[PATCH 1/1] crypto/fsl: correct printf() statement.
The sequence of arguments should match the format string. For printing unsigned numbers we should use %u.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/crypto/fsl/jobdesc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/crypto/fsl/jobdesc.c b/drivers/crypto/fsl/jobdesc.c index decde64078..fbc1aeddee 100644 --- a/drivers/crypto/fsl/jobdesc.c +++ b/drivers/crypto/fsl/jobdesc.c @@ -102,8 +102,8 @@ int caam_page_alloc(uint8_t page_num, uint8_t partition_num)
/* if the page is not owned => problem */ if ((temp_reg & SMCSJR_PO) != PAGE_OWNED) { - printf("Allocation of page %d in partition %d failed 0x%X\n", - temp_reg, page_num, partition_num); + printf("Allocation of page %u in partition %u failed 0x%X\n", + page_num, partition_num, temp_reg);
return ERROR_IN_PAGE_ALLOC; } -- 2.20.1
