[U-Boot] [PATCH 2/4 v2] s5pc1xx: support onenand driver
This patch includes the onenand driver for s5pc100
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- drivers/mtd/onenand/Makefile | 2 + drivers/mtd/onenand/samsung.c | 626 +++++++++++++++++++++++++++++++++++ include/linux/mtd/onenand.h | 1 + include/linux/mtd/onenand_regs.h | 4 + include/linux/mtd/samsung_onenand.h | 132 ++++++++ 5 files changed, 765 insertions(+), 0 deletions(-) create mode 100644 drivers/mtd/onenand/samsung.c create mode 100644 include/linux/mtd/samsung_onenand.h
diff --git a/drivers/mtd/onenand/Makefile b/drivers/mtd/onenand/Makefile index 1d35a57..9317341 100644 --- a/drivers/mtd/onenand/Makefile +++ b/drivers/mtd/onenand/Makefile @@ -26,6 +26,8 @@ include $(TOPDIR)/config.mk LIB := $(obj)libonenand.a
COBJS-$(CONFIG_CMD_ONENAND) := onenand_uboot.o onenand_base.o onenand_bbt.o +COBJS-$(CONFIG_S3C64XX) += samsung.o +COBJS-$(CONFIG_S5PC1XX) += samsung.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c new file mode 100644 index 0000000..03dfff8 --- /dev/null +++ b/drivers/mtd/onenand/samsung.c @@ -0,0 +1,626 @@ +/* + * S3C64XX/S5PC100 OneNAND driver at U-Boot + * + * Copyright (C) 2008-2009 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * Implementation: + * Emulate the pseudo BufferRAM + */ + +#include <common.h> +#include <malloc.h> +#include <linux/mtd/compat.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/onenand.h> +#include <linux/mtd/samsung_onenand.h> + +#include <asm/io.h> +#include <asm/errno.h> + +#ifdef ONENAND_DEBUG +#define DPRINTK(format, args...) \ +do { \ + printf("%s[%d]: " format "\n", __func__, __LINE__, ##args); \ +} while (0) +#else +#define DPRINTK(...) do { } while (0) +#endif + +#define ONENAND_ERASE_STATUS 0x00 +#define ONENAND_MULTI_ERASE_SET 0x01 +#define ONENAND_ERASE_START 0x03 +#define ONENAND_UNLOCK_START 0x08 +#define ONENAND_UNLOCK_END 0x09 +#define ONENAND_LOCK_START 0x0A +#define ONENAND_LOCK_END 0x0B +#define ONENAND_LOCK_TIGHT_START 0x0C +#define ONENAND_LOCK_TIGHT_END 0x0D +#define ONENAND_UNLOCK_ALL 0x0E +#define ONENAND_OTP_ACCESS 0x12 +#define ONENAND_SPARE_ACCESS_ONLY 0x13 +#define ONENAND_MAIN_ACCESS_ONLY 0x14 +#define ONENAND_ERASE_VERIFY 0x15 +#define ONENAND_MAIN_SPARE_ACCESS 0x16 +#define ONENAND_PIPELINE_READ 0x4000 + +#if defined(CONFIG_S3C64XX) +#define MAP_00 (0x0 << 24) +#define MAP_01 (0x1 << 24) +#define MAP_10 (0x2 << 24) +#define MAP_11 (0x3 << 24) + +#elif defined(CONFIG_S5PC1XX) +#define MAP_00 (0x0 << 26) +#define MAP_01 (0x1 << 26) +#define MAP_10 (0x2 << 26) +#define MAP_11 (0x3 << 26) + +#endif + +/* The 'addr' is byte address. It makes a 16-bit word */ +#define CMD_MAP_00(addr) (MAP_00 | ((addr) << 1)) +#define CMD_MAP_01(mem_addr) (MAP_01 | (mem_addr)) +#define CMD_MAP_10(mem_addr) (MAP_10 | (mem_addr)) +#define CMD_MAP_11(addr) (MAP_11 | ((addr) << 2)) + +struct s3c_onenand { + struct mtd_info *mtd; + + void __iomem *base; + void __iomem *ahb_addr; + + int bootram_command; + + void __iomem *page_buf; + void __iomem *oob_buf; + + unsigned int (*mem_addr)(int fba, int fpa, int fsa); + + struct samsung_onenand *reg; +}; + +static struct s3c_onenand *onenand; + +static int s3c_read_cmd(unsigned int cmd) +{ + return readl(onenand->ahb_addr + cmd); +} + +static void s3c_write_cmd(int value, unsigned int cmd) +{ + writel(value, onenand->ahb_addr + cmd); +} + +/* + * 1Gb: FBA[21:12] FPA[11:6] FSA[5:4] + * 2Gb: FBA[22:12] FPA[11:6] FSA[5:4] + * 4Gb: FBA[23:12] FPA[11:6] FSA[5:4] + */ +static unsigned int s3c64xx_mem_addr(int fba, int fpa, int fsa) +{ + return (fba << 12) | (fpa << 6) | (fsa << 4); +} + +/* + * 1Gb: FBA[22:13] FPA[12:7] FSA[6:5] + * 2Gb: FBA[23:13] FPA[12:7] FSA[6:5] + * 4Gb: FBA[24:13] FPA[12:7] FSA[6:5] + */ +static unsigned int s5pc100_mem_addr(int fba, int fpa, int fsa) +{ + return (fba << 13) | (fpa << 7) | (fsa << 5); +} + +static void s3c_onenand_reset(void) +{ + unsigned long timeout = 0x10000; + int stat; + + writel(ONENAND_MEM_RESET_COLD, &onenand->reg->MEM_RESET); + while (timeout--) { + stat = readl(&onenand->reg->INT_ERR_STAT); + if (stat & RST_CMP) + break; + } + stat = readl(&onenand->reg->INT_ERR_STAT); + writel(stat, &onenand->reg->INT_ERR_ACK); + + /* Clear interrupt */ + writel(0x0, &onenand->reg->INT_ERR_ACK); + /* Clear the ECC status */ + writel(0x0, &onenand->reg->ECC_ERR_STAT); +} + +static unsigned short s3c_onenand_readw(void __iomem *addr) +{ + struct onenand_chip *this = onenand->mtd->priv; + int reg = addr - this->base; + int word_addr = reg >> 1; + int value; + + /* It's used for probing time */ + switch (reg) { + case ONENAND_REG_MANUFACTURER_ID: + return readl(&onenand->reg->MANUFACT_ID); + case ONENAND_REG_DEVICE_ID: + return readl(&onenand->reg->DEVICE_ID); + case ONENAND_REG_VERSION_ID: + return readl(&onenand->reg->FLASH_VER_ID); + case ONENAND_REG_DATA_BUFFER_SIZE: + return readl(&onenand->reg->DATA_BUF_SIZE); + case ONENAND_REG_TECHNOLOGY: + return readl(&onenand->reg->TECH); + case ONENAND_REG_SYS_CFG1: + return readl(&onenand->reg->MEM_CFG); + + /* Used at unlock all status */ + case ONENAND_REG_CTRL_STATUS: + return 0; + + case ONENAND_REG_WP_STATUS: + return ONENAND_WP_US; + + default: + break; + } + + /* BootRAM access control */ + if (reg < ONENAND_DATARAM && onenand->bootram_command) { + if (word_addr == 0) + return readl(&onenand->reg->MANUFACT_ID); + if (word_addr == 1) + return readl(&onenand->reg->DEVICE_ID); + if (word_addr == 2) + return readl(&onenand->reg->FLASH_VER_ID); + } + + value = s3c_read_cmd(CMD_MAP_11(word_addr)) & 0xffff; + printk(KERN_INFO "s3c_onenand_readw: Illegal access" + " at reg 0x%x, value 0x%x\n", word_addr, value); + return value; +} + +static void s3c_onenand_writew(unsigned short value, void __iomem *addr) +{ + struct onenand_chip *this = onenand->mtd->priv; + int reg = addr - this->base; + int word_addr = reg >> 1; + + /* It's used for probing time */ + switch (reg) { + case ONENAND_REG_SYS_CFG1: + writel(value, &onenand->reg->MEM_CFG); + return; + + case ONENAND_REG_START_ADDRESS1: + case ONENAND_REG_START_ADDRESS2: + return; + + /* Lock/lock-tight/unlock/unlock_all */ + case ONENAND_REG_START_BLOCK_ADDRESS: + return; + + default: + break; + } + + /* BootRAM access control */ + if (reg < ONENAND_DATARAM) { + if (value == ONENAND_CMD_READID) { + onenand->bootram_command = 1; + return; + } + if (value == ONENAND_CMD_RESET) { + writel(ONENAND_MEM_RESET_COLD, + &onenand->reg->MEM_RESET); + onenand->bootram_command = 0; + return; + } + } + + printk(KERN_INFO "s3c_onenand_writew: Illegal access" + " at reg 0x%x, value 0x%x\n", word_addr, value); + + s3c_write_cmd(value, CMD_MAP_11(word_addr)); +} + +static int s3c_onenand_wait(struct mtd_info *mtd, int state) +{ + unsigned int flags = INT_ACT; + unsigned int stat, ecc; + unsigned long timeout = 0x100000; + + switch (state) { + case FL_READING: + flags |= BLK_RW_CMP | LOAD_CMP; + break; + case FL_WRITING: + flags |= BLK_RW_CMP | PGM_CMP; + break; + case FL_ERASING: + flags |= BLK_RW_CMP | ERS_CMP; + break; + case FL_LOCKING: + flags |= BLK_RW_CMP; + break; + default: + break; + } + + while (timeout--) { + stat = readl(&onenand->reg->INT_ERR_STAT); + if (stat & flags) + break; + } + + /* To get correct interrupt status in timeout case */ + stat = readl(&onenand->reg->INT_ERR_STAT); + writel(stat, &onenand->reg->INT_ERR_ACK); + + /* + * In the Spec. it checks the controller status first + * However if you get