRP(spix, MFSEL4, 27), + GRP(spixcs1, MFSEL4, 28), + GRP(spi1cs1, MFSEL5, 0), + GRP(jm2, MFSEL5, 1), + GRP(j2j3, MFSEL5, 2), + GRP(spi1d23, MFSEL5, 3), + GRP(spi1cs2, MFSEL5, 4), + GRP(spi1cs3, MFSEL5, 5), + GRP(bu6, MFSEL5, 6), + GRP(bu5, MFSEL5, 7), + GRP(bu4, MFSEL5, 8), + GRP(r1oen, MFSEL5, 9), + GRP(r2oen, MFSEL5, 10), + GRP(rmii3, MFSEL5, 11), + GRP(bu5b, MFSEL5, 12), + GRP(bu4b, MFSEL5, 13), + GRP(r3oen, MFSEL5, 14), + GRP(jm1, MFSEL5, 15), + GRP(gpi35, MFSEL5, 16), + GRP(i3c0, MFSEL5, 17), + GRP(gpi36, MFSEL5, 18), + GRP(i3c1, MFSEL5, 19), + GRP(tp_gpio4b, MFSEL5, 20), + GRP(i3c2, MFSEL5, 21), + GRP(tp_gpio5b, MFSEL5, 22), + GRP(i3c3, MFSEL5, 23), + GRP(smb16, MFSEL5, 24), + GRP(smb17, MFSEL5, 25), + GRP(smb18, MFSEL5, 26), + GRP(smb19, MFSEL5, 27), + GRP(smb20, MFSEL5, 28), + GRP(smb21, MFSEL5, 29), + GRP(smb22, MFSEL5, 30), + GRP(smb23, MFSEL5, 31), + GRP(smb23b, MFSEL6, 0), + GRP(cp1utxd, MFSEL6, 1), + GRP(cp1gpio0, MFSEL6, 2), + GRP(cp1gpio1, MFSEL6, 3), + GRP(cp1gpio2, MFSEL6, 4), + GRP(cp1gpio3, MFSEL6, 5), + GRP(cp1gpio4, MFSEL6, 6), + GRP(cp1gpio5, MFSEL6, 7), + GRP(cp1gpio6, MFSEL6, 8), + GRP(cp1gpio7, MFSEL6, 9), + GRP(i3c4, MFSEL6, 10), + GRP(pwm8, MFSEL6, 11), + GRP(pwm9, MFSEL6, 12), + GRP(pwm10, MFSEL6, 13), + GRP(pwm11, MFSEL6, 14), + GRP(nbu1crts, MFSEL6, 15), + GRP(fm0, MFSEL6, 16), + GRP(fm1, MFSEL6, 17), + GRP(fm2, MFSEL6, 18), + GRP(gpio1836, MFSEL6, 19), + GRP(cp1gpio0b, MFSEL6, 20), + GRP(cp1gpio1b, MFSEL6, 21), + GRP(cp1gpio2b, MFSEL6, 22), + GRP(cp1gpio3b, MFSEL6, 23), + GRP(cp1gpio7b, MFSEL6, 24), + GRP(cp1gpio6b, MFSEL6, 25), + GRP(cp1gpio5b, MFSEL6, 26), + GRP(cp1gpio4b, MFSEL6, 27), + GRP(cp1gpio3c, MFSEL6, 28), + GRP(cp1gpio2c, MFSEL6, 29), + GRP(r3rxer, MFSEL6, 30), + GRP(cp1urxd, MFSEL6, 31), + GRP(tp_gpio0, MFSEL7, 0), + GRP(tp_gpio1, MFSEL7, 1), + GRP(tp_gpio2, MFSEL7, 2), + GRP(tp_gpio3, MFSEL7, 3), + GRP(tp_gpio4, MFSEL7, 4), + GRP(tp_gpio5, MFSEL7, 5), + GRP(tp_gpio6, MFSEL7, 6), + GRP(tp_gpio7, MFSEL7, 7), + GRP(tp_gpio0b, MFSEL7, 8), + GRP(tp_gpio1b, MFSEL7, 9), + GRP(tp_gpio2b, MFSEL7, 10), + GRP(tp_smb1, MFSEL7, 11), + GRP(tp_uart, MFSEL7, 12), + GRP(tp_jtag3, MFSEL7, 13), + GRP(gpio187, MFSEL7, 24), + GRP(gpio1889, MFSEL7, 25), + GRP(smb14b, MFSEL7, 26), + GRP(smb15b, MFSEL7, 27), + GRP(tp_smb2, MFSEL7, 28), + GRP(vgadig, MFSEL7, 29), + GRP(smb16b, MFSEL7, 30), + GRP(smb0b, I2CSEGSEL, 0), + GRP(smb0c, I2CSEGSEL, 1), + GRP(smb0d, I2CSEGSEL, 2), + GRP(smb1b, I2CSEGSEL, 5), + GRP(smb1c, I2CSEGSEL, 6), + GRP(smb1d, I2CSEGSEL, 7), + GRP(smb2b, I2CSEGSEL, 8), + GRP(smb2c, I2CSEGSEL, 9), + GRP(smb2d, I2CSEGSEL, 10), + GRP(smb3b, I2CSEGSEL, 11), + GRP(smb3c, I2CSEGSEL, 12), + GRP(smb3d, I2CSEGSEL, 13), + GRP(smb4b, I2CSEGSEL, 14), + GRP(smb4c, I2CSEGSEL, 15), + GRP(smb4d, I2CSEGSEL, 16), + GRP(smb5b, I2CSEGSEL, 19), + GRP(smb5c, I2CSEGSEL, 20), + GRP(smb5d, I2CSEGSEL, 21), + GRP(smb0den, I2CSEGSEL, 22), + GRP(smb6b, I2CSEGSEL, 24), + GRP(smb6c, I2CSEGSEL, 25), + GRP(smb6d, I2CSEGSEL, 26), + GRP(smb7b, I2CSEGSEL, 27), + GRP(smb7c, I2CSEGSEL, 28), + GRP(smb7d, I2CSEGSEL, 29), + GRP(lkgpo0, FLOCKR1, 0), + GRP(lkgpo1, FLOCKR1, 4), + GRP(lkgpo2, FLOCKR1, 8), + GRP(nprd_smi, FLOCKR1, 20), + GRP(mmcwp, FLOCKR1, 