[U-Boot] [PATCH 1/1] Make FAT code comply to coding rules.
Currently the fat code is messy related to Coding rules.
Signed-off-by: Remy Bohmer linux@bohmer.net --- fs/fat/fat.c | 1004 ++++++++++++++++++++++++++++----------------------------- fs/fat/file.c | 65 ++-- include/fat.h | 7 +- 3 files changed, 518 insertions(+), 558 deletions(-)
diff --git a/fs/fat/fat.c b/fs/fat/fat.c index 06eabc3..0d4942a 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -34,8 +34,7 @@ /* * Convert a string to lowercase. */ -static void -downcase(char *str) +static void downcase(char *str) { while (*str != '\0') { TOLOWER(*str); @@ -43,7 +42,7 @@ downcase(char *str) } }
-static block_dev_desc_t *cur_dev = NULL; +static block_dev_desc_t *cur_dev = NULL; static unsigned long part_offset = 0; static int cur_part = 1;
@@ -51,21 +50,18 @@ static int cur_part = 1; #define DOS_PART_MAGIC_OFFSET 0x1fe #define DOS_FS_TYPE_OFFSET 0x36
-int disk_read (__u32 startblock, __u32 getsize, __u8 * bufptr) +static int disk_read(__u32 startblock, __u32 nofblocks, __u8 *bufptr) { startblock += part_offset; if (cur_dev == NULL) return -1; - if (cur_dev->block_read) { - return cur_dev->block_read (cur_dev->dev - , startblock, getsize, (unsigned long *)bufptr); - } + if (cur_dev->block_read) + return cur_dev->block_read(cur_dev->dev, startblock, nofblocks, + (unsigned long *)bufptr); return -1; }
- -int -fat_register_device(block_dev_desc_t *dev_desc, int part_no) +int fat_register_device(block_dev_desc_t *dev_desc, int part_no) { unsigned char buffer[SECTOR_SIZE]; disk_partition_t info; @@ -74,22 +70,22 @@ fat_register_device(block_dev_desc_t *dev_desc, int part_no) return -1; cur_dev = dev_desc; /* check if we have a MBR (on floppies we have only a PBR) */ - if (dev_desc->block_read (dev_desc->dev, 0, 1, (ulong *) buffer) != 1) { - printf ("** Can't read from device %d **\n", dev_desc->dev); + if (dev_desc->block_read(dev_desc->dev, 0, 1, (ulong *)buffer) != 1) { + printf("** Can't read from device %d **\n", dev_desc->dev); return -1; } if (buffer[DOS_PART_MAGIC_OFFSET] != 0x55 || - buffer[DOS_PART_MAGIC_OFFSET + 1] != 0xaa) { + buffer[DOS_PART_MAGIC_OFFSET + 1] != 0xaa) /* no signature found */ return -1; - } + #if (defined(CONFIG_CMD_IDE) || \ defined(CONFIG_CMD_SCSI) || \ defined(CONFIG_CMD_USB) || \ defined(CONFIG_MMC) || \ defined(CONFIG_SYSTEMACE) ) /* First we assume, there is a MBR */ - if (!get_partition_info (dev_desc, part_no, &info)) { + if (!get_partition_info(dev_desc, part_no, &info)) { part_offset = info.start; cur_part = part_no; } else if (!strncmp((char *)&buffer[DOS_FS_TYPE_OFFSET], "FAT", 3)) { @@ -97,13 +93,13 @@ fat_register_device(block_dev_desc_t *dev_desc, int part_no) cur_part = 1; part_offset = 0; } else { - printf ("** Partition %d not valid on device %d **\n", - part_no, dev_desc->dev); + printf("** Partition %d not valid on device %d **\n", + part_no, dev_desc->dev); return -1; }
#else - if (!strncmp((char *)&buffer[DOS_FS_TYPE_OFFSET],"FAT",3)) { + if (!strncmp((char *)&buffer[DOS_FS_TYPE_OFFSET], "FAT", 3)) { /* ok, we assume we are on a PBR only */ cur_part = 1; part_offset = 0; @@ -121,37 +117,34 @@ fat_register_device(block_dev_desc_t *dev_desc, int part_no) return 0; }
- /* * Get the first occurence of a directory delimiter ('/' or '') in a string. * Return index into string if found, -1 otherwise. */ -static int -dirdelim(char *str) +static int dirdelim(char *str) { char *start = str;
while (*str != '\0') { - if (ISDIRDELIM(*str)) return str - start; + if (ISDIRDELIM(*str)) + return str - start; str++; } return -1; }
- /* * Match volume_info fs_type strings. * Return 0 on match, -1 otherwise. */ -static int -compare_sign(char *str1, char *str2) +static int compare_sign(char *str1, char *str2) { - char *end = str1+SIGNLEN; + char *end = str1 + SIGNLEN;
while (str1 != end) { - if (*str1 != *str2) { + if (*str1 != *str2) return -1; - } + str1++; str2++; } @@ -159,15 +152,14 @@ compare_sign(char *str1, char *str2) return 0; }
- /* * Extract zero terminated short name from a directory entry. */ -static void get_name (dir_entry *dirent, char *s_name) +static void get_name(dir_entry *dirent, char *s_name) { char *ptr;
