[U-Boot] [PATCH] [UBI] Basic Unsorted Block Image (UBI) support v3 (#1)
UBI (Latin: "where?") stands for "Unsorted Block Images". It is a volume management system for flash devices which manages multiple logical volumes on a single physical flash device and spreads the I/O load (i.e, wear-leveling) across the whole flash chip.
In a sense, UBI may be compared to the Logical Volume Manager (LVM). Whereas LVM maps logical sectors to physical sectors, UBI maps logical eraseblocks to physical eraseblocks. But besides the mapping, UBI implements global wear-leveling and I/O errors handling.
For more details, Please visit the following URL. http://www.linux-mtd.infradead.org/doc/ubi.html
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- diff --git a/drivers/mtd/ubi/Makefile b/drivers/mtd/ubi/Makefile new file mode 100644 index 0000000..30eed96 --- /dev/null +++ b/drivers/mtd/ubi/Makefile @@ -0,0 +1,48 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libubi.a +COBJS-y += build.o vtbl.o vmt.o upd.o kapi.o eba.o io.o wl.o scan.o crc32.o + +COBJS-y += misc.o +COBJS-y += debug.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/drivers/mtd/ubi/build.c b/drivers/mtd/ubi/build.c new file mode 100644 index 0000000..b6f8699 --- /dev/null +++ b/drivers/mtd/ubi/build.c @@ -0,0 +1,1185 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * Copyright (c) Nokia Corporation, 2007 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём), + * Frank Haverkamp + */ + +/* + * This file includes UBI initialization and building of UBI devices. + * + * When UBI is initialized, it attaches all the MTD devices specified as the + * module load parameters or the kernel boot parameters. If MTD devices were + * specified, UBI does not attach any MTD device, but it is possible to do + * later using the "UBI control device". + * + * At the moment we only attach UBI devices by scanning, which will become a + * bottleneck when flashes reach certain large size. Then one may improve UBI + * and add other methods, although it does not seem to be easy to do. + */ + +#ifdef UBI_LINUX +#include <linux/err.h> +#include <linux/module.h> +#include <linux/moduleparam.h> +#include <linux/stringify.h> +#include <linux/stat.h> +#include <linux/miscdevice.h> +#include <linux/log2.h> +#include <linux/kthread.h> +#endif +#include <ubi_uboot.h> +#include "ubi.h" + +/* Maximum length of the 'mtd=' parameter */ +#define MTD_PARAM_LEN_MAX 64 + +/** + * struct mtd_dev_param - MTD device parameter description data structure. + * @name: MTD device name or number string + * @vid_hdr_offs: VID header offset + */ +struct mtd_dev_param { + char name[MTD_PARAM_LEN_MAX]; + int vid_hdr_offs; +}; + +/* Numbers of elements set in the @mtd_dev_param array */ +static int mtd_devs; + +/* MTD devices specification parameters */ +static struct mtd_dev_param mtd_dev_param[UBI_MAX_DEVICES]; + +/* Root UBI "class" object (corresponds to '/<sysfs>/class/ubi/') */ +struct class *ubi_class; + +#ifdef UBI_LINUX +/* Slab cache for wear-leveling entries */ +struct kmem_cache *ubi_wl_entry_slab; + +/* UBI control character device */ +static struct miscdevice ubi_ctrl_cdev = { + .minor = MISC_DYNAMIC_MINOR, + .name = "ubi_ctrl", + .fops = &ubi_ctrl_cdev_operations, +}; +#endif + +/* All UBI devices in system */ +struct ubi_device *ubi_devices[UBI_MAX_DEVICES]; + +#ifdef UBI_LINUX +/* Serializes UBI devices creations and removals */ +DEFINE_MUTEX(ubi_devices_mutex); + +/* Protects @ubi_devices and @ubi->ref_count */ +static DEFINE_SPINLOCK(ubi_devices_lock); + +/* "Show" method for files in '/<sysfs>/class/ubi/' */ +static ssize_t ubi_version_show(struct class *class, char *buf) +{ + return sprintf(buf, "%d\n", UBI_VERSION); +} + +/* UBI version attribute ('/<sysfs>/class/ubi/version') */ +static struct class_attribute ubi_version = + __ATTR(version, S_IRUGO, ubi_version_show, NULL); + +static ssize_t dev_attribute_show(struct device *dev, + struct device_attribute *attr, char *buf); + +/* UBI device attributes (correspond to files in '/<sysfs>/class/ubi/ubiX') */ +static struct device_attribute dev_eraseblock_size = + __ATTR(eraseblock_size, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_avail_eraseblocks = + __ATTR(avail_eraseblocks, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_total_eraseblocks = + __ATTR(total_eraseblocks, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_volumes_count = + __ATTR(volumes_count, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_max_ec = + __ATTR(max_ec, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_reserved_for_bad = + __ATTR(reserved_for_bad, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_bad_peb_count = + __ATTR(bad_peb_count, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_max_vol_count = + __ATTR(max_vol_count, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_min_io_size = + __ATTR(min_io_size, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_bgt_enabled = + __ATTR(bgt_enabled, S_IRUGO, dev_attribute_show, NULL); +static struct device_attribute dev_mtd_num = + __ATTR(mtd_num, S_IRUGO, dev_attribute_show, NULL); +#endif + +/** + * ubi_get_device - get UBI device. + * @ubi_num: UBI device number + * + * This function returns UBI device description object for UBI device number + * @ubi_num, or %NULL if the device does not exist. This function increases the + * device reference count to prevent removal of the device. In other words, the + * device cannot be removed if its reference count is not zero. + */ +struct ubi_device *ubi_get_device(int ubi_num) +{ + struct ubi_device *ubi; + + spin_lock(&ubi_devices_lock); + ubi = ubi_devices[ubi_num]; + if (ubi) { + ubi_assert(ubi->ref_count >= 0); + ubi->ref_count += 1; + get_device(&ubi->dev); + } + spin_unlock(&ubi_devices_lock); + + return ubi; +} + +/** + * ubi_put_device - drop an UBI device reference. + * @ubi: UBI device description object + */ +void ubi_put_device(struct ubi_device *ubi) +{ + spin_lock(&ubi_devices_lock); + ubi->ref_count -= 1; + put_device(&ubi->dev); + spin_unlock(&ubi_devices_lock); +} + +/** + * ubi_get_by_major - get UBI device description object by character device + * major number. + * @major: major number + * + * This function is similar to 'ubi_get_device()', but it searches the device + * by its major number. + */ +struct ubi_device *ubi_get_by_major(int major) +{ + int i; + struct ubi_device *ubi; + + spin_lock(&ubi_devices_lock); + for (i = 0; i < UBI_MAX_DEVICES; i++) { + ubi = ubi_devices[i]; + if (ubi && MAJOR(ubi->cdev.dev) == major) { + ubi_assert(ubi->ref_count >= 0); + ubi->ref_count += 1; + get_device(&ubi->dev); + spin_unlock(&ubi_devices_lock); + return ubi; + } + } + spin_unlock(&ubi_devices_lock); + + return NULL; +} + +/** + * ubi_major2num - get UBI device number by character device major number. + * @major: major number + * + * This function searches UBI device number object by its major number. If UBI + * device was not found, this function returns -ENODEV, otherwise the UBI device + * number is returned. + */ +int ubi_major2num(int major) +{ + int i, ubi_num = -ENODEV; + + spin_lock(&ubi_devices_lock); + for (i = 0; i < UBI_MAX_DEVICES; i++) { + struct ubi_device *ubi = ubi_devices[i]; + + if (ubi && MAJOR(ubi->cdev.dev) == major) { + ubi_num = ubi->ubi_num; + break; + } + } + spin_unlock(&ubi_devices_lock); + + return ubi_num; +} + +#ifdef UBI_LINUX +/* "Show" method for files in '/<sysfs>/class/ubi/ubiX/' */ +static ssize_t dev_attribute_show(struct device *dev, + struct device_attribute *attr, char *buf) +{ + ssize_t ret; + struct ubi_device *ubi; + + /* + * The below code looks weird, but it actually makes sense. We get the + * UBI device reference from the contained 'struct ubi_device'. But it + * is unclear if the device was removed or not yet. Indeed, if the + * device was removed before we increased its reference count, + * 'ubi_get_device()' will return -ENODEV and we fail. + * + * Remember, 'struct ubi_device' is freed in the release function, so + * we still can use 'ubi->ubi_num'. + */ + ubi = container_of(dev, struct ubi_device, dev); + ubi = ubi_get_device(ubi->ubi_num); + if (!ubi) + return -ENODEV; + + if (attr == &dev_eraseblock_size) + ret = sprintf(buf, "%d\n", ubi->leb_size); + else if (attr == &dev_avail_eraseblocks) + ret = sprintf(buf, "%d\n", ubi->avail_pebs); + else if (attr == &dev_total_eraseblocks) + ret = sprintf(buf, "%d\n", ubi->good_peb_count); + else if (attr == &dev_volumes_count) + ret = sprintf(buf, "%d\n", ubi->vol_count - UBI_INT_VOL_COUNT); + else if (attr == &dev_max_ec) + ret = sprintf(buf, "%d\n", ubi->max_ec); + else if (attr == &dev_reserved_for_bad) + ret = sprintf(buf, "%d\n", ubi->beb_rsvd_pebs); + else if (attr == &dev_bad_peb_count) + ret = sprintf(buf, "%d\n", ubi->bad_peb_count); + else if (attr == &dev_max_vol_count) + ret = sprintf(buf, "%d\n", ubi->vtbl_slots); + else if (attr == &dev_min_io_size) + ret = sprintf(buf, "%d\n", ubi->min_io_size); + else if (attr == &dev_bgt_enabled) + ret = sprintf(buf, "%d\n", ubi->thread_enabled); + else if (attr == &dev_mtd_num) + ret = sprintf(buf, "%d\n", ubi->mtd->index); + else + ret = -EINVAL; + + ubi_put_device(ubi); + return ret; +} + +/* Fake "release" method for UBI devices */ +static void dev_release(struct device *dev) { } + +/** + * ubi_sysfs_init - initialize sysfs for an UBI device. + * @ubi: UBI device description object + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +static int ubi_sysfs_init(struct ubi_device *ubi) +{ + int err; + + ubi->dev.release = dev_release; + ubi->dev.devt = ubi->cdev.dev; + ubi->dev.class = ubi_class; + sprintf(&ubi->dev.bus_id[0], UBI_NAME_STR"%d", ubi->ubi_num); + err = device_register(&ubi->dev); + if (err) + return err; + + err = device_create_file(&ubi->dev, &dev_eraseblock_size); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_avail_eraseblocks); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_total_eraseblocks); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_volumes_count); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_max_ec); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_reserved_for_bad); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_bad_peb_count); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_max_vol_count); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_min_io_size); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_bgt_enabled); + if (err) + return err; + err = device_create_file(&ubi->dev, &dev_mtd_num); + return err; +} + +/** + * ubi_sysfs_close - close sysfs for an UBI device. + * @ubi: UBI device description object + */ +static void ubi_sysfs_close(struct ubi_device *ubi) +{ + device_remove_file(&ubi->dev, &dev_mtd_num); + device_remove_file(&ubi->dev, &dev_bgt_enabled); + device_remove_file(&ubi->dev, &dev_min_io_size); + device_remove_file(&ubi->dev, &dev_max_vol_count); + device_remove_file(&ubi->dev, &dev_bad_peb_count); + device_remove_file(&ubi->dev, &dev_reserved_for_bad); + device_remove_file(&ubi->dev, &dev_max_ec); + device_remove_file(&ubi->dev, &dev_volumes_count); + device_remove_file(&ubi->dev, &dev_total_eraseblocks); + device_remove_file(&ubi->dev, &dev_avail_eraseblocks); + device_remove_file(&ubi->dev, &dev_eraseblock_size); + device_unregister(&ubi->dev); +} +#endif + +/** + * kill_volumes - destroy all volumes. + * @ubi: UBI device description object + */ +static void kill_volumes(struct ubi_device *ubi) +{ + int i; + + for (i = 0; i < ubi->vtbl_slots; i++) + if (ubi->volumes[i]) + ubi_free_volume(ubi, ubi->volumes[i]); +} + +/** + * uif_init - initialize user interfaces for an UBI device. + * @ubi: UBI device description object + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +static int uif_init(struct ubi_device *ubi) +{ + int i, err; +#ifdef UBI_LINUX + dev_t dev; +#endif + + sprintf(ubi->ubi_name, UBI_NAME_STR "%d", ubi->ubi_num); + + /* + * Major numbers for the UBI character devices are allocated + * dynamically. Major numbers of volume character devices are + * equivalent to ones of the corresponding UBI character device. Minor + * numbers of UBI character devices are 0, while minor numbers of + * volume character devices start from 1. Thus, we allocate one major + * number and ubi->vtbl_slots + 1 minor numbers. + */ + err = alloc_chrdev_region(&dev, 0, ubi->vtbl_slots + 1, ubi->ubi_name); + if (err) { + ubi_err("cannot register UBI character devices"); + return err; + } + + ubi_assert(MINOR(dev) == 0); + cdev_init(&ubi->cdev, &ubi_cdev_operations); + dbg_msg("%s major is %u", ubi->ubi_name, MAJOR(dev)); + ubi->cdev.owner = THIS_MODULE; + + err = cdev_add(&ubi->cdev, dev, 1); + if (err) { + ubi_err("cannot add character device"); + goto out_unreg; + } + + err = ubi_sysfs_init(ubi); + if (err) + goto out_sysfs; + + for (i = 0; i < ubi->vtbl_slots; i++) + if (ubi->volumes[i]) { + err = ubi_add_volume(ubi, ubi->volumes[i]); + if (err) { + ubi_err("cannot add volume %d", i); + goto out_volumes; + } + } + + return 0; + +out_volumes: + kill_volumes(ubi); +out_sysfs: + ubi_sysfs_close(ubi); + cdev_del(&ubi->cdev); +out_unreg: + unregister_chrdev_region(ubi->cdev.dev, ubi->vtbl_slots + 1); + ubi_err("cannot initialize UBI %s, error %d", ubi->ubi_name, err); + return err; +} + +/** + * uif_close - close user interfaces for an UBI device. + * @ubi: UBI device description object + */ +static void uif_close(struct ubi_device *ubi) +{ + kill_volumes(ubi); + ubi_sysfs_close(ubi); + cdev_del(&ubi->cdev); + unregister_chrdev_region(ubi->cdev.dev, ubi->vtbl_slots + 1); +} + +/** + * attach_by_scanning - attach an MTD device using scanning method. + * @ubi: UBI device descriptor + * + * This function returns zero in case of success and a negative error code in + * case of failure. + * + * Note, currently this is the only method to attach UBI devices. Hopefully in + * the future we'll have more scalable attaching methods and avoid full media + * scanning. But even in this case scanning will be needed as a fall-back + * attaching method if there are some on-flash table corruptions. + */ +static int attach_by_scanning(struct ubi_device *ubi) +{ + int err; + struct ubi_scan_info *si; + + si = ubi_scan(ubi); + if (IS_ERR(si)) + return PTR_ERR(si); + + ubi->bad_peb_count = si->bad_peb_count; + ubi->good_peb_count = ubi->peb_count - ubi->bad_peb_count; + ubi->max_ec = si->max_ec; + ubi->mean_ec = si->mean_ec; + + err = ubi_read_volume_table(ubi, si); + if (err) + goto out_si; + + err = ubi_wl_init_scan(ubi, si); + if (err) + goto out_vtbl; + + err = ubi_eba_init_scan(ubi, si); + if (err) + goto out_wl; + + ubi_scan_destroy_si(si); + return 0; + +out_wl: + ubi_wl_close(ubi); +out_vtbl: + vfree(ubi->vtbl); +out_si: + ubi_scan_destroy_si(si); + return err; +} + +/** + * io_init - initialize I/O unit for a given UBI device. + * @ubi: UBI device description object + * + * If @ubi->vid_hdr_offset or @ubi->leb_start is zero, default offsets are + * assumed: + * o EC header is always at offset zero - this cannot be changed; + * o VID header starts just after the EC header at the closest address + * aligned to @io->hdrs_min_io_size; + * o data starts just after the VID header at the closest address aligned to + * @io->min_io_size + * + * This function returns zero in case of success and a negative error code in + * case of failure. + */ +static int io_init(struct ubi_device *ubi) +{ + if (ubi->mtd->numeraseregions != 0) { + /* + * Some flashes have several erase regions. Different regions + * may have different eraseblock size and other + * characteristics. It looks like mostly multi-region flashes + * have one "main" region and one or more small regions to + * store boot loader code or boot parameters or whatever. I + * guess we should just pick the largest region. But this is + * not implemented. + */ + ubi_err("multiple regions, not implemented"); + return -EINVAL; + } + + if (ubi->vid_hdr_offset < 0) + return -EINVAL; + + /* + * Note, in this implementation we support MTD devices with 0x7FFFFFFF + * physical eraseblocks maximum. + */ + + ubi->peb_size = ubi->mtd->erasesize; + ubi->peb_count = ubi->mtd->size / ubi->mtd->erasesize; + ubi->flash_size = ubi->mtd->size; + + if (ubi->mtd->block_isbad && ubi->mtd->block_markbad) + ubi->bad_allowed = 1; + + ubi->min_io_size = ubi->mtd->writesize; + ubi->hdrs_min_io_size = ubi->mtd->writesize >> ubi->mtd->subpage_sft; + + /* + * Make sure minimal I/O unit is power of 2. Note, there is no + * fundamental reason for this assumption. It is just an optimization + * which allows us to avoid costly division operations. + */ + if (!is_power_of_2(ubi->min_io_size)) { + ubi_err("min. I/O unit (%d) is not power of 2", + ubi->min_io_size); + return -EINVAL; + } + + ubi_assert(ubi->hdrs_min_io_size > 0); + ubi_assert(ubi->hdrs_min_io_size <= ubi->min_io_size); + ubi_assert(ubi->min_io_size % ubi->hdrs_min_io_size == 0); + + /* Calculate default aligned sizes of EC and VID headers */ + ubi->ec_hdr_alsize = ALIGN(UBI_EC_HDR_SIZE, ubi->hdrs_min_io_size); + ubi->vid_hdr_alsize = ALIGN(UBI_VID_HDR_SIZE, ubi->hdrs_min_io_size); + + dbg_msg("min_io_size %d", ubi->min_io_size); + dbg_msg("hdrs_min_io_size %d", ubi->hdrs_min_io_size); + dbg_msg("ec_hdr_alsize %d", ubi->ec_hdr_alsize); + dbg_msg("vid_hdr_alsize %d", ubi->vid_hdr_alsize); + + if (ubi->vid_hdr_offset == 0) + /* Default offset */ + ubi->vid_hdr_offset = ubi->vid_hdr_aloffset = + ubi->ec_hdr_alsize; + else { + ubi->vid_hdr_aloffset = ubi->vid_hdr_offset & + ~(ubi->hdrs_min_io_size - 1); + ubi->vid_hdr_shift = ubi->vid_hdr_offset - + ubi->vid_hdr_aloffset; + } + + /* Similar for the data offset */ + ubi->leb_start = ubi->vid_hdr_offset + UBI_EC_HDR_SIZE; + ubi->leb_start = ALIGN(ubi->leb_start, ubi->min_io_size); + + dbg_msg("vid_hdr_offset %d", ubi->vid_hdr_offset); + dbg_msg("vid_hdr_aloffset %d", ubi->vid_hdr_aloffset); + dbg_msg("vid_hdr_shift %d", ubi->vid_hdr_shift); + dbg_msg("leb_start %d", ubi->leb_start); + + /* The shift must be aligned to 32-bit boundary */ + if (ubi->vid_hdr_shift % 4) { + ubi_err("unaligned VID header shift %d", + ubi->vid_hdr_shift); + return -EINVAL; + } + + /* Check sanity */ + if (ubi->vid_hdr_offset < UBI_EC_HDR_SIZE || + ubi->leb_start < ubi->vid_hdr_offset + UBI_VID_HDR_SIZE || + ubi->leb_start > ubi->peb_size - UBI_VID_HDR_SIZE || + ubi->leb_start & (ubi->min_io_size - 1)) { + ubi_err("bad VID header (%d) or data offsets (%d)", + ubi->vid_hdr_offset, ubi->leb_start); + return -EINVAL; + } + + /* + * It may happen that EC and VID headers are situated in one minimal + * I/O unit. In this case we can only accept this UBI image in + * read-only mode. + */ + if (ubi->vid_hdr_offset + UBI_VID_HDR_SIZE <= ubi->hdrs_min_io_size) { + ubi_warn("EC and VID headers are in the same minimal I/O unit, " + "switch to read-only mode"); + ubi->ro_mode = 1; + } + + ubi->leb_size = ubi->peb_size - ubi->leb_start; + + if (!