[U-Boot-Users] support usb storage in u-boot for at91rm9200
---------- Forwarded message ---------- From: kiennd kiennd@gmail.com Date: Sep 18, 2006 3:05 PM Subject: support usb storage in u-boot for at91rm9200 To: u-boot-users@lists.sourceforge.net
Hi everybody!
I'm building u-boot bin file to load into ARM9 single board ( Atmel AT91RM9200 ).
With default functions ( command ) of u-boot version 1.1.4, u-boot is loaded into my board and run correctly.
Note: I use u-boot-1.1.4-g7213859d.tar.bz2ftp://ftp.denx.de/pub/u-boot/u-boot-1.1.4-g7213859d.tar.bz2downloaded from ftp://ftp.denx.de/pub/u-boot/, I also try u-boot source from git repository http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git
But when i add some functions for usb storage ( i want to boot my debian os in compact flash ), u-boot can't start.
some lines added in include/configs/at91rm9200dk.h
#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_COMMANDS \ ((CONFIG_CMD_DFL | CFG_CMD_MII | CFG_CMD_PING | CFG_CMD_USB ) & \ ~(CFG_CMD_BDI | \ CFG_CMD_IMI | \ CFG_CMD_AUTOSCRIPT | \ CFG_CMD_FPGA | \ CFG_CMD_MISC | \ CFG_CMD_LOADS ))
/* For USB support */ #if (CONFIG_COMMANDS & CFG_CMD_USB) #define CONFIG_USB_STORAGE #define CONFIG_USB_OHCI #define CONFIG_DOS_PARTITION /*#define CONFIG_USB_KEYBOARD */ /*#define CFG_DEVICE_DEREGISTER */ /*#define CONFIG_SUPPORT_VFAT*/ #define LITTLEENDIAN #endif /* CONFIG_COMMANDS & CFG_CMD_USB*/
Then build u-boot.bin and load into. The terminal display :
###################################### 1: Upload loader to Dataflash with vector 6 modification. 2: Upload u-boot to Dataflash. 3: Upload linux to Dataflash 4: Start U-boot 5: [nm] Identify Dataflash
[nm] dataflash_print_info :.id = DataFlash:AT45DB321 Dataflash read successful: Starting U-boot ###################################### and stop here.... and I can't use u-boot.
Can you give me some suggestion. If possible, can you share me your u-boot.bin .
PS: I send you some attack files: one for my u-boot.bin ( can't start ), one for at91rm9200dk.h, one for my board picture. You check and give me some suggestion.
Thank you!
Note: I use u-boot-1.1.4-g7213859d.tar.bz2 ftp://ftp.denx.de/pub/u-boot/u-boot-1.1.4-g7213859d.tar.bz2 downloaded from ftp://ftp.denx.de/pub/u-boot/, I also try u-boot source from git repository http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git
Your problem is that U-boot is linked to the wrong address (0). Instead it should be linked to the position, where you intend to run u-boot (in SDRAM) I know Wolfgang Denx diesnt like the idea of running U.boot from RAM, but you cannot run from an SPI flash, have to copy to RAM first, and the SDRAM on AT91RM9200 is located at 0x20000000 and above.
The prinout you see, is not from U.boot. It looks like a customized version of "dataflashboot.bin" It "bombs" after dataflashboot.bin has loaded u-boot into SDRAM and jumped to it starting point.
Since it is in the wrong locatgion, all the constant string pointers are off, and really only points at '\0' characters, so any attempt to printout data will fail.
You can get my u-boot at ftp://at91dist:distib@ftp.atmel.fr/ in the "third Party" directory.
do:
make at91rm9200df_config
to get dataflash support.
This u-boot is based on the same source package, but with a number of modifications, all not acceptable to Wolfgang...
Thank you!
Using Tomcat but need to do more? Need to support web services, security? Get stuff done quickly with pre-integrated technology to make your job easier Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&da...
U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
If you are using Dataflash to store u-boot, you can read this as well. http://www.koansoftware.com/it/art.php?art=90 HTH
----- Original Message ----- From: "Marco Cavallini" arm.linux@koansoftware.com To: "kiennd" kiennd@gmail.com Cc: u-boot-users@lists.sourceforge.net Sent: Tuesday, September 19, 2006 7:59 AM Subject: Re: [U-Boot-Users] support usb storage in u-boot for at91rm9200
The Atmel web site is unfortunately a little dated. The ftp://at91dist:distrib@ftp.atmel.fr/ has more updated dataflashboot in the Third Party Section
Best Regards Ulf Samuelsson ulf@atmel.com Atmel Nordic AB Mail: Box 2033, 174 02 Sundbyberg, Sweden Visit: Kavallerivägen 24, 174 58 Sundbyberg, Sweden Phone +46 (8) 441 54 22 Fax +46 (8) 441 54 29 GSM +46 (706) 22 44 57
Technical support when I am not available: AT89 C51 Applications Group: mailto:micro.hotline@nto.atmel.com AT90 AVR Applications Group: mailto:avr@atmel.com AT91 ARM Applications Group: mailto:at91support@atmel.com FPSLIC Application Group: mailto:fpslic@atmel.com Best AVR link: www.avrfreaks.net
kiennd
Marco Cavallini
Ulf Samuelsson