- memcpy (s_name, dirent->name, 8); + memcpy(s_name, dirent->name, 8); s_name[8] = '\0'; ptr = s_name; while (*ptr && *ptr != ' ') @@ -175,7 +167,7 @@ static void get_name (dir_entry *dirent, char *s_name) if (dirent->ext[0] && dirent->ext[0] != ' ') { *ptr = '.'; ptr++; - memcpy (ptr, dirent->ext, 3); + memcpy(ptr, dirent->ext, 3); ptr[3] = '\0'; while (*ptr && *ptr != ' ') ptr++; @@ -185,19 +177,20 @@ static void get_name (dir_entry *dirent, char *s_name) *s_name = '\0'; else if (*s_name == aRING) *s_name = DELETED_FLAG; - downcase (s_name); + downcase(s_name); }
/* * Get the entry at index 'entry' in a FAT (12/16/32) table. * On failure 0x00 is returned. */ -static __u32 -get_fatent(fsdata *mydata, __u32 entry) +static __u32 get_fatent(fsdata *mydata, __u32 entry) { __u32 bufnum; __u32 offset; __u32 ret = 0x00; + __u32 off16; + __u16 val1, val2;
switch (mydata->fatsize) { case 32: @@ -220,7 +213,7 @@ get_fatent(fsdata *mydata, __u32 entry)
/* Read a new block of FAT entries into the cache. */ if (bufnum != mydata->fatbufnum) { - int getsize = FATBUFSIZE/FS_BLOCK_SIZE; + int nofblocks = FATBUFSIZE / FS_BLOCK_SIZE; __u8 *bufptr = mydata->fatbuf; __u32 fatlength = mydata->fatlength; __u32 startblock = bufnum * FATBUFBLOCKS; @@ -228,8 +221,9 @@ get_fatent(fsdata *mydata, __u32 entry) fatlength *= SECTOR_SIZE; /* We want it in bytes now */ startblock += mydata->fat_sect; /* Offset from start of disk */
- if (getsize > fatlength) getsize = fatlength; - if (disk_read(startblock, getsize, bufptr) < 0) { + if (nofblocks > (fatlength / FS_BLOCK_SIZE)) + nofblocks = fatlength / FS_BLOCK_SIZE; + if (disk_read(startblock, nofblocks, bufptr) < 0) { FAT_DPRINT("Error reading FAT blocks\n"); return ret; } @@ -239,96 +233,89 @@ get_fatent(fsdata *mydata, __u32 entry) /* Get the actual entry from the table */ switch (mydata->fatsize) { case 32: - ret = FAT2CPU32(((__u32*)mydata->fatbuf)[offset]); + ret = FAT2CPU32(((__u32 *) mydata->fatbuf)[offset]); break; case 16: - ret = FAT2CPU16(((__u16*)mydata->fatbuf)[offset]); + ret = FAT2CPU16(((__u16 *) mydata->fatbuf)[offset]); break; - case 12: { - __u32 off16 = (offset*3)/4; - __u16 val1, val2; + case 12: + off16 = (offset * 3) / 4;
switch (offset & 0x3) { case 0: - ret = FAT2CPU16(((__u16*)mydata->fatbuf)[off16]); + ret = FAT2CPU16(((__u16 *) mydata->fatbuf)[off16]); ret &= 0xfff; break; case 1: - val1 = FAT2CPU16(((__u16*)mydata->fatbuf)[off16]); + val1 = FAT2CPU16(((__u16 *) mydata->fatbuf)[off16]); val1 &= 0xf000; - val2 = FAT2CPU16(((__u16*)mydata->fatbuf)[off16+1]); + val2 = FAT2CPU16(((__u16 *) mydata->fatbuf)[off16 + 1]); val2 &= 0x00ff; ret = (val2 << 4) | (val1 >> 12); break; case 2: - val1 = FAT2CPU16(((__u16*)mydata->fatbuf)[off16]); + val1 = FAT2CPU16(((__u16 *) mydata->fatbuf)[off16]); val1 &= 0xff00; - val2 = FAT2CPU16(((__u16*)mydata->fatbuf)[off16+1]); + val2 = FAT2CPU16(((__u16 *) mydata->fatbuf)[off16 + 1]); val2 &= 0x000f; ret = (val2 << 8) | (val1 >> 8); break; case 3: - ret = FAT2CPU16(((__u16*)mydata->fatbuf)[off16]);; + ret = FAT2CPU16(((__u16 *) mydata->fatbuf)[off16]); ret = (ret & 0xfff0) >> 4; break; default: break; } - } - break; + break; } FAT_DPRINT("ret: %d, offset: %d\n", ret, offset);
return ret; }
- /* * Read at most 'size' bytes from the specified cluster into 'buffer'. * Return 0 on success, -1 otherwise. */ -static int -get_cluster(fsdata *mydata, __u32 clustnum, __u8 *buffer, unsigned long size) +static int get_cluster(fsdata *mydata, __u32 clustnum, + __u8 *buffer, unsigned long size_bytes) { int idx = 0; __u32 startsect;
- if (clustnum > 0) { - startsect = mydata->data_begin + clustnum*mydata->clust_size; - } else { + if (clustnum > 0) + startsect = mydata->data_begin + clustnum * mydata->clust_size; + else startsect = mydata->rootdir_sect; - }
FAT_DPRINT("gc - clustnum: %d, startsect: %d\n", clustnum, startsect); - if (disk_read(startsect, size/FS_BLOCK_SIZE , buffer) < 0) { + if (disk_read(startsect, size_bytes / FS_BLOCK_SIZE, buffer) < 0) { FAT_DPRINT("Error reading data\n"); return -1; } - if(size % FS_BLOCK_SIZE) { + if (size_bytes % FS_BLOCK_SIZE) { __u8 tmpbuf[FS_BLOCK_SIZE]; - idx= size/FS_BLOCK_SIZE; + idx = size_bytes / FS_BLOCK_SIZE; if (disk_read(startsect + idx, 1, tmpbuf) < 0) { FAT_DPRINT("Error reading data\n"); return -1; } - buffer += idx*FS_BLOCK_SIZE; + buffer += idx * FS_BLOCK_SIZE;