(ubi->mtd->flags & MTD_WRITEABLE)) { + ubi_msg("MTD device %d is write-protected, attach in " + "read-only mode", ubi->mtd->index); + ubi->ro_mode = 1; + } + + ubi_msg("physical eraseblock size: %d bytes (%d KiB)", + ubi->peb_size, ubi->peb_size >> 10); + ubi_msg("logical eraseblock size: %d bytes", ubi->leb_size); + ubi_msg("smallest flash I/O unit: %d", ubi->min_io_size); + if (ubi->hdrs_min_io_size != ubi->min_io_size) + ubi_msg("sub-page size: %d", + ubi->hdrs_min_io_size); + ubi_msg("VID header offset: %d (aligned %d)", + ubi->vid_hdr_offset, ubi->vid_hdr_aloffset); + ubi_msg("data offset: %d", ubi->leb_start); + + /* + * Note, ideally, we have to initialize ubi->bad_peb_count here. But + * unfortunately, MTD does not provide this information. We should loop + * over all physical eraseblocks and invoke mtd->block_is_bad() for + * each physical eraseblock. So, we skip ubi->bad_peb_count + * uninitialized and initialize it after scanning. + */ + + return 0; +} + +/** + * autoresize - re-size the volume which has the "auto-resize" flag set. + * @ubi: UBI device description object + * @vol_id: ID of the volume to re-size + * + * This function re-sizes the volume marked by the @UBI_VTBL_AUTORESIZE_FLG in + * the volume table to the largest possible size. See comments in ubi-header.h + * for more description of the flag. Returns zero in case of success and a + * negative error code in case of failure. + */ +static int autoresize(struct ubi_device *ubi, int vol_id) +{ + struct ubi_volume_desc desc; + struct ubi_volume *vol = ubi->volumes[vol_id]; + int err, old_reserved_pebs = vol->reserved_pebs; + + /* + * Clear the auto-resize flag in the volume in-memory copy of the + * volume table, and 'ubi_resize_volume()' will propogate this change + * to the flash. + */ + ubi->vtbl[vol_id].flags &= ~UBI_VTBL_AUTORESIZE_FLG; + + if (ubi->avail_pebs == 0) { + struct ubi_vtbl_record vtbl_rec; + + /* + * No avalilable PEBs to re-size the volume, clear the flag on + * flash and exit. + */ + memcpy(&vtbl_rec, &ubi->vtbl[vol_id], + sizeof(struct ubi_vtbl_record)); + err = ubi_change_vtbl_record(ubi, vol_id, &vtbl_rec); + if (err) + ubi_err("cannot clean auto-resize flag for volume %d", + vol_id); + } else { + desc.vol = vol; + err = ubi_resize_volume(&desc, + old_reserved_pebs + ubi->avail_pebs); + if (err) + ubi_err("cannot auto-resize volume %d", vol_id); + } + + if (err) + return err; + + ubi_msg("volume %d ("%s") re-sized from %d to %d LEBs", vol_id, + vol->name, old_reserved_pebs, vol->reserved_pebs); + return 0; +} + +/** + * ubi_attach_mtd_dev - attach an MTD device. + * @mtd_dev: MTD device description object + * @ubi_num: number to assign to the new UBI device + * @vid_hdr_offset: VID header offset + * + * This function attaches MTD device @mtd_dev to UBI and assign @ubi_num number + * to the newly created UBI device, unless @ubi_num is %UBI_DEV_NUM_AUTO, in + * which case this function finds a vacant device nubert and assings it + * automatically. Returns the new UBI device number in case of success and a + * negative error code in case of failure. + * + * Note, the invocations of this function has to be serialized by the + * @ubi_devices_mutex. + */ +int ubi_attach_mtd_dev(struct mtd_info *mtd, int ubi_num, int vid_hdr_offset) +{ + struct ubi_device *ubi; + int i, err; + + /* + * Check if we already have the same MTD device attached. + * + * Note, this function assumes that UBI devices creations and deletions + * are serialized, so it does not take the &ubi_devices_lock. + */ + for (i = 0; i < UBI_MAX_DEVICES; i++) { + ubi = ubi_devices[i]; + if (ubi && mtd->index == ubi->mtd->index) { + dbg_err("mtd%d is already attached to ubi%d", + mtd->index, i); + return -EEXIST; + } + } + + /* + * Make sure this MTD device is not emulated on top of an UBI volume + * already. Well, generally this recursion works fine, but there are + * different problems like the UBI module takes a reference to itself + * by attaching (and thus, opening) the emulated MTD device. This + * results in inability to unload the module. And in general it makes + * no sense to attach emulated MTD devices, so we prohibit this. + */ + if (mtd->type == MTD_UBIVOLUME) { + ubi_err("refuse attaching mtd%d - it is already emulated on " + "top of UBI", mtd->index); + return -EINVAL; + } + + if (ubi_num == UBI_DEV_NUM_AUTO) { + /* Search for an empty slot in the @ubi_devices array */ + for (ubi_num = 0; ubi_num < UBI_MAX_DEVICES; ubi_num++) + if (!ubi_devices[ubi_num]) + break; + if (ubi_num == UBI_MAX_DEVICES) { + dbg_err("only %d UBI devices may be created", UBI_MAX_DEVICES); + return -ENFILE; + } + } else { + if (ubi_num >= UBI_MAX_DEVICES) + return -EINVAL; + + /* Make sure ubi_num is not busy */ + if (ubi_devices[ubi_num]) { + dbg_err("ubi%d already exists", ubi_num); + return -EEXIST; + } + } + + ubi = kzalloc(sizeof(struct ubi_device), GFP_KERNEL); + if (!ubi) + return -ENOMEM; + + ubi->mtd = mtd; + ubi->ubi_num = ubi_num; + ubi->vid_hdr_offset = vid_hdr_offset; + ubi->autoresize_vol_id = -1; + + mutex_init(&ubi->buf_mutex); + mutex_init(&ubi->ckvol_mutex); + mutex_init(&ubi->volumes_mutex); + spin_lock_init(&ubi->volumes_lock); + + ubi_msg("attaching mtd%d to ubi%d", mtd->index, ubi_num); + + err = io_init(ubi); + if (err) + goto out_free; + + ubi->peb_buf1 = vmalloc(ubi->peb_size); + if (!ubi->peb_buf1) + goto out_free; + + ubi->peb_buf2 = vmalloc(ubi->peb_size); + if (!ubi->peb_buf2) + goto out_free; + +#ifdef CONFIG_MTD_UBI_DEBUG + mutex_init(&ubi->dbg_buf_mutex); + ubi->dbg_peb_buf = vmalloc(ubi->peb_size); + if (!ubi->dbg_peb_buf) + goto out_free; +#endif + + err = attach_by_scanning(ubi); + if (err) { + dbg_err("failed to attach by scanning, error %d", err); + goto out_free; + } + + if (ubi->autoresize_vol_id != -1) { + err = autoresize(ubi, ubi->autoresize_vol_id); + if (err) + goto out_detach; + } + + err = uif_init(ubi); + if (err) + goto out_detach; + + ubi->bgt_thread = kthread_create(ubi_thread, ubi, ubi->bgt_name); + if (IS_ERR(ubi->bgt_thread)) { + err = PTR_ERR(ubi->bgt_thread); + ubi_err("cannot spawn "%s", error %d", ubi->bgt_name, + err); + goto out_uif; + } + + ubi_msg("attached mtd%d to ubi%d", mtd->index, ubi_num); + ubi_msg("MTD device name: "%s"", mtd->name); + ubi_msg("MTD device size: %llu MiB", ubi->flash_size >> 20); + ubi_msg("number of good PEBs: %d", ubi->good_peb_count); + ubi_msg("number of bad PEBs: %d", ubi->bad_peb_count); + ubi_msg("max. allowed volumes: %d", ubi->vtbl_slots); + ubi_msg("wear-leveling threshold: %d", CONFIG_MTD_UBI_WL_THRESHOLD); + ubi_msg("number of internal volumes: %d", UBI_INT_VOL_COUNT); + ubi_msg("number of user volumes: %d", + ubi->vol_count - UBI_INT_VOL_COUNT); + ubi_msg("available PEBs: %d", ubi->avail_pebs); + ubi_msg("total number of reserved PEBs: %d", ubi->rsvd_pebs); + ubi_msg("number of PEBs reserved for bad PEB handling: %d", + ubi->beb_rsvd_pebs); + ubi_msg("max/mean erase counter: %d/%d", ubi->max_ec, ubi->mean_ec); + + /* Enable the background thread */ + if (!DBG_DISABLE_BGT) { + ubi->thread_enabled = 1; + wake_up_process(ubi->bgt_thread); + } + + ubi_devices[ubi_num] = ubi; + return ubi_num; + +out_uif: + uif_close(ubi); +out_detach: + ubi_eba_close(ubi); + ubi_wl_close(ubi); + vfree(ubi->vtbl); +out_free: + vfree(ubi->peb_buf1); + vfree(ubi->peb_buf2); +#ifdef CONFIG_MTD_UBI_DEBUG + vfree(ubi->dbg_peb_buf); +#endif + kfree(ubi); + return err; +} + +/** + * ubi_detach_mtd_dev - detach an MTD device. + * @ubi_num: UBI device number to detach from + * @anyway: detach MTD even if device reference count is not zero + * + * This function destroys an UBI device number @ubi_num and detaches the + * underlying MTD device. Returns zero in case of success and %-EBUSY if the + * UBI device is busy and cannot be destroyed, and %-EINVAL if it does not + * exist. + * + * Note, the invocations of this function has to be serialized by the + * @ubi_devices_mutex. + */ +int ubi_detach_mtd_dev(int ubi_num, int anyway) +{ + struct ubi_device *ubi; + + if (ubi_num < 0 || ubi_num >= UBI_MAX_DEVICES) + return -EINVAL; + + spin_lock(&ubi_devices_lock); + ubi = ubi_devices[ubi_num]; + if (!ubi) { + spin_unlock(&ubi_devices_lock); + return -EINVAL; + } + + if (ubi->ref_count) { + if (!anyway) { + spin_unlock(&ubi_devices_lock); + return -EBUSY; + } + /* This may only happen if there is a bug */ + ubi_err("%s reference count %d, destroy anyway", + ubi->ubi_name, ubi->ref_count); + } + ubi_devices[ubi_num] = NULL; + spin_unlock(&ubi_devices_lock); + + ubi_assert(ubi_num == ubi->ubi_num); + dbg_msg("detaching mtd%d from ubi%d", ubi->mtd->index, ubi_num); + + /* + * Before freeing anything, we have to stop the background thread to + * prevent it from doing anything on this device while we are freeing. + */ + if (ubi->bgt_thread) + kthread_stop(ubi->bgt_thread); + + uif_close(ubi); + ubi_eba_close(ubi); + ubi_wl_close(ubi); + vfree(ubi->vtbl); + put_mtd_device(ubi->mtd); + vfree(ubi->peb_buf1); + vfree(ubi->peb_buf2); +#ifdef CONFIG_MTD_UBI_DEBUG + vfree(ubi->dbg_peb_buf); +#endif + ubi_msg("mtd%d is