[U-Boot] [RFC 0/3] dm, efi: integrate efi_disk into DM
This patch set came from the past discussion[1] on my "removable device support" patch and is intended to be an attempt to integrate efi_disk (more precisely, EFI_BLOCK_IO_PROTOCOL-capable efi object) into u-boot's Driver Model as much seamlessly as possible
[1] https://lists.denx.de/pipermail/u-boot/2019-January/354010.html
Basic idea is * create UCLASS_PARTITION * enumerate all the partitions when a block device is probed * hook up a creation of UCLASS_BLK or UCLASS_PARTITION device to efi handler for efi_disk attributes to be properly set up
Since this patch is a prototype (or POC, proof-of-concept), the aim here is to discuss further about how in a better shape we will be able to merge the two worlds.
Example operation: (Two scsi disks, one with no partition, one with two partitions)
U-Boot 2019.01-rc3-00024-ga81a6f87ad48 (Jan 29 2019 - 10:56:45 +0900)
DRAM: 1 GiB In: pl011@9000000 Out: pl011@9000000 Err: pl011@9000000 Net: No ethernet found. Hit any key to stop autoboot: 0 => efi devices Device Device Path ================ ==================== 000000007ef01350 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) => scsi rescan
Reset SCSI scanning bus for devices... Target spinup took 0 ms. Target spinup took 0 ms. SATA link 2 timeout. SATA link 3 timeout. SATA link 4 timeout. SATA link 5 timeout. AHCI 0001.0000 32 slots 6 ports 1.5 Gbps 0x3f impl SATA mode flags: 64bit ncq only Device 0: (0:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 16.0 MB = 0.0 GB (32768 x 512) Device 0: (1:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 256.0 MB = 0.2 GB (524288 x 512) => efi devices Device Device Path ================ ==================== 000000007ef01350 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) 000000007ef0b2c0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(0,0) 000000007ef0b7b0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0) 000000007ef0c760 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(-1,MBR,0x086246ba,0x17ff56048,0x7eeeb770) 000000007ef0cb50 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(-1,MBR,0x086246ba,0x17ff56048,0x7eeeb770) => dm tree Class index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver ... pci 0 [ + ] pci_generic_ecam |-- pcie@10000000 pci_generi 0 [ ] pci_generic_drv | |-- pci_0:0.0 virtio 32 [ ] virtio-pci.l | |-- virtio-pci.l#0 ahci 0 [ + ] ahci_pci | `-- ahci_pci scsi 0 [ + ] ahci_scsi | `-- ahci_scsi blk 0 [ ] scsi_blk | |-- ahci_scsi.id0lun0 blk 1 [ ] scsi_blk | `-- ahci_scsi.id1lun0 partition 0 [ ] blk_partition | |-- ahci_scsi.id1lun0:1 partition 1 [ ] blk_partition | `-- ahci_scsi.id1lun0:2 ...
Thanks, -Takahiro Akashi
AKASHI Takahiro (3): dm: blk: add UCLASS_PARTITION efi_loader: associate BLK/PARTITION device to efi_disk drivers: align block device drivers with DM-efi integration
common/usb_storage.c | 27 ++++- drivers/block/blk-uclass.c | 61 ++++++++++ drivers/core/device.c | 3 + drivers/scsi/scsi.c | 22 ++++ include/blk.h | 24 ++++ include/dm/device.h | 4 + include/dm/uclass-id.h | 1 + lib/efi_driver/efi_block_device.c | 30 ++--- lib/efi_loader/efi_disk.c | 192 +++++++++++++++++++++--------- 9 files changed, 283 insertions(+), 81 deletions(-)
UCLASS_PARTITION device will be created as a child node of UCLASS_BLK device.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- drivers/block/blk-uclass.c | 52 ++++++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + 2 files changed, 53 insertions(+)
diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index baaf431e5e0c..d4ca30f23fc1 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -10,6 +10,8 @@ #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/uclass-internal.h> +#include <part.h> +#include <string.h>
static const char *if_typename_str[IF_TYPE_COUNT] = { [IF_TYPE_IDE] = "ide", @@ -654,3 +656,53 @@ UCLASS_DRIVER(blk) = { .post_probe = blk_post_probe, .per_device_platdata_auto_alloc_size = sizeof(struct blk_desc), }; + +U_BOOT_DRIVER(blk_partition) = { + .name = "blk_partition", + .id = UCLASS_PARTITION, + .platdata_auto_alloc_size = sizeof(struct disk_part), +}; + +UCLASS_DRIVER(partition) = { + .id = UCLASS_PARTITION, + .name = "partition", +}; + +#if defined(CONFIG_PARTITIONS) && defined(CONFIG_HAVE_BLOCK_DEVICE) +int blk_create_partitions(struct udevice *parent) +{ + int part; + struct blk_desc *desc = dev_get_uclass_platdata(parent); + disk_partition_t info; + struct disk_part *part_data; + char devname[32]; + struct udevice *dev; + int disks = 0, ret; + + /* Add devices for each partition */ + for (part = 1; part <= MAX_SEARCH_PARTITIONS; part++) { + if (part_get_info(desc, part, &info)) + continue; + snprintf(devname, sizeof(devname), "%s:%d", parent->name, + part); + + ret = device_bind_driver(parent, "blk_partition", + strdup(devname), &dev); + if (ret) + return ret; + + part_data = dev_get_uclass_platdata(dev); + part_data->partnum = part; + part_data->gpt_part_info = info; + + disks++; + } + + return disks; +} +#else +int blk_create_partitions(struct udevice *dev) +{ + return 0; +} +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index f3bafb3c6353..e02b5f8fda42 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -65,6 +65,7 @@ enum uclass_id { UCLASS_NVME, /* NVM Express device */ UCLASS_PANEL, /* Display panel, such as an LCD */ UCLASS_PANEL_BACKLIGHT, /* Backlight controller for panel */ + UCLASS_PARTITION, /* Logical disk partition device */ UCLASS_PCH, /* x86 platform controller hub */ UCLASS_PCI, /* PCI bus */ UCLASS_PCI_GENERIC, /* Generic PCI bus device */
On Tue, 29 Jan 2019, AKASHI Takahiro wrote:
My $.25 -- IMHO, block device partitions in Device Tree is _NOT_ a very good idea.
