[U-Boot] [PATCH 3/8 v4] integratorap: support relocation
The integrator board was apparently never converted over to support relocation until now. After this the integrator u-boot both compiles and boots on the Integrator AP.
This also fixes the SDRAM memory size detection.
Signed-off-by: Linus Walleij linus.walleij@linaro.org --- board/armltd/integrator/integrator.c | 15 +++++++-------- include/configs/integratorap.h | 2 +- 2 files changed, 8 insertions(+), 9 deletions(-)
diff --git a/board/armltd/integrator/integrator.c b/board/armltd/integrator/integrator.c index 9bb56b5..c8d2bc7 100644 --- a/board/armltd/integrator/integrator.c +++ b/board/armltd/integrator/integrator.c @@ -86,15 +86,9 @@ int misc_init_r (void) return (0); }
-/****************************** - Routine: - Description: -******************************/ int dram_init (void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; #ifdef CONFIG_CM_SPD_DETECT { extern void dram_query(void); @@ -118,8 +112,13 @@ extern void dram_query(void); */ sdram_shift = ((cm_reg_sdram & 0x0000001C)/4)%4; gd->bd->bi_dram[0].size = 0x01000000 << sdram_shift; - + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + 0x01000000 << sdram_shift); } +#else + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + PHYS_SDRAM_1_SIZE); #endif /* CM_SPD_DETECT */
return 0; diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index 8b41885..1650c03 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -47,7 +47,7 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_CM_INIT 1 #define CONFIG_CM_REMAP 1 -#undef CONFIG_CM_SPD_DETECT +#define CONFIG_CM_SPD_DETECT
/* * Size of malloc() pool
Linus Walleij