the correct information in case of + * power off recovery (POR) test, it should read ECC status first + */ + if (stat & LOAD_CMP) { + ecc = readl(&onenand->reg->ECC_ERR_STAT); + if (ecc & ONENAND_ECC_4BIT_UNCORRECTABLE) { + printk(KERN_INFO "%s: ECC error = 0x%04x\n", + __func__, ecc); + mtd->ecc_stats.failed++; + return -EBADMSG; + } + } + + if (stat & (LOCKED_BLK | ERS_FAIL | PGM_FAIL | LD_FAIL_ECC_ERR)) { + printk(KERN_INFO "%s: controller error = 0x%04x\n", + __func__, stat); + if (stat & LOCKED_BLK) + printk(KERN_INFO "%s: it's locked error = 0x%04x\n", + __func__, stat); + + return -EIO; + } + + return 0; +} + +static int s3c_onenand_command(struct mtd_info *mtd, int cmd, + loff_t addr, size_t len) +{ + struct onenand_chip *this = mtd->priv; + unsigned int *m, *s; + int fba, fpa, fsa = 0; + unsigned int mem_addr; + int i, mcount, scount; + int index; + + fba = (int) (addr >> this->erase_shift); + fpa = (int) (addr >> this->page_shift); + fpa &= this->page_mask; + + mem_addr = onenand->mem_addr(fba, fpa, fsa); + + switch (cmd) { + case ONENAND_CMD_READ: + case ONENAND_CMD_READOOB: + case ONENAND_CMD_BUFFERRAM: + ONENAND_SET_NEXT_BUFFERRAM(this); + default: + break; + } + + index = ONENAND_CURRENT_BUFFERRAM(this); + + /* + * Emulate Two BufferRAMs and access with 4 bytes pointer + */ + m = (unsigned int *) onenand->page_buf; + s = (unsigned int *) onenand->oob_buf; + + if (index) { + m += (this->writesize >> 2); + s += (mtd->oobsize >> 2); + } + + mcount = mtd->writesize >> 2; + scount = mtd->oobsize >> 2; + + switch (cmd) { + case ONENAND_CMD_READ: + /* Main */ + for (i = 0; i < mcount; i++) + *m++ = s3c_read_cmd(CMD_MAP_01(mem_addr)); + return 0; + + case ONENAND_CMD_READOOB: + writel(TSRF, &onenand->reg->TRANS_SPARE); + /* Main */ + for (i = 0; i < mcount; i++) + *m++ = s3c_read_cmd(CMD_MAP_01(mem_addr)); + + /* Spare */ + for (i = 0; i < scount; i++) + *s++ = s3c_read_cmd(CMD_MAP_01(mem_addr)); + + writel(0, &onenand->reg->TRANS_SPARE); + return 0; + + case ONENAND_CMD_PROG: + /* Main */ + for (i = 0; i < mcount; i++) + s3c_write_cmd(*m++, CMD_MAP_01(mem_addr)); + return 0; + + case ONENAND_CMD_PROGOOB: + writel(TSRF, &onenand->reg->TRANS_SPARE); + + /* Main - dummy write */ + for (i = 0; i < mcount; i++) + s3c_write_cmd(0xffffffff, CMD_MAP_01(mem_addr)); + + /* Spare */ + for (i = 0; i < scount; i++) + s3c_write_cmd(*s++, CMD_MAP_01(mem_addr)); + + writel(0, &onenand->reg->TRANS_SPARE); + return 0; + + case ONENAND_CMD_UNLOCK_ALL: + s3c_write_cmd(ONENAND_UNLOCK_ALL, CMD_MAP_10(mem_addr)); + return 0; + + case ONENAND_CMD_ERASE: + s3c_write_cmd(ONENAND_ERASE_START, CMD_MAP_10(mem_addr)); + return 0; + + case ONENAND_CMD_MULTIBLOCK_ERASE: + s3c_write_cmd(ONENAND_MULTI_ERASE_SET, CMD_MAP_10(mem_addr)); + return 0; + + case ONENAND_CMD_ERASE_VERIFY: + s3c_write_cmd(ONENAND_ERASE_VERIFY, CMD_MAP_10(mem_addr)); + return 0; + + default: + break; + } + + return 0; +} + +static unsigned char *s3c_get_bufferram(struct mtd_info *mtd, int area) +{ + struct onenand_chip *this = mtd->priv; + int index = ONENAND_CURRENT_BUFFERRAM(this); + unsigned char *p; + + if (area == ONENAND_DATARAM) { + p = (unsigned char *) onenand->page_buf; + if (index == 1) + p += this->writesize; + } else { + p = (unsigned char *) onenand->oob_buf; + if (index == 1) + p += mtd->oobsize; + } + + return p; +} + +static int onenand_read_bufferram(struct mtd_info *mtd, loff_t addr, int area, + unsigned char *buffer, int offset, + size_t count) +{ + unsigned char *p; + + p = s3c_get_bufferram(mtd, area); + memcpy(buffer, p + offset, count); + return 0; +} + +static int onenand_write_bufferram(struct mtd_info *mtd, loff_t addr, int area, + const unsigned char *buffer, int offset, + size_t count) +{ + unsigned char *p; + + p = s3c_get_bufferram(mtd, area); + memcpy(p + offset, buffer, count); + return 0; +} + +static int s3c_onenand_bbt_wait(struct mtd_info *mtd, int state) +{ + struct samsung_onenand *reg = (struct samsung_onenand *)onenand->base; + unsigned int flags = INT_ACT | LOAD_CMP; + unsigned int stat; + unsigned long timeout = 0x10000; + + while (timeout--) { + stat = readl(®->INT_ERR_STAT); + if (stat & flags) + break; + } + /* To get correct interrupt status in timeout case */ + stat = readl(&onenand->reg->INT_ERR_STAT); + writel(stat, &onenand->reg->INT_ERR_ACK); + + if (stat & LD_FAIL_ECC_ERR) { + s3c_onenand_reset(); + return ONENAND_BBT_READ_ERROR; + } + + if (stat & LOAD_CMP) { + int ecc = readl(&onenand->reg->ECC_ERR_STAT); + if (ecc & ONENAND_ECC_4BIT_UNCORRECTABLE) { + s3c_onenand_reset(); + return ONENAND_BBT_READ_ERROR; + } + } + + return 0; +} + +static void s3c_onenand_check_lock_status(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + unsigned int block, end; + int tmp; + + end = this->chipsize >> this->erase_shift; + + for (block = 0; block < end; block++) { + tmp = s3c_read_cmd(CMD_MAP_01(onenand->mem_addr(block, 0, 0))); + + if (readl(&onenand->reg->INT_ERR_STAT) & LOCKED_BLK) { + printf("block %d is write-protected!\n", block); + writel(LOCKED_BLK, &onenand->reg->INT_ERR_ACK); + } + } +} + +static void s3c_onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, + size_t len, int cmd) +{ + struct onenand_chip *this = mtd->priv; + int start, end, start_mem_addr, end_mem_addr; + + start = ofs >> this->erase_shift; + start_mem_addr = onenand->mem_addr(start, 0, 0); + end = start + (len >> this->erase_shift) - 1; + end_mem_addr = onenand->mem_addr(end, 0, 0); + + if (cmd == ONENAND_CMD_LOCK) { + s3c_write_cmd(ONENAND_LOCK_START, CMD_MAP_10(start_mem_addr)); + s3c_write_cmd(ONENAND_LOCK_END, CMD_MAP_10(end_mem_addr)); + } else { + s3c_write_cmd(ONENAND_UNLOCK_START, CMD_MAP_10(start_mem_addr)); + s3c_write_cmd(ONENAND_UNLOCK_END, CMD_MAP_10(end_mem_addr)); + } + + this->wait(mtd, FL_LOCKING); +} + +static void s3c_onenand_unlock_all(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + loff_t ofs = 0; + size_t len = this->chipsize; + + /* FIXME workaround */ + this->subpagesize = mtd->writesize; + mtd->subpage_sft = 0; + + if (this->options & ONENAND_HAS_UNLOCK_ALL) { + /* Write unlock command */ + this->command(mtd, ONENAND_CMD_UNLOCK_ALL, 0, 0); + + /* No need to check return value */ + this->wait(mtd, FL_LOCKING); + + /* Workaround for all block unlock in DDP */ + if (!ONENAND_IS_DDP(this)) { + s3c_onenand_check_lock_status(mtd); + return; + } + + /* All blocks on another chip */ + ofs = this->chipsize >> 1; + len = this->chipsize >> 1; + } + + s3c_onenand_do_lock_cmd(mtd, ofs, len, ONENAND_CMD_UNLOCK); + + s3c_onenand_check_lock_status(mtd); +} + +#ifdef CONFIG_S3C64XX +static void s3c_set_width_regs(struct onenand_chip *this) +{ + int dev_id, density; + int fba, fpa, fsa; + int dbs_dfs; + + dev_id = DEVICE_ID0_REG; + + density = (dev_id >> ONENAND_DEVICE_DENSITY_SHIFT) & 0xf; + dbs_dfs = !!