[PATCH] arm: Check FEAT_CCIDX when parsing ccsidr_el1 register
Current Cache Size ID Register (ccsidr_el1) has two "flavors" depending on whether FEAT_CCIDX is implemented or not. When FEAT_CCIDX is implemented Associativity parameter is coded on bits [23:3] and NumSets parameter on bits [55:32]. When FEAT_CCIDX is not implemented then Associativity parameter is coded on bits [12:3] and NumSets parameter on bits [27:13]. Current U-Boot code does not check whether FEAT_CCIDX is implemented and always parses ccsidr_el1 as if FEAT_CCIDX was not implemented. This is of course wrong on systems where FEAT_CCIDX is implemented. This patch fixes that problems and tests whether FEAT_CCIDX is implemented or not and accordingly parses the ccsidr_el1 register.
Signed-off-by: Lukasz Wiecaszek lukasz.wiecaszek@gmail.com --- arch/arm/cpu/armv8/cache.S | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/cpu/armv8/cache.S b/arch/arm/cpu/armv8/cache.S index 3fe935cf28..c9e46859b4 100644 --- a/arch/arm/cpu/armv8/cache.S +++ b/arch/arm/cpu/armv8/cache.S @@ -20,6 +20,7 @@ * * x0: cache level * x1: 0 clean & invalidate, 1 invalidate only + * x16: FEAT_CCIDX * x2~x9: clobbered */ .pushsection .text.__asm_dcache_level, "ax" @@ -29,8 +30,14 @@ ENTRY(__asm_dcache_level) isb /* sync change of cssidr_el1 */ mrs x6, ccsidr_el1 /* read the new cssidr_el1 */ ubfx x2, x6, #0, #3 /* x2 <- log2(cache line size)-4 */ + cbz x16, 3f /* check for FEAT_CCIDX */ + ubfx x3, x6, #3, #21 /* x3 <- number of cache ways - 1 */ + ubfx x4, x6, #32, #24 /* x4 <- number of cache sets - 1 */ + b 4f +3: ubfx x3, x6, #3, #10 /* x3 <- number of cache ways - 1 */ ubfx x4, x6, #13, #15 /* x4 <- number of cache sets - 1 */ +4: add x2, x2, #4 /* x2 <- log2(cache line size) */ clz w5, w3 /* bit position of #ways */ /* x12 <- cache level << 1 */ @@ -74,6 +81,8 @@ ENTRY(__asm_dcache_all) ubfx x11, x10, #24, #3 /* x11 <- loc */ cbz x11, finished /* if loc is 0, exit */ mov x15, lr + mrs x16, s3_0_c0_c7_2 /* read value of id_aa64mmfr2_el1*/ + ubfx x16, x16, #20, #4 /* save FEAT_CCIDX identifier in x16 */ mov x0, #0 /* start flush at cache level 0 */ /* x0 <- cache level */ /* x10 <- clidr_el1 */
Lukasz Wiecaszek
