[U-Boot] [PATCHv2 1/2] ti: keystone2: Move CONFIG_ISW_ENTRY_ADDR to a common place
The ISW_ENTRY_ADDR Kconfig option under mach-omap2 isn't a SoC specific notion but rather "where is our previous stage loaded in memory?" option. Make use of this on ARCH_KEYSTONE rather than SPL_TEXT_BASE for our HS builds that are not using SPL anyhow.
Cc: Vitaly Andrianov vitalya@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Tom Rini trini@konsulko.com --- On a related note, can we please move SRAM_SCRATCH_SPACE_ADDR to a more fixed location? The build logic here is going to break again when more SPL symbols move to Kconfig, thanks! --- arch/arm/Kconfig | 15 +++++++++++++++ arch/arm/mach-omap2/Kconfig | 15 --------------- configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + include/configs/k2e_evm.h | 4 ---- include/configs/k2g_evm.h | 3 --- include/configs/k2hk_evm.h | 3 --- include/configs/k2l_evm.h | 3 --- include/configs/ti_armv7_keystone2.h | 5 +++-- 15 files changed, 26 insertions(+), 30 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f42eccef80dd..49904cac670e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1465,6 +1465,21 @@ config TI_SECURE_DEVICE authenticated) and the code. See the doc/README.ti-secure file for further details.
+if AM43XX || AM33XX || OMAP54XX || ARCH_KEYSTONE +config ISW_ENTRY_ADDR + hex "Address in memory or XIP address of bootloader entry point" + default 0x402F4000 if AM43XX + default 0x402F0400 if AM33XX + default 0x40301350 if OMAP54XX + help + After any reset, the boot ROM searches the boot media for a valid + boot image. For non-XIP devices, the ROM then copies the image into + internal memory. For all boot modes, after the ROM processes the + boot image it eventually computes the entry point address depending + on the device type (secure/non-secure), boot media (xip/non-xip) and + image headers. +endif + source "arch/arm/mach-aspeed/Kconfig"
source "arch/arm/mach-at91/Kconfig" diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 1cac4437d72c..d29f1ca0b58b 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -167,21 +167,6 @@ config TI_SECURE_EMIF_PROTECTED_REGION_SIZE using hardware memory firewalls. This value must be smaller than the TI_SECURE_EMIF_TOTAL_REGION_SIZE value.
-if AM43XX || AM33XX || OMAP54XX -config ISW_ENTRY_ADDR - hex "Address in memory or XIP address of bootloader entry point" - default 0x402F4000 if AM43XX - default 0x402F0400 if AM33XX - default 0x40301350 if OMAP54XX - help - After any reset, the boot ROM searches the boot media for a valid - boot image. For non-XIP devices, the ROM then copies the image into - internal memory. For all boot modes, after the ROM processes the - boot image it eventually computes the entry point address depending - on the device type (secure/non-secure), boot media (xip/non-xip) and - image headers. -endif - source "arch/arm/mach-omap2/omap3/Kconfig"
source "arch/arm/mach-omap2/omap4/Kconfig" diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index a108f88dfd32..b16740173cf6 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_SYS_TEXT_BASE=0xC000000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 67f6fb1da5f4..682c2f4523dc 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 838b6f14b6d1..7401c4baf811 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC0A0000 CONFIG_SYS_TEXT_BASE=0xC000000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 93fa2360ad11..42fc68308eda 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y CONFIG_TI_SECURE_DEVICE=y +CONFIG_ISW_ENTRY_ADDR=0xC0A0000 CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2G_EVM=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index ce139d11d633..8034ae420089 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC200000 CONFIG_SYS_TEXT_BASE=0xC000000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index db61557f11da..79124226c7a3 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC200000 CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 368171d134b4..d810110b8396 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_SYS_TEXT_BASE=0xC000000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 7bb672f50c1e..aac396239238 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index 2c0e4cbe92fd..547127490c92 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -40,10 +40,6 @@
#include <configs/ti_armv7_keystone2.h>
-/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE 0x0c100000 - - #define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS
/* NAND Configuration */ diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index 90f9a9922cab..3aeb9044f396 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -72,9 +72,6 @@ "bootm ${fit_loadaddr}#${name_fdt}" #endif
-/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE 0x0c0a0000 - /* NAND Configuration */ #define CONFIG_SYS_NAND_PAGE_2K
diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index 0b909a1bf6fa..d4f2e96bab08 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -40,9 +40,6 @@
-/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE 0x0c200000 - #define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS
/* NAND Configuration */ diff --git a/include/configs/k2l_evm.h b/include/configs/k2l_evm.h index 59e6b096733a..cfdb36e2d7ff 100644 --- a/include/configs/k2l_evm.h +++ b/include/configs/k2l_evm.h @@ -40,9 +40,6 @@
-/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE 0x0c100000 - #define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS
/* NAND Configuration */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 0c7d66486832..842b56bf0379 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -22,7 +22,7 @@ /* Memory Configuration */ #define CONFIG_SYS_LPAE_SDRAM_BASE 0x800000000 #define CONFIG_MAX_RAM_BANK_SIZE (2 << 30) /* 2GB */ -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE - \ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_ISW_ENTRY_ADDR - \ GENERATED_GBL_DATA_SIZE)
#ifdef CONFIG_SYS_MALLOC_F_LEN @@ -32,9 +32,10 @@ #endif
/* SPL SPI Loader Configuration */ +#define CONFIG_SPL_TEXT_BASE CONFIG_ISW_ENTRY_ADDR #define CONFIG_SPL_PAD_TO 65536 #define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_PAD_TO - 8) -#define CONFIG_SPL_BSS_START_ADDR (CONFIG_SPL_TEXT_BASE + \ +#define CONFIG_SPL_BSS_START_ADDR (CONFIG_ISW_ENTRY_ADDR + \ CONFIG_SPL_MAX_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (32 * 1024) #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \
From: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing values.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com [trini: Re-run migration] Signed-off-by: Tom Rini trini@konsulko.com --- README | 3 --- common/spl/Kconfig | 7 +++++++ configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/A20-Olimex-SOM204-EVB_defconfig | 1 + configs/A33-OLinuXino_defconfig | 1 + configs/Ainol_AW1_defconfig | 1 + configs/Ampe_A76_defconfig | 1 + configs/Auxtek-T003_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/B4420QDS_NAND_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/Bananapi_M2_Ultra_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapi_m2m_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 1 + configs/CHIP_defconfig | 1 + configs/CHIP_pro_defconfig | 1 + configs/CSQ_CS908_defconfig | 1 + configs/Chuwi_V7_CW0825_defconfig | 1 + configs/Colombus_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard4_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Cubietruck_plus_defconfig | 1 + configs/Empire_electronix_d709_defconfig | 1 + configs/Empire_electronix_m712_defconfig | 1 + configs/Hummingbird_A31_defconfig | 1 + configs/Hyundai_A7HD_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Lamobo_R1_defconfig | 1 + configs/LicheePi_Zero_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Linksprite_pcDuino_defconfig | 1 + configs/MK808C_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MSI_Primo73_defconfig | 1 + configs/MSI_Primo81_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000G_quad_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_I7_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Mele_M9_defconfig | 1 + configs/Merrii_A80_Optimus_defconfig | 1 + configs/Mini-X_defconfig | 1 + configs/Nintendo_NES_Classic_Edition_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020MBG-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020UTM-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1024RDB_NAND_defconfig | 1 + configs/P1024RDB_SDCARD_defconfig | 1 + configs/P1024RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/Sinlinx_SinA31s_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Sinovoip_BPI_M2_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 1 + configs/Sunchip_CX-A99_defconfig | 1 + configs/T1023RDB_NAND_defconfig | 1 + configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2081QDS_NAND_defconfig | 1 + configs/T2081QDS_SDCARD_defconfig | 1 + configs/T2081QDS_SPIFLASH_defconfig | 1 + configs/T4160QDS_NAND_defconfig | 1 + configs/T4160QDS_SDCARD_defconfig | 1 + configs/T4240QDS_NAND_defconfig | 1 + configs/T4240QDS_SDCARD_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/UTOO_P66_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 1 + configs/Wobo_i5_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/Yones_Toptech_BS1078_V2_defconfig | 1 + configs/a64-olinuxino_defconfig | 1 + configs/alt_defconfig | 1 + configs/am3517_crane_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_usb_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_evm_r5_defconfig | 1 + configs/amarula_a64_relic_defconfig | 1 + configs/apalis-tk1_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/arndale_defconfig | 1 + configs/avnet_ultra96_rev1_defconfig | 1 + configs/ba10_tv_box_defconfig | 1 + configs/bananapi_m1_plus_defconfig | 1 + configs/bananapi_m2_berry_defconfig | 1 + configs/bananapi_m2_plus_h3_defconfig | 1 + configs/bananapi_m2_plus_h5_defconfig | 1 + configs/bananapi_m2_zero_defconfig | 1 + configs/bananapi_m64_defconfig | 1 + configs/beaver_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/cairo_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_link64_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_speedy_defconfig | 1 + configs/ci20_mmc_defconfig | 1 + configs/cl-som-am57x_defconfig | 1 + configs/cl-som-imx7_defconfig | 1 + configs/clearfog_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/cm_t54_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colorfly_e708_q1_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/corvus_defconfig | 1 + configs/da850_am18xxevm_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/dh_imx6_defconfig | 1 + configs/difrnce_dit4350_defconfig | 1 + configs/display5_defconfig | 1 + configs/display5_factory_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_usb_defconfig | 1 + configs/ds414_defconfig | 1 + configs/dserve_dsrv9703c_defconfig | 1 + configs/duovero_defconfig | 1 + configs/eco5pk_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/emlid_neutis_n5_devboard_defconfig | 1 + configs/evb-rk3036_defconfig | 1 + configs/evb-rk3229_defconfig | 1 + configs/evb-rk3288_defconfig | 1 + configs/evb-rk3399_defconfig | 1 + configs/fennec-rk3288_defconfig | 1 + configs/ficus-rk3399_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 1 + configs/ga10h_v1_1_defconfig | 1 + configs/gose_defconfig | 1 + configs/gt90h_v4_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/h8_homlet_v2_defconfig | 1 + configs/harmony_defconfig | 1 + configs/helios4_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/iNet_3F_defconfig | 1 + configs/iNet_3W_defconfig | 1 + configs/iNet_86VS_defconfig | 1 + configs/iNet_D978_rev2_defconfig | 1 + configs/icnova-a20-swac_defconfig | 1 + configs/igep00x0_defconfig | 1 + configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6dl_mamoj_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/imx6qdl_icore_mipi_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6qdl_icore_rqs_defconfig | 1 + configs/imx6ul_geam_mmc_defconfig | 1 + configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_emmc_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + configs/inet1_defconfig | 1 + configs/inet86dz_defconfig | 1 + configs/inet97fv2_defconfig | 1 + configs/inet98v_rev2_defconfig | 1 + configs/inet9f_rev03_defconfig | 1 + configs/inet_q972_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/jesurun_q5_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/kc1_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/kp_imx6q_tpc_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/lager_defconfig | 1 + configs/libretech_all_h3_cc_h2_plus_defconfig | 1 + configs/libretech_all_h3_cc_h3_defconfig | 1 + configs/libretech_all_h3_cc_h5_defconfig | 1 + configs/liteboard_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_sdcard_qspi_defconfig | 1 + configs/ls1046ardb_emmc_defconfig | 1 + configs/ls1046ardb_qspi_spl_defconfig | 1 + configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_defconfig | 1 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_sdcard_qspi_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/maxbcm_defconfig | 1 + configs/mccmon6_nor_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/mcx_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/mixtile_loftq_defconfig | 1 + configs/mk802_a10s_defconfig | 1 + configs/mk802_defconfig | 1 + configs/mk802ii_defconfig | 1 + configs/mt7629_rfb_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx31pdk_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6memcal_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/nanopi_a64_defconfig | 1 + configs/nanopi_m1_defconfig | 1 + configs/nanopi_m1_plus_defconfig | 1 + configs/nanopi_neo2_defconfig | 1 + configs/nanopi_neo_air_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/nanopi_neo_plus2_defconfig | 1 + configs/novena_defconfig | 1 + configs/nyan-big_defconfig | 1 + configs/omap35_logic_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/omap5_uevm_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/opos6uldev_defconfig | 1 + configs/orangepi_2_defconfig | 1 + configs/orangepi_lite2_defconfig | 1 + configs/orangepi_lite_defconfig | 1 + configs/orangepi_one_defconfig | 1 + configs/orangepi_one_plus_defconfig | 1 + configs/orangepi_pc2_defconfig | 1 + configs/orangepi_pc_defconfig | 1 + configs/orangepi_pc_plus_defconfig | 1 + configs/orangepi_plus2e_defconfig | 1 + configs/orangepi_plus_defconfig | 1 + configs/orangepi_prime_defconfig | 1 + configs/orangepi_r1_defconfig | 1 + configs/orangepi_win_defconfig | 1 + configs/orangepi_zero_defconfig | 1 + configs/orangepi_zero_plus2_defconfig | 1 + configs/orangepi_zero_plus_defconfig | 1 + configs/origen_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/parrot_r16_defconfig | 1 + configs/paz00_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/pfla02_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/phycore_pcl063_defconfig | 1 + configs/pico-hobbit-imx6ul_defconfig | 1 + configs/pico-hobbit-imx7d_defconfig | 1 + configs/pico-imx6ul_defconfig | 1 + configs/pico-imx7d_defconfig | 1 + configs/pico-pi-imx6ul_defconfig | 1 + configs/pico-pi-imx7d_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/pine64-lts_defconfig | 1 + configs/pine64_plus_defconfig | 1 + configs/pine_h64_defconfig | 1 + configs/pinebook_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/plutux_defconfig | 1 + configs/polaroid_mid2407pxe03_defconfig | 1 + configs/polaroid_mid2809pxe04_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/porter_defconfig | 1 + configs/pov_protab2_ips9_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/q8_a13_tablet_defconfig | 1 + configs/q8_a23_tablet_800x480_defconfig | 1 + configs/q8_a33_tablet_1024x600_defconfig | 1 + configs/q8_a33_tablet_800x480_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/r7-tv-dongle_defconfig | 1 + configs/riotboard_spl_defconfig | 1 + configs/rock2_defconfig | 1 + configs/rock960-rk3399_defconfig | 1 + configs/rock_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sc_sps_1_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/silk_defconfig | 1 + configs/sksimx6_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/smdkv310_defconfig | 1 + configs/sniper_defconfig | 1 + configs/snow_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/sopine_baseboard_defconfig | 1 + configs/spring_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stout_defconfig | 1 + configs/sun8i_a23_evb_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/tbs_a711_defconfig | 1 + configs/tec-ng_defconfig | 1 + configs/tec_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/ti814x_evm_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/tinker-rk3288_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/ts4600_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/twister_defconfig | 1 + configs/udoo_defconfig | 1 + configs/udoo_neo_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_v7_defconfig | 1 + configs/venice2_defconfig | 1 + configs/ventana_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/wb45n_defconfig | 1 + configs/wb50n_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + configs/x530_defconfig | 1 + configs/x600_defconfig | 1 + configs/xfi3_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + configs/xilinx_zynqmp_zc1232_revA_defconfig | 1 + configs/xilinx_zynqmp_zc1254_revA_defconfig | 1 + configs/xilinx_zynqmp_zc1275_revA_defconfig | 1 + configs/xilinx_zynqmp_zc1275_revB_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 + configs/xilinx_zynqmp_zcu100_revC_defconfig | 1 + configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + configs/xilinx_zynqmp_zcu104_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu104_revC_defconfig | 1 + configs/xilinx_zynqmp_zcu106_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu111_revA_defconfig | 1 + configs/xpress_spl_defconfig | 1 + configs/zc5202_defconfig | 1 + configs/zc5601_defconfig | 1 + include/configs/B4860QDS.h | 1 - include/configs/BSC9131RDB.h | 1 - include/configs/BSC9132QDS.h | 1 - include/configs/C29XPCIE.h | 1 - include/configs/MPC8313ERDB.h | 3 +-- include/configs/P1010RDB.h | 4 ---- include/configs/P1022DS.h | 3 --- include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240QDS.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/alt.h | 1 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 2 -- include/configs/am43xx_evm.h | 1 - include/configs/am65x_evm.h | 5 ----- include/configs/apf27.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/bur_am335x_common.h | 1 - include/configs/chromebook_link.h | 2 -- include/configs/ci20.h | 1 - include/configs/clearfog.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t43.h | 1 - include/configs/controlcenterdc.h | 2 -- include/configs/corvus.h | 1 - include/configs/da850evm.h | 1 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/devkit3250.h | 1 - include/configs/devkit8000.h | 3 --- include/configs/ds414.h | 1 - include/configs/edminiv2.h | 1 - include/configs/exynos5250-common.h | 2 -- include/configs/exynos5420-common.h | 5 ----- include/configs/gose.h | 1 - include/configs/helios4.h | 1 - include/configs/imx6_spl.h | 1 - include/configs/imx7_spl.h | 1 - include/configs/imx8mq_evk.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/ipam390.h | 1 - include/configs/kc1.h | 1 - include/configs/koelsch.h | 1 - include/configs/lager.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 2 -- include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 2 -- include/configs/ls1046a_common.h | 3 --- include/configs/ls1088a_common.h | 1 - include/configs/ls2080a_common.h | 1 - include/configs/m53menlo.h | 1 - include/configs/maxbcm.h | 1 - include/configs/mcx.h | 1 - include/configs/mt7629.h | 1 - include/configs/mx31pdk.h | 2 -- include/configs/mxs.h | 1 - include/configs/omap3_beagle.h | 2 -- include/configs/omap3_evm.h | 2 -- include/configs/omap3_igep00x0.h | 2 -- include/configs/omap3_logic.h | 2 -- include/configs/omap3_overo.h | 2 -- include/configs/omapl138_lcdk.h | 1 - include/configs/origen.h | 1 - include/configs/p1_p2_rdb_pc.h | 3 --- include/configs/pcl063.h | 2 -- include/configs/picosam9g45.h | 1 - include/configs/porter.h | 1 - include/configs/qemu-x86.h | 2 -- include/configs/rk3036_common.h | 1 - include/configs/rk3188_common.h | 1 - include/configs/rk322x_common.h | 1 - include/configs/rk3288_common.h | 5 ----- include/configs/rk3368_common.h | 1 - include/configs/rk3399_common.h | 1 - include/configs/sama5d27_som1_ek.h | 1 - include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/silk.h | 1 - include/configs/smartweb.h | 1 - include/configs/smdkv310.h | 2 -- include/configs/sniper.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/socfpga_stratix10_socdk.h | 1 - include/configs/stm32f746-disco.h | 1 - include/configs/stm32mp1.h | 1 - include/configs/stout.h | 1 - include/configs/sunxi-common.h | 3 --- include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/taurus.h | 1 - include/configs/tegra114-common.h | 1 - include/configs/tegra124-common.h | 1 - include/configs/tegra20-common.h | 1 - include/configs/tegra30-common.h | 1 - include/configs/theadorable.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_am335x_common.h | 1 - include/configs/ti_armv7_keystone2.h | 1 - include/configs/ti_omap3_common.h | 1 - include/configs/ti_omap4_common.h | 1 - include/configs/ti_omap5_common.h | 2 -- include/configs/tricorder.h | 1 - include/configs/turris_omnia.h | 1 - include/configs/uniphier.h | 3 --- include/configs/wb45n.h | 1 - include/configs/wb50n.h | 1 - include/configs/woodburn_sd.h | 1 - include/configs/work_92105.h | 1 - include/configs/x530.h | 1 - include/configs/x600.h | 1 - include/configs/xilinx_zynqmp.h | 1 - include/configs/zynq-common.h | 1 - scripts/config_whitelist.txt | 1 - 646 files changed, 525 insertions(+), 174 deletions(-)
diff --git a/README b/README index 6525b81e3f83..8f0d0c966104 100644 --- a/README +++ b/README @@ -2441,9 +2441,6 @@ FIT uImage format: When defined, the linker checks that the actual size does not exceed it.