What if one decided to re-partition his drive? Or just use bigger or smaller drive? Would he has to re-write DTS file and re-compile everything? And such change is not something extraordinary, it is a routine action.
IMHO partitions do _NOT_ belong to Block Device. That's what partition tables are.
It _MIGHT_ make sense for some particular devices such as MTD that don't have partition tables but _NOT_ for Block Devices in general.
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
This is about device model, not device tree :). Device trees indeed should not contain partition information. Our internal object model however would do well if it had them.
Alex
DM assumes using Device Tree.
As there’s no compatible-string, this indeed is for the internal object model only.
- .name = "blk_partition",
- .id = UCLASS_PARTITION,
- .platdata_auto_alloc_size = sizeof(struct disk_part),
- .name = "partition",
- int part;
- struct blk_desc *desc = dev_get_uclass_platdata(parent);
- disk_partition_t info;
- struct disk_part *part_data;
- char devname[32];
- struct udevice *dev;
- int disks = 0, ret;
- /* Add devices for each partition */
- for (part = 1; part <= MAX_SEARCH_PARTITIONS; part++) {
continue;
part);
if (ret)
This looks like a memory leak for the output of strdup().
return ret;
Why would we leave here if one partition fails? Does this imply that all further partitions will fail? Should we use continue here?
Best regards
Heinrich
disks++;
- return disks;
- UCLASS_PARTITION, /* Logical disk partition device */ UCLASS_PCH, /* x86 platform controller hub */ UCLASS_PCI, /* PCI bus */ UCLASS_PCI_GENERIC, /* Generic PCI bus device */
- int part;
- char devname[32];
continue;
part);
if (ret)
Yes, I'm aware of that, but please note that this is a prototype and so I haven't paid much attention to failure cases (error recovery). First of all, even in the current implementation, we don't support *unplugging* (or unbind in EFI jargon?) devices. It's a more fundamental issue.
return ret;
Ditto. Please be patient for the time being :)
-Takahiro Akashi
Best regards
Heinrich
disks++;
- return disks;
Hi Takahiro,
On Mon, 28 Jan 2019 at 19:59, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
int part;
char devname[32];
int disks = 0, ret;
continue;
part);
if (ret)
return ret;
disks++;
return disks;
-- 2.19.1
This looks OK to me. It does need a test in test/dm/partition.c for the new uclass.
efi_disk_create() will initialize efi_disk attributes for each device, either UCLASS_BLK or UCLASS_PARTITION.
Currently (temporarily), efi_disk_obj structure is embedded into blk_desc to hold efi-specific attributes.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- drivers/block/blk-uclass.c | 9 ++ drivers/core/device.c | 3 + include/blk.h | 24 +++++ include/dm/device.h | 4 + lib/efi_loader/efi_disk.c | 192 ++++++++++++++++++++++++++----------- 5 files changed, 174 insertions(+), 58 deletions(-)
diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index d4ca30f23fc1..28c45d724113 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -657,6 +657,9 @@ UCLASS_DRIVER(blk) = { .per_device_platdata_auto_alloc_size = sizeof(struct blk_desc), };
+/* FIXME */ +extern int efi_disk_create(struct udevice *dev); + U_BOOT_DRIVER(blk_partition) = { .name = "blk_partition", .id = UCLASS_PARTITION, @@ -695,6 +698,12 @@ int blk_create_partitions(struct udevice *parent) part_data->partnum = part; part_data->gpt_part_info = info;
+ ret = efi_disk_create(dev); + if (ret) { + device_unbind(dev); + return ret; + } + disks++; }
diff --git a/drivers/core/device.c b/drivers/core/device.c index 0d15e5062b66..8625fccb0dcb 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -67,6 +67,9 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv, dev->parent = parent; dev->driver = drv; dev->uclass = uc; +#ifdef CONFIG_EFI_LOADER + INIT_LIST_HEAD(&dev->efi_obj.protocols); +#endif
dev->seq = -1; dev->req_seq = -1; diff --git a/include/blk.h b/include/blk.h index d0c033aece0f..405f6f790d66 100644 --- a/include/blk.h +++ b/include/blk.h @@ -8,6 +8,7 @@ #define BLK_H
#include <efi.h> +#include <efi_api.h>
#ifdef CONFIG_SYS_64BIT_LBA typedef uint64_t lbaint_t; @@ -53,6 +54,26 @@ enum sig_type { SIG_TYPE_COUNT /* Number of signature types */ };
+/* FIXME */ +/** + * struct efi_disk_obj - EFI disk object + * + * @ops: EFI disk I/O protocol interface + * @media: block I/O media information + * @dp: device path to the block device + * @part: partition + * @volume: simple file system protocol of the partition + * @offset: offset into disk for simple partition + */ +struct efi_disk_obj { + struct efi_block_io ops; + struct efi_block_io_media media; + struct efi_device_path *dp; + unsigned int part; + struct efi_simple_file_system_protocol *volume; + lbaint_t offset; +}; + /* * With driver model (CONFIG_BLK) this is uclass platform data, accessible * with dev_get_uclass_platdata(dev) @@ -92,6 +113,9 @@ struct blk_desc { * device. Once these functions are removed we can drop this field. */ struct udevice *bdev; +#ifdef CONFIG_EFI_LOADER + struct efi_disk_obj efi_disk; +#endif #else unsigned long (*block_read)(struct blk_desc *block_dev, lbaint_t start, diff --git a/include/dm/device.h b/include/dm/device.h index 27a6d7b9fdb0..121bfb46b1a0 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -12,6 +12,7 @@
#include <dm/ofnode.h> #include <dm/uclass-id.h> +#include <efi_loader.h> #include <fdtdec.h> #include <linker_lists.h> #include <linux/compat.h> @@ -146,6 +147,9 @@ struct udevice { #ifdef CONFIG_DEVRES struct list_head devres_head; #endif +#ifdef CONFIG_EFI_LOADER + struct efi_object efi_obj; +#endif };
/* Maximum sequence number supported */ diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index c037526ad2d0..84fa0ddfba14 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -14,33 +14,6 @@
const efi_guid_t efi_block_io_guid = BLOCK_IO_GUID;
