[U-Boot] [PATCH v2] mvebu_mmc: Driver addition
In function mvebu_mmc_write notice command timeout. It is possible that a command is done, but a timeout occurred.
Enable timeout in set bus function.
Set window registers. Without that I could not use the driver on a Kirkwood 88F6282 SoC.
Set high capacity and 52MHz driver feature.
Signed-off-by: Mario Schuknecht mario.schuknecht@dresearch-fe.de ---
Changes in v2: - Correct indentation - Remove unneeded parentheses - Use correct coding style for multi-line statements
drivers/mmc/mvebu_mmc.c | 62 ++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 61 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mvebu_mmc.c b/drivers/mmc/mvebu_mmc.c index 9759198..d34e743 100644 --- a/drivers/mmc/mvebu_mmc.c +++ b/drivers/mmc/mvebu_mmc.c @@ -17,8 +17,12 @@ #include <asm/arch/kirkwood.h> #include <mvebu_mmc.h>
+DECLARE_GLOBAL_DATA_PTR; + #define DRIVER_NAME "MVEBU_MMC"
+#define MVEBU_TARGET_DRAM 0 + static void mvebu_mmc_write(u32 offs, u32 val) { writel(val, CONFIG_SYS_MMC_BASE + (offs)); @@ -164,6 +168,9 @@ static int mvebu_mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, return TIMEOUT; } } + if (mvebu_mmc_read(SDIO_ERR_INTR_STATUS) & + (SDIO_ERR_CMD_TIMEOUT | SDIO_ERR_DATA_TIMEOUT)) + return TIMEOUT;
/* Handling response */ if (cmd->resp_type & MMC_RSP_136) { @@ -271,6 +278,7 @@ static void mvebu_mmc_set_bus(unsigned int bus)
/* default to maximum timeout */ ctrl_reg |= SDIO_HOST_CTRL_TMOUT(SDIO_HOST_CTRL_TMOUT_MAX); + ctrl_reg |= SDIO_HOST_CTRL_TMOUT_EN;
ctrl_reg |= SDIO_HOST_CTRL_PUSH_PULL_EN;
@@ -296,6 +304,55 @@ static void mvebu_mmc_set_ios(struct mmc *mmc) mvebu_mmc_set_clk(mmc->clock); }
+/* + * Set window register. + */ +static void mvebu_window_setup(void) +{ + int i; + + for (i = 0; i < 4; i++) { + mvebu_mmc_write(WINDOW_CTRL(i), 0); + mvebu_mmc_write(WINDOW_BASE(i), 0); + } + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + u32 size, base, attrib; + + /* Enable DRAM bank */ + switch (i) { + case 0: + attrib = KWCPU_ATTR_DRAM_CS0; + break; + case 1: + attrib = KWCPU_ATTR_DRAM_CS1; + break; + case 2: + attrib = KWCPU_ATTR_DRAM_CS2; + break; + case 3: + attrib = KWCPU_ATTR_DRAM_CS3; + break; + default: + /* invalide bank, disable access */ + attrib = 0; + break; + } + + size = gd->bd->bi_dram[i].size; + base = gd->bd->bi_dram[i].start; + if (size && attrib) { + mvebu_mmc_write(WINDOW_CTRL(i), + MVCPU_WIN_CTRL_DATA(size, + MVEBU_TARGET_DRAM, + attrib, + MVCPU_WIN_ENABLE)); + } else { + mvebu_mmc_write(WINDOW_CTRL(i), MVCPU_WIN_DISABLE); + } + mvebu_mmc_write(WINDOW_BASE(i), base); + } +} + static int mvebu_mmc_initialize(struct mmc *mmc) { debug("%s: mvebu_mmc_initialize", DRIVER_NAME); @@ -322,6 +379,8 @@ static int mvebu_mmc_initialize(struct mmc *mmc) mvebu_mmc_write(SDIO_NOR_INTR_EN, 0); mvebu_mmc_write(SDIO_ERR_INTR_EN, 0);
+ mvebu_window_setup(); + /* SW reset */ mvebu_mmc_write(SDIO_SW_RESET, SDIO_SW_RESET_NOW);
@@ -342,7 +401,8 @@ static struct mmc_config mvebu_mmc_cfg = { .f_min = MVEBU_MMC_BASE_FAST_CLOCK / MVEBU_MMC_BASE_DIV_MAX, .f_max = MVEBU_MMC_CLOCKRATE_MAX, .voltages = MMC_VDD_32_33 | MMC_VDD_33_34, - .host_caps = MMC_MODE_4BIT | MMC_MODE_HS, + .host_caps = MMC_MODE_4BIT | MMC_MODE_HS | MMC_MODE_HC | + MMC_MODE_HS_52MHz, .part_type = PART_TYPE_DOS, .b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, };
Thanks, Stefan
Is there a chance that this patch [1] will be applied?
Mario
[1] http://lists.denx.de/pipermail/u-boot/2014-August/187109.html
2014-08-25 15:28 GMT+02:00 Stefan Roese sr@denx.de:
Thanks, Stefan
Hi Mario,
On Aug 25, 2014, at 3:12 PM, Mario Schuknecht mario.schuknecht@dresearch-fe.de wrote:
Changes in v2:
return TIMEOUT;
- Set window register.
- int i;
- for (i = 0; i < 4; i++) {
- for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) {
switch (i) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
attrib = 0;
break;
MVEBU_TARGET_DRAM,
attrib,
MVCPU_WIN_ENABLE));
} else {
- mvebu_window_setup();
- /* SW reset */ mvebu_mmc_write(SDIO_SW_RESET, SDIO_SW_RESET_NOW);
- .host_caps = MMC_MODE_4BIT | MMC_MODE_HS | MMC_MODE_HC |
.part_type = PART_TYPE_DOS, .b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT,MMC_MODE_HS_52MHz,
1.8.4.5
Applied, thanks
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
Mario Schuknecht
Pantelis Antoniou
Stefan Roese