- memcpy(buffer, tmpbuf, size % FS_BLOCK_SIZE); + memcpy(buffer, tmpbuf, size_bytes % FS_BLOCK_SIZE); return 0; } - return 0; }
- /* * Read at most 'maxsize' bytes from the file associated with 'dentptr' * into 'buffer'. * Return the number of bytes read or -1 on fatal errors. */ -static long -get_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer, - unsigned long maxsize) +static long get_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer, + unsigned long maxsize) { unsigned long filesize = FAT2CPU32(dentptr->size), gotsize = 0; unsigned int bytesperclust = mydata->clust_size * SECTOR_SIZE; @@ -338,25 +325,44 @@ get_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer,
FAT_DPRINT("Filesize: %ld bytes\n", filesize);
- if (maxsize > 0 && filesize > maxsize) filesize = maxsize; + if (maxsize > 0 && filesize > maxsize) + filesize = maxsize;
FAT_DPRINT("Reading: %ld bytes\n", filesize);
- actsize=bytesperclust; - endclust=curclust; - do { + actsize = bytesperclust; + endclust = curclust; + for (;;) { /* search for consecutive clusters */ - while(actsize < filesize) { + while (actsize < filesize) { newclust = get_fatent(mydata, endclust); - if((newclust -1)!=endclust) - goto getit; + if ((newclust - 1) != endclust) { + if (get_cluster(mydata, curclust, buffer, + (int)actsize) != 0) { + FAT_ERROR("Error reading cluster\n"); + return -1; + } + gotsize += (int)actsize; + filesize -= actsize; + buffer += actsize; + curclust = get_fatent(mydata, endclust); + if (CHECK_CLUST(curclust, mydata->fatsize)) { + FAT_DPRINT("curclust: 0x%x\n", + curclust); + FAT_ERROR("Invalid FAT entry\n"); + return gotsize; + } + actsize = bytesperclust; + endclust = curclust; + continue; + } if (CHECK_CLUST(newclust, mydata->fatsize)) { FAT_DPRINT("curclust: 0x%x\n", newclust); FAT_DPRINT("Invalid FAT entry\n"); return gotsize; } - endclust=newclust; - actsize+= bytesperclust; + endclust = newclust; + actsize += bytesperclust; } /* actsize >= file size */ actsize -= bytesperclust; @@ -369,90 +375,75 @@ get_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer, gotsize += (int)actsize; filesize -= actsize; buffer += actsize; - actsize= filesize; + actsize = filesize; if (get_cluster(mydata, endclust, buffer, (int)actsize) != 0) { FAT_ERROR("Error reading cluster\n"); return -1; } - gotsize+=actsize; + gotsize += actsize; return gotsize; -getit: - if (get_cluster(mydata, curclust, buffer, (int)actsize) != 0) { - FAT_ERROR("Error reading cluster\n"); - return -1; - } - gotsize += (int)actsize; - filesize -= actsize; - buffer += actsize; - curclust = get_fatent(mydata, endclust); - if (CHECK_CLUST(curclust, mydata->fatsize)) { - FAT_DPRINT("curclust: 0x%x\n", curclust); - FAT_ERROR("Invalid FAT entry\n"); - return gotsize; - } - actsize=bytesperclust; - endclust=curclust; - } while (1); + } }
- #ifdef CONFIG_SUPPORT_VFAT /* * Extract the file name information from 'slotptr' into 'l_name', * starting at l_name[*idx]. * Return 1 if terminator (zero byte) is found, 0 otherwise. */ -static int -slot2str(dir_slot *slotptr, char *l_name, int *idx) +static int slot2str(dir_slot *slotptr, char *l_name, int *idx) { int j;
for (j = 0; j <= 8; j += 2) { l_name[*idx] = slotptr->name0_4[j]; - if (l_name[*idx] == 0x00) return 1; + if (l_name[*idx] == 0x00) + return 1; (*idx)++; } for (j = 0; j <= 10; j += 2) { l_name[*idx] = slotptr->name5_10[j]; - if (l_name[*idx] == 0x00) return 1; + if (l_name[*idx] == 0x00) + return 1; (*idx)++; } for (j = 0; j <= 2; j += 2) { l_name[*idx] = slotptr->name11_12[j]; - if (l_name[*idx] == 0x00) return 1; + if (l_name[*idx] == 0x00) + return 1; (*idx)++; }
return 0; }
- /* * Extract the full long filename starting at 'retdent' (which is really * a slot) into 'l_name'. If successful also copy the real directory entry * into 'retdent' * Return 0 on success, -1 otherwise. */ -__u8 get_vfatname_block[MAX_CLUSTSIZE]; -static int -get_vfatname(fsdata *mydata, int curclust, __u8 *cluster, - dir_entry *retdent, char *l_name) +static __u8 get_vfatname_block[MAX_CLUSTSIZE]; + +static int get_vfatname(fsdata *mydata, int curclust, __u8 *cluster, + dir_entry *retdent, char *l_name) { dir_entry *realdent; - dir_slot *slotptr = (dir_slot*) retdent; - __u8 *nextclust = cluster + mydata->clust_size * SECTOR_SIZE; - __u8 counter = (slotptr->id & ~LAST_LONG_ENTRY_MASK) & 0xff; + dir_slot *slotptr = (dir_slot *) retdent; + __u8 *nextclust = cluster + mydata->clust_size * SECTOR_SIZE; + __u8 counter = (slotptr->id & ~LAST_LONG_ENTRY_MASK) & 0xff; int idx = 0;