24), + GRP(rg2refck, INTCR4, 6), + GRP(r1en, INTCR4, 12), + GRP(r2en, INTCR4, 13), + GRP(r3en, INTCR4, 14), + GRP(gpio, 0, 0), +}; + +/* Pin flags */ +#define SLEW BIT(0) /* Has Slew Control */ +#define DSLO_MASK GENMASK(11, 8) /* Drive strength */ +#define DSHI_MASK GENMASK(15, 12) +#define DS(lo, hi) (((lo) << 8) | ((hi) << 12)) +#define DSLO(x) FIELD_GET(DSLO_MASK, x) /* Low DS value */ +#define DSHI(x) FIELD_GET(DSHI_MASK, x) /* High DS value */ + +#define MAX_ALT_FUNCS 5 /* Max alternate functions */ +struct pin_info { + int gpio_num; + char *name; + char *alt_func[MAX_ALT_FUNCS]; + int num_funcs; + u32 flags; +}; + +static const struct pin_info npcm8xx_pins[] = { + {0, "gpio0", {"iox1", "smb6c", "smb18"}, 3, SLEW}, + {1, "gpio1", {"iox1", "smb6c", "smb18"}, 3, SLEW}, + {2, "gpio2", {"iox1", "smb6b", "smb17"}, 3, SLEW}, + {3, "gpio3", {"iox1", "smb6b", "smb17"}, 3, SLEW}, + {4, "gpio4", {"iox2", "smb1d"}, 2, SLEW}, + {5, "gpio5", {"iox2", "smb1d"}, 2, SLEW}, + {6, "gpio6", {"iox2", "smb2d"}, 2, SLEW}, + {7, "gpio7", {"iox2", "smb2d"}, 2, SLEW}, + {8, "gpio8", {"lkgpo1", "tp_gpio0b"}, 2, DS(8, 12)}, + {9, "gpio9", {"lkgpo2", "tp_gpio1b"}, 2, DS(8, 12)}, + {10, "gpio10", {"ioxh", "smb6d", "smb16"}, 3, SLEW}, + {11, "gpio11", {"ioxh", "smb6d", "smb16"}, 3, SLEW}, + {12, "gpio12", {"gspi", "smb5d"}, 2, SLEW}, + {13, "gpio13", {"gspi", "smb5d"}, 2, SLEW}, + {14, "gpio14", {"gspi", "smb5c"}, 2, SLEW}, + {15, "gpio15", {"gspi", "smb5c"}, 2, SLEW}, + {16, "gpio16", {"lkgpo0", "smb7b", "tp_gpio2b"}, 3, SLEW}, + {17, "gpio17", {"pspi", "cp1gpio5"}, 2, SLEW}, + {18, "gpio18", {"pspi", "smb4b"}, 2, SLEW}, + {19, "gpio19", {"pspi", "smb4b"}, 2, SLEW}, + {20, "gpio20", {"hgpio0", "smb15", "smb4c"}, 3, SLEW}, + {21, "gpio21", {"hgpio1", "smb15", "smb4c"}, 3, SLEW}, + {22, "gpio22", {"hgpio2", "smb14", "smb4d"}, 3, SLEW}, + {23, "gpio23", {"hgpio3", "smb14", "smb4d"}, 3, SLEW}, + {24, "gpio24", {"hgpio4", "ioxh", "smb7c", "tp_smb2"}, 4, SLEW}, + {25, "gpio25", {"hgpio5", "ioxh", "smb7c"}, 3, SLEW}, + {26, "gpio26", {"smb5"}, 1, 0}, + {27, "gpio27", {"smb5"}, 1, 0}, + {28, "gpio28", {"smb4"}, 1, 0}, + {29, "gpio29", {"smb4"}, 1, 0}, + {30, "gpio30", {"smb3"}, 1, 0}, + {31, "gpio31", {"smb3"}, 1, 0}, + {32, "gpio32", {"smb14b", "spi0cs1"}, 2, SLEW}, + {33, "gpio33", {"i3c4"}, 1, SLEW}, + {34, "gpio34", {"i3c4"}, 1, SLEW}, + {35, "gpio35", {"gpi35"}, 1, 0}, + {36, "gpio36", {"gpi36"}, 1, 0}, + {37, "gpio37", {"smb3c", "smb23"}, 2, SLEW}, + {38, "gpio38", {"smb3c", "smb23"}, 2, SLEW}, + {39, "gpio39", {"smb3b", "smb22"}, 2, SLEW}, + {40, "gpio40", {"smb3b", "smb22"}, 2, SLEW}, + {41, "gpio41", {"bmcuart0a", "cp1urxd"}, 2, 0}, + {42, "gpio42", {"bmcuart0a", "cp1utxd"}, 2, DS(2, 4)}, + {43, "gpio43", {"hsi1a", "bmcuart1"}, 2, 0}, + {44, "gpio44", {"hsi1b", "nbu1crts", "jtag2", "tp_jtag3", "j2j3"}, 5, 0}, + {45, "gpio45", {"hsi1c", "jtag2", "j2j3", "tp_jtag3"}, 4, DS(2, 8)}, + {46, "gpio46", {"hsi1c", "jtag2", "j2j3", "tp_jtag3"}, 4, 0}, + {47, "gpio47", {"hsi1c",}, 1, DS(2, 8)}, + {48, "gpio48", {"hsi2a", "bmcuart0b"}, 2, 0}, + {49, "gpio49", {"hsi2a", "bmcuart0b"}, 2, 0}, + {50, "gpio50", {"hsi2b", "bu6", "tp_uart"}, 3, 0}, + {51, "gpio51", {"hsi2b", "bu6", "tp_uart"}, 3, 