[U-Boot-Users] [PATCH] allow ports to override bootelf behavior
Change the bootelf setup function into a dedicated weak function called do_bootelf_exec. This way ports can control the behavior however they like before/after calling the ELF entry point. --- common/cmd_elf.c | 33 +++++++++++++++++++++------------ 1 files changed, 21 insertions(+), 12 deletions(-)
diff --git a/common/cmd_elf.c b/common/cmd_elf.c index 4683554..62e5e76 100644 --- a/common/cmd_elf.c +++ b/common/cmd_elf.c @@ -27,23 +27,34 @@ DECLARE_GLOBAL_DATA_PTR; #define MAX(a,b) ((a) > (b) ? (a) : (b)) #endif
-static inline void bootelf_setup(int argc, char *argv[]) +int valid_elf_image (unsigned long addr); +unsigned long load_elf_image (unsigned long addr); + +/* Allow ports to override the default behavior */ +__attribute__((weak)) +unsigned long do_bootelf_exec (ulong (*entry)(int, char *[]), int argc, char *argv[]) { + unsigned long ret; + /* * QNX images require the data cache is disabled. * Data cache is already flushed, so just turn it off. */ - if (dcache_status ()) + int dcache = dcache_status (); + if (dcache) dcache_disable ();
-#ifdef CONFIG_BLACKFIN - if (icache_status ()) - icache_disable (); -#endif -} + /* + * pass address parameter as argv[0] (aka command name), + * and all remaining args + */ + ret = entry (argc, argv);
-int valid_elf_image (unsigned long addr); -unsigned long load_elf_image (unsigned long addr); + if (dcache) + dcache_enable (); + + return ret; +}
/* ====================================================================== * Interpreter command to boot an arbitrary ELF image from memory. @@ -68,13 +79,11 @@ int do_bootelf (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
printf ("## Starting application at 0x%08lx ...\n", addr);
- bootelf_setup(argc, argv); - /* * pass address parameter as argv[0] (aka command name), * and all remaining args */ - rc = ((ulong (*)(int, char *[])) addr) (--argc, &argv[1]); + rc = do_bootelf_exec ((void *)addr, argc - 1, argv + 1); if (rc != 0) rcode = 1;
Split the arch-specific logic out of the common go code and into a dedicated weak function called do_go_exec() that lives in cpu directories. This will need review from i386/nios people to make sure I didn't break them. --- common/cmd_boot.c | 33 +++++---------------------------- lib_i386/board.c | 8 ++++++++ lib_nios/board.c | 10 ++++++++++ 3 files changed, 23 insertions(+), 28 deletions(-)
diff --git a/common/cmd_boot.c b/common/cmd_boot.c index 9d4f026..d83f5af 100644 --- a/common/cmd_boot.c +++ b/common/cmd_boot.c @@ -28,25 +28,11 @@ #include <command.h> #include <net.h>
-#if defined(CONFIG_I386) -DECLARE_GLOBAL_DATA_PTR; -#endif - -static inline void go_setup(int argc, char *argv[]) +/* Allow ports to override the default behavior */ +__attribute__((weak)) +unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[]) { -#if defined(CONFIG_I386) - /* - * x86 does not use a dedicated register to pass the pointer - * to the global_data - */ - argv[0] = (char *)gd; - -#elif defined(CONFIG_BLACKFIN) - if (dcache_status ()) - dcache_disable (); - if (icache_status ()) - icache_disable (); -#endif + return entry (argc, argv); }
int do_go (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -63,20 +49,11 @@ int do_go (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
printf ("## Starting application at 0x%08lX ...\n", addr);
- go_setup(argc, argv); - -#if defined(CONFIG_NIOS) - /* - * Nios function pointers are address >> 1 - */ - addr >>= 1; -#endif - /* * pass address parameter as argv[0] (aka command name), * and all remaining args */ - rc = ((ulong (*)(int, char *[]))addr) (--argc, &argv[1]); + rc = do_go_exec ((void *)addr, argc - 1, argv + 1); if (rc != 0) rcode = 1;
printf ("## Application terminated, rc = 0x%lX\n", rc); diff --git a/lib_i386/board.c b/lib_i386/board.c index 47fbab4..22191e6 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -421,3 +421,11 @@ void hang (void) puts ("### ERROR ### Please RESET the board ###\n"); for (;;); } + +unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[]) +{ + /* + * Nios function pointers are address >> 1 + */ + return (entry >> 1) (argc, argv); +} diff --git a/lib_nios/board.c b/lib_nios/board.c index 0a0d2e3..cdaf753 100644 --- a/lib_nios/board.c +++ b/lib_nios/board.c @@ -190,3 +190,13 @@ void hang (void) puts("### ERROR ### Please reset board ###\n"); for (;;); } + +unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[]) +{ + /* + * x86 does not use a dedicated register to pass the pointer + * to the global_data + */ + argv[-1] = (char *)gd; + return entry (argc, argv); +}
Applied, thanks.
Applied, thanks.
Applied, thanks.
Unfortunately this breaks all 440 ports using elf:
Configuring for sequoia board... common/libcommon.a(cmd_elf.o): In function `do_bootelf_exec': /home/stefan/git/u-boot/u-boot/common/cmd_elf.c:54: undefined reference to `dcache_enable' make: *** [u-boot] Error 1 ppc_4xx-size: './u-boot': No such file
No dcache_enble() here currently. I'll send a patch to add dcache_enable() to 440 in a short while. But this could affect other platforms as well.
Best regards, Stefan
Mike Frysinger
Stefan Roese
