[U-Boot] [PATCH] mkimage: fit_image: Use macros from image.h
There is no reason not to use macros which are already defined. It is also much easier for grepping.
tools/fit_image.c | 53 +++++++++++++++++++++++++++++------------------------ 1 file changed, 29 insertions(+), 24 deletions(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 3c265357ae73..4b626354fb3f 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -202,21 +202,22 @@ static int fit_write_images(struct image_tool_params *params, char *fdt) typename = genimg_get_type_short_name(params->fit_image_type); snprintf(str, sizeof(str), "%s-1", typename); fdt_begin_node(fdt, str); - fdt_property_string(fdt, "description", params->imagename); - fdt_property_string(fdt, "type", typename); - fdt_property_string(fdt, "arch", + fdt_property_string(fdt, FIT_DESC_PROP, params->imagename); + fdt_property_string(fdt, FIT_TYPE_PROP, typename); + fdt_property_string(fdt, FIT_ARCH_PROP, genimg_get_arch_short_name(params->arch)); - fdt_property_string(fdt, "os", genimg_get_os_short_name(params->os)); - fdt_property_string(fdt, "compression", + fdt_property_string(fdt, FIT_OS_PROP, + genimg_get_os_short_name(params->os)); + fdt_property_string(fdt, FIT_COMP_PROP, genimg_get_comp_short_name(params->comp)); - fdt_property_u32(fdt, "load", params->addr); - fdt_property_u32(fdt, "entry", params->ep); + fdt_property_u32(fdt, FIT_LOAD_PROP, params->addr); + fdt_property_u32(fdt, FIT_ENTRY_PROP, params->ep);
/* * Put data last since it is large. SPL may only load the first part * of the DT, so this way it can access all the above fields. */ - ret = fdt_property_file(params, fdt, "data", params->datafile); + ret = fdt_property_file(params, fdt, FIT_DATA_PROP, params->datafile); if (ret) return ret; fdt_end_node(fdt); @@ -230,14 +231,15 @@ static int fit_write_images(struct image_tool_params *params, char *fdt) fdt_begin_node(fdt, str);
get_basename(str, sizeof(str), cont->fname); - fdt_property_string(fdt, "description", str); - ret = fdt_property_file(params, fdt, "data", cont->fname); + fdt_property_string(fdt, FIT_DESC_PROP, str); + ret = fdt_property_file(params, fdt, FIT_DATA_PROP, + cont->fname); if (ret) return ret; - fdt_property_string(fdt, "type", typename); - fdt_property_string(fdt, "arch", + fdt_property_string(fdt, FIT_TYPE_PROP, typename); + fdt_property_string(fdt, FIT_ARCH_PROP, genimg_get_arch_short_name(params->arch)); - fdt_property_string(fdt, "compression", + fdt_property_string(fdt, FIT_COMP_PROP, genimg_get_comp_short_name(IH_COMP_NONE)); fdt_end_node(fdt); } @@ -246,10 +248,12 @@ static int fit_write_images(struct image_tool_params *params, char *fdt) if (params->fit_ramdisk) { fdt_begin_node(fdt, FIT_RAMDISK_PROP "-1");
- fdt_property_string(fdt, "type", FIT_RAMDISK_PROP); - fdt_property_string(fdt, "os", genimg_get_os_short_name(params->os)); + fdt_property_string(fdt, FIT_TYPE_PROP, FIT_RAMDISK_PROP); + fdt_property_string(fdt, FIT_OS_PROP, + genimg_get_os_short_name(params->os));
- ret = fdt_property_file(params, fdt, "data", params->fit_ramdisk); + ret = fdt_property_file(params, fdt, FIT_DATA_PROP, + params->fit_ramdisk); if (ret) return ret;
@@ -278,7 +282,7 @@ static void fit_write_configs(struct image_tool_params *params, char *fdt) int upto;
fdt_begin_node(fdt, "configurations"); - fdt_property_string(fdt, "default", "conf-1"); + fdt_property_string(fdt, FIT_DEFAULT_PROP, "conf-1");
upto = 0; for (cont = params->content_head; cont; cont = cont->next) { @@ -289,7 +293,7 @@ static void fit_write_configs(struct image_tool_params *params, char *fdt) fdt_begin_node(fdt, str);
get_basename(str, sizeof(str), cont->fname); - fdt_property_string(fdt, "description", str); + fdt_property_string(fdt, FIT_DESC_PROP, str);
typename = genimg_get_type_short_name(params->fit_image_type); snprintf(str, sizeof(str), "%s-1", typename); @@ -329,7 +333,7 @@ static int fit_build_fdt(struct image_tool_params *params, char *fdt, int size) return ret; fdt_finish_reservemap(fdt); fdt_begin_node(fdt, ""); - fdt_property_strf(fdt, "description", + fdt_property_strf(fdt, FIT_DESC_PROP, "%s image with one or more FDT blobs", genimg_get_type_name(params->fit_image_type)); fdt_property_strf(fdt, "creator", "U-Boot mkimage %s", PLAIN_VERSION); @@ -441,25 +445,26 @@ static int fit_extract_data(struct image_tool_params *params, const char *fname) const char *data; int len;
- data = fdt_getprop(fdt, node, "data", &len); + data = fdt_getprop(fdt, node, FIT_DATA_PROP, &len); if (!data) continue; memcpy(buf + buf_ptr, data, len); debug("Extracting data size %x\n", len);
- ret = fdt_delprop(fdt, node, "data"); + ret = fdt_delprop(fdt, node, FIT_DATA_PROP); if (ret) { ret = -EPERM; goto err_munmap; } if (params->external_offset > 0) { /* An external offset positions the data absolutely. */ - fdt_setprop_u32(fdt, node, "data-position", + fdt_setprop_u32(fdt, node, FIT_DATA_POSITION_PROP, params->external_offset + buf_ptr); } else { - fdt_setprop_u32(fdt, node, "data-offset", buf_ptr); + fdt_setprop_u32(fdt, node, FIT_DATA_OFFSET_PROP, + buf_ptr); } - fdt_setprop_u32(fdt, node, "data-size", len); + fdt_setprop_u32(fdt, node, FIT_DATA_SIZE_PROP, len);
buf_ptr += (len + 3) & ~3; }
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Simon Glass sjg@chromium.org
Michal Simek
