[PATCH 0/3] dwc3: gadget: properly fix cache operations
We experience huge problems with cache handling on Qualcomm systems, and it appears the dcache handling in the DWC3 gadget code is quite wrong and causes operational issues.
This serie fixes the dcache operations on unaligned data, and properly invalidate buffers when reading back data from hardware.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- Neil Armstrong (3): usb: dwc3: allocate setup_buf with dma_alloc_coherent() usb: dwc3: fix dcache flush range calculation usb: dwc3: invalidate dcache on buffer used in interrupt handling
drivers/usb/dwc3/core.h | 2 ++ drivers/usb/dwc3/ep0.c | 6 ++++-- drivers/usb/dwc3/gadget.c | 10 ++++++---- drivers/usb/dwc3/io.h | 13 ++++++++++++- 4 files changed, 24 insertions(+), 7 deletions(-) --- base-commit: 3f772959501c99fbe5aa0b22a36efe3478d1ae1c change-id: 20240719-u-boot-dwc3-gadget-dcache-fixup-ea1e92758663
Also allocate the setup_buf with dma_alloc_coherent() since it's also consumed by the hardware DMA.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/usb/dwc3/core.h | 2 ++ drivers/usb/dwc3/ep0.c | 4 ++-- drivers/usb/dwc3/gadget.c | 8 ++++---- 3 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/dwc3/core.h b/drivers/usb/dwc3/core.h index 7374ce950da..ce35460c405 100644 --- a/drivers/usb/dwc3/core.h +++ b/drivers/usb/dwc3/core.h @@ -670,6 +670,7 @@ struct dwc3_scratchpad_array { * @ep0_trb: dma address of ep0_trb * @ep0_usb_req: dummy req used while handling STD USB requests * @ep0_bounce_addr: dma address of ep0_bounce + * @setup_buf_addr: dma address if setup_buf * @scratch_addr: dma address of scratchbuf * @lock: for synchronizing * @dev: pointer to our struct device @@ -757,6 +758,7 @@ struct dwc3 { dma_addr_t ep0_trb_addr; dma_addr_t ep0_bounce_addr; dma_addr_t scratch_addr; + dma_addr_t setup_buf_addr; struct dwc3_request ep0_usb_req;
/* device lock */ diff --git a/drivers/usb/dwc3/ep0.c b/drivers/usb/dwc3/ep0.c index 16b11ce3d9f..0c7e0123368 100644 --- a/drivers/usb/dwc3/ep0.c +++ b/drivers/usb/dwc3/ep0.c @@ -381,7 +381,7 @@ static int dwc3_ep0_handle_status(struct dwc3 *dwc, dep = dwc->eps[0]; dwc->ep0_usb_req.dep = dep; dwc->ep0_usb_req.request.length = sizeof(*response_pkt); - dwc->ep0_usb_req.request.buf = dwc->setup_buf; + dwc->ep0_usb_req.request.buf = (void *)dwc->setup_buf_addr; dwc->ep0_usb_req.request.complete = dwc3_ep0_status_cmpl;
return __dwc3_gadget_ep0_queue(dep, &dwc->ep0_usb_req); @@ -663,7 +663,7 @@ static int dwc3_ep0_set_sel(struct dwc3 *dwc, struct usb_ctrlrequest *ctrl) dep = dwc->eps[0]; dwc->ep0_usb_req.dep = dep; dwc->ep0_usb_req.request.length = dep->endpoint.maxpacket; - dwc->ep0_usb_req.request.buf = dwc->setup_buf; + dwc->ep0_usb_req.request.buf = (void *)dwc->setup_buf_addr; dwc->ep0_usb_req.request.complete = dwc3_ep0_set_sel_cmpl;
return __dwc3_gadget_ep0_queue(dep, &dwc->ep0_usb_req); diff --git a/drivers/usb/dwc3/gadget.c b/drivers/usb/dwc3/gadget.c index 7d6bcc2627f..d41b590afb8 100644 --- a/drivers/usb/dwc3/gadget.c +++ b/drivers/usb/dwc3/gadget.c @@ -2622,8 +2622,8 @@ int dwc3_gadget_init(struct dwc3 *dwc) goto err1; }
- dwc->setup_buf = memalign(CONFIG_SYS_CACHELINE_SIZE, - DWC3_EP0_BOUNCE_SIZE); + dwc->setup_buf = dma_alloc_coherent(DWC3_EP0_BOUNCE_SIZE, + (unsigned long *)&dwc->setup_buf_addr); if (!dwc->setup_buf) { ret = -ENOMEM; goto err2; @@ -2670,7 +2670,7 @@ err4: dma_free_coherent(dwc->ep0_bounce);
err3: - kfree(dwc->setup_buf); + dma_free_coherent(dwc->setup_buf);
err2: dma_free_coherent(dwc->ep0_trb); @@ -2692,7 +2692,7 @@ void dwc3_gadget_exit(struct dwc3 *dwc)
Hi Neil,
Thank you for the patch.
On ven., juil. 19, 2024 at 15:56, Neil Armstrong neil.armstrong@linaro.org wrote:
The subject of the patch says:
"usb: dwc3: allocate setup_buf with dma_alloc_coherent()"
Isn't this line just repeating the title?