-/** - * struct efi_disk_obj - EFI disk object - * - * @header: EFI object header - * @ops: EFI disk I/O protocol interface - * @ifname: interface name for block device - * @dev_index: device index of block device - * @media: block I/O media information - * @dp: device path to the block device - * @part: partition - * @volume: simple file system protocol of the partition - * @offset: offset into disk for simple partition - * @desc: internal block device descriptor - */ -struct efi_disk_obj { - struct efi_object header; - struct efi_block_io ops; - const char *ifname; - int dev_index; - struct efi_block_io_media media; - struct efi_device_path *dp; - unsigned int part; - struct efi_simple_file_system_protocol *volume; - lbaint_t offset; - struct blk_desc *desc; -}; - static efi_status_t EFIAPI efi_disk_reset(struct efi_block_io *this, char extended_verification) { @@ -64,7 +37,7 @@ static efi_status_t efi_disk_rw_blocks(struct efi_block_io *this, unsigned long n;
diskobj = container_of(this, struct efi_disk_obj, ops); - desc = (struct blk_desc *) diskobj->desc; + desc = container_of(diskobj, struct blk_desc, efi_disk); blksz = desc->blksz; blocks = buffer_size / blksz; lba += diskobj->offset; @@ -217,6 +190,7 @@ efi_fs_from_path(struct efi_device_path *full_path) return handler->protocol_interface; }
+#ifndef CONFIG_BLK /* * Create a handle for a partition or disk * @@ -343,6 +317,136 @@ int efi_disk_create_partitions(efi_handle_t parent, struct blk_desc *desc,
return disks; } +#else +static int efi_disk_create_common(efi_handle_t handle, + struct efi_disk_obj *disk, + struct blk_desc *desc) +{ + efi_status_t ret; + + /* Hook up to the device list */ + efi_add_handle(handle); + + /* Fill in EFI IO Media info (for read/write callbacks) */ + disk->media.removable_media = desc->removable; + disk->media.media_present = 1; + disk->media.block_size = desc->blksz; + disk->media.io_align = desc->blksz; + disk->media.last_block = desc->lba - disk->offset; + disk->ops.media = &disk->media; + + /* add protocols */ + disk->ops = block_io_disk_template; + ret = efi_add_protocol(handle, &efi_block_io_guid, &disk->ops); + if (ret != EFI_SUCCESS) + goto err; + + ret = efi_add_protocol(handle, &efi_guid_device_path, disk->dp); + if (ret != EFI_SUCCESS) + goto err; + + return 0; + +err: + /* FIXME: undo adding protocols */ + return -1; +} + +/* + * Create a handle for a raw disk + * + * @dev uclass device + * @return 0 on success, -1 otherwise + */ +int efi_disk_create_raw(struct udevice *dev) +{ + struct blk_desc *desc = dev_get_uclass_platdata(dev); + struct efi_disk_obj *disk = &desc->efi_disk; + + /* Don't add empty devices */ + if (!desc->lba) + return -1; + + /* raw block device */ + disk->offset = 0; + disk->part = 0; + disk->dp = efi_dp_from_part(desc, 0); + + /* efi IO media */ + disk->media.logical_partition = 0; + + return efi_disk_create_common(&dev->efi_obj, disk, desc); +} + +/* + * Create a handle for a partition + * + * @dev uclass device + * @return 0 on success, -1 otherwise + */ +int efi_disk_create_part(struct udevice *dev) +{ + struct udevice *parent = dev->parent; + struct blk_desc *desc = dev_get_uclass_platdata(parent); + struct blk_desc *this; + struct disk_part *pdata = dev_get_uclass_platdata(dev); + struct efi_disk_obj *disk; + struct efi_device_path *node; + + int ret; + + /* dummy block device */ + this = malloc(sizeof(*this)); + if (!this) + return -1; + disk = &this->efi_disk; + + /* logical disk partition */ + disk->offset = pdata->gpt_part_info.start; + disk->part = pdata->partnum; + + node = efi_dp_part_node(desc, disk->part); + disk->dp = efi_dp_append_node(desc->efi_disk.dp, node); + efi_free_pool(node); + + /* efi IO media */ + disk->media.logical_partition = 1; + + ret = efi_disk_create_common(&dev->efi_obj, disk, desc); + if (ret) + goto err; + + /* partition may support file system access */ + disk->volume = efi_simple_file_system(desc, disk->part, disk->dp); + ret = efi_add_protocol(&dev->efi_obj, + &efi_simple_file_system_protocol_guid, + disk->volume); + if (ret != EFI_SUCCESS) + goto err; + + return 0; + +err: + free(this); + /* FIXME: undo create */ + + return -1; +} + +int efi_disk_create(struct udevice *dev) +{ + enum uclass_id id; + + id = device_get_uclass_id(dev); + + if (id == UCLASS_BLK) + return efi_disk_create_raw(dev); + else if (id == UCLASS_PARTITION) + return efi_disk_create_part(dev); + else + return -1; +} +#endif /* CONFIG_BLK */
/* * U-Boot doesn't have a list of all online disk devices. So when running our @@ -357,38 +461,10 @@ int efi_disk_create_partitions(efi_handle_t parent, struct blk_desc *desc, */ efi_status_t efi_disk_register(void) { +#ifndef CONFIG_BLK struct efi_disk_obj *disk; int disks = 0; efi_status_t ret; -#ifdef CONFIG_BLK - struct udevice *dev; - - for (uclass_first_device_check(UCLASS_BLK, &dev); dev; - uclass_next_device_check(&dev)) { - struct blk_desc *desc = dev_get_uclass_platdata(dev); - const char *if_typename = blk_get_if_type_name(desc->if_type); - - /* Add block device for the full device */ - printf("Scanning disk %s...\n", dev->name); - ret = efi_disk_add_dev(NULL, NULL, if_typename, - desc, desc->devnum, 0, 0, &disk); - if (ret == EFI_NOT_READY) { - printf("Disk %s not ready\n", dev->name); - continue; - } - if (ret) { - printf("ERROR: failure to add disk device %s, r = %lu\n", - dev->name, ret & ~EFI_ERROR_MASK); - return ret; - } - disks++; - - /* Partitions show up as block devices in EFI */ - disks += efi_disk_create_partitions( - &disk->header, desc, if_typename, - desc->devnum, dev->name); - } -#else int i, if_type;
/* Search for all available disk devices */ @@ -435,8 +511,8 @@ efi_status_t efi_disk_register(void) if_typename, i, devname); } } -#endif printf("Found %d disks\n", disks); +#endif
return EFI_SUCCESS; }
if (ret) {
device_unbind(dev);
return ret;
- disks++; }
- INIT_LIST_HEAD(&dev->efi_obj.protocols);
This looks like an incomplete initialization of efi_obj. Why don't we use efi_create_handle.
