[U-Boot] [PATCH v3 0/3] apf27: add support of armadeus apf27
Difference between v3 and v2: - rebase on imx branch - merge support and spl patch - clean code of apf27_gpio_init - clean code of start.S - enable only 64MB of ram so it could work on all apf27
Difference between v1 and v2: - use spl instead of nand_spl - use gpio api - remove use of useless CONFIG_SYS - remove use of config.mk - remove dead code
Philippe Reynes (3): apf27: add missing constant to mx27 apf27: add support for the armadeus APF27 board apf27: add FPGA support for the apf27 board
MAINTAINERS | 5 + arch/arm/cpu/arm926ejs/mx27/asm-offsets.c | 34 ++ arch/arm/include/asm/arch-mx27/imx-regs.h | 11 +- arch/arm/include/asm/arch-mx27/mxc_nand.h | 83 +++++ board/armadeus/apf27/Makefile | 51 +++ board/armadeus/apf27/apf27.c | 363 +++++++++++++++++++ board/armadeus/apf27/apf27.h | 477 +++++++++++++++++++++++++ board/armadeus/apf27/fpga.c | 262 ++++++++++++++ board/armadeus/apf27/fpga.h | 39 ++ board/armadeus/apf27/start.S | 538 +++++++++++++++++++++++++++++ board/armadeus/apf27/u-boot-spl.lds | 86 +++++ boards.cfg | 1 + include/configs/apf27.h | 445 ++++++++++++++++++++++++ 13 files changed, 2394 insertions(+), 1 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx27/mxc_nand.h create mode 100644 board/armadeus/apf27/Makefile create mode 100644 board/armadeus/apf27/apf27.c create mode 100644 board/armadeus/apf27/apf27.h create mode 100644 board/armadeus/apf27/fpga.c create mode 100644 board/armadeus/apf27/fpga.h create mode 100644 board/armadeus/apf27/start.S create mode 100644 board/armadeus/apf27/u-boot-spl.lds create mode 100644 include/configs/apf27.h
Add some missing constant (chip select, ...), and a file mxc_nand.h with the NFC constant.
Signed-off-by: Philippe Reynes tremyfr@yahoo.fr Signed-off-by: Eric Jarrige eric.jarrige@armadeus.org --- arch/arm/cpu/arm926ejs/mx27/asm-offsets.c | 34 ++++++++++++ arch/arm/include/asm/arch-mx27/imx-regs.h | 11 ++++- arch/arm/include/asm/arch-mx27/mxc_nand.h | 83 +++++++++++++++++++++++++++++ 3 files changed, 127 insertions(+), 1 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx27/mxc_nand.h
diff --git a/arch/arm/cpu/arm926ejs/mx27/asm-offsets.c b/arch/arm/cpu/arm926ejs/mx27/asm-offsets.c index f3a8d7b..b95c58c 100644 --- a/arch/arm/cpu/arm926ejs/mx27/asm-offsets.c +++ b/arch/arm/cpu/arm926ejs/mx27/asm-offsets.c @@ -34,6 +34,7 @@ int main(void) DEFINE(PCDR1, IMX_PLL_BASE + offsetof(struct pll_regs, pcdr1)); DEFINE(PCCR0, IMX_PLL_BASE + offsetof(struct pll_regs, pccr0)); DEFINE(PCCR1, IMX_PLL_BASE + offsetof(struct pll_regs, pccr1)); + DEFINE(CCSR, IMX_PLL_BASE + offsetof(struct pll_regs, ccsr));
DEFINE(ESDCTL0_ROF, offsetof(struct esdramc_regs, esdctl0)); DEFINE(ESDCFG0_ROF, offsetof(struct esdramc_regs, esdcfg0)); @@ -41,5 +42,38 @@ int main(void) DEFINE(ESDCFG1_ROF, offsetof(struct esdramc_regs, esdcfg1)); DEFINE(ESDMISC_ROF, offsetof(struct esdramc_regs, esdmisc));
+ DEFINE(GPCR, IMX_SYSTEM_CTL_BASE + + offsetof(struct system_control_regs, gpcr)); + DEFINE(FMCR, IMX_SYSTEM_CTL_BASE + + offsetof(struct system_control_regs, fmcr)); + DEFINE(DSCR2, IMX_SYSTEM_CTL_BASE + + offsetof(struct system_control_regs, dscr2)); + DEFINE(DSCR3, IMX_SYSTEM_CTL_BASE + + offsetof(struct system_control_regs, dscr3)); + DEFINE(DSCR7, IMX_SYSTEM_CTL_BASE + + offsetof(struct system_control_regs, dscr7)); + DEFINE(DSCR10, IMX_SYSTEM_CTL_BASE + + offsetof(struct system_control_regs, dscr10)); + + DEFINE(CS0U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs0u)); + DEFINE(CS0L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs0l)); + DEFINE(CS0A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs0a)); + DEFINE(CS1U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs1u)); + DEFINE(CS1L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs1l)); + DEFINE(CS1A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs1a)); + DEFINE(CS2U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs2u)); + DEFINE(CS2L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs2l)); + DEFINE(CS2A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs2a)); + DEFINE(CS3U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs3u)); + DEFINE(CS3L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs3l)); + DEFINE(CS3A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs3a)); + DEFINE(CS4U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs4u)); + DEFINE(CS4L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs4l)); + DEFINE(CS4A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs4a)); + DEFINE(CS5U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs5u)); + DEFINE(CS5L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs5l)); + DEFINE(CS5A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs5a)); + DEFINE(EIM, IMX_WEIM_BASE + offsetof(struct weim_regs, eim)); + return 0; } diff --git a/arch/arm/include/asm/arch-mx27/imx-regs.h b/arch/arm/include/asm/arch-mx27/imx-regs.h index 2f6c823..d3a14e1 100644 --- a/arch/arm/include/asm/arch-mx27/imx-regs.h +++ b/arch/arm/include/asm/arch-mx27/imx-regs.h @@ -185,7 +185,7 @@ struct iim_regs { struct fuse_bank { u32 fuse_regs[0x20]; u32 fuse_rsvd[0xe0]; - } bank[1]; + } bank[2]; };
struct fuse_bank0_regs { @@ -511,4 +511,13 @@ struct fuse_bank0_regs { #define IIM_ERR_SNSE (1 << 2) #define IIM_ERR_PARITYE (1 << 1)
+/* + * Memory areas of the NFC + */ +#define IMX_NFC_BASE (0xD8000000) +#define IMX_NFC_MAIN_AREA0 (0xD8000000) +#define IMX_NFC_MAIN_AREA1 (0xD8000200) +#define IMX_NFC_SPARE_AREA0 (0xD8000800) +#define IMX_NFC_REGS (0xD8000E00) + #endif /* _IMX_REGS_H */ diff --git a/arch/arm/include/asm/arch-mx27/mxc_nand.h b/arch/arm/include/asm/arch-mx27/mxc_nand.h new file mode 100644 index 0000000..564419e --- /dev/null +++ b/arch/arm/include/asm/arch-mx27/mxc_nand.h @@ -0,0 +1,83 @@ +/* + * (c) 2012 Philippe Reynes tremyfr@yahoo.fr + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MXC_NAND_H +#define __MXC_NAND_H + +/* + * NFC registers address offset + */ +#define NFC_OFFSET_BUFSIZE (0x00) /* Internal SRAM Size */ +#define NFC_OFFSET_BLCK_ADD_LOCK (0x02) /* NAND Flash Block Address for + Lock Check */ +#define NFC_OFFSET_BUF_ADDR (0x04) /* Buffer Number for Page Data + Transfer To/From Flash Mem */ +#define NFC_OFFSET_FLASH_ADDR (0x06) /* NAND Flash Address */ +#define NFC_OFFSET_FLASH_CMD (0x08) /* NAND Flash Command */ +#define NFC_OFFSET_CONFIG (0x0A) /* NFC Internal Buffer Lock + Control */ +#define NFC_OFFSET_ECC_STATUS_RESULT (0x0C) /* Controller Status/Result of + Flash Operation */ +#define NFC_OFFSET_ECC_RSLT_MAIN_AREA (0x0E) /* ECC Error Position of Main + Area Data Error */ +#define NFC_OFFSET_ECC_RSLT_SPARE_AREA (0x10) /* ECC Error Position of Spare + Area Data Error */ +#define NFC_OFFSET_WRPROT (0x12) /* Nand Flash Write Protection */ +#define NFC_OFFSET_UNLOCKSTART_BLKADDR (0x14) /* Start Address for Write + Protection Unlock */ +#define NFC_OFFSET_UNLOCKEND_BLKADDR (0x16) /* End Address for Write + Protection Unlock */ +#define NFC_OFFSET_WRPR_STAT (0x18) /* Current Nand Flash Write + Protection Status */ +#define NFC_OFFSET_CONFIG1 (0x1A) /* Nand Flash Operation + Configuration 1 */ +#define NFC_OFFSET_CONFIG2 (0x1C) /* Nand Flash Operation + Configuration 2 */ + +/* NFC_ECC_STATUS_RESULT Status Register Bit Fields */ +#define NFC_ECC_STAT_ERM_SHFT (2) /* ERM shift */ +#define NFC_ECC_STAT_ERS_MASK (0x03) /* ERS mask */ +#define NFC_ECC_STAT_ERROR1 (1<<0) /* correctable error */ +#define NFC_ECC_STAT_ERROR2 (1<<1) /* non correctable error */ + +/* NFC_CONFIG Control Register Bit Fields */ +#define NFC_CONFIG_UNLOCKED (1<<1) /* unlocked */ +#define NFC_CONFIG_LOCKED (1<<0) /* locked */ + +/* NFC_CONFIG1 Control Register Bit Fields */ +#define NFC_CONFIG1_CEn (1<<7) /* Flash force CE */ +#define NFC_CONFIG1_RST (1<<6) /* Reset */ +#define NFC_CONFIG1_BIG (1<<5) /* Big Endian Mode */ +#define NFC_CONFIG1_INT_MSK (1<<4) /* Mask Interrupt Bit */ +#define NFC_CONFIG1_ECC_EN (1<<3) /* ECC operation enable */ +#define NFC_CONFIG1_SP_EN (1<<2) /* Flash spare enable */ + +/* NFC_CONFIG2 Control Register Bit Fields */ +#define NFC_CONFIG2_INT (1<<15) /* Interrupt */ +#define NFC_CONFIG2_FDO_STATUS (4<<3) /* Flash status output */ +#define NFC_CONFIG2_FDO_ID (2<<3) /* Flash ID output */ +#define NFC_CONFIG2_FDO_PAGE (1<<3) /* Flash data output */ +#define NFC_CONFIG2_FDI (1<<2) /* Flash data input */ +#define NFC_CONFIG2_FADD (1<<1) /* Flash address input */ +#define NFC_CONFIG2_FCMD (1<<0) /* Flash command input */ + +#endif
Hi Philippe,
- DEFINE(GPCR, IMX_SYSTEM_CTL_BASE +
- DEFINE(FMCR, IMX_SYSTEM_CTL_BASE +
- DEFINE(DSCR2, IMX_SYSTEM_CTL_BASE +
- DEFINE(DSCR3, IMX_SYSTEM_CTL_BASE +
- DEFINE(DSCR7, IMX_SYSTEM_CTL_BASE +
- DEFINE(DSCR10, IMX_SYSTEM_CTL_BASE +
- DEFINE(CS0U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs0u));
- DEFINE(CS0L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs0l));
- DEFINE(CS0A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs0a));
- DEFINE(CS1U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs1u));
- DEFINE(CS1L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs1l));
- DEFINE(CS1A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs1a));
- DEFINE(CS2U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs2u));
- DEFINE(CS2L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs2l));
- DEFINE(CS2A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs2a));
- DEFINE(CS3U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs3u));
- DEFINE(CS3L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs3l));
- DEFINE(CS3A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs3a));
- DEFINE(CS4U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs4u));
- DEFINE(CS4L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs4l));
- DEFINE(CS4A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs4a));
- DEFINE(CS5U, IMX_WEIM_BASE + offsetof(struct weim_regs, cs5u));
- DEFINE(CS5L, IMX_WEIM_BASE + offsetof(struct weim_regs, cs5l));
- DEFINE(CS5A, IMX_WEIM_BASE + offsetof(struct weim_regs, cs5a));
- DEFINE(EIM, IMX_WEIM_BASE + offsetof(struct weim_regs, eim));
- } bank[1];
- } bank[2];
I think the
- Memory areas of the NFC
- (c) 2012 Philippe Reynes tremyfr@yahoo.fr
- project.
- MA 02111-1307 USA
- NFC registers address offset
Lock Check */
Control */
Flash Operation */
Area Data Error */
Area Data Error */
Configuration 1 */
Configuration 2 */
Why do you need an extra definitions for the NFC controller when we have already one general for all i.MX ? What you define here can be found in include/fsl_nfc.h, and the NFC controller for i.MX27 is supported as well.