detached from ubi%d", ubi->mtd->index, ubi->ubi_num); + kfree(ubi); + return 0; +} + +/** + * find_mtd_device - open an MTD device by its name or number. + * @mtd_dev: name or number of the device + * + * This function tries to open and MTD device described by @mtd_dev string, + * which is first treated as an ASCII number, and if it is not true, it is + * treated as MTD device name. Returns MTD device description object in case of + * success and a negative error code in case of failure. + */ +static struct mtd_info * __init open_mtd_device(const char *mtd_dev) +{ + struct mtd_info *mtd; + int mtd_num; + char *endp; + + mtd_num = simple_strtoul(mtd_dev, &endp, 0); + if (*endp != '\0' || mtd_dev == endp) { + /* + * This does not look like an ASCII integer, probably this is + * MTD device name. + */ + mtd = get_mtd_device_nm(mtd_dev); + } else + mtd = get_mtd_device(NULL, mtd_num); + + return mtd; +} + +int __init ubi_init(void) +{ + int err, i, k; + + /* Ensure that EC and VID headers have correct size */ + BUILD_BUG_ON(sizeof(struct ubi_ec_hdr) != 64); + BUILD_BUG_ON(sizeof(struct ubi_vid_hdr) != 64); + + if (mtd_devs > UBI_MAX_DEVICES) { + ubi_err("too many MTD devices, maximum is %d", UBI_MAX_DEVICES); + return -EINVAL; + } + + /* Create base sysfs directory and sysfs files */ + ubi_class = class_create(THIS_MODULE, UBI_NAME_STR); + if (IS_ERR(ubi_class)) { + err = PTR_ERR(ubi_class); + ubi_err("cannot create UBI class"); + goto out; + } + + err = class_create_file(ubi_class, &ubi_version); + if (err) { + ubi_err("cannot create sysfs file"); + goto out_class; + } + + err = misc_register(&ubi_ctrl_cdev); + if (err) { + ubi_err("cannot register device"); + goto out_version; + } + +#ifdef UBI_LINUX + ubi_wl_entry_slab = kmem_cache_create("ubi_wl_entry_slab", + sizeof(struct ubi_wl_entry), + 0, 0, NULL); + if (!ubi_wl_entry_slab) + goto out_dev_unreg; +#endif + + /* Attach MTD devices */ + for (i = 0; i < mtd_devs; i++) { + struct mtd_dev_param *p = &mtd_dev_param[i]; + struct mtd_info *mtd; + + cond_resched(); + + mtd = open_mtd_device(p->name); + if (IS_ERR(mtd)) { + err = PTR_ERR(mtd); + goto out_detach; + } + + mutex_lock(&ubi_devices_mutex); + err = ubi_attach_mtd_dev(mtd, UBI_DEV_NUM_AUTO, + p->vid_hdr_offs); + mutex_unlock(&ubi_devices_mutex); + if (err < 0) { + put_mtd_device(mtd); + ubi_err("cannot attach mtd%d", mtd->index); + goto out_detach; + } + } + + return 0; + +out_detach: + for (k = 0; k < i; k++) + if (ubi_devices[k]) { + mutex_lock(&ubi_devices_mutex); + ubi_detach_mtd_dev(ubi_devices[k]->ubi_num, 1); + mutex_unlock(&ubi_devices_mutex); + } +#ifdef UBI_LINUX + kmem_cache_destroy(ubi_wl_entry_slab); +out_dev_unreg: +#endif + misc_deregister(&ubi_ctrl_cdev); +out_version: + class_remove_file(ubi_class, &ubi_version); +out_class: + class_destroy(ubi_class); +out: + ubi_err("UBI error: cannot initialize UBI, error %d", err); + return err; +} +module_init(ubi_init); + +void __exit ubi_exit(void) +{ + int i; + + for (i = 0; i < UBI_MAX_DEVICES; i++) + if (ubi_devices[i]) { + mutex_lock(&ubi_devices_mutex); + ubi_detach_mtd_dev(ubi_devices[i]->ubi_num, 1); + mutex_unlock(&ubi_devices_mutex); + } + kmem_cache_destroy(ubi_wl_entry_slab); + misc_deregister(&ubi_ctrl_cdev); + class_remove_file(ubi_class, &ubi_version); + class_destroy(ubi_class); +} +module_exit(ubi_exit); + +/** + * bytes_str_to_int - convert a string representing number of bytes to an + * integer. + * @str: the string to convert + * + * This function returns positive resulting integer in case of success and a + * negative error code in case of failure. + */ +static int __init bytes_str_to_int(const char *str) +{ + char *endp; + unsigned long result; + + result = simple_strtoul(str, &endp, 0); + if (str == endp || result < 0) { + printk(KERN_ERR "UBI error: incorrect bytes count: "%s"\n", + str); + return -EINVAL; + } + + switch (*endp) { + case 'G': + result *= 1024; + case 'M': + result *= 1024; + case 'K': + result *= 1024; + if (endp[1] == 'i' && endp[2] == 'B') + endp += 2; + case '\0': + break; + default: + printk(KERN_ERR "UBI error: incorrect bytes count: "%s"\n", + str); + return -EINVAL; + } + + return result; +} + +/** + * ubi_mtd_param_parse - parse the 'mtd=' UBI parameter. + * @val: the parameter value to parse + * @kp: not used + * + * This function returns zero in case of success and a negative error code in + * case of error. + */ +int __init ubi_mtd_param_parse(const char *val, struct kernel_param *kp) +{ + int i, len; + struct mtd_dev_param *p; + char buf[MTD_PARAM_LEN_MAX]; + char *pbuf = &buf[0]; + char *tokens[2] = {NULL, NULL}; + + if (!val) + return -EINVAL; + + if (mtd_devs == UBI_MAX_DEVICES) { + printk(KERN_ERR "UBI error: too many parameters, max. is %d\n", + UBI_MAX_DEVICES); + return -EINVAL; + } + + len = strnlen(val, MTD_PARAM_LEN_MAX); + if (len == MTD_PARAM_LEN_MAX) { + printk(KERN_ERR "UBI error: parameter "%s" is too long, " + "max. is %d\n", val, MTD_PARAM_LEN_MAX); + return -EINVAL; + } + + if (len == 0) { + printk(KERN_WARNING "UBI warning: empty 'mtd=' parameter - " + "ignored\n"); + return 0; + } + + strcpy(buf, val); + + /* Get rid of the final newline */ + if (buf[len - 1] == '\n') + buf[len - 1] = '\0'; + + for (i = 0; i < 2; i++) + tokens[i] = strsep(&pbuf, ","); + + if (pbuf) { + printk(KERN_ERR "UBI error: too many arguments at "%s"\n", + val); + return -EINVAL; + } + + p = &mtd_dev_param[mtd_devs]; + strcpy(&p->name[0], tokens[0]); + + if (tokens[1]) + p->vid_hdr_offs = bytes_str_to_int(tokens[1]); + + if (p->vid_hdr_offs < 0) + return p->vid_hdr_offs; + + mtd_devs += 1; + return 0; +} + +module_param_call(mtd, ubi_mtd_param_parse, NULL, NULL, 000); +MODULE_PARM_DESC(mtd, "MTD devices to attach. Parameter format: " + "mtd=<name|num>[,<vid_hdr_offs>].\n" + "Multiple "mtd" parameters may be specified.\n" + "MTD devices may be specified by their number or name.\n" + "Optional "vid_hdr_offs" parameter specifies UBI VID " + "header position and data starting position to be used " + "by UBI.\n" + "Example: mtd=content,1984 mtd=4 - attach MTD device" + "with name "content" using VID header offset 1984, and " + "MTD device number 4 with default VID header offset."); + +MODULE_VERSION(__stringify(UBI_VERSION)); +MODULE_DESCRIPTION("UBI - Unsorted Block Images"); +MODULE_AUTHOR("Artem Bityutskiy"); +MODULE_LICENSE("GPL"); diff --git a/drivers/mtd/ubi/crc32.c b/drivers/mtd/ubi/crc32.c new file mode 100644 index 0000000..b57a7db --- /dev/null +++ b/drivers/mtd/ubi/crc32.c @@ -0,0 +1,512 @@ +/* + * Oct 15, 2000 Matt Domsch Matt_Domsch@dell.com + * Nicer crc32 functions/docs submitted by linux@horizon.com. Thanks! + * Code was from the public domain, copyright abandoned. Code was + * subsequently included in the kernel, thus was re-licensed under the + * GNU GPL v2. + * + * Oct 12, 2000 Matt Domsch Matt_Domsch@dell.com + * Same crc32 function was used in 5 other places in the kernel. + * I made one version, and deleted the others. + * There are various incantations of crc32(). Some use a seed of 0 or ~0. + * Some xor at the end with ~0. The generic crc32() function takes + * seed as an argument, and doesn't xor at the end. Then individual + * users can do whatever they need. + * drivers/net/smc9194.c uses seed ~0, doesn't xor with ~0. + * fs/jffs2 uses seed 0, doesn't xor with ~0. + * fs/partitions/efi.c uses seed ~0, xor's with ~0. + * + * This source code is licensed under the GNU General Public License, + * Version 2. See the file COPYING for more details. + */ + +#ifdef UBI_LINUX +#include <linux/crc32.h> +#include <linux/kernel.h> +#include <linux/module.h> +#include <linux/compiler.h> +#endif +#include <linux/types.h> + +#include <asm/byteorder.h> + +#ifdef UBI_LINUX +#include <linux/slab.h> +#include <linux/init.h> +#include <asm/atomic.h> +#endif +#include "crc32defs.h" +#define CRC_LE_BITS 8 + +# define __force +#ifndef __constant_cpu_to_le32 +#define __constant_cpu_to_le32(x) ((__force __le32)(__u32)(x)) +#endif +#ifndef __constant_le32_to_cpu +#define __constant_le32_to_cpu(x) ((__force __u32)(__le32)(x)) +#endif + +#if CRC_LE_BITS == 8 +#define tole(x) __constant_cpu_to_le32(x) +#define tobe(x) __constant_cpu_to_be32(x) +#else +#define tole(x) (x) +#define tobe(x) (x) +#endif +#include "crc32table.h" +#ifdef UBI_LINUX +MODULE_AUTHOR("Matt Domsch Matt_Domsch@dell.com"); +MODULE_DESCRIPTION("Ethernet CRC32 calculations"); +MODULE_LICENSE("GPL"); +#endif +/** + * crc32_le() - Calculate bitwise little-endian Ethernet AUTODIN II CRC32 + * @crc: seed value for computation. ~0 for Ethernet, sometimes 0 for + * other uses, or the previous crc32 value if computing incrementally. + * @p: pointer to buffer over which CRC is run + * @len: length of buffer @p + */ +u32 crc32_le(u32 crc, unsigned char const *p, size_t len); + +#if CRC_LE_BITS == 1 +/* + * In fact, the table-based code will work in this case, but it can be + * simplified by inlining the table in ?: form. + */ + +u32 crc32_le(u32 crc, unsigned char const *p, size_t len) +{ + int i; + while (len--) { + crc ^= *p++; + for (i = 0; i < 8; i++) + crc = (crc >> 1) ^ ((crc & 1) ? CRCPOLY_LE : 0); + } + return crc; +} +#else /* Table-based approach */ + +u32 crc32_le(u32 crc, unsigned char const *p, size_t len) +{ +# if CRC_LE_BITS == 8 + const u32 *b = (u32 *) p; + const u32 *tab = crc32table_le; + +# ifdef __LITTLE_ENDIAN +# define DO_CRC(x) (crc = tab[(crc ^ (x)) & 255] ^ (crc>>8)) +# else +# define DO_CRC(x) (crc = tab[((crc >> 24) ^ (x)) & 255] ^ (crc<<8)) +# endif + crc = __cpu_to_le32(crc); + /* Align it */ + if ((((long)b) & 3 && len)) { + do { + u8 *p = (u8 *) b; + DO_CRC(*p++); + b = (void *)p; + } while ((--len) && ((long)b) & 3); + } + if ((len >= 4)) { + /* load data 32 bits wide, xor data 32 bits wide. */ + size_t save_len = len & 3; + len = len >> 2; + --b; /* use pre increment below(*++b) for speed */ + do { + crc ^= *++b; + DO_CRC(0); + DO_CRC(0); + DO_CRC(0); + DO_CRC(0); + } while (--len); + b++; /* point to next byte(s) */ + len = save_len; + } + /* And the last few bytes */ + if (len) { + do { + u8 *p = (u8 *) b; + DO_CRC(*p++); + b = (void *)p; + } while (--len); + } + + return __le32_to_cpu(crc); +#undef ENDIAN_SHIFT +#undef DO_CRC + +# elif CRC_LE_BITS == 4 + while (len--) { + crc ^= *p++; + crc = (crc >> 4) ^ crc32table_le[crc & 15]; + crc = (crc >> 4) ^ crc32table_le[crc & 15]; + } + return crc; +# elif CRC_LE_BITS == 2 + while (len--) { + crc ^= *p++; + crc = (crc >> 2) ^ crc32table_le[crc & 3]; + crc = (crc >> 2) ^ crc32table_le[crc & 3]; + crc = (crc >> 2) ^ crc32table_le[crc & 3]; + crc = (crc >> 2) ^ crc32table_le[crc & 3]; + } + return crc; +# endif +} +#endif +#ifdef UBI_LINUX +/** + * crc32_be() - Calculate bitwise big-endian Ethernet AUTODIN II CRC32 + * @crc: seed value for computation. ~0 for Ethernet, sometimes 0 for + * other uses, or the previous crc32 value if computing incrementally. + * @p: pointer to buffer over which CRC is run + * @len: length of buffer @p + */ +u32 __attribute_pure__ crc32_be(u32 crc, unsigned char const *p, size_t len); + +#if CRC_BE_BITS == 1 +/* + * In fact, the table-based code will work in this case, but it can be + * simplified by inlining the table in ?: form. + */ + +u32 __attribute_pure__ crc32_be(u32 crc, unsigned char const *p, size_t len) +{ + int i; + while (len--) { + crc ^= *p++ << 24; + for (i = 0; i < 8; i++) + crc = + (crc << 1) ^ ((crc & 0x80000000) ? CRCPOLY_BE : 0); + } + return crc; +} + +#else /* Table-based approach */ +u32 __attribute_pure__ crc32_be(u32 crc, unsigned char const *p, size_t len) +{ +# if CRC_BE_BITS == 8 + const u32 *b = (u32 *) p; + const u32 *tab = crc32table_be; + +# ifdef __LITTLE_ENDIAN +# define DO_CRC(x) (crc = tab[(crc ^ (x)) & 255] ^ (crc>>8)) +# else +# define DO_CRC(x) (crc = tab[((crc >> 24) ^ (x)) & 255] ^ (crc<<8)) +# endif + + crc = __cpu_to_be32(crc); + /* Align it */ + if (unlikely(((long)b) & 3 && len)) { + do { + u8 *p = (u8 *) b; + DO_CRC(*p++); + b = (u32 *) p; + } while ((--len) && ((long)b) & 3); + } + if (likely(len >= 4)) { + /* load data 32 bits wide, xor data 32 bits wide. */ + size_t save_len = len & 3; + len = len >> 2; + --b; /* use pre increment below(*++b) for speed */ + do { + crc ^= *++b; + DO_CRC(0); + DO_CRC(0); + DO_CRC(0); + DO_CRC(0); + } while (--len); + b++; /* point to next byte(s) */ + len = save_len; + } + /* And the last few bytes */ + if (len) { + do { + u8 *p = (u8 *) b; + DO_CRC(*p++); + b = (void *)p; + } while (--len); + } + return __be32_to_cpu(crc); +#undef ENDIAN_SHIFT +#undef DO_CRC + +# elif CRC_BE_BITS == 4 + while (len--) { + crc ^= *p++ << 24; + crc = (crc << 4) ^ crc32table_be[crc >> 28]; + crc = (crc << 4) ^ crc32table_be[crc >> 28]; + } + return crc; +# elif CRC_BE_BITS == 2 + while (len--) { + crc ^= *p++ << 24; + crc = (crc << 2) ^ crc32table_be[crc >> 30]; + crc = (crc << 2) ^ crc32table_be[crc >> 30]; + crc = (crc << 2) ^ crc32table_be[crc >> 30]; + crc = (crc << 2) ^ crc32table_be[crc >> 30]; + } + return crc; +# endif +} +#endif + +EXPORT_SYMBOL(crc32_le); +EXPORT_SYMBOL(crc32_be); +#endif +/* + * A brief CRC tutorial. + * + * A CRC is a long-division remainder. You add the CRC to the message, + * and the whole thing (message+CRC) is a multiple of the given + * CRC polynomial. To check the CRC, you can either check that the + * CRC matches the recomputed value, *or* you can check that the + * remainder computed on the message+CRC is 0. This latter approach + * is used by a lot of hardware implementations, and is why so many + * protocols put the end-of-frame flag after the CRC. + * + * It's actually the same long division you learned in school, except that + * - We're working in binary, so the digits are only 0 and 1, and + * - When dividing polynomials, there are no carries. Rather than add and + * subtract, we just xor. Thus, we tend to get a bit sloppy about + * the difference between adding and subtracting. + * + * A 32-bit CRC polynomial is actually 33 bits long. But since it's + * 33 bits long, bit 32 is always going to be set, so usually the CRC + * is written in hex with the most significant bit omitted. (If you're + * familiar with the IEEE 754 floating-point format, it's the same idea.) + * + * Note that a CRC is computed over a string of *bits*, so you have + * to decide on the endianness of the bits within each byte. To get + * the best error-detecting properties, this should correspond to the + * order they're actually sent. For example, standard RS-232 serial is + * little-endian; the most significant bit (sometimes used for parity) + * is sent last. And when appending a CRC word to a message, you should + * do it in the right order, matching the endianness. + * + * Just like with ordinary division, the remainder is always smaller than + * the divisor (the CRC polynomial) you're dividing by. Each step of the + * division, you take one more digit (bit) of the dividend and append it + * to the current remainder. Then you figure out the appropriate multiple + * of the divisor to subtract to being the remainder back into range. + * In binary, it's easy - it has to be either 0 or 1, and to make the + * XOR cancel, it's just a copy of bit 32 of the remainder. + * + * When computing a CRC, we don't care about the quotient, so we can + * throw the quotient bit away, but subtract the appropriate multiple of + * the polynomial from the remainder and we're back to where we started, + * ready to process the next bit. + * + * A big-endian CRC written this way would be coded like: + * for (i = 0; i < input_bits; i++) { + * multiple = remainder & 0x80000000 ? CRCPOLY : 0; + * remainder = (remainder << 1 | next_input_bit()) ^ multiple; + * } + * Notice how, to get at bit 32 of the shifted remainder, we look + * at bit 31 of the remainder *before* shifting it. + * + * But also notice how the next_input_bit() bits we're shifting into + * the remainder don't actually affect any decision-making until + * 32 bits later. Thus, the first 32 cycles of this are pretty boring. + * Also, to add the CRC to a message, we need a 32-bit-long hole for it at + * the end, so we have to add 32 extra cycles shifting in zeros at the + * end of every message, + * + * So the standard trick is to rearrage merging in the next_input_bit() + * until the moment it's needed. Then the first 32 cycles can be precomputed, + * and merging in the final 32 zero bits to make room for the CRC can be + * skipped entirely. + * This changes the code to: + * for (i = 0; i < input_bits; i++) { + * remainder ^= next_input_bit() << 31; + * multiple = (remainder & 0x80000000) ? CRCPOLY : 0; + * remainder = (remainder << 1) ^ multiple; + * } + * With this optimization, the little-endian code is simpler: + * for (i = 0; i < input_bits; i++) { + * remainder ^= next_input_bit(); + * multiple = (remainder & 1) ? CRCPOLY : 0; + * remainder = (remainder >> 1) ^ multiple; + * } + * + * Note that the other details of endianness have been hidden in CRCPOLY + * (which must be bit-reversed) and next_input_bit(). + * + * However, as long as next_input_bit is returning the bits in a sensible + * order, we can actually do the merging 8 or more bits at a time rather + * than one bit at a time: + * for (i = 0; i < input_bytes; i++) { + * remainder ^= next_input_byte() << 24; + * for (j = 0; j < 8; j++) { + * multiple = (remainder & 0x80000000) ? CRCPOLY : 0; + * remainder = (remainder << 1) ^ multiple; + * } + * } + * Or in little-endian: + * for (i = 0; i < input_bytes; i++) { + * remainder ^= next_input_byte(); + * for (j = 0; j < 8; j++) { + * multiple = (remainder & 1) ? CRCPOLY : 0; + * remainder = (remainder << 1) ^ multiple; + * } + * } + * If the input is a multiple of 32 bits, you can even XOR in a 32-bit + * word at a time and increase the inner loop count to 32. + * + * You can also mix and match the two loop styles, for example doing the + * bulk of a message byte-at-a-time and adding bit-at-a-time processing + * for any fractional bytes at the end. + * + * The only remaining optimization is to the byte-at-a-time table method. + * Here, rather than just shifting one bit of the remainder to decide + * in the correct multiple to subtract, we can shift a byte at a time. + * This produces a 40-bit (rather than a 33-bit) intermediate remainder, + * but again the multiple of the polynomial to subtract depends only on + * the high bits, the high 8 bits in this case. + * + * The multile we need in that case is the low 32 bits of a 40-bit + * value whose high 8 bits are given, and which is a multiple of the + * generator polynomial. This is simply the CRC-32 of the given + * one-byte message. + * + * Two more