[PATCH 1/1] CVE-2022-30767: unbounded memcpy with a failed length check
This patch tries to fix a CVE-2019-14196 fix
In if-condition, where NFSV2_FLAG is checked, memcpy call is performed to transfer a reply data of NFS_FHSIZE size. Since the data field in struct rpc_t structure has the size of (1024 / 4) + 26 = 282, while NFS_FHSIZE is only 32, it won't lead to out-of-bounds write (considering the size of data array won't change in the future).
What concerns if-condition for NFSV3_FLAG, since filefh3_length is signed integer, it may carry negative values which may lead to memcpy failure, so in this case we need to introduce not only boundary check (filefh3_length > NFS3_FHSIZE), which exists, but also make sure that filefh3_length is not negative.
Signed-off-by: gerbert gerbert@users.noreply.github.com --- net/nfs.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/net/nfs.c b/net/nfs.c index 9152ab742e..5186130ea9 100644 --- a/net/nfs.c +++ b/net/nfs.c @@ -566,13 +566,13 @@ static int nfs_lookup_reply(uchar *pkt, unsigned len) }
if (supported_nfs_versions & NFSV2_FLAG) { - if (((uchar *)&(rpc_pkt.u.reply.data[0]) - (uchar *)(&rpc_pkt) + NFS_FHSIZE) > len) - return -NFS_RPC_DROP; memcpy(filefh, rpc_pkt.u.reply.data + 1, NFS_FHSIZE); } else { /* NFSV3_FLAG */ filefh3_length = ntohl(rpc_pkt.u.reply.data[1]); + if (filefh3_length < 0) + return -NFS_RPC_DROP; if (filefh3_length > NFS3_FHSIZE) - filefh3_length = NFS3_FHSIZE; + filefh3_length = NFS3_FHSIZE; memcpy(filefh, rpc_pkt.u.reply.data + 2, filefh3_length); }
This has been addressed as: https://patchwork.ozlabs.org/project/uboot/patch/20220518163103.372-1-zi0Bla... and more clearly: https://source.denx.de/u-boot/u-boot/-/commit/bdbf7a05e26f3c5fd437c99e2755ff... recently, thanks.
Tom Rini писал 2022-06-06 17:43:
That's right. But as far as I can see if-condition for NFS v2 has the same leftover, which was removed from v3 part. In this case I guess it can be removed.
Kind regards, Gerbert
gerbert