Best regards, Stefano Babic
Signed-off-by: Philippe Reynes tremyfr@yahoo.fr Signed-off-by: Eric Jarrige eric.jarrige@armadeus.org Signed-off-by: Nicolas Colombain nicolas.colombain@armadeus.com --- MAINTAINERS | 5 + board/armadeus/apf27/Makefile | 48 +++ board/armadeus/apf27/apf27.c | 347 ++++++++++++++++++++++ board/armadeus/apf27/apf27.h | 477 +++++++++++++++++++++++++++++++ board/armadeus/apf27/start.S | 538 +++++++++++++++++++++++++++++++++++ board/armadeus/apf27/u-boot-spl.lds | 86 ++++++ boards.cfg | 1 + include/configs/apf27.h | 445 +++++++++++++++++++++++++++++ 8 files changed, 1947 insertions(+), 0 deletions(-) create mode 100644 board/armadeus/apf27/Makefile create mode 100644 board/armadeus/apf27/apf27.c create mode 100644 board/armadeus/apf27/apf27.h create mode 100644 board/armadeus/apf27/start.S create mode 100644 board/armadeus/apf27/u-boot-spl.lds create mode 100644 include/configs/apf27.h
diff --git a/MAINTAINERS b/MAINTAINERS index e34d9f3..3ac0c92 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -696,6 +696,11 @@ Ilko Iliev iliev@ronetix.at PM9263 AT91SAM9263 PM9G45 ARM926EJS (AT91SAM9G45 SoC)
+Eric Jarrige eric.jarrige@armadeus.org +Philippe Reynes tremyfr@yahoo.fr + + apf27 ARM926EJS (i.MX27 SoC) + Michael Jones michael.jones@matrix-vision.de
omap3_mvblx ARM ARMV7 (OMAP3xx SoC) diff --git a/board/armadeus/apf27/Makefile b/board/armadeus/apf27/Makefile new file mode 100644 index 0000000..f57f405 --- /dev/null +++ b/board/armadeus/apf27/Makefile @@ -0,0 +1,48 @@ +# +# (C) Copyright 2000-2004 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# (C) Copyright 2012 +# Eric Jarrige eric.jarrige@armadeus.org +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifndef CONFIG_SPL_BUILD +COBJS := apf27.o +endif + +SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) +START := $(addprefix $(obj),$(START)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/armadeus/apf27/apf27.c b/board/armadeus/apf27/apf27.c new file mode 100644 index 0000000..cbd09a7 --- /dev/null +++ b/board/armadeus/apf27/apf27.c @@ -0,0 +1,347 @@ +/* + * Copyright (C) 2007 Sascha Hauer, Pengutronix + * Copyright (C) 2008-2012 Eric Jarrige eric.jarrige@armadeus.org + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <environment.h> +#include <jffs2/jffs2.h> +#include <nand.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/gpio.h> +#include <asm/errno.h> +#include "apf27.h" +#include "crc.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Fuse bank 1 row 8 is "reserved for future use" and therefore available for + * customer use. The APF27 board uses this fuse to store the board revision: + * 0: initial board revision + * 1: first revision - Presence of the second RAM chip on the board is blown in + * fuse bank 1 row 9 bit 0 - No hardware change + * N: to be defined + */ +u32 get_board_rev(void) +{ + struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; + + return readl(&iim->bank[1].fuse_regs[8]); +} + +/* + * Fuse bank 1 row 9 is "reserved for future use" and therefore available for + * customer use. The APF27 board revision 1 uses the bit 0 to permanently store + * the presence of the second RAM chip + * 0: AFP27 with 1 RAM of 64 MiB + * 1: AFP27 with 2 RAM chips of 64 MiB each (128MB) + */ +int get_num_ram_bank(void) +{ + struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; + int nr_dram_banks = 1; + + if ((get_board_rev() > 0) && (CONFIG_NR_DRAM_BANKS > 1)) + nr_dram_banks += readl(&iim->bank[1].fuse_regs[9]) & 0x01; + else + nr_dram_banks = CONFIG_NR_DRAM_POPULATED; + + return nr_dram_banks; +} + +static void apf27_port_init(int port, u32 gpio_dr, u32 ocr1, u32 ocr2, + u32 iconfa1, u32 iconfa2, u32 iconfb1, u32 iconfb2, + u32 icr1, u32 icr2, u32 imr, u32 gpio_dir, u32 gpr, + u32 puen, u32 gius) +{ + struct gpio_port_regs *regs = (struct gpio_port_regs *)IMX_GPIO_BASE; + + writel(gpio_dr, ®s->port[port].gpio_dr); + writel(ocr1, ®s->port[port].ocr1); + writel(ocr2, ®s->port[port].ocr2); + writel(iconfa1, ®s->port[port].iconfa1); + writel(iconfa2, ®s->port[port].iconfa2); + writel(iconfb1, ®s->port[port].iconfb1); + writel(iconfb2, ®s->port[port].iconfb2); + writel(icr1, ®s->port[port].icr1); + writel(icr2, ®s->port[port].icr2); + writel(imr, ®s->port[port].imr); + writel(gpio_dir, ®s->port[port].gpio_dir); + writel(gpr, ®s->port[port].gpr); + writel(puen, ®s->port[port].puen); + writel(gius, ®s->port[port].gius); +} + +#define APF27_PORT_INIT(n) apf27_port_init(PORT##n, ACFG_DR_##n##_VAL, \ + ACFG_OCR1_##n##_VAL, ACFG_OCR2_##n##_VAL, ACFG_ICFA1_##n##_VAL, \ + ACFG_ICFA2_##n##_VAL, ACFG_ICFB1_##n##_VAL, ACFG_ICFB2_##n##_VAL, \ + ACFG_ICR1_##n##_VAL, ACFG_ICR2_##n##_VAL, ACFG_IMR_##n##_VAL, \ + ACFG_DDIR_##n##_VAL, ACFG_GPR_##n##_VAL, ACFG_PUEN_##n##_VAL, \ + ACFG_GIUS_##n##_VAL) + +void apf27_gpio_init(void) +{ + APF27_PORT_INIT(A); + APF27_PORT_INIT(B); + APF27_PORT_INIT(C); + APF27_PORT_INIT(D); + APF27_PORT_INIT(E); + APF27_PORT_INIT(F); +} + +static int apf27_devices_init(void) +{ + struct gpio_port_regs *regs = (struct gpio_port_regs *)IMX_GPIO_BASE; + int i; + unsigned int mode[] = { + PD0_AIN_FEC_TXD0, + PD1_AIN_FEC_TXD1, + PD2_AIN_FEC_TXD2, + PD3_AIN_FEC_TXD3, + PD4_AOUT_FEC_RX_ER, + PD5_AOUT_FEC_RXD1, + PD6_AOUT_FEC_RXD2, + PD7_AOUT_FEC_RXD3, + PD8_AF_FEC_MDIO, + PD9_AIN_FEC_MDC | GPIO_PUEN, + PD10_AOUT_FEC_CRS, + PD11_AOUT_FEC_TX_CLK, + PD12_AOUT_FEC_RXD0, + PD13_AOUT_FEC_RX_DV, + PD14_AOUT_FEC_CLR, + PD15_AOUT_FEC_COL, + PD16_AIN_FEC_TX_ER, + PF23_AIN_FEC_TX_EN, + PE12_PF_UART1_TXD, + PE13_PF_UART1_RXD, + }; + + for (i = 0; i < ARRAY_SIZE(mode); i++) + imx_gpio_mode(mode[i]); + +#ifdef CONFIG_MXC_MMC + mx27_sd2_init_pins(); + imx_gpio_mode((GPIO_PORTF | GPIO_OUT | GPIO_PUEN | GPIO_GPIO | 16)); + writel(readl(®s->port[PORTF].gpio_dr) | (1 << 16), + ®s->port[PORTF].gpio_dr); +#endif + return 0; +} + +static void board_setup_aipi(void) +{ + struct aipi_regs *aipi1 = (struct aipi_regs *)IMX_AIPI1_BASE; + struct aipi_regs *aipi2 = (struct aipi_regs *)IMX_AIPI2_BASE; + struct system_control_regs *system = \ + (struct system_control_regs *)IMX_SYSTEM_CTL_BASE; + u32 gpcr; + + /* setup AIPI1 and AIPI2 */ + writel(ACFG_AIPI1_PSR0_VAL, &aipi1->psr0); + writel(ACFG_AIPI1_PSR1_VAL, &aipi1->psr1); + writel(ACFG_AIPI2_PSR0_VAL, &aipi2->psr0); + writel(ACFG_AIPI2_PSR1_VAL, &aipi2->psr1); + + /* Change SDRAM signal strengh */ + gpcr = readl(&system->gpcr); + gpcr |= ACFG_GPCR_VAL; + writel(gpcr, &system->gpcr); +} + +static void board_setup_csx(void) +{ + struct weim_regs *weim = (struct weim_regs *)IMX_WEIM_BASE; + + writel(ACFG_CS0U_VAL, &weim->cs0u); + writel(ACFG_CS0L_VAL, &weim->cs0l); + writel(ACFG_CS0A_VAL, &weim->cs0a); + + writel(ACFG_CS1U_VAL, &weim->cs1u); + writel(ACFG_CS1L_VAL, &weim->cs1l); + writel(ACFG_CS1A_VAL, &weim->cs1a); + + writel(ACFG_CS2U_VAL, &weim->cs2u); + writel(ACFG_CS2L_VAL, &weim->cs2l); + writel(ACFG_CS2A_VAL, &weim->cs2a); + + writel(ACFG_CS3U_VAL, &weim->cs3u); + writel(ACFG_CS3L_VAL, &weim->cs3l); + writel(ACFG_CS3A_VAL, &weim->cs3a); + + writel(ACFG_CS4U_VAL, &weim->cs4u); + writel(ACFG_CS4L_VAL, &weim->cs4l); + writel(ACFG_CS4A_VAL, &weim->cs4a); + + writel(ACFG_CS5U_VAL, &weim->cs5u); + writel(ACFG_CS5L_VAL, &weim->cs5l); + writel(ACFG_CS5A_VAL, &weim->cs5a); + + writel(ACFG_EIM_VAL, &weim->eim); +} + +static void board_setup_port(void) +{ + struct system_control_regs *system = \ + (struct system_control_regs *)IMX_SYSTEM_CTL_BASE; + + writel(ACFG_FMCR_VAL, &system->fmcr); +} + +static void board_setup_clock() +{ + struct pll_regs *pll = (struct pll_regs *)IMX_PLL_BASE; + volatile int wait = 0x1000; + u32 cscr; + + /* disable MPLL/SPLL first */ + cscr = readl(&pll->cscr); + cscr &= ~(CSCR_MPEN|CSCR_SPEN); + writel(cscr, &pll->cscr); + + /* pll clock initialization */ + writel(ACFG_MPCTL0_VAL, &pll->mpctl0); + writel(ACFG_SPCTL0_VAL, &pll->spctl0); + + cscr = ACFG_CSCR_VAL|CSCR_MPLL_RESTART|CSCR_SPLL_RESTART; + writel(cscr, &pll->cscr); + + /* add some delay here */ + while (wait) + wait--; + + /* peripheral clock divider */ + writel(ACFG_PCDR0_VAL, &pll->pcdr0); + writel(ACFG_PCDR1_VAL, &pll->pcdr1); + + /* Configure PCCR0 and PCCR1 */ + writel(ACFG_PCCR0_VAL, &pll->pccr0); + writel(ACFG_PCCR1_VAL, &pll->pccr1); +} + +int board_early_init_f(void) +{ + board_setup_aipi(); + board_setup_csx(); + board_setup_port(); + board_setup_clock(); + + return 0; +} + +int +board_init(void) +{ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + apf27_gpio_init(); + apf27_devices_init(); + + return 0; +} + +int +dram_init(void) +{ + /* dram_init must store complete ramsize in gd->ram_size */ + if (get_num_ram_bank() > 1) { + gd->ram_size = PHYS_SDRAM_2 - CONFIG_SYS_SDRAM_BASE + + get_ram_size((void *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); + } else { + gd->ram_size = get_ram_size((void *)PHYS_SDRAM_1, + PHYS_SDRAM_1_SIZE); + } + + return 0; +} + +void dram_init_banksize(void) +{ + phys_size_t ramsize = gd->ram_size; + + if (get_num_ram_bank() > 1) + ramsize -= PHYS_SDRAM_2 - CONFIG_SYS_SDRAM_BASE; + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = ramsize; + gd->ram_size = gd->bd->bi_dram[0].size; + + if (CONFIG_NR_DRAM_BANKS > 1) { + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + if (get_num_ram_bank() > 1) + gd->bd->bi_dram[1].size = ramsize; + else + gd->bd->bi_dram[1].size = 0; + gd->ram_size += gd->bd->bi_dram[1].size; + } +} + +/* + * Miscellaneous initialisation + */ +int +misc_init_r(void) +{ + char *s; + u_char * firmware_buffer = (u_char *)(CONFIG_SYS_LOAD_ADDR + \ + CONFIG_SYS_MONITOR_LEN); + size_t size = 0; + size_t offset = -1; + char *autoload = getenv("firmware_autoload"); + u8 pnum; + struct mtd_device *dev; + struct part_info *part; + + /* detect compatibility issue of environment version */ + s = getenv("env_version"); + if ((NULL == s) || (0 != strcmp(s, CONFIG_ENV_VERSION))) { + char * const vars[] = {"flash_reset_env"}; + printf("*** Warning - Environment version change suggests: " + "run flash_reset_env; reset\n"); + set_default_vars(1, vars); + } + + /* Unlock whole flash but U-Boot */ + s = getenv("env_offset"); + offset = CONFIG_ENV_OFFSET; + if ((s != NULL) && (0 != strcmp(s, "0"))) + offset = simple_strtoul(s, NULL, 16); + + if (nand_unlock(&nand_info[0], offset, nand_info[0].size - offset, 0)) + printf("NAND flash lock/unlocked failed\n"); + + + return 0; +} + +int checkboard(void) +{ + printf("Board: Armadeus APF27 revision %d\n", get_board_rev()); + return 0; +} + +void enable_caches(void) +{ + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); +} + +inline void lowlevel_init(void) {} diff --git a/board/armadeus/apf27/apf27.h b/board/armadeus/apf27/apf27.h new file mode 100644 index 0000000..bb007e8 --- /dev/null +++ b/board/armadeus/apf27/apf27.h @@ -0,0 +1,477 @@ +#ifndef __APF27_H +#define __APF27_H + +/* FPGA program pin configuration */ +#define ACFG_FPGA_PWR (GPIO_PORTF | 19) /* FPGA prog pin */ +#define ACFG_FPGA_PRG (GPIO_PORTF | 11) /* FPGA prog pin */ +#define ACFG_FPGA_CLK (GPIO_PORTF | 15) /* FPGA clk pin */ +#define ACFG_FPGA_RDATA 0xD6000000 /* FPGA data addr */ +#define ACFG_FPGA_WDATA 0xD6000000 /* FPGA data addr */ +#define ACFG_FPGA_INIT (GPIO_PORTF | 12) /* FPGA init pin */ +#define ACFG_FPGA_DONE (GPIO_PORTF | 9) /* FPGA done pin */ +#define ACFG_FPGA_RW (GPIO_PORTF | 21) /* FPGA done pin */ +#define ACFG_FPGA_CS (GPIO_PORTF | 22) /* FPGA done pin */ +#define ACFG_FPGA_SUSPEND (GPIO_PORTF | 10) /* FPGA done pin */ +#define ACFG_FPGA_RESET (GPIO_PORTF | 7) /* FPGA done pin */ + +/* MPU CLOCK source before PLL */ +/* ACFG_CLK_FREQ (2/3 MPLL clock or ext 266 MHZ) */ +#ifndef CONFIG_MX27_CLK26 +#if (CONFIG_MX27_CLK32 == 32000) +#define ACFG_MPCTL0_VAL 0x00211803 /* 398.998 MHz */ +#define ACFG_MPCTL1_VAL 0 +#define CONFIG_MPLL_FREQ 399 +#else /* CONFIG_MX27_CLK32 == 32768*/ +#define ACFG_MPCTL0_VAL 0x01EF15D5 /* 399.000 MHz */ +#define ACFG_MPCTL1_VAL 0 +#define CONFIG_MPLL_FREQ 399 +#endif /* CONFIG_MX27_CLK32 */ +#else /* CONFIG_MX27_CLK26 in use*/ +#define ACFG_MPCTL0_VAL 0x00331C23 /* 399.000 MHz */ +#define ACFG_MPCTL1_VAL 0 +#define CONFIG_MPLL_FREQ 399 +#endif /* CONFIG_MX27_CLK26 */ + +#define ACFG_CLK_FREQ (CONFIG_MPLL_FREQ*2/3) /* 266 MHz */ + +/* Serial clock source before PLL (should be named ACFG_SYSPLL_CLK_FREQ)*/ +#ifndef CONFIG_MX27_CLK26 +#if (CONFIG_MX27_CLK32 == 32000) +#define ACFG_SPCTL0_VAL 0x04A02419 /* 300.00020 MHz */ +#define ACFG_SPCTL1_VAL 0 +#define CONFIG_SPLL_FREQ 300 /* MHz */ +#else /* CONFIG_MX27_CLK32 == 32768*/ +#define ACFG_SPCTL0_VAL 0x0475206F /* 299.99937 MHz */ +#define ACFG_SPCTL1_VAL 0 +#define CONFIG_SPLL_FREQ 300 /* MHz */ +#endif /* CONFIG_MX27_CLK32 */ +#else /* CONFIG_MX27_CLK26 in use*/ +#define ACFG_SPCTL0_VAL 0x040C2C07 /* 300 MHz */ +#define ACFG_SPCTL1_VAL 0x0 +#define CONFIG_SPLL_FREQ 300 /* MHz */ +#endif /* CONFIG_MX27_CLK26 */ + +/* ARM bus frequency (have to be a CONFIG_MPLL_FREQ ratio) */ +#define CONFIG_ARM_FREQ 399 /* up to 400 MHz */ + +/* external bus frequency (have to be a ACFG_CLK_FREQ ratio) */ +#define CONFIG_HCLK_FREQ 133 /* (ACFG_CLK_FREQ/2) */ + +#define CONFIG_PERIF1_FREQ 16 /* 16.625 MHz UART, GPT, PWM*/ +#define CONFIG_PERIF2_FREQ 33 /* 33.25 MHz CSPI and SDHC */ +#define CONFIG_PERIF3_FREQ 33 /* 33.25 MHz LCD*/ +#define CONFIG_PERIF4_FREQ 33 /* 33.25 MHz CSI*/ +#define CONFIG_SSI1_FREQ 66 /* 66.50 MHz SSI1*/ +#define CONFIG_SSI2_FREQ 66 /* 66.50 MHz SSI2*/ +#define CONFIG_MSHC_FREQ 66 /* 66.50 MHz MSHC*/ +#define CONFIG_H264_FREQ 66 /* 66.50 MHz H264*/ +#define CONFIG_CLK0_DIV 3 /* Divide CLK0 by 4 */ +#define CONFIG_CLK0_EN 1 /* CLK0 enabled */ + +/* external bus frequency (have to be a CONFIG_HCLK_FREQ ratio) */ +#define CONFIG_NFC_FREQ 44 /* NFC Clock up to 44 MHz wh 133MHz*/ + +/* external serial bus frequency (have to be a CONFIG_SPLL_FREQ ratio) */ +#define CONFIG_USB_FREQ 60 /* 60 MHz */ + +/* + * SDRAM + */ +#if (ACFG_SDRAM_MBYTE_SYZE == 64) /* micron MT46H16M32LF -6 */ +/* micron 64MB */ +#define ACFG_SDRAM_NUM_COL 9 /* 8, 9, 10 or 11 + column address bits */ +#define ACFG_SDRAM_NUM_ROW 13 /* 11, 12 or 13 + row address bits */ +#define ACFG_SDRAM_REFRESH 3 /* 0=OFF 1=2048 + 2=4096 3=8192 refresh */ +#define ACFG_SDRAM_EXIT_PWD 25 /* ns exit power + down delay */ +#define ACFG_SDRAM_W2R_DELAY 1 /* write to read + cycle delay > 0 */ +#define ACFG_SDRAM_ROW_PRECHARGE_DELAY 18 /* ns */ +#define ACFG_SDRAM_TMRD_DELAY 2 /* Load mode register + cycle delay 1..4 */ +#define ACFG_SDRAM_TWR_DELAY 1 /* LPDDR: 0=2ck 1=3ck; + SDRAM: 0=1ck 1=2ck*/ +#define ACFG_SDRAM_RAS_DELAY 42 /* ns ACTIVE-to-PRECHARGE + delay */ +#define ACFG_SDRAM_RRD_DELAY 12 /* ns ACTIVE-to-ACTIVE + delay */ +#define ACFG_SDRAM_RCD_DELAY 18 /* ns Row to Column delay */ +#define ACFG_SDRAM_RC_DELAY 70 /* ns Row cycle delay (tRFC + refresh to command) */ +#define ACFG_SDRAM_CLOCK_CYCLE_CL_1 0 /* ns clock cycle time + estimated fo CL=1 + 0=force 3 for lpddr */ +#define ACFG_SDRAM_PARTIAL_ARRAY_SR 0 /* 0=full 1=half 2=quater + 3=Eighth 4=Sixteenth */ +#define ACFG_SDRAM_DRIVE_STRENGH 0 /* 0=Full-strength 1=half + 2=quater 3=Eighth */ +#define ACFG_SDRAM_BURST_LENGTH 3 /* 2^N BYTES (N=0..3) */ +#define ACFG_SDRAM_SINGLE_ACCESS 0 /* 1= single access; + 0 = Burst mode */ +#endif + +#if (ACFG_SDRAM_MBYTE_SYZE == 128) +/* micron 128MB */ +#define ACFG_SDRAM_NUM_COL 9 /* 8, 9, 10 or 11 + column address bits */ +#define ACFG_SDRAM_NUM_ROW 14 /* 11, 12 or 13 + row address bits */ +#define ACFG_SDRAM_REFRESH 3 /* 0=OFF 1=2048 + 2=4096 3=8192 refresh */ +#define ACFG_SDRAM_EXIT_PWD 25 /* ns exit power + down delay */ +#define ACFG_SDRAM_W2R_DELAY 1 /* write to read + cycle delay > 0 */ +#define ACFG_SDRAM_ROW_PRECHARGE_DELAY 18 /* ns */ +#define ACFG_SDRAM_TMRD_DELAY 2 /* Load mode register + cycle delay 1..4 */ +#define ACFG_SDRAM_TWR_DELAY 1 /* LPDDR: 0=2ck 1=3ck; + SDRAM: 0=1ck 1=2ck*/ +#define ACFG_SDRAM_RAS_DELAY 42 /* ns ACTIVE-to-PRECHARGE + delay */ +#define ACFG_SDRAM_RRD_DELAY 12 /* ns ACTIVE-to-ACTIVE + delay */ +#define ACFG_SDRAM_RCD_DELAY 18 /* ns Row to Column delay */ +#define ACFG_SDRAM_RC_DELAY 70 /* ns Row cycle delay (tRFC + refresh to command)*/ +#define ACFG_SDRAM_CLOCK_CYCLE_CL_1 0 /* ns clock cycle time + estimated fo CL=1 + 0=force 3 for lpddr*/ +#define ACFG_SDRAM_PARTIAL_ARRAY_SR 0 /* 0=full 1=half 2=quater + 3=Eighth 4=Sixteenth */ +#define ACFG_SDRAM_DRIVE_STRENGH 0 /* 0=Full-strength 1=half + 2=quater 3=Eighth */ +#define ACFG_SDRAM_BURST_LENGTH 3 /* 2^N BYTES (N=0..3) */ +#define ACFG_SDRAM_SINGLE_ACCESS 0 /* 1= single access; + 0 = Burst mode */ +#endif + +#if (ACFG_SDRAM_MBYTE_SYZE == 256) +/* micron 256MB */ +#define ACFG_SDRAM_NUM_COL 10 /* 8, 9, 10 or 11 + column address bits */ +#define ACFG_SDRAM_NUM_ROW 14 /* 11, 12 or 13 + row address bits */ +#define ACFG_SDRAM_REFRESH 3 /* 0=OFF 1=2048 + 2=4096 3=8192 refresh */ +#define ACFG_SDRAM_EXIT_PWD 25 /* ns exit power + down delay */ +#define ACFG_SDRAM_W2R_DELAY 1 /* write to read cycle + delay > 0 */ +#define ACFG_SDRAM_ROW_PRECHARGE_DELAY 18 /* ns */ +#define ACFG_SDRAM_TMRD_DELAY 2 /* Load mode register + cycle delay 1..4 */ +#define ACFG_SDRAM_TWR_DELAY 1 /* LPDDR: 0=2ck 1=3ck; + SDRAM: 0=1ck 1=2ck */ +#define ACFG_SDRAM_RAS_DELAY 42 /* ns ACTIVE-to-PRECHARGE + delay */ +#define ACFG_SDRAM_RRD_DELAY 12 /* ns ACTIVE-to-ACTIVE + delay */ +#define ACFG_SDRAM_RCD_DELAY 18 /* ns Row to Column delay */ +#define ACFG_SDRAM_RC_DELAY 70 /* ns Row cycle delay (tRFC + refresh to command) */ +#define ACFG_SDRAM_CLOCK_CYCLE_CL_1 0 /* ns clock cycle time + estimated fo CL=1 + 0=force 3 for lpddr */ +#define ACFG_SDRAM_PARTIAL_ARRAY_SR 0 /* 0=full 1=half 2=quater + 3=Eighth 4=Sixteenth */ +#define ACFG_SDRAM_DRIVE_STRENGH 0 /* 0=Full-strength + 1=half + 2=quater + 3=Eighth */ +#define ACFG_SDRAM_BURST_LENGTH 3 /* 2^N BYTES (N=0..3) */ +#define ACFG_SDRAM_SINGLE_ACCESS 0 /* 1= single access; + 0 = Burst mode */ +#endif + +/* + * External interface + */ +/* + * CSCRxU_VAL: + * 31| x | x | x x |x x x x| x x | x | x |x x x x|16 + * |SP |WP | BCD | BCS | PSZ |PME|SYNC| DOL | + * + * 15| x x | x x x x x x | x | x x x x | x x x x |0 + * | CNC | WSC |EW | WWS | EDC | + * + * CSCRxL_VAL: + * 31| x x x x | x x x x | x x x x | x x x x |16 + * | OEA | OEN | EBWA | EBWN | + * 15|x x x x| x |x x x |x x x x| x | x | x | x | 0 + * | CSA |EBC| DSZ | CSN |PSR|CRE|WRAP|CSEN| + * + * CSCRxA_VAL: + * 31| x x x x | x x x x | x x x x | x x x x |16 + * | EBRA | EBRN | RWA | RWN | + * 15| x | x x |x x x|x x|x x|x x| x | x | x | x | 0 + * |MUM| LAH | LBN |LBA|DWW|DCT|WWU|AGE|CNC2|FCE| + */ + +/* CS0 configuration for 16 bit nor flash */ +#define ACFG_CS0U_VAL 0x0000CC03 +#define ACFG_CS0L_VAL 0xa0330D01 +#define ACFG_CS0A_VAL 0x00220800 + +#define ACFG_CS1U_VAL 0x00000f00 +#define ACFG_CS1L_VAL 0x00000D01 +#define ACFG_CS1A_VAL 0 + +#define ACFG_CS2U_VAL 0 +#define ACFG_CS2L_VAL 0 +#define ACFG_CS2A_VAL 0 + +#define ACFG_CS3U_VAL 0 +#define ACFG_CS3L_VAL 0 +#define ACFG_CS3A_VAL 0 + +#define ACFG_CS4U_VAL 0 +#define ACFG_CS4L_VAL 0 +#define ACFG_CS4A_VAL 0 + +/* FPGA 16 bit data bus */ +#define ACFG_CS5U_VAL 0x00000600 +#define ACFG_CS5L_VAL 0x00000D01 +#define ACFG_CS5A_VAL 0 + +#define ACFG_EIM_VAL 0x00002200 + +/* FPGA specific settings */ +/* CLKO */ +#define ACFG_CCSR_VAL 0x00000305 +/* drive strength CLKO set to 2*/ +#define ACFG_DSCR10_VAL 0x00020000 +/* drive strength A1..A12 set to 2*/ +#define ACFG_DSCR3_VAL 0x02AAAAA8 +/* drive strength ctrl*/ +#define ACFG_DSCR7_VAL 0x00020880 +/* drive strength data*/ +#define ACFG_DSCR2_VAL 0xAAAAAAAA + + +/* + * Default