(dev_id & ONENAND_DEVICE_IS_DDP); + + fba = density + 7; + if (dbs_dfs) + fba--; /* Decrease the fba */ + fpa = 6; + if (density >= ONENAND_DEVICE_DENSITY_512Mb) + fsa = 2; + else + fsa = 1; + + DPRINTK("FBA %lu, FPA %lu, FSA %lu, DDP %lu", + FBA_WIDTH0_REG, FPA_WIDTH0_REG, FSA_WIDTH0_REG, + DDP_DEVICE_REG); + + DPRINTK("mem_cfg0 0x%lx, sync mode %lu, " + "dev_page_size %lu, BURST LEN %lu", + MEM_CFG0_REG, SYNC_MODE_REG, + DEV_PAGE_SIZE_REG, BURST_LEN0_REG); + + DEV_PAGE_SIZE_REG = 0x1; + + FBA_WIDTH0_REG = fba; + FPA_WIDTH0_REG = fpa; + FSA_WIDTH0_REG = fsa; + DBS_DFS_WIDTH0_REG = dbs_dfs; +} +#endif + +void s3c_onenand_init(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + + onenand = malloc(sizeof(struct s3c_onenand)); + if (!onenand) + return; + + onenand->page_buf = malloc(SZ_4K * sizeof(char)); + if (!onenand->page_buf) + return; + memset(onenand->page_buf, 0xFF, SZ_4K); + + onenand->oob_buf = malloc(128 * sizeof(char)); + if (!onenand->oob_buf) + return; + memset(onenand->oob_buf, 0xFF, 128); + + onenand->mtd = mtd; + +#ifdef CONFIG_S5PC1XX + /* S5PC100 specific values */ + onenand->base = (void *) 0xE7100000; + onenand->ahb_addr = (void *) 0xB0000000; + onenand->mem_addr = s5pc100_mem_addr; +#else + onenand->base = (void *) 0x70100000; + onenand->ahb_addr = (void *) 0x20000000; + onenand->mem_addr = s3c64xx_mem_addr; +#endif + onenand->reg = (struct samsung_onenand *)onenand->base; + + this->read_word = s3c_onenand_readw; + this->write_word = s3c_onenand_writew; + + this->wait = s3c_onenand_wait; + this->bbt_wait = s3c_onenand_bbt_wait; + this->unlock_all = s3c_onenand_unlock_all; + this->command = s3c_onenand_command; + + this->read_bufferram = onenand_read_bufferram; + this->write_bufferram = onenand_write_bufferram; + + this->options |= ONENAND_RUNTIME_BADBLOCK_CHECK; +} diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 06f7baf..9a6f317 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -135,6 +135,7 @@ struct onenand_chip { #define ONENAND_HAS_CONT_LOCK (0x0001) #define ONENAND_HAS_UNLOCK_ALL (0x0002) #define ONENAND_HAS_2PLANE (0x0004) +#define ONENAND_RUNTIME_BADBLOCK_CHECK (0x0200) #define ONENAND_PAGEBUF_ALLOC (0x1000) #define ONENAND_OOBBUF_ALLOC (0x2000)
diff --git a/include/linux/mtd/onenand_regs.h b/include/linux/mtd/onenand_regs.h index fc63380..07fed1c 100644 --- a/include/linux/mtd/onenand_regs.h +++ b/include/linux/mtd/onenand_regs.h @@ -121,6 +121,8 @@ #define ONENAND_CMD_LOCK_TIGHT (0x2C) #define ONENAND_CMD_UNLOCK_ALL (0x27) #define ONENAND_CMD_ERASE (0x94) +#define ONENAND_CMD_MULTIBLOCK_ERASE (0x95) +#define ONENAND_CMD_ERASE_VERIFY (0x71) #define ONENAND_CMD_RESET (0xF0) #define ONENAND_CMD_READID (0x90)
@@ -184,7 +186,9 @@ * ECC Status Reigser FF00h (R) */ #define ONENAND_ECC_1BIT (1 << 0) +#define ONENAND_ECC_1BIT_ALL (0x5555) #define ONENAND_ECC_2BIT (1 << 1) #define ONENAND_ECC_2BIT_ALL (0xAAAA) +#define ONENAND_ECC_4BIT_UNCORRECTABLE (0x1010)
#endif /* __ONENAND_REG_H */ diff --git a/include/linux/mtd/samsung_onenand.h b/include/linux/mtd/samsung_onenand.h new file mode 100644 index 0000000..d389606 --- /dev/null +++ b/include/linux/mtd/samsung_onenand.h @@ -0,0 +1,132 @@ +/* + * Copyright (C) 2005-2009 Samsung Electronics + * Minkyu Kang mk7.kang@samsung.com + * Kyungmin Park kyungmin.park@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __SAMSUNG_ONENAND_H__ +#define __SAMSUNG_ONENAND_H__ + +#include <asm/hardware.h> + +/* + * OneNAND Controller + */ + +#ifndef __ASSEMBLY__ +struct samsung_onenand { + unsigned long MEM_CFG; /* 0x0000 */ + unsigned char res1[0xc]; + unsigned long BURST_LEN; /* 0x0010 */ + unsigned char res2[0xc]; + unsigned long MEM_RESET; /* 0x0020 */ + unsigned char res3[0xc]; + unsigned long INT_ERR_STAT; /* 0x0030 */ + unsigned char res4[0xc]; + unsigned long INT_ERR_MASK; /* 0x0040 */ + unsigned char res5[0xc]; + unsigned long INT_ERR_ACK; /* 0x0050 */ + unsigned char res6[0xc]; + unsigned long ECC_ERR_STAT; /* 0x0060 */ + unsigned char res7[0xc]; + unsigned long MANUFACT_ID; /* 0x0070 */ + unsigned char res8[0xc]; + unsigned long DEVICE_ID; /* 0x0080 */ + unsigned char res9[0xc]; + unsigned long DATA_BUF_SIZE; /* 0x0090 */ + unsigned char res10[0xc]; + unsigned long BOOT_BUF_SIZE; /* 0x00A0 */ + unsigned char res11[0xc]; + unsigned long BUF_AMOUNT; /* 0x00B0 */ + unsigned char res12[0xc]; + unsigned long TECH; /* 0x00C0 */ + unsigned char res13[0xc]; + unsigned long FBA; /* 0x00D0 */ + unsigned char res14[0xc]; + unsigned long FPA; /* 0x00E0 */ + unsigned char res15[0xc]; + unsigned long FSA; /* 0x00F0 */ + unsigned char res16[0x3c]; + unsigned long SYNC_MODE; /* 0x0130 */ + unsigned char res17[0xc]; + unsigned long TRANS_SPARE; /* 0x0140 */ + unsigned char res18[0x3c]; + unsigned long ERR_PAGE_ADDR; /* 0x0180 */ + unsigned char res19[0x1c]; + unsigned long INT_PIN_EN; /* 0x01A0 */ + unsigned char res20[0x1c]; + unsigned long ACC_CLOCK; /* 0x01C0 */ + unsigned char res21[0x1c]; + unsigned long ERR_BLK_ADDR; /* 0x01E0 */ + unsigned char res22[0xc]; + unsigned long FLASH_VER_ID; /* 0x01F0 */ + unsigned char res23[0x6c]; + unsigned long WATCHDOG_CNT_LOW; /* 0x0260 */ + unsigned char res24[0xc]; + unsigned long WATCHDOG_CNT_HI; /* 0x0270 */ + unsigned char res25[0xc]; + unsigned long SYNC_WRITE; /* 0x0280 */ + unsigned char res26[0x1c]; + unsigned long COLD_RESET; /* 0x02A0 */ + unsigned char res27[0xc]; + unsigned long DDP_DEVICE; /* 0x02B0 */ + unsigned char res28[0xc]; + unsigned long MULTI_PLANE; /* 0x02C0 */ + unsigned char res29[0x1c]; + unsigned long TRANS_MODE; /* 0x02E0 */ + unsigned char res30[0x1c]; + unsigned long ECC_ERR_STAT2; /* 0x0300 */ + unsigned char res31[0xc]; + unsigned long ECC_ERR_STAT3; /* 0x0310 */ + unsigned char res32[0xc]; + unsigned long ECC_ERR_STAT4; /* 0x0320 */ + unsigned char res33[0x1c]; + unsigned long DEV_PAGE_SIZE; /* 0x0340 */ + unsigned char res34[0x4c]; + unsigned long INT_MON_STATUS; /* 0x0390 */ +}; +#endif + +#define ONENAND_MEM_RESET_HOT 0x3 +#define ONENAND_MEM_RESET_COLD 0x2 +#define ONENAND_MEM_RESET_WARM 0x1 + +#define CACHE_OP_ERR (1 << 13) +#define RST_CMP (1 << 12) +#define RDY_ACT (1 << 11) +#define INT_ACT (1 << 10) +#define UNSUP_CMD (1 << 9) +#define LOCKED_BLK (1 << 8) +#define BLK_RW_CMP (1 << 7) +#define ERS_CMP (1 << 6) +#define PGM_CMP (1 << 5) +#define LOAD_CMP (1 << 4) +#define ERS_FAIL (1 << 3) +#define PGM_FAIL (1 << 2) +#define INT_TO (1 << 1) +#define LD_FAIL_ECC_ERR (1 << 0) + +#define TSRF (1 << 0) + +/* common initialize function */ +extern void s3c_onenand_init(struct mtd_info *); + +#endif
Dear Minkyu Kang,
- struct mtd_info *mtd;
- void __iomem *base;
- void __iomem *ahb_addr;
- int bootram_command;
- void __iomem *page_buf;
- void __iomem *oob_buf;
- unsigned int (*mem_addr)(int fba, int fpa, int fsa);
- struct samsung_onenand *reg;
Please drop these blank lines.
- 1Gb: FBA[21:12] FPA[11:6] FSA[5:4]
- 2Gb: FBA[22:12] FPA[11:6] FSA[5:4]
- 4Gb: FBA[23:12] FPA[11:6] FSA[5:4]
- return (fba << 12) | (fpa << 6) | (fsa << 4);
- 1Gb: FBA[22:13] FPA[12:7] FSA[6:5]
- 2Gb: FBA[23:13] FPA[12:7] FSA[6:5]
- 4Gb: FBA[24:13] FPA[12:7] FSA[6:5]
- return (fba << 13) | (fpa << 7) | (fsa << 5);
Hm... when I wrote "This function needs explanation. Please add a comment what it does, and how." I meant some comment that really explains what is goong on here - what the arguments are, what the return value is, and which sort of transformation the function performs. Your comment is not exactly helpful.
I can see what the code is doing, but I have no idea what that means - reading your comments don't help my understanding.
What I see raises just additional questions: should there be no error checking? I mean, something like
... ((fpa & 0x3f) << 7) | ((fsa & 3) << 5)
- unsigned long MEM_CFG; /* 0x0000 */
- unsigned char res1[0xc];
- unsigned long BURST_LEN; /* 0x0010 */
- unsigned char res2[0xc];
- unsigned long MEM_RESET; /* 0x0020 */
- unsigned char res3[0xc];
Upper case vaiable names are not allowed. Upper case identifiers are reserved for macros only. Please use lower case names.