Why should a device be aware of struct efi_obj? We only need a handle to install protocols.
+/* FIXME */
Fix what?
- struct efi_disk_obj - EFI disk object
- @ops: EFI disk I/O protocol interface
- @media: block I/O media information
- @dp: device path to the block device
- @part: partition
- @volume: simple file system protocol of the partition
- @offset: offset into disk for simple partition
- lbaint_t offset;
- With driver model (CONFIG_BLK) this is uclass platform data, accessible
- with dev_get_uclass_platdata(dev)
- struct efi_disk_obj efi_disk;
This must be a handle (i.e. a pointer). Otherwise when the last protocol is removed we try to free memory that was never malloc'ed.
- struct efi_object efi_obj;
+#endif };
- @header: EFI object header
- @ifname: interface name for block device
- @dev_index: device index of block device
- @part: partition
- @desc: internal block device descriptor
- int dev_index;
- lbaint_t offset;
- desc = container_of(diskobj, struct blk_desc, efi_disk); blksz = desc->blksz; blocks = buffer_size / blksz; lba += diskobj->offset;
- Create a handle for a partition or disk
- efi_status_t ret;
- /* Hook up to the device list */
- efi_add_handle(handle);
- /* Fill in EFI IO Media info (for read/write callbacks) */
- disk->media.removable_media = desc->removable;
- disk->media.media_present = 1;
- disk->media.block_size = desc->blksz;
- disk->media.io_align = desc->blksz;
- disk->media.last_block = desc->lba - disk->offset;
- disk->ops.media = &disk->media;
- /* add protocols */
- disk->ops = block_io_disk_template;
- ret = efi_add_protocol(handle, &efi_block_io_guid, &disk->ops);
- if (ret != EFI_SUCCESS)
goto err;
- ret = efi_add_protocol(handle, &efi_guid_device_path, disk->dp);
goto err;
+err:
- /* FIXME: undo adding protocols */
- return -1;
- Create a handle for a raw disk
- @dev uclass device
- @return 0 on success, -1 otherwise
- struct efi_disk_obj *disk = &desc->efi_disk;
- /* Don't add empty devices */
- if (!desc->lba)
return -1;
- /* raw block device */
- disk->offset = 0;
- disk->part = 0;
- disk->dp = efi_dp_from_part(desc, 0);
- /* efi IO media */
- disk->media.logical_partition = 0;
- return efi_disk_create_common(&dev->efi_obj, disk, desc);
- struct udevice *parent = dev->parent;
- struct blk_desc *this;
- struct disk_part *pdata = dev_get_uclass_platdata(dev);
- struct efi_disk_obj *disk;
- struct efi_device_path *node;
- int ret;
- /* dummy block device */
- this = malloc(sizeof(*this));
- if (!this)
return -1;
- disk = &this->efi_disk;
- /* logical disk partition */
- disk->offset = pdata->gpt_part_info.start;
- disk->part = pdata->partnum;
- node = efi_dp_part_node(desc, disk->part);
- disk->dp = efi_dp_append_node(desc->efi_disk.dp, node);
- efi_free_pool(node);
- disk->media.logical_partition = 1;
- ret = efi_disk_create_common(&dev->efi_obj, disk, desc);
- if (ret)
goto err;
- /* partition may support file system access */
- disk->volume = efi_simple_file_system(desc, disk->part, disk->dp);
- ret = efi_add_protocol(&dev->efi_obj,
disk->volume);
goto err;
+err:
- free(this);
- /* FIXME: undo create */
- return -1;
- enum uclass_id id;
- id = device_get_uclass_id(dev);
- if (id == UCLASS_BLK)
- else if (id == UCLASS_PARTITION)
- else
return -1;
- U-Boot doesn't have a list of all online disk devices. So when running our
Who cares for this output? If really needed make it debug().
Who minds if it is a CD-ROM drive with no disk inserted? Debug() might be adequate here.
continue;
if (ret) {
return ret;
disks++;
I would prefer this to be debug() or eliminated.
Best regards
Heinrich
if (ret) {
device_unbind(dev);
return ret;
- disks++; }
I think that it is more or less a matter of implementation. I will address this issue later if necessary.