configuration for GPIOs and peripherals + */ +#ifndef ACFG_APF27_CUSTOM +#define ACFG_DDIR_A_VAL 0x00000000 +#define ACFG_OCR1_A_VAL 0x00000000 +#define ACFG_OCR2_A_VAL 0x00000000 +#define ACFG_ICFA1_A_VAL 0xFFFFFFFF +#define ACFG_ICFA2_A_VAL 0xFFFFFFFF +#define ACFG_ICFB1_A_VAL 0xFFFFFFFF +#define ACFG_ICFB2_A_VAL 0xFFFFFFFF +#define ACFG_DR_A_VAL 0x00000000 +#define ACFG_GIUS_A_VAL 0xFFFFFFFF +#define ACFG_ICR1_A_VAL 0x00000000 +#define ACFG_ICR2_A_VAL 0x00000000 +#define ACFG_IMR_A_VAL 0x00000000 +#define ACFG_GPR_A_VAL 0x00000000 +#define ACFG_PUEN_A_VAL 0xFFFFFFFF + +#define ACFG_DDIR_B_VAL 0x00000000 +#define ACFG_OCR1_B_VAL 0x00000000 +#define ACFG_OCR2_B_VAL 0x00000000 +#define ACFG_ICFA1_B_VAL 0xFFFFFFFF +#define ACFG_ICFA2_B_VAL 0xFFFFFFFF +#define ACFG_ICFB1_B_VAL 0xFFFFFFFF +#define ACFG_ICFB2_B_VAL 0xFFFFFFFF +#define ACFG_DR_B_VAL 0x00000000 +#define ACFG_GIUS_B_VAL 0xFF3FFFF0 +#define ACFG_ICR1_B_VAL 0x00000000 +#define ACFG_ICR2_B_VAL 0x00000000 +#define ACFG_IMR_B_VAL 0x00000000 +#define ACFG_GPR_B_VAL 0x00000000 +#define ACFG_PUEN_B_VAL 0xFFFFFFFF + +#define ACFG_DDIR_C_VAL 0x00000000 +#define ACFG_OCR1_C_VAL 0x00000000 +#define ACFG_OCR2_C_VAL 0x00000000 +#define ACFG_ICFA1_C_VAL 0xFFFFFFFF +#define ACFG_ICFA2_C_VAL 0xFFFFFFFF +#define ACFG_ICFB1_C_VAL 0xFFFFFFFF +#define ACFG_ICFB2_C_VAL 0xFFFFFFFF +#define ACFG_DR_C_VAL 0x00000000 +#define ACFG_GIUS_C_VAL 0xFFFFC07F +#define ACFG_ICR1_C_VAL 0x00000000 +#define ACFG_ICR2_C_VAL 0x00000000 +#define ACFG_IMR_C_VAL 0x00000000 +#define ACFG_GPR_C_VAL 0x00000000 +#define ACFG_PUEN_C_VAL 0xFFFFFF87 + +#define ACFG_DDIR_D_VAL 0x00000000 +#define ACFG_OCR1_D_VAL 0x00000000 +#define ACFG_OCR2_D_VAL 0x00000000 +#define ACFG_ICFA1_D_VAL 0xFFFFFFFF +#define ACFG_ICFA2_D_VAL 0xFFFFFFFF +#define ACFG_ICFB1_D_VAL 0xFFFFFFFF +#define ACFG_ICFB2_D_VAL 0xFFFFFFFF +#define ACFG_DR_D_VAL 0x00000000 +#define ACFG_GIUS_D_VAL 0xFFFFFFFF +#define ACFG_ICR1_D_VAL 0x00000000 +#define ACFG_ICR2_D_VAL 0x00000000 +#define ACFG_IMR_D_VAL 0x00000000 +#define ACFG_GPR_D_VAL 0x00000000 +#define ACFG_PUEN_D_VAL 0xFFFFFFFF + +#define ACFG_DDIR_E_VAL 0x00000000 +#define ACFG_OCR1_E_VAL 0x00000000 +#define ACFG_OCR2_E_VAL 0x00000000 +#define ACFG_ICFA1_E_VAL 0xFFFFFFFF +#define ACFG_ICFA2_E_VAL 0xFFFFFFFF +#define ACFG_ICFB1_E_VAL 0xFFFFFFFF +#define ACFG_ICFB2_E_VAL 0xFFFFFFFF +#define ACFG_DR_E_VAL 0x00000000 +#define ACFG_GIUS_E_VAL 0xFCFFCCF8 +#define ACFG_ICR1_E_VAL 0x00000000 +#define ACFG_ICR2_E_VAL 0x00000000 +#define ACFG_IMR_E_VAL 0x00000000 +#define ACFG_GPR_E_VAL 0x00000000 +#define ACFG_PUEN_E_VAL 0xFFFFFFFF + +#define ACFG_DDIR_F_VAL 0x00000000 +#define ACFG_OCR1_F_VAL 0x00000000 +#define ACFG_OCR2_F_VAL 0x00000000 +#define ACFG_ICFA1_F_VAL 0xFFFFFFFF +#define ACFG_ICFA2_F_VAL 0xFFFFFFFF +#define ACFG_ICFB1_F_VAL 0xFFFFFFFF +#define ACFG_ICFB2_F_VAL 0xFFFFFFFF +#define ACFG_DR_F_VAL 0x00000000 +#define ACFG_GIUS_F_VAL 0xFF7F8000 +#define ACFG_ICR1_F_VAL 0x00000000 +#define ACFG_ICR2_F_VAL 0x00000000 +#define ACFG_IMR_F_VAL 0x00000000 +#define ACFG_GPR_F_VAL 0x00000000 +#define ACFG_PUEN_F_VAL 0xFFFFFFFF +#endif /* ACFG_APF27_CUSTOM */ + +/* Enforce DDR signal strengh & enable USB/PP/DMA burst override bits */ +#define ACFG_GPCR_VAL 0x0003000F + +#define ACFG_ESDMISC_VAL ESDMISC_LHD+ESDMISC_MDDREN + +/* FMCR select num LPDDR RAMs and nand 16bits, 2KB pages */ +#if (CONFIG_NR_DRAM_BANKS == 1) +#define ACFG_FMCR_VAL 0xFFFFFFF9 +#elif (CONFIG_NR_DRAM_BANKS == 2) +#define ACFG_FMCR_VAL 0xFFFFFFFB +#endif + +#ifndef ACFG_APF27_CUSTOM +#define ACFG_AIPI1_PSR0_VAL 0x20040304 +#define ACFG_AIPI1_PSR1_VAL 0xDFFBFCFB +#define ACFG_AIPI2_PSR0_VAL 0x00000000 +#define ACFG_AIPI2_PSR1_VAL 0xFFFFFFFF +#endif /* ACFG_APF27_CUSTOM */ + +/* PCCR enable DMA FEC I2C1 IIM SDHC1 */ +#ifndef ACFG_APF27_CUSTOM +#define ACFG_PCCR0_VAL 0x05070410 +#define ACFG_PCCR1_VAL 0xA14A0608 +#endif /* ACFG_APF27_CUSTOM */ + +/* + * From here, there should not be any user configuration. + * All Equations are automatic + */ + +/* fixme none integer value (7.5ns) => 2*hclock = 15ns */ +#define ACFG_2XHCLK_LGTH (2000/CONFIG_HCLK_FREQ) /* ns */ + +/* USB 60 MHz ; ARM up to 400; HClK up to 133MHz*/ +#ifdef CONFIG_MX27_CLK26 +#define CSCR_MASK 0x0303800D +#else +#define CSCR_MASK 0x0300800D +#endif +#define ACFG_CSCR_VAL\ + (CSCR_MASK \ + |((((CONFIG_SPLL_FREQ/CONFIG_USB_FREQ)-1)&0x07) << 28) \ + |((((CONFIG_MPLL_FREQ/CONFIG_ARM_FREQ)-1)&0x03) << 12) \ + |((((ACFG_CLK_FREQ/CONFIG_HCLK_FREQ)-1)&0x03) << 8)) + +/* SSIx CLKO NFC H264 MSHC */ +#define ACFG_PCDR0_VAL\ + (((((ACFG_CLK_FREQ/CONFIG_MSHC_FREQ)-1)&0x3F)<<0) \ + |((((CONFIG_HCLK_FREQ/CONFIG_NFC_FREQ)-1)&0x0F)<<6) \ + |(((((ACFG_CLK_FREQ/CONFIG_H264_FREQ)-2)*2)&0x3F)<<10)\ + |(((((ACFG_CLK_FREQ/CONFIG_SSI1_FREQ)-2)*2)&0x3F)<<16)\ + |(((CONFIG_CLK0_DIV)&0x07)<<22)\ + |(((CONFIG_CLK0_EN)&0x01)<<25)\ + |(((((ACFG_CLK_FREQ/CONFIG_SSI2_FREQ)-2)*2)&0x3F)<<26)) + +/* PERCLKx */ +#define ACFG_PCDR1_VAL\ + (((((ACFG_CLK_FREQ/CONFIG_PERIF1_FREQ)-1)&0x3F)<<0) \ + |((((ACFG_CLK_FREQ/CONFIG_PERIF2_FREQ)-1)&0x3F)<<8) \ + |((((ACFG_CLK_FREQ/CONFIG_PERIF3_FREQ)-1)&0x3F)<<16) \ + |((((ACFG_CLK_FREQ/CONFIG_PERIF4_FREQ)-1)&0x3F)<<24)) + +/* SDRAM controller programming Values */ +#if (((2*ACFG_SDRAM_CLOCK_CYCLE_CL_1) > (3*ACFG_2XHCLK_LGTH)) \ + || (ACFG_SDRAM_CLOCK_CYCLE_CL_1 < 1)) +#define REG_FIELD_SCL_VAL 3 +#define REG_FIELD_SCLIMX_VAL 0 +#else +#define REG_FIELD_SCL_VAL\ + ((2*ACFG_SDRAM_CLOCK_CYCLE_CL_1+ACFG_2XHCLK_LGTH-1)/ \ + ACFG_2XHCLK_LGTH) +#define REG_FIELD_SCLIMX_VAL REG_FIELD_SCL_VAL +#endif + +#if ((2*ACFG_SDRAM_RC_DELAY) > (16*ACFG_2XHCLK_LGTH)) +#define REG_FIELD_SRC_VAL 0 +#else +#define REG_FIELD_SRC_VAL\ + ((2*ACFG_SDRAM_RC_DELAY+ACFG_2XHCLK_LGTH-1)/ \ + ACFG_2XHCLK_LGTH) +#endif + +/* TBD Power down timer ; PRCT Bit Field Encoding; burst length 8 ; FP = 0*/ +#define REG_ESDCTL_BASE_CONFIG (0x80020485\ + | (((ACFG_SDRAM_NUM_ROW-11)&0x7)<<24)\ + | (((ACFG_SDRAM_NUM_COL-8)&0x3)<<20)\ + | (((ACFG_SDRAM_REFRESH)&0x7)<<13)) + +#define ACFG_NORMAL_RW_CMD ((0x0<<28)+REG_ESDCTL_BASE_CONFIG) +#define ACFG_PRECHARGE_CMD ((0x1<<28)+REG_ESDCTL_BASE_CONFIG) +#define ACFG_AUTOREFRESH_CMD ((0x2<<28)+REG_ESDCTL_BASE_CONFIG) +#define ACFG_SET_MODE_REG_CMD ((0x3<<28)+REG_ESDCTL_BASE_CONFIG) + +/* ESDRAMC Configuration Registers : force CL=3 to lpddr */ +#define ACFG_SDRAM_ESDCFG_REGISTER_VAL (0x0\ + | (((((2*ACFG_SDRAM_EXIT_PWD+ACFG_2XHCLK_LGTH-1)/ \ + ACFG_2XHCLK_LGTH)-1)&0x3)<<21)\ + | (((ACFG_SDRAM_W2R_DELAY-1)&0x1)<<20)\ + | (((((2*ACFG_SDRAM_ROW_PRECHARGE_DELAY+ \ + ACFG_2XHCLK_LGTH-1)/ACFG_2XHCLK_LGTH)-1)&0x3)<<18) \ + | (((ACFG_SDRAM_TMRD_DELAY-1)&0x3)<<16)\ + | (((ACFG_SDRAM_TWR_DELAY)&0x1)<<15)\ + | (((((2*ACFG_SDRAM_RAS_DELAY+ACFG_2XHCLK_LGTH-1)/ \ + ACFG_2XHCLK_LGTH)-1)&0x7)<<12) \ + | (((((2*ACFG_SDRAM_RRD_DELAY+ACFG_2XHCLK_LGTH-1)/ \ + ACFG_2XHCLK_LGTH)-1)&0x3)<<10) \ + | (((REG_FIELD_SCLIMX_VAL)&0x3)<<8)\ + | (((((2*ACFG_SDRAM_RCD_DELAY+ACFG_2XHCLK_LGTH-1)/ \ + ACFG_2XHCLK_LGTH)-1)&0x7)<<4) \ + | (((REG_FIELD_SRC_VAL)&0x0F)<<0)) + +/* Issue Mode register Command to SDRAM*/ +#define ACFG_SDRAM_MODE_REGISTER_VAL\ + ((((ACFG_SDRAM_BURST_LENGTH)&0x7)<<(0))\ + | (((REG_FIELD_SCL_VAL)&0x7)<<(4))\ + | ((0)<<(3)) /* sequentiql access */ \ + /*| (((ACFG_SDRAM_SINGLE_ACCESS)&0x1)<<(1))*/) + +/* Issue Extended Mode register Command to SDRAM*/ +#define ACFG_SDRAM_EXT_MODE_REGISTER_VAL\ + ((ACFG_SDRAM_PARTIAL_ARRAY_SR<<0)\ + | (ACFG_SDRAM_DRIVE_STRENGH<<(5))\ + | (1<<(ACFG_SDRAM_NUM_COL+ACFG_SDRAM_NUM_ROW+1+2))) + +/* Issue Precharge all Command to SDRAM*/ +#define ACFG_SDRAM_PRECHARGE_ALL_VAL (1<<10) + +#endif /* __APF27_H */ diff --git a/board/armadeus/apf27/start.S b/board/armadeus/apf27/start.S new file mode 100644 index 0000000..05d5de0 --- /dev/null +++ b/board/armadeus/apf27/start.S @@ -0,0 +1,538 @@ +/* + * IMX27 NAND Flash SPL (Secondary Program Loader) + * + * Copyright (c) 2008 Armadeus Project / eja + * + * Based on Freescale NAND SPL + * + * Copyright (C) 1998, 1999, 2000, 2001, 2002 Red Hat, Inc. + * Copyright (c) 2008-2012 Eric Jarrige eric.jarrige@armadeus.org + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + +#include <config.h> +#include <generated/asm-offsets.h> +#include <version.h> +#include <asm/macro.h> +#include <asm/arch/mxc_nand.h> +#include <asm/arch/imx-regs.h> +#include "apf27.h" + +/* + * Standard NAND flash commands + */ +#define NAND_CMD_READ0 0 +#define NAND_CMD_READ1 1 +#define NAND_CMD_PAGEPROG 0x10 +#define NAND_CMD_READOOB 0x50 +#define NAND_CMD_ERASE1 0x60 +#define NAND_CMD_STATUS 0x70 +#define NAND_CMD_STATUS_MULTI 0x71 +#define NAND_CMD_SEQIN 0x80 +#define NAND_CMD_READID 0x90 +#define NAND_CMD_ERASE2 0xd0 +#define NAND_CMD_RESET 0xff + +/* Extended commands for large page devices */ +#define NAND_CMD_READSTART 0x30 +#define NAND_CMD_CACHEDPROG 0x15 + +/* Status bits */ +#define NAND_STATUS_FAIL 0x01 +#define NAND_STATUS_FAIL_N1 0x02 +#define NAND_STATUS_TRUE_READY 0x20 +#define NAND_STATUS_READY 0x40 +#define NAND_STATUS_WP 0x80 + + .macro nand_boot + +#ifdef CONFIG_BOOT_TRACE_REG +/* + * If CONFIG_BOOT_TRACE_REG is a SDRAM address then be sure to use the following + * 2 command after SDRAM init + */ + +/* Backup state of previous boot to CONFIG_BOOT_TRACE_REG+4*/ +#define BACKUP_TRACE() \ + ldr r4, =CONFIG_BOOT_TRACE_REG; \ + ldr r3, [r4]; \ + str r3, [r4, #0x04]; + +/* Save a state of boot at CONFIG_BOOT_TRACE_REG */ +#define BOOT_TRACE(val) \ + ldr r4, =CONFIG_BOOT_TRACE_REG; \ + ldr r3, =val; \ + str r3, [r4]; +#else +#define BACKUP_TRACE() +#define BOOT_TRACE(val) +#endif + +nand_boot_setup: + + /* Copy SPL image from flash to SDRAM first */ + BOOT_TRACE(1) + ldr r0, =IMX_NFC_MAIN_AREA0 + add r2, r0, #(IMX_NFC_SPARE_AREA0-IMX_NFC_MAIN_AREA0) //2KB NFC Buff + ldr