[U-Boot] [PATCH] powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boards
P1010RDB and p1_pc_rdb_pc has incorrect configuration for CONFIG_DDR_RAW_TIMING. It should be CONFIG_SYS_DDR_RAW_TIMING. Incorrect setting causes DDR failure in case of SPD absent.
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/p1010rdb/ddr.c | 6 +++--- board/freescale/p1_p2_rdb_pc/ddr.c | 4 ++-- include/configs/P1010RDB.h | 2 +- include/configs/p1_p2_rdb_pc.h | 2 +- 4 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/board/freescale/p1010rdb/ddr.c b/board/freescale/p1010rdb/ddr.c index e5d8423..36c8545 100644 --- a/board/freescale/p1010rdb/ddr.c +++ b/board/freescale/p1010rdb/ddr.c @@ -31,7 +31,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifndef CONFIG_DDR_RAW_TIMING +#ifndef CONFIG_SYS_DDR_RAW_TIMING #define CONFIG_SYS_DRAM_SIZE 1024
fsl_ddr_cfg_regs_t ddr_cfg_regs_800 = { @@ -165,7 +165,7 @@ phys_size_t fixed_sdram(void) return ddr_size; }
-#else /* CONFIG_DDR_RAW_TIMING */ +#else /* CONFIG_SYS_DDR_RAW_TIMING */ /* * Samsung K4B2G0846C-HCF8 * The following timing are for "downshift" @@ -247,4 +247,4 @@ void fsl_ddr_board_options(memctl_options_t *popts, } }
-#endif /* CONFIG_DDR_RAW_TIMING */ +#endif /* CONFIG_SYS_DDR_RAW_TIMING */ diff --git a/board/freescale/p1_p2_rdb_pc/ddr.c b/board/freescale/p1_p2_rdb_pc/ddr.c index f0cbde7..88ba56f 100644 --- a/board/freescale/p1_p2_rdb_pc/ddr.c +++ b/board/freescale/p1_p2_rdb_pc/ddr.c @@ -15,7 +15,7 @@ #include <asm/io.h> #include <asm/fsl_law.h>
-#ifdef CONFIG_DDR_RAW_TIMING +#ifdef CONFIG_SYS_DDR_RAW_TIMING #if defined(CONFIG_P1020RDB_PROTO) || \ defined(CONFIG_P1021RDB) || \ defined(CONFIG_P1020UTM) @@ -204,7 +204,7 @@ int fsl_ddr_get_dimm_params(dimm_params_t *pdimm,
return 0; } -#endif /* CONFIG_DDR_RAW_TIMING */ +#endif /* CONFIG_SYS_DDR_RAW_TIMING */
/* Fixed sdram init -- doesn't use serial presence detect. */ phys_size_t fixed_sdram(void) diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index af4609f..d63115d 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -181,7 +181,7 @@
/* DDR Setup */ #define CONFIG_FSL_DDR3 -#define CONFIG_DDR_RAW_TIMING +#define CONFIG_SYS_DDR_RAW_TIMING #define CONFIG_DDR_SPD #define CONFIG_SYS_SPD_BUS_NUM 1 #define SPD_EEPROM_ADDRESS 0x52 diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 8e8fa16..a4ae52c 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -227,7 +227,7 @@
York Sun