+/* FIXME */
Fix what?
For simplicity, this data structure was copied from efi_disk.c in this initial release. As the implementation goes *sophisticated*, some members may go away or move somewhere, say in blk_desc itself.
- @part: partition
- lbaint_t offset;
Who actually frees?
+#endif };
- @part: partition
- int dev_index;
- lbaint_t offset;
- efi_status_t ret;
goto err;
goto err;
+err:
- return -1;
- if (!desc->lba)
return -1;
- disk->offset = 0;
- disk->part = 0;
- int ret;
- if (!this)
return -1;
- if (ret)
goto err;
disk->volume);
goto err;
+err:
- free(this);
- return -1;
- else
return -1;
Please note that this is a line to be deleted.
Ditto
continue;
if (ret) {
return ret;
disks++;
I didn't change anything on this line and the function, efi_disk_register(), will eventually go away.
Best regards
Heinrich
if (ret) {
device_unbind(dev);
return ret;
- disks++; }
+/* FIXME */
Fix what?
- @part: partition
- lbaint_t offset;
Who actually frees?
see UEFI spec for UninstallProtocolInterface():
"If the last protocol interface is removed from a handle, the handle is freed and is no longer valid."
Best regards
Heinrich
+#endif };
- @part: partition
- int dev_index;
- lbaint_t offset;
- efi_status_t ret;
goto err;
goto err;
+err:
- return -1;
- if (!desc->lba)
return -1;
- disk->offset = 0;
- disk->part = 0;
- int ret;
- if (!this)
return -1;
- if (ret)
goto err;
disk->volume);
goto err;
+err:
- free(this);
- return -1;
- else
return -1;
Ditto
continue;
if (ret) {
return ret;
disks++;
Best regards
Heinrich
if (ret) {
device_unbind(dev);
return ret;
- disks++; }
+/* FIXME */
Fix what?
- @part: partition
- lbaint_t offset;
Who actually frees?
Got it. So, under the current implementation, any efi_object must be allocated by efi code itself and all derived efi objects have an efi_object as the first member. (We can lift this restriction by adding object-specific "free" function, like calling (handle->free)(handle) instead of free(handle) though.)
Umm. This will make it a bit difficult to remove efi_disk_obj from our code.
-Takahiro Akashi
Best regards
Heinrich
+#endif };
- @part: partition
- int dev_index;
- lbaint_t offset;
- efi_status_t ret;
goto err;
goto err;
+err:
- return -1;
- if (!desc->lba)
return -1;
- disk->offset = 0;
- disk->part = 0;
- int ret;
- if (!this)
return -1;
- if (ret)
goto err;
disk->volume);
goto err;
+err:
- free(this);
- return -1;
- else
return -1;
Ditto
continue;
if (ret) {
return ret;
disks++;
Best regards
Heinrich
Hi AKASHI,
I think the objective should be to drop the EFI data structures.
So your approach of just including them in DM structures seems about right to me, as a short-term migration measure. Given the large amount of code that has built up I don't think it is possible to do it any other way.
It is very unfortunate though.
So basically migration could be something like this:
1. Move each of the EFI structs into the DM structs one by one 2. Drop struct members that are not needed and can be calculated from DM members 3. Update DM to have 1:1 uclasses for each EFI protocol 4. Move all the protocol structs into the DM uclasses 5. Whittle these down until they are just shells used by the API, with everything going through normal DM calls
Or would it be better to just start again and rewrite it with the existing code as a base?
Looking at it, efi_object is not very useful in DM. It contains two members:
1. link - linked list link, which devices already have, although we don't have a single list of all them. Instead they are linked into separate lists for each uclass
2. protocols - list of protocols. But DM devices support only one protocol. Multiple protocols are handled using child devices. E.g a UCLASS_PMIC device that supports UCLASS_GPIO, UCLASS_REGULATOR and UCLASS_AUDIO_CODEC would have three children, one for each uclass. So perhaps with EFI we should create a separate child for each protocol in a similar way?
Which comes back to the idea of creating an EFI child device for every DM device. Perhaps instead we create one EFI child for each protocol supported by the parent device?
Another point is that the operations supported by EFI should be in DM operations structs. For example I think struct efi_simple_text_output_protocol should have methods which call into the corresponding uclass operations.
It is confusing that an EFI disk is in fact a partition. Or do I have that wrong?
Anyway that's all the thoughts I have at present. Thanks for your efforts on this.
Hi Simon,
Thank you for suggestive comments. I've got no idea of making DM class for EFI protocol.
On Wed, Jan 30, 2019 at 06:22:47PM -0700, Simon Glass wrote:
Hi AKASHI,
More or less so, yes.
Right.
- Move each of the EFI structs into the DM structs one by one
- Drop struct members that are not needed and can be calculated from DM members
- Update DM to have 1:1 uclasses for each EFI protocol
- Move all the protocol structs into the DM uclasses
- Whittle these down until they are just shells used by the API, with
- link - linked list link, which devices already have, although we
- protocols - list of protocols. But DM devices support only one
Well, "child device as a EFI protocol" is really workable, but I have some concerns: * Can a DM device be an abstract instance with no real hardware? * There may be two different types of "children" mixed for an EFI object - some physical hierarchy, say disk partitions for a raw disk - these EFI protocols That is, for example, one raw disk has - partition 1 has - block io protocol - device path protocol - simple file system protocol - partition 2 has - block io protocol - device path protocol - simple file system protocol - block io protocol - device path protocol * device path protocol can be annoying as almost all devices (visible to UEFI) have some sort of device path, while corresponding u-boot notion is, say, "scsi 0:1" which only appears on command interfaces.
I'm not sure if those concerns are acceptable.
I have no idea on those "console" devices yet.
IMO, EFI disk is any type of EFI object which supports EFI_BLOCK_IO_PROTOCOL. So a raw disk(UCLASS_BLK) as well as its partitions(UCLASS_PARTITION) are EFI disks as well. Is this an answer to you?