- CONFIG_SPL_TEXT_BASE - TEXT_BASE for linking the SPL binary. - CONFIG_SPL_RELOC_TEXT_BASE Address to relocate to. If unspecified, this is equal to CONFIG_SPL_TEXT_BASE (i.e. no relocation is done). diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 206c24076da8..dd078fe79d1e 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -56,6 +56,13 @@ config SPL_LDSCRIPT U-Boot stage. Set this to the path of the linker-script to be used for SPL.
+config SPL_TEXT_BASE + hex "SPL Text Base" + default ISW_ENTRY_ADDR if AM43XX || AM33XX || OMAP54XX || ARCH_KEYSTONE + default 0x0 + help + The address in memory that SPL will be running from. + config SPL_BOARD_INIT bool "Call board-specific initialization in SPL" help diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index aaff0a6b6574..9641d0f2fb27 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -11,6 +11,7 @@ CONFIG_SATAPWR="PC3" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 59c33378e733..1b212d22c4a9 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -9,6 +9,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=1 CONFIG_USB1_VBUS_PIN="PB10" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index fb2c2be8e2f1..8eaa5d4f0733 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_POWER="PB10" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 41f36d7601c7..c70a6de3ae15 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 235191b009a8..a3daefc3da96 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_SPI_SUNXI=y CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index d58fe19e1cde..49ed281b800e 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -11,6 +11,7 @@ CONFIG_SATAPWR="PC3" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 8cee64fca7aa..9750fff02f97 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -9,6 +9,7 @@ CONFIG_SATAPWR="PC3" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/A20-OLinuXino_MICRO-eMMC_defconfig b/configs/A20-OLinuXino_MICRO-eMMC_defconfig index e3dfd66fb05d..bfa04b0e5211 100644 --- a/configs/A20-OLinuXino_MICRO-eMMC_defconfig +++ b/configs/A20-OLinuXino_MICRO-eMMC_defconfig @@ -11,6 +11,7 @@ CONFIG_SATAPWR="PB8" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index c72782e572a7..3a00162410b8 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -12,6 +12,7 @@ CONFIG_SATAPWR="PB8" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 152a8c815aa4..af1041d49d0a 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -13,6 +13,7 @@ CONFIG_SATAPWR="PC3" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig index 862670ba0dcf..bc42fe9be4c0 100644 --- a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig +++ b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig @@ -13,6 +13,7 @@ CONFIG_GMAC_TX_DELAY=4 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/A20-Olimex-SOM204-EVB_defconfig b/configs/A20-Olimex-SOM204-EVB_defconfig index 66acd8206d04..2caaf9c83a10 100644 --- a/configs/A20-Olimex-SOM204-EVB_defconfig +++ b/configs/A20-Olimex-SOM204-EVB_defconfig @@ -12,6 +12,7 @@ CONFIG_GMAC_TX_DELAY=4 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/A33-OLinuXino_defconfig b/configs/A33-OLinuXino_defconfig index bffb95cfa305..33e2d863c0de 100644 --- a/configs/A33-OLinuXino_defconfig +++ b/configs/A33-OLinuXino_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="PB2" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index fe7920de8c95..ed168451c674 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 762ac4addb74..ce57f2b970c1 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index 0f4b84d7111b..5c3b4ddfb997 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -8,6 +8,7 @@ CONFIG_USB1_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index f852f0cb6197..066b5a9cc029 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="PG13" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index fd74888d6c72..57a6c451249b 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index bfd1bcf6f690..e3d1a0f88efe 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index 3f271ccca714..51c8eb929c95 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFFE000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index 51dc15228870..fcc9a57e5d1f 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -12,6 +12,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_MISC_INIT_R is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFFE000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index 0db36b004fdf..1a71f460b147 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFFE000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index a37a8a29fb2b..e4924d87d6d3 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFFE000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y diff --git a/configs/Bananapi_M2_Ultra_defconfig b/configs/Bananapi_M2_Ultra_defconfig index c18afc839edd..286673e89e56 100644 --- a/configs/Bananapi_M2_Ultra_defconfig +++ b/configs/Bananapi_M2_Ultra_defconfig @@ -10,6 +10,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-r40-bananapi-m2-ultra" diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index e504ff7dfe10..fd281f48f230 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -9,6 +9,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Bananapi_m2m_defconfig b/configs/Bananapi_m2m_defconfig index 2ba61867a97a..17e052130278 100644 --- a/configs/Bananapi_m2m_defconfig +++ b/configs/Bananapi_m2m_defconfig @@ -10,6 +10,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB0_ID_DET="PH8" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 94433c961428..60e67b685369 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -11,6 +11,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index aef42acb16cc..d85f332d1a6c 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_MISC_INIT_R is not set CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 950a2d5cb5d1..c6f70d8119d0 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y CONFIG_USB0_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index b5b4f03e71f1..b1439b79f14b 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN5I=y CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y CONFIG_USB0_VBUS_PIN="PB10" CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MTDPARTS=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 7e0fbdd51ccc..f23104de9214 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -7,6 +7,7 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 64d500b8e1c7..1668c47b42a4 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_HITACHI_TX18D42VM=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index fc2d97cbefb9..a5e046392642 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -17,6 +17,7 @@ CONFIG_VIDEO_LCD_PANEL_I2C_SCL="PA24" CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index ffb665a21fbe..86479f5932b2 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -8,6 +8,7 @@ CONFIG_SATAPWR="PB8" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Cubieboard4_defconfig b/configs/Cubieboard4_defconfig index 9c92b614da3a..7d55f858d7a6 100644 --- a/configs/Cubieboard4_defconfig +++ b/configs/Cubieboard4_defconfig @@ -12,6 +12,7 @@ CONFIG_USB1_VBUS_PIN="PH14" CONFIG_USB3_VBUS_PIN="PH15" CONFIG_AXP_GPIO=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index d1e37828bf24..9db906e3db74 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -8,6 +8,7 @@ CONFIG_SATAPWR="PB8" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 0c3a93801303..523af32ed75c 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -13,6 +13,7 @@ CONFIG_GMAC_TX_DELAY=1 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index 869bffcfca0c..23a79f5c44a5 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -16,6 +16,7 @@ CONFIG_AXP_GPIO=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index b6b44c8c438b..274ef0175f0c 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index d9cadcfec048..60115267f284 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index d837ea15f03e..84c8b91195b3 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -9,6 +9,7 @@ CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index e4efa585b8a7..4c7cdc796fb4 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 21241a984ad3..bcbb6e0a011b 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -8,6 +8,7 @@ CONFIG_SATAPWR="PB8" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 72add89c2046..753dd1da7c00 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -10,6 +10,7 @@ CONFIG_GMAC_TX_DELAY=4 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/LicheePi_Zero_defconfig b/configs/LicheePi_Zero_defconfig index d031c7de60a1..519d8a5f430f 100644 --- a/configs/LicheePi_Zero_defconfig +++ b/configs/LicheePi_Zero_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN8I_V3S=y CONFIG_DRAM_CLK=360 CONFIG_DRAM_ZQ=14779 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 7bb38fe2955e..96bfe86b4d54 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -10,6 +10,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index f5ae27a56a9b..a242de506ad6 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -8,6 +8,7 @@ CONFIG_SATAPWR="PH2" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 7e83afc74456..cb03b4da41f3 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -6,6 +6,7 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index 49508f64489a..e2b33b779495 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index ab28a78cbe5a..44865711c23f 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=6 CONFIG_MISC_INIT_R=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFF00000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index a454ec67fc66..83f0f6d01bee 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=6 CONFIG_MISC_INIT_R=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFF00000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index fec863fd9dca..7458cc82b6ac 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -10,6 +10,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 0779d044eea2..439dc0db707f 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 103ae4d967f8..c73b9f3c1034 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN4I=y CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index 759f1dcd12e1..9efd238037e3 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -8,6 +8,7 @@ CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 34821ceb49c5..7c501e890c51 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -8,6 +8,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 2c0138633959..1dc9566dc62d 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -7,6 +7,7 @@ CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 93d45514ab92..ba93d7038220 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -9,6 +9,7 @@ CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 191032fbf7c2..4399811a0dc2 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -9,6 +9,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index bae39c95e1de..9e19575934d9 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -7,6 +7,7 @@ CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index b4eea0abe584..770a577b9304 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -12,6 +12,7 @@ CONFIG_USB1_VBUS_PIN="PH4" CONFIG_USB3_VBUS_PIN="PH5" CONFIG_AXP_GPIO=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index 54b40d56960e..70f9e1100094 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -6,6 +6,7 @@ CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index be116db00ef0..f7691e501ce2 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -9,6 +9,7 @@ CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_AXP_GPIO=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set CONFIG_CMD_MTDPARTS=y # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index c58ccbaa6a23..4a5cc1685678 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -12,6 +12,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 0943b9d6bee8..7022f21199eb 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -14,6 +14,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 23993301c77f..e8531ca11ef9 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 798a0dcc3747..96cfbdf9fa77 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xD0001000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 3b4992fcf562..0808da301940 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xD0001000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 0dd4d4a45b4b..cca3e9733c8a 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index eb3151c37023..8424d5f56fb9 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xD0001000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 55134467391c..8bada15fb602 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xD0001000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 0f7e989b4eca..6d86aed1a009 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index aca04419f512..58fdeaccd0d1 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xD0001000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 704135637427..0dc717603c3f 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xD0001000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index cdf51c873516..9fa6853e841e 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 56200bb6e8bb..b45534b4bcee 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xD0001000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index f44d36c34207..d8b7ef4459ed 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xD0001000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig index cd1c8fc965b2..1a2e7a911e5d 100644 --- a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020MBG-PC_SDCARD_defconfig b/configs/P1020MBG-PC_SDCARD_defconfig index 21c10af1640a..a401b4773fdb 100644 --- a/configs/P1020MBG-PC_SDCARD_defconfig +++ b/configs/P1020MBG-PC_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 09fc7d9fb960..6523dff57a76 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 778a258bd7b7..10dafdecdb7d 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 31572566d4a7..5faf85c478d6 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 2cc48c6a1165..d76160353721 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 983fbc740b99..198ecfc7a77d 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 0f49a81c0440..e377952104cd 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 58f25714e5aa..ebe28113d937 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index c6cb7a58e12a..b9dac4ed2a6c 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 848ca279aa25..51ccf9bd62fc 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig index 0c15789c4474..a67c37a0c780 100644 --- a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1020UTM-PC_SDCARD_defconfig b/configs/P1020UTM-PC_SDCARD_defconfig index 3285aabfc272..f144f31fb803 100644 --- a/configs/P1020UTM-PC_SDCARD_defconfig +++ b/configs/P1020UTM-PC_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index d03cfc0016b8..3ef3ac631cb2 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index a086c527ac6c..69f59ecc8cdc 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index 2ff094c16561..c487a8729856 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index 0ee7a35bee3d..aa946f7fbaec 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index 4c49da3a7cd4..4d6ad774ddb6 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index ac8c9b2669d7..30f890e7011d 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index a28d506a600c..6264b1e3dbc4 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index 5e49b0372605..ad82d364d8b6 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index cf1b6a040847..41c26c172e84 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index c69ae0135b3b..acb5f645f0f3 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index dbf1872f626e..d3516f816e3e 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 2c0546100afe..164f0472b463 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index ed1b5e5aa2d5..acc5cbc6e661 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index 0925c2cf1bae..9112b2263d7a 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index 398112fe4cd3..c7a2c65835ba 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index 9e5bf25eac3b..579398089902 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 5ca059cce143..941733b0bba6 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index ebb04754daa4..f3bd1e70257d 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index e16c38584835..a6577e604d8d 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index fb78b202e96b..3f4851c77f7b 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index e45381427767..d9e749cb4342 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 964f21d7ab45..428043ebea7d 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 784262e447d1..e657de8aad27 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 647009750d97..a32d5be87e7c 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xF8F81000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index b0b924ebd61d..1a430ebbc95d 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -11,6 +11,7 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 9005e41724ab..77f9bd2f51a7 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 946336b958df..2e73e6b91582 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -7,6 +7,7 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index 79743a9c9a51..712cbb5b3897 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -17,6 +17,7 @@ CONFIG_SATAPWR="PD25" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/Sunchip_CX-A99_defconfig b/configs/Sunchip_CX-A99_defconfig index d4218f0faddc..6f6efdd7a2bd 100644 --- a/configs/Sunchip_CX-A99_defconfig +++ b/configs/Sunchip_CX-A99_defconfig @@ -12,6 +12,7 @@ CONFIG_USB1_VBUS_PIN="PL7" CONFIG_USB3_VBUS_PIN="PL8" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index 22feb6fca711..cdf3021f8ad6 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index de99d1663686..29b7256d83a0 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index b0434ea5d043..861b984b2de2 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index fa031a988f24..c5108ca863ea 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index be461fc8ad8f..e269fc36d6b1 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 8ad4d35f3024..bd8a44904917 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 294d1267720d..8ce1f9bcbc12 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index e31578c6b5e1..384c98fb2e44 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 148eef0719e0..33ea8ea73d62 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index 637fa078363e..8ac15bf6e5a0 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index 88f3c287ece0..24d238bd10cd 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 7adf65cc8a1a..ef97f6d83e3f 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 3287d1b5953b..e3388f124c35 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index 57d214da3b26..6ee651999810 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index c086a9fe99a3..8a1b0f25da45 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 0bb15cc37204..aa1c04ce55d5 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 1f7cf60695f7..4a24e1605125 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index a2a7d67c8032..1b0443f34b15 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 245abd225d94..c7079160ceff 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 0d727143a040..370c96f973a0 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 4b2d1828ef48..107cfae7157e 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 8c36654544e9..129765a3b57d 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 948a05af899e..80b17902620a 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 30e87df3bb87..71c3df49c2a4 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 0cccb3a85d84..9eda1a69fd08 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 4a5a56e5f441..ca5b89e63d1b 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index dfe5e8bf0c8c..860a932a5199 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 6d6d6408e5ca..66c49b13d019 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index d38a1e371634..7641347cd7c0 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T2081QDS_SDCARD_defconfig b/configs/T2081QDS_SDCARD_defconfig index 4dd0e909d38a..e1bf1c97e6b8 