[U-Boot] [PATCH v2 0/3] Pandora config fixes and updates
These patches update pandora's config for relocations and memory layout changes. They also sync the config with one shipped on production units.
Please apply at least the first patch for v2010.12 so that we have pandora buildable. Patches generated on top of u-boot-ti, also applies on mainline u-boot.
Grazvydas Ignotas (3): OMAP3: pandora: fix relocation and init memory map OMAP3: pandora: remove unused config macros OMAP3: pandora: update config for production
board/pandora/config.mk | 33 ----------- include/configs/omap3_pandora.h | 117 +++++++++++++++++--------------------- 2 files changed, 52 insertions(+), 98 deletions(-) delete mode 100644 board/pandora/config.mk
Fix the build breakage introduced by the recent relocation and memory layout changes for ARM.
Signed-off-by: Grazvydas Ignotas notasas@gmail.com --- board/pandora/config.mk | 33 --------------------------------- include/configs/omap3_pandora.h | 8 ++++++++ 2 files changed, 8 insertions(+), 33 deletions(-) delete mode 100644 board/pandora/config.mk
diff --git a/board/pandora/config.mk b/board/pandora/config.mk deleted file mode 100644 index 0fab80c..0000000 --- a/board/pandora/config.mk +++ /dev/null @@ -1,33 +0,0 @@ -# -# (C) Copyright 2006 -# Texas Instruments, <www.ti.com> -# -# Pandora uses OMAP3 (ARM-CortexA8) cpu -# see http://www.ti.com/ for more information on Texas Instruments -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# Physical Address: -# 8000'0000 (bank0) -# A000/0000 (bank1) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -# For use with external or internal boots. -CONFIG_SYS_TEXT_BASE = 0x80e80000 diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index b78aacf..b8cd2cd 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -243,6 +243,14 @@ /* SDRAM Bank Allocation method */ #define SDRC_R_B_C 1
+#define CONFIG_SYS_TEXT_BASE 0x80008000 +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) + /*----------------------------------------------------------------------- * FLASH and environment organization */
Pandora's config has various flash related macros that are either not referenced anywhere in the code or are used by drivers that are not enabled. Remove them.
Signed-off-by: Grazvydas Ignotas notasas@gmail.com --- Alternatively this old patch can be applied to clean up more OMAP boards: http://lists.denx.de/pipermail/u-boot/2010-April/070860.html
include/configs/omap3_pandora.h | 20 -------------------- 1 files changed, 0 insertions(+), 20 deletions(-)
diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index b8cd2cd..f386bc4 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -261,40 +261,20 @@ #define PISMO1_NAND_SIZE GPMC_SIZE_128M #define PISMO1_ONEN_SIZE GPMC_SIZE_128M
-#define CONFIG_SYS_MAX_FLASH_SECT 520 /* max number of sectors on */ - /* one chip */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
#define CONFIG_SYS_FLASH_BASE boot_flash_base
/* Monitor at start of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
#define CONFIG_ENV_IS_IN_NAND 1 -#define ONENAND_ENV_OFFSET 0x240000 /* environment starts here */ #define SMNAND_ENV_OFFSET 0x240000 /* environment starts here */
#define CONFIG_SYS_ENV_SECT_SIZE boot_flash_sec #define CONFIG_ENV_OFFSET boot_flash_off #define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET
-/*----------------------------------------------------------------------- - * CFI FLASH driver setup - */ -/* timeout values are in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) - -/* Flash banks JFFS2 should use */ -#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + \ - CONFIG_SYS_MAX_NAND_DEVICE) -#define CONFIG_SYS_JFFS2_MEM_NAND -/* use flash_info[2] */ -#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS -#define CONFIG_SYS_JFFS2_NUM_BANKS 1 - #ifndef __ASSEMBLY__ extern unsigned int boot_flash_base; extern volatile unsigned int boot_flash_env_addr;
Do you think this patch still applies clean?
It will be better if you repost to refresh us all.
Regards, Sandeep
Update pandora's config so that it can boot production kernels from NAND. This enables UBI, USB, sets up NAND layout and default boot command. It also expands malloc area so that UBI works.