Dear Wolfgang
2009/9/10 Wolfgang Denk wd@denx.de:
Dear Minkyu Kang,
ok.
ok I'll write more comments.
hm.. I think no need. because of each capacity have different offset and each argument is got from mtd. Kyungmin, how you think?
sure i do.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de That's the thing about people who think they hate computers. What they really hate is lousy programmers.
- Larry Niven and Jerry Pournelle in "Oath of Fealty"
thanks Minkyu Kang
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- Changes since v1: - move samsung_onenand.h to include/linux/mtd/ - make C struct instead of base+offset - Remove the "1 &&" in while loop
Changes since v2: - drop blank lines - adds some comments - modify to lower case letter in C struct
drivers/mtd/onenand/Makefile | 1 + drivers/mtd/onenand/samsung.c | 622 +++++++++++++++++++++++++++++++++++ include/linux/mtd/onenand.h | 1 + include/linux/mtd/onenand_regs.h | 4 + include/linux/mtd/samsung_onenand.h | 131 ++++++++ 5 files changed, 759 insertions(+), 0 deletions(-) create mode 100644 drivers/mtd/onenand/samsung.c create mode 100644 include/linux/mtd/samsung_onenand.h
diff --git a/drivers/mtd/onenand/Makefile b/drivers/mtd/onenand/Makefile index 1d35a57..2571df0 100644 --- a/drivers/mtd/onenand/Makefile +++ b/drivers/mtd/onenand/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk LIB := $(obj)libonenand.a
COBJS-$(CONFIG_CMD_ONENAND) := onenand_uboot.o onenand_base.o onenand_bbt.o +COBJS-$(CONFIG_SAMSUNG_ONENAND) += samsung.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c new file mode 100644 index 0000000..5433f19 --- /dev/null +++ b/drivers/mtd/onenand/samsung.c @@ -0,0 +1,622 @@ +/* + * S3C64XX/S5PC100 OneNAND driver at U-Boot + * + * Copyright (C) 2008-2009 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * Implementation: + * Emulate the pseudo BufferRAM + */ + +#include <common.h> +#include <malloc.h> +#include <linux/mtd/compat.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/onenand.h> +#include <linux/mtd/samsung_onenand.h> + +#include <asm/io.h> +#include <asm/errno.h> + +#ifdef ONENAND_DEBUG +#define DPRINTK(format, args...) \ +do { \ + printf("%s[%d]: " format "\n", __func__, __LINE__, ##args); \ +} while (0) +#else +#define DPRINTK(...) do { } while (0) +#endif + +#define ONENAND_ERASE_STATUS 0x00 +#define ONENAND_MULTI_ERASE_SET 0x01 +#define ONENAND_ERASE_START 0x03 +#define ONENAND_UNLOCK_START 0x08 +#define ONENAND_UNLOCK_END 0x09 +#define ONENAND_LOCK_START 0x0A +#define ONENAND_LOCK_END 0x0B +#define ONENAND_LOCK_TIGHT_START 0x0C +#define ONENAND_LOCK_TIGHT_END 0x0D +#define ONENAND_UNLOCK_ALL 0x0E +#define ONENAND_OTP_ACCESS 0x12 +#define ONENAND_SPARE_ACCESS_ONLY 0x13 +#define ONENAND_MAIN_ACCESS_ONLY 0x14 +#define ONENAND_ERASE_VERIFY 0x15 +#define ONENAND_MAIN_SPARE_ACCESS 0x16 +#define ONENAND_PIPELINE_READ 0x4000 + +#if defined(CONFIG_S3C64XX) +#define MAP_00 (0x0 << 24) +#define MAP_01 (0x1 << 24) +#define MAP_10 (0x2 << 24) +#define MAP_11 (0x3 << 24) +#elif defined(CONFIG_S5PC1XX) +#define MAP_00 (0x0 << 26) +#define MAP_01 (0x1 << 26) +#define MAP_10 (0x2 << 26) +#define MAP_11 (0x3 << 26) +#endif + +/* read/write of XIP buffer */ +#define CMD_MAP_00(mem_addr) (MAP_00 | ((mem_addr) << 1)) +/* read/write to the memory device */ +#define CMD_MAP_01(mem_addr) (MAP_01 | (mem_addr)) +/* control special functions of the memory device */ +#define CMD_MAP_10(mem_addr) (MAP_10 | (mem_addr)) +/* direct interface(direct access) with the memory device */ +#define CMD_MAP_11(mem_addr) (MAP_11 | ((mem_addr) << 2)) + +struct s3c_onenand { + struct mtd_info *mtd; + void __iomem *base; + void __iomem *ahb_addr; + int bootram_command; + void __iomem *page_buf; + void __iomem *oob_buf; + unsigned int (*mem_addr)(int fba, int fpa, int fsa); + struct samsung_onenand *reg; +}; + +static struct s3c_onenand *onenand; + +static int s3c_read_cmd(unsigned int cmd) +{ + return readl(onenand->ahb_addr + cmd); +} + +static void s3c_write_cmd(int value, unsigned int cmd) +{ + writel(value, onenand->ahb_addr + cmd); +} + +/* + * MEM_ADDR + * + * fba: flash block address + * fpa: flash page address + * fsa: flash sector address + * + * return the buffer address on the memory device + * It will be combined with CMD_MAP_XX + */ +#if defined(CONFIG_S3C64XX) +static unsigned int s3c_mem_addr(int fba, int fpa, int fsa) +{ + return (fba << 12) | (fpa << 6) | (fsa << 4); +} +#elif defined(CONFIG_S5PC1XX) +static unsigned int s3c_mem_addr(int fba, int fpa, int fsa) +{ + return (fba << 13) | (fpa << 7) | (fsa << 5); +} +#endif + +static void s3c_onenand_reset(void) +{ + unsigned long timeout = 0x10000; + int stat; + + writel(ONENAND_MEM_RESET_COLD, &onenand->reg->mem_reset); + while (timeout--) { + stat = readl(&onenand->reg->int_err_stat); + if (stat & RST_CMP) + break; + } + stat = readl(&onenand->reg->int_err_stat); + writel(stat, &onenand->reg->int_err_ack); + + /* Clear interrupt */ + writel(0x0, &onenand->reg->int_err_ack); + /* Clear the ECC status */ + writel(0x0, &onenand->reg->ecc_err_stat); +} + +static unsigned short s3c_onenand_readw(void __iomem *addr) +{ + struct onenand_chip *this = onenand->mtd->priv; + int reg = addr - this->base; + int word_addr = reg >> 1; + int value; + + /* It's used for probing time */ + switch (reg) { + case ONENAND_REG_MANUFACTURER_ID: + return readl(&onenand->reg->manufact_id); + case ONENAND_REG_DEVICE_ID: + return readl(&onenand->reg->device_id); + case ONENAND_REG_VERSION_ID: + return readl(&onenand->reg->flash_ver_id); + case ONENAND_REG_DATA_BUFFER_SIZE: + return readl(&onenand->reg->data_buf_size); + case ONENAND_REG_TECHNOLOGY: + return readl(&onenand->reg->tech); + case ONENAND_REG_SYS_CFG1: + return readl(&onenand->reg->mem_cfg); + + /* Used at unlock all status */ + case ONENAND_REG_CTRL_STATUS: + return 0; + + case ONENAND_REG_WP_STATUS: + return ONENAND_WP_US; + + default: + break; + } + + /* BootRAM access control */ + if (reg < ONENAND_DATARAM && onenand->bootram_command) { + if (word_addr == 0) + return readl(&onenand->reg->manufact_id); + if (word_addr == 1) + return readl(&onenand->reg->device_id); + if (word_addr == 2) + return readl(&onenand->reg->flash_ver_id); + } + + value = s3c_read_cmd(CMD_MAP_11(word_addr)) & 0xffff; + printk(KERN_INFO "s3c_onenand_readw: Illegal access" + " at reg 0x%x, value 0x%x\n", word_addr, value); + return value; +} + +static void s3c_onenand_writew(unsigned short value, void __iomem *addr) +{ + struct onenand_chip *this = onenand->mtd->priv; + int reg = addr - this->base; + int word_addr = reg >> 1; + + /* It's used for probing time */ + switch (reg) { + case ONENAND_REG_SYS_CFG1: + writel(value, &onenand->reg->mem_cfg); + return; + + case ONENAND_REG_START_ADDRESS1: + case ONENAND_REG_START_ADDRESS2: + return; + + /* Lock/lock-tight/unlock/unlock_all */ + case ONENAND_REG_START_BLOCK_ADDRESS: + return; + + default: + break; + } + + /* BootRAM access control */ + if (reg < ONENAND_DATARAM) { + if (value == ONENAND_CMD_READID) { + onenand->bootram_command = 1; + return; + } + if (value == ONENAND_CMD_RESET) { + writel(ONENAND_MEM_RESET_COLD, + &onenand->reg->mem_reset); + onenand->bootram_command = 0; + return; + } + } + + printk(KERN_INFO "s3c_onenand_writew: Illegal access" + " at reg 0x%x, value 0x%x\n", word_addr, value); + + s3c_write_cmd(value, CMD_MAP_11(word_addr)); +} + +static int s3c_onenand_wait(struct mtd_info *mtd, int state) +{ + unsigned int flags = INT_ACT; + unsigned int stat, ecc; + unsigned