100644 --- a/configs/T2081QDS_SDCARD_defconfig +++ b/configs/T2081QDS_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T2081QDS_SPIFLASH_defconfig b/configs/T2081QDS_SPIFLASH_defconfig index 6dc7d6db6558..bd586c8ded40 100644 --- a/configs/T2081QDS_SPIFLASH_defconfig +++ b/configs/T2081QDS_SPIFLASH_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index af529b296787..403398ec4eae 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index b29c069102c4..8195ce11cf91 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index caeeacbefc3a..3fc09da9e310 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index b461e0880b33..60aa2b05b5d8 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 8bde98373808..280a63b90f35 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index c4d1a4ee54e5..3c95f4581993 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -20,6 +20,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_TL059WV5C0=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index 44ac1c5214b4..818cb5ff6eba 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 22fedf10da19..670219778bdb 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index 3c6fae7a8013..172e365d3c7e 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PB3" CONFIG_USB1_VBUS_PIN="PG12" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index f7e2237435b4..c266804e61e6 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -19,6 +19,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index 8e3fd06dc448..5cc725b5a03e 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/a64-olinuxino_defconfig b/configs/a64-olinuxino_defconfig index 1c59cb48536a..5bf06f5def16 100644 --- a/configs/a64-olinuxino_defconfig +++ b/configs/a64-olinuxino_defconfig @@ -6,6 +6,7 @@ CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/alt_defconfig b/configs/alt_defconfig index c4ece795073a..632f74641f2a 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -19,6 +19,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0xE6300000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index 530407b40689..3398936e75c1 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -8,6 +8,7 @@ CONFIG_EMIF4=y CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=10 +CONFIG_SPL_TEXT_BASE=0x40200800 # CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y # CONFIG_CMDLINE_EDITING is not set diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 9ba518f3d2a4..2edd5e62c0b9 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -12,6 +12,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=10 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index c01fda9cce0e..6d0b466294e8 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x403018E0 CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 3e2c166e0df1..343ec41835ca 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x40300000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 6e4580ae3929..baf5bb999a79 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x40306D50 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 8f6fd25531b4..26889564319e 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -17,6 +17,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run run_kern" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 49498b13b655..4a9b9e0e06fb 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -17,6 +17,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_LOAD_FIT=y CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0x41C00000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/amarula_a64_relic_defconfig b/configs/amarula_a64_relic_defconfig index dc94c147c021..10270aede8d0 100644 --- a/configs/amarula_a64_relic_defconfig +++ b/configs/amarula_a64_relic_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 # CONFIG_VIDEO_DE2 is not set CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 7ce02008acd7..938f33c857d2 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Apalis TK1 # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 86dabd37360e..ff301537410c 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -21,6 +21,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index c184420b39db..ebff3887557b 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_STDIO_DEREGISTER=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Apalis T30 # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index e482f48e87dc..2342141aca35 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySMX0,115200 mtdparts=mxc_nand.0:1M(u-boot)ro,512K(env),512K(env2),512K(firmware),512K(dtb),5M(kernel),-(rootfs) ubi.mtd=rootfs root=ubi0:rootfs rootfstype=ubifs " CONFIG_VERSION_VARIABLE=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0xA0000000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="BIOS> " diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index baca2a662403..de89bdcea6a0 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 24422645cbac..f14f55c1c3a7 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x2023400 CONFIG_SYS_PROMPT="ARNDALE # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/avnet_ultra96_rev1_defconfig b/configs/avnet_ultra96_rev1_defconfig index 15a682789350..d3776a5a631c 100644 --- a/configs/avnet_ultra96_rev1_defconfig +++ b/configs/avnet_ultra96_rev1_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index 796ff7038444..1d11254c368e 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -9,6 +9,7 @@ CONFIG_USB2_VBUS_PIN="PH12" CONFIG_VIDEO_COMPOSITE=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/bananapi_m1_plus_defconfig b/configs/bananapi_m1_plus_defconfig index f32857980ebc..16b3486471c4 100644 --- a/configs/bananapi_m1_plus_defconfig +++ b/configs/bananapi_m1_plus_defconfig @@ -9,6 +9,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/bananapi_m2_berry_defconfig b/configs/bananapi_m2_berry_defconfig index e8cb46677a5d..d2595de9b58a 100644 --- a/configs/bananapi_m2_berry_defconfig +++ b/configs/bananapi_m2_berry_defconfig @@ -8,6 +8,7 @@ CONFIG_MMC0_CD_PIN="PH13" CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-v40-bananapi-m2-berry" diff --git a/configs/bananapi_m2_plus_h3_defconfig b/configs/bananapi_m2_plus_h3_defconfig index 597618fb900b..789c0413f614 100644 --- a/configs/bananapi_m2_plus_h3_defconfig +++ b/configs/bananapi_m2_plus_h3_defconfig @@ -9,6 +9,7 @@ CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/bananapi_m2_plus_h5_defconfig b/configs/bananapi_m2_plus_h5_defconfig index e7c10dbdf2d0..a55809b8bb61 100644 --- a/configs/bananapi_m2_plus_h5_defconfig +++ b/configs/bananapi_m2_plus_h5_defconfig @@ -9,6 +9,7 @@ CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/bananapi_m2_zero_defconfig b/configs/bananapi_m2_zero_defconfig index 91302eb49cf8..a3a85af9b65a 100644 --- a/configs/bananapi_m2_zero_defconfig +++ b/configs/bananapi_m2_zero_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/bananapi_m64_defconfig b/configs/bananapi_m64_defconfig index 7d41ebb070cf..7eed348e48b6 100644 --- a/configs/bananapi_m64_defconfig +++ b/configs/bananapi_m64_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH13" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 41e94e082866..e1f9e2257902 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Tegra30 (Beaver) # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 2bafc793bc80..191cb30a29d8 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -16,6 +16,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 4edef39d8b1c..a0c334f3df33 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -9,6 +9,7 @@ CONFIG_BOOTDELAY=-2 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200800 CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="Cairo # " diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 5ba6751aa91f..71b0820d1773 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Tegra30 (Cardhu) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index 2747847ae47c..601c0bd22e54 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Tegra124 (TK1-SOM) # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 99c581b2de95..2e8bb4fcc431 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -21,6 +21,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index ea19c69661bb..18b9c7a40f2d 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -16,6 +16,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-mickey.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_SPI_LOAD=y diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 92c65b179a1f..c801906135e7 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-bob.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF8C2000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SPL_SPI_LOAD=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 617c7060443d..4e6c6df09906 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -19,6 +19,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-jerry.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_SPI_LOAD=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 12f26570af78..504885330937 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_LAST_STAGE_INIT=y +CONFIG_SPL_TEXT_BASE=0xFFFD0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CPU_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 297d0e4854a5..8437e05a345a 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -17,6 +17,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-minnie.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_SPI_LOAD=y diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index 624b8f838049..7d2ff3e4a1c2 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -18,6 +18,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-speedy.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_SPI_LOAD=y diff --git a/configs/ci20_mmc_defconfig b/configs/ci20_mmc_defconfig index 9602c8c6fec0..d45e4027d312 100644 --- a/configs/ci20_mmc_defconfig +++ b/configs/ci20_mmc_defconfig @@ -15,6 +15,7 @@ CONFIG_BOOTCOMMAND="ext4load mmc 0:1 0x88000000 /boot/uImage; bootm 0x88000000" CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_CPUINFO=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0xF4000A00 # CONFIG_SPL_BANNER_PRINT is not set # CONFIG_TPL_BANNER_PRINT is not set CONFIG_HUSH_PARSER=y diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index cd780cdb98cf..6508ed498a03 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -8,6 +8,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40300000 # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_SPI_LOAD=y diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index 3501e2b86443..860a7287f8dc 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x911000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x80 CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index c90600eaf9d6..992b3f39824c 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x141 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index c8d1e8311130..8c04f6663e76 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd; run legacy_bootcmd" CONFIG_MISC_INIT_R=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x80 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index cfbe97c3dad0..5359a43d9821 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SPL_TEXT_BASE=0x40200800 # CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3x # " diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index ea0cafa6f0eb..7aeac5d4c6ff 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x40300350 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x480 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index 05ac37cc2503..fa9972b47fb7 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40300000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_SATA_SUPPORT=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 207228135458..4c5f864cbc89 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -21,6 +21,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index a3eea926fdf0..ed3e9c2c1f81 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_STDIO_DEREGISTER=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_TEXT_BASE=0x108000 CONFIG_SYS_PROMPT="Colibri T20 # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index b9b2773b7a09..739da6c96068 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_STDIO_DEREGISTER=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Colibri T30 # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index 2e9b3020695f..c0896e37c4f8 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index f22a3ab819c7..8c6e96822ecb 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_LAST_STAGE_INIT=y +CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index a1af2f1342f5..959f8bb4a8a3 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index 419224104af4..8110c3cab819 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -19,6 +19,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 41dae05fb904..1928dab12d8b 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -18,6 +18,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 48b7c2a97a11..55cd567e1911 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -16,6 +16,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 8828c6fafb2a..e4937958d3dc 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Tegra114 (Dalmore) # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 2c9254b5cfe6..4c13beb7facb 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y # CONFIG_CMD_FLASH is not set diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 3e1b404408a2..20e02d9c3eaf 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y # CONFIG_CMD_FLASH is not set diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index b36b7c3b2c31..694b10980022 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index b6c61c3a4843..8fe36809811c 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y # CONFIG_CMD_FLASH is not set diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index ea2aee4ef4ae..7ff009d3ec49 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=2 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_OS_BOOT=y # CONFIG_CMD_IMI is not set CONFIG_CMD_SPL=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index a14c5f2261fb..5ee6406d9d03 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index f99b97d3d5ac..4afedf4b3abf 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/display5_defconfig b/configs/display5_defconfig index cdf3642dd210..5ca4231113e9 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6Q" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_BOOTCOUNT_LIMIT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 6b9febf62fb6..4a4813777417 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTCOMMAND="echo SDP Display5 recovery" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index ef061501ef35..7032d5d93ff2 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x40300000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 378b3d791ccd..cdc299cd4ba6 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -27,6 +27,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x40306D50 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index ce42f23867c3..aac54164e25c 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y # CONFIG_CMD_FLASH is not set diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index 9a19fd67a82a..71aad9605d4b 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 782a9dc29126..419ed7ad6df8 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run f CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40300000 # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SYS_PROMPT="duovero # " diff --git a/configs/eco5pk_defconfig b/configs/eco5pk_defconfig index b48d8e708c8c..fccc95fcdd2f 100644 --- a/configs/eco5pk_defconfig +++ b/configs/eco5pk_defconfig @@ -7,6 +7,7 @@ CONFIG_EMIF4=y CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=10 +CONFIG_SPL_TEXT_BASE=0x40200000 # CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ECO5-PK # " diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 1d06b3e612f5..c07fb9436d05 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -11,6 +11,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/emlid_neutis_n5_devboard_defconfig b/configs/emlid_neutis_n5_devboard_defconfig index 3df0ca13f04d..e0f375a95ac2 100644 --- a/configs/emlid_neutis_n5_devboard_defconfig +++ b/configs/emlid_neutis_n5_devboard_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881977 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index eb7b3a47aff0..a02d24f8020d 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3036-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x10081000 CONFIG_SPL_STACK_R=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 14ff54af20e7..20692dd8d5f4 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -15,6 +15,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_FDT_FILE="rk3229-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x10081000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200 CONFIG_CMD_GPT=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index d0eba8a1a077..a2739175aca8 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -15,6 +15,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-evb-rk808.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 3a0ed1808b3f..475a21f2f198 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF8C2000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SPL_ATF=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 4e0898d81864..e561c97927b2 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -16,6 +16,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_DEFAULT_FDT_FILE="rk3288-fennec.