[U-Boot-Users] [PATCH] mpc86xx: Rearrange start.S to allow use of new law code
Rearrange start.S as follows:
* split the BAT initialization so that only 2 BATs (for the boot page and stack) are programmed very early on. The rest are initialized later. * Move other BAT setup, ccsrbar setup, and law setup later in the code after translation has been enabled.
These changes will facilitate the moving of law and BAT initialization to C code, and will aid with 36-bit physical addressing support.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- cpu/mpc86xx/start.S | 122 +++++++++++++++++++++++++++++---------------------- 1 files changed, 69 insertions(+), 53 deletions(-)
diff --git a/cpu/mpc86xx/start.S b/cpu/mpc86xx/start.S index c83310a..6cf145f 100644 --- a/cpu/mpc86xx/start.S +++ b/cpu/mpc86xx/start.S @@ -235,17 +235,8 @@ in_flash: bl enable_ext_addr
/* setup the bats */ - bl setup_bats - sync - -#if (CFG_CCSRBAR_DEFAULT != CFG_CCSRBAR) - /* setup ccsrbar */ - bl setup_ccsrbar -#endif + bl early_bats
- /* setup the law entries */ - bl law_entry - sync /* * Cache must be enabled here for stack-in-cache trick. * This means we need to enable the BATS. @@ -281,6 +272,19 @@ in_flash: stwu r0, -4(r1) /* stack backtraces terminate cleanly */
GET_GOT /* initialize GOT access */ + + /* setup the rest of the bats */ + bl setup_bats + bl clear_tlbs + sync + +#if (CFG_CCSRBAR_DEFAULT != CFG_CCSRBAR) + /* setup ccsrbar */ + bl setup_ccsrbar +#endif + + bl law_entry + sync
/* run low-level CPU init code (from Flash) */ bl cpu_init_f @@ -359,6 +363,7 @@ invalidate_bats:
/* setup_bats - set them up to some initial state */ + /* Skip any BATS setup in early_bats */ .globl setup_bats setup_bats:
@@ -454,42 +459,6 @@ setup_bats: mtspr DBAT4U, r3 isync
- /* IBAT 5 */ - addis r4, r0, CFG_IBAT5L@h - ori r4, r4, CFG_IBAT5L@l - addis r3, r0, CFG_IBAT5U@h - ori r3, r3, CFG_IBAT5U@l - mtspr IBAT5L, r4 - mtspr IBAT5U, r3 - isync - - /* DBAT 5 */ - addis r4, r0, CFG_DBAT5L@h - ori r4, r4, CFG_DBAT5L@l - addis r3, r0, CFG_DBAT5U@h - ori r3, r3, CFG_DBAT5U@l - mtspr DBAT5L, r4 - mtspr DBAT5U, r3 - isync - - /* IBAT 6 */ - addis r4, r0, CFG_IBAT6L@h - ori r4, r4, CFG_IBAT6L@l - addis r3, r0, CFG_IBAT6U@h - ori r3, r3, CFG_IBAT6U@l - mtspr IBAT6L, r4 - mtspr IBAT6U, r3 - isync - - /* DBAT 6 */ - addis r4, r0, CFG_DBAT6L@h - ori r4, r4, CFG_DBAT6L@l - addis r3, r0, CFG_DBAT6U@h - ori r3, r3, CFG_DBAT6U@l - mtspr DBAT6L, r4 - mtspr DBAT6U, r3 - isync - /* IBAT 7 */ addis r4, r0, CFG_IBAT7L@h ori r4, r4, CFG_IBAT7L@l @@ -508,18 +477,65 @@ setup_bats: mtspr DBAT7U, r3 isync
-1: - addis r3, 0, 0x0000 - addis r5, 0, 0x4 /* upper bound of 0x00040000 for 7400/750 */ + sync + blr + +/* + * early_bats: + * + * Set up bats needed early on - this is usually the BAT for the + * stack-in-cache and the Flash + */ + .globl early_bats +early_bats: + /* IBAT 5 */ + lis r4, CFG_IBAT5L@h + ori r4, r4, CFG_IBAT5L@l + lis r3, CFG_IBAT5U@h + ori r3, r3, CFG_IBAT5U@l + mtspr IBAT5L, r4 + mtspr IBAT5U, r3 isync
+ /* DBAT 5 */ + lis r4, CFG_DBAT5L@h + ori r4, r4, CFG_DBAT5L@l + lis r3, CFG_DBAT5U@h + ori r3, r3, CFG_DBAT5U@l + mtspr DBAT5L, r4 + mtspr DBAT5U, r3 + isync + + /* IBAT 6 */ + lis r4, CFG_IBAT6L@h + ori r4, r4, CFG_IBAT6L@l + lis r3, CFG_IBAT6U@h + ori r3, r3, CFG_IBAT6U@l + mtspr IBAT6L, r4 + mtspr IBAT6U, r3 + isync + + /* DBAT 6 */ + lis r4, CFG_DBAT6L@h + ori r4, r4, CFG_DBAT6L@l + lis r3, CFG_DBAT6U@h + ori r3, r3, CFG_DBAT6U@l + mtspr DBAT6L, r4 + mtspr DBAT6U, r3 + isync + blr + + .globl clear_tlbs +clear_tlbs: + addis r3, 0, 0x0000 + addis r5, 0, 0x4 + isync tlblp: - tlbie r3 + tlbie r3 sync - addi r3, r3, 0x1000 - cmp 0, 0, r3, r5 + addi r3, r3, 0x1000 + cmp 0, 0, r3, r5 blt tlblp - blr
.globl enable_addr_trans
Becky Bruce