Those said, your suggestion is truly worth considering.
On Thu, 31 Jan 2019 at 22:53, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
Hi Simon,
Hi AKASHI,
Right.
- Can a DM device be an abstract instance with no real hardware?
Yes we do that quite a bit. Even UCLASS_BLK is like this, if you think about it.
- There may be two different types of "children" mixed for an EFI object
- device path protocol can be annoying as almost all devices (visible to UEFI) have some sort of device path, while corresponding u-boot notion is, say, "scsi 0:1" which only appears on command interfaces.
Yes. We could use the device path from concatenating device names from all parents, perhaps. I've been thinking about adding that to the command line as an option.
Yes OK, I see.
OK, good. Certainly an interesting project.
Hi Simon,
Hi AKASHI,
Right.
OK
Device path is kinda device hierarchy of DM, so it's easily confusing. Please see an example below.
Yes OK, I see.
Conversion of efi protocols to uclass device(UCLASS_PROTOCOL) was done and efi_handle_t is now 'struct udevice *'!
I could do this almost "systematically," but the code size doesn't decrease much. This is no surprise because we rely on udevice only for traversing efi handles and protocols. We still need lots of "wrapper" layers on top of block devices, file systems and so on due to differences of APIs and their semantics. (Because of this, I don't have good confidence yet that efi protocol should also be a device in DM.)
Here is a sample operation:
=> efi dev Device Device Path ================ ==================== 000000007eef9590 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) => scsi rescan
Reset SCSI scanning bus for devices... Target spinup took 0 ms. Target spinup took 0 ms. SATA link 2 timeout. SATA link 3 timeout. SATA link 4 timeout. SATA link 5 timeout. AHCI 0001.0000 32 slots 6 ports 1.5 Gbps 0x3f impl SATA mode flags: 64bit ncq only Device 0: (0:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 16.0 MB = 0.0 GB (32768 x 512) Device 0: (1:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 256.0 MB = 0.2 GB (524288 x 512) => efi devices Device Device Path ================ ==================== 000000007eef9590 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) 000000007ef04c50 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(0,0) 000000007ef02d10 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0) 000000007ef05c70 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(335544330,MBR,0x086246ba,0x17ff501a0,0x7eee4770) 000000007ef06270 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(335544330,MBR,0x086246ba,0x17ff501a0,0x7eee4770) => efi dh Handle Protocols ================ ==================== 000000007eef9590 Device Path, Device Path To Text, Device Path Utilities, Unicode Collation 2 000000007ef00970 Driver Binding 000000007eef7b80 Simple Text Output, Simple Text Input, Simple Text Input Ex 000000007ef04c50 Block IO, Device Path 000000007ef02d10 Block IO, Device Path 000000007ef05c70 Block IO, Device Path, Simple File System 000000007ef06270 Block IO, Device Path, Simple File System => dm tree Class index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver simple_bus 0 [ ] generic_simple_bus |-- platform@c000000 virtio 0 [ + ] virtio-mmio |-- virtio_mmio@a000000
pci 0 [ + ] pci_generic_ecam |-- pcie@10000000 pci_generi 0 [ ] pci_generic_drv | |-- pci_0:0.0 virtio 32 [ ] virtio-pci.l | |-- virtio-pci.l#0 ahci 0 [ + ] ahci_pci | `-- ahci_pci scsi 0 [ + ] ahci_scsi | `-- ahci_scsi blk 0 [ ] scsi_blk | |-- ahci_scsi.id0lun0 efi_protoc 8 [ ] efi_protocol | | |-- (PROTO) efi_protoc 9 [ ] efi_protocol | | `-- (PROTO) blk 1 [ ] scsi_blk | `-- ahci_scsi.id1lun0 efi_protoc 10 [ ] efi_protocol | |-- (PROTO) efi_protoc 11 [ ] efi_protocol | |-- (PROTO) partition 0 [ ] blk_partition | |-- ahci_scsi.id1lun0:1 efi_protoc 12 [ ] efi_protocol | | |-- (PROTO) efi_protoc 13 [ ] efi_protocol | | |-- (PROTO) efi_protoc 14 [ ] efi_protocol | | `-- (PROTO) partition 1 [ ] blk_partition | `-- ahci_scsi.id1lun0:2 efi_protoc 15 [ ] efi_protocol | |-- (PROTO) efi_protoc 16 [ ] efi_protocol | |-- (PROTO) efi_protoc 17 [ ] efi_protocol | `-- (PROTO) rtc 0 [ ] rtc-pl031 |-- pl031@9010000 serial 0 [ ] serial_pl01x |-- pl011@9050000 serial 1 [ + ] serial_pl01x |-- pl011@9000000 efi_protoc 5 [ ] efi_protocol | |-- (PROTO) efi_protoc 6 [ ] efi_protocol | |-- (PROTO) efi_protoc 7 [ ] efi_protocol | `-- (PROTO) mtd 0 [ + ] cfi_flash |-- flash@0 firmware 0 [ + ] psci |-- psci sysreset 0 [ ] psci-sysreset | `-- psci-sysreset efi_object 0 [ ] efi_dumb_object |-- efi_root efi_protoc 0 [ ] efi_protocol | |-- (PROTO) efi_protoc 1 [ ] efi_protocol | |-- (PROTO) efi_protoc 2 [ ] efi_protocol | |-- (PROTO) efi_protoc 3 [ ] efi_protocol | `-- (PROTO) efi_object 1 [ ] efi_dumb_object `-- EFI block driver efi_protoc 4 [ ] efi_protocol `-- (PROTO)
As you can see, I have only one efi protocol "driver" and so there's no specific name given for each protocol now.
As I'm still debugging my code, I will re-post my patch once it gets back working.
Hi Simon,
Hi AKASHI,
Right.
OK
Yes OK, I see.