long timeout = 0x100000; + + switch (state) { + case FL_READING: + flags |= BLK_RW_CMP | LOAD_CMP; + break; + case FL_WRITING: + flags |= BLK_RW_CMP | PGM_CMP; + break; + case FL_ERASING: + flags |= BLK_RW_CMP | ERS_CMP; + break; + case FL_LOCKING: + flags |= BLK_RW_CMP; + break; + default: + break; + } + + while (timeout--) { + stat = readl(&onenand->reg->int_err_stat); + if (stat & flags) + break; + } + + /* To get correct interrupt status in timeout case */ + stat = readl(&onenand->reg->int_err_stat); + writel(stat, &onenand->reg->int_err_ack); + + /* + * In the Spec. it checks the controller status first + * However if you get the correct information in case of + * power off recovery (POR) test, it should read ECC status first + */ + if (stat & LOAD_CMP) { + ecc = readl(&onenand->reg->ecc_err_stat); + if (ecc & ONENAND_ECC_4BIT_UNCORRECTABLE) { + printk(KERN_INFO "%s: ECC error = 0x%04x\n", + __func__, ecc); + mtd->ecc_stats.failed++; + return -EBADMSG; + } + } + + if (stat & (LOCKED_BLK | ERS_FAIL | PGM_FAIL | LD_FAIL_ECC_ERR)) { + printk(KERN_INFO "%s: controller error = 0x%04x\n", + __func__, stat); + if (stat & LOCKED_BLK) + printk(KERN_INFO "%s: it's locked error = 0x%04x\n", + __func__, stat); + + return -EIO; + } + + return 0; +} + +static int s3c_onenand_command(struct mtd_info *mtd, int cmd, + loff_t addr, size_t len) +{ + struct onenand_chip *this = mtd->priv; + unsigned int *m, *s; + int fba, fpa, fsa = 0; + unsigned int mem_addr; + int i, mcount, scount; + int index; + + fba = (int) (addr >> this->erase_shift); + fpa = (int) (addr >> this->page_shift); + fpa &= this->page_mask; + + mem_addr = onenand->mem_addr(fba, fpa, fsa); + + switch (cmd) { + case ONENAND_CMD_READ: + case ONENAND_CMD_READOOB: + case ONENAND_CMD_BUFFERRAM: + ONENAND_SET_NEXT_BUFFERRAM(this); + default: + break; + } + + index = ONENAND_CURRENT_BUFFERRAM(this); + + /* + * Emulate Two BufferRAMs and access with 4 bytes pointer + */ + m = (unsigned int *) onenand->page_buf; + s = (unsigned int *) onenand->oob_buf; + + if (index) { + m += (this->writesize >> 2); + s += (mtd->oobsize >> 2); + } + + mcount = mtd->writesize >> 2; + scount = mtd->oobsize >> 2; + + switch (cmd) { + case ONENAND_CMD_READ: + /* Main */ + for (i = 0; i < mcount; i++) + *m++ = s3c_read_cmd(CMD_MAP_01(mem_addr)); + return 0; + + case ONENAND_CMD_READOOB: + writel(TSRF, &onenand->reg->trans_spare); + /* Main */ + for (i = 0; i < mcount; i++) + *m++ = s3c_read_cmd(CMD_MAP_01(mem_addr)); + + /* Spare */ + for (i = 0; i < scount; i++) + *s++ = s3c_read_cmd(CMD_MAP_01(mem_addr)); + + writel(0, &onenand->reg->trans_spare); + return 0; + + case ONENAND_CMD_PROG: + /* Main */ + for (i = 0; i < mcount; i++) + s3c_write_cmd(*m++, CMD_MAP_01(mem_addr)); + return 0; + + case ONENAND_CMD_PROGOOB: + writel(TSRF, &onenand->reg->trans_spare); + + /* Main - dummy write */ + for (i = 0; i < mcount; i++) + s3c_write_cmd(0xffffffff, CMD_MAP_01(mem_addr)); + + /* Spare */ + for (i = 0; i < scount; i++) + s3c_write_cmd(*s++, CMD_MAP_01(mem_addr)); + + writel(0, &onenand->reg->trans_spare); + return 0; + + case ONENAND_CMD_UNLOCK_ALL: + s3c_write_cmd(ONENAND_UNLOCK_ALL, CMD_MAP_10(mem_addr)); + return 0; + + case ONENAND_CMD_ERASE: + s3c_write_cmd(ONENAND_ERASE_START, CMD_MAP_10(mem_addr)); + return 0; + + case ONENAND_CMD_MULTIBLOCK_ERASE: + s3c_write_cmd(ONENAND_MULTI_ERASE_SET, CMD_MAP_10(mem_addr)); + return 0; + + case ONENAND_CMD_ERASE_VERIFY: + s3c_write_cmd(ONENAND_ERASE_VERIFY, CMD_MAP_10(mem_addr)); + return 0; + + default: + break; + } + + return 0; +} + +static unsigned char *s3c_get_bufferram(struct mtd_info *mtd, int area) +{ + struct onenand_chip *this = mtd->priv; + int index = ONENAND_CURRENT_BUFFERRAM(this); + unsigned char *p; + + if (area == ONENAND_DATARAM) { + p = (unsigned char *) onenand->page_buf; + if (index == 1) + p += this->writesize; + } else { + p = (unsigned char *) onenand->oob_buf; + if (index == 1) + p += mtd->oobsize; + } + + return p; +} + +static int onenand_read_bufferram(struct mtd_info *mtd, loff_t addr, int area, + unsigned char *buffer, int offset, + size_t count) +{ + unsigned char *p; + + p = s3c_get_bufferram(mtd, area); + memcpy(buffer, p + offset, count); + return 0; +} + +static int onenand_write_bufferram(struct mtd_info *mtd, loff_t addr, int area, + const unsigned char *buffer, int offset, + size_t count) +{ + unsigned char *p; + + p = s3c_get_bufferram(mtd, area); + memcpy(p + offset, buffer, count); + return 0; +} + +static int s3c_onenand_bbt_wait(struct mtd_info *mtd, int state) +{ + struct samsung_onenand *reg = (struct samsung_onenand *)onenand->base; + unsigned int flags = INT_ACT | LOAD_CMP; + unsigned int stat; + unsigned long timeout = 0x10000; + + while (timeout--) { + stat = readl(®->int_err_stat); + if (stat & flags) + break; + } + /* To get correct interrupt status in timeout case */ + stat = readl(&onenand->reg->int_err_stat); + writel(stat, &onenand->reg->int_err_ack); + + if (stat & LD_FAIL_ECC_ERR) { + s3c_onenand_reset(); + return ONENAND_BBT_READ_ERROR; + } + + if (stat & LOAD_CMP) { + int ecc = readl(&onenand->reg->ecc_err_stat); + if (ecc & ONENAND_ECC_4BIT_UNCORRECTABLE) { + s3c_onenand_reset(); + return ONENAND_BBT_READ_ERROR; + } + } + + return 0; +} + +static void s3c_onenand_check_lock_status(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + unsigned int block, end; + int tmp; + + end = this->chipsize >> this->erase_shift; + + for (block = 0; block < end; block++) { + tmp = s3c_read_cmd(CMD_MAP_01(onenand->mem_addr(block, 0, 0))); + + if (readl(&onenand->reg->int_err_stat) & LOCKED_BLK) { + printf("block %d is write-protected!\n", block); + writel(LOCKED_BLK, &onenand->reg->int_err_ack); + } + } +} + +static void s3c_onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, + size_t len, int cmd) +{ + struct onenand_chip *this = mtd->priv; + int start, end, start_mem_addr, end_mem_addr; + + start = ofs >> this->erase_shift; + start_mem_addr = onenand->mem_addr(start, 0, 0); + end = start + (len >> this->erase_shift) - 1; + end_mem_addr = onenand->mem_addr(end, 0, 0); + + if (cmd == ONENAND_CMD_LOCK) { + s3c_write_cmd(ONENAND_LOCK_START, CMD_MAP_10(start_mem_addr)); + s3c_write_cmd(ONENAND_LOCK_END, CMD_MAP_10(end_mem_addr)); + } else { + s3c_write_cmd(ONENAND_UNLOCK_START, CMD_MAP_10(start_mem_addr)); + s3c_write_cmd(ONENAND_UNLOCK_END, CMD_MAP_10(end_mem_addr)); + } + + this->wait(mtd, FL_LOCKING); +} + +static void s3c_onenand_unlock_all(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + loff_t ofs = 0; + size_t len = this->chipsize; + + /* FIXME workaround */ + this->subpagesize = mtd->writesize; + mtd->subpage_sft = 0; + + if (this->options & ONENAND_HAS_UNLOCK_ALL) { + /* Write unlock command */ + this->command(mtd, ONENAND_CMD_UNLOCK_ALL, 0, 0); + + /* No need to check return value */ + this->wait(mtd, FL_LOCKING); + + /* Workaround for all block unlock in DDP */ + if (!ONENAND_IS_DDP(this)) { + s3c_onenand_check_lock_status(mtd); + return; + } + + /* All blocks on another chip */ + ofs = this->chipsize >> 1; + len = this->chipsize >> 1; + } + + s3c_onenand_do_lock_cmd(mtd, ofs, len, ONENAND_CMD_UNLOCK); + s3c_onenand_check_lock_status(mtd); +} + +#ifdef CONFIG_S3C64XX +static void s3c_set_width_regs(struct onenand_chip *this) +{ + int dev_id, density; + int fba, fpa, fsa; + int dbs_dfs; + + dev_id = DEVICE_ID0_REG; + + density = (dev_id >> ONENAND_DEVICE_DENSITY_SHIFT) & 0xf; + dbs_dfs = !!