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index 4e4e7dd55a36..d544576a4275 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF8C2000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SPL_ATF=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index b8eae0f2adb7..70eed866bf1a 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -15,6 +15,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 3b3be2218fd7..794af11bf5ae 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF8C2000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SPL_ATF=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 25346ee4565d..b743a2b2db5f 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -17,6 +17,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 39e4cfdfc28d..257982dc4023 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -19,6 +19,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0xE6300000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index 8957340ba059..02dea21e9f6f 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 07171c700997..ea3842befeca 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -24,6 +24,7 @@ CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 0ed2209e3b79..17ed741e24c9 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -24,6 +24,7 @@ CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 57e4a999aba9..a08723a3f2dd 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -24,6 +24,7 @@ CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index 99a7dee6014d..f0eef3d711b2 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -11,6 +11,7 @@ CONFIG_AXP_GPIO=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 1b89580b823b..9b99d17c175e 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_HARMONY=y CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x108000 CONFIG_SYS_PROMPT="Tegra20 (Harmony) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index 6ef40b036625..92749194caee 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x141 # CONFIG_CMD_FLASH is not set diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index c44237f1dc60..43f4c67fbf26 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -7,6 +7,7 @@ CONFIG_MACPWR="PH21" CONFIG_VIDEO_COMPOSITE=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index dafb860d6e6f..fc2d19579c02 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index dae498001b2f..50aa8df14468 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index b13861071982..e2987d232be5 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index 95da7ba94fc2..1372785f4324 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -17,6 +17,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index b60da9ea5bb8..2ba4620fdfe5 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_POWER="PH22" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 6391c1b2dd38..d6fd9ab6a636 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index c34c515080e9..fdda16a055d2 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -16,6 +16,7 @@ CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index f3661c0a7634..c019da42912a 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -10,6 +10,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_OS_BOOT=y CONFIG_CRC32_VERIFY=y CONFIG_CMD_MEMTEST=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index cf149d615b32..2d513e1f5bbf 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 8a875a8716b4..eea0fd1df9f7 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_TPL_BANNER_PRINT is not set diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 7a0e5169b63f..724f5013b6d0 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 68ad1c6d2028..93545731095b 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index cf149d615b32..2d513e1f5bbf 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index a4766063cada..2dfcabedcb1e 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 8a7f41b53c2c..a17406ee6b89 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="geam6ul> " diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index bf61f768abed..f37971954624 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index abf1a93a982d..378a11fa705f 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="isiotmx6ul> " diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 8961661a90ae..fb27d7a829de 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 46100b671963..989dc445d03a 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage.cfg" +CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_SPL_BOARD_INIT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 3c8bf53dce4b..191a6521126d 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index 5961829ac2d2..55f0b31a4e05 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index e01e555c326d..23a83dda46de 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index f2372343cf2f..cd461394fb8d 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index 8aa8d6a0e3aa..19c3d050e2f7 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig index c7a5a24a1497..ec288fef30f0 100644 --- a/configs/inet_q972_defconfig +++ b/configs/inet_q972_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 7244b0f92a0c..d87038c9482a 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -13,6 +13,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 729b3f5ed789..0d8d765451e7 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -8,6 +8,7 @@ CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index c59ca475cb0f..7b72ddad438a 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Tegra124 (Jetson TK1) # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index 69991a8fa8b4..7b126b750912 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -8,6 +8,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SPL_TEXT_BASE=0x40300000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 75beab4ccef6..377d70d5fc58 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -19,6 +19,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0xE6300000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/kp_imx6q_tpc_defconfig b/configs/kp_imx6q_tpc_defconfig index cb58ed6678b9..2b04e069ff28 100644 --- a/configs/kp_imx6q_tpc_defconfig +++ b/configs/kp_imx6q_tpc_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index d6d5abb2b625..50ace854e134 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_FDT_FILE="rk3036-kylin.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x10081000 CONFIG_SPL_STACK_R=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 686aa2c171b6..f0c471a26109 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -19,6 +19,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0xE6300000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/libretech_all_h3_cc_h2_plus_defconfig b/configs/libretech_all_h3_cc_h2_plus_defconfig index 8f3144895c6d..c54ad0b49769 100644 --- a/configs/libretech_all_h3_cc_h2_plus_defconfig +++ b/configs/libretech_all_h3_cc_h2_plus_defconfig @@ -8,6 +8,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/libretech_all_h3_cc_h3_defconfig b/configs/libretech_all_h3_cc_h3_defconfig index e5e0f593a7db..71b766d071f2 100644 --- a/configs/libretech_all_h3_cc_h3_defconfig +++ b/configs/libretech_all_h3_cc_h3_defconfig @@ -8,6 +8,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/libretech_all_h3_cc_h5_defconfig b/configs/libretech_all_h3_cc_h5_defconfig index e4a93bde481f..0a6714046a51 100644 --- a/configs/libretech_all_h3_cc_h5_defconfig +++ b/configs/libretech_all_h3_cc_h5_defconfig @@ -8,6 +8,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index e4a2fcc7fbe5..95763cd215c1 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -15,6 +15,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="imx6ul-liteboard.dtb" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index cbe1bf11863a..732f99658363 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_MISC_INIT_R=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_CMD_BOOTZ=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 81701fccf0c5..00755ae3de7a 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -19,6 +19,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 55793783d026..d7ecaca3bc07 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -18,6 +18,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index db308bc6135b..5c5136d1b554 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -18,6 +18,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 42cf38b34771..c427dcec06bb 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index f94e31fc26d6..046502a01b88 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -22,6 +22,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 9310d6ecc81a..531a31d97668 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -22,6 +22,7 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index f81ef5ecbdce..ee094eefd4b2 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -19,6 +19,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index e876db3297f5..68bbf08c242a 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 23a47d6c3e44..bb7d11d833d6 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 0feeb64f71e9..c6a6c526a485 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -19,6 +19,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index a232b45a7945..c3d725e13947 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 753957f65809..477c83d06554 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 23e54603bbc6..42f3ac480275 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 2d9169babdea..5ff490d384f8 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -16,6 +16,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:4m(nand_uboot),36m(nand_kernel),472m(nand_free);spi0.0:2m(uboot),14m(free)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index f11da29c79f9..58d4399b3382 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:4m(nand_uboot),36m(nand_kernel),472m(nand_free);spi0.0:2m(uboot),14m(free)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index a7620d23ad30..523aacedb1c5 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:2m(uboot),14m(free)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 4b4528986929..d741ba00895b 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index 975cc580bda9..639e4a53c0b1 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 643a52039a96..01b36ef02e8e 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index a7624967cfbe..3d46f91a1384 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index c022ebf357e6..bccf78449a8c 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x1800A000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 6a9577aba2c5..9ae45f3449c0 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x1800A000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index b53f2121257a..ab1a1b9995f2 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x1800A000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index a7cdead46e9d..33ddb2751f53 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x1800A000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 170c2ce15f3b..6f6f32e2a864 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_SPL_TEXT_BASE=0x1800A000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index d4c64a52f1e2..31783e042875 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_SPL_TEXT_BASE=0x1800A000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 9f9297c5fb62..cccafd3ed28d 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0600 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x1800A000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 5555e05030b5..7ea06cd533b5 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -18,6 +18,7 @@ CONFIG_BOOTARGS="console=ttymxc0,115200" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x70008000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 5c716cdec8b8..0dfc50e412e5 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 1ab29c1ca657..c9c80a562359 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -12,6 +12,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_nor.cfg" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 6d47db57eeec..2e206f6853b0 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -13,6 +13,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_sd.cfg" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index a70865c62240..094c06b1d5ee 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -10,6 +10,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SPL_TEXT_BASE=0x40200000 # CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mcx # " diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 0a3250988a17..7c1692ad137b 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x108000 CONFIG_SYS_PROMPT="Tegra20 (Medcom-Wide) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index b26bd1e7c115..5c88a33c22e1 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -15,6 +15,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-miqi.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 858e3208114f..85def720000a 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -9,6 +9,7 @@ CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index 1495d8a3a694..2228d12dd52b 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_EMR1=0 CONFIG_USB1_VBUS_PIN="PB10" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 2b1ce038aefb..85baf1e3be8f 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN4I=y CONFIG_USB2_VBUS_PIN="PH12" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index 89e581bbbac1..b3acb3740edc 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/mt7629_rfb_defconfig b/configs/mt7629_rfb_defconfig index 459c67827dbd..01b952fc15b0 100644 --- a/configs/mt7629_rfb_defconfig +++ b/configs/mt7629_rfb_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_DEFAULT_FDT_FILE="mt7629-rfb" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x201000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 33b961a8edf7..710f89036181 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=10 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SPL_TEXT_BASE=0x40200000 # CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mt_ventoux => " diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 0e552a6ac496..85adbe06666f 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -13,6 +13,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTEFI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 86f4d6babde9..eb94ab3158d3 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index d0572212f1ec..4fe54255bf55 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index ab59d7599b48..0b88a607fe9f 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 6b774cf248a3..f823069326bf 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 0a77e6e9f739..4e89169ee635 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index c6dcb45f8783..238ec1117132 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x87DC0000 CONFIG_SPL_NAND_SUPPORT=y # CONFIG_AUTO_COMPLETE is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 506e3a71df18..83dbeac04ba3 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/mx6memcal_defconfig b/configs/mx6memcal_defconfig index 2350e158a783..7d31ae48a0ee 100644 --- a/configs/mx6memcal_defconfig +++ b/configs/mx6memcal_defconfig @@ -11,6 +11,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,SPL,MX6QDL" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_ETHER=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index f51b5af7abfd..c0f64f50e288 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_FS_EXT4=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index ac879a3d2093..f7609ad41d84 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_FS_EXT4=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index bcfeb3091033..5c0d774eb81e 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 0b6bb2286bd5..db0fdbe1810b 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 4a3c56faa619..247aa4b73126 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 185f543df6e1..e12df387e219 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/nanopi_a64_defconfig b/configs/nanopi_a64_defconfig index a9424de31a63..73bfe46099c5 100644 --- a/configs/nanopi_a64_defconfig +++ b/configs/nanopi_a64_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN50I=y CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/nanopi_m1_defconfig b/configs/nanopi_m1_defconfig index b3a7870ea9a6..30f5334d552a 100644 --- a/configs/nanopi_m1_defconfig +++ b/configs/nanopi_m1_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/nanopi_m1_plus_defconfig b/configs/nanopi_m1_plus_defconfig index b83cdf2e1ccd..b613877dba29 100644 --- a/configs/nanopi_m1_plus_defconfig +++ b/configs/nanopi_m1_plus_defconfig @@ -9,6 +9,7 @@ CONFIG_MMC0_CD_PIN="PH13" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/nanopi_neo2_defconfig b/configs/nanopi_neo2_defconfig index 9de893adfaf9..6670385f978c 100644 --- a/configs/nanopi_neo2_defconfig +++ b/configs/nanopi_neo2_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881977 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/nanopi_neo_air_defconfig b/configs/nanopi_neo_air_defconfig index 33f9c0746c16..8020407b4966 100644 --- a/configs/nanopi_neo_air_defconfig +++ b/configs/nanopi_neo_air_defconfig @@ -9,6 +9,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/nanopi_neo_defconfig b/configs/nanopi_neo_defconfig index 40f5bd176e59..f60c7e6240b2 100644 --- a/configs/nanopi_neo_defconfig +++ b/configs/nanopi_neo_defconfig @@ -9,6 +9,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/nanopi_neo_plus2_defconfig b/configs/nanopi_neo_plus2_defconfig index 88c76a55e53f..4a5889199cc9 100644 --- a/configs/nanopi_neo_plus2_defconfig +++ b/configs/nanopi_neo_plus2_defconfig @@ -8,6 +8,7 @@ CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 4c9c1cb9eb57..298cb23107e7 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -23,6 +23,7 @@ CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 19120d0a4c9b..b00252992bb7 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTSTAGE_STASH=y CONFIG_BOOTSTAGE_STASH_ADDR=0x83000000 CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Tegra124 (Nyan-big) # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 5b5f3eb7b47f..c50978d195d6 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -16,6 +16,7 @@ CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="logicpd-torpedo-35xx-devkit.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 396f32169959..99c409aa131c 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -15,6 +15,7 @@ CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="logicpd-som-lv-35xx-devkit.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 73ffa83d0c53..269ae7cc8dc7 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-beagle.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index aa3a2a969cea..c7b8eb36a553 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -12,6 +12,7 @@ CONFIG_TPL_SYS_MALLOC_F_LEN=0x400 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index 8b71e26befaf..de5e2ae99bb6 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SYS_EXTRA_OPTIONS="SYS_BOARD_OMAP3_HA" CONFIG_BOOTDELAY=3 +CONFIG_SPL_TEXT_BASE=0x40200800 # CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index b38b6fd75a88..1ba3849b35dd 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -15,6 +15,7 @@ CONFIG_ANDROID_BOOT_IMAGE=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index c6106c5d23a8..e3f60de37f8b 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -15,6 +15,7 @@ CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="logicpd-som-lv-37xx-devkit.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index b2fb146889e3..4c209b0c8866 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=2 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 9885f6a9e51a..806b7a52413d 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -8,6 +8,7 @@ CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run f CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40300000 # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 0e01c8edcbf4..1d7f21a79a8a 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run f CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40300000 # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_CMD_ASKENV=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 84d4e2b37cdc..9a7fccd93e10 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -9,6 +9,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0x40300000 # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y CONFIG_CMD_SPL=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index d66af98ba35c..4b5d1b1c814d 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -17,6 +17,7 @@ CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xb5 CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index 3660eaad615e..52cfe224d692 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -23,6 +23,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="imx6ul-opos6uldev.