0}, + {52, "gpio52", {"hsi2c", "bu5"}, 2, 0}, + {53, "gpio53", {"hsi2c", "bu5"}, 2, 0}, + {54, "gpio54", {"hsi2c", "bu4"}, 2, 0}, + {55, "gpio55", {"hsi2c", "bu4"}, 2, 0}, + {56, "gpio56", {"r1err", "r1oen"}, 2, 0}, + {57, "gpio57", {"r1md", "tp_gpio4b"}, 2, DS(2, 4)}, + {58, "gpio58", {"r1md", "tp_gpio5b"}, 2, DS(2, 4)}, + {59, "gpio59", {"hgpio6", "smb3d", "smb19"}, 3, 0}, + {60, "gpio60", {"hgpio7", "smb3d", "smb19"}, 3, 0}, + {61, "gpio61", {"hsi1c"}, 1, 0}, + {62, "gpio62", {"hsi1b", "jtag2", "j2j3", "nbu1crts", "tp_jtag3"}, 5, 0}, + {63, "gpio63", {"hsi1a", "bmcuart1"}, 2, 0}, + {64, "gpio64", {"fanin0"}, 1, 0}, + {65, "gpio65", {"fanin1"}, 1, 0}, + {66, "gpio66", {"fanin2"}, 1, 0}, + {67, "gpio67", {"fanin3"}, 1, 0}, + {68, "gpio68", {"fanin4"}, 1, 0}, + {69, "gpio69", {"fanin5"}, 1, 0}, + {70, "gpio70", {"fanin6"}, 1, 0}, + {71, "gpio71", {"fanin7"}, 1, 0}, + {72, "gpio72", {"fanin8"}, 1, 0}, + {73, "gpio73", {"fanin9"}, 1, 0}, + {74, "gpio74", {"fanin10"}, 1, 0}, + {75, "gpio75", {"fanin11"}, 1, 0}, + {76, "gpio76", {"fanin12"}, 1, 0}, + {77, "gpio77", {"fanin13"}, 1, 0}, + {78, "gpio78", {"fanin14"}, 1, 0}, + {79, "gpio79", {"fanin15"}, 1, 0}, + {80, "gpio80", {"pwm0"}, 1, DS(4, 8)}, + {81, "gpio81", {"pwm1"}, 1, DS(4, 8)}, + {82, "gpio82", {"pwm2"}, 1, DS(4, 8)}, + {83, "gpio83", {"pwm3"}, 1, DS(4, 8)}, + {84, "gpio84", {"r2"}, 1, DS(4, 8) | SLEW}, + {85, "gpio85", {"r2"}, 1, DS(4, 8) | SLEW}, + {86, "gpio86", {"r2"}, 1, DS(4, 8) | SLEW}, + {87, "gpio87", {"r2"}, 1, 0}, + {88, "gpio88", {"r2"}, 1, 0}, + {89, "gpio89", {"r2"}, 1, 0}, + {90, "gpio90", {"r2err", "r2oen"}, 2, 0}, + {91, "gpio91", {"r2md", "cp1gpio6", "tp_gpio0"}, 3, DS(2, 4)}, + {92, "gpio92", {"r2md", "cp1gpio7", "tp_gpio1"}, 3, DS(2, 4)}, + {93, "gpio93", {"ga20kbc", "smb5d"}, 2, 0}, + {94, "gpio94", {"ga20kbc", "smb5d"}, 2, 0}, + {95, "gpio95", {"lpc", "espi"}, 2, 0}, + {96, "gpio96", {"cp1gpio7b", "bu2", "tp_gpio7"}, 3, SLEW}, + {97, "gpio97", {"cp1gpio6b", "bu2", "tp_gpio6"}, 3, SLEW}, + {98, "gpio98", {"bu4b", "cp1gpio5b", "tp_gpio5"}, 3, SLEW}, + {99, "gpio99", {"bu4b", "cp1gpio4b", "tp_gpio4"}, 3, SLEW}, + {100, "gpio100", {"bu5b", "cp1gpio3c", "tp_gpio3"}, 3, SLEW}, + {101, "gpio101", {"bu5b", "cp1gpio2c", "tp_gpio2"}, 3, SLEW}, + {102, "gpio102", {"vgadig"}, 1, DS(4, 8)}, + {103, "gpio103", {"vgadig"}, 1, DS(4, 8)}, + {104, "gpio104", {"vgadig"}, 1, 0}, + {105, "gpio105", {"vgadig"}, 1, 0}, + {106, "gpio106", {"i3c5"}, 1, SLEW}, + {107, "gpio107", {"i3c5"}, 1, SLEW}, + {108, "gpio108", {"rg1mdio"}, 1, 0}, + {109, "gpio109", {"rg1mdio"}, 1, 0}, + {110, "gpio110", {"rg2", "ddr", "rmii3"}, 3, 0}, + {111, "gpio111", {"rg2", "ddr", "rmii3"}, 3, 0}, + {112, "gpio112", {"rg2", "ddr"}, 2, 0}, + {113, "gpio113", {"rg2", "ddr"}, 2, 0}, + {114, "gpio114", {"smb0"}, 1, 0}, + {115, "gpio115", {"smb0"}, 1, 0}, + {116, "gpio116", {"smb1"}, 1, 0}, + {117, "gpio117", {"smb1"}, 1, 0}, + {118, "gpio118", {"smb2"}, 1, 0}, + {119, "gpio119", {"smb2"}, 1, 0}, + {120, "gpio120", {"smb2c"}, 1, SLEW}, + {121, "gpio121", {"smb2c"}, 1, SLEW}, + {122, "gpio122", {"smb2b"}, 1, SLEW}, + {123, "gpio123", {"smb2b"}, 1, SLEW}, + {124, "gpio124", {"smb1c", "cp1gpio3b"}, 2, SLEW}, + {125, "gpio125", {"smb1c", "cp1gpio2b"}, 