[PATCH v3 3/5] arm: dts: rockchip: move all rk3128 u-boot specific properties in separate dtsi files
Move all rk3128 u-boot specific properties in separate dtsi files. Sort emmc node.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com ---
Changed V2: Keep max-frequency property in dtsi --- arch/arm/dts/rk3128-evb-u-boot.dtsi | 7 +++++++ arch/arm/dts/rk3128-evb.dts | 10 +++++----- arch/arm/dts/rk3128-u-boot.dtsi | 19 +++++++++++++++++++ arch/arm/dts/rk3128.dtsi | 9 --------- 4 files changed, 31 insertions(+), 14 deletions(-) create mode 100644 arch/arm/dts/rk3128-evb-u-boot.dtsi create mode 100644 arch/arm/dts/rk3128-u-boot.dtsi
diff --git a/arch/arm/dts/rk3128-evb-u-boot.dtsi b/arch/arm/dts/rk3128-evb-u-boot.dtsi new file mode 100644 index 00000000..8b16bbe4 --- /dev/null +++ b/arch/arm/dts/rk3128-evb-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3128-u-boot.dtsi" + +&emmc { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3128-evb.dts b/arch/arm/dts/rk3128-evb.dts index a407ac2d..e7d8f7c9 100644 --- a/arch/arm/dts/rk3128-evb.dts +++ b/arch/arm/dts/rk3128-evb.dts @@ -37,6 +37,11 @@ }; };
+&emmc { + fifo-mode; + status = "okay"; +}; + &i2c1 { status = "okay";
@@ -74,11 +79,6 @@ status = "okay"; };
-&emmc { - fifo-mode; - status = "okay"; -}; - &pinctrl { usb_otg { otg_vbus_drv: host-vbus-drv { diff --git a/arch/arm/dts/rk3128-u-boot.dtsi b/arch/arm/dts/rk3128-u-boot.dtsi new file mode 100644 index 00000000..4a98e249 --- /dev/null +++ b/arch/arm/dts/rk3128-u-boot.dtsi @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rockchip-u-boot.dtsi" + +/ { + dmc: dmc@20004000 { + compatible = "rockchip,rk3128-dmc", "syscon"; + reg = <0x0 0x20004000 0x0 0x1000>; + u-boot,dm-pre-reloc; + }; +}; + +&cru { + u-boot,dm-pre-reloc; +}; + +&grf { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3128.dtsi b/arch/arm/dts/rk3128.dtsi index 5a1c1547..b58804b6 100644 --- a/arch/arm/dts/rk3128.dtsi +++ b/arch/arm/dts/rk3128.dtsi @@ -237,14 +237,7 @@ clock-names = "clk_nandc", "g_clk_nandc", "hclk_nandc"; };
- dmc: dmc@20004000 { - u-boot,dm-pre-reloc; - compatible = "rockchip,rk3128-dmc", "syscon"; - reg = <0x0 0x20004000 0x0 0x1000>; - }; - cru: clock-controller@20000000 { - u-boot,dm-pre-reloc; compatible = "rockchip,rk3128-cru"; reg = <0x20000000 0x1000>; rockchip,grf = <&grf>; @@ -453,7 +446,6 @@ };
emmc: dwmmc@1021c000 { - u-boot,dm-pre-reloc; compatible = "rockchip,rk3128-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x1021c000 0x4000>; max-frequency = <150000000>; @@ -538,7 +530,6 @@ };
grf: syscon@20008000 { - u-boot,dm-pre-reloc; compatible = "rockchip,rk3128-grf", "syscon"; reg = <0x20008000 0x1000>; };
Johan Jonker