- while ((__u8*)slotptr < nextclust) { - if (counter == 0) break; + while ((__u8 *) slotptr < nextclust) { + if (counter == 0) + break; if (((slotptr->id & ~LAST_LONG_ENTRY_MASK) & 0xff) != counter) return -1; slotptr++; counter--; }
- if ((__u8*)slotptr >= nextclust) { + if ((__u8 *) slotptr >= nextclust) { dir_slot *slotptr2;
slotptr--; @@ -467,29 +458,32 @@ get_vfatname(fsdata *mydata, int curclust, __u8 *cluster, FAT_DPRINT("Error: reading directory block\n"); return -1; } - slotptr2 = (dir_slot*) get_vfatname_block; + slotptr2 = (dir_slot *) get_vfatname_block; while (slotptr2->id > 0x01) { slotptr2++; } /* Save the real directory entry */ - realdent = (dir_entry*)slotptr2 + 1; - while ((__u8*)slotptr2 >= get_vfatname_block) { + realdent = (dir_entry *) slotptr2 + 1; + while ((__u8 *) slotptr2 >= get_vfatname_block) { slot2str(slotptr2, l_name, &idx); slotptr2--; } } else { /* Save the real directory entry */ - realdent = (dir_entry*)slotptr; + realdent = (dir_entry *) slotptr; }
do { slotptr--; - if (slot2str(slotptr, l_name, &idx)) break; + if (slot2str(slotptr, l_name, &idx)) + break; } while (!(slotptr->id & LAST_LONG_ENTRY_MASK));
l_name[idx] = '\0'; - if (*l_name == DELETED_FLAG) *l_name = '\0'; - else if (*l_name == aRING) *l_name = DELETED_FLAG; + if (*l_name == DELETED_FLAG) + *l_name = '\0'; + else if (*l_name == aRING) + *l_name = DELETED_FLAG; downcase(l_name);
/* Return the real directory entry */ @@ -498,174 +492,181 @@ get_vfatname(fsdata *mydata, int curclust, __u8 *cluster, return 0; }
- /* Calculate short name checksum */ -static __u8 -mkcksum(const char *str) +static __u8 mkcksum(const char *str) { int i; __u8 ret = 0;
- for (i = 0; i < 11; i++) { - ret = (((ret&1)<<7)|((ret&0xfe)>>1)) + str[i]; - } + for (i = 0; i < 11; i++) + ret = (((ret & 1) << 7) | ((ret & 0xfe) >> 1)) + str[i];
return ret; } #endif
- -/* - * Get the directory entry associated with 'filename' from the directory - * starting at 'startsect' - */ -__u8 get_dentfromdir_block[MAX_CLUSTSIZE]; -static dir_entry *get_dentfromdir (fsdata * mydata, int startsect, - char *filename, dir_entry * retdent, - int dols) +/* Returns 0 on illegal vfat entry, 1 on valid vfat entry */ +static int valid_vfat(fsdata *mydata, dir_entry *dentptr, __u16 *prevcksum, + int curclust, char *l_name, int dols, int *dirs, + int *files, __u8 *read_block) { - __u16 prevcksum = 0xffff; - __u32 curclust = START (retdent); - int files = 0, dirs = 0; - - FAT_DPRINT ("get_dentfromdir: %s\n", filename); - while (1) { - dir_entry *dentptr; - int i; - - if (get_cluster (mydata, curclust, get_dentfromdir_block, - mydata->clust_size * SECTOR_SIZE) != 0) { - FAT_DPRINT ("Error: reading directory block\n"); - return NULL; - } - dentptr = (dir_entry *) get_dentfromdir_block; - for (i = 0; i < DIRENTSPERCLUST; i++) { - char s_name[14], l_name[256]; - - l_name[0] = '\0'; - if (dentptr->name[0] == DELETED_FLAG) { - dentptr++; - continue; - } - if ((dentptr->attr & ATTR_VOLUME)) { #ifdef CONFIG_SUPPORT_VFAT - if ((dentptr->attr & ATTR_VFAT) && - (dentptr->name[0] & LAST_LONG_ENTRY_MASK)) { - prevcksum = ((dir_slot *) dentptr) - ->alias_checksum; - get_vfatname (mydata, curclust, get_dentfromdir_block, - dentptr, l_name); - if (dols) { + if ((dentptr->attr & ATTR_VFAT) && + (dentptr->name[0] & LAST_LONG_ENTRY_MASK)) { + *prevcksum = ((dir_slot *) dentptr)->alias_checksum; + if (get_vfatname(mydata, curclust, read_block, dentptr, l_name)) + return 0; + + if (dols != LS_NO) { int isdir = (dentptr->attr & ATTR_DIR); char dirc; int doit = 0;