2, SLEW}, + {126, "gpio126", {"smb1b", "cp1gpio1b"}, 2, SLEW}, + {127, "gpio127", {"smb1b", "cp1gpio0b"}, 2, SLEW}, + {128, "gpio128", {"smb8"}, 1, 0}, + {129, "gpio129", {"smb8"}, 1, 0}, + {130, "gpio130", {"smb9"}, 1, 0}, + {131, "gpio131", {"smb9"}, 1, 0}, + {132, "gpio132", {"smb10"}, 1, 0}, + {133, "gpio133", {"smb10"}, 1, 0}, + {134, "gpio134", {"smb11", "smb23b"}, 2, 0}, + {135, "gpio135", {"smb11", "smb23b"}, 2, 0}, + {136, "gpio136", {"jm1"}, 1, SLEW}, + {137, "gpio137", {"jm1"}, 1, SLEW}, + {138, "gpio138", {"jm1"}, 1, SLEW}, + {139, "gpio139", {"jm1"}, 1, SLEW}, + {140, "gpio140", {"jm1"}, 1, SLEW}, + {141, "gpio141", {"smb7b"}, 1, 0}, + {142, "gpio142", {"smb7d", "tp_smb1"}, 2, SLEW}, + {143, "gpio143", {"smb7d", "tp_smb1"}, 2, SLEW}, + {144, "gpio144", {"pwm4"}, 1, DS(4, 8)}, + {145, "gpio145", {"pwm5"}, 1, DS(4, 8)}, + {146, "gpio146", {"pwm6"}, 1, DS(4, 8)}, + {147, "gpio147", {"pwm7"}, 1, DS(4, 8)}, + {148, "gpio148", {"mmc8"}, 1, DS(8, 12) | SLEW}, + {149, "gpio149", {"mmc8"}, 1, DS(8, 12) | SLEW}, + {150, "gpio150", {"mmc8"}, 1, DS(8, 12) | SLEW}, + {151, "gpio151", {"mmc8"}, 1, DS(8, 12) | SLEW}, + {152, "gpio152", {"mmc"}, 1, DS(8, 12) | SLEW}, + {153, "gpio153", {"mmcwp"}, 1, 0}, + {154, "gpio154", {"mmc"}, 1, DS(8, 12) | SLEW}, + {155, "gpio155", {"mmccd", "mmcrst"}, 2, 0}, + {156, "gpio156", {"mmc"}, 1, DS(8, 12) | SLEW}, + {157, "gpio157", {"mmc"}, 1, DS(8, 12) | SLEW}, + {158, "gpio158", {"mmc"}, 1, DS(8, 12) | SLEW}, + {159, "gpio159", {"mmc"}, 1, DS(8, 12) | SLEW}, + {160, "gpio160", {"clkout"}, 1, DS(8, 12) | SLEW}, + {161, "gpio161", {"espi", "lpc"}, 2, 0}, + {162, "gpio162", {"clkrun"}, 1, DS(8, 12)}, + {163, "gpio163", {"espi", "lpc"}, 2, 0}, + {164, "gpio164", {"espi", "lpc"}, 2, 0}, + {165, "gpio165", {"espi", "lpc"}, 2, 0}, + {166, "gpio166", {"espi", "lpc"}, 2, 0}, + {167, "gpio167", {"espi", "lpc"}, 2, 0}, + {168, "gpio168", {"espi", "serirq"}, 2, 0}, + {169, "gpio169", {"scipme", "smb21"}, 2, 0}, + {170, "gpio170", {"sci", "smb21"}, 2, 0}, + {171, "gpio171", {"smb6"}, 1, 0}, + {172, "gpio172", {"smb6"}, 1, 0}, + {173, "gpio173", {"smb7"}, 1, 0}, + {174, "gpio174", {"smb7"}, 1, 0}, + {175, "gpio175", {"spi1", "faninx", "fm1"}, 3, DS(8, 12)}, + {176, "gpio176", {"spi1", "faninx", "fm1"}, 3, DS(8, 12)}, + {177, "gpio177", {"spi1", "faninx", "fm1"}, 3, DS(8, 12)}, + {178, "gpio178", {"r1"}, 1, DS(8, 12) | SLEW}, + {179, "gpio179", {"r1"}, 1, DS(8, 12) | SLEW}, + {180, "gpio180", {"r1"}, 1, DS(8, 12) | SLEW}, + {181, "gpio181", {"r1"}, 1, 0}, + {182, "gpio182", {"r1"}, 1, 0}, + {183, "gpio183", {"spi3", "gpio1836"}, 2, DS(8, 12) | SLEW}, + {184, "gpio184", {"spi3", "gpio1836"}, 2, DS(8, 12) | SLEW}, + {185, "gpio185", {"spi3", "gpio1836"}, 2, DS(8, 12) | SLEW}, + {186, "gpio186", {"spi3", "gpio1836"}, 2, DS(8, 12) | SLEW}, + {187, "gpio187", {"spi3cs1", "smb14b", "gpio187"}, 3, SLEW}, + {188, "gpio188", {"spi3quad", "spi3cs2", "gpio1889"}, 3, DS(8, 12) | SLEW}, + {189, "gpio189", {"spi3quad", "spi3cs3", "gpio1889"}, 3, DS(8, 12) | SLEW}, + {190, "gpio190", {"nprd_smi"}, 1, DS(2, 4)}, + {191, "gpio191", {"spi1d23", "spi1cs2", "fm1", "smb15"}, 4, SLEW}, + {192, "gpio192", {"spi1d23", "spi1cs3", "fm1", "smb15"}, 