To be clear, what is converted to DM device here is "struct efi_handler," not "protocol interface" structure in UEFI world. The latter is a well-defined data structure in UEFI spec and cannot be treated as a DM device.
I changed this part of output:
to
efi_object 0 [ ] efi_dumb_object `-- efi_root efi_protoc 0 [ ] efi_protocol |-- (PROTO) efi_protoc 1 [ ] efi_protocol |-- (PROTO) efi_protoc 2 [ ] efi_protocol |-- (PROTO) efi_protoc 3 [ ] efi_protocol |-- (PROTO) efi 0 [ ] EFI block driver `-- EFI block driver efi_protoc 4 [ ] efi_protocol `-- (PROTO)
More specifically, there seem to be a few options: 1-1. to keep one uclass, distinguishing protocols with an internal id, something like IF_TYPE_* for blk_desc 1-2. to keep one uclass, having one driver for one protocol, (Either way, there's not common "operation" btw protocols here.)
2. to give each protocol an unique uclass id
Efi_disk_create() should be hook up at every creation of block device at each driver. Associated blk_desc must be properly set up before calling this function.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- common/usb_storage.c | 27 +++++++++++++++++++++++++-- drivers/scsi/scsi.c | 22 ++++++++++++++++++++++ lib/efi_driver/efi_block_device.c | 30 +++++++++--------------------- 3 files changed, 56 insertions(+), 23 deletions(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index 8c889bb1a648..ff895c0e4557 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -46,6 +46,10 @@ #include <part.h> #include <usb.h>
+/* FIXME */ +extern int efi_disk_create(struct udevice *dev); +extern int blk_create_partitions(struct udevice *parent); + #undef BBB_COMDAT_TRACE #undef BBB_XPORT_TRACE
@@ -227,8 +231,27 @@ static int usb_stor_probe_device(struct usb_device *udev)
ret = usb_stor_get_info(udev, data, blkdev); if (ret == 1) { - usb_max_devs++; - debug("%s: Found device %p\n", __func__, udev); + ret = efi_disk_create(dev); + if (ret) { + debug("Cannot create efi_disk device\n"); + ret = device_unbind(dev); + if (ret) + return ret; + } else { + usb_max_devs++; + ret = blk_create_partitions(dev); + if (ret < 0) { + debug("Cannot create disk partition device\n"); + /* TODO: undo create */ + + ret = device_unbind(dev); + if (ret) + return ret; + } + usb_max_devs += ret; + debug("%s: Found device %p, partitions:%d\n", + __func__, udev, ret); + } } else { debug("usb_stor_get_info: Invalid device\n"); ret = device_unbind(dev); diff --git a/drivers/scsi/scsi.c b/drivers/scsi/scsi.c index df47e2fc78bd..f0f8cbc0bf26 100644 --- a/drivers/scsi/scsi.c +++ b/drivers/scsi/scsi.c @@ -11,6 +11,10 @@ #include <dm/device-internal.h> #include <dm/uclass-internal.h>
+/* FIXME */ +int efi_disk_create(struct udevice *dev); +int blk_create_partitions(struct udevice *parent); + #if !defined(CONFIG_DM_SCSI) # ifdef CONFIG_SCSI_DEV_LIST # define SCSI_DEV_LIST CONFIG_SCSI_DEV_LIST @@ -593,9 +597,27 @@ static int do_scsi_scan_one(struct udevice *dev, int id, int lun, bool verbose) memcpy(&bdesc->product, &bd.product, sizeof(bd.product)); memcpy(&bdesc->revision, &bd.revision, sizeof(bd.revision));
+ ret = efi_disk_create(bdev); + if (ret) { + debug("Can't create efi_disk device\n"); + ret = device_unbind(bdev); + + return ret; + } + ret = blk_create_partitions(bdev); + if (ret < 0) { + debug("Can't create efi_disk partitions\n"); + /* TODO: undo create */ + + ret = device_unbind(bdev); + + return ret; + } + if (verbose) { printf(" Device %d: ", 0); dev_print(bdesc); + debug("Found %d partitions\n", ret); } return 0; } diff --git a/lib/efi_driver/efi_block_device.c b/lib/efi_driver/efi_block_device.c index 3f147cf60879..4ab3402d6768 100644 --- a/lib/efi_driver/efi_block_device.c +++ b/lib/efi_driver/efi_block_device.c @@ -32,6 +32,10 @@ #include <dm/device-internal.h> #include <dm/root.h>
+/* FIXME */ +extern int efi_disk_create(struct udevice *dev); +extern int blk_create_partitions(struct udevice *parent); + /* * EFI attributes of the udevice handled by this driver. * @@ -102,24 +106,6 @@ static ulong efi_bl_write(struct udevice *dev, lbaint_t blknr, lbaint_t blkcnt, return blkcnt; }
-/* - * Create partions for the block device. - * - * @handle EFI handle of the block device - * @dev udevice of the block device - */ -static int efi_bl_bind_partitions(efi_handle_t handle, struct udevice *dev) -{ - struct blk_desc *desc; - const char *if_typename; - - desc = dev_get_uclass_platdata(dev); - if_typename = blk_get_if_type_name(desc->if_type); - - return efi_disk_create_partitions(handle, desc, if_typename, - desc->devnum, dev->name); -} - /* * Create a block device for a handle * @@ -168,15 +154,17 @@ static int efi_bl_bind(efi_handle_t handle, void *interface) platdata->handle = handle; platdata->io = interface;
+ ret = efi_disk_create(bdev); + if (ret) + return ret; + ret = device_probe(bdev); if (ret) return ret; EFI_PRINT("%s: block device '%s' created\n", __func__, bdev->name); - /* Create handles for the partions of the block device */ - disks = efi_bl_bind_partitions(handle, bdev); + disks = blk_create_partitions(bdev); EFI_PRINT("Found %d partitions\n", disks); - return 0; }
- #undef BBB_COMDAT_TRACE #undef BBB_XPORT_TRACE
usb_max_devs++;
if (ret) {
if (ret)
return ret;
} else {
usb_max_devs++;
if (ret < 0) {
if (ret)
return ret;
Why do we need to do this in device specific code?
