[PATCH] sunxi: Bring back SD card as MMC device 0
Commit 2243d19e5618 ("mmc: mmc-uclass: Use dev_seq() to read aliases node's index") now actually enforces U-Boot's device enumeration policy, where explicitly named devices come first, then any other non-named devices follow, without filling gaps.
For quite a while we have had an "mmc1 = &mmc2;" alias in our sunxi-u-boot.dtsi, which now leads to the problem that the SD card (which was always mmc device 0) now gets to be number 2. I guess this breaks quite some boot scripts, and is confusing at least.
Just add an explicit mmc0 alias in the very same file to fix this and restore the old behaviour.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reported-by: Samuel Holland samuel@sholland.org --- arch/arm/dts/sunxi-u-boot.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/sunxi-u-boot.dtsi b/arch/arm/dts/sunxi-u-boot.dtsi index a4227a3c22d..06da009fa28 100644 --- a/arch/arm/dts/sunxi-u-boot.dtsi +++ b/arch/arm/dts/sunxi-u-boot.dtsi @@ -12,6 +12,7 @@
/ { aliases { + mmc0 = &mmc0; mmc1 = &mmc2; };
On Fri, 16 Apr 2021 12:08:09 +0100 Andre Przywara andre.przywara@arm.com wrote:
Can someone please say if this is the right solution? I think the SD card has always been mmc device 0 in U-Boot, so I think it's worth keeping that. Just not sure if this is the right way of fixing that?
Cheers, Andre
/ { aliases {
mmc1 = &mmc2; };mmc0 = &mmc0;
Playing with aliases always gets confused and might get a different behavior, IMHO. Detect the dev number by U-Boot itself and look at traverse bootenv by all possible dev numbers in sunxi-common.h, but this has one slide effect that we mark mmc2 as devnum 1 for the sake of fastboot so if we mark fastboot number for specific board properly (by static or runtime) then explicit aliases wouldn't required.
Jagan.
On Sun, 25 Apr 2021 18:03:05 +0530 Jagan Teki jagan@amarulasolutions.com wrote:
Hi Jagan,
thanks for your input!
I am not so sure about that, since aliases force a fixed numbering, so it should be less confusing. We have the same problem in the kernel now, and Samuel sent some patches to have aliases in the mainline DTs as well [1].
OK, I will have a look at how the automatic distro boot behaves with this change. My concern was more the interactive user, who is used to have the SD card at device 0 (I certainly am).
Ah, good point, thanks for the heads up. I guess this is the actual reason for the alias in our -u-boot.dtsi? Maybe we find a different way to let fastboot find the eMMC? Then we can drop the extra mmc1 alias, get our numbering back, and can cope with the incoming aliases from the mainline DTs as well?
Cheers, Andre
[1] http://lists.infradead.org/pipermail/linux-arm-kernel/2021-April/652946.html
Hi Jagan,
Okay.
Agreed.
On Mon, 26 Apr 2021 17:52:51 +0530 Jagan Teki jagan@amarulasolutions.com wrote:
Hi Jagan,
Hi Jagan,
Okay.
Agreed.
So I had a look at fastboot, and posted an RFC[1] to try and fix this properly. This seems to somewhat work, but there are more assumptions in (sunxi) U-Boot about the eMMC being device 1 (boot source, distro_boot scripts, ...). I agree that we should remove this assumption, but this requires more work and scrutiny to find all those cases.
For now the change in numbering breaks right, left, and centre: boot.scr cannot be found anymore, fastboot cannot find the SD card, custom scripts stop working.
So I would very much like to merge this patch here, to fix the currently bad user experience and get a clean v2021.07 release. We can meanwhile look into a proper solution for this problem, to become more robust against enumeration changes (for instance due to aliases).
Thanks, Andre
As a user who spent quite some time trying to find out what's going on, I can only second that.
If it helps, I can offer a "tested by". I tested this patch on a Pine 64+ using pine64_plus_defconfig.
Tested-by: Simon Baatz gmbnomis@gmail.com
Andre Przywara
Jagan Teki
Simon Baatz
