[U-Boot] [PATCH] freescale: m5253demo: fix unused-but-set-variable warnings
Fix the following warning messages:
In function 'flash_erase': 180:21: warning: variable 'last' set but not used [-Wunused-but-set-variable] In function 'write_buff': 322:10: warning: variable 'port_width' set but not used [-Wunused-but-set-variable]
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: TsiChung Liew Tsi-Chung.Liew@freescale.com --- board/freescale/m5253demo/flash.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/board/freescale/m5253demo/flash.c b/board/freescale/m5253demo/flash.c index 387e454..16bba59 100644 --- a/board/freescale/m5253demo/flash.c +++ b/board/freescale/m5253demo/flash.c @@ -177,7 +177,7 @@ int flash_erase(flash_info_t * info, int s_first, int s_last) { FPWV *addr; int flag, prot, sect, count; - ulong type, start, last; + ulong type, start; int rcode = 0, flashtype = 0;
if ((s_first < 0) || (s_first > s_last)) { @@ -217,7 +217,6 @@ int flash_erase(flash_info_t * info, int s_first, int s_last) flag = disable_interrupts();
start = get_timer(0); - last = start;
if ((s_last - s_first) == (CONFIG_SYS_SST_SECT - 1)) { if (prot == 0) { @@ -319,14 +318,13 @@ int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) { ulong wp, count; u16 data; - int rc, port_width; + int rc;
if (info->flash_id == FLASH_UNKNOWN) return 4;
/* get lower word aligned address */ wp = addr; - port_width = sizeof(FPW);
/* handle unaligned start bytes */ if (wp & 1) {
Masahiro Yamada
