[U-Boot] [PATCH v2] ARM: imx: Support larger SPL size on IMX6DQ
Previously the SPL size on all iMX6 platforms was restricted to 68KB because the OCRAM size on iMX6SL/DL parts is only 128KB. However, the other iMX6 variants have 256KB of OCRAM. Add an option CONFIG_MX6_OCRAM_256KB which allows using the full size on boards which don't need to support the SL/DL variants. This allows for an SPL size of 196KB, which makes it much easier to use configurations such as SPL with driver model and FDT control.
Signed-off-by: Robert Hancock hancock@sedsystems.ca ---
Changed since v2: Remove "default n" in Kconfig since that is the default.
arch/arm/mach-imx/mx6/Kconfig | 9 +++++++++ common/spl/Kconfig | 3 ++- include/configs/imx6_spl.h | 28 ++++++++++++++++++++++++++-- 3 files changed, 37 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index fe5991e..9c27176 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -87,6 +87,15 @@ config MX6ULL select SYSCOUNTER_TIMER select SYS_L2CACHE_OFF
+config MX6_OCRAM_256KB + bool "Support 256KB OCRAM" + depends on MX6D || MX6Q + help + Allows using the full 256KB size of the OCRAM on the MX6Q/MX6D series + of chips, such as for SPL. The OCRAM of the Lite series of chips is + only 128KB, so using this option will prevent the resulting code from + working on those chips. + config MX6_DDRCAL bool "Include dynamic DDR calibration routines" depends on SPL diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 54154b9..c5ad047 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -28,7 +28,8 @@ config SPL_FRAMEWORK config SPL_SIZE_LIMIT int "Maximum size of SPL image" depends on SPL - default 69632 if ARCH_MX6 + default 69632 if ARCH_MX6 && !MX6_OCRAM_256KB + default 200704 if ARCH_MX6 && MX6_OCRAM_256KB default 0 help Specifies the maximum length of the U-Boot SPL image. diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 212dee7..a223930 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -7,10 +7,32 @@ #define __IMX6_SPL_CONFIG_H
#ifdef CONFIG_SPL + +#ifdef CONFIG_MX6_OCRAM_256KB /* - * see Figure 8-3 in IMX6DQ/IMX6SDL Reference manuals: + * see Figure 8.4.1 in IMX6DQ Reference manuals: + * - IMX6DQ OCRAM (IRAM) is from 0x00907000 to 0x0093FFFF + * - BOOT ROM stack is at 0x0093FFB8 + * - if icache/dcache is enabled (eFuse/strapping controlled) then the + * IMX BOOT ROM will setup MMU table at 0x00938000, therefore we need to + * fit between 0x00907000 and 0x00938000. + * - Additionally the BOOT ROM loads what they consider the firmware image + * which consists of a 4K header in front of us that contains the IVT, DCD + * and some padding thus 'our' max size is really 0x00908000 - 0x00938000 + * or 192KB + */ +#define CONFIG_SPL_MAX_SIZE 0x30000 +#define CONFIG_SPL_STACK 0x0093FFB8 +/* + * Pad SPL to 196KB (4KB header + 192KB max size). This allows to write the + * SPL/U-Boot combination generated with u-boot-with-spl.imx directly to a + * boot media (given that boot media specific offset is configured properly). + */ +#define CONFIG_SPL_PAD_TO 0x31000 +#else +/* + * see Figure 8-3 in IMX6SDL Reference manuals: * - IMX6SDL OCRAM (IRAM) is from 0x00907000 to 0x0091FFFF - * - IMX6DQ has 2x IRAM of IMX6SDL but we intend to support IMX6SDL as well * - BOOT ROM stack is at 0x0091FFB8 * - if icache/dcache is enabled (eFuse/strapping controlled) then the * IMX BOOT ROM will setup MMU table at 0x00918000, therefore we need to @@ -29,6 +51,8 @@ */ #define CONFIG_SPL_PAD_TO 0x11000
+#endif + /* MMC support */ #if defined(CONFIG_SPL_MMC_SUPPORT) #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1
Tested-by: Adam Ford aford173@gmail.com #imx6q_logic
help
#ifdef CONFIG_SPL
- see Figure 8-3 in IMX6DQ/IMX6SDL Reference manuals:
- see Figure 8.4.1 in IMX6DQ Reference manuals:
- IMX BOOT ROM will setup MMU table at 0x00938000, therefore we need to
- fit between 0x00907000 and 0x00938000.
- which consists of a 4K header in front of us that contains the IVT, DCD
- and some padding thus 'our' max size is really 0x00908000 - 0x00938000
- or 192KB
- Pad SPL to 196KB (4KB header + 192KB max size). This allows to write the
- SPL/U-Boot combination generated with u-boot-with-spl.imx directly to a
- boot media (given that boot media specific offset is configured properly).
- see Figure 8-3 in IMX6SDL Reference manuals:
- IMX BOOT ROM will setup MMU table at 0x00918000, therefore we need to
1.8.3.1
Stefano,
Any chance this can be adopted? I have a bunch of patches pending this, because my SPL is tight and this patch gives it some breathing room.
thanks,
adam
help
#ifdef CONFIG_SPL
- or 192KB
1.8.3.1
Stefano,
It's been over a month. Is there any reason this cannot be applied?
thanks
adam
thanks,
adam
help
#ifdef CONFIG_SPL
- or 192KB
1.8.3.1
It has been applied in Stefano's tree: https://gitlab.denx.de/u-boot/custodians/u-boot-imx/commit/90fb571d61a8967f5...
Fantastic! I just looked at master. Hopefully it'll get pulled after the next pull request.
Thank you,
adam
My last PR was rejected (at least, discouraged) due to the number of changes and release is approaching. But I will not try to pick up random patches from u-boot-imx master and try to push it just to get it in release. I am starting to pick up all pacthes that are ready in -next, starting from u-boot-imx, -master.
Regards, Stefano
That makes sense since this is an improvement and not a bug fix.
adam
Regards, Stefano
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
Adam Ford
Fabio Estevam
Robert Hancock
Stefano Babic