r1, =CONFIG_SYS_NAND_U_BOOT_DST + + BOOT_TRACE(2) +1: ldmia r0!, {r3-r10} + stmia r1!, {r3-r10} + cmp r0, r2 + blo 1b + + + + /* Jump to SDRAM */ + BOOT_TRACE(3) + ldr r1, =0x7FF + and r0, pc, r1 /* offset of pc */ + ldr r1, =CONFIG_SYS_NAND_U_BOOT_DST + add r1, r1, #0x10 + add pc, r0, r1 + nop + nop + nop + nop + +nand_copy_main: + BOOT_TRACE(4) + /* r0: nfc base. Reloaded after each page copying */ + ldr r0, =IMX_NFC_MAIN_AREA0 + + /* r1: starting flash addr to be copied. Updated constantly */ + /* bypass the first preloaded pages */ + ldr r1, =(IMX_NFC_SPARE_AREA0-IMX_NFC_MAIN_AREA0) + + /* r2: end of 1st RAM buf. Doesn't change */ + ldr r2, =IMX_NFC_MAIN_AREA1 + + /* r12: NFC register base. Doesn't change */ + ldr r12, =IMX_NFC_REGS + + ldr r11, =CONFIG_SYS_NAND_U_BOOT_DST + + /* r13: end of SDRAM address for copying. Doesn't change */ + add r13, r11, #CONFIG_SYS_NAND_U_BOOT_SIZE + + /* r11: starting SDRAM address for copying. Updated constantly */ + add r11, r11, r1 + + /* unlock internal buffer */ + ldr r3, =NFC_CONFIG_UNLOCKED + strh r3, [r12, #NFC_OFFSET_CONFIG] + + /* enable ECC and mask interrupts */ + ldr r3, =(NFC_CONFIG1_ECC_EN | NFC_CONFIG1_INT_MSK) + strh r3, [r12, #NFC_OFFSET_CONFIG1] + +nfc_read_page: + BOOT_TRACE(5) + /* send NAND_CMD_READ0 command */ + ldr r3, =NAND_CMD_READ0; + strh r3, [r12, #NFC_OFFSET_FLASH_CMD] + + ldr r3, =NFC_CONFIG2_FCMD + strh r3, [r12, #NFC_OFFSET_CONFIG2] + bl do_wait_op_done + + /* send NAND address to read. TODO small page support */ + BOOT_TRACE(6) + mov r3, r1, lsr #1 + bl do_addr_input /* 1st addr cycle */ + + mov r3, r1, lsr #9 + and r3, r3, #0x03 + bl do_addr_input /* 2nd addr cycle */ + + mov r3, r1, lsr #11 + bl do_addr_input /* 3rd addr cycle */ + + mov r3, r1, lsr #19 + bl do_addr_input /* 4th addr cycle */ + + /* Small NAND flashs (== 1Gb) support 5 addr cycles */ + mov r3, r1, lsr #27 + bl do_addr_input /* 5th addr cycle */ + + /* send NAND_CMD_READSTART command. TODO small page support */ + BOOT_TRACE(7) + mov r3, #NAND_CMD_READSTART; + strh r3, [r12, #NFC_OFFSET_FLASH_CMD] + mov r3, #NFC_CONFIG2_FCMD + strh r3, [r12, #NFC_OFFSET_CONFIG2] + bl do_wait_op_done + + /* read and copy buf 0 */ + BOOT_TRACE(8) + mov r3, #0 + strh r3, [r12, #NFC_OFFSET_BUF_ADDR] + + mov r3, #NFC_CONFIG2_FDO_PAGE + strh r3, [r12, #NFC_OFFSET_CONFIG2] + bl do_wait_op_done + + bl test_and_copy_buffer + + /* read and copy buf 1 */ + mov r3, #1 + strh r3, [r12, #NFC_OFFSET_BUF_ADDR] + + mov r3, #NFC_CONFIG2_FDO_PAGE + strh r3, [r12, #NFC_OFFSET_CONFIG2] + bl do_wait_op_done + + bl test_and_copy_buffer + + /* here we should test if 512B page flash and bypass next buffers */ + /* read and copy buf 2. TODO small page support */ + mov r3, #2 + strh r3, [r12, #NFC_OFFSET_BUF_ADDR] + + mov r3, #NFC_CONFIG2_FDO_PAGE + strh r3, [r12, #NFC_OFFSET_CONFIG2] + bl do_wait_op_done + + bl test_and_copy_buffer + + /* read and copy buf 3 */ + mov r3, #3 + strh r3, [r12, #NFC_OFFSET_BUF_ADDR] + + mov r3, #NFC_CONFIG2_FDO_PAGE + strh r3, [r12, #NFC_OFFSET_CONFIG2] + bl do_wait_op_done + + bl test_and_copy_buffer + + /* is the last page ? */ + BOOT_TRACE(12) + cmp r11, r13 + bge nand_copy_main_done + + /* r0: nfc base. Reloaded after each page copying */ + ldr r0, =IMX_NFC_MAIN_AREA0 + /* r2: end of 1st RAM buf. Doesn't change */ + ldr r2, =IMX_NFC_MAIN_AREA1 + b nfc_read_page + +nand_copy_main_done: + BOOT_TRACE(13) + .endm /* nand_boot */ + + .macro init_aipi + /* + * setup AIPI1 and AIPI2 + */ + write32 AIPI1_PSR0, ACFG_AIPI1_PSR0_VAL + write32 AIPI1_PSR1, ACFG_AIPI1_PSR1_VAL + write32 AIPI2_PSR0, ACFG_AIPI2_PSR0_VAL + write32 AIPI2_PSR1, ACFG_AIPI2_PSR1_VAL + + /* Change SDRAM signal strengh */ + ldr r0, =GPCR + ldr r1, =ACFG_GPCR_VAL + ldr r5, [r0] + orr r5, r5, r1 + str r5, [r0] + + .endm /* init_aipi */ + + .macro init_clock + ldr r0, =CSCR + /* disable MPLL/SPLL first */ + ldr r1, [r0] + bic r1, r1, #(CSCR_MPEN|CSCR_SPEN) + str r1, [r0] + + /* + * pll clock initialization predefined in apf27.h + */ + write32 MPCTL0, ACFG_MPCTL0_VAL + write32 SPCTL0, ACFG_SPCTL0_VAL + + write32 CSCR, ACFG_CSCR_VAL|CSCR_MPLL_RESTART|CSCR_SPLL_RESTART + + /* + * add some delay here + */ + mov r1, #0x1000 + 1: subs r1, r1, #0x1 + bne 1b + + /* peripheral clock divider */ + write32 PCDR0, ACFG_PCDR0_VAL + write32 PCDR1, ACFG_PCDR1_VAL + + /* Configure PCCR0 and PCCR1 */ + write32 PCCR0, ACFG_PCCR0_VAL + write32 PCCR1, ACFG_PCCR1_VAL + + .endm /* init_clock */ + +/* + ************************************************************************* + * + * No jump vector table. Use reset vector as direct entry point. + * Do not support any interrupt event within SPL + * + ************************************************************************* + */ + + +.globl _start +_start: + +/* + ************************************************************************* + * + * Startup Code (reset vector) + * + * do important init only if we don't start from memory! + * setup Memory and board specific bits prior to relocation. + * relocate armboot to ram + * setup stack + * + ************************************************************************* + */ + + +/* + * the actual reset code + */ + +reset: + /* + * set the cpu to SVC32 mode + */ + mrs r0,cpsr + bic r0,r0,#0x1f + orr r0,r0,#0xd3 + msr cpsr,r0 + + /* + * invalidate I/D cache/TLB and drain write buffer + */ + mov r0, #0 + mcr p15, 0, r0, c7, c7, 0 /* invalidate I cache and D cache */ + mcr p15, 0, r0, c8, c7, 0 /* invalidate TLBs */ + mcr p15, 0, r0, c7, c10, 4 /* Drain the write buffer */ + + /* + * disable MMU stuff and caches + */ + mrc p15, 0, r0, c1, c0, 0 + bic r0, r0, #0x00002300 /* clear bits 13, 9:8 (--V- --RS) */ + bic r0, r0, #0x00000087 /* clear bits 7, 2:0 (B--- -CAM) */ + orr r0, r0, #0x00000002 /* set bit 2 (A) Align */ + orr r0, r0, #0x00001000 /* set bit 12 (I) I-Cache */ + mcr p15, 0, r0, c1, c0, 0 + +init_aipi_start: + init_aipi + + /* check if sdram has been setup (running within sdram) */ + cmp pc, #0xa0000000 /* start of first sdram memory space */ + blo init_clock_start + cmp pc, #0xc0000000 /* end of second sdram memory space */ + blo regular_boot + + /* running from sdram with full code present -> regular_boot */ +init_clock_start: + init_clock + +init_sdram_start: + bl setup_sdram_ddr + + /* save state of previous boot (SDRAM is configured)*/ + BACKUP_TRACE() + + /* nand_boot BOOT_TRACE(1..13) */ + + nand_boot + + BOOT_TRACE(14) /* start regular U-Boot */ + +regular_boot: /* jump to start of next 2kiB block (U-Boot) */ + ldr r0, =0xfffff800 + and r0, r0, pc + add pc, r0, #0x800 + +do_wait_op_done: + 1: + ldrh r3, [r12, #NFC_OFFSET_CONFIG2] + ands r3, r3, #NFC_CONFIG2_INT + beq 1b + mov r3, #0x0 + strh r3, [r12, #NFC_OFFSET_CONFIG2] + mov pc, lr + +do_addr_input: + mov r9, lr + and r3, r3, #0xFF + strh r3, [r12, #NFC_OFFSET_FLASH_ADDR] + mov r3, #NFC_CONFIG2_FADD + strh r3, [r12, #NFC_OFFSET_CONFIG2] + bl do_wait_op_done + mov pc, r9 + +test_and_copy_buffer: + /* check for bad block (2 bits error in main or spare are)*/ + BOOT_TRACE(9) + ldrh r4, [r12, #NFC_OFFSET_ECC_STATUS_RESULT] + ands r4, r4, #(NFC_ECC_STAT_ERROR2| \ + (NFC_ECC_STAT_ERROR2<<NFC_ECC_STAT_ERM_SHFT)) + bne skip_bad_buffer + + /* check BI byte of the current spare buffer */ + ldr r4, =IMX_NFC_SPARE_AREA0 + ldrh r3, [r12, #NFC_OFFSET_BUF_ADDR] /* for the current buffer */ + orr r4, r3, lsl #0x04 + + /* at bi word offset 4. */ + /* Fixme position change betwwen 8 and 16 bits bus */ + ldrh r4, [r4, #0x04] + and r4, r4, #0x0FF00 /* has to be 0xFFxx */ + cmp r4, #0x0FF00 + bne skip_bad_buffer + +copy_good_buffer: + /* copying 512 bytes buffer */ + BOOT_TRACE(10) +1: ldmia r0!, {r3-r10} + stmia r11!, {r3-r10} + cmp r0, r2 + blo 1b + b end_of_copy + +skip_bad_buffer: + BOOT_TRACE(11) + /* bad pages do not contain valid data and have to be skip */ + add r0, r0, #0x200 + + /* rewind ram addr to start of buffer */ + ldr r3, =(~0x1FF) + and r11, r11, r3 + +end_of_copy: + add r2, r2, #0x200 + add r1, r1, #0x200 + + mov pc, lr + +setup_sdram_ddr: + + /* wait for SDRAM/LPDDR ready (SDRAMRDY) */ + ldr r0, =IMX_ESD_BASE + ldr r4, =ESDMISC_SDRAM_RDY +2: ldr r1, [r0, #ESDMISC_ROF] + ands r1, r1, r4 + bpl 2b + + /* LPDDR Soft Reset Mobile/Low Power DDR SDRAM. */ + ldr r0, =IMX_ESD_BASE + ldr r4, =ACFG_ESDMISC_VAL + orr r1, r4, #ESDMISC_MDDR_DL_RST + str r1, [r0, #ESDMISC_ROF] + + /* Hold for more than 200ns */ + ldr r1, =0x10000 + 1: subs r1, r1, #0x1 + bne 1b + + str r4, [r0] + + ldr r0, =IMX_ESD_BASE + ldr r1, =ACFG_SDRAM_ESDCFG_REGISTER_VAL + str r1, [r0, #ESDCFG0_ROF] + + ldr r0, =IMX_ESD_BASE + ldr r1, =ACFG_PRECHARGE_CMD + str r1, [r0, #ESDCTL0_ROF] + + /* write8(0xA0001000, any value) */ + ldr r1, =PHYS_SDRAM_1+ACFG_SDRAM_PRECHARGE_ALL_VAL + strb r2, [r1] + + ldr r1, =ACFG_AUTOREFRESH_CMD + str r1, [r0, #ESDCTL0_ROF] + + ldr r4, =PHYS_SDRAM_1 /* CSD0 base address */ + + ldr r6,=0x7 /* load loop counter */ +1: str r5,[r4] /* run auto-refresh cycle to array 0 */ + subs r6,r6,#1 + bne 1b + + ldr r1, =ACFG_SET_MODE_REG_CMD + str r1, [r0, #ESDCTL0_ROF] + + /* set standard mode register */ + ldr r4, = PHYS_SDRAM_1+ACFG_SDRAM_MODE_REGISTER_VAL + strb r2, [r4] + + /* set extended mode register */ + ldr r4, =PHYS_SDRAM_1+ACFG_SDRAM_EXT_MODE_REGISTER_VAL + strb r5, [r4] + + ldr r1, =ACFG_NORMAL_RW_CMD + str r1, [r0, #ESDCTL0_ROF] + + /* 2nd sdram */ + ldr r0, =IMX_ESD_BASE + ldr r1, =ACFG_SDRAM_ESDCFG_REGISTER_VAL + str r1, [r0, #ESDCFG1_ROF] + + ldr r0, =IMX_ESD_BASE + ldr r1, =ACFG_PRECHARGE_CMD + str r1, [r0, #ESDCTL1_ROF] + + /* write8(0xB0001000, any value) */ + ldr r1, =PHYS_SDRAM_2+ACFG_SDRAM_PRECHARGE_ALL_VAL + strb r2, [r1] + + ldr r1, =ACFG_AUTOREFRESH_CMD + str r1, [r0, #ESDCTL1_ROF] + + ldr r4, =PHYS_SDRAM_2 /* CSD1 base address */ + + ldr r6,=0x7 /* load loop counter */ +1: str r5,[r4] /* run auto-refresh cycle to array 0 */ + subs r6,r6,#1 + bne 1b + + ldr r1, =ACFG_SET_MODE_REG_CMD + str r1, [r0, #ESDCTL1_ROF] + + /* set standard mode register */ + ldr r4, =PHYS_SDRAM_2+ACFG_SDRAM_MODE_REGISTER_VAL + strb r2, [r4] + + /* set extended mode register */ + ldr r4, =PHYS_SDRAM_2+ACFG_SDRAM_EXT_MODE_REGISTER_VAL + strb r2, [r4] + + ldr r1, =ACFG_NORMAL_RW_CMD + str r1, [r0, #ESDCTL1_ROF] + + mov pc, lr + diff --git a/board/armadeus/apf27/u-boot-spl.lds b/board/armadeus/apf27/u-boot-spl.lds new file mode 100644 index 0000000..9e82c6f --- /dev/null +++ b/board/armadeus/apf27/u-boot-spl.lds @@ -0,0 +1,86 @@ +/* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * January 2004 - Changed to support H4 device + * Copyright (c) 2004-2008 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0xA0fff800; + + . = ALIGN(4); + .text : { + board/armadeus/apf27/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { + *(.data) + } + + . = ALIGN(4); + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + .bss : { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end__ = .; + } + + _end = .; + + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynsym*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.hash*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +} diff --git a/boards.cfg b/boards.cfg index 6f21af0..fdee7e7 100644 --- a/boards.cfg +++ b/boards.cfg @@ -186,6 +186,7 @@ jadecpu arm arm926ejs jadecpu syteco mx25pdk arm arm926ejs mx25pdk freescale mx25 mx25pdk:IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg tx25 arm arm926ejs tx25 karo mx25 zmx25 arm arm926ejs zmx25 syteco mx25 +apf27 arm arm926ejs apf27 armadeus mx27 imx27lite arm arm926ejs imx27lite logicpd mx27 magnesium arm arm926ejs imx27lite logicpd mx27 apx4devkit arm arm926ejs apx4devkit bluegiga mxs apx4devkit diff --git a/include/configs/apf27.h b/include/configs/apf27.h new file mode 100644 index 0000000..403f081 --- /dev/null +++ b/include/configs/apf27.h @@ -0,0 +1,445 @@ +/* + * + * Configuration settings for the Armadeus Project motherboard APF27 + * + * Copyright (C) 2008-2012 ej / Armadeus Project eric.jarrige@armadeus.org + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_VERSION_VARIABLE +#define CONFIG_ENV_VERSION "3.3" +#define CONFIG_IDENT_STRING " apf27 patch 3.8" +#define CONFIG_BOARD_NAME apf27 + +/* + * SoC configurations + */ +#define CONFIG_ARM926EJS /* this is an ARM926EJS CPU */ +#define CONFIG_MX27 /* in a Freescale i.MX27 Chip */ +#define CONFIG_MACH_TYPE 1698 /* APF27 */ + +/* + * Enable the call to miscellaneous platform dependent initialization. + */ +#define CONFIG_SYS_NO_FLASH /* to be define before <config_cmd_default.h> */ +#define CONFIG_MISC_INIT_R +#define CONFIG_BOARD_EARLY_INIT_F + +/* + * Board display option + */ +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_CPUINFO + +/* + * SPL + */ +/* Copy SPL+U-Boot here */ +#define CONFIG_SYS_NAND_U_BOOT_DST (CONFIG_SYS_TEXT_BASE - 0x800) +/* Size is the partion size */ +#define CONFIG_SYS_NAND_U_BOOT_SIZE CONFIG_SYS_MONITOR_LEN +/* Build image with spl and u-boot */ +#define CONFIG_NAND_U_BOOT +#define CONFIG_SPL_PAD_TO 0xa1000000 + +/* + * SPL + */ +#define CONFIG_SPL +#define CONFIG_SPL_NO_CPU_SUPPORT_CODE +#define CONFIG_SPL_START_S_PATH "board/armadeus/apf27" +#define CONFIG_SPL_LDSCRIPT "board/armadeus/apf27/u-boot-spl.lds" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT + + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 + +#define CONFIG_HOSTNAME CONFIG_BOARD_NAME +#define CONFIG_ROOTPATH "/tftpboot/" __stringify(CONFIG_BOARD_NAME) "-root" + +/* + * U-Boot Commands + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV /* ask for env variable */ +#define CONFIG_CMD_BSP /* Board Specific functions */ +#define CONFIG_CMD_CACHE /* icache, dcache */ +#define CONFIG_CMD_DHCP /* DHCP Support */ +#define CONFIG_CMD_DNS +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_IMX_FUSE /* imx iim fuse */ +#define CONFIG_CMD_MII /* MII support */ +#define CONFIG_CMD_MMC +#define CONFIG_CMD_MTDPARTS /* MTD partition support */ +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_NAND_LOCK_UNLOCK +#define CONFIG_CMD_NAND_TRIMFFS +#define CONFIG_CMD_NFS /* NFS support */ +#define CONFIG_CMD_PING /* ping support */ +#define CONFIG_CMD_SETEXPR /* setexpr support */ +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS + +/* + * Memory configurations + */ +#define CONFIG_NR_DRAM_POPULATED 1 +#define CONFIG_NR_DRAM_BANKS 2 + +#define ACFG_SDRAM_MBYTE_SYZE 64 + +#define PHYS_SDRAM_1 0xA0000000 +#define PHYS_SDRAM_2 0xB0000000 +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (512<<10)) +#define CONFIG_SYS_MEMTEST_START 0xA0000000 /* memtest test area */ +#define CONFIG_SYS_MEMTEST_END 0xA0300000 /* 3 MiB RAM test */ + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE \ + + PHYS_SDRAM_1_SIZE - 0x0100000) + +#define CONFIG_SYS_TEXT_BASE 0xA1000000 + +/* + * FLASH organization + */ +#define ACFG_MONITOR_OFFSET 0x00000000 +#define CONFIG_SYS_MONITOR_LEN 0x00100000 /* 1MiB */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OVERWRITE +#define CONFIG_ENV_OFFSET 0x00100000 /* NAND offset */ +#define CONFIG_ENV_SIZE 0x00020000 /* 128kB */ +#define CONFIG_ENV_RANGE 0X00080000 /* 512kB */ +#define CONFIG_ENV_OFFSET_REDUND \ + (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) /* +512kB */ +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE /* 512kB */ +#define CONFIG_FIRMWARE_OFFSET 0x00200000 +#define CONFIG_KERNEL_OFFSET 0x00300000 +#define CONFIG_ROOTFS_OFFSET 0x00800000 + +#define CONFIG_MTDMAP "mxc_nand.0" +#define MTDIDS_DEFAULT "nand0=" CONFIG_MTDMAP +#define MTDPARTS_DEFAULT "mtdparts=" CONFIG_MTDMAP \ + ":1M(u-boot)ro," \ + "512K(env)," \ + "512K(env2)," \ + "512K(firmware)," \ + "512K(dtb)," \ + "5M(kernel)," \ + "-(rootfs)" + +/* + * U-Boot general configurations + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "BIOS> " /* prompt string */ +#define CONFIG_SYS_CBSIZE 2048 /* console I/O buffer */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) + /* Print buffer size */ +#define CONFIG_SYS_MAXARGS 16 /* max command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + /* Boot argument buffer size */ +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_HUSH_PARSER /* enable the "hush" shell */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " /* secondary prompt string */ + +/* + * Boot Linux + */ +#define CONFIG_CMDLINE_TAG /* send commandline to Kernel */ +#define CONFIG_SETUP_MEMORY_TAGS /* send memory definition to kernel */ +#define CONFIG_INITRD_TAG /* send initrd params */ + +#define CONFIG_OF_LIBFDT + +#define CONFIG_BOOTDELAY 5 +#define CONFIG_ZERO_BOOTDELAY_CHECK +#define CONFIG_BOOTFILE __stringify(CONFIG_BOARD_NAME) "-linux.bin" +#define CONFIG_BOOTARGS "console=" __stringify(ACFG_CONSOLE_DEV) "," \ + __stringify(CONFIG_BAUDRATE) " " MTDPARTS_DEFAULT \ + " ubi.mtd=rootfs root=ubi0:rootfs rootfstype=ubifs " + +#define ACFG_CONSOLE_DEV ttySMX0 +#define CONFIG_BOOTCOMMAND "run ubifsboot" +#define CONFIG_SYS_AUTOLOAD "no" +/* + * Default load address for user programs and kernel + */ +#define CONFIG_LOADADDR 0xA0000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * Extra Environments + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "env_version=" CONFIG_ENV_VERSION "\0" \ + "consoledev=" __stringify(ACFG_CONSOLE_DEV) "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "partition=nand0,6\0" \ + "u-boot_addr=" __stringify(ACFG_MONITOR_OFFSET) "\0" \ + "env_addr=" __stringify(CONFIG_ENV_OFFSET) "\0" \ + "firmware_addr=" __stringify(CONFIG_FIRMWARE_OFFSET) "\0" \ + "kernel_addr=" __stringify(CONFIG_KERNEL_OFFSET) "\0" \ + "rootfs_addr=" __stringify(CONFIG_ROOTFS_OFFSET) "\0" \ + "board_name=" __stringify(CONFIG_BOARD_NAME) "\0" \ + "kernel_addr_r=A0000000\0" \ + "addnfsargs=setenv bootargs ${bootargs} " \ + "root=/dev/nfs rw nfsroot=${serverip}:${rootpath}\0" \ + "addubifsargs=setenv bootargs ${bootargs} " \ + "ubi.mtd=rootfs root=ubi0:rootfs rootfstype=ubifs\0" \ + "addmmcargs=setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk0p1 rootfstype=ext2\0" \ + "addipargs=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:" \ + "${hostname}:eth0:off \0" \ + "nfsboot=setenv bootargs console=${consoledev},${baudrate} " \ + "${mtdparts} ${extrabootargs}; run addnfsargs addipargs;"\ + "nfs ${kernel_addr_r} " \ + "${serverip}:${rootpath}/boot/${board_name}-linux.bin;" \ + "if test -n ${fdt_addr_r} ; then " \ + "nand read ${fdt_addr_r} dtb; fi;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "ubifsboot=setenv bootargs console=${consoledev},${baudrate} " \ + "${mtdparts} ${extrabootargs};run addubifsargs addipargs;"\ + "if test -n ${fdt_addr_r} ; then " \ + "nand read ${fdt_addr_r} dtb; fi;" \ + "nboot ${kernel_addr_r} kernel;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "mmcboot=setenv bootargs console=${consoledev},${baudrate} " \ + "${mtdparts} ${extrabootargs}; run addmmcargs addipargs;"\ + "if test -n ${fdt_addr_r} ; then " \ + "nand read ${fdt_addr_r} dtb; fi;" \ + "mmc dev 0; ext2load mmc 0 ${kernel_addr_r}" \ + " /boot/${board_name}-linux.bin;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "boot_nfs_fallback_flash=if ping ${serverip};" \ + "then echo Boot over NFS; run nfsboot;" \ + "else echo Boot from the board; run ubifsboot;" \ + "fi\0" \ + "firmware_autoload=0\0" \ + "flash_uboot=nand unlock ${u-boot_addr} ;" \ + "nand erase.part u-boot;" \ + "if nand write.trimffs ${fileaddr} ${u-boot_addr} ${filesize};"\ + "then nand lock; nand unlock ${env_addr};" \ + "echo Flashing of uboot succeed;" \ + "else echo Flashing of uboot failed;" \ + "fi; \0" \ + "flash_firmware=nand erase.part firmware;" \ + "if nand write.trimffs ${fileaddr} ${firmware_addr} ${filesize};"\ + "then echo Flashing of Firmware succeed;" \ + "else echo Flashing of Firmware failed;" \ + "fi\0" \ + "flash_kernel=nand erase.part kernel;" \ + "if nand write.trimffs ${fileaddr} ${kernel_addr} ${filesize};"\ + "then echo Flashing of kernel succeed;" \ + "else echo Flashing of kernel failed;" \ + "fi\0" \ + "flash_rootfs=nand erase.part rootfs;" \ + "if nand write.trimffs ${fileaddr} ${rootfs_addr} ${filesize};"\ + "then echo Flashing of rootfs succeed;" \ + "else echo Flashing of rootfs failed;" \ + "fi\0" \ + "flash_dtb=nand erase.part dtb;" \ + "if nand write.trimffs ${fileaddr} dtb ${filesize};" \ + "then echo Flashing of rootfs succeed;" \ + "else echo Flashing of rootfs failed;" \ + "fi\0" \ + "flash_reset_env=env default -f -a; saveenv;" \ + "echo Flash environment variables erased!