Alex
- #if !defined(CONFIG_DM_SCSI) # ifdef CONFIG_SCSI_DEV_LIST # define SCSI_DEV_LIST CONFIG_SCSI_DEV_LIST
- ret = efi_disk_create(bdev);
- if (ret) {
return ret;
- ret = blk_create_partitions(bdev);
- if (ret < 0) {
return ret;
- if (verbose) { printf(" Device %d: ", 0); dev_print(bdesc);
} return 0; }debug("Found %d partitions\n", ret);
- EFI attributes of the udevice handled by this driver.
- Create partions for the block device.
- @handle EFI handle of the block device
- @dev udevice of the block device
- Create a block device for a handle
- if (ret)
return ret;
- ret = device_probe(bdev); if (ret) return ret; EFI_PRINT("%s: block device '%s' created\n", __func__, bdev->name);
- disks = blk_create_partitions(bdev); EFI_PRINT("Found %d partitions\n", disks);
- return 0; }
Alex,
diff --git a/common/usb_storage.c b/common/usb_storage.c index 8c889bb1a648..ff895c0e4557 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -46,6 +46,10 @@ #include <part.h> #include <usb.h> +/* FIXME */ +extern int efi_disk_create(struct udevice *dev); +extern int blk_create_partitions(struct udevice *parent);
#undef BBB_COMDAT_TRACE #undef BBB_XPORT_TRACE @@ -227,8 +231,27 @@ static int usb_stor_probe_device(struct usb_device *udev) ret = usb_stor_get_info(udev, data, blkdev); if (ret == 1) {
usb_max_devs++;
if (ret) {
if (ret)
return ret;
} else {
usb_max_devs++;
if (ret < 0) {
if (ret)
return ret;
Good point.
* efi_disk_create() As I said in the past, efi_disk_create() will expect that blk_desc has been initialized before it is called. (There may be some possibility of removing this assumption.)
Blk_desc is often initialized after blk_create_device() in a driver. So it won't be able to be placed in blk_create_device().
If, however, we have a "delayed" execution mechanism (like timer event as you suggested before), we may put this function in a single point.
* blk_create_partions() I initially thought of putting this function in part_init() which is to be called at "probe," but was concerned that there might be a chance that efi API be called before probing. If this is not the case, we may also place this function in a single point. (Unfortunately, "scsi rescan" won't kick off a probe hook though.)
Alex
diff --git a/drivers/scsi/scsi.c b/drivers/scsi/scsi.c index df47e2fc78bd..f0f8cbc0bf26 100644 --- a/drivers/scsi/scsi.c +++ b/drivers/scsi/scsi.c @@ -11,6 +11,10 @@ #include <dm/device-internal.h> #include <dm/uclass-internal.h> +/* FIXME */ +int efi_disk_create(struct udevice *dev); +int blk_create_partitions(struct udevice *parent);
- if (ret) {
return ret;
- if (ret < 0) {
return ret;
} return 0;debug("Found %d partitions\n", ret);
} diff --git a/lib/efi_driver/efi_block_device.c b/lib/efi_driver/efi_block_device.c index 3f147cf60879..4ab3402d6768 100644 --- a/lib/efi_driver/efi_block_device.c +++ b/lib/efi_driver/efi_block_device.c @@ -32,6 +32,10 @@ #include <dm/device-internal.h> #include <dm/root.h> +/* FIXME */ +extern int efi_disk_create(struct udevice *dev); +extern int blk_create_partitions(struct udevice *parent);
@@ -102,24 +106,6 @@ static ulong efi_bl_write(struct udevice *dev, lbaint_t blknr, lbaint_t blkcnt, return blkcnt; } -/*
- if (ret)
return ret;
Basic idea is
- create UCLASS_PARTITION
- enumerate all the partitions when a block device is probed
- hook up a creation of UCLASS_BLK or UCLASS_PARTITION device to efi handler for efi_disk attributes to be properly set up
I like the approach. It seems pretty clean and gives us a smooth transition from the split world to a unified all-dm world. Eventually the efi object list will just naturally disappear and we can drop all calls to add efi object handles.
Alex
Basic idea is
Alex
Thanks Takahiro, it is good to have a reference to work on to bring the worlds together.
I still have some issues:
The implementation lacks the driver binding protocol to handle block devices that are not discovered by U-Boot but supplied by an EFI driver or application. I would prefer if the block uclass would provide this protocol.
In EFI a handle can always be deleted by first stopping all controllers and then removing all protocols.
The current implementation of partitions tries to use a struct efi_obj instead of a handle. This is incompatible to the rest of the EFI subsystem.
Best regards
Heinrich
Heinrich,
Basic idea is
Alex
I don't yet have deep understandings of DM, but I believe that any UCLASS_BLK instance should have a backing block device, blk_desc, which is pointed to by uclass_platdata. But your efi block device, UCLASS_BLK/IF_TYPE_EFI, does never initialize this structure, in particular "ops," and so it won't work as a block device on u-boot side.
I guess that it is one of reasons that EFI block driver doesn't work with my patch.
If you agree with me, it would be much easier for you to modify EFI block driver :)
What do you mean by "delete?" Some efi object will directly use efi_add_handle(). Efi object is solely responsible for maintaining a handle.
How incompatible? A handle is always a pointer to opaque data outside the implementation. struct efi_obj in blk_desc is explicitly handled only in efi_disk.c. What's wrong with that?
-Takahiro Akashi
Best regards
Heinrich
participants (6)
AKASHI Takahiro
Alexander Graf
Philipp Tomsich
Sergey Kubushyn