details: normally, appending zero bits to a message which + * is already a multiple of a polynomial produces a larger multiple of that + * polynomial. To enable a CRC to detect this condition, it's common to + * invert the CRC before appending it. This makes the remainder of the + * message+crc come out not as zero, but some fixed non-zero value. + * + * The same problem applies to zero bits prepended to the message, and + * a similar solution is used. Instead of starting with a remainder of + * 0, an initial remainder of all ones is used. As long as you start + * the same way on decoding, it doesn't make a difference. + */ + +#ifdef UNITTEST + +#include <stdlib.h> +#include <stdio.h> + +#ifdef UBI_LINUX /*Not used at present */ +static void buf_dump(char const *prefix, unsigned char const *buf, size_t len) +{ + fputs(prefix, stdout); + while (len--) + printf(" %02x", *buf++); + putchar('\n'); + +} +#endif + +static void bytereverse(unsigned char *buf, size_t len) +{ + while (len--) { + unsigned char x = bitrev8(*buf); + *buf++ = x; + } +} + +static void random_garbage(unsigned char *buf, size_t len) +{ + while (len--) + *buf++ = (unsigned char)random(); +} + +#ifdef UBI_LINUX /* Not used at present */ +static void store_le(u32 x, unsigned char *buf) +{ + buf[0] = (unsigned char)x; + buf[1] = (unsigned char)(x >> 8); + buf[2] = (unsigned char)(x >> 16); + buf[3] = (unsigned char)(x >> 24); +} +#endif + +static void store_be(u32 x, unsigned char *buf) +{ + buf[0] = (unsigned char)(x >> 24); + buf[1] = (unsigned char)(x >> 16); + buf[2] = (unsigned char)(x >> 8); + buf[3] = (unsigned char)x; +} + +/* + * This checks that CRC(buf + CRC(buf)) = 0, and that + * CRC commutes with bit-reversal. This has the side effect + * of bytewise bit-reversing the input buffer, and returns + * the CRC of the reversed buffer. + */ +static u32 test_step(u32 init, unsigned char *buf, size_t len) +{ + u32 crc1, crc2; + size_t i; + + crc1 = crc32_be(init, buf, len); + store_be(crc1, buf + len); + crc2 = crc32_be(init, buf, len + 4); + if (crc2) + printf("\nCRC cancellation fail: 0x%08x should be 0\n", crc2); + + for (i = 0; i <= len + 4; i++) { + crc2 = crc32_be(init, buf, i); + crc2 = crc32_be(crc2, buf + i, len + 4 - i); + if (crc2) + printf("\nCRC split fail: 0x%08x\n", crc2); + } + + /* Now swap it around for the other test */ + + bytereverse(buf, len + 4); + init = bitrev32(init); + crc2 = bitrev32(crc1); + if (crc1 != bitrev32(crc2)) + printf("\nBit reversal fail: 0x%08x -> 0x%08x -> 0x%08x\n", + crc1, crc2, bitrev32(crc2)); + crc1 = crc32_le(init, buf, len); + if (crc1 != crc2) + printf("\nCRC endianness fail: 0x%08x != 0x%08x\n", crc1, crc2); + crc2 = crc32_le(init, buf, len + 4); + if (crc2) + printf("\nCRC cancellation fail: 0x%08x should be 0\n", crc2); + + for (i = 0; i <= len + 4; i++) { + crc2 = crc32_le(init, buf, i); + crc2 = crc32_le(crc2, buf + i, len + 4 - i); + if (crc2) + printf("\nCRC split fail: 0x%08x\n", crc2); + } + + return crc1; +} + +#define SIZE 64 +#define INIT1 0 +#define INIT2 0 + +int main(void) +{ + unsigned char buf1[SIZE + 4]; + unsigned char buf2[SIZE + 4]; + unsigned char buf3[SIZE + 4]; + int i, j; + u32 crc1, crc2, crc3; + + for (i = 0; i <= SIZE; i++) { + printf("\rTesting length %d...", i); + fflush(stdout); + random_garbage(buf1, i); + random_garbage(buf2, i); + for (j = 0; j < i; j++) + buf3[j] = buf1[j] ^ buf2[j]; + + crc1 = test_step(INIT1, buf1, i); + crc2 = test_step(INIT2, buf2, i); + /* Now check that CRC(buf1 ^ buf2) = CRC(buf1) ^ CRC(buf2) */ + crc3 = test_step(INIT1 ^ INIT2, buf3, i); + if (crc3 != (crc1 ^ crc2)) + printf("CRC XOR fail: 0x%08x != 0x%08x ^ 0x%08x\n", + crc3, crc1, crc2); + } + printf("\nAll test complete. No failures expected.\n"); + return 0; +} + +#endif /* UNITTEST */ diff --git a/drivers/mtd/ubi/crc32defs.h b/drivers/mtd/ubi/crc32defs.h new file mode 100644 index 0000000..f5a5401 --- /dev/null +++ b/drivers/mtd/ubi/crc32defs.h @@ -0,0 +1,32 @@ +/* + * There are multiple 16-bit CRC polynomials in common use, but this is + * *the* standard CRC-32 polynomial, first popularized by Ethernet. + * x^32+x^26+x^23+x^22+x^16+x^12+x^11+x^10+x^8+x^7+x^5+x^4+x^2+x^1+x^0 + */ +#define CRCPOLY_LE 0xedb88320 +#define CRCPOLY_BE 0x04c11db7 + +/* How many bits at a time to use. Requires a table of 4<<CRC_xx_BITS bytes. */ +/* For less performance-sensitive, use 4 */ +#ifndef CRC_LE_BITS +# define CRC_LE_BITS 8 +#endif +#ifndef CRC_BE_BITS +# define CRC_BE_BITS 8 +#endif + +/* + * Little-endian CRC computation. Used with serial bit streams sent + * lsbit-first. Be sure to use cpu_to_le32() to append the computed CRC. + */ +#if CRC_LE_BITS > 8 || CRC_LE_BITS < 1 || CRC_LE_BITS & CRC_LE_BITS-1 +# error CRC_LE_BITS must be a power of 2 between 1 and 8 +#endif + +/* + * Big-endian CRC computation. Used with serial bit streams sent + * msbit-first. Be sure to use cpu_to_be32() to append the computed CRC. + */ +#if CRC_BE_BITS > 8 || CRC_BE_BITS < 1 || CRC_BE_BITS & CRC_BE_BITS-1 +# error CRC_BE_BITS must be a power of 2 between 1 and 8 +#endif diff --git a/drivers/mtd/ubi/crc32table.h b/drivers/mtd/ubi/crc32table.h new file mode 100644 index 0000000..0438af4 --- /dev/null +++ b/drivers/mtd/ubi/crc32table.h @@ -0,0 +1,136 @@ +/* this file is generated - do not edit */ + +static const u32 crc32table_le[] = { +tole(0x00000000L), tole(0x77073096L), tole(0xee0e612cL), tole(0x990951baL), +tole(0x076dc419L), tole(0x706af48fL), tole(0xe963a535L), tole(0x9e6495a3L), +tole(0x0edb8832L), tole(0x79dcb8a4L), tole(0xe0d5e91eL), tole(0x97d2d988L), +tole(0x09b64c2bL), tole(0x7eb17cbdL), tole(0xe7b82d07L), tole(0x90bf1d91L), +tole(0x1db71064L), tole(0x6ab020f2L), tole(0xf3b97148L), tole(0x84be41deL), +tole(0x1adad47dL), tole(0x6ddde4ebL), tole(0xf4d4b551L), tole(0x83d385c7L), +tole(0x136c9856L), tole(0x646ba8c0L), tole(0xfd62f97aL), tole(0x8a65c9ecL), +tole(0x14015c4fL), tole(0x63066cd9L), tole(0xfa0f3d63L), tole(0x8d080df5L), +tole(0x3b6e20c8L), tole(0x4c69105eL), tole(0xd56041e4L), tole(0xa2677172L), +tole(0x3c03e4d1L), tole(0x4b04d447L), tole(0xd20d85fdL), tole(0xa50ab56bL), +tole(0x35b5a8faL), tole(0x42b2986cL), tole(0xdbbbc9d6L), tole(0xacbcf940L), +tole(0x32d86ce3L), tole(0x45df5c75L), tole(0xdcd60dcfL), tole(0xabd13d59L), +tole(0x26d930acL), tole(0x51de003aL), tole(0xc8d75180L), tole(0xbfd06116L), +tole(0x21b4f4b5L), tole(0x56b3c423L), tole(0xcfba9599L), tole(0xb8bda50fL), +tole(0x2802b89eL), tole(0x5f058808L), tole(0xc60cd9b2L), tole(0xb10be924L), +tole(0x2f6f7c87L), tole(0x58684c11L), tole(0xc1611dabL), tole(0xb6662d3dL), +tole(0x76dc4190L), tole(0x01db7106L), tole(0x98d220bcL), tole(0xefd5102aL), +tole(0x71b18589L), tole(0x06b6b51fL), tole(0x9fbfe4a5L), tole(0xe8b8d433L), +tole(0x7807c9a2L), tole(0x0f00f934L), tole(0x9609a88eL), tole(0xe10e9818L), +tole(0x7f6a0dbbL), tole(0x086d3d2dL), tole(0x91646c97L), tole(0xe6635c01L), +tole(0x6b6b51f4L), tole(0x1c6c6162L), tole(0x856530d8L), tole(0xf262004eL), +tole(0x6c0695edL), tole(0x1b01a57bL), tole(0x8208f4c1L), tole(0xf50fc457L), +tole(0x65b0d9c6L), tole(0x12b7e950L), tole(0x8bbeb8eaL), tole(0xfcb9887cL), +tole(0x62dd1ddfL), tole(0x15da2d49L), tole(0x8cd37cf3L), tole(0xfbd44c65L), +tole(0x4db26158L), tole(0x3ab551ceL), tole(0xa3bc0074L), tole(0xd4bb30e2L), +tole(0x4adfa541L), tole(0x3dd895d7L), tole(0xa4d1c46dL), tole(0xd3d6f4fbL), +tole(0x4369e96aL), tole(0x346ed9fcL), tole(0xad678846L), tole(0xda60b8d0L), +tole(0x44042d73L), tole(0x33031de5L), tole(0xaa0a4c5fL), tole(0xdd0d7cc9L), +tole(0x5005713cL), tole(0x270241aaL), tole(0xbe0b1010L), tole(0xc90c2086L), +tole(0x5768b525L), tole(0x206f85b3L), tole(0xb966d409L), tole(0xce61e49fL), +tole(0x5edef90eL), tole(0x29d9c998L), tole(0xb0d09822L), tole(0xc7d7a8b4L), +tole(0x59b33d17L), tole(0x2eb40d81L), tole(0xb7bd5c3bL), tole(0xc0ba6cadL), +tole(0xedb88320L), tole(0x9abfb3b6L), tole(0x03b6e20cL), tole(0x74b1d29aL), +tole(0xead54739L), tole(0x9dd277afL), tole(0x04db2615L), tole(0x73dc1683L), +tole(0xe3630b12L), tole(0x94643b84L), tole(0x0d6d6a3eL), tole(0x7a6a5aa8L), +tole(0xe40ecf0bL), tole(0x9309ff9dL), tole(0x0a00ae27L), tole(0x7d079eb1L), +tole(0xf00f9344L), tole(0x8708a3d2L), tole(0x1e01f268L), tole(0x6906c2feL), +tole(0xf762575dL), tole(0x806567cbL), tole(0x196c3671L), tole(0x6e6b06e7L), +tole(0xfed41b76L), tole(0x89d32be0L), tole(0x10da7a5aL), tole(0x67dd4accL), +tole(0xf9b9df6fL), tole(0x8ebeeff9L), tole(0x17b7be43L), tole(0x60b08ed5L), +tole(0xd6d6a3e8L), tole(0xa1d1937eL), tole(0x38d8c2c4L), tole(0x4fdff252L), +tole(0xd1bb67f1L), tole(0xa6bc5767L), tole(0x3fb506ddL), tole(0x48b2364bL), +tole(0xd80d2bdaL), tole(0xaf0a1b4cL), tole(0x36034af6L), tole(0x41047a60L), +tole(0xdf60efc3L), tole(0xa867df55L), tole(0x316e8eefL), tole(0x4669be79L), +tole(0xcb61b38cL), tole(0xbc66831aL), tole(0x256fd2a0L), tole(0x5268e236L), +tole(0xcc0c7795L), tole(0xbb0b4703L), tole(0x220216b9L), tole(0x5505262fL), +tole(0xc5ba3bbeL), tole(0xb2bd0b28L), tole(0x2bb45a92L), tole(0x5cb36a04L), +tole(0xc2d7ffa7L), tole(0xb5d0cf31L), tole(0x2cd99e8bL), tole(0x5bdeae1dL), +tole(0x9b64c2b0L), tole(0xec63f226L), tole(0x756aa39cL), tole(0x026d930aL), +tole(0x9c0906a9L), tole(0xeb0e363fL), tole(0x72076785L), tole(0x05005713L), +tole(0x95bf4a82L), tole(0xe2b87a14L), tole(0x7bb12baeL), tole(0x0cb61b38L), +tole(0x92d28e9bL), tole(0xe5d5be0dL), tole(0x7cdcefb7L), tole(0x0bdbdf21L), +tole(0x86d3d2d4L), tole(0xf1d4e242L), tole(0x68ddb3f8L), tole(0x1fda836eL), +tole(0x81be16cdL), tole(0xf6b9265bL), tole(0x6fb077e1L), tole(0x18b74777L), +tole(0x88085ae6L), tole(0xff0f6a70L), tole(0x66063bcaL), tole(0x11010b5cL), +tole(0x8f659effL), tole(0xf862ae69L), tole(0x616bffd3L), tole(0x166ccf45L), +tole(0xa00ae278L), tole(0xd70dd2eeL), tole(0x4e048354L), tole(0x3903b3c2L), +tole(0xa7672661L), tole(0xd06016f7L), tole(0x4969474dL), tole(0x3e6e77dbL), +tole(0xaed16a4aL), tole(0xd9d65adcL), tole(0x40df0b66L), tole(0x37d83bf0L), +tole(0xa9bcae53L), tole(0xdebb9ec5L), tole(0x47b2cf7fL), tole(0x30b5ffe9L), +tole(0xbdbdf21cL), tole(0xcabac28aL), tole(0x53b39330L), tole(0x24b4a3a6L), +tole(0xbad03605L), tole(0xcdd70693L), tole(0x54de5729L), tole(0x23d967bfL), +tole(0xb3667a2eL), tole(0xc4614ab8L), tole(0x5d681b02L), tole(0x2a6f2b94L), +tole(0xb40bbe37L), tole(0xc30c8ea1L), tole(0x5a05df1bL), tole(0x2d02ef8dL) +}; +#ifdef