- @ep0_trb: dma address of ep0_trb
- @ep0_usb_req: dummy req used while handling STD USB requests
- @ep0_bounce_addr: dma address of ep0_bounce
- @setup_buf_addr: dma address if setup_buf
if -> of
Both remarks being minor, please add:
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
- @scratch_addr: dma address of scratchbuf
- @lock: for synchronizing
- @dev: pointer to our struct device
/* device lock */
- dwc->setup_buf = dma_alloc_coherent(DWC3_EP0_BOUNCE_SIZE,
if (!dwc->setup_buf) { ret = -ENOMEM; goto err2;(unsigned long *)&dwc->setup_buf_addr);
err3:
- dma_free_coherent(dwc->setup_buf);
-- 2.34.1
On 24/07/2024 17:03, Mattijs Korpershoek wrote:
Hi Neil,
Yeah it's a verbose rewrite of the subject, I'll rewrite it to be less bad!
thanks Neil
if -> of
/* device lock */
err3:
-- 2.34.1
The current flush operation will omit doing a flush/invalidate on the first and last bytes if the base address and size are not aligned with DMA_MINALIGN.
This causes operation failures Qualcomm platforms.
Take in account the alignment and size of the buffer and also flush the previous and last cacheline.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/usb/dwc3/io.h | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/dwc3/io.h b/drivers/usb/dwc3/io.h index 04791d4c9be..1aaf5413c6d 100644 --- a/drivers/usb/dwc3/io.h +++ b/drivers/usb/dwc3/io.h @@ -50,6 +50,9 @@ static inline void dwc3_writel(void __iomem *base, u32 offset, u32 value)
static inline void dwc3_flush_cache(uintptr_t addr, int length) { - flush_dcache_range(addr, addr + ROUND(length, CACHELINE_SIZE)); + uintptr_t start_addr = (uintptr_t)addr & ~(ARCH_DMA_MINALIGN - 1); + uintptr_t end_addr = ALIGN((uintptr_t)addr + length, ARCH_DMA_MINALIGN); + + flush_dcache_range(start_addr, end_addr); } #endif /* __DRIVERS_USB_DWC3_IO_H */
Hi Neil,
- uintptr_t start_addr = (uintptr_t)addr & ~(ARCH_DMA_MINALIGN - 1);
- uintptr_t end_addr = ALIGN((uintptr_t)addr + length, ARCH_DMA_MINALIGN);
- flush_dcache_range(start_addr, end_addr);
-- 2.34.1
On Qualcomm systems, the setup buffer and even buffers are in a bad state at interrupt handling, so invalidate the dcache lines for the setup_buf and event buffer to make sure we read correct data written by the hardware.
This fixes the following error: dwc3-generic-peripheral usb@a600000: UNKNOWN IRQ type -1 dwc3-generic-peripheral usb@a600000: UNKNOWN IRQ type 4673109
and invalid situation in dwc3_gadget_giveback() because setup_buf content is read at 0s and leads to fatal crash fixed by [1].
[1] https://lore.kernel.org/all/20240528-topic-sm8x50-dwc3-gadget-crash-fix-v1-1...
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/usb/dwc3/ep0.c | 2 ++ drivers/usb/dwc3/gadget.c | 2 ++ drivers/usb/dwc3/io.h | 8 ++++++++ 3 files changed, 12 insertions(+)
diff --git a/drivers/usb/dwc3/ep0.c b/drivers/usb/dwc3/ep0.c index 0c7e0123368..fc1d5892106 100644 --- a/drivers/usb/dwc3/ep0.c +++ b/drivers/usb/dwc3/ep0.c @@ -743,6 +743,8 @@ static void dwc3_ep0_inspect_setup(struct dwc3 *dwc, if (!dwc->gadget_driver) goto out;
+ dwc3_invalidate_cache(ctrl, sizeof(*ctrl)); + len = le16_to_cpu(ctrl->wLength); if (!len) { dwc->three_stage_setup = false; diff --git a/drivers/usb/dwc3/gadget.c b/drivers/usb/dwc3/gadget.c index d41b590afb8..0bc9aee4daa 100644 --- a/drivers/usb/dwc3/gadget.c +++ b/drivers/usb/dwc3/gadget.c @@ -2503,6 +2503,8 @@ static irqreturn_t dwc3_process_event_buf(struct dwc3 *dwc, u32 buf) while (left > 0) { union dwc3_event event;
+ dwc3_invalidate_cache((uintptr_t)evt->buf, evt->length); + event.raw = *(u32 *) (evt->buf + evt->lpos);
dwc3_process_event_entry(dwc, &event); diff --git a/drivers/usb/dwc3/io.h b/drivers/usb/dwc3/io.h index 1aaf5413c6d..7cf05203b0d 100644 --- a/drivers/usb/dwc3/io.h +++ b/drivers/usb/dwc3/io.h @@ -55,4 +55,12 @@ static inline void dwc3_flush_cache(uintptr_t addr, int length)
flush_dcache_range(start_addr, end_addr); } + +static inline void dwc3_invalidate_cache(uintptr_t addr, int length) +{ + uintptr_t start_addr = (uintptr_t)addr & ~(ARCH_DMA_MINALIGN - 1); + uintptr_t end_addr = ALIGN((uintptr_t)addr + length, ARCH_DMA_MINALIGN); + + invalidate_dcache_range(start_addr, end_addr); +} #endif /* __DRIVERS_USB_DWC3_IO_H */
Hi Neil,
- dwc3_invalidate_cache(ctrl, sizeof(*ctrl));
- len = le16_to_cpu(ctrl->wLength); if (!len) { dwc->three_stage_setup = false;
- invalidate_dcache_range(start_addr, end_addr);
-- 2.34.1
Mattijs Korpershoek
Neil Armstrong