(dev_id & ONENAND_DEVICE_IS_DDP); + + fba = density + 7; + if (dbs_dfs) + fba--; /* Decrease the fba */ + fpa = 6; + if (density >= ONENAND_DEVICE_DENSITY_512Mb) + fsa = 2; + else + fsa = 1; + + DPRINTK("FBA %lu, FPA %lu, FSA %lu, DDP %lu", + FBA_WIDTH0_REG, FPA_WIDTH0_REG, FSA_WIDTH0_REG, + DDP_DEVICE_REG); + + DPRINTK("mem_cfg0 0x%lx, sync mode %lu, " + "dev_page_size %lu, BURST LEN %lu", + MEM_CFG0_REG, SYNC_MODE_REG, + DEV_PAGE_SIZE_REG, BURST_LEN0_REG); + + DEV_PAGE_SIZE_REG = 0x1; + + FBA_WIDTH0_REG = fba; + FPA_WIDTH0_REG = fpa; + FSA_WIDTH0_REG = fsa; + DBS_DFS_WIDTH0_REG = dbs_dfs; +} +#endif + +void s3c_onenand_init(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + u32 size = (4 << 10); /* 4 KiB */ + + onenand = malloc(sizeof(struct s3c_onenand)); + if (!onenand) + return; + + onenand->page_buf = malloc(size * sizeof(char)); + if (!onenand->page_buf) + return; + memset(onenand->page_buf, 0xff, size); + + onenand->oob_buf = malloc(128 * sizeof(char)); + if (!onenand->oob_buf) + return; + memset(onenand->oob_buf, 0xff, 128); + + onenand->mtd = mtd; + +#if defined(CONFIG_S3C64XX) + onenand->base = (void *)0x70100000; + onenand->ahb_addr = (void *)0x20000000; +#elif defined(CONFIG_S5PC1XX) + onenand->base = (void *)0xE7100000; + onenand->ahb_addr = (void *)0xB0000000; +#endif + onenand->mem_addr = s3c_mem_addr; + onenand->reg = (struct samsung_onenand *)onenand->base; + + this->read_word = s3c_onenand_readw; + this->write_word = s3c_onenand_writew; + + this->wait = s3c_onenand_wait; + this->bbt_wait = s3c_onenand_bbt_wait; + this->unlock_all = s3c_onenand_unlock_all; + this->command = s3c_onenand_command; + + this->read_bufferram = onenand_read_bufferram; + this->write_bufferram = onenand_write_bufferram; + + this->options |= ONENAND_RUNTIME_BADBLOCK_CHECK; +} diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 06f7baf..9a6f317 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -135,6 +135,7 @@ struct onenand_chip { #define ONENAND_HAS_CONT_LOCK (0x0001) #define ONENAND_HAS_UNLOCK_ALL (0x0002) #define ONENAND_HAS_2PLANE (0x0004) +#define ONENAND_RUNTIME_BADBLOCK_CHECK (0x0200) #define ONENAND_PAGEBUF_ALLOC (0x1000) #define ONENAND_OOBBUF_ALLOC (0x2000)
#endif /* __ONENAND_REG_H */ diff --git a/include/linux/mtd/samsung_onenand.h b/include/linux/mtd/samsung_onenand.h new file mode 100644 index 0000000..9865780 --- /dev/null +++ b/include/linux/mtd/samsung_onenand.h @@ -0,0 +1,131 @@ +/* + * Copyright (C) 2005-2009 Samsung Electronics + * Minkyu Kang mk7.kang@samsung.com + * Kyungmin Park kyungmin.park@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __SAMSUNG_ONENAND_H__ +#define __SAMSUNG_ONENAND_H__ + +/* + * OneNAND Controller + */ + +#ifndef __ASSEMBLY__ +struct samsung_onenand { + unsigned long mem_cfg; /* 0x0000 */ + unsigned char res1[0xc]; + unsigned long burst_len; /* 0x0010 */ + unsigned char res2[0xc]; + unsigned long mem_reset; /* 0x0020 */ + unsigned char res3[0xc]; + unsigned long int_err_stat; /* 0x0030 */ + unsigned char res4[0xc]; + unsigned long int_err_mask; /* 0x0040 */ + unsigned char res5[0xc]; + unsigned long int_err_ack; /* 0x0050 */ + unsigned char res6[0xc]; + unsigned long ecc_err_stat; /* 0x0060 */ + unsigned char res7[0xc]; + unsigned long manufact_id; /* 0x0070 */ + unsigned char res8[0xc]; + unsigned long device_id; /* 0x0080 */ + unsigned char res9[0xc]; + unsigned long data_buf_size; /* 0x0090 */ + unsigned char res10[0xc]; + unsigned long boot_buf_size; /* 0x00A0 */ + unsigned char res11[0xc]; + unsigned long buf_amount; /* 0x00B0 */ + unsigned char res12[0xc]; + unsigned long tech; /* 0x00C0 */ + unsigned char res13[0xc]; + unsigned long fba; /* 0x00D0 */ + unsigned char res14[0xc]; + unsigned long fpa; /* 0x00E0 */ + unsigned char res15[0xc]; + unsigned long fsa; /* 0x00F0 */ + unsigned char res16[0x3c]; + unsigned long sync_mode; /* 0x0130 */ + unsigned char res17[0xc]; + unsigned long trans_spare; /* 0x0140 */ + unsigned char res18[0x3c]; + unsigned long err_page_addr; /* 0x0180 */ + unsigned char res19[0x1c]; + unsigned long int_pin_en; /* 0x01A0 */ + unsigned char res20[0x1c]; + unsigned long acc_clock; /* 0x01C0 */ + unsigned char res21[0x1c]; + unsigned long err_blk_addr; /* 0x01E0 */ + unsigned char res22[0xc]; + unsigned long flash_ver_id; /* 0x01F0 */ + unsigned char res23[0x6c]; + unsigned long watchdog_cnt_low; /* 0x0260 */ + unsigned char res24[0xc]; + unsigned long watchdog_cnt_hi; /* 0x0270 */ + unsigned char res25[0xc]; + unsigned long sync_write; /* 0x0280 */ + unsigned char res26[0x1c]; + unsigned long cold_reset; /* 0x02A0 */ + unsigned char res27[0xc]; + unsigned long ddp_device; /* 0x02B0 */ + unsigned char res28[0xc]; + unsigned long multi_plane; /* 0x02C0 */ + unsigned char res29[0x1c]; + unsigned long trans_mode; /* 0x02E0 */ + unsigned char res30[0x1c]; + unsigned long ecc_err_stat2; /* 0x0300 */ + unsigned char res31[0xc]; + unsigned long ecc_err_stat3; /* 0x0310 */ + unsigned char res32[0xc]; + unsigned long ecc_err_stat4; /* 0x0320 */ + unsigned char res33[0x1c]; + unsigned long dev_page_size; /* 0x0340 */ + unsigned char res34[0x4c]; + unsigned long int_mon_status; /* 0x0390 */ +}; +#endif + +#define ONENAND_MEM_RESET_HOT 0x3 +#define ONENAND_MEM_RESET_COLD 0x2 +#define ONENAND_MEM_RESET_WARM 0x1 + +#define INT_ERR_ALL 0x3fff +#define CACHE_OP_ERR (1 << 13) +#define RST_CMP (1 << 12) +#define RDY_ACT (1 << 11) +#define INT_ACT (1 << 10) +#define UNSUP_CMD (1 << 9) +#define LOCKED_BLK (1 << 8) +#define BLK_RW_CMP (1 << 7) +#define ERS_CMP (1 << 6) +#define PGM_CMP (1 << 5) +#define LOAD_CMP (1 << 4) +#define ERS_FAIL (1 << 3) +#define PGM_FAIL (1 << 2) +#define INT_TO (1 << 1) +#define LD_FAIL_ECC_ERR (1 << 0) + +#define TSRF (1 << 0) + +/* common initialize function */ +extern void s3c_onenand_init(struct mtd_info *); + +#endif
Changes since v1:
Changes since v2:
- drop blank lines
- S3C64XX/S5PC100 OneNAND driver at U-Boot
- Copyright (C) 2008-2009 Samsung Electronics
- Kyungmin Park kyungmin.park@samsung.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
Add full GPL 2 copyright.
- Implementation:
- Emulate the pseudo BufferRAM
<snip>
This and other struct, #defines may be better handled in a H file. Why did you include them all here?
Otherwise fine. Just fix the copyright.
Tom
Dear Tom.
2009/9/22 Tom Tom.Rix@windriver.com:
Changes since v1:
Changes since v2:
- drop blank lines
Ok, thanks
- Implementation:
<snip>
It will be moved H file thanks
Tom _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Thanks Minkyu Kang
On Wed, Sep 23, 2009 at 7:49 PM, Minkyu Kang promsoft@gmail.com wrote:
Dear Tom.
Changes since v1:
Changes since v2:
- drop blank lines
Ok, thanks
- Implementation:
<snip>
No, No. Please leave it. User must know that which MAP bit are used. Later I will remove #ifdef.
Thank you, Kyungmin Park
Dear Tom.
Changes since v1:
Changes since v2:
- drop blank lines
Ok, thanks
- Implementation:
<snip>
I was not referring to just the MAP bits. There is in general a large number of #defines and other information that may be better handled by moving them to an H file.
Moving them in not a requirement.
Please resubmit with just the copyright change if you do not want to do the move.
Tom
Dear Tom, Kyungmin & Minkyu,
To avoid misunderstandings: the required phrase is "GPL, either version 2, or (at your option) any later version"; please see note 1 at http://www.denx.de/wiki/U-Boot/Patches for details.
Does this mean you will not accept any more patches that import new NAND code from Linux, as that code is v2-only?