UBI_LINUX +static const u32 crc32table_be[] = { +tobe(0x00000000L), tobe(0x04c11db7L), tobe(0x09823b6eL), tobe(0x0d4326d9L), +tobe(0x130476dcL), tobe(0x17c56b6bL), tobe(0x1a864db2L), tobe(0x1e475005L), +tobe(0x2608edb8L), tobe(0x22c9f00fL), tobe(0x2f8ad6d6L), tobe(0x2b4bcb61L), +tobe(0x350c9b64L), tobe(0x31cd86d3L), tobe(0x3c8ea00aL), tobe(0x384fbdbdL), +tobe(0x4c11db70L), tobe(0x48d0c6c7L), tobe(0x4593e01eL), tobe(0x4152fda9L), +tobe(0x5f15adacL), tobe(0x5bd4b01bL), tobe(0x569796c2L), tobe(0x52568b75L), +tobe(0x6a1936c8L), tobe(0x6ed82b7fL), tobe(0x639b0da6L), tobe(0x675a1011L), +tobe(0x791d4014L), tobe(0x7ddc5da3L), tobe(0x709f7b7aL), tobe(0x745e66cdL), +tobe(0x9823b6e0L), tobe(0x9ce2ab57L), tobe(0x91a18d8eL), tobe(0x95609039L), +tobe(0x8b27c03cL), tobe(0x8fe6dd8bL), tobe(0x82a5fb52L), tobe(0x8664e6e5L), +tobe(0xbe2b5b58L), tobe(0xbaea46efL), tobe(0xb7a96036L), tobe(0xb3687d81L), +tobe(0xad2f2d84L), tobe(0xa9ee3033L), tobe(0xa4ad16eaL), tobe(0xa06c0b5dL), +tobe(0xd4326d90L), tobe(0xd0f37027L), tobe(0xddb056feL), tobe(0xd9714b49L), +tobe(0xc7361b4cL), tobe(0xc3f706fbL), tobe(0xceb42022L), tobe(0xca753d95L), +tobe(0xf23a8028L), tobe(0xf6fb9d9fL), tobe(0xfbb8bb46L), tobe(0xff79a6f1L), +tobe(0xe13ef6f4L), tobe(0xe5ffeb43L), tobe(0xe8bccd9aL), tobe(0xec7dd02dL), +tobe(0x34867077L), tobe(0x30476dc0L), tobe(0x3d044b19L), tobe(0x39c556aeL), +tobe(0x278206abL), tobe(0x23431b1cL), tobe(0x2e003dc5L), tobe(0x2ac12072L), +tobe(0x128e9dcfL), tobe(0x164f8078L), tobe(0x1b0ca6a1L), tobe(0x1fcdbb16L), +tobe(0x018aeb13L), tobe(0x054bf6a4L), tobe(0x0808d07dL), tobe(0x0cc9cdcaL), +tobe(0x7897ab07L), tobe(0x7c56b6b0L), tobe(0x71159069L), tobe(0x75d48ddeL), +tobe(0x6b93dddbL), tobe(0x6f52c06cL), tobe(0x6211e6b5L), tobe(0x66d0fb02L), +tobe(0x5e9f46bfL), tobe(0x5a5e5b08L), tobe(0x571d7dd1L), tobe(0x53dc6066L), +tobe(0x4d9b3063L), tobe(0x495a2dd4L), tobe(0x44190b0dL), tobe(0x40d816baL), +tobe(0xaca5c697L), tobe(0xa864db20L), tobe(0xa527fdf9L), tobe(0xa1e6e04eL), +tobe(0xbfa1b04bL), tobe(0xbb60adfcL), tobe(0xb6238b25L), tobe(0xb2e29692L), +tobe(0x8aad2b2fL), tobe(0x8e6c3698L), tobe(0x832f1041L), tobe(0x87ee0df6L), +tobe(0x99a95df3L), tobe(0x9d684044L), tobe(0x902b669dL), tobe(0x94ea7b2aL), +tobe(0xe0b41de7L), tobe(0xe4750050L), tobe(0xe9362689L), tobe(0xedf73b3eL), +tobe(0xf3b06b3bL), tobe(0xf771768cL), tobe(0xfa325055L), tobe(0xfef34de2L), +tobe(0xc6bcf05fL), tobe(0xc27dede8L), tobe(0xcf3ecb31L), tobe(0xcbffd686L), +tobe(0xd5b88683L), tobe(0xd1799b34L), tobe(0xdc3abdedL), tobe(0xd8fba05aL), +tobe(0x690ce0eeL), tobe(0x6dcdfd59L), tobe(0x608edb80L), tobe(0x644fc637L), +tobe(0x7a089632L), tobe(0x7ec98b85L), tobe(0x738aad5cL), tobe(0x774bb0ebL), +tobe(0x4f040d56L), tobe(0x4bc510e1L), tobe(0x46863638L), tobe(0x42472b8fL), +tobe(0x5c007b8aL), tobe(0x58c1663dL), tobe(0x558240e4L), tobe(0x51435d53L), +tobe(0x251d3b9eL), tobe(0x21dc2629L), tobe(0x2c9f00f0L), tobe(0x285e1d47L), +tobe(0x36194d42L), tobe(0x32d850f5L), tobe(0x3f9b762cL), tobe(0x3b5a6b9bL), +tobe(0x0315d626L), tobe(0x07d4cb91L), tobe(0x0a97ed48L), tobe(0x0e56f0ffL), +tobe(0x1011a0faL), tobe(0x14d0bd4dL), tobe(0x19939b94L), tobe(0x1d528623L), +tobe(0xf12f560eL), tobe(0xf5ee4bb9L), tobe(0xf8ad6d60L), tobe(0xfc6c70d7L), +tobe(0xe22b20d2L), tobe(0xe6ea3d65L), tobe(0xeba91bbcL), tobe(0xef68060bL), +tobe(0xd727bbb6L), tobe(0xd3e6a601L), tobe(0xdea580d8L), tobe(0xda649d6fL), +tobe(0xc423cd6aL), tobe(0xc0e2d0ddL), tobe(0xcda1f604L), tobe(0xc960ebb3L), +tobe(0xbd3e8d7eL), tobe(0xb9ff90c9L), tobe(0xb4bcb610L), tobe(0xb07daba7L), +tobe(0xae3afba2L), tobe(0xaafbe615L), tobe(0xa7b8c0ccL), tobe(0xa379dd7bL), +tobe(0x9b3660c6L), tobe(0x9ff77d71L), tobe(0x92b45ba8L), tobe(0x9675461fL), +tobe(0x8832161aL), tobe(0x8cf30badL), tobe(0x81b02d74L), tobe(0x857130c3L), +tobe(0x5d8a9099L), tobe(0x594b8d2eL), tobe(0x5408abf7L), tobe(0x50c9b640L), +tobe(0x4e8ee645L), tobe(0x4a4ffbf2L), tobe(0x470cdd2bL), tobe(0x43cdc09cL), +tobe(0x7b827d21L), tobe(0x7f436096L), tobe(0x7200464fL), tobe(0x76c15bf8L), +tobe(0x68860bfdL), tobe(0x6c47164aL), tobe(0x61043093L), tobe(0x65c52d24L), +tobe(0x119b4be9L), tobe(0x155a565eL), tobe(0x18197087L), tobe(0x1cd86d30L), +tobe(0x029f3d35L), tobe(0x065e2082L), tobe(0x0b1d065bL), tobe(0x0fdc1becL), +tobe(0x3793a651L), tobe(0x3352bbe6L), tobe(0x3e119d3fL), tobe(0x3ad08088L), +tobe(0x2497d08dL), tobe(0x2056cd3aL), tobe(0x2d15ebe3L), tobe(0x29d4f654L), +tobe(0xc5a92679L), tobe(0xc1683bceL), tobe(0xcc2b1d17L), tobe(0xc8ea00a0L), +tobe(0xd6ad50a5L), tobe(0xd26c4d12L), tobe(0xdf2f6bcbL), tobe(0xdbee767cL), +tobe(0xe3a1cbc1L), tobe(0xe760d676L), tobe(0xea23f0afL), tobe(0xeee2ed18L), +tobe(0xf0a5bd1dL), tobe(0xf464a0aaL), tobe(0xf9278673L), tobe(0xfde69bc4L), +tobe(0x89b8fd09L), tobe(0x8d79e0beL), tobe(0x803ac667L), tobe(0x84fbdbd0L), +tobe(0x9abc8bd5L), tobe(0x9e7d9662L), tobe(0x933eb0bbL), tobe(0x97ffad0cL), +tobe(0xafb010b1L), tobe(0xab710d06L), tobe(0xa6322bdfL), tobe(0xa2f33668L), +tobe(0xbcb4666dL), tobe(0xb8757bdaL), tobe(0xb5365d03L), tobe(0xb1f740b4L) +}; +#endif diff --git a/drivers/mtd/ubi/debug.c b/drivers/mtd/ubi/debug.c new file mode 100644 index 0000000..492ab5c --- /dev/null +++ b/drivers/mtd/ubi/debug.c @@ -0,0 +1,192 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * Here we keep all the UBI debugging stuff which should normally be disabled + * and compiled-out, but it is extremely helpful when hunting bugs or doing big + * changes. + */ +#include <ubi_uboot.h> + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG + +#include "ubi.h" + +/** + * ubi_dbg_dump_ec_hdr - dump an erase counter header. + * @ec_hdr: the erase counter header to dump + */ +void ubi_dbg_dump_ec_hdr(const struct ubi_ec_hdr *ec_hdr) +{ + dbg_msg("erase counter header dump:"); + dbg_msg("magic %#08x", be32_to_cpu(ec_hdr->magic)); + dbg_msg("version %d", (int)ec_hdr->version); + dbg_msg("ec %llu", (long long)be64_to_cpu(ec_hdr->ec)); + dbg_msg("vid_hdr_offset %d", be32_to_cpu(ec_hdr->vid_hdr_offset)); + dbg_msg("data_offset %d", be32_to_cpu(ec_hdr->data_offset)); + dbg_msg("hdr_crc %#08x", be32_to_cpu(ec_hdr->hdr_crc)); + dbg_msg("erase counter header hexdump:"); + print_hex_dump(KERN_DEBUG, "", DUMP_PREFIX_OFFSET, 32, 1, + ec_hdr, UBI_EC_HDR_SIZE, 1); +} + +/** + * ubi_dbg_dump_vid_hdr - dump a volume identifier header. + * @vid_hdr: the volume identifier header to dump + */ +void ubi_dbg_dump_vid_hdr(const struct ubi_vid_hdr *vid_hdr) +{ + dbg_msg("volume identifier header dump:"); + dbg_msg("magic %08x", be32_to_cpu(vid_hdr->magic)); + dbg_msg("version %d", (int)vid_hdr->version); + dbg_msg("vol_type %d", (int)vid_hdr->vol_type); + dbg_msg("copy_flag %d", (int)vid_hdr->copy_flag); + dbg_msg("compat %d", (int)vid_hdr->compat); + dbg_msg("vol_id %d", be32_to_cpu(vid_hdr->vol_id)); + dbg_msg("lnum %d", be32_to_cpu(vid_hdr->lnum)); + dbg_msg("leb_ver %u", be32_to_cpu(vid_hdr->leb_ver)); + dbg_msg("data_size %d", be32_to_cpu(vid_hdr->data_size)); + dbg_msg("used_ebs %d", be32_to_cpu(vid_hdr->used_ebs)); + dbg_msg("data_pad %d", be32_to_cpu(vid_hdr->data_pad)); + dbg_msg("sqnum %llu", + (unsigned long long)be64_to_cpu(vid_hdr->sqnum)); + dbg_msg("hdr_crc %08x", be32_to_cpu(vid_hdr->hdr_crc)); + dbg_msg("volume identifier header hexdump:"); +} + +/** + * ubi_dbg_dump_vol_info- dump volume information. + * @vol: UBI volume description object + */ +void ubi_dbg_dump_vol_info(const struct ubi_volume *vol) +{ + dbg_msg("volume information dump:"); + dbg_msg("vol_id %d", vol->vol_id); + dbg_msg("reserved_pebs %d", vol->reserved_pebs); + dbg_msg("alignment %d", vol->alignment); + dbg_msg("data_pad %d", vol->data_pad); + dbg_msg("vol_type %d", vol->vol_type); + dbg_msg("name_len %d", vol->name_len); + dbg_msg("usable_leb_size %d", vol->usable_leb_size); + dbg_msg("used_ebs %d", vol->used_ebs); + dbg_msg("used_bytes %lld", vol->used_bytes); + dbg_msg("last_eb_bytes %d", vol->last_eb_bytes); + dbg_msg("corrupted %d", vol->corrupted); + dbg_msg("upd_marker %d", vol->upd_marker); + + if (vol->name_len <= UBI_VOL_NAME_MAX && + strnlen(vol->name, vol->name_len + 1) == vol->name_len) { + dbg_msg("name %s", vol->name); + } else { + dbg_msg("the 1st 5 characters of the name: %c%c%c%c%c", + vol->name[0], vol->name[1], vol->name[2], + vol->name[3], vol->name[4]); + } +} + +/** + * ubi_dbg_dump_vtbl_record - dump a &struct ubi_vtbl_record object. + * @r: the object to dump + * @idx: volume table index + */ +void ubi_dbg_dump_vtbl_record(const