4, SLEW}, + {193, "gpio193", {"r1"}, 1, 0}, + {194, "gpio194", {"smb0b", "fm0"}, 2, SLEW}, + {195, "gpio195", {"smb0b", "fm0"}, 2, SLEW}, + {196, "gpio196", {"smb0c", "fm0"}, 2, SLEW}, + {197, "gpio197", {"smb0den", "fm0"}, 2, SLEW}, + {198, "gpio198", {"smb0d", "fm0"}, 2, SLEW}, + {199, "gpio199", {"smb0d", "fm0"}, 2, SLEW}, + {200, "gpio200", {"r2"}, 1, 0}, + {201, "gpio201", {"r1"}, 1, 0}, + {202, "gpio202", {"smb0c", "fm0"}, 2, SLEW}, + {203, "gpio203", {"faninx", "spi1", "fm1"}, 3, DS(8, 12)}, + {208, "gpio208", {"rg2", "ddr"}, 2, SLEW}, + {209, "gpio209", {"rg2", "ddr", "rmii3"}, 3, SLEW}, + {210, "gpio210", {"rg2", "ddr", "rmii3"}, 3, DS(8, 12) | SLEW}, + {211, "gpio211", {"rg2", "ddr", "rmii3"}, 3, DS(8, 12) | SLEW}, + {212, "gpio212", {"rg2", "ddr", "r3rxer"}, 3, DS(8, 12) | SLEW}, + {213, "gpio213", {"rg2", "ddr", "r3oen"}, 3, DS(8, 12) | SLEW}, + {214, "gpio214", {"rg2", "ddr", "rmii3"}, 3, DS(8, 12) | SLEW}, + {215, "gpio215", {"rg2", "ddr", "rmii3"}, 3, DS(8, 12) | SLEW}, + {216, "gpio216", {"rg2mdio", "ddr"}, 2, DS(8, 12) | SLEW}, + {217, "gpio217", {"rg2mdio", "ddr"}, 2, DS(8, 12) | SLEW}, + {218, "gpio218", {"wdog1", "smb16"}, 2, SLEW}, + {219, "gpio219", {"wdog2", "smb16"}, 2, SLEW}, + {220, "gpio220", {"smb12", "pwm8"}, 2, SLEW}, + {221, "gpio221", {"smb12", "pwm9"}, 2, SLEW}, + {222, "gpio222", {"smb13"}, 1, SLEW}, + {223, "gpio223", {"smb13"}, 1, SLEW}, + {224, "gpio224", {"spix", "fm2"}, 2, DS(8, 12) | SLEW}, + {225, "gpio225", {"spix", "fm2"}, 2, DS(8, 12) | SLEW}, + {226, "gpio226", {"spix", "fm2"}, 2, DS(8, 12) | SLEW}, + {227, "gpio227", {"spix", "fm2"}, 2, DS(8, 12) | SLEW}, + {228, "gpio228", {"spixcs1", "fm2"}, 2, DS(8, 12) | SLEW}, + {229, "gpio229", {"spix", "fm2"}, 2, DS(8, 12) | SLEW}, + {230, "gpio230", {"spix", "fm2"}, 2, DS(8, 12) | SLEW}, + {231, "gpio231", {"clkreq"}, 1, DS(8, 12) | SLEW}, + {233, "gpio233", {"spi1cs1", "fm1"}, 2, 0}, + {234, "gpio234", {"pwm10", "smb20"}, 2, SLEW}, + {235, "gpio235", {"pwm11", "smb20"}, 2, SLEW}, + {240, "gpio240", {"i3c0"}, 2, SLEW}, + {241, "gpio241", {"i3c0"}, 2, SLEW}, + {242, "gpio242", {"i3c1"}, 2, SLEW}, + {243, "gpio243", {"i3c1"}, 2, SLEW}, + {244, "gpio244", {"i3c2"}, 2, SLEW}, + {245, "gpio245", {"i3c2"}, 2, SLEW}, + {246, "gpio246", {"i3c3"}, 2, SLEW}, + {247, "gpio247", {"i3c3"}, 2, SLEW}, + {250, "gpio250", {"ddr", "rg2refck"}, 2, DS(8, 12) | SLEW}, +}; + +static const struct group_config *npcm8xx_group_get(const char *name) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(npcm8xx_groups); i++) { + if (!strcmp(npcm8xx_groups[i].name, name)) + return &npcm8xx_groups[i]; + } + + return NULL; +} + +static int npcm8xx_get_pin_selector(int gpio) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(npcm8xx_pins); i++) { + if (npcm8xx_pins[i].gpio_num == gpio) + return i; + } + + return -ENOENT; +} + +static int npcm8xx_group_set_func(struct udevice *dev, + const struct group_config *group, + char *func) +{ + struct npcm8xx_pinctrl_priv *priv = dev_get_priv(dev); + + dev_dbg(dev, "set_func [grp %s][func %s]\n", group->name, func); + if (strcmp(group->name, func)) + regmap_update_bits(priv->gcr_regmap, group->reg, + BIT(group->bit), 0); + else + regmap_update_bits(priv->gcr_regmap, group->reg, + BIT(group->bit), BIT(group->bit)); + + return 0; +} + +static int npcm8xx_pinmux_set(struct udevice *dev, + unsigned int pin_selector, + unsigned int func_selector) +{ + const struct pin_info *pin; + char *func = npcm8xx_groups[func_selector].name; + const struct group_config *group; + int i; + + pin = &npcm8xx_pins[pin_selector]; + dev_dbg(dev, "set_mux [pin %s][func %s]\n", pin->name, func); + + for (i = 0; i < pin->num_funcs; i++) { + group = npcm8xx_group_get(pin->alt_func[i]); + if (!group) + break; + npcm8xx_group_set_func(dev, group, func); + } + + return 0; +} + +static int npcm8xx_pinmux_group_set(struct udevice *dev, + unsigned int group_selector, + unsigned int func_selector) +{ + const struct group_config *group; + int pin_selector; + int i; + + dev_dbg(dev, "set_mux [grp %s][func %s]\n", + npcm8xx_groups[group_selector].name, + npcm8xx_groups[func_selector].name); + group = &npcm8xx_groups[group_selector]; + + if (group->npins == 0) { + /* No corresponding GPIO pins */ + npcm8xx_group_set_func(dev, group, + npcm8xx_groups[func_selector].name); + return 0; + } + + for (i = 0; i < group->npins; i++) { + pin_selector = npcm8xx_get_pin_selector(group->pins[i]); + if (pin_selector < 0) { + dev_dbg(dev, "invalid pin %d\n", group->pins[i]); + return -EINVAL; + } + npcm8xx_pinmux_set(dev, pin_selector, func_selector); + } + + return 0; +} + +static int npcm8xx_get_pins_count(struct udevice *dev) +{ + return ARRAY_SIZE(npcm8xx_pins); +} + +static const char *npcm8xx_get_pin_name(struct udevice *dev, + unsigned int selector) +{ + return npcm8xx_pins[selector].name; +} + +static int npcm8xx_get_groups_count(struct udevice *dev) +{ + return ARRAY_SIZE(npcm8xx_groups); +} + +static const char *npcm8xx_get_group_name(struct udevice *dev, + unsigned int selector) +{ + return npcm8xx_groups[selector].name; +} + +#if CONFIG_IS_ENABLED(PINCONF) +#define PIN_CONFIG_PERSIST_STATE (PIN_CONFIG_END + 1) +#define PIN_CONFIG_POLARITY_STATE (PIN_CONFIG_END + 2) +#define PIN_CONFIG_EVENT_CLEAR (PIN_CONFIG_END + 3) + +static const struct pinconf_param npcm8xx_conf_params[] = { + { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 }, + { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 }, + { "input-enable", PIN_CONFIG_INPUT_ENABLE, 1 }, + { "output-enable", PIN_CONFIG_OUTPUT_ENABLE, 1 }, + { "output-high", PIN_CONFIG_OUTPUT, 1, }, + { "output-low", PIN_CONFIG_OUTPUT, 0, }, + { "drive-open-drain", PIN_CONFIG_DRIVE_OPEN_DRAIN, 1 }, + { "drive-push-pull", PIN_CONFIG_DRIVE_PUSH_PULL, 1 }, + { "persist-enable", PIN_CONFIG_PERSIST_STATE, 1 }, + { "persist-disable", PIN_CONFIG_PERSIST_STATE, 0 }, + { "input-debounce", PIN_CONFIG_INPUT_DEBOUNCE, 0 }, + { "active-high", PIN_CONFIG_POLARITY_STATE, 0 }, + { "active-low", PIN_CONFIG_POLARITY_STATE, 1 }, + { "drive-strength", PIN_CONFIG_DRIVE_STRENGTH, 0 }, + { "slew-rate", PIN_CONFIG_SLEW_RATE, 0}, + { "event-clear", PIN_CONFIG_EVENT_CLEAR, 0}, +}; + +/* Support for retaining the state after soft reset */ +static int npcm8xx_gpio_reset_persist(struct udevice *dev, unsigned int bank, + unsigned int enable) +{ + struct npcm8xx_pinctrl_priv *priv = dev_get_priv(dev); + u8 offset = bank + GPIOX_OFFSET; + + dev_dbg(dev, "set