if (isdir) { - dirs++; - dirc = '/'; - doit = 1; - } else { - dirc = ' '; - if (l_name[0] != 0) { - files++; + (*dirs)++; + dirc = '/'; doit = 1; - } + } else { + dirc = ' '; + if (l_name[0] != 0) { + (*files)++; + doit = 1; + } } if (doit) { - if (dirc == ' ') { - printf (" %8ld %s%c\n", - (long) FAT2CPU32 (dentptr->size), - l_name, dirc); - } else { - printf (" %s%c\n", l_name, dirc); - } + if (dirc == ' ') + printf(" %8ld %s%c\n", (long)FAT2CPU32 + (dentptr->size), l_name, dirc); + else + printf(" %s%c\n", l_name, + dirc); } - dentptr++; - continue; - } - FAT_DPRINT ("vfatname: |%s|\n", l_name); - } else -#endif - { - /* Volume label or VFAT entry */ - dentptr++; - continue; } - } - if (dentptr->name[0] == 0) { - if (dols) { - printf ("\n%d file(s), %d dir(s)\n\n", files, dirs); + FAT_DPRINT("Rootvfatname: |%s|\n", l_name); + return 1; + } +#endif + /* Probably just a Volume label */ + return 0; +} + +/* + * Get the directory entry associated with 'filename' from the directory + * starting at 'startsect' + */ +static __u8 get_dentfromdir_block[MAX_CLUSTSIZE]; + +static dir_entry *get_dentfromdir(fsdata *mydata, int startsect, + char *filename, dir_entry *retdent, int dols) +{ + __u16 prevcksum = 0xffff; + __u32 curclust = START(retdent); + int files = 0, dirs = 0; + + FAT_DPRINT("get_dentfromdir: %s\n", filename); + for (;;) { + dir_entry *dentptr; + int i; + + if (get_cluster(mydata, curclust, get_dentfromdir_block, + mydata->clust_size * SECTOR_SIZE) != 0) { + FAT_DPRINT("Error: reading directory block\n"); + return NULL; } - FAT_DPRINT ("Dentname == NULL - %d\n", i); - return NULL; - } + dentptr = (dir_entry *) get_dentfromdir_block; + for (i = 0; i < DIRENTSPERCLUST; i++) { + char s_name[14], l_name[256]; + + l_name[0] = '\0'; + if (dentptr->name[0] == DELETED_FLAG) { + dentptr++; + continue; + } + if ((dentptr->attr & ATTR_VOLUME) && + !valid_vfat(mydata, dentptr, &prevcksum, curclust, + l_name, dols, &dirs, &files, + get_dentfromdir_block)) { + /* Ignore volume labels */ + dentptr++; + continue; + } + + if (dentptr->name[0] == 0) { + if (dols != LS_NO) + printf("\n%d file(s), %d dir(s)\n\n", + files, dirs); + + FAT_DPRINT("Dentname == NULL - %d\n", i); + return NULL; + } #ifdef CONFIG_SUPPORT_VFAT - if (dols && mkcksum (dentptr->name) == prevcksum) { - dentptr++; - continue; - } + if ((dols != LS_NO) && + (mkcksum(dentptr->name) == prevcksum)) { + dentptr++; + continue; + } #endif - get_name (dentptr, s_name); - if (dols) { - int isdir = (dentptr->attr & ATTR_DIR); - char dirc; - int doit = 0; - - if (isdir) { - dirs++; - dirc = '/'; - doit = 1; - } else { - dirc = ' '; - if (s_name[0] != 0) { - files++; - doit = 1; - } + get_name(dentptr, s_name); + if (dols != LS_NO) { + int isdir = (dentptr->attr & ATTR_DIR); + char dirc; + int doit = 0; + + if (isdir) { + dirs++; + dirc = '/'; + doit = 1; + } else { + dirc = ' '; + if (s_name[0] != 0) { + files++; + doit = 1; + } + } + if (doit) { + if (dirc == ' ') + printf(" %8ld %s%c\n", (long) + FAT2CPU32(dentptr->size), + s_name, dirc); + else + printf(" %s%c\n", + s_name, dirc); + } + dentptr++; + continue; + } + if (strcmp(filename, s_name) + && strcmp(filename, l_name)) { + FAT_DPRINT("Mismatch: |%s|%s|\n", s_name, + l_name); + dentptr++; + continue; + } + memcpy(retdent, dentptr, sizeof(dir_entry)); + + FAT_DPRINT("DentName: %s", s_name); + FAT_DPRINT(", start: 0x%x", START(dentptr)); + FAT_DPRINT(", size: 0x%x %s\n", + FAT2CPU32(dentptr->size), + (dentptr->attr & ATTR_DIR) ? "(DIR)" : ""); + + return retdent; } - if (doit) { - if (dirc == ' ') { - printf (" %8ld %s%c\n", - (long) FAT2CPU32 (dentptr->size), s_name, - dirc); - } else { - printf (" %s%c\n", s_name, dirc); - } + curclust = get_fatent(mydata, curclust); + if (CHECK_CLUST(curclust, mydata->fatsize)) { + FAT_DPRINT("curclust: 0x%x\n", curclust); + FAT_ERROR("Invalid FAT entry\n"); + return NULL; } - dentptr++; - continue; - } - if (strcmp (filename, s_name) && strcmp (filename, l_name)) { - FAT_DPRINT ("Mismatch: |%s|%s|\n", s_name, l_name); - dentptr++; - continue; - } - memcpy (retdent, dentptr, sizeof (dir_entry)); - - FAT_DPRINT ("DentName: %s", s_name); - FAT_DPRINT (", start: 0x%x", START (dentptr)); - FAT_DPRINT (", size: 0x%x %s\n", - FAT2CPU32 (dentptr->size), - (dentptr->attr & ATTR_DIR) ? "(DIR)" : ""); - - return retdent; - } - curclust = get_fatent (mydata, curclust); - if (CHECK_CLUST(curclust, mydata->fatsize)) { - FAT_DPRINT ("curclust: 0x%x\n", curclust); - FAT_ERROR ("Invalid FAT entry\n"); - return NULL; } - } - - return NULL; + return NULL; }
- /* * Read boot sector and volume info from a FAT filesystem */ -static int -read_bootsectandvi(boot_sector *bs, volume_info *volinfo, int *fatsize) +static int read_bootsectandvi(boot_sector *bs, volume_info *volinfo, + int *fatsize) { __u8 block[FS_BLOCK_SIZE]; volume_info *vistart; @@ -676,27 +677,27 @@ read_bootsectandvi(boot_sector *bs, volume_info *volinfo, int *fatsize) }