Signed-off-by: Grazvydas Ignotas notasas@gmail.com --- include/configs/omap3_pandora.h | 89 +++++++++++++++++++-------------------- 1 files changed, 44 insertions(+), 45 deletions(-)
diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index f386bc4..72b0cc2 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -1,6 +1,6 @@ /* - * (C) Copyright 2008 - * Grazvydas Ignotas notasas@gmail.com + * (C) Copyright 2008-2010 + * GraÅžvydas Ignotas notasas@gmail.com * * Configuration settings for the OMAP3 Pandora. * @@ -59,14 +59,24 @@ * Size of malloc() pool */ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ - /* Sector */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) - /* initial data */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024 + CONFIG_ENV_SIZE)
/* * Hardware drivers */
+#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* USB */ +#define CONFIG_MUSB_UDC 1 +#define CONFIG_USB_OMAP3 1 +#define CONFIG_TWL4030_USB 1 + +/* USB device configuration */ +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 + /* * NS16550 Configuration */ @@ -101,11 +111,11 @@
#define CONFIG_CMD_EXT2 /* EXT2 Support */ #define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_JFFS2 /* JFFS2 Support */
#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_CACHE /* Cache control */
#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ @@ -141,52 +151,41 @@
#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ -#define CONFIG_JFFS2_NAND -/* nand device jffs2 lives on */ -#define CONFIG_JFFS2_DEV "nand0" -/* start of jffs2 partition */ -#define CONFIG_JFFS2_PART_OFFSET 0x680000 -#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* size of jffs2 */ - /* partition */ + +#ifdef CONFIG_CMD_NAND +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_LZO + +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:512k(xloader),"\ + "1920k(uboot),128k(uboot-env),"\ + "10m(boot),-(rootfs)" +#else +#define MTDPARTS_DEFAULT +#endif
/* Environment information */ #define CONFIG_BOOTDELAY 1
#define CONFIG_EXTRA_ENV_SETTINGS \ + "usbtty=cdc_acm\0" \ "loadaddr=0x82000000\0" \ - "console=ttyS0,115200n8\0" \ - "videospec=omapfb:vram:2M,vram:4M\0" \ - "mmcargs=setenv bootargs console=${console} " \ - "video=${videospec} " \ - "root=/dev/mmcblk0p2 rw " \ - "rootfstype=ext3 rootwait\0" \ - "nandargs=setenv bootargs console=${console} " \ - "video=${videospec} " \ - "root=/dev/mtdblock4 rw " \ - "rootfstype=jffs2\0" \ - "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ - "bootscript=echo Running bootscript from mmc ...; " \ - "source ${loadaddr}\0" \ - "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "bootm ${loadaddr}\0" \ - "nandboot=echo Booting from nand ...; " \ - "run nandargs; " \ - "nand read ${loadaddr} 280000 400000; " \ - "bootm ${loadaddr}\0" \ + "bootargs=ubi.mtd=4 ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs " \ + "rw rootflags=bulk_read console=ttyS0,115200n8 " \ + "vram=6272K omapfb.vram=0:3000K\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \
#define CONFIG_BOOTCOMMAND \ - "if mmc init; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loaduimage; then " \ - "run mmcboot; " \ - "else run nandboot; " \ - "fi; " \ - "fi; " \ - "else run nandboot; fi" + "if mmc init && fatload mmc1 0 ${loadaddr} autoboot.scr || " \ + "ext2load mmc1 0 ${loadaddr} autoboot.scr; then " \ + "source ${loadaddr}; " \ + "fi; " \ + "ubi part boot && ubifsmount boot && ubifsload ${loadaddr} uImage && bootm ${loadaddr}"
#define CONFIG_AUTO_COMPLETE 1 /* @@ -269,7 +268,7 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_ENV_IS_IN_NAND 1 -#define SMNAND_ENV_OFFSET 0x240000 /* environment starts here */ +#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
Pushed the entire series to u-boot-ti
--Sandeep
Grazvydas Ignotas
Paulraj, Sandeep
