[PATCH] Makefile: Add target to generate hex output for combined spl and dtb
From: Dalon Westergreen dalon.westergreen@intel.com
Some architectures, Stratix10/Agilex, require a hex formatted spl that combines the spl image and dtb. This adds a target to create said hex file with and offset of SPL_TEXT_BASE.
Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- Makefile | 11 ++++++----- include/configs/socfpga_soc64_common.h | 2 +- scripts/Makefile.spl | 8 ++++++++ 3 files changed, 15 insertions(+), 6 deletions(-)
diff --git a/Makefile b/Makefile index 4da46dea39..f1adc9aa23 100644 --- a/Makefile +++ b/Makefile @@ -1263,11 +1263,6 @@ OBJCOPYFLAGS_u-boot-nodtb.bin := -O binary \ $(if $(CONFIG_X86_16BIT_INIT),-R .start16 -R .resetvec) \ $(if $(CONFIG_MPC85XX_HAVE_RESET_VECTOR),-R .bootpg -R .resetvec)
-OBJCOPYFLAGS_u-boot-spl.hex = $(OBJCOPYFLAGS_u-boot.hex) - -spl/u-boot-spl.hex: spl/u-boot-spl FORCE - $(call if_changed,objcopy) - binary_size_check: u-boot-nodtb.bin FORCE @file_size=$(shell wc -c u-boot-nodtb.bin | awk '{print $$1}') ; \ map_size=$(shell cat u-boot.map | \ @@ -1935,6 +1930,12 @@ spl/u-boot-spl.bin: spl/u-boot-spl @: $(SPL_SIZE_CHECK)
+spl/u-boot-spl-dtb.bin: spl/u-boot-spl + @: + +spl/u-boot-spl-dtb.hex: spl/u-boot-spl + @: + spl/u-boot-spl: tools prepare \ $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_SPL_OF_PLATDATA),dts/dt.dtb) \ $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_TPL_OF_PLATDATA),dts/dt.dtb) diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index fdcd7d3e9a..1af359466c 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -200,7 +200,7 @@ unsigned int cm_get_l4_sys_free_clk_hz(void); * 0x8000_0000 ...... End of SDRAM_1 (assume 2GB) * */ -#define CONFIG_SPL_TARGET "spl/u-boot-spl.hex" +#define CONFIG_SPL_TARGET "spl/u-boot-spl-dtb.hex" #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE #define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR #define CONFIG_SPL_BSS_MAX_SIZE 0x100000 /* 1 MB */ diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index ea4e045769..625e06d0d9 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -229,6 +229,9 @@ ifneq ($(CONFIG_TARGET_SOCFPGA_GEN5)$(CONFIG_TARGET_SOCFPGA_ARRIA10),) INPUTS-y += $(obj)/$(SPL_BIN).sfp endif
+INPUTS-$(CONFIG_TARGET_SOCFPGA_STRATIX10) += $(obj)/u-boot-spl-dtb.hex +INPUTS-$(CONFIG_TARGET_SOCFPGA_AGILEX) += $(obj)/u-boot-spl-dtb.hex + ifdef CONFIG_ARCH_SUNXI INPUTS-y += $(obj)/sunxi-spl.bin
@@ -389,6 +392,11 @@ $(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE MKIMAGEFLAGS_sunxi-spl.bin = -T sunxi_egon \ -n $(CONFIG_DEFAULT_DEVICE_TREE)
+OBJCOPYFLAGS_u-boot-spl-dtb.hex := -I binary -O ihex --change-address=$(CONFIG_SPL_TEXT_BASE) + +$(obj)/u-boot-spl-dtb.hex: $(obj)/u-boot-spl-dtb.bin FORCE + $(call if_changed,objcopy) + $(obj)/sunxi-spl.bin: $(obj)/$(SPL_BIN).bin FORCE $(call if_changed,mkimage)
- 0x8000_0000 ...... End of SDRAM_1 (assume 2GB)
The commit message / subject doesn't make it clear that you're doing something for SoCFPGA here, and I seem to recall this change being proposed a while ago and it wasn't clear that this is really the best default path forward I thought?
-- 2.13.0
Hi Tom,
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Saturday, February 20, 2021 5:02 AM To: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Cc: u-boot@lists.denx.de; Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com Subject: Re: [PATCH] Makefile: Add target to generate hex output for combined spl and dtb
R .resetvec)
$(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_SPL_OF_PLATDATA ),dts/dt.dtb) \
$(if
$(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_TPL_OF_PLATDATA ),dts/d
dtb.hex
boot-spl-dtb.hex
+OBJCOPYFLAGS_u-boot-spl-dtb.hex := -I binary -O ihex +--change-address=$(CONFIG_SPL_TEXT_BASE)
Noted. I will resend the patch and enhance the message / subject .
I have checked again with the team about this, we still would like to generate the 'u-boot-spl-dtb.hex' for socfpga soc64 devices by default during u-boot compilation which is always needed by customer to generate the final configuration bitstream. Can you please advise if this is not the right way for the implementation?
Thanks, Siew Chin
-- 2.13.0
-- Tom
On Tue, Feb 23, 2021 at 07:00:47AM +0000, Lim, Elly Siew Chin wrote:
Hi Tom,
R .resetvec)
$(if
dtb.hex
boot-spl-dtb.hex
I think the changes are fine then, please just update the commit message, thanks!
Hi Tom,
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Wednesday, February 24, 2021 12:29 AM To: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Cc: u-boot@lists.denx.de; Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com Subject: Re: [PATCH] Makefile: Add target to generate hex output for combined spl and dtb
Hi Tom,
R .resetvec)
),dts/dt.dtb) \
$(if
),dts/d
MB */
boot-spl-
dtb.hex
boot-spl-dtb.hex
I have sent 2cd patch for review. Thanks.
-- Tom
Lim, Elly Siew Chin
Siew Chin Lim