-Scott
Changes since v3: - fix the copyright
drivers/mtd/onenand/Makefile | 1 + drivers/mtd/onenand/samsung.c | 636 +++++++++++++++++++++++++++++++++++ include/linux/mtd/onenand.h | 1 + include/linux/mtd/onenand_regs.h | 4 + include/linux/mtd/samsung_onenand.h | 131 +++++++ 5 files changed, 773 insertions(+), 0 deletions(-) create mode 100644 drivers/mtd/onenand/samsung.c create mode 100644 include/linux/mtd/samsung_onenand.h
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c new file mode 100644 index 0000000..f2be687 --- /dev/null +++ b/drivers/mtd/onenand/samsung.c @@ -0,0 +1,636 @@ +/* + * S3C64XX/S5PC100 OneNAND driver at U-Boot + * + * Copyright (C) 2008-2009 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * + * Implementation: + * Emulate the pseudo BufferRAM + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <linux/mtd/compat.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/onenand.h> +#include <linux/mtd/samsung_onenand.h> + +#include <asm/io.h> +#include <asm/errno.h> + +#ifdef ONENAND_DEBUG +#define DPRINTK(format, args...) \ +do { \ + printf("%s[%d]: " format "\n", __func__, __LINE__, ##args); \ +} while (0) +#else +#define DPRINTK(...) do { } while (0) +#endif + +#define ONENAND_ERASE_STATUS 0x00 +#define ONENAND_MULTI_ERASE_SET 0x01 +#define ONENAND_ERASE_START 0x03 +#define ONENAND_UNLOCK_START 0x08 +#define ONENAND_UNLOCK_END 0x09 +#define ONENAND_LOCK_START 0x0A +#define ONENAND_LOCK_END 0x0B +#define ONENAND_LOCK_TIGHT_START 0x0C +#define ONENAND_LOCK_TIGHT_END 0x0D +#define ONENAND_UNLOCK_ALL 0x0E +#define ONENAND_OTP_ACCESS 0x12 +#define ONENAND_SPARE_ACCESS_ONLY 0x13 +#define ONENAND_MAIN_ACCESS_ONLY 0x14 +#define ONENAND_ERASE_VERIFY 0x15 +#define ONENAND_MAIN_SPARE_ACCESS 0x16 +#define ONENAND_PIPELINE_READ 0x4000 + +#if defined(CONFIG_S3C64XX) +#define MAP_00 (0x0 << 24) +#define MAP_01 (0x1 << 24) +#define MAP_10 (0x2 << 24) +#define MAP_11 (0x3 << 24) +#elif defined(CONFIG_S5PC1XX) +#define MAP_00 (0x0 << 26) +#define MAP_01 (0x1 << 26) +#define MAP_10 (0x2 << 26) +#define MAP_11 (0x3 << 26) +#endif + +/* read/write of XIP buffer */ +#define CMD_MAP_00(mem_addr) (MAP_00 | ((mem_addr) << 1)) +/* read/write to the memory device */ +#define CMD_MAP_01(mem_addr) (MAP_01 | (mem_addr)) +/* control special functions of the memory device */ +#define CMD_MAP_10(mem_addr) (MAP_10 | (mem_addr)) +/* direct interface(direct access) with the memory device */ +#define CMD_MAP_11(mem_addr) (MAP_11 | ((mem_addr) << 2)) + +struct s3c_onenand { + struct mtd_info *mtd; + void __iomem *base; + void __iomem *ahb_addr; + int bootram_command; + void __iomem *page_buf; + void __iomem *oob_buf; + unsigned int (*mem_addr)(int fba, int fpa, int fsa); + struct samsung_onenand *reg; +}; + +static struct s3c_onenand *onenand; + +static int s3c_read_cmd(unsigned int cmd) +{ + return readl(onenand->ahb_addr + cmd); +} + +static void s3c_write_cmd(int value, unsigned int cmd) +{ + writel(value, onenand->ahb_addr + cmd); +} + +/* + * MEM_ADDR + * + * fba: flash block address + * fpa: flash page address + * fsa: flash sector address + * + * return the buffer address on the memory device + * It will be combined with CMD_MAP_XX + */ +#if defined(CONFIG_S3C64XX) +static unsigned int s3c_mem_addr(int fba, int fpa, int fsa) +{ + return (fba << 12) | (fpa << 6) | (fsa << 4); +} +#elif defined(CONFIG_S5PC1XX) +static unsigned int s3c_mem_addr(int fba, int fpa, int fsa) +{ + return (fba << 13) | (fpa << 7) | (fsa << 5); +} +#endif + +static void s3c_onenand_reset(void) +{ + unsigned long timeout = 0x10000; + int stat; + + writel(ONENAND_MEM_RESET_COLD, &onenand->reg->mem_reset); + while (timeout--) { + stat = readl(&onenand->reg->int_err_stat); + if (stat & RST_CMP) + break; + } + stat = readl(&onenand->reg->int_err_stat); + writel(stat, &onenand->reg->int_err_ack); + + /* Clear interrupt */ + writel(0x0, &onenand->reg->int_err_ack); + /* Clear the ECC status */ + writel(0x0, &onenand->reg->ecc_err_stat); +} + +static unsigned short s3c_onenand_readw(void __iomem *addr) +{ + struct onenand_chip *this = onenand->mtd->priv; + int reg = addr - this->base; + int word_addr = reg >> 1; + int value; + + /* It's used for probing time */ + switch (reg) { + case ONENAND_REG_MANUFACTURER_ID: + return readl(&onenand->reg->manufact_id); + case ONENAND_REG_DEVICE_ID: + return readl(&onenand->reg->device_id); + case ONENAND_REG_VERSION_ID: + return readl(&onenand->reg->flash_ver_id); + case ONENAND_REG_DATA_BUFFER_SIZE: + return readl(&onenand->reg->data_buf_size); + case ONENAND_REG_TECHNOLOGY: + return readl(&onenand->reg->tech); + case ONENAND_REG_SYS_CFG1: + return readl(&onenand->reg->mem_cfg); + + /* Used at unlock all status */ + case ONENAND_REG_CTRL_STATUS: + return 0; + + case ONENAND_REG_WP_STATUS: + return ONENAND_WP_US; + + default: + break; + } + + /* BootRAM access control */ + if (reg < ONENAND_DATARAM && onenand->bootram_command) { + if (word_addr == 0) + return readl(&onenand->reg->manufact_id); + if (word_addr == 1) + return readl(&onenand->reg->device_id); + if (word_addr == 2) + return readl(&onenand->reg->flash_ver_id); + } + + value = s3c_read_cmd(CMD_MAP_11(word_addr)) & 0xffff; + printk(KERN_INFO "s3c_onenand_readw: Illegal access" + " at reg 0x%x, value 0x%x\n", word_addr, value); + return value; +} + +static void s3c_onenand_writew(unsigned short value, void __iomem *addr) +{ + struct onenand_chip *this = onenand->mtd->priv; + int reg = addr - this->base; + int word_addr = reg >> 1; + + /* It's used for probing time */ + switch (reg) { + case ONENAND_REG_SYS_CFG1: + writel(value, &onenand->reg->mem_cfg); + return; + + case ONENAND_REG_START_ADDRESS1: + case ONENAND_REG_START_ADDRESS2: + return; + + /* Lock/lock-tight/unlock/unlock_all */ + case ONENAND_REG_START_BLOCK_ADDRESS: + return; + + default: + break; + } + + /* BootRAM access control */ + if (reg < ONENAND_DATARAM) { + if (value == ONENAND_CMD_READID) { + onenand->bootram_command = 1; + return; + } + if (value == ONENAND_CMD_RESET) { + writel(ONENAND_MEM_RESET_COLD, + &onenand->reg->mem_reset); + onenand->bootram_command = 0; + return; + } + } + + printk(KERN_INFO "s3c_onenand_writew: Illegal access" + " at reg 0x%x, value 0x%x\n", word_addr, value); + + s3c_write_cmd(value, CMD_MAP_11(word_addr)); +} + +static int s3c_onenand_wait(struct mtd_info *mtd, int state) +{ + unsigned int flags = INT_ACT; + unsigned int stat, ecc; + unsigned long timeout = 0x100000; + + switch (state) { + case FL_READING: + flags |= BLK_RW_CMP | LOAD_CMP; + break; + case FL_WRITING: + flags |= BLK_RW_CMP | PGM_CMP; + break; + case FL_ERASING: + flags |= BLK_RW_CMP | ERS_CMP; + break; + case FL_LOCKING: + flags |= BLK_RW_CMP; + break; + default: + break; + } + + while (timeout--) { + stat = readl(&onenand->reg->int_err_stat); + if (stat & flags) + break; + } + + /* To get correct interrupt status in timeout case */ + stat = readl(&onenand->reg->int_err_stat); + writel(stat, &onenand->reg->int_err_ack); + + /* + * In the Spec. it checks the controller status first + * However if you get the correct information in case of + * power off recovery (POR) test, it should read ECC status first + */ + if (stat & LOAD_CMP) { + ecc = readl(&onenand->reg->ecc_err_stat); + if (ecc & ONENAND_ECC_4BIT_UNCORRECTABLE) { + printk(KERN_INFO "%s: ECC error = 0x%04x\n", + __func__, ecc); + mtd->ecc_stats.failed++; + return -EBADMSG; + } + } + + if (stat & (LOCKED_BLK | ERS_FAIL | PGM_FAIL | LD_FAIL_ECC_ERR)) { + printk(KERN_INFO "%s: controller error = 0x%04x\n", + __func__, stat); + if (stat & LOCKED_BLK) + printk(KERN_INFO "%s: it's locked error = 0x%04x\n", + __func__, stat); + + return -EIO; + } + + return 0; +} + +static int s3c_onenand_command(struct mtd_info *mtd, int cmd, + loff_t addr, size_t len) +{ + struct onenand_chip *this = mtd->priv; + unsigned int *m, *s; + int fba, fpa, fsa = 0; + unsigned int mem_addr; + int i, mcount, scount; + int index; + + fba = (int) (addr >> this->erase_shift); + fpa = (int) (addr >> this->page_shift); + fpa &= this->page_mask; + + mem_addr = onenand->mem_addr(fba, fpa, fsa); + + switch (cmd) { + case ONENAND_CMD_READ: + case ONENAND_CMD_READOOB: + case ONENAND_CMD_BUFFERRAM: + ONENAND_SET_NEXT_BUFFERRAM(this); + default: + break; + } + + index = ONENAND_CURRENT_BUFFERRAM(this); + + /* + * Emulate Two BufferRAMs and access with 4 bytes pointer + */ + m = (unsigned int *) onenand->page_buf; + s = (unsigned int *) onenand->oob_buf; + + if (index) { + m += (this->writesize >> 2); + s += (mtd->oobsize >> 2); + } + + mcount = mtd->writesize >> 2; + scount = mtd->oobsize >> 2; + + switch (cmd) { + case ONENAND_CMD_READ: + /* Main */ + for (i = 0; i < mcount; i++) + *m++ = s3c_read_cmd(CMD_MAP_01(mem_addr)); + return 0; + + case ONENAND_CMD_READOOB: + writel(TSRF, &onenand->reg->trans_spare); + /* Main */ + for (i = 0; i < mcount; i++) + *m++ = s3c_read_cmd(CMD_MAP_01(mem_addr)); + + /* Spare */ + for (i = 0; i < scount; i++) + *s++ = s3c_read_cmd(CMD_MAP_01(mem_addr)); + + writel(0, &onenand->reg->trans_spare); + return 0; + + case ONENAND_CMD_PROG: + /* Main */ + for (i = 0; i < mcount; i++) + s3c_write_cmd(*m++, CMD_MAP_01(mem_addr)); + return 0; + + case ONENAND_CMD_PROGOOB: + writel(TSRF, &onenand->reg->trans_spare); + + /* Main - dummy write */ + for (i = 0; i < mcount; i++) + s3c_write_cmd(0xffffffff, CMD_MAP_01(mem_addr)); + + /* Spare */ + for (i = 0; i < scount; i++) + s3c_write_cmd(*s++, CMD_MAP_01(mem_addr)); + + writel(0, &onenand->reg->trans_spare); + return 0; + + case ONENAND_CMD_UNLOCK_ALL: + s3c_write_cmd(ONENAND_UNLOCK_ALL, CMD_MAP_10(mem_addr)); + return 0; + + case ONENAND_CMD_ERASE: + s3c_write_cmd(ONENAND_ERASE_START, CMD_MAP_10(mem_addr)); + return 0; + + case ONENAND_CMD_MULTIBLOCK_ERASE: + s3c_write_cmd(ONENAND_MULTI_ERASE_SET, CMD_MAP_10(mem_addr)); + return 0; + + case ONENAND_CMD_ERASE_VERIFY: + s3c_write_cmd(ONENAND_ERASE_VERIFY, CMD_MAP_10(mem_addr)); + return 0; + + default: + break; + } + + return 0; +} + +static unsigned char *s3c_get_bufferram(struct mtd_info *mtd, int area) +{ + struct onenand_chip *this = mtd->priv; + int index = ONENAND_CURRENT_BUFFERRAM(this); + unsigned char *p; + + if (area == ONENAND_DATARAM) { + p = (unsigned char *) onenand->page_buf; + if (index == 1) + p += this->writesize; + } else { + p = (unsigned char *) onenand->oob_buf; + if (index == 1) + p += mtd->oobsize; + } + + return p; +} + +static int onenand_read_bufferram(struct mtd_info *mtd, loff_t addr, int area, + unsigned char *buffer, int offset, + size_t count) +{ + unsigned char *p; + + p = s3c_get_bufferram(mtd, area); + memcpy(buffer, p + offset, count); + return 0; +} + +static int onenand_write_bufferram(struct mtd_info *mtd, loff_t addr, int area, + const unsigned char *buffer, int offset, + size_t count) +{ + unsigned char *p; + + p = s3c_get_bufferram(mtd, area); + memcpy(p + offset, buffer, count); + return 0; +} + +static int s3c_onenand_bbt_wait(struct mtd_info *mtd, int state) +{ + struct samsung_onenand *reg = (struct samsung_onenand *)onenand->base; + unsigned int flags = INT_ACT | LOAD_CMP; + unsigned int stat; + unsigned long timeout = 0x10000; + + while (timeout--) { + stat = readl(®->int_err_stat); + if (stat & flags) + break; + } + /* To get correct interrupt status in timeout case */ + stat = readl(&onenand->reg->int_err_stat); + writel(stat, &onenand->reg->int_err_ack); + + if (stat & LD_FAIL_ECC_ERR) { + s3c_onenand_reset(); + return ONENAND_BBT_READ_ERROR; + } + + if (stat & LOAD_CMP) { + int ecc = readl(&onenand->reg->ecc_err_stat); + if (ecc & ONENAND_ECC_4BIT_UNCORRECTABLE) { + s3c_onenand_reset(); + return ONENAND_BBT_READ_ERROR; + } + } + + return 0; +} + +static void s3c_onenand_check_lock_status(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + unsigned int block, end; + int tmp; + + end = this->chipsize >> this->erase_shift; + + for (block = 0; block < end; block++) { + tmp = s3c_read_cmd(CMD_MAP_01(onenand->mem_addr(block, 0, 0))); + + if (readl(&onenand->reg->int_err_stat) & LOCKED_BLK) { + printf("block %d is write-protected!\n", block); + writel(LOCKED_BLK, &onenand->reg->int_err_ack); + } + } +} + +static void s3c_onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, + size_t len, int cmd) +{ + struct onenand_chip *this = mtd->priv; + int start, end, start_mem_addr, end_mem_addr; + + start = ofs >> this->erase_shift; + start_mem_addr = onenand->mem_addr(start, 0, 0); + end = start + (len >> this->erase_shift) - 1; + end_mem_addr = onenand->mem_addr(end, 0, 0); + + if (cmd == ONENAND_CMD_LOCK) { + s3c_write_cmd(ONENAND_LOCK_START, CMD_MAP_10(start_mem_addr)); + s3c_write_cmd(ONENAND_LOCK_END, CMD_MAP_10(end_mem_addr)); + } else { + s3c_write_cmd(ONENAND_UNLOCK_START, CMD_MAP_10(start_mem_addr)); + s3c_write_cmd(ONENAND_UNLOCK_END, CMD_MAP_10(end_mem_addr)); + } + + this->wait(mtd, FL_LOCKING); +} + +static void s3c_onenand_unlock_all(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + loff_t ofs = 0; + size_t len = this->chipsize; + + /* FIXME workaround */ + this->subpagesize = mtd->writesize; + mtd->subpage_sft = 0; + + if (this->options & ONENAND_HAS_UNLOCK_ALL) { + /* Write unlock command */ + this->command(mtd, ONENAND_CMD_UNLOCK_ALL, 0, 0); + + /* No need to check return value */ + this->wait(mtd, FL_LOCKING); + + /* Workaround for all block unlock in DDP */ + if (!ONENAND_IS_DDP(this)) { + s3c_onenand_check_lock_status(mtd); + return; + } + + /* All blocks on another chip */ + ofs = this->chipsize >> 1; + len = this->chipsize >> 1; + } + + s3c_onenand_do_lock_cmd(mtd, ofs, len, ONENAND_CMD_UNLOCK); + s3c_onenand_check_lock_status(mtd); +} + +#ifdef CONFIG_S3C64XX +static void s3c_set_width_regs(struct onenand_chip *this) +{ + int dev_id, density; + int fba, fpa, fsa; + int dbs_dfs; + + dev_id = DEVICE_ID0_REG; + + density = (dev_id >> ONENAND_DEVICE_DENSITY_SHIFT) & 0xf; + dbs_dfs = !!(dev_id & ONENAND_DEVICE_IS_DDP); + + fba = density + 7; + if (dbs_dfs) + fba--; /* Decrease the fba */ + fpa = 6; + if (density >= ONENAND_DEVICE_DENSITY_512Mb) + fsa = 2; + else + fsa = 1; + + DPRINTK("FBA %lu, FPA %lu, FSA %lu, DDP %lu", + FBA_WIDTH0_REG, FPA_WIDTH0_REG, FSA_WIDTH0_REG, + DDP_DEVICE_REG); + + DPRINTK("mem_cfg0 0x%lx, sync mode %lu, " + "dev_page_size %lu, BURST LEN %lu", + MEM_CFG0_REG, SYNC_MODE_REG, + DEV_PAGE_SIZE_REG, BURST_LEN0_REG); + + DEV_PAGE_SIZE_REG = 0x1; + + FBA_WIDTH0_REG = fba; + FPA_WIDTH0_REG = fpa; + FSA_WIDTH0_REG = fsa; + DBS_DFS_WIDTH0_REG = dbs_dfs; +} +#endif + +void s3c_onenand_init(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + u32 size = (4 << 10); /* 4 KiB */ + + onenand = malloc(sizeof(struct s3c_onenand)); + if (!onenand) + return; + + onenand->page_buf = malloc(size * sizeof(char)); + if (!onenand->page_buf) + return; + memset(onenand->page_buf, 0xff, size); + + onenand->oob_buf = malloc(128 * sizeof(char)); + if (!onenand->oob_buf) + return; + memset(onenand->oob_buf, 0xff, 128); + + onenand->mtd = mtd; + +#if defined(CONFIG_S3C64XX) + onenand->base = (void *)0x70100000; + onenand->ahb_addr = (void *)0x20000000; +#elif defined(CONFIG_S5PC1XX) + onenand->base = (void *)0xE7100000; + onenand->ahb_addr = (void *)0xB0000000; +#endif + onenand->mem_addr = s3c_mem_addr; + onenand->reg = (struct samsung_onenand *)onenand->base; + + this->read_word = s3c_onenand_readw; + this->write_word = s3c_onenand_writew; + + this->wait = s3c_onenand_wait; + this->bbt_wait = s3c_onenand_bbt_wait; + this->unlock_all = s3c_onenand_unlock_all; + this->command = s3c_onenand_command; + + this->read_bufferram = onenand_read_bufferram; + this->write_bufferram = onenand_write_bufferram; + + this->options |= ONENAND_RUNTIME_BADBLOCK_CHECK; +} diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 06f7baf..9a6f317 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -135,6 +135,7 @@ struct onenand_chip { #define ONENAND_HAS_CONT_LOCK (0x0001) #define ONENAND_HAS_UNLOCK_ALL (0x0002) #define ONENAND_HAS_2PLANE (0x0004) +#define ONENAND_RUNTIME_BADBLOCK_CHECK (0x0200) #define ONENAND_PAGEBUF_ALLOC (0x1000) #define ONENAND_OOBBUF_ALLOC (0x2000)
Minkyu Kang wrote:
This patch includes the onenand driver for s5pc100
Changes since v1:
Changes since v2:
- drop blank lines
Changes since v3:
- fix the copyright
applied to u-boot-samsung
Minkyu Kang
Dear Scott Wood,
Importing code from Linux is one big exception - well knowing, that we will have to solve these issues in some future time.
participants (6)
Kyungmin Park
Minkyu Kang
Minkyu Kang
Scott Wood
Tom