memcpy(bs, block, sizeof(boot_sector)); - bs->reserved = FAT2CPU16(bs->reserved); - bs->fat_length = FAT2CPU16(bs->fat_length); - bs->secs_track = FAT2CPU16(bs->secs_track); - bs->heads = FAT2CPU16(bs->heads); -#if 0 /* UNUSED */ - bs->hidden = FAT2CPU32(bs->hidden); + bs->reserved = FAT2CPU16(bs->reserved); + bs->fat_length = FAT2CPU16(bs->fat_length); + bs->secs_track = FAT2CPU16(bs->secs_track); + bs->heads = FAT2CPU16(bs->heads); +#if 0 /* UNUSED */ + bs->hidden = FAT2CPU32(bs->hidden); #endif - bs->total_sect = FAT2CPU32(bs->total_sect); + bs->total_sect = FAT2CPU32(bs->total_sect);
/* FAT32 entries */ if (bs->fat_length == 0) { /* Assume FAT32 */ bs->fat32_length = FAT2CPU32(bs->fat32_length); - bs->flags = FAT2CPU16(bs->flags); + bs->flags = FAT2CPU16(bs->flags); bs->root_cluster = FAT2CPU32(bs->root_cluster); - bs->info_sector = FAT2CPU16(bs->info_sector); - bs->backup_boot = FAT2CPU16(bs->backup_boot); - vistart = (volume_info*) (block + sizeof(boot_sector)); + bs->info_sector = FAT2CPU16(bs->info_sector); + bs->backup_boot = FAT2CPU16(bs->backup_boot); + vistart = (volume_info *) (block + sizeof(boot_sector)); *fatsize = 32; } else { - vistart = (volume_info*) &(bs->fat32_length); + vistart = (volume_info *)&(bs->fat32_length); *fatsize = 0; } memcpy(volinfo, vistart, sizeof(volume_info)); @@ -706,9 +707,8 @@ read_bootsectandvi(boot_sector *bs, volume_info *volinfo, int *fatsize) vistart->fs_type[8] = '\0';
if (*fatsize == 32) { - if (compare_sign(FAT32_SIGN, vistart->fs_type) == 0) { + if (compare_sign(FAT32_SIGN, vistart->fs_type) == 0) return 0; - } } else { if (compare_sign(FAT12_SIGN, vistart->fs_type) == 0) { *fatsize = 12; @@ -724,258 +724,228 @@ read_bootsectandvi(boot_sector *bs, volume_info *volinfo, int *fatsize) return -1; }
+static __u8 do_fat_read_block[MAX_CLUSTSIZE]; /* Block buffer */
-__u8 do_fat_read_block[MAX_CLUSTSIZE]; /* Block buffer */ -long -do_fat_read (const char *filename, void *buffer, unsigned long maxsize, - int dols) +long do_fat_read(const char *filename, void *buffer, + unsigned long maxsize, int dols) { -#if CONFIG_NIOS /* NIOS CPU cannot access big automatic arrays */ - static +#if CONFIG_NIOS /* NIOS CPU cannot access big automatic arrays */ + static #endif - char fnamecopy[2048]; - boot_sector bs; - volume_info volinfo; - fsdata datablock; - fsdata *mydata = &datablock; - dir_entry *dentptr; - __u16 prevcksum = 0xffff; - char *subname = ""; - int rootdir_size, cursect; - int idx, isdir = 0; - int files = 0, dirs = 0; - long ret = 0; - int firsttime; - - if (read_bootsectandvi (&bs, &volinfo, &mydata->fatsize)) { - FAT_DPRINT ("Error: reading boot sector\n"); - return -1; - } - if (mydata->fatsize == 32) { - mydata->fatlength = bs.fat32_length; - } else { - mydata->fatlength = bs.fat_length; - } - mydata->fat_sect = bs.reserved; - cursect = mydata->rootdir_sect - = mydata->fat_sect + mydata->fatlength * bs.fats; - mydata->clust_size = bs.cluster_size; - if (mydata->fatsize == 32) { - rootdir_size = mydata->clust_size; - mydata->data_begin = mydata->rootdir_sect /* + rootdir_size */ - - (mydata->clust_size * 2); - } else { - rootdir_size = ((bs.dir_entries[1] * (int) 256 + bs.dir_entries[0]) - * sizeof (dir_entry)) / SECTOR_SIZE; - mydata->data_begin = mydata->rootdir_sect + rootdir_size - - (mydata->clust_size * 2); - } - mydata->fatbufnum = -1; - - FAT_DPRINT ("FAT%d, fatlength: %d\n", mydata->fatsize, - mydata->fatlength); - FAT_DPRINT ("Rootdir begins at sector: %d, offset: %x, size: %d\n" - "Data begins at: %d\n", - mydata->rootdir_sect, mydata->rootdir_sect * SECTOR_SIZE, - rootdir_size, mydata->data_begin); - FAT_DPRINT ("Cluster size: %d\n", mydata->clust_size); - - /* "cwd" is always the root... */ - while (ISDIRDELIM (*filename)) - filename++; - /* Make a copy of the filename and convert it to lowercase */ - strcpy (fnamecopy, filename); - downcase (fnamecopy); - if (*fnamecopy == '\0') { - if (!dols) - return -1; - dols = LS_ROOT; - } else if ((idx = dirdelim (fnamecopy)) >= 0) { - isdir = 1; - fnamecopy[idx] = '\0'; - subname = fnamecopy + idx + 1; - /* Handle multiple delimiters */ - while (ISDIRDELIM (*subname)) - subname++; - } else if (dols) { - isdir = 