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index ab6566e49a8b..ce99dda76640 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -9,6 +9,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_USB1_VBUS_PIN="PG13" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/orangepi_lite2_defconfig b/configs/orangepi_lite2_defconfig index e5f7d15bf654..defd8074e4b3 100644 --- a/configs/orangepi_lite2_defconfig +++ b/configs/orangepi_lite2_defconfig @@ -6,6 +6,7 @@ CONFIG_MMC0_CD_PIN="PF6" # CONFIG_PSCI_RESET is not set CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x20060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/orangepi_lite_defconfig b/configs/orangepi_lite_defconfig index 1092a852503a..f9d76d31e404 100644 --- a/configs/orangepi_lite_defconfig +++ b/configs/orangepi_lite_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 404fdd91197b..8e64b0994353 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/orangepi_one_plus_defconfig b/configs/orangepi_one_plus_defconfig index f46b4f6b998f..b451f2f97199 100644 --- a/configs/orangepi_one_plus_defconfig +++ b/configs/orangepi_one_plus_defconfig @@ -6,6 +6,7 @@ CONFIG_MMC0_CD_PIN="PF6" # CONFIG_PSCI_RESET is not set CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x20060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/orangepi_pc2_defconfig b/configs/orangepi_pc2_defconfig index ad837382c8e8..72572ce6cce0 100644 --- a/configs/orangepi_pc2_defconfig +++ b/configs/orangepi_pc2_defconfig @@ -8,6 +8,7 @@ CONFIG_MACPWR="PD6" CONFIG_SPL_SPI_SUNXI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index de11df755e4e..1f40a987fa6d 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/orangepi_pc_plus_defconfig b/configs/orangepi_pc_plus_defconfig index ce26cfaf9b55..9e570c85f064 100644 --- a/configs/orangepi_pc_plus_defconfig +++ b/configs/orangepi_pc_plus_defconfig @@ -8,6 +8,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index b0813e4e10b0..ac9160c0e43a 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -9,6 +9,7 @@ CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 05023737a956..b36360a761f9 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -11,6 +11,7 @@ CONFIG_USB1_VBUS_PIN="PG13" CONFIG_SATAPWR="PG11" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/orangepi_prime_defconfig b/configs/orangepi_prime_defconfig index 20ae6df5a0d4..b32825c9d8b6 100644 --- a/configs/orangepi_prime_defconfig +++ b/configs/orangepi_prime_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881977 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/orangepi_r1_defconfig b/configs/orangepi_r1_defconfig index 05c3b08b766e..f046c9fc61bd 100644 --- a/configs/orangepi_r1_defconfig +++ b/configs/orangepi_r1_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SPI_SUNXI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-r1" CONFIG_SUN8I_EMAC=y diff --git a/configs/orangepi_win_defconfig b/configs/orangepi_win_defconfig index dc0ca591491a..184f8a496145 100644 --- a/configs/orangepi_win_defconfig +++ b/configs/orangepi_win_defconfig @@ -6,6 +6,7 @@ CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_SPL_SPI_SUNXI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/orangepi_zero_defconfig b/configs/orangepi_zero_defconfig index 44fc18b7b1ed..435303a2db26 100644 --- a/configs/orangepi_zero_defconfig +++ b/configs/orangepi_zero_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SPI_SUNXI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-zero" CONFIG_SUN8I_EMAC=y diff --git a/configs/orangepi_zero_plus2_defconfig b/configs/orangepi_zero_plus2_defconfig index e62b3cb15041..3278dd60f08b 100644 --- a/configs/orangepi_zero_plus2_defconfig +++ b/configs/orangepi_zero_plus2_defconfig @@ -8,6 +8,7 @@ CONFIG_MMC0_CD_PIN="PH13" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/orangepi_zero_plus_defconfig b/configs/orangepi_zero_plus_defconfig index cc8b8c7f9ab9..86775db8f64f 100644 --- a/configs/orangepi_zero_plus_defconfig +++ b/configs/orangepi_zero_plus_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=624 CONFIG_DRAM_ZQ=3881977 CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 7a30d9648f74..e1a70adfc7ae 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -10,6 +10,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x2021410 CONFIG_SYS_PROMPT="ORIGEN # " # CONFIG_CMD_XIMG is not set CONFIG_CMD_THOR_DOWNLOAD=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index c8c53e8d9165..79d1d9230fd8 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -16,6 +16,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index ce60a4a4d308..935443bc19b6 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -12,6 +12,7 @@ CONFIG_USB1_VBUS_PIN="PD12" CONFIG_AXP_GPIO=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index f23773c37ed9..8f8212ee0778 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_PAZ00=y CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x108000 CONFIG_SYS_PROMPT="Tegra20 (Paz00) MOD # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index af4768f71024..ec50f2444130 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTDELAY=3 CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 96ec8fdb0bcc..4b7e66806e83 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -11,6 +11,7 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x2024410 CONFIG_SYS_PROMPT="Peach-Pi # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 792f22fa1fee..484f03dc058a 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x2024410 CONFIG_SYS_PROMPT="Peach-Pit # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index 2eb59e4abec8..3e5ab50122b8 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTDELAY=3 CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 1e54035c0364..7f7971805a50 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -16,6 +16,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_DEFAULT_FDT_FILE="rk3288-phycore-rdk.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index 75058f664a22..34a10016c14d 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x909000 CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_MEMTEST=y diff --git a/configs/pico-hobbit-imx6ul_defconfig b/configs/pico-hobbit-imx6ul_defconfig index 4cfef86882ee..3547c2726fa6 100644 --- a/configs/pico-hobbit-imx6ul_defconfig +++ b/configs/pico-hobbit-imx6ul_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-hobbit.dtb" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_SDP_SUPPORT=y diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index f58d5171ba30..425187c1bcb7 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-hobbit.dtb" CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x911000 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index edbca4ee14c1..6d98a3d66884 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="ask" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_SDP_SUPPORT=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 7e13923cb43a..41abf8aa35fb 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="ask" CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x911000 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/pico-pi-imx6ul_defconfig b/configs/pico-pi-imx6ul_defconfig index 18abf838060c..a33c8149229a 100644 --- a/configs/pico-pi-imx6ul_defconfig +++ b/configs/pico-pi-imx6ul_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-pi.dtb" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_SDP_SUPPORT=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index c8ac2ffd5f47..526c76184db8 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-pi.dtb" CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x911000 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 49e6d5e6b2a4..61e1830955a6 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/pine64-lts_defconfig b/configs/pine64-lts_defconfig index fd3cdeec8585..0394c5c3baec 100644 --- a/configs/pine64-lts_defconfig +++ b/configs/pine64-lts_defconfig @@ -10,6 +10,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_SPL_SPI_SUNXI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 8ee72a46139e..c3ab702f0e85 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -6,6 +6,7 @@ CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_PINE64_DT_SELECTION=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/pine_h64_defconfig b/configs/pine_h64_defconfig index e34f4fd1e46b..671a28801158 100644 --- a/configs/pine_h64_defconfig +++ b/configs/pine_h64_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 # CONFIG_PSCI_RESET is not set CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x20060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/pinebook_defconfig b/configs/pinebook_defconfig index 2760f8cc398a..75cb05690437 100644 --- a/configs/pinebook_defconfig +++ b/configs/pinebook_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_CLK=552 CONFIG_DRAM_ZQ=3881949 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_R_I2C_ENABLE=y +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index edb11996a7e0..c7fec4d51282 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -16,6 +16,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index a317ebb355d1..02e8bb0c5aa5 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -16,6 +16,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 318eada004ae..9b903c3f9136 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x108000 CONFIG_SYS_PROMPT="Tegra20 (Plutux) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 1bf90cabdaff..2d753eb611f9 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index f69df5a3d66c..79151cffcabd 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index ca194fd62b32..b468f42178e7 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -16,6 +16,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_DEFAULT_FDT_FILE="rk3288-popmetal.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 826f78bb42c4..faa63cb8ec3a 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -19,6 +19,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0xE6300000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index f269de62931b..8640667c1a8c 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 3fcff2580a19..03890f3313ff 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -22,6 +22,7 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-puma-haikou.dtb" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF8C2000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 01549883b90d..29cab0793a8c 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index e26c6e74bf6f..81b49945828d 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index b5434252057c..3268f4a89225 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index f6d9cbaa1d92..1bfd1d8b7955 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 34acc09317d2..e592306da9b3 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -27,6 +27,7 @@ CONFIG_BOOTARGS="root=/dev/sdb3 init=/sbin/init rootwait ro" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_LAST_STAGE_INIT=y +CONFIG_SPL_TEXT_BASE=0xFFFD0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CPU_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index caf162c9f627..8b8dc279ec42 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=384 CONFIG_USB1_VBUS_PIN="PG13" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/riotboard_spl_defconfig b/configs/riotboard_spl_defconfig index 2298d5b615b5..e3632d1ee290 100644 --- a/configs/riotboard_spl_defconfig +++ b/configs/riotboard_spl_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTCOMMAND="run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 746c0bfb353c..c6b0317112bc 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -15,6 +15,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-rock2-square.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index 17311e685bb6..7f2e3f31f4c4 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF8C2000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SPL_ATF=y diff --git a/configs/rock_defconfig b/configs/rock_defconfig index 2de51e8c5316..e92ebcacd609 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -15,6 +15,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEFAULT_FDT_FILE="rk3188-radxarock.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x10080800 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_RANDOM_UUID=y diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 9ba8d79e3103..14887dd2c9c7 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -25,6 +25,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk1p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 5dcd80cfbe30..0edc9e475b24 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index d6c30e2b5614..438b8e74b8f3 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -24,6 +24,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 49e2a735605f..0a471a58fcc0 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -26,6 +26,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk1p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 9bb4a07546a8..908370288f8b 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p1 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index f0995da20a77..6cf344f7afdb 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -24,6 +24,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index a6682462f170..1b1e9136a0e5 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 548b0b87c0ba..c6e2d76b81f8 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -26,6 +26,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwai # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 0e366653465c..a4409d8ac8fd 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 824fa2768cb6..e4b17c6630ad 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 9f15c9770597..ff8fd4eed46b 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -25,6 +25,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 38a8b1c3b42d..b147077dd5fa 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -22,6 +22,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 89cfee44ba6a..5982498f8d18 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 9e2e1a95fb41..c9aa1368d16f 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -26,6 +26,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwai # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index b830b8f653c2..544d5720a2b0 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index c6ab3fd61aac..781865915626 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 6d4692efd174..c1837f2dd623 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -18,6 +18,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index 12387d438651..da91df8e1c1a 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -16,6 +16,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 0a2c7d95101a..643bc01e1b9e 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_SEABOARD=y CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SPL_TEXT_BASE=0x108000 CONFIG_SYS_PROMPT="Tegra20 (SeaBoard) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 09196d7bb8e5..b0116504334f 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -19,6 +19,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0xE6300000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/sksimx6_defconfig b/configs/sksimx6_defconfig index b614f97fc9bf..b6ea6fc18e54 100644 --- a/configs/sksimx6_defconfig +++ b/configs/sksimx6_defconfig @@ -23,6 +23,7 @@ CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_VERSION_VARIABLE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index c86fde7399be..49f6e8817cd6 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -14,6 +14,7 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x2023400 CONFIG_SYS_PROMPT="SMDK5250 # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index e92472ecc713..1ba335fdf918 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x2024410 CONFIG_SYS_PROMPT="SMDK5420 # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 681cbf05728a..fe113efafc28 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -7,6 +7,7 @@ CONFIG_IDENT_STRING=" for SMDKC210/V310" CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x2021410 CONFIG_SYS_PROMPT="SMDKV310 # " # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPT=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index deb22618e919..ef6f77ba7a3e 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -8,6 +8,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SPL_TEXT_BASE=0x40200000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 86a668ff3393..e870f20950e1 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x2023400 CONFIG_SYS_PROMPT="snow # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index f321a0ac3bc4..4c08a3ec4534 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_DEFAULT_FDT_FILE="socfpga_arria10_socdk_sdmmc.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0xFFE00000 CONFIG_SPL_FPGA_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_CMD_ASKENV=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 2f040926490a..4a853e275bfe 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_FDT_FILE="socfpga_arria5_socdk.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 2625aadf4024..2ce10310604c 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_socdk.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index b6f4f8a3dd2f..aecaee869568 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 9a89bb5d689b..8306c6e94fc8 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_de0_nano_soc.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index db516891ba7d..27b29ac9f701 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_de10_nano.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index 5bed7557238b..119fc6842922 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_de1_soc.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index cd7211d202ba..e6eacb4c2bd4 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y CONFIG_CMD_ASKENV=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 4c17d1a9e4a5..a98ccd51f221 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_sockit.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 45fd78a15cd4..bf76a187fb0c 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_socrates.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index d984047bfe63..62f3612cdf7f 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -18,6 +18,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 9e6d582ee3af..fa9973c2860f 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -8,6 +8,7 @@ CONFIG_IDENT_STRING="socfpga_stratix10" CONFIG_SPL_FS_FAT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=5 +CONFIG_SPL_TEXT_BASE=0xFFE00000 CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SOCFPGA_STRATIX10 # " diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 3eba09dcb16a..1a010109a2cd 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -19,6 +19,7 @@ CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/sopine_baseboard_defconfig b/configs/sopine_baseboard_defconfig index 9d7e3a2b6c29..dd4d669977e4 100644 --- a/configs/sopine_baseboard_defconfig +++ b/configs/sopine_baseboard_defconfig @@ -11,6 +11,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_SPL_SPI_SUNXI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x10060 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/spring_defconfig b/configs/spring_defconfig index c0084289d96b..e866103aa71a 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x2023400 CONFIG_SYS_PROMPT="spring # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 121e96280895..b93efb34c6ae 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -12,6 +12,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x8000000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index d20b2ab35084..a03e61722605 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_TARGET_STM32MP1=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_TEXT_BASE=0x2FFC2500 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index 552cf55df5d5..f50320cf314b 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -19,6 +19,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_VERSION_VARIABLE=y +CONFIG_SPL_TEXT_BASE=0xE6300000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/sun8i_a23_evb_defconfig b/configs/sun8i_a23_evb_defconfig index fa53d254ea99..a7e5dd3600c3 100644 --- a/configs/sun8i_a23_evb_defconfig +++ b/configs/sun8i_a23_evb_defconfig @@ -9,6 +9,7 @@ CONFIG_USB0_VBUS_DET="axp_vbus_detect" CONFIG_USB1_VBUS_PIN="PH7" CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index b4b25de2034d..06c660bea724 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index 01c75542532d..9ac1d882ce1d 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_TAO3530=y CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=3 +CONFIG_SPL_TEXT_BASE=0x40200800 # CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="TAO-3530 # " diff --git a/configs/tbs_a711_defconfig b/configs/tbs_a711_defconfig index 007ff89348e0..b8e9da5197d5 100644 --- a/configs/tbs_a711_defconfig +++ b/configs/tbs_a711_defconfig @@ -13,6 +13,7 @@ CONFIG_USB0_ID_DET="PH11" CONFIG_AXP_GPIO=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_TEXT_BASE=0x60 # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 0d8267f8a461..3f0f6a3318f0 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Tegra30 (TEC-NG) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 7017aade6860..3109def2ea51 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x108000 CONFIG_SYS_PROMPT="Tegra20 (TEC) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index a7d02e957afb..5a2ef3f5181d 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -20,6 +20,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index c4c3dd9e404f..72d58097656a 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x40300000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_YMODEM_SUPPORT=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 2e8a5980e63f..bf877f596b42 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x40400000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 68adf7635bff..29a61baeb823 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -16,6 +16,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_DEFAULT_FDT_FILE="rk3288-tinker.