\0" \ + "download_uboot=tftpboot ${loadaddr} ${board_name}-u-boot-nand.bin\0" \ + "download_kernel=tftpboot ${loadaddr} ${board_name}-linux.bin\0" \ + "download_rootfs=tftpboot ${loadaddr} ${board_name}-rootfs.ubi\0" \ + "download_dtb=tftpboot ${loadaddr} imx27-${board_name}.dtb\0" \ + "update_uboot=run download_uboot flash_uboot\0" \ + "update_kernel=run download_kernel flash_kernel\0" \ + "update_rootfs=run download_rootfs flash_rootfs\0" \ + "update_dtb=run download_dtb flash_dtb\0" \ + "update_all=run download_kernel flash_kernel download_rootfs " \ + "flash_rootfs download_uboot flash_uboot\0" \ + "unlock_regs=mw 10000008 0; mw 10020008 0\0" \ + +/* + * Serial Driver + */ +#define CONFIG_MXC_UART +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_MXC_UART_BASE UART1_BASE + +/* + * GPIO + */ +#define CONFIG_MXC_GPIO + +/* + * NOR + */ + +/* + * NAND + */ +#define CONFIG_NAND_MXC + +#define CONFIG_MXC_NAND_REGS_BASE 0xD8000000 +#define CONFIG_SYS_NAND_BASE CONFIG_MXC_NAND_REGS_BASE +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +#define CONFIG_MXC_NAND_HWECC +#define CONFIG_SYS_NAND_LARGEPAGE +#define IMX27_NAND_16BITS +#define NAND_MAX_CHIPS 1 + + +#define CONFIG_FLASH_SHOW_PROGRESS 45 +#define CONFIG_SYS_NAND_QUIET 1 + +#define CONFIG_BOOT_TRACE_REG 0xAFFFFFF8 /* Addr to store traces of SPL boot*/ + +/* + * Partitions & Filsystems + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_DOS_PARTITION +#define CONFIG_SUPPORT_VFAT + +/* + * UBIFS + */ +#define CONFIG_RBTREE +#define CONFIG_LZO + +/* + * Ethernet (on SOC imx FEC) + */ +#define CONFIG_FEC_MXC + +#define CONFIG_NET_MULTI +#define CONFIG_FEC_MXC_PHYADDR 0x1f +#define CONFIG_MII 1 /* MII PHY management */ + +/* + * FPGA + */ +#define CONFIG_FPGA CONFIG_SYS_SPARTAN3 +#define CONFIG_FPGA_COUNT 1 +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_SYS_FPGA_WAIT 20000 /* 20 ms */ +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_CHECK_CTRLC +#define CONFIG_SYS_FPGA_CHECK_ERROR + +/* + * Fuses - IIM + */ +#ifdef CONFIG_CMD_IMX_FUSE +#define IIM_MAC_BANK 0 +#define IIM_MAC_ROW 5 +#define IIM0_SCC_KEY 11 +#define IIM1_SUID 1 +#endif + +/* + * I2C + */ +#ifdef CONFIG_CMD_I2C +#define CONFIG_HARD_I2C 1 + +#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ +#define CONFIG_SYS_I2C_SLAVE 0x7F + +#define CONFIG_I2C_CMD_TREE +#define CONFIG_I2C_MULTI_BUS 2 +#define CONFIG_SYS_I2C_NOPROBES { } + +#ifdef CONFIG_CMD_EEPROM +# define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM 24LC02 */ +# define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* bytes of address */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* msec */ +#endif /* CONFIG_CMD_EEPROM */ +#endif /* CONFIG_CMD_I2C */ + +/* + * SD/MMC + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MXC_MMC +#define CONFIG_MXC_MCI_REGS_BASE 0x10014000 +#endif + +/* + * RTC + */ +#ifdef CONFIG_CMD_DATE +#define CONFIG_RTC_DS1374 +#define CONFIG_SYS_RTC_BUS_NUM 0 +#endif /* CONFIG_CMD_DATE */ + +/* + * Clocks + */ +#define CONFIG_SYS_HZ 1000 /* Ticks per second */ + +/* + * PLL + * + * 31 | x |x| x x x x |x x x x x x x x x x |x x|x x x x|x x x x x x x x x x| 0 + * |CPLM|X|----PD---|--------MFD---------|XXX|--MFI--|-----MFN-----------| + */ +#define CONFIG_MX27_CLK32 32768 /* 32768 or 32000 Hz crystal */ +#undef CONFIG_MX27_CLK26 /* No external 26MHz external clock */ + +#if (ACFG_SDRAM_MBYTE_SYZE == 64) /* micron MT46H16M32LF -6 */ +/* micron 64MB */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ +#define PHYS_SDRAM_2_SIZE 0x04000000 /* 64 MB */ +#endif + +#if (ACFG_SDRAM_MBYTE_SYZE == 128) +/* micron 128MB */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ +#endif + +#if (ACFG_SDRAM_MBYTE_SYZE == 256) +/* micron 256MB */ +#define PHYS_SDRAM_1_SIZE 0x10000000 /* 256 MB */ +#define PHYS_SDRAM_2_SIZE 0x10000000 /* 256 MB */ +#endif + +#endif /* __CONFIG_H */
Hi Philippe,
I tried your patches, but build fails:
./MAKEALL apf27 Configuring for apf27 board... make: *** [nand_spl] Error 2 arm-linux-gnueabi-size: './u-boot': No such file make: *** nand_spl/board/armadeus/apf27: No such file or directory. Stop. make: *** [nand_spl] Error 2 make: *** Waiting for unfinished jobs....
Using the generic SPL, I am expecting that nand_spl is not used at all. Objects and result should go into the SPL directory.
- Fuse bank 1 row 8 is "reserved for future use" and therefore available for
- customer use. The APF27 board uses this fuse to store the board revision:
- 0: initial board revision
- 1: first revision - Presence of the second RAM chip on the board is blown in
- N: to be defined
- struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE;
- return readl(&iim->bank[1].fuse_regs[8]);
- Fuse bank 1 row 9 is "reserved for future use" and therefore available for
- customer use. The APF27 board revision 1 uses the bit 0 to permanently store
- the presence of the second RAM chip
- 0: AFP27 with 1 RAM of 64 MiB
- 1: AFP27 with 2 RAM chips of 64 MiB each (128MB)
This should be declared static, I think.
- /* dram_init must store complete ramsize in gd->ram_size */
- if (get_num_ram_bank() > 1) {
- } else {
PHYS_SDRAM_1_SIZE);
Doesn't the following code work ?
gd->ram_size = get_ram_size((void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + get_ram_size((void *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE);
- phys_size_t ramsize = gd->ram_size;
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = ramsize;
- gd->ram_size = gd->bd->bi_dram[0].size;
- if (CONFIG_NR_DRAM_BANKS > 1) {
Do you need this ? It seems from your code that you can find at run time how many banks are mounted.
- Miscellaneous initialisation
- char *s;
- u_char * firmware_buffer = (u_char *)(CONFIG_SYS_LOAD_ADDR + \
- size_t size = 0;
- size_t offset = -1;
- char *autoload = getenv("firmware_autoload");
you search for the environment, but autoload is not used in this function, right ?
- u8 pnum;
- struct mtd_device *dev;
- struct part_info *part;
- /* detect compatibility issue of environment version */
- s = getenv("env_version");
- if ((NULL == s) || (0 != strcmp(s, CONFIG_ENV_VERSION))) {
Not clear at all. You add a version to the environment, ok, but you check it with a version number known at compile time. Do you use it really
- /* Unlock whole flash but U-Boot */
- s = getenv("env_offset");
- offset = CONFIG_ENV_OFFSET;
This seems dangerous. You can set a variable, but the offset for the environment is defined at compile time. This does not make a lot of sense for me.
- /* Enable D-cache. I-cache is already enabled in start.S */
- dcache_enable();
I suggest you move this function in a separate patch to arch/arm/cpu/arm926ejs/mx27/generic.c. This code can be used by other boards, too.
Style, wrong multiline comment.
Is it old code ? CONFIG_MX27_CLK26 is not used at all in u-boot, and you do not define it. If we can get rid of it, please then clean up also the other parts using #ifndef CONFIG_MX27_CLK26
- SDRAM
row address bits */
down delay */
cycle delay > 0 */
cycle delay 1..4 */
delay */
delay */
estimated fo CL=1
0 = Burst mode */
row address bits */
down delay */
cycle delay > 0 */
cycle delay 1..4 */
delay */
delay */
estimated fo CL=1
0 = Burst mode */
row address bits */
down delay */
delay > 0 */
cycle delay 1..4 */
delay */
delay */
estimated fo CL=1
1=half
2=quater
3=Eighth */
0 = Burst mode */
I understand why, but maybe it is more readable if you define a table in apf27.c and you access to it on depend of the selected RAM. Something like: struct ram_timing { ..... }
struct ram_timing apf27_ram[] = { {... }, /* 64 MB */ {...}, /* 128 MB */ {...} /* 256 MB */ }
What do you think about ?
- Default configuration for GPIOs and peripherals
I am unsure if I have understood. This seems the setup of the GPIOs controller, and for that we have gpio_ function. Why do we need all this stuff ?
..but ACFG_APF27_CUSTOM is not set at all - also old code and can we clean up ?
- IMX27 NAND Flash SPL (Secondary Program Loader)
- Copyright (c) 2008 Armadeus Project / eja
- Based on Freescale NAND SPL
- Copyright (C) 1998, 1999, 2000, 2001, 2002 Red Hat, Inc.
- Copyright (c) 2008-2012 Eric Jarrige eric.jarrige@armadeus.org
- project.
- MA 02111-1307 USA
- Standard NAND flash commands
- .macro nand_boot
- If CONFIG_BOOT_TRACE_REG is a SDRAM address then be sure to use the following
- 2 command after SDRAM init
- ldr r4, =CONFIG_BOOT_TRACE_REG; \
- ldr r3, [r4]; \
- str r3, [r4, #0x04];
- ldr r3, =val; \
- str r3, [r4];
+nand_boot_setup:
- /* Copy SPL image from flash to SDRAM first */
- BOOT_TRACE(1)
- ldr r0, =IMX_NFC_MAIN_AREA0
- add r2, r0, #(IMX_NFC_SPARE_AREA0-IMX_NFC_MAIN_AREA0) //2KB NFC Buff
- ldr r1, =CONFIG_SYS_NAND_U_BOOT_DST
- BOOT_TRACE(2)
- stmia r1!, {r3-r10}
- cmp r0, r2
- blo 1b
If SPL can link mxc_nand.c, you have all functions if you link also nand_spl_simple.o and nand_spl_load.o. Why do we need to redefine them in assembly ?