1; - } - - while (1) { - int i; - - if (disk_read (cursect, mydata->clust_size, do_fat_read_block) < 0) { - FAT_DPRINT ("Error: reading rootdir block\n"); - return -1; + char fnamecopy[2048]; + boot_sector bs; + volume_info volinfo; + fsdata datablock; + fsdata *mydata = &datablock; + dir_entry *dentptr; + __u16 prevcksum = 0xffff; + char *subname = ""; + int rootdir_size, cursect; + int idx, isdir = 0; + int files = 0, dirs = 0; + long ret = 0; + int firsttime; + + if (read_bootsectandvi(&bs, &volinfo, &mydata->fatsize)) { + FAT_DPRINT("Error: reading boot sector\n"); + return -1; } - dentptr = (dir_entry *) do_fat_read_block; - for (i = 0; i < DIRENTSPERBLOCK; i++) { - char s_name[14], l_name[256]; - - l_name[0] = '\0'; - if ((dentptr->attr & ATTR_VOLUME)) { -#ifdef CONFIG_SUPPORT_VFAT - if ((dentptr->attr & ATTR_VFAT) && - (dentptr->name[0] & LAST_LONG_ENTRY_MASK)) { - prevcksum = ((dir_slot *) dentptr)->alias_checksum; - get_vfatname (mydata, 0, do_fat_read_block, dentptr, l_name); - if (dols == LS_ROOT) { - int isdir = (dentptr->attr & ATTR_DIR); - char dirc; - int doit = 0; - - if (isdir) { - dirs++; - dirc = '/'; - doit = 1; - } else { - dirc = ' '; - if (l_name[0] != 0) { - files++; - doit = 1; - } + if (mydata->fatsize == 32) + mydata->fatlength = bs.fat32_length; + else + mydata->fatlength = bs.fat_length; + + mydata->fat_sect = bs.reserved; + cursect = mydata->rootdir_sect = mydata->fat_sect + + (mydata->fatlength * bs.fats); + mydata->clust_size = bs.cluster_size; + if (mydata->fatsize == 32) { + rootdir_size = mydata->clust_size; + mydata->data_begin = mydata->rootdir_sect /* + rootdir_size */ + - (mydata->clust_size * 2); + } else { + rootdir_size = ((bs.dir_entries[1] * (int)256 + + bs.dir_entries[0]) * sizeof(dir_entry)) / SECTOR_SIZE; + mydata->data_begin = mydata->rootdir_sect + rootdir_size + - (mydata->clust_size * 2); + } + mydata->fatbufnum = -1; + + FAT_DPRINT("FAT%d, fatlength: %d\n", mydata->fatsize, + mydata->fatlength); + FAT_DPRINT("Rootdir begins at sector: %d, offset: %x, size: %d\n" + "Data begins at: %d\n", + mydata->rootdir_sect, mydata->rootdir_sect * SECTOR_SIZE, + rootdir_size, mydata->data_begin); + FAT_DPRINT("Cluster size: %d\n", mydata->clust_size); + + /* "cwd" is always the root... */ + while (ISDIRDELIM(*filename)) + filename++; + /* Make a copy of the filename and convert it to lowercase */ + strcpy(fnamecopy, filename); + downcase(fnamecopy); + if (*fnamecopy == '\0') { + if (dols == LS_NO) + return -1; + dols = LS_ROOT; + } else if ((idx = dirdelim(fnamecopy)) >= 0) { + isdir = 1; + fnamecopy[idx] = '\0'; + subname = fnamecopy + idx + 1; + /* Handle multiple delimiters */ + while (ISDIRDELIM(*subname)) + subname++; + } else if (dols != LS_NO) + isdir = 1; + + for (;;) { + int i; + + if (disk_read(cursect, 1, do_fat_read_block) < 0) { + FAT_DPRINT("Error: reading rootdir block\n"); + return -1; + } + dentptr = (dir_entry *) do_fat_read_block; + for (i = 0; i < DIRENTSPERBLOCK; i++) { + char s_name[14], l_name[256]; + + l_name[0] = '\0'; + if (dentptr->name[0] == DELETED_FLAG) { + /* Ignore deleted entries */ + dentptr++; + continue; } - if (doit) { - if (dirc == ' ') { - printf (" %8ld %s%c\n", - (long) FAT2CPU32 (dentptr->size), - l_name, dirc); - } else { - printf (" %s%c\n", l_name, dirc); - } + if ((dentptr->attr & ATTR_VOLUME) && + !valid_vfat(mydata, dentptr, &prevcksum, 0, l_name, + dols, &dirs, &files, + do_fat_read_block)) { + /* Ignore volume labels */ + dentptr++; + continue; + } + if (dentptr->name[0] == 0) { + FAT_DPRINT("RootDentname == NULL - %d\n", i); + if (dols == LS_ROOT) { + printf("\n%d file(s), %d dir(s)\n\n", + files, dirs); + return 0; + } + return -1; } - dentptr++; - continue; - } - FAT_DPRINT ("Rootvfatname: |%s|\n", l_name); - } else -#endif - { - /* Volume label or VFAT entry */ - dentptr++; - continue; - } - } else if (dentptr->name[0] == 0) { - FAT_DPRINT ("RootDentname == NULL - %d\n", i); - if (dols == LS_ROOT) { - printf ("\n%d file(s), %d dir(s)\n\n", files, dirs); - return 0; - } - return -1; - } #ifdef CONFIG_SUPPORT_VFAT - else if (dols == LS_ROOT - && mkcksum (dentptr->name) == prevcksum) { - dentptr++; - continue; - } + if (dols == LS_ROOT && + mkcksum(dentptr->name) == prevcksum) { + dentptr++; + continue; + } #endif - get_name (dentptr, s_name); - if (dols == LS_ROOT) { - int isdir = (dentptr->attr & ATTR_DIR); - char dirc; - int doit = 0; - - if (isdir) { - dirc = '/'; - if (s_name[0] != 0) { - dirs++; - doit = 1; - } - } else { - dirc = ' '; - if (s_name[0] != 0) { - files++; - doit = 1; - } - } - if (doit) { - if (dirc == ' ') { - printf (" %8ld %s%c\n", - (long) FAT2CPU32 (dentptr->size), s_name, - dirc); - } else { - printf (" %s%c\n", s_name, dirc); - } - } - dentptr++; - continue; - } - if (strcmp (fnamecopy, s_name) && strcmp (fnamecopy, l_name)) { - FAT_DPRINT ("RootMismatch: |%s|%s|\n", s_name, l_name); - dentptr++; - continue; - } - if (isdir && !