[U-Boot] [PATCH 1/2] bootm: active fdt support only on ppc, m68k and sparc as done in image.c
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- common/cmd_bootm.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 861712b..2b4df80 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -251,6 +251,7 @@ static int bootm_start(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) }
#if defined(CONFIG_OF_LIBFDT) +#if defined(CONFIG_PPC) || defined(CONFIG_M68K) || defined(CONFIG_SPARC) /* find flattened device tree */ ret = boot_get_fdt (flag, argc, argv, &images, &images.ft_addr, &images.ft_len); @@ -261,6 +262,7 @@ static int bootm_start(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
set_working_fdt_addr(images.ft_addr); #endif +#endif }
images.os.start = (ulong)os_hdr;
print load_end value not pointer
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- common/cmd_bootm.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 2b4df80..9c63e04 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -339,13 +339,13 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress) return BOOTM_ERR_UNIMPLEMENTED; } puts ("OK\n"); - debug (" kernel loaded at 0x%08lx, end = 0x%8p\n", load, load_end); + debug (" kernel loaded at 0x%08lx, end = 0x%08lx\n", load, *load_end); if (boot_progress) show_boot_progress (7);
if ((load < blob_end) && (*load_end > blob_start)) { debug ("images.os.start = 0x%lX, images.os.end = 0x%lx\n", blob_start, blob_end); - debug ("images.os.load = 0x%lx, load_end = 0x%p\n", load, load_end); + debug ("images.os.load = 0x%lx, load_end = 0x%lx\n", load, *load_end);
return BOOTM_ERR_OVERLAP; }
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 1220991504-20366-2-git-send-email-plagnioj@jcrosoft.com you wrote:
Applied, thanks.
Good catch!
In message 1220991504-20366-1-git-send-email-plagnioj@jcrosoft.com you wrote:
#endif +#endif
I think this is not correct. There are even PPC board where FDT support is not enabled because CONFIG_OF_LIBFDT is not set. Your patch would change that - what's wrong with enabling CONFIG_OF_LIBFDT for the boards where you want to use it?
Applied, thanks.