- /* Jump to SDRAM */
- BOOT_TRACE(3)
- ldr r1, =0x7FF
- and r0, pc, r1 /* offset of pc */
- add r1, r1, #0x10
- add pc, r0, r1
This is also done by generic SPL code.
- Startup Code (reset vector)
- do important init only if we don't start from memory!
- setup Memory and board specific bits prior to relocation.
- relocate armboot to ram
- setup stack
- the actual reset code
+reset:
- mrs r0,cpsr
- bic r0,r0,#0x1f
- orr r0,r0,#0xd3
- msr cpsr,r0
- mov r0, #0
- mcr p15, 0, r0, c7, c7, 0 /* invalidate I cache and D cache */
- mcr p15, 0, r0, c8, c7, 0 /* invalidate TLBs */
- mcr p15, 0, r0, c7, c10, 4 /* Drain the write buffer */
- mrc p15, 0, r0, c1, c0, 0
- bic r0, r0, #0x00002300 /* clear bits 13, 9:8 (--V- --RS) */
- bic r0, r0, #0x00000087 /* clear bits 7, 2:0 (B--- -CAM) */
- orr r0, r0, #0x00000002 /* set bit 2 (A) Align */
- orr r0, r0, #0x00001000 /* set bit 12 (I) I-Cache */
- mcr p15, 0, r0, c1, c0, 0
You also duplicate stuff that is in the generic arch/arm/cpu/arm926ejs/start.S. Better, you substitute the generic one with yours. But the generic has support to call SPL function, so why to replace it ?
- SPL
- SPL
I have not understood why using CONFIG_SPL_FRAMEWORK does not work for you. You should have availbale a lot of function that you redefine in your patches.
Best regards, Stefano Babic
Signed-off-by: Philippe Reynes tremyfr@yahoo.fr Signed-off-by: Eric Jarrige eric.jarrige@armadeus.org --- board/armadeus/apf27/Makefile | 3 + board/armadeus/apf27/apf27.c | 16 +++ board/armadeus/apf27/fpga.c | 262 +++++++++++++++++++++++++++++++++++++++++ board/armadeus/apf27/fpga.h | 39 ++++++ 4 files changed, 320 insertions(+), 0 deletions(-) create mode 100644 board/armadeus/apf27/fpga.c create mode 100644 board/armadeus/apf27/fpga.h
diff --git a/board/armadeus/apf27/Makefile b/board/armadeus/apf27/Makefile index f57f405..9d356a3 100644 --- a/board/armadeus/apf27/Makefile +++ b/board/armadeus/apf27/Makefile @@ -29,6 +29,9 @@ LIB = $(obj)lib$(BOARD).o
ifndef CONFIG_SPL_BUILD COBJS := apf27.o +ifdef CONFIG_FPGA +COBJS += fpga.o +endif endif
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/board/armadeus/apf27/apf27.c b/board/armadeus/apf27/apf27.c index cbd09a7..e375a76 100644 --- a/board/armadeus/apf27/apf27.c +++ b/board/armadeus/apf27/apf27.c @@ -30,6 +30,7 @@ #include <asm/errno.h> #include "apf27.h" #include "crc.h" +#include "fpga.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -310,6 +311,21 @@ misc_init_r(void) struct mtd_device *dev; struct part_info *part;
+#if defined(CONFIG_FPGA) + /* init and download fpga */ + if ((autoload) && (0 == strcmp(autoload, "1"))) { + if (mtdparts_init() == 0) + if (find_dev_and_part("firmware", + &dev, &pnum, &part) == 0) { + size = part->size; + if (nand_read_skip_bad(&nand_info[0], + part->offset, &size, firmware_buffer)) + size = 0; + } + } + APF27_init_fpga(firmware_buffer, size); +#endif + /* detect compatibility issue of environment version */ s = getenv("env_version"); if ((NULL == s) || (0 != strcmp(s, CONFIG_ENV_VERSION))) { diff --git a/board/armadeus/apf27/fpga.c b/board/armadeus/apf27/fpga.c new file mode 100644 index 0000000..d5c27a7 --- /dev/null +++ b/board/armadeus/apf27/fpga.c @@ -0,0 +1,262 @@ +/* + * (C) Copyright 2002-2012 + * Eric Jarrige eric.jarrige@armadeus.org + * Rich Ireland, Enterasys Networks, rireland@enterasys.com. + * Keith Outwater, keith_outwater@mvis.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> + +#include <asm/arch/imx-regs.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <command.h> +#include <config.h> +#include "fpga.h" +#include <spartan3.h> +#include "apf27.h" + +/* + * Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * Spartan2 code is used to download our Spartan 3 :) code is compatible. + * Just take care about the file size + */ +Xilinx_Spartan3_Slave_Parallel_fns fpga_fns = { + fpga_pre_fn, + fpga_pgm_fn, + fpga_init_fn, + NULL, + fpga_done_fn, + fpga_clk_fn, + fpga_cs_fn, + fpga_wr_fn, + fpga_rdata_fn, + fpga_wdata_fn, + fpga_busy_fn, + fpga_abort_fn, + fpga_post_fn, +}; + +Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { + {Xilinx_Spartan3, + slave_parallel, + 1196128l/8, + (void *) &fpga_fns, + 0} +}; + +/* + * Initialize GPIO port B before download + */ +int +fpga_pre_fn(int cookie) +{ + /* Initialize GPIO pins */ + gpio_set_value(ACFG_FPGA_PWR, 1); + imx_gpio_mode(ACFG_FPGA_INIT | GPIO_IN | GPIO_PUEN | GPIO_GPIO); + imx_gpio_mode(ACFG_FPGA_DONE | GPIO_IN | GPIO_PUEN | GPIO_GPIO); + imx_gpio_mode(ACFG_FPGA_PRG | GPIO_OUT | GPIO_PUEN | GPIO_GPIO); + imx_gpio_mode(ACFG_FPGA_CLK | GPIO_OUT | GPIO_PUEN | GPIO_GPIO); + imx_gpio_mode(ACFG_FPGA_RW | GPIO_OUT | GPIO_PUEN | GPIO_GPIO); + imx_gpio_mode(ACFG_FPGA_CS | GPIO_OUT | GPIO_PUEN | GPIO_GPIO); + imx_gpio_mode(ACFG_FPGA_SUSPEND|GPIO_OUT|GPIO_PUEN|GPIO_GPIO); + gpio_set_value(ACFG_FPGA_RESET, 1); + imx_gpio_mode(ACFG_FPGA_RESET | GPIO_OUT | GPIO_PUEN | GPIO_GPIO); + imx_gpio_mode(ACFG_FPGA_PWR | GPIO_OUT | GPIO_PUEN | GPIO_GPIO); + gpio_set_value(ACFG_FPGA_PRG, 1); + gpio_set_value(ACFG_FPGA_CLK, 1); + gpio_set_value(ACFG_FPGA_RW, 1); + gpio_set_value(ACFG_FPGA_CS, 1); + gpio_set_value(ACFG_FPGA_SUSPEND, 0); + gpio_set_value(ACFG_FPGA_PWR, 0); + + return cookie; +} + +/* + * Set the FPGA's active-low program line to the specified level + */ +int +fpga_pgm_fn(int assert, int flush, int cookie) +{ + debug("%s:%d: FPGA PROGRAM %s", __func__, __LINE__, + assert ? "high" : "low"); + gpio_set_value(ACFG_FPGA_PRG, !assert); + return assert; +} + +/* + * Set the FPGA's active-high clock line to the specified level + */ +int +fpga_clk_fn(int assert_clk, int flush, int cookie) +{ + debug("%s:%d: FPGA CLOCK %s", __func__, __LINE__, + assert_clk ? "high" : "low"); + gpio_set_value(ACFG_FPGA_CLK, !assert_clk); + return assert_clk; +} + +/* + * Test the state of the active-low FPGA INIT line. Return 1 on INIT + * asserted (low). + */ +int +fpga_init_fn(int cookie) +{ + int value; + debug("%s:%d: INIT check... ", __func__, __LINE__); + value = gpio_get_value(ACFG_FPGA_INIT); + /* printf("init value read %x",value); */ +#ifdef CONFIG_SYS_FPGA_IS_PROTO + return value; +#else + return !value; +#endif +} + +/* + * Test the state of the active-high FPGA DONE pin + */ +int +fpga_done_fn(int cookie) +{ + debug("%s:%d: DONE check... %s", __func__, __LINE__, + gpio_get_value(ACFG_FPGA_DONE) ? "high" : "low"); + return gpio_get_value(ACFG_FPGA_DONE) ? FPGA_SUCCESS : FPGA_FAIL; +} + +/* + * Set the FPGA's wr line to the specified level + */ +int +fpga_wr_fn(int assert_write, int flush, int cookie) +{ + debug("%s:%d: FPGA RW... %s ", __func__, __LINE__, + assert_write ? "high" : "low"); + gpio_set_value(ACFG_FPGA_RW, !assert_write); + return assert_write; +} + +int +fpga_cs_fn(int assert_cs, int flush, int cookie) +{ + debug("%s:%d: FPGA CS %s ", __func__, __LINE__, + assert_cs ? "high" : "low"); + gpio_set_value(ACFG_FPGA_CS, !assert_cs); + return assert_cs; +} + +int +fpga_rdata_fn(unsigned char *data, int cookie) +{ + debug("%s:%d: FPGA READ DATA %02X ", __func__, __LINE__, + *((char *)ACFG_FPGA_RDATA)); + *data = (unsigned char) \ + ((*((unsigned short *)ACFG_FPGA_RDATA))&0x00FF); + return *data; +} + +int +fpga_wdata_fn(unsigned char data, int cookie) +{ + debug("%s:%d: FPGA WRITE DATA %02X ", __func__, __LINE__, + data); + *((unsigned short *)ACFG_FPGA_WDATA) = data; + return data; +} + +int +fpga_abort_fn(int cookie) +{ + return cookie; +} + + +int +fpga_busy_fn(int cookie) +{ + return 1; +} + +int +fpga_post_fn(int cookie) +{ + debug("%s:%d: FPGA POST ", __func__, __LINE__); + + imx_gpio_mode(ACFG_FPGA_RW | GPIO_PF | GPIO_PUEN); + imx_gpio_mode(ACFG_FPGA_CS | GPIO_PF | GPIO_PUEN); + imx_gpio_mode(ACFG_FPGA_CLK | GPIO_PF | GPIO_PUEN); + gpio_set_value(ACFG_FPGA_PRG, 1); + gpio_set_value(ACFG_FPGA_RESET, 0); + imx_gpio_mode(ACFG_FPGA_RESET | GPIO_OUT | GPIO_PUEN | GPIO_GPIO); + return cookie; +} + +void apf27_fpga_setup(void) +{ + struct pll_regs *pll = (struct pll_regs *)IMX_PLL_BASE; + struct system_control_regs *system = \ + (struct system_control_regs *)IMX_SYSTEM_CTL_BASE; + + /* Configure FPGA CLKO */ + writel(ACFG_CCSR_VAL, &pll->ccsr); + + /* Configure strentgh for FPGA */ + writel(ACFG_DSCR10_VAL, &system->dscr10); + writel(ACFG_DSCR3_VAL, &system->dscr3); + writel(ACFG_DSCR7_VAL, &system->dscr7); + writel(ACFG_DSCR2_VAL, &system->dscr2); +} + +/* + * Initialize the fpga. Return 1 on success, 0 on failure. + */ +int +APF27_init_fpga(u_char *buffer, size_t size) +{ + char *autoload = getenv("firmware_autoload"); + + int i, lout = 0; + + apf27_fpga_setup(); + + fpga_init(); + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { + debug("%s:%d: Adding fpga %d\n", __func__, __LINE__, i); + fpga_add(fpga_xilinx, &fpga[i]); + } + + if ((size >= fpga[0].size) && (autoload) && + (0 == strcmp(autoload, "1"))) { + if (ctrlc()) { + printf("Firmware download stopped!\n"); + } else if (FPGA_SUCCESS != fpga_load(0, (void *)buffer, size)) { + printf("Firmware download failed!\n"); + } else { + printf("Firmware successfully programmed\n"); + lout = 1; + } + } + return lout; +} diff --git a/board/armadeus/apf27/fpga.h b/board/armadeus/apf27/fpga.h new file mode 100644 index 0000000..b11b24c --- /dev/null +++ b/board/armadeus/apf27/fpga.h @@ -0,0 +1,39 @@ +/* + * (C) Copyright 2002-2012 + * Eric Jarrige eric.jarrige@armadeus.org + * Rich Ireland, Enterasys Networks, rireland@enterasys.com. + * Keith Outwater, keith_outwater@mvis.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +extern int APF27_init_fpga(u_char *buffer, size_t size); + +extern int fpga_pre_fn(int cookie); +extern int fpga_pgm_fn(int assert_pgm, int flush, int cookie); +extern int fpga_cs_fn(int assert_cs, int flush, int cookie); +extern int fpga_init_fn(int cookie); +extern int fpga_done_fn(int cookie); +extern int fpga_clk_fn(int assert_clk, int flush, int cookie); +extern int fpga_wr_fn(int assert_write, int flush, int cookie); +extern int fpga_rdata_fn(unsigned char *data, int cookie); +extern int fpga_wdata_fn(unsigned char data, int cookie); +extern int fpga_abort_fn(int cookie); +extern int fpga_post_fn(int cookie); +extern int fpga_busy_fn(int cookie);
Philippe Reynes
Stefano Babic
