[U-Boot] [PATCH] spi: Use DIV_ROUND_UP at appropriate places
This change slightly improves readability.
Signed-off-by: Axel Lin axel.lin@ingics.com --- drivers/spi/cf_qspi.c | 2 +- drivers/spi/mxc_spi.c | 6 +++--- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/cf_qspi.c b/drivers/spi/cf_qspi.c index a37ac4e..06bcf91 100644 --- a/drivers/spi/cf_qspi.c +++ b/drivers/spi/cf_qspi.c @@ -171,7 +171,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, volatile qspi_t *qspi = dev->regs; u8 *txbuf = (u8 *)dout; u8 *rxbuf = (u8 *)din; - u32 count = ((bitlen / 8) + (bitlen % 8 ? 1 : 0)); + u32 count = DIV_ROUND_UP(bitlen, 8); u32 n, i = 0;
/* Sanitize arguments */ diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 5bed858..2ea3228 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -224,7 +224,7 @@ int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, const u8 *dout, u8 *din, unsigned long flags) { struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); - int nbytes = (bitlen + 7) / 8; + int nbytes = DIV_ROUND_UP(bitlen, 8); u32 data, cnt, i; struct cspi_regs *regs = (struct cspi_regs *)mxcs->base;
@@ -294,7 +294,7 @@ int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, /* Transfer completed, clear any pending request */ reg_write(®s->stat, MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF);
- nbytes = (bitlen + 7) / 8; + nbytes = DIV_ROUND_UP(bitlen, 8);
cnt = nbytes % 32;
@@ -330,7 +330,7 @@ int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { - int n_bytes = (bitlen + 7) / 8; + int n_bytes = DIV_ROUND_UP(bitlen, 8); int n_bits; int ret; u32 blk_size;
IMHO: Can you please use the proper commit header prefix.
I am just sharing my thoughts, ignore this if you know it already. I followed below syntax. "<main_module>: <sub_module>: <sub_sub_module>: <COMMIT_HEADER>"
Ex: for this commit (seems like this commit changes two drivers) spi: cf_qspi | mxc_spi: Use DIV_ROUND_UP at appropriate places
if you send same changes individually. spi: cf_qspi: Use DIV_ROUND_UP at appropriate places spi: mxc_spi: Use DIV_ROUND_UP at appropriate places
Was this equivalent to (bitlen + 7) / 8 ?
-- Thanks, Jagan.
2013/6/14 Jagan Teki jagannadh.teki@gmail.com:
This does not scale. What if a (trivial) patch touches 10 drivers?
I was thinking doing so may add maintainer's burden. (well for this case with 2 patches, it's not a problem) But since you prefer sending a fix per driver, I'll resend the patches.
Yes. And that is the point of this patch ( to handle divide-round-up in a uniform way).
-- Thanks, Jagan.
Yes, you are correct if the changes is common to across the all drivers or If the changes which are more in 10 spi drivers out of 20 or > 10 for your example - use "spi: " and I think it's good to use above syntax as you changesd two drivers.
I am just showing the possibilities of using the coding guidelines, nothing more.
-- Thanks, Jagan.
There is another issue: patman recognizes each <subpart>: and checks for an alias to find the e-mail to send patches, and stops to go on if it is not found. In this example, you can use patman if there is an entry for spi: (and this is you as SPI custodian) and also for mxc_spi:, and usually there is no maintainer for each driver. I agree that using a long chain does not scale, and I think the hidden rule to use subsystem: <subject> works well in most cases, Axel did in this patchset.
Regards, Stefano
On 14/06/13 09:09 AM, Axel Lin wrote:
2013/6/14 Jagan Tekijagannadh.teki@gmail.com:
I am just sharing my thoughts, ignore this if you know it already. I followed below syntax. "<main_module>:<sub_module>:<sub_sub_module>:<COMMIT_HEADER>"
Depends how trivial it is I guess. I can see benefits to both approaches.
This one is simple enough that I am okay if it is grouped.
Just for my own education, how do I correctly ACK just the part I know (mcf_qspi in this case) in a grouped patch? Is there a way to automate my "Signed-off-by:" via e-mail?
-- Richard Retanubun
Signed-off-by: Axel Linaxel.lin@ingics.com
-- Thanks, Jagan.
On Fri, Jun 14, 2013 at 6:54 PM, Richard Retanubun richardretanubun@ruggedcom.com wrote:
Usually normal mail server like gmail or outlook doesn' update these s-o-b or a-b use thunderbread mail logic, that will automate when u did these changes.
-- Thanks, Jagan.
Axel Lin
Jagan Teki
Richard Retanubun
Stefano Babic