gpio persist, bank %d, enable %d\n", bank, enable); + + if (enable) { + regmap_update_bits(priv->rst_regmap, WD0RCR, BIT(offset), 0); + regmap_update_bits(priv->rst_regmap, WD1RCR, BIT(offset), 0); + regmap_update_bits(priv->rst_regmap, WD2RCR, BIT(offset), 0); + regmap_update_bits(priv->rst_regmap, CORSTC, BIT(offset), 0); + } else { + regmap_update_bits(priv->rst_regmap, WD0RCR, BIT(offset), + BIT(offset)); + regmap_update_bits(priv->rst_regmap, WD1RCR, BIT(offset), + BIT(offset)); + regmap_update_bits(priv->rst_regmap, WD2RCR, BIT(offset), + BIT(offset)); + regmap_update_bits(priv->rst_regmap, CORSTC, BIT(offset), + BIT(offset)); + } + + return 0; +} + +static bool is_gpio_persist(struct udevice *dev, unsigned int bank) +{ + struct npcm8xx_pinctrl_priv *priv = dev_get_priv(dev); + u8 offset = bank + GPIOX_OFFSET; + u32 val; + int status; + + status = npcm_get_reset_status(); + dev_dbg(dev, "reset status: 0x%x\n", status); + + if (status & CORST) + regmap_read(priv->rst_regmap, CORSTC, &val); + else if (status & WD0RST) + regmap_read(priv->rst_regmap, WD0RCR, &val); + else if (status & WD1RST) + regmap_read(priv->rst_regmap, WD1RCR, &val); + else if (status & WD2RST) + regmap_read(priv->rst_regmap, WD2RCR, &val); + else + return false; + + return !(val & BIT(offset)); +} + +static int npcm8xx_pinconf_set(struct udevice *dev, unsigned int selector, + unsigned int param, unsigned int arg) +{ + struct npcm8xx_pinctrl_priv *priv = dev_get_priv(dev); + unsigned int pin = npcm8xx_pins[selector].gpio_num; + unsigned int bank = pin / NPCM8XX_GPIO_PER_BANK; + unsigned int gpio = (pin % NPCM8XX_GPIO_PER_BANK); + void __iomem *base = priv->gpio_base + (0x1000 * bank); + u32 flags = npcm8xx_pins[pin].flags; + int ret = 0; + + dev_dbg(dev, "set_conf [pin %d][param 0x%x, arg 0x%x]\n", + pin, param, arg); + + if (is_gpio_persist(dev, bank)) { + dev_dbg(dev, "retain the state\n"); + return 0; + } + + switch (param) { + case PIN_CONFIG_BIAS_DISABLE: + dev_dbg(dev, "set pin %d bias disable\n", pin); + clrbits_le32(base + GPIO_PU, BIT(gpio)); + clrbits_le32(base + GPIO_PD, BIT(gpio)); + break; + case PIN_CONFIG_BIAS_PULL_DOWN: + dev_dbg(dev, "set pin %d bias pull down\n", pin); + clrbits_le32(base + GPIO_PU, BIT(gpio)); + setbits_le32(base + GPIO_PD, BIT(gpio)); + break; + case PIN_CONFIG_BIAS_PULL_UP: + dev_dbg(dev, "set pin %d bias pull up\n", pin); + setbits_le32(base + GPIO_PU, BIT(gpio)); + clrbits_le32(base + GPIO_PD, BIT(gpio)); + break; + case PIN_CONFIG_INPUT_ENABLE: + dev_dbg(dev, "set pin %d input enable\n", pin); + setbits_le32(base + GPIO_OEC, BIT(gpio)); + setbits_le32(base + GPIO_IEM, BIT(gpio)); + break; + case PIN_CONFIG_OUTPUT_ENABLE: + dev_dbg(dev, "set pin %d output enable\n", pin); + clrbits_le32(base + GPIO_IEM, BIT(gpio)); + setbits_le32(base + GPIO_OES, BIT(gpio)); + case PIN_CONFIG_OUTPUT: + dev_dbg(dev, "set pin %d output %d\n", pin, arg); + clrbits_le32(base + GPIO_IEM, BIT(gpio)); + setbits_le32(base + GPIO_OES, BIT(gpio)); + if (arg) + setbits_le32(base + GPIO_DOUT, BIT(gpio)); + else + clrbits_le32(base + GPIO_DOUT, BIT(gpio)); + break; + case PIN_CONFIG_DRIVE_PUSH_PULL: + dev_dbg(dev, "set pin %d push pull\n", pin); + clrbits_le32(base + GPIO_OTYP, BIT(gpio)); + break; + case PIN_CONFIG_DRIVE_OPEN_DRAIN: + dev_dbg(dev, "set pin %d open drain\n", pin); + setbits_le32(base + GPIO_OTYP, BIT(gpio)); + break; + case PIN_CONFIG_INPUT_DEBOUNCE: + dev_dbg(dev, "set pin %d input debounce\n", pin); + setbits_le32(base + GPIO_DBNC, BIT(gpio)); + break; + case PIN_CONFIG_POLARITY_STATE: + dev_dbg(dev, "set pin %d active %d\n", pin, arg); + if (arg) + setbits_le32(base + GPIO_POL, BIT(gpio)); + else + clrbits_le32(base + GPIO_POL, BIT(gpio)); + break; + case PIN_CONFIG_DRIVE_STRENGTH: + dev_dbg(dev, "set pin %d driver strength %d\n", pin, arg); + if (DSLO(flags) == arg) + clrbits_le32(base + GPIO_ODSC, BIT(gpio)); + else if (DSHI(flags) == arg) + setbits_le32(base + GPIO_ODSC, BIT(gpio)); + else + ret = -EOPNOTSUPP; + break; + case PIN_CONFIG_SLEW_RATE: + dev_dbg(dev, "set pin %d slew rate %d\n", pin, arg); + if (!(flags & SLEW)) { + ret = -EOPNOTSUPP; + break; + } + if (arg) + setbits_le32(base + GPIO_OSRC, BIT(gpio)); + else + clrbits_le32(base + GPIO_OSRC, BIT(gpio)); + break; + case PIN_CONFIG_EVENT_CLEAR: + dev_dbg(dev, "set pin %d event clear\n", pin); + clrbits_le32(base + GPIO_EVEN, BIT(gpio)); + setbits_le32(base + GPIO_EVST, BIT(gpio)); + break; + case PIN_CONFIG_PERSIST_STATE: + npcm8xx_gpio_reset_persist(dev, bank, arg); + break; + + default: + ret = -EOPNOTSUPP; + } + + return ret; +} +#endif + +static struct pinctrl_ops npcm8xx_pinctrl_ops = { + .set_state = pinctrl_generic_set_state, + .get_pins_count = npcm8xx_get_pins_count, + .get_pin_name = npcm8xx_get_pin_name, + .get_groups_count = npcm8xx_get_groups_count, + .get_group_name = npcm8xx_get_group_name, + .get_functions_count = npcm8xx_get_groups_count, + .get_function_name = npcm8xx_get_group_name, + .pinmux_set = npcm8xx_pinmux_set, + .pinmux_group_set = npcm8xx_pinmux_group_set, +#if CONFIG_IS_ENABLED(PINCONF) + .pinconf_num_params = ARRAY_SIZE(npcm8xx_conf_params), + .pinconf_params = npcm8xx_conf_params, + .pinconf_set = npcm8xx_pinconf_set, + .pinconf_group_set = npcm8xx_pinconf_set, +#endif +}; + +static int npcm8xx_pinctrl_probe(struct udevice *dev) +{ + struct npcm8xx_pinctrl_priv *priv = dev_get_priv(dev); + + priv->gpio_base = dev_read_addr_ptr(dev); + if (!priv->gpio_base) + return -EINVAL; + + priv->gcr_regmap = syscon_regmap_lookup_by_phandle(dev, "syscon-gcr"); + if (IS_ERR(priv->gcr_regmap)) + return -EINVAL; + + priv->rst_regmap = syscon_regmap_lookup_by_phandle(dev, "syscon-rst"); + if (IS_ERR(priv->rst_regmap)) + return -EINVAL; + + return 0; +} + +static const struct udevice_id npcm8xx_pinctrl_ids[] = { + { .compatible = "nuvoton,npcm845-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(pinctrl_npcm8xx) = { + .name = "nuvoton_npcm8xx_pinctrl", + .id = UCLASS_PINCTRL, + .of_match = npcm8xx_pinctrl_ids, + .priv_auto = sizeof(struct npcm8xx_pinctrl_priv), + .ops = &npcm8xx_pinctrl_ops, + .probe = npcm8xx_pinctrl_probe, +};
Hi Stanley,
v2:
A few thoughts below
help
This should have more text
- Copyright (c) 2022 Nuvoton Technology Corp.
lower-case hex consistently
char *name;
uint
unsigned int npins;
u32 bit;
.name = #x, \
.reg = _reg, \
.bit = _bit, \
int pin_selector;
int i;
!group->npins
Stanley Chu