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0xFF704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 300f3faf6b34..40e3c2369187 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=0 CONFIG_SILENT_CONSOLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP3 Tricorder # " # CONFIG_CMD_IMI is not set diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index ab2b15111d07..cf5907f3ac85 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SYS_EXTRA_OPTIONS="FLASHCARD" CONFIG_BOOTDELAY=0 CONFIG_SILENT_CONSOLE=y +CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set CONFIG_CMD_EEPROM=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 5c2cc31e0abe..23bb652daae5 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x108000 CONFIG_SYS_PROMPT="Tegra20 (TrimSlice) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/ts4600_defconfig b/configs/ts4600_defconfig index 8062532396c5..c979a2c8760f 100644 --- a/configs/ts4600_defconfig +++ b/configs/ts4600_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 7e5943b10851..9be01d38dd6b 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y # CONFIG_CMD_FLASH is not set diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 04c713f28aa7..5e6af17a1fb2 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -7,6 +7,7 @@ CONFIG_EMIF4=y CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=10 +CONFIG_SPL_TEXT_BASE=0x40200000 # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index a8cec9bb306d..5cd93acf15df 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index eac1dc9aeecd..653574b0accd 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index de9182eba358..eb7061a84033 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTCOMMAND="run ${bootdev}script; run ${bootdev}boot" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="env exist ${bootdev}preboot && run ${bootdev}preboot" CONFIG_LOGLEVEL=6 +CONFIG_SPL_TEXT_BASE=0x40000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_CMD_CONFIG=y diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index bb9ce1a59bb6..0d6775399799 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -12,6 +12,7 @@ CONFIG_BOOTCOMMAND="run ${bootdev}script; run ${bootdev}boot" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="env exist ${bootdev}preboot && run ${bootdev}preboot" CONFIG_LOGLEVEL=6 +CONFIG_SPL_TEXT_BASE=0x100000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_CMD_CONFIG=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 55c34ca8ed4b..636c0e3bab57 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +CONFIG_SPL_TEXT_BASE=0x80108000 CONFIG_SYS_PROMPT="Tegra124 (Venice2) # " # CONFIG_CMD_IMI is not set CONFIG_CMD_DFU=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 4cb0fef51a68..e355e3180bef 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_VENTANA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SPL_TEXT_BASE=0x108000 CONFIG_SYS_PROMPT="Tegra20 (Ventana) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 5725487446b5..1bf0afd46881 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index d57c06ae139b..58088783718f 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index 1b62c6899bf1..68b770218ce7 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -11,6 +11,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 00c219f04689..2927d1225ca9 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -12,6 +12,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/woodburn/imximage.cfg" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x10002300 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 25b9e885d8e6..2edec7dc3f32 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -19,6 +19,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC=y CONFIG_MISC_INIT_R=y +CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_CMD_MEMINFO=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index a96f54c73713..971350b651aa 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -14,6 +14,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0xD2800B00 CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="X600> " diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 6046ebe9e79a..3e8dca293764 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -18,6 +18,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index a49fb84c11fc..7530866eaef3 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -11,6 +11,7 @@ CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_TEXT_BASE=0xFFFC0000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="ZynqMP> " diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index 658ea6ddcd44..4a9a67e2d9bb 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -11,6 +11,7 @@ CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_TEXT_BASE=0xFFFC0000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="ZynqMP> " diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index ba521876b75f..ff36f957a7a8 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -11,6 +11,7 @@ CONFIG_NR_DRAM_BANKS=1 # CONFIG_IMAGE_FORMAT_LEGACY is not set # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_zc1232_revA_defconfig b/configs/xilinx_zynqmp_zc1232_revA_defconfig index 80a310fb1cee..eb73439db56b 100644 --- a/configs/xilinx_zynqmp_zc1232_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1232_revA_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1254_revA_defconfig b/configs/xilinx_zynqmp_zc1254_revA_defconfig index 75ec572827bf..a2003d9f4886 100644 --- a/configs/xilinx_zynqmp_zc1254_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1254_revA_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1275_revA_defconfig b/configs/xilinx_zynqmp_zc1275_revA_defconfig index 731bd06d26f4..eb1aa557f1bf 100644 --- a/configs/xilinx_zynqmp_zc1275_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revA_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1275_revB_defconfig b/configs/xilinx_zynqmp_zc1275_revB_defconfig index aa44f0424337..afadaa8b5266 100644 --- a/configs/xilinx_zynqmp_zc1275_revB_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revB_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index bf141c5e168a..fb705f4283f4 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 01c29c0e70a3..d20df426f6df 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig index 439f89e50f3c..47dabd8ff030 100644 --- a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 6f14234a590e..d67cd3687da6 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index f1970aadf417..37d0c20d72d2 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu100_revC_defconfig b/configs/xilinx_zynqmp_zcu100_revC_defconfig index 6e0767164c7e..34d31a011184 100644 --- a/configs/xilinx_zynqmp_zcu100_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu100_revC_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index 371e6363db2f..b4bf18180467 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index a0fb6c3586cc..6863aa84d5f9 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index db7c093d5ebc..a93bead8c2eb 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu104_revA_defconfig b/configs/xilinx_zynqmp_zcu104_revA_defconfig index eacf75d9f8e2..9692a27493b2 100644 --- a/configs/xilinx_zynqmp_zcu104_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revA_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu104_revC_defconfig b/configs/xilinx_zynqmp_zcu104_revC_defconfig index 1c9a6d6f1ec4..b827a7e08eb9 100644 --- a/configs/xilinx_zynqmp_zcu104_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revC_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index 1b685ca04925..6304615369ca 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu111_revA_defconfig b/configs/xilinx_zynqmp_zcu111_revA_defconfig index 74106d7ea8fa..613c3d26ef67 100644 --- a/configs/xilinx_zynqmp_zcu111_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu111_revA_defconfig @@ -13,6 +13,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_TEXT_BASE=0xFFFC0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index 908d92e96f83..584db344faa4 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index cca1f2ddd314..fa1c4750a73e 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx6q-zc5202.dtb" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index cfe80b38de5e..59ef59659367 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx6q-zc5601.dtb" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_TEXT_BASE=0x908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 42b333721611..e4990a9f0172 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -17,7 +17,6 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #else #define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xFFFD8000 #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 71e840a4b8d5..10ba2abe40bb 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -24,7 +24,6 @@ #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin"
-#define CONFIG_SPL_TEXT_BASE 0xFFFFE000 #define CONFIG_SPL_MAX_SIZE 8192 #define CONFIG_SPL_RELOC_TEXT_BASE 0x00100000 #define CONFIG_SPL_RELOC_STACK 0x00100000 diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index f385509dafe9..02a73fd619dc 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -32,7 +32,6 @@ #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin"
-#define CONFIG_SPL_TEXT_BASE 0xFFFFE000 #define CONFIG_SPL_MAX_SIZE 8192 #define CONFIG_SPL_RELOC_TEXT_BASE 0x00100000 #define CONFIG_SPL_RELOC_STACK 0x00100000 diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index ebf44b5529c3..c9198c4abf80 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -33,7 +33,6 @@ #define CONFIG_SPL_INIT_MINIMAL #define CONFIG_SPL_NAND_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xff800000 #define CONFIG_SPL_MAX_SIZE 8192 #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0xf8f80000 diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index cfa5b5652488..a47b4db82e2d 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -27,7 +27,6 @@ #define CONFIG_NS16550_MIN_FUNCTIONS #endif
-#define CONFIG_SYS_TEXT_BASE_SPL 0xfff00000 #define CONFIG_SPL_MAX_SIZE (4 * 1024) #define CONFIG_SPL_PAD_TO 0x4000
@@ -39,7 +38,7 @@ #define CONFIG_SYS_NAND_U_BOOT_RELOC_SP (CONFIG_SYS_NAND_U_BOOT_RELOC + 0x10000)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE_SPL /* start of monitor */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE /* start of monitor */ #endif
#endif /* CONFIG_NAND */ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 134ffe52714f..f94203a86073 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -16,7 +16,6 @@ #ifdef CONFIG_SDCARD #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_TEXT_BASE 0xD0001000 #define CONFIG_SPL_PAD_TO 0x18000 #define CONFIG_SPL_MAX_SIZE (96 * 1024) #define CONFIG_SYS_MMC_U_BOOT_SIZE (512 << 10) @@ -39,7 +38,6 @@ #define CONFIG_SPL_SPI_FLASH_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_TEXT_BASE 0xD0001000 #define CONFIG_SPL_PAD_TO 0x18000 #define CONFIG_SPL_MAX_SIZE (96 * 1024) #define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (512 << 10) @@ -62,7 +60,6 @@ #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin"
-#define CONFIG_SPL_TEXT_BASE 0xFFFFE000 #define CONFIG_SPL_MAX_SIZE 8192 #define CONFIG_SPL_RELOC_TEXT_BASE 0x00100000 #define CONFIG_SPL_RELOC_STACK 0x00100000 @@ -88,7 +85,6 @@ #define CONFIG_SPL_INIT_MINIMAL #define CONFIG_SPL_NAND_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xff800000 #define CONFIG_SPL_MAX_SIZE 8192 #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0xD0000000 diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 3ccfeca890bc..06690459b2ff 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -13,7 +13,6 @@ #ifdef CONFIG_SDCARD #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_TEXT_BASE 0xf8f81000 #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_MMC_U_BOOT_SIZE (768 << 10) @@ -32,7 +31,6 @@ #define CONFIG_SPL_SPI_FLASH_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_TEXT_BASE 0xf8f81000 #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (768 << 10) @@ -67,7 +65,6 @@ #elif defined(CONFIG_SPL_BUILD) #define CONFIG_SPL_INIT_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xff800000 #define CONFIG_SPL_MAX_SIZE 4096 #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0xf8f80000 diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index c63dfd318680..1341b2c3d840 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -29,7 +29,6 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_SYS_FSL_PBL_PBI board/freescale/t102xqds/t1024_pbi.cfg #define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xFFFD8000 #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index b0f93abf983c..32bcfa3aa0f5 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -32,7 +32,6 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_SYS_FSL_PBL_PBI board/freescale/t102xrdb/t1024_pbi.cfg #define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xFFFD8000 #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 4cecab3401e9..92f6809679e1 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -21,7 +21,6 @@ #endif
#define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xFFFD8000 #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #ifdef CONFIG_SPL_BUILD diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 9ca384cc0caf..8d07f82590d0 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -36,7 +36,6 @@ #define CONFIG_SYS_FSL_PBL_PBI board/freescale/t208xqds/t208x_pbi.cfg
#define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xFFFD8000 #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 446e4268ef68..c0b1b0e46b89 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_FSL_PBL_PBI board/freescale/t208xrdb/t2080_pbi.cfg
#define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xFFFD8000 #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 06939015d042..13c825e778a4 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -21,7 +21,6 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #else #define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xFFFD8000 #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index f42a4f4af0fb..7f927767b929 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -21,7 +21,6 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #else #define CONFIG_SPL_FLUSH_IMAGE -#define CONFIG_SPL_TEXT_BASE 0xFFFD8000 #define CONFIG_SPL_PAD_TO 0x40000 #define CONFIG_SPL_MAX_SIZE 0x28000 #define RESET_VECTOR_OFFSET 0x27FFC diff --git a/include/configs/alt.h b/include/configs/alt.h index 3f7f379e06c4..c924e64a40c3 100644 --- a/include/configs/alt.h +++ b/include/configs/alt.h @@ -42,7 +42,6 @@ "bootm_size=0x10000000\0"
/* SPL support */ -#define CONFIG_SPL_TEXT_BASE 0xe6300000 #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 3ce3814cbeec..2c510265cca8 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -218,7 +218,6 @@ GENERATED_GBL_DATA_SIZE)
/* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x40200800 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 300f56541ed0..9475e9975d5a 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -189,8 +189,6 @@ #define CONFIG_ENV_ADDR 0x260000
/* Defines for SPL */ -#undef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_TEXT_BASE 0x40200000
#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index ed71f4ce56ac..2f6b91ba3e9a 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -35,7 +35,6 @@ #define CONFIG_POWER_TPS62362
/* SPL defines. */ -#define CONFIG_SPL_TEXT_BASE CONFIG_ISW_ENTRY_ADDR #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (128 << 20))
diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index 9ce5b6e8241e..b043bf886bf8 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -19,11 +19,6 @@ #define CONFIG_SYS_SDRAM_BASE1 0x880000000
/* SPL Loader Configuration */ -#ifdef CONFIG_TARGET_AM654_A53_EVM -#define CONFIG_SPL_TEXT_BASE 0x80080000 -#else -#define CONFIG_SPL_TEXT_BASE 0x41c00000 -#endif
#ifdef CONFIG_SYS_K3_SPL_ATF #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "tispl.bin" diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 1cee2fa2920e..b7a7ec5ee0c7 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -27,7 +27,6 @@ */ #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_MAX_SIZE 2048 -#define CONFIG_SPL_TEXT_BASE 0xA0000000
/* NAND boot config */ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 0958d63c9409..044c428a716a 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -96,7 +96,6 @@ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000)
/* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x300000 #define CONFIG_SPL_MAX_SIZE 0x010000 #define CONFIG_SPL_STACK 0x310000
diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 777a99b7305c..c41acd824147 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -136,7 +136,6 @@ #define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024)
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x300000 #define CONFIG_SPL_MAX_SIZE 0x6000 #define CONFIG_SPL_STACK 0x308000
diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 6adb965c3cd6..57010734a655 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -111,7 +111,6 @@ #define CONFIG_SYS_MALLOC_LEN (512 * 1024 + 0x1000)
diff --git a/include/configs/bur_am335x_common.h b/include/configs/bur_am335x_common.h index 1bbfa16660e8..42e3e568be78 100644 --- a/include/configs/bur_am335x_common.h +++ b/include/configs/bur_am335x_common.h @@ -41,7 +41,6 @@ * Y-MODEM to load u-boot.img, when booted over UART. We must also include * the scratch space that U-Boot uses in SRAM. */ -#define CONFIG_SPL_TEXT_BASE 0x402F0400 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
diff --git a/include/configs/chromebook_link.h b/include/configs/chromebook_link.h index ee546d8f8933..ca592768925e 100644 --- a/include/configs/chromebook_link.h +++ b/include/configs/chromebook_link.h @@ -18,8 +18,6 @@ #define CONFIG_ENV_SECT_SIZE 0x1000 #define CONFIG_ENV_OFFSET 0x003f8000
-#define CONFIG_SPL_TEXT_BASE 0xfffd0000 - #define BOOT_DEVICE_SPI 10
#define CONFIG_SPL_BOARD_LOAD_IMAGE diff --git a/include/configs/ci20.h b/include/configs/ci20.h index 9a3621329dcb..21a86323c267 100644 --- a/include/configs/ci20.h +++ b/include/configs/ci20.h @@ -59,7 +59,6 @@ /* SPL */ #define CONFIG_SPL_STACK 0xf4008000 /* only max. 2KB spare! */
-#define CONFIG_SPL_TEXT_BASE 0xf4000a00 #define CONFIG_SPL_MAX_SIZE ((14 * 1024) - 0xa00)
#define CONFIG_SPL_BSS_START_ADDR 0xf4004000 diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index f9510826d7df..820eecab22fc 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -76,7 +76,6 @@
/* Defines for SPL */ #define CONFIG_SPL_SIZE (140 << 10) -#define CONFIG_SPL_TEXT_BASE 0x40000030 #define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - 0x0030)
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 8722841384f6..fd693cf25141 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -232,7 +232,6 @@ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000
diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 79eb865bf9c4..65739abca634 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -125,7 +125,6 @@ "fi;"
/* SPL defines. */ -#define CONFIG_SPL_TEXT_BASE 0x40300350 #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + (128 << 20)) #define CONFIG_SYS_SPI_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_MONITOR_LEN (512 * 1024) diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 06c93c3e664c..b63f7eeadb71 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -88,10 +88,8 @@ #define CONFIG_SPL_SIZE (160 << 10)
#if defined(CONFIG_SECURED_MODE_IMAGE) -#define CONFIG_SPL_TEXT_BASE 0x40002614 #define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - 0x2614) #else -#define CONFIG_SPL_TEXT_BASE 0x40000030 #define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - 0x30) #endif
diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 5dd5c28e08af..80c2cb0362f9 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -102,7 +102,6 @@ SZ_4M, 0x1000)
/* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x300000 #define CONFIG_SPL_MAX_SIZE (12 * SZ_1K) #define CONFIG_SPL_STACK (SZ_16K)
diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 14a3046f19e3..5ae3caa86abf 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -275,7 +275,6 @@ CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN #define CONFIG_SPL_STACK 0x8001ff00 -#define CONFIG_SPL_TEXT_BASE 0x80000000 #define CONFIG_SPL_MAX_FOOTPRINT 32768 #define CONFIG_SPL_PAD_TO 32768 #endif diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index 4c30077060f5..52534ab49750 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -64,7 +64,6 @@
