[U-Boot] [PATCH] pcm052: fix MTD partitioning
MTD partitioning in current pcm052 configuration is inconsistent. Fix it across MTDPARTS_DEFAULT, CONFIG_EXTRA_ENV_SETTINGS, and CONFIG_ENV_OFFSET[_REDUND].
Signed-off-by: Albert ARIBAUD (3ADEV) albert.aribaud@3adev.fr ---
include/configs/pcm052.h | 120 +++++++++++++++++++++++++++++++++-------------- 1 file changed, 85 insertions(+), 35 deletions(-)
diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index 903f94c..150698e 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -60,14 +60,15 @@ #define CONFIG_CMD_MTDPARTS #define CONFIG_MTD_PARTITIONS #define CONFIG_MTD_DEVICE -#define MTDIDS_DEFAULT "nand0=NAND,nor0=qspi0-a,nor1=qspi0-b" +#define MTDIDS_DEFAULT "nand0=NAND" #define MTDPARTS_DEFAULT "mtdparts=NAND:256k(spare)"\ ",384k(bootloader)"\ ",128k(env1)"\ ",128k(env2)"\ - ",3840k(kernel)"\ - ",-(rootfs)"\ - ",qspi0-a:-(jffs2),qspio0-b:-(jffs2)" + ",128k(dtb)"\ + ",6144k(kernel)"\ + ",65536k(ramdisk)"\ + ",450944k(root)" #endif
#define CONFIG_MMC @@ -135,36 +136,85 @@ #define CONFIG_BOARD_SIZE_LIMIT 524288
#define CONFIG_BOOTCOMMAND "run bootcmd_sd" -#define CONFIG_EXTRA_ENV_SETTINGS \ - "bootfile=uImage\0" \ - "bootargs_base=setenv bootargs rw mem=256M " \ - "console=ttymxc1,115200n8\0" \ - "bootargs_sd=setenv bootargs ${bootargs} " \ - "root=/dev/mmcblk0p2 rootwait\0" \ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "blimg_file=u-boot.imx\0" \ + "blsec_addr=0x81000000\0" \ + "blimg_addr=0x81000400\0" \ + "kernel_file=zImage\0" \ + "kernel_addr=0x82000000\0" \ + "fdt_file=vf610-pcm052.dtb\0" \ + "fdt_addr=0x81000000\0" \ + "ram_file=uRamdisk\0" \ + "ram_addr=0x83000000\0" \ + "filesys=rootfs.ubifs\0" \ + "sys_addr=0x81000000\0" \ + "tftploc=/path/to/tftp/directory/\0" \ + "nfs_root=/path/to/nfs/root\0" \ + "tftptimeout=1000\0" \ + "tftptimeoutcountmax=1000000\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "bootargs_base=setenv bootargs rw mem=256M " \ + "console=ttyLP1,115200n8\0" \ + "bootargs_sd=setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk0p2 rootwait\0" \ "bootargs_net=setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp " \ - "nfsroot=${serverip}:${nfs_root},v3,tcp\0" \ - "bootargs_nand=setenv bootargs ${bootargs} " \ - "root=/dev/mtdblock2 rootfstype=jffs2\0" \ - "bootargs_mtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ - "bootcmd_sd=run bootargs_base bootargs_sd bootargs_mtd; mmc rescan; " \ - "fatload mmc 0:1 ${loadaddr} ${bootfile}; bootm ${loadaddr}\0" \ - "bootcmd_net=run bootargs_base bootargs_net bootargs_mtd; " \ - "tftpboot ${loadaddr} ${tftploc}${bootfile}; bootm\0" \ - "bootcmd_nand='run bootargs_base bootargs_nand bootargs_mtd; " \ - "nand read ${loadaddr} 0x000E0000 0x3C0000; " \ - "bootm ${loadaddr}\0" \ - "tftploc=/path/to/tftp/directory/\0" \ - "nfs_root=/path/to/nfs/root\0" \ - "mtdparts=" MTDPARTS_DEFAULT "\0" \ - "update_kernel_from_sd=mw.b $(loadaddr) 0xff 0x3C0000; " \ - "mmc rescan; fatload mmc 0:2 ${loadaddr} ${bootfile}; " \ - "nand erase 0xE0000 0x3C0000; " \ - "nand write.i ${loadaddr} 0xE0000 0x3C0000\0" \ - "update_rootfs_from_tftp=mw.b ${loadaddr} 0xff 0x8F20000; " \ - "tftp ${loadaddr} ${tftp}${filesys}; " \ - "nand erase 0x4A0000 0x8F20000; " \ - "nand write.i ${loadaddr} 0x4A0000 0x8F20000\0" \ - "filesys=rootfs.jffs2\0" + "nfsroot=${serverip}:${nfs_root},v3,tcp\0" \ + "bootargs_nand=setenv bootargs ${bootargs} " \ + "ubi.mtd=6 rootfstype=ubifs root=ubi0:rootfs\0" \ + "bootargs_ram=setenv bootargs ${bootargs} " \ + "root=/dev/ram rw initrd=${ram_addr}\0" \ + "bootargs_mtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "bootcmd_sd=run bootargs_base bootargs_sd bootargs_mtd; " \ + "fatload mmc 0:1 ${kernel_addr} ${kernel_file}; " \ + "fatload mmc 0:1 ${fdt_addr} ${fdt_file}; " \ + "bootz ${kernel_addr} - ${fdt_addr}\0" \ + "bootcmd_net=run bootargs_base bootargs_net bootargs_mtd; " \ + "tftpboot ${kernel_addr} ${tftpdir}${kernel_file}; " \ + "tftpboot ${fdt_addr} ${tftpdir}${fdt_file}; " \ + "bootz ${kernel_addr} - ${fdt_addr}\0" \ + "bootcmd_nand=run bootargs_base bootargs_nand bootargs_mtd; " \ + "nand read ${fdt_addr} dtb; " \ + "nand read ${kernel_addr} kernel; " \ + "bootz ${kernel_addr} - ${fdt_addr}\0" \ + "bootcmd_ram=run bootargs_base bootargs_ram bootargs_mtd; " \ + "nand read ${fdt_addr} dtb; " \ + "nand read ${kernel_addr} kernel; " \ + "nand read ${ram_addr} ramdisk; " \ + "bootz ${kernel_addr} ${ram_addr} ${fdt_addr}\0" \ + "update_bootloader_from_tftp=mtdparts default; " \ + "nand read ${blsec_addr} bootloader; " \ + "mw.b ${blimg_addr} 0xff 0x5FC00; " \ + "if tftp ${blimg_addr} ${tftpdir}${blimg_file}; then " \ + "nand erase.part bootloader; " \ + "nand write ${blsec_addr} bootloader ${filesize}; fi\0" \ + "update_kernel_from_sd=if fatload mmc 0:2 ${kernel_addr} " \ + "${kernel_file}; " \ + "then mtdparts default; " \ + "nand erase.part kernel; " \ + "nand write ${kernel_addr} kernel ${filesize}; " \ + "if fatload mmc 0:2 ${fdt_addr} ${fdt_file}; then " \ + "nand erase.part dtb; " \ + "nand write ${fdt_addr} dtb ${filesize}; fi\0" \ + "update_kernel_from_tftp=if tftp ${fdt_addr} ${tftpdir}${fdt_file}; " \ + "then setenv fdtsize ${filesize}; " \ + "if tftp ${kernel_addr} ${tftpdir}${kernel_file}; then " \ + "mtdparts default; " \ + "nand erase.part dtb; " \ + "nand write ${fdt_addr} dtb ${fdtsize}; " \ + "nand erase.part kernel; " \ + "nand write ${kernel_addr} kernel ${filesize}; fi; fi\0" \ + "update_rootfs_from_tftp=if tftp ${sys_addr} ${tftpdir}${filesys}; " \ + "then mtdparts default; " \ + "nand erase.part root; " \ + "ubi part root; " \ + "ubi create rootfs; " \ + "ubi write ${sys_addr} rootfs ${filesize}; fi\0" \ + "update_ramdisk_from_tftp=if tftp ${ram_addr} ${tftpdir}${ram_file}; " \ + "then mtdparts default; " \ + "nand erase.part ramdisk; " \ + "nand write ${ram_addr} ramdisk ${filesize}; fi\0"
/* miscellaneous commands */ #define CONFIG_CMD_ELF @@ -220,9 +270,9 @@ #ifdef CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_OFFSET 0x80000 +#define CONFIG_ENV_OFFSET 0xA0000 #define CONFIG_ENV_SIZE_REDUND (8 * 1024) -#define CONFIG_ENV_OFFSET_REDUND 0xA0000 +#define CONFIG_ENV_OFFSET_REDUND 0xC0000 #endif
#define CONFIG_OF_LIBFDT
Bonjour Tom,
Great, thanks!
Cordialement, Albert ARIBAUD 3ADEV
Albert ARIBAUD