struct ubi_vtbl_record *r, int idx) +{ + int name_len = be16_to_cpu(r->name_len); + + dbg_msg("volume table record %d dump:", idx); + dbg_msg("reserved_pebs %d", be32_to_cpu(r->reserved_pebs)); + dbg_msg("alignment %d", be32_to_cpu(r->alignment)); + dbg_msg("data_pad %d", be32_to_cpu(r->data_pad)); + dbg_msg("vol_type %d", (int)r->vol_type); + dbg_msg("upd_marker %d", (int)r->upd_marker); + dbg_msg("name_len %d", name_len); + + if (r->name[0] == '\0') { + dbg_msg("name NULL"); + return; + } + + if (name_len <= UBI_VOL_NAME_MAX && + strnlen(&r->name[0], name_len + 1) == name_len) { + dbg_msg("name %s", &r->name[0]); + } else { + dbg_msg("1st 5 characters of the name: %c%c%c%c%c", + r->name[0], r->name[1], r->name[2], r->name[3], + r->name[4]); + } + dbg_msg("crc %#08x", be32_to_cpu(r->crc)); +} + +/** + * ubi_dbg_dump_sv - dump a &struct ubi_scan_volume object. + * @sv: the object to dump + */ +void ubi_dbg_dump_sv(const struct ubi_scan_volume *sv) +{ + dbg_msg("volume scanning information dump:"); + dbg_msg("vol_id %d", sv->vol_id); + dbg_msg("highest_lnum %d", sv->highest_lnum); + dbg_msg("leb_count %d", sv->leb_count); + dbg_msg("compat %d", sv->compat); + dbg_msg("vol_type %d", sv->vol_type); + dbg_msg("used_ebs %d", sv->used_ebs); + dbg_msg("last_data_size %d", sv->last_data_size); + dbg_msg("data_pad %d", sv->data_pad); +} + +/** + * ubi_dbg_dump_seb - dump a &struct ubi_scan_leb object. + * @seb: the object to dump + * @type: object type: 0 - not corrupted, 1 - corrupted + */ +void ubi_dbg_dump_seb(const struct ubi_scan_leb *seb, int type) +{ + dbg_msg("eraseblock scanning information dump:"); + dbg_msg("ec %d", seb->ec); + dbg_msg("pnum %d", seb->pnum); + if (type == 0) { + dbg_msg("lnum %d", seb->lnum); + dbg_msg("scrub %d", seb->scrub); + dbg_msg("sqnum %llu", seb->sqnum); + dbg_msg("leb_ver %u", seb->leb_ver); + } +} + +/** + * ubi_dbg_dump_mkvol_req - dump a &struct ubi_mkvol_req object. + * @req: the object to dump + */ +void ubi_dbg_dump_mkvol_req(const struct ubi_mkvol_req *req) +{ + char nm[17]; + + dbg_msg("volume creation request dump:"); + dbg_msg("vol_id %d", req->vol_id); + dbg_msg("alignment %d", req->alignment); + dbg_msg("bytes %lld", (long long)req->bytes); + dbg_msg("vol_type %d", req->vol_type); + dbg_msg("name_len %d", req->name_len); + + memcpy(nm, req->name, 16); + nm[16] = 0; + dbg_msg("the 1st 16 characters of the name: %s", nm); +} + +#endif /* CONFIG_MTD_UBI_DEBUG_MSG */ diff --git a/drivers/mtd/ubi/debug.h b/drivers/mtd/ubi/debug.h new file mode 100644 index 0000000..06294ac --- /dev/null +++ b/drivers/mtd/ubi/debug.h @@ -0,0 +1,152 @@ +/* + * Copyright (c) International Business Machines Corp., 2006 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See + * the GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Author: Artem Bityutskiy (Битюцкий Артём) + */ + +#ifndef __UBI_DEBUG_H__ +#define __UBI_DEBUG_H__ + +#ifdef CONFIG_MTD_UBI_DEBUG +#ifdef UBI_LINUX +#include <linux/random.h> +#endif + +#define ubi_assert(expr) BUG_ON(!(expr)) +#define dbg_err(fmt, ...) ubi_err(fmt, ##__VA_ARGS__) +#else +#define ubi_assert(expr) ({}) +#define dbg_err(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_DISABLE_BGT +#define DBG_DISABLE_BGT 1 +#else +#define DBG_DISABLE_BGT 0 +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG +/* Generic debugging message */ +#define dbg_msg(fmt, ...) \ + printk(KERN_DEBUG "UBI DBG: %s: " fmt "\n", \ + __func__, ##__VA_ARGS__) + +#define ubi_dbg_dump_stack() dump_stack() + +struct ubi_ec_hdr; +struct ubi_vid_hdr; +struct ubi_volume; +struct ubi_vtbl_record; +struct ubi_scan_volume; +struct ubi_scan_leb; +struct ubi_mkvol_req; + +void ubi_dbg_dump_ec_hdr(const struct ubi_ec_hdr *ec_hdr); +void ubi_dbg_dump_vid_hdr(const struct ubi_vid_hdr *vid_hdr); +void ubi_dbg_dump_vol_info(const struct ubi_volume *vol); +void ubi_dbg_dump_vtbl_record(const struct ubi_vtbl_record *r, int idx); +void ubi_dbg_dump_sv(const struct ubi_scan_volume *sv); +void ubi_dbg_dump_seb(const struct ubi_scan_leb *seb, int type); +void ubi_dbg_dump_mkvol_req(const struct ubi_mkvol_req *req); + +#else + +#define dbg_msg(fmt, ...) ({}) +#define ubi_dbg_dump_stack() ({}) +#define ubi_dbg_dump_ec_hdr(ec_hdr) ({}) +#define ubi_dbg_dump_vid_hdr(vid_hdr) ({}) +#define ubi_dbg_dump_vol_info(vol) ({}) +#define ubi_dbg_dump_vtbl_record(r, idx) ({}) +#define ubi_dbg_dump_sv(sv) ({}) +#define ubi_dbg_dump_seb(seb, type) ({}) +#define ubi_dbg_dump_mkvol_req(req) ({}) + +#endif /* CONFIG_MTD_UBI_DEBUG_MSG */ + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG_EBA +/* Messages from the eraseblock association unit */ +#define dbg_eba(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#else +#define dbg_eba(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG_WL +/* Messages from the wear-leveling unit */ +#define dbg_wl(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#else +#define dbg_wl(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG_IO +/* Messages from the input/output unit */ +#define dbg_io(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#else +#define dbg_io(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_MSG_BLD +/* Initialization and build messages */ +#define dbg_bld(fmt, ...) dbg_msg(fmt, ##__VA_ARGS__) +#else +#define dbg_bld(fmt, ...) ({}) +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_EMULATE_BITFLIPS +/** + * ubi_dbg_is_bitflip - if it is time to emulate a bit-flip. + * + * Returns non-zero if a bit-flip should be emulated, otherwise returns zero. + */ +static inline int ubi_dbg_is_bitflip(void) +{ + return !(random32() % 200); +} +#else +#define ubi_dbg_is_bitflip() 0 +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_EMULATE_WRITE_FAILURES +/** + * ubi_dbg_is_write_failure - if it is time to emulate a write failure. + * + * Returns non-zero if a write failure should be emulated, otherwise returns + * zero. + */ +static inline int ubi_dbg_is_write_failure(void) +{ + return !(random32() % 500); +} +#else +#define ubi_dbg_is_write_failure() 0 +#endif + +#ifdef CONFIG_MTD_UBI_DEBUG_EMULATE_ERASE_FAILURES +/** + * ubi_dbg_is_erase_failure - if its time to emulate an erase failure. + * + * Returns non-zero if an erase failure should be emulated, otherwise returns + * zero. + */ +static inline int ubi_dbg_is_erase_failure(void) +{ + return !(random32() % 400); +} +#else +#define ubi_dbg_is_erase_failure() 0 +#endif + +#endif /* !__UBI_DEBUG_H__ */
Dear Kyungmin Park,
Some more comments after testing your patches.
2008/10/28 Kyungmin Park kmpark@infradead.org:
UBI (Latin: "where?") stands for "Unsorted Block Images". It is a volume management system for flash devices which manages multiple logical volumes on a single physical flash device and spreads the I/O load (i.e, wear-leveling) across the whole flash chip.
In a sense, UBI may be compared to the Logical Volume Manager (LVM). Whereas LVM maps logical sectors to physical sectors, UBI maps logical eraseblocks to physical eraseblocks. But besides the mapping, UBI implements global wear-leveling and I/O errors handling.
For more details, Please visit the following URL. http://www.linux-mtd.infradead.org/doc/ubi.html
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com
diff --git a/drivers/mtd/ubi/build.c b/drivers/mtd/ubi/build.c new file mode 100644 index 0000000..b6f8699 --- /dev/null +++ b/drivers/mtd/ubi/build.c +static int io_init(struct ubi_device *ubi) +{
* not implemented.
return -EINVAL;
return -EINVAL;
ubi->min_io_size);
return -EINVAL;
ubi->ec_hdr_alsize;
else {
return -EINVAL;
/* Check sanity */
return -EINVAL;
* read-only mode.
ubi->ro_mode = 1;
ubi->ro_mode = 1;
I got these messages on my console, my suggestion is that (almost) all of the standard info messages are off by default.
int i, err;
mtd->index, i);
return -EEXIST;
return -EINVAL;
break;
return -ENFILE;
} else {
return -EINVAL;
return -EEXIST;
if (!ubi)
return -ENOMEM;
ubi->mtd = mtd;
err = io_init(ubi);
if (err)
goto out_free;
if (!ubi->peb_buf1)
goto out_free;
if (!ubi->peb_buf2)
goto out_free;
goto out_free;
if (err) {
goto out_free;
if (err)
goto out_detach;
if (err)
goto out_detach;
ubi_err("cannot spawn \"%s\", error %d", ubi->bgt_name,
err);
goto out_uif;
ubi_msg("MTD device name: \"%s\"", mtd->name);
All these should also be off by default IMO.
Regards, Magnus
On Mon, Nov 3, 2008 at 6:01 AM, Magnus Lilja lilja.magnus@gmail.com wrote:
Dear Kyungmin Park,
* not implemented.
return -EINVAL;
return -EINVAL;
ubi->min_io_size);
return -EINVAL;
ubi->ec_hdr_alsize;
else {
return -EINVAL;
/* Check sanity */
return -EINVAL;
* read-only mode.
ubi->ro_mode = 1;
ubi->ro_mode = 1;
int i, err;
mtd->index, i);
return -EEXIST;
return -EINVAL;
break;
return -ENFILE;
} else {
return -EINVAL;
return -EEXIST;
if (!ubi)
return -ENOMEM;
ubi->mtd = mtd;
err = io_init(ubi);
if (err)
goto out_free;
if (!ubi->peb_buf1)
goto out_free;
if (!ubi->peb_buf2)
goto out_free;
goto out_free;
if (err) {
goto out_free;
if (err)
goto out_detach;
if (err)
goto out_detach;
err);
goto out_uif;
These messages are default on kernel. If you want to off, we can add the another configuration to ubi_msg macro
Thank you, Kyungmin Park
2008/11/3 Kyungmin Park kmpark@infradead.org:
Yes, but in the kernel you can alter the log-level.
Regards, Magnus
Kyungmin Park
Magnus Lilja
