[PATCH] binman: btool: gzip: fix packer name so that binary can be found
From: Quentin Schulz quentin.schulz@theobroma-systems.com
The binary is looked on the system by the suffix of the packer class. This means binman was looking for btool_gzip on the system and not gzip.
Therefore, let's pass "gzip" as the name so that it can be found and used.
Fixes: 0f369d79925a ("binman: Add gzip bintool") Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- tools/binman/btool/btool_gzip.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/btool/btool_gzip.py b/tools/binman/btool/btool_gzip.py index 7bea300b5d..70cbc19f04 100644 --- a/tools/binman/btool/btool_gzip.py +++ b/tools/binman/btool/btool_gzip.py @@ -27,5 +27,5 @@ class Bintoolbtool_gzip(bintool.BintoolPacker): man gzip """ def __init__(self, name): - super().__init__(name, compress_args=[], + super().__init__("gzip", compress_args=[], version_regex=r'gzip ([0-9.]+)')
Oops! I wonder how we could test this? One way would be to require those tools to be present and write a test that reads the version, I suppose.
Hi Quentin,
Am 31.08.2022 um 19:44 schrieb Simon Glass:
Are you sure? I test it and the name is already gzip because the bintool is requested as gzip. The find_bintool_class function only change the class name.
We already have a test for the compressions: testCompUtilVersions
Regards Stefan
Hi Stefan,
On 9/1/22 08:12, Stefan Herbrechtsmeier wrote:
Hi Quentin,
From current master: tools/binman/binman tool --list Name Version Description Path --------------- ----------- ------------------------- ------------------------------ btool_gzip - btool_gzip compression (not found)
With my patch: tools/binman/binman tool --list Name Version Description Path --------------- ----------- ------------------------- ------------------------------ gzip 1.11 gzip compression /usr/bin/gzip
Bintool.get_tool_list will return btool_gzip. Bintool.list_all will then iterate over all tools and call Bintool.create(name) for each.
Bintool.create will call Bintool.find_bintool_class with btool_gzip and it'll return the Bintoolbtool_gzip class. Then its constructor will be called, with btool_gzip passed as argument, here: https://source.denx.de/u-boot/u-boot/-/blob/master/tools/binman/bintool.py#L...
This is because Bintool.create has no knowledge of btool_gzip actually being gzip unlike Bintool.find_bintool_class.
Another way to handle this, and without user intervention would be to remove btool_ prefix when listing the supported tools since Bintool.find_bintool_class will actually handle the case where the prefix is missing.
It'd be something like: diff --git a/tools/binman/bintool.py b/tools/binman/bintool.py index ec30ceff74..433ee87c46 100644 --- a/tools/binman/bintool.py +++ b/tools/binman/bintool.py @@ -135,6 +135,7 @@ class Bintool: names = [os.path.splitext(os.path.basename(fname))[0] for fname in files] names = [name for name in names if name[0] != '_'] + names = [name[6:] if name.startswith('btool_') else name for name in names] if include_testing: names.append('_testing') return sorted(names)
Which also makes sure that the tools are actually alphabetically ordered (it is currently ordered with the "btool_" prefix).
Now I have to ask... Why not simplify all this and force all bintools to be prefixed with btool_ so we do not have to care about different scenarii?
We'd need each btool class to provide the name of the binary expected to exist on a given system. Then we could mock calls to os.path.isfile and os.access in patman.tool_find and check that the correct string is searched for. If we don't have a hardcoded value that the developer had to put there, automated tests won't help anyways since here we'd have looked for btool_gzip in one of the mocked calls and that would have succeeded unfortunately.
If the tests are skipped because gzip is not found but is actually present, that is not great either.
I have nothing more interesting to offer though at the moment, I'm sorry.
Cheers, Quentin
Hi Quentin,
Am 01.09.2022 um 16:34 schrieb Quentin Schulz:
Hi Stefan,
Hi Quentin,
Ok, we use different ways to test it. I use the version test and this use a fixed gzip name as input.
I think this is a better solution.
This would make things easier.
The test isn't skipped because it use a fixed list of required tools (ex. gzip) and therefore work. The problem is the tools option which doesn't remove the prefix.
Regards Stefan
Hi Quentin,
Hi Stefan,
Hi Quentin,
Applied to u-boot-dm, thanks!
Hi Stefan,
On Thu, 1 Sept 2022 at 00:12, Stefan Herbrechtsmeier stefan.herbrechtsmeier-oss@weidmueller.com wrote:
Hi Quentin,
When I tested it, it was not picking up the correct version without this patch.
Regards Stefan
Quentin Schulz
Quentin Schulz