/* SPL */ /* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x40004030 #define CONFIG_SPL_MAX_SIZE ((128 << 10) - 0x4030)
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 626a406cff81..9d1a3cc5e119 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -61,7 +61,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 1f328e97c545..2205f298c07d 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -81,7 +81,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 6cba3269278e..dbf2e8f718bf 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -74,7 +74,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 2f8c655b2cc4..ae9e4d4a2c88 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -157,7 +157,6 @@ * SPL specific defines */ /* SPL will be executed at offset 0 */ -#define CONFIG_SPL_TEXT_BASE 0x00000000
/* SPL will use SRAM as stack */ #define CONFIG_SPL_STACK 0x0000FFF8 diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 1b175be38707..2eb658dc6196 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -154,9 +154,6 @@
-#undef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/ - /* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 diff --git a/include/configs/ds414.h b/include/configs/ds414.h index 4ba050553a54..d8d5cd94e7c7 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -82,7 +82,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 645fc3ffb81c..a608c0f0a563 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -15,7 +15,6 @@ * SPL */
-#define CONFIG_SPL_TEXT_BASE 0xffff0000 #define CONFIG_SPL_MAX_SIZE 0x0000fff0 #define CONFIG_SPL_STACK 0x00020000 #define CONFIG_SPL_BSS_START_ADDR 0x00020000 diff --git a/include/configs/exynos5250-common.h b/include/configs/exynos5250-common.h index c3473f7ef820..65da3815fbd6 100644 --- a/include/configs/exynos5250-common.h +++ b/include/configs/exynos5250-common.h @@ -17,8 +17,6 @@
#define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024)
-#define CONFIG_SPL_TEXT_BASE 0x02023400 - #define CONFIG_IRAM_STACK 0x02050000
#define CONFIG_SYS_INIT_SP_ADDR CONFIG_IRAM_STACK diff --git a/include/configs/exynos5420-common.h b/include/configs/exynos5420-common.h index 3738c78d258e..2d362f396151 100644 --- a/include/configs/exynos5420-common.h +++ b/include/configs/exynos5420-common.h @@ -17,11 +17,6 @@
#define CONFIG_VAR_SIZE_SPL
-#ifdef CONFIG_VAR_SIZE_SPL -#define CONFIG_SPL_TEXT_BASE 0x02024410 -#else -#define CONFIG_SPL_TEXT_BASE 0x02024400 -#endif #define CONFIG_IRAM_TOP 0x02074000
#define CONFIG_SPL_MAX_FOOTPRINT (30 * 1024) diff --git a/include/configs/gose.h b/include/configs/gose.h index 8f0e37848819..0de0a362e3e2 100644 --- a/include/configs/gose.h +++ b/include/configs/gose.h @@ -38,7 +38,6 @@ "bootm_size=0x10000000\0"
/* SPL support */ -#define CONFIG_SPL_TEXT_BASE 0xe6300000 #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 diff --git a/include/configs/helios4.h b/include/configs/helios4.h index 4e98f19a4035..9bd07923ffd8 100644 --- a/include/configs/helios4.h +++ b/include/configs/helios4.h @@ -100,7 +100,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 3d9a7dc9023d..212dee7f28c5 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -20,7 +20,6 @@ * and some padding thus 'our' max size is really 0x00908000 - 0x00918000 * or 64KB */ -#define CONFIG_SPL_TEXT_BASE 0x00908000 #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_STACK 0x0091FFB8 /* diff --git a/include/configs/imx7_spl.h b/include/configs/imx7_spl.h index aca32dbabdca..7ef7017f51c7 100644 --- a/include/configs/imx7_spl.h +++ b/include/configs/imx7_spl.h @@ -21,7 +21,6 @@ * and some padding thus 'our' max size is really 0x00946BB8 - 0x00911000. * 64KB is more then enough for the SPL. */ -#define CONFIG_SPL_TEXT_BASE 0x00911000 #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_STACK 0x00946BB8 /* diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index a9e38a70e60f..08d241537d38 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -13,7 +13,6 @@ #define CONFIG_CSF_SIZE 0x2000 /* 8K region */ #endif
-#define CONFIG_SPL_TEXT_BASE 0x7E1000 #define CONFIG_SPL_MAX_SIZE (124 * 1024) #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index 312e30dc6c18..949cdb66ceb2 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -10,7 +10,6 @@ #include <asm/arch/imx-regs.h>
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_TEXT_BASE 0x0 #define CONFIG_SPL_MAX_SIZE (124 * 1024) #define CONFIG_SYS_MONITOR_LEN (1024 * 1024) #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index df9a8a088153..e4e8e2ad7a9b 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -212,7 +212,6 @@ CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN #define CONFIG_SPL_STACK 0x8001ff00 -#define CONFIG_SPL_TEXT_BASE 0x80000000 #define CONFIG_SPL_MAX_SIZE 0x20000 #define CONFIG_SPL_MAX_FOOTPRINT 32768
diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 9b1149b19026..59814b5514ce 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -70,7 +70,6 @@ * SPL */
-#define CONFIG_SPL_TEXT_BASE 0x40300000 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE) #define CONFIG_SPL_BSS_START_ADDR 0x80000000 diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index 33c8bd414976..c42139dc3ad5 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -38,7 +38,6 @@ "bootm_size=0x10000000\0"
/* SPL support */ -#define CONFIG_SPL_TEXT_BASE 0xe6300000 #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 diff --git a/include/configs/lager.h b/include/configs/lager.h index 89c5d01d3c5c..5acd5a21184b 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -39,7 +39,6 @@ "bootm_size=0x10000000\0"
/* SPL support */ -#define CONFIG_SPL_TEXT_BASE 0xe6300000 #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 4af3988886a6..ee570bc1a9cf 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -69,7 +69,6 @@ #define CONFIG_SPL_MMC_SUPPORT #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0xe8
-#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000 #define CONFIG_SPL_PAD_TO 0x1c000 diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index d75ac4e57ea2..3cbbd7392029 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -51,7 +51,6 @@ unsigned long get_board_ddr_clk(void); board/freescale/ls1021aqds/ls102xa_rcw_sd_ifc.cfg #endif
-#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000 #define CONFIG_SPL_PAD_TO 0x1c000 @@ -67,7 +66,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_NAND_BOOT #define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1021aqds/ls102xa_rcw_nand.cfg
-#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000 #define CONFIG_SPL_PAD_TO 0x1c000 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index da55bf2f43b2..7fe7bab8e41a 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -74,7 +74,6 @@ #define CONFIG_U_BOOT_HDR_SIZE (16 << 10) #endif /* ifdef CONFIG_SECURE_BOOT */
-#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000 #define CONFIG_SPL_PAD_TO 0x1c000 diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index f7e7877414f6..824a23ae8b01 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -64,7 +64,6 @@ /* SD boot SPL */ #ifdef CONFIG_SD_BOOT
-#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x17000 #define CONFIG_SPL_STACK 0x1001e000 #define CONFIG_SPL_PAD_TO 0x1d000 @@ -92,7 +91,6 @@ /* NAND SPL */ #ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PBL_PAD -#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000 #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index d9fcd3af5efa..00499d78c24e 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -63,7 +63,6 @@
/* SD boot SPL */ #ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1f000 /* 124 KiB */ #define CONFIG_SPL_STACK 0x10020000 #define CONFIG_SPL_PAD_TO 0x21000 /* 132 KiB */ @@ -89,7 +88,6 @@
#if defined(CONFIG_QSPI_BOOT) && defined(CONFIG_SPL) #define CONFIG_SPL_TARGET "spl/u-boot-spl.pbl" -#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1f000 #define CONFIG_SPL_STACK 0x10020000 #define CONFIG_SPL_PAD_TO 0x20000 @@ -114,7 +112,6 @@
#define CONFIG_SPL_NAND_SUPPORT #define CONFIG_SPL_DRIVERS_MISC_SUPPORT -#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x17000 /* 90 KiB */ #define CONFIG_SPL_STACK 0x1001f000 #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 50c18f154251..e8e1dc2d9201 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -228,7 +228,6 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SPL_MAX_SIZE 0x16000 #define CONFIG_SPL_STACK (CONFIG_SYS_FSL_OCRAM_BASE + 0x9ff0) #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_TEXT_BASE 0x1800a000
#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START 0x80200000 diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 454c9e94b66c..c7d8a3b6eb6c 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -208,7 +208,6 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SPL_MAX_SIZE 0x16000 #define CONFIG_SPL_STACK (CONFIG_SYS_FSL_OCRAM_BASE + 0x9ff0) #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_TEXT_BASE 0x1800a000
#ifdef CONFIG_NAND_BOOT #define CONFIG_SYS_NAND_U_BOOT_DST 0x80400000 diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 51456fbe5563..b67813747ec9 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -176,7 +176,6 @@ * NAND SPL */ #define CONFIG_SPL_TARGET "u-boot-with-nand-spl.imx" -#define CONFIG_SPL_TEXT_BASE 0x70008000 #define CONFIG_SPL_PAD_TO 0x8000 #define CONFIG_SPL_STACK 0x70004000
diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index d378333ab1b1..c24ee5a782f0 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -60,7 +60,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 5f7423b7172c..411c27c4a89d 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -246,7 +246,6 @@ #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC
-#define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/ #define CONFIG_SPL_MAX_SIZE (54 * 1024) /* 8 KB for stack */ #define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK
diff --git a/include/configs/mt7629.h b/include/configs/mt7629.h index 9910d8c89a6a..6e9b868aa490 100644 --- a/include/configs/mt7629.h +++ b/include/configs/mt7629.h @@ -33,7 +33,6 @@
/* Defines for SPL */ #define CONFIG_SPL_STACK 0x106000 -#define CONFIG_SPL_TEXT_BASE 0x201000 #define CONFIG_SPL_MAX_SIZE SZ_64K #define CONFIG_SPL_MAX_FOOTPRINT SZ_64K #define CONFIG_SPL_PAD_TO 0x10000 diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 4765764f83a9..858ab510371a 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -25,8 +25,6 @@ #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_MAX_SIZE 2048
-#define CONFIG_SPL_TEXT_BASE 0x87dc0000 - #ifndef CONFIG_SPL_BUILD #define CONFIG_SKIP_LOWLEVEL_INIT #endif diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 217167a21e4e..cc5d4c85fe9b 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -80,7 +80,6 @@ * As for the SPL, we must avoid the first 4 KiB as well, but we load the * IVT and CST to 0x8000, so we don't need to waste the subsequent 4 KiB. */ -#define CONFIG_SPL_TEXT_BASE 0x00001000
/* U-Boot general configuration */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 7698a90c4e98..f0c8c990fafc 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -17,8 +17,6 @@ * We are only ever GP parts and will utilize all of the "downloaded image" * area in SRAM which starts at 0x40200000 and ends at 0x4020FFFF (64KB). */ -#undef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_TEXT_BASE 0x40200000
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 07bcbc6f4ea7..5b9d8a57e3d3 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -22,8 +22,6 @@ * We are only ever GP parts and will utilize all of the "downloaded image" * area in SRAM which starts at 0x40200000 and ends at 0x4020FFFF (64KB). */ -#undef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_TEXT_BASE 0x40200000
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 521e1675e0ef..23d12c6a4e86 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -15,8 +15,6 @@ * We are only ever GP parts and will utilize all of the "downloaded image" * area in SRAM which starts at 0x40200000 and ends at 0x4020FFFF (64KB). */ -#undef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_TEXT_BASE 0x40200000
#define CONFIG_REVISION_TAG 1
diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index fe557f91caa7..2423dfae6d78 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -19,8 +19,6 @@ * area in SRAM which starts at 0x40200000 and ends at 0x4020FFFF (64KB) in * order to allow for BCH8 to fit in. */ -#undef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_TEXT_BASE 0x40200000
#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 35f3af4ae9ab..ea941dbb81ab 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -11,8 +11,6 @@ * We are only ever GP parts and will utilize all of the "downloaded image" * area in SRAM which starts at 0x40200000 and ends at 0x4020FFFF (64KB). */ -#undef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_TEXT_BASE 0x40200000
/* call misc_init_r */
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 2002444e425b..9229de45d9ca 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -269,7 +269,6 @@ CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN #define CONFIG_SPL_STACK 0x8001ff00 -#define CONFIG_SPL_TEXT_BASE 0x80000000 #define CONFIG_SPL_MAX_FOOTPRINT 32768 #define CONFIG_SPL_PAD_TO 32768 #endif diff --git a/include/configs/origen.h b/include/configs/origen.h index 1acc42f964d4..1075084ba32f 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -44,7 +44,6 @@
/* MMC SPL */ #define COPY_BL2_FNPTR_ADDR 0x02020030 -#define CONFIG_SPL_TEXT_BASE 0x02021410
#define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x40007000\0" \ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 8fda0c1e226c..4f91a2db1250 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -137,7 +137,6 @@ #ifdef CONFIG_SDCARD #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_TEXT_BASE 0xf8f81000 #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_MMC_U_BOOT_SIZE (768 << 10) @@ -156,7 +155,6 @@ #define CONFIG_SPL_SPI_FLASH_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_TEXT_BASE 0xf8f81000 #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SPL_MAX_SIZE (128 * 1024) #define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (768 << 10) @@ -188,7 +186,6 @@ #define CONFIG_SPL_INIT_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_TEXT_BASE 0xff800000 #define CONFIG_SPL_MAX_SIZE 4096 #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0xf8f80000 diff --git a/include/configs/pcl063.h b/include/configs/pcl063.h index 4ceab519cbc5..12d8d67f0ff8 100644 --- a/include/configs/pcl063.h +++ b/include/configs/pcl063.h @@ -21,8 +21,6 @@ * * Tweak the SPL text base address to avoid this. */ -#undef CONFIG_SPL_TEXT_BASE -#define CONFIG_SPL_TEXT_BASE 0x00909000
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M) diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index c2882e6daf6c..ad41d161493a 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -104,7 +104,6 @@ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000)
diff --git a/include/configs/porter.h b/include/configs/porter.h index 9950f80afd7d..1db28869cd0c 100644 --- a/include/configs/porter.h +++ b/include/configs/porter.h @@ -43,7 +43,6 @@ "bootm_size=0x10000000\0"
/* SPL support */ -#define CONFIG_SPL_TEXT_BASE 0xe6300000 #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h index 4b9ddd6f2589..4cd1cac3bd2b 100644 --- a/include/configs/qemu-x86.h +++ b/include/configs/qemu-x86.h @@ -35,8 +35,6 @@
/* SPI is not supported */
#define CONFIG_SPL_BOARD_LOAD_IMAGE diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 4fc9226712d9..ed9a70056139 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -19,7 +19,6 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x60100000 #define CONFIG_SYS_LOAD_ADDR 0x60800800 #define CONFIG_SPL_STACK 0x10081fff -#define CONFIG_SPL_TEXT_BASE 0x10081000
#define CONFIG_ROCKCHIP_MAX_INIT_SIZE (4 << 10) #define CONFIG_ROCKCHIP_CHIP_TAG "RK30" diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index 36e494ee95a9..6e62667144e5 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -26,7 +26,6 @@ #define CONFIG_ROCKCHIP_MAX_INIT_SIZE (0x8000 - 0x800) #define CONFIG_ROCKCHIP_CHIP_TAG "RK31"
-#define CONFIG_SPL_TEXT_BASE 0x10080800 /* spl size 32kb sram - 2kb bootrom */ #define CONFIG_SPL_MAX_SIZE (0x8000 - 0x800) #define CONFIG_ROCKCHIP_SERIAL 1 diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index e72aa8d2d384..22eb064fadc3 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -20,7 +20,6 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x60100000 #define CONFIG_SYS_LOAD_ADDR 0x60800800 #define CONFIG_SPL_STACK 0x10088000 -#define CONFIG_SPL_TEXT_BASE 0x10081000
#define CONFIG_ROCKCHIP_MAX_INIT_SIZE (28 << 10) #define CONFIG_ROCKCHIP_CHIP_TAG "RK32" diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index c59f5eff7a98..c706c513f691 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -23,11 +23,6 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x00100000 #define CONFIG_SYS_LOAD_ADDR 0x00800800 #define CONFIG_SPL_STACK 0xff718000 -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_TPL_BOOTROM_SUPPORT) -# define CONFIG_SPL_TEXT_BASE 0x0 -#else -# define CONFIG_SPL_TEXT_BASE 0xff704000 -#endif
/* RAW SD card / eMMC locations. */ #define CONFIG_SYS_SPI_U_BOOT_OFFS (128 << 10) diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 88c1af0974ce..cf51f25bf343 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x00300000 #define CONFIG_SYS_LOAD_ADDR 0x00280000
-#define CONFIG_SPL_TEXT_BASE 0x00000000 #define CONFIG_SPL_MAX_SIZE 0x40000 #define CONFIG_SPL_BSS_START_ADDR 0x400000 #define CONFIG_SPL_BSS_MAX_SIZE 0x20000 diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index b977b1faa731..b71da0d1776f 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -19,7 +19,6 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x00300000 #define CONFIG_SYS_LOAD_ADDR 0x00800800 #define CONFIG_SPL_STACK 0xff8effff -#define CONFIG_SPL_TEXT_BASE 0xff8c2000 #define CONFIG_SPL_MAX_SIZE 0x30000 - 0x2000 /* BSS setup */ #define CONFIG_SPL_BSS_START_ADDR 0xff8e0000 diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h index 7c7479b4d4c4..e32c6b234e75 100644 --- a/include/configs/sama5d27_som1_ek.h +++ b/include/configs/sama5d27_som1_ek.h @@ -57,7 +57,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x200000 #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index 2cec1c7b42fb..7eec104d27c8 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -52,7 +52,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x200000 #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 8a9a19d38e61..696933da73d0 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -58,7 +58,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x300000 #define CONFIG_SPL_MAX_SIZE 0x18000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index ca1c2b0861a3..192a96c5d7ae 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -76,7 +76,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x300000 #define CONFIG_SPL_MAX_SIZE 0x18000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index bbb16993ec40..14653fecd506 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -40,7 +40,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x200000 #define CONFIG_SPL_MAX_SIZE 0x18000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index d58041650cfc..a220bb836da5 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -40,7 +40,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x200000 #define CONFIG_SPL_MAX_SIZE 0x18000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index d8ed02bf7955..cc77355f3de8 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -88,7 +88,6 @@ #define CONFIG_SYS_I2C
/* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x402F0400 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
diff --git a/include/configs/silk.h b/include/configs/silk.h index 112806c342b7..c42b57ab2a6e 100644 --- a/include/configs/silk.h +++ b/include/configs/silk.h @@ -43,7 +43,6 @@ "bootm_size=0x10000000\0"
/* SPL support */ -#define CONFIG_SPL_TEXT_BASE 0xe6300000 #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 28af575bf203..d31cd90a31ce 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -174,7 +174,6 @@ #endif
/* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x0 #define CONFIG_SPL_MAX_SIZE (SZ_4K)
#define CONFIG_SPL_BSS_START_ADDR CONFIG_SYS_SDRAM_BASE diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 6da713728fe2..68af0ef450fc 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -37,8 +37,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #define COPY_BL2_FNPTR_ADDR 0x00002488
-#define CONFIG_SPL_TEXT_BASE 0x02021410 - #define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000"
/* Miscellaneous configurable options */ diff --git a/include/configs/sniper.h b/include/configs/sniper.h index aa78684b02fc..540ea77ce03d 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -64,7 +64,6 @@ * SPL */
-#define CONFIG_SPL_TEXT_BASE 0x40200000 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE) #define CONFIG_SPL_BSS_START_ADDR 0x80000000 diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 181af9b646a3..eadab2e79a23 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -248,7 +248,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * 0xFFEz_zzzz ...... Malloc area (grows up to top) * 0xFFE3_FFFF ...... End of SRAM (top) */ -#define CONFIG_SPL_TEXT_BASE CONFIG_SYS_INIT_RAM_ADDR #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE
#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index 0e73239f568c..d22b7e4177a9 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -201,7 +201,6 @@ unsigned int cm_get_l4_sys_free_clk_hz(void); * */ #define CONFIG_SPL_TARGET "spl/u-boot-spl.hex" -#define CONFIG_SPL_TEXT_BASE CONFIG_SYS_INIT_RAM_ADDR #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE #define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR #define CONFIG_SPL_BSS_MAX_SIZE 0x100000 /* 1 MB */ diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index dae402f91b8c..d75c095df7ff 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -61,7 +61,6 @@ /* For SPL */ #ifdef CONFIG_SUPPORT_SPL #define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR -#define CONFIG_SPL_TEXT_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_SPL_LEN 0x00008000 #define CONFIG_SYS_UBOOT_START 0x080083FD diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 701298cab88b..11c0a68616d7 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -56,7 +56,6 @@ /* SPL support */ #ifdef CONFIG_SPL /* BOOTROM load address */ -#define CONFIG_SPL_TEXT_BASE 0x2FFC2500 /* SPL use DDR */ #define CONFIG_SPL_BSS_START_ADDR 0xC0200000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 diff --git a/include/configs/stout.h b/include/configs/stout.h index 93d980569c99..4a465e01bd3c 100644 --- a/include/configs/stout.h +++ b/include/configs/stout.h @@ -47,7 +47,6 @@ "bootm_size=0x10000000\0"
/* SPL support */ -#define CONFIG_SPL_TEXT_BASE 0xe6300000 #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b01d1c3c8435..2bf4e74bf61c 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -184,7 +184,6 @@ * autoconf.mk. */ #if CONFIG_SUNXI_SRAM_ADDRESS == 0x10000 -#define CONFIG_SPL_TEXT_BASE 0x10060 /* sram start+header */ #define CONFIG_SPL_MAX_SIZE 0x7fa0 /* 32 KiB */ #ifdef CONFIG_ARM64 /* end of SRAM A2 for now, as SRAM A1 is pretty tight for an ARM64 build */ @@ -193,12 +192,10 @@ #define LOW_LEVEL_SRAM_STACK 0x00018000 #endif /* !CONFIG_ARM64 */ #elif CONFIG_SUNXI_SRAM_ADDRESS == 0x20000 -#define CONFIG_SPL_TEXT_BASE 0x20060 /* sram start+header */ #define CONFIG_SPL_MAX_SIZE 0x7fa0 /* 32 KiB */ /* end of SRAM A2 on H6 for now */ #define LOW_LEVEL_SRAM_STACK 0x00118000 #else -#define CONFIG_SPL_TEXT_BASE 0x60 /* sram start+header */ #define CONFIG_SPL_MAX_SIZE 0x5fa0 /* 24KB on sun4i/sun7i */ #define LOW_LEVEL_SRAM_STACK 0x00008000 /* End of sram */ #endif diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index dd71d8984089..e7bab7203e49 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -142,7 +142,6 @@ #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC
-#define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/ #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE) #define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 1384a35c0cfe..a95cbed33aec 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -219,7 +219,6 @@ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000
diff --git a/include/configs/taurus.h b/include/configs/taurus.h index f283ab7fcab7..5703be00e389 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -133,7 +133,6 @@ ROUND(3 * CONFIG_ENV_SIZE + SZ_4M, 0x1000)
/* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x0 #define CONFIG_SPL_MAX_SIZE (31 * SZ_512) #define CONFIG_SPL_STACK (ATMEL_BASE_SRAM1 + SZ_16K) #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE - \ diff --git a/include/configs/tegra114-common.h b/include/configs/tegra114-common.h index 1aa44126455a..d3a704569767 100644 --- a/include/configs/tegra114-common.h +++ b/include/configs/tegra114-common.h @@ -54,7 +54,6 @@ "ramdisk_addr_r=0x83100000\0"
/* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x80108000 #define CONFIG_SYS_SPL_MALLOC_START 0x80090000 #define CONFIG_SPL_STACK 0x800ffffc
diff --git a/include/configs/tegra124-common.h b/include/configs/tegra124-common.h index 353068416423..522993b958ac 100644 --- a/include/configs/tegra124-common.h +++ b/include/configs/tegra124-common.h @@ -56,7 +56,6 @@ "ramdisk_addr_r=0x83100000\0"
diff --git a/include/configs/tegra20-common.h b/include/configs/tegra20-common.h index e58477e2898e..1e31d82574a6 100644 --- a/include/configs/tegra20-common.h +++ b/include/configs/tegra20-common.h @@ -55,7 +55,6 @@ "ramdisk_addr_r=0x03100000\0"
/* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x00108000 #define CONFIG_SYS_SPL_MALLOC_START 0x00090000 #define CONFIG_SPL_STACK 0x000ffffc
diff --git a/include/configs/tegra30-common.h b/include/configs/tegra30-common.h index 2d8948d9d983..54bc6756abef 100644 --- a/include/configs/tegra30-common.h +++ b/include/configs/tegra30-common.h @@ -51,7 +51,6 @@ "ramdisk_addr_r=0x83100000\0"
diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 886456ec26ee..b22b484efecb 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -99,7 +99,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + (128 << 10)) diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 05ba83b1f52c..512386ee222f 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -122,7 +122,6 @@ #define CONFIG_ENV_OVERWRITE
/* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x40300000 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index e622f4a00bea..fc5608b3fd47 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -90,7 +90,6 @@
/* SPL */ /* Defines for SPL */ -#define CONFIG_SPL_TEXT_BASE 0x40400000 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index 68f64655a799..0b9930e884ee 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -40,7 +40,6 @@ * supports X-MODEM loading via UART, and we leverage this and then use * Y-MODEM to load u-boot.img, when booted over UART. */ -#define CONFIG_SPL_TEXT_BASE CONFIG_ISW_ENTRY_ADDR #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (128 << 20))
diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 842b56bf0379..a9d069d9cbe0 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -32,7 +32,6 @@ #endif
/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE CONFIG_ISW_ENTRY_ADDR #define CONFIG_SPL_PAD_TO 65536 #define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_PAD_TO - 8) #define CONFIG_SPL_BSS_START_ADDR (CONFIG_ISW_ENTRY_ADDR + \ diff --git a/include/configs/ti_omap3_common.h b/include/configs/ti_omap3_common.h index c668284b3e44..5d9c8efe58f3 100644 --- a/include/configs/ti_omap3_common.h +++ b/include/configs/ti_omap3_common.h @@ -55,7 +55,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 << 10)
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x40200800 #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (64 << 20))
diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index 5d21c572f860..fc59aba1fa58 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -124,7 +124,6 @@ * SPL is overlapped with public stack and breaking non HS devices to boot. * So moving TEXT_BASE down to non-HS limit. */ -#define CONFIG_SPL_TEXT_BASE 0x40300000 #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (128 << 20))
diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index ba57c40182cc..351b5c9070a1 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -81,7 +81,6 @@ * RAM from address 0x40301350 (0x40300000+0x1000(reserved)+0x350(cert)). */ #define TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ 0x1000 -#define CONFIG_SPL_TEXT_BASE CONFIG_ISW_ENTRY_ADDR /* If no specific start address is specified then the secure EMIF * region will be placed at the end of the DDR space. In order to prevent * the main u-boot relocation from clobbering that memory and causing a @@ -95,7 +94,6 @@ * For all booting on GP parts, the flash loader image is * downloaded into internal RAM at address 0x40300000. */ -#define CONFIG_SPL_TEXT_BASE 0x40300000 #endif
#define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 13307fc1996a..683375a0df1a 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -219,7 +219,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1
diff --git a/include/configs/turris_omnia.h b/include/configs/turris_omnia.h index b90be65a4fb2..6c1181e6dacf 100644 --- a/include/configs/turris_omnia.h +++ b/include/configs/turris_omnia.h @@ -75,7 +75,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 1e509ce9ad7b..31a9c59ed5b3 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -229,9 +229,6 @@ /* only for SPL */ #if defined(CONFIG_ARCH_UNIPHIER_LD4) || \ defined(CONFIG_ARCH_UNIPHIER_SLD8) -#define CONFIG_SPL_TEXT_BASE 0x00040000 -#else -#define CONFIG_SPL_TEXT_BASE 0x00100000 #endif
#define CONFIG_SPL_STACK (0x00200000) diff --git a/include/configs/wb45n.h b/include/configs/wb45n.h index add4019b3115..43de2e111933 100644 --- a/include/configs/wb45n.h +++ b/include/configs/wb45n.h @@ -110,7 +110,6 @@ #define CONFIG_SYS_MALLOC_LEN (512 * 1024 + 0x1000)
diff --git a/include/configs/wb50n.h b/include/configs/wb50n.h index 2684b6c16c54..e3973d02a2a2 100644 --- a/include/configs/wb50n.h +++ b/include/configs/wb50n.h @@ -95,7 +95,6 @@ #define CONFIG_SYS_MALLOC_LEN (2 * 1024 * 1024)
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x300000 #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 diff --git a/include/configs/woodburn_sd.h b/include/configs/woodburn_sd.h index 06433d0e71f1..60d8a4b8c369 100644 --- a/include/configs/woodburn_sd.h +++ b/include/configs/woodburn_sd.h @@ -19,7 +19,6 @@ * SPL */
-#define CONFIG_SPL_TEXT_BASE 0x10002300 #define CONFIG_SPL_MAX_SIZE (64 * 1024) /* 8 KB for stack */ #define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK
diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index 67b5e9aa1131..8d97905a5951 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -138,7 +138,6 @@ */
/* SPL will be executed at offset 0 */ -#define CONFIG_SPL_TEXT_BASE 0x00000000 /* SPL will use SRAM as stack */ #define CONFIG_SPL_STACK 0x0000FFF8 /* Use the framework and generic lib */ diff --git a/include/configs/x530.h b/include/configs/x530.h index a83d49ba356e..d6d8214ff025 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -112,7 +112,6 @@
#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) diff --git a/include/configs/x600.h b/include/configs/x600.h index 639da8012c6f..c893752dcdf0 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -199,7 +199,6 @@ /* * SPL related defines */ -#define CONFIG_SPL_TEXT_BASE 0xd2800b00 #define CONFIG_SPL_MAX_SIZE (CONFIG_SRAM_SIZE - 0xb00) #define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/spear"
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 27a8e4d4906d..be078619bc6f 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -220,7 +220,6 @@ "dfu_bufsiz=0x1000\0" #endif
-#define CONFIG_SPL_TEXT_BASE 0xfffc0000 #define CONFIG_SPL_STACK 0xfffffffc #define CONFIG_SPL_MAX_SIZE 0x40000
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index a285fcdece73..920ee532e0aa 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -313,7 +313,6 @@ #endif
/* SP location before relocation, must use scratch RAM */ -#define CONFIG_SPL_TEXT_BASE 0x0
/* 3 * 64kB blocks of OCM - one is on the top because of bootrom */ #define CONFIG_SPL_MAX_SIZE 0x30000 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index db00376d92f6..b8262644c041 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1893,7 +1893,6 @@ CONFIG_SPL_STACK_ADDR CONFIG_SPL_STACK_SIZE CONFIG_SPL_START_S_PATH CONFIG_SPL_TARGET -CONFIG_SPL_TEXT_BASE CONFIG_SPL_UBI CONFIG_SPL_UBI_INFO_ADDR CONFIG_SPL_UBI_LEB_START
Hi Tom,
Am 19.03.2019 um 12:14 schrieb Tom Rini:
From: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing values.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com [trini: Re-run migration] Signed-off-by: Tom Rini trini@konsulko.com
Unfortunately, this clashes with Marek's last pull-request, where socfpga_common.h has changed in this exact area.
However, after manually fixing this merge conflict, everything works fine (tested on socfpga_socrates).
On 19/03/19 4:44 PM, Tom Rini wrote:
The ISW_ENTRY_ADDR Kconfig option under mach-omap2 isn't a SoC specific notion but rather "where is our previous stage loaded in memory?" option. Make use of this on ARCH_KEYSTONE rather than SPL_TEXT_BASE for our HS builds that are not using SPL anyhow.
Cc: Vitaly Andrianov vitalya@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Tom Rini trini@konsulko.com
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com?
On a related note, can we please move SRAM_SCRATCH_SPACE_ADDR to a more fixed location? The build logic here is going to break again when more
I guess you are talking about keystone2 devices. All omap platforms has sram scratch space as last 1K. Something similar can be done for keystone2 platforms as well.
Thanks and regards, Lokesh
SPL symbols move to Kconfig, thanks!
arch/arm/Kconfig | 15 +++++++++++++++ arch/arm/mach-omap2/Kconfig | 15 --------------- configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + include/configs/k2e_evm.h | 4 ---- include/configs/k2g_evm.h | 3 --- include/configs/k2hk_evm.h | 3 --- include/configs/k2l_evm.h | 3 --- include/configs/ti_armv7_keystone2.h | 5 +++-- 15 files changed, 26 insertions(+), 30 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f42eccef80dd..49904cac670e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1465,6 +1465,21 @@ config TI_SECURE_DEVICE authenticated) and the code. See the doc/README.ti-secure file for further details.
+if AM43XX || AM33XX || OMAP54XX || ARCH_KEYSTONE +config ISW_ENTRY_ADDR
- hex "Address in memory or XIP address of bootloader entry point"
- default 0x402F4000 if AM43XX
- default 0x402F0400 if AM33XX
- default 0x40301350 if OMAP54XX
- help
After any reset, the boot ROM searches the boot media for a valid
boot image. For non-XIP devices, the ROM then copies the image into
internal memory. For all boot modes, after the ROM processes the
boot image it eventually computes the entry point address depending
on the device type (secure/non-secure), boot media (xip/non-xip) and
image headers.
+endif
source "arch/arm/mach-aspeed/Kconfig"
source "arch/arm/mach-at91/Kconfig" diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 1cac4437d72c..d29f1ca0b58b 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -167,21 +167,6 @@ config TI_SECURE_EMIF_PROTECTED_REGION_SIZE using hardware memory firewalls. This value must be smaller than the TI_SECURE_EMIF_TOTAL_REGION_SIZE value.
-if AM43XX || AM33XX || OMAP54XX -config ISW_ENTRY_ADDR
- help
image headers.
-endif
source "arch/arm/mach-omap2/omap3/Kconfig"
source "arch/arm/mach-omap2/omap4/Kconfig" diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index a108f88dfd32..b16740173cf6 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_SYS_TEXT_BASE=0xC000000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 67f6fb1da5f4..682c2f4523dc 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 838b6f14b6d1..7401c4baf811 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC0A0000 CONFIG_SYS_TEXT_BASE=0xC000000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 93fa2360ad11..42fc68308eda 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y CONFIG_TI_SECURE_DEVICE=y +CONFIG_ISW_ENTRY_ADDR=0xC0A0000 CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2G_EVM=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index ce139d11d633..8034ae420089 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC200000 CONFIG_SYS_TEXT_BASE=0xC000000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index db61557f11da..79124226c7a3 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC200000 CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 368171d134b4..d810110b8396 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_SYS_TEXT_BASE=0xC000000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 7bb672f50c1e..aac396239238 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y +CONFIG_ISW_ENTRY_ADDR=0xC100000 CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index 2c0e4cbe92fd..547127490c92 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -40,10 +40,6 @@
#include <configs/ti_armv7_keystone2.h>
-/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE 0x0c100000
#define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS
/* NAND Configuration */ diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index 90f9a9922cab..3aeb9044f396 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -72,9 +72,6 @@ "bootm ${fit_loadaddr}#${name_fdt}" #endif
-/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE 0x0c0a0000
/* NAND Configuration */ #define CONFIG_SYS_NAND_PAGE_2K
diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index 0b909a1bf6fa..d4f2e96bab08 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -40,9 +40,6 @@
-/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE 0x0c200000
/* NAND Configuration */ diff --git a/include/configs/k2l_evm.h b/include/configs/k2l_evm.h index 59e6b096733a..cfdb36e2d7ff 100644 --- a/include/configs/k2l_evm.h +++ b/include/configs/k2l_evm.h @@ -40,9 +40,6 @@
/* NAND Configuration */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 0c7d66486832..842b56bf0379 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -22,7 +22,7 @@ /* Memory Configuration */ #define CONFIG_SYS_LPAE_SDRAM_BASE 0x800000000 #define CONFIG_MAX_RAM_BANK_SIZE (2 << 30) /* 2GB */ -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE - \ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_ISW_ENTRY_ADDR - \ GENERATED_GBL_DATA_SIZE)
#ifdef CONFIG_SYS_MALLOC_F_LEN @@ -32,9 +32,10 @@ #endif
/* SPL SPI Loader Configuration */ +#define CONFIG_SPL_TEXT_BASE CONFIG_ISW_ENTRY_ADDR #define CONFIG_SPL_PAD_TO 65536 #define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_PAD_TO - 8) -#define CONFIG_SPL_BSS_START_ADDR (CONFIG_SPL_TEXT_BASE + \ +#define CONFIG_SPL_BSS_START_ADDR (CONFIG_ISW_ENTRY_ADDR + \ CONFIG_SPL_MAX_SIZE) #define CONFIG_SPL_BSS_MAX_SIZE (32 * 1024) #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \
Thanks.
Well, as came up in another thread, that's not quite true for OMAP platforms. Today we shove it in such a location that stack could grow into it, and IFF what the am437x TRM says is true, we've been violating rules wrt stack placement since forever (that "public stack" is for ROM use only). We do shove sram scratch to the end of the download image area, yes. And yes, moving forward and given how big the download area is for keystone2, I would like to see scratch moved to the last 1K of download and stack put below that, for safety.
Hi Tom,
Thanks.
I see what you are talking about. Then CONFIG_SYS_INIT_SP_ADDR should be updated to SRAM_SCRATCH_SPACE_ADDR instead of NON_SECURE_SRAM_END. I am surprised we never faced an issue.
That public stack is used by ROM only while downloading the image. Once ROM completes the download it is available for use by any bootloader.
On Thu, Mar 21, 2019 at 11:02:37AM +0530, Lokesh Vutla wrote:
Hi Tom,
Thanks.
Keystone2 is "huge" and we got a bit lucky on AM335x/etc/etc until recently.
Ah, OK. I'll not worry too much that the TRM claims it's for the ROM only then and that'll save us some headroom on these otherwise constrained platforms.
Cc: Vitaly Andrianov vitalya@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com?
Lokesh Vutla
Simon Goldschmidt