(dentptr->attr & ATTR_DIR)) - return -1; + get_name(dentptr, s_name); + if (dols == LS_ROOT) { + int isdir = (dentptr->attr & ATTR_DIR); + char dirc; + int doit = 0; + + if (isdir) { + dirc = '/'; + if (s_name[0] != 0) { + dirs++; + doit = 1; + } + } else { + dirc = ' '; + if (s_name[0] != 0) { + files++; + doit = 1; + } + } + if (doit) { + if (dirc == ' ') + printf(" %8ld %s%c\n", (long) + FAT2CPU32(dentptr->size), + s_name, dirc); + else + printf(" %s%c\n", + s_name, dirc); + } + dentptr++; + continue; + } + if (strcmp(fnamecopy, s_name) + && strcmp(fnamecopy, l_name)) { + FAT_DPRINT("RootMismatch: |%s|%s|\n", s_name, + l_name); + dentptr++; + continue; + } + if (isdir && !(dentptr->attr & ATTR_DIR)) + return -1;
- FAT_DPRINT ("RootName: %s", s_name); - FAT_DPRINT (", start: 0x%x", START (dentptr)); - FAT_DPRINT (", size: 0x%x %s\n", - FAT2CPU32 (dentptr->size), isdir ? "(DIR)" : ""); + FAT_DPRINT("RootName: %s", s_name); + FAT_DPRINT(", start: 0x%x", START(dentptr)); + FAT_DPRINT(", size: 0x%x %s\n", + FAT2CPU32(dentptr->size), + isdir ? "(DIR)" : "");
- goto rootdir_done; /* We got a match */ - } - cursect++; - } - rootdir_done: - - firsttime = 1; - while (isdir) { - int startsect = mydata->data_begin - + START (dentptr) * mydata->clust_size; - dir_entry dent; - char *nextname = NULL; - - dent = *dentptr; - dentptr = &dent; - - idx = dirdelim (subname); - if (idx >= 0) { - subname[idx] = '\0'; - nextname = subname + idx + 1; - /* Handle multiple delimiters */ - while (ISDIRDELIM (*nextname)) - nextname++; - if (dols && *nextname == '\0') - firsttime = 0; - } else { - if (dols && firsttime) { - firsttime = 0; - } else { - isdir = 0; - } - } + goto rootdir_done; /* We got a match */ + } + cursect++; + } +rootdir_done: + + firsttime = 1; + while (isdir) { + int startsect = mydata->data_begin + + START(dentptr) * mydata->clust_size; + dir_entry dent; + char *nextname = NULL; + + dent = *dentptr; + dentptr = &dent; + + idx = dirdelim(subname); + if (idx >= 0) { + subname[idx] = '\0'; + nextname = subname + idx + 1; + /* Handle multiple delimiters */ + while (ISDIRDELIM(*nextname)) + nextname++; + if (dols != LS_NO && *nextname == '\0') + firsttime = 0; + } else { + if (dols != LS_NO && firsttime) + firsttime = 0; + else + isdir = 0; + }
- if (get_dentfromdir (mydata, startsect, subname, dentptr, - isdir ? 0 : dols) == NULL) { - if (dols && !isdir) - return 0; - return -1; - } + if (get_dentfromdir(mydata, startsect, subname, dentptr, + isdir ? 0 : dols) == NULL) { + if (dols != LS_NO && !isdir) + return 0; + return -1; + }
- if (idx >= 0) { - if (!(dentptr->attr & ATTR_DIR)) - return -1; - subname = nextname; + if (idx >= 0) { + if (!(dentptr->attr & ATTR_DIR)) + return -1; + subname = nextname; + } } - } - ret = get_contents (mydata, dentptr, buffer, maxsize); - FAT_DPRINT ("Size: %d, got: %ld\n", FAT2CPU32 (dentptr->size), ret); + ret = get_contents(mydata, dentptr, buffer, maxsize); + FAT_DPRINT("Size: %d, got: %ld\n", FAT2CPU32(dentptr->size), ret);
- return ret; + return ret; }
- -int -file_fat_detectfs(void) +int file_fat_detectfs(void) { - boot_sector bs; - volume_info volinfo; - int fatsize; - char vol_label[12]; + boot_sector bs; + volume_info volinfo; + int fatsize; + char vol_label[12];
- if(cur_dev==NULL) { + if (cur_dev == NULL) { printf("No current device\n"); return 1; } @@ -984,41 +954,37 @@ file_fat_detectfs(void) defined(CONFIG_CMD_USB) || \ defined(CONFIG_MMC) printf("Interface: "); - switch(cur_dev->if_type) { + switch (cur_dev->if_type) { case IF_TYPE_IDE : printf("IDE"); break; case IF_TYPE_SCSI : printf("SCSI"); break; case IF_TYPE_ATAPI : printf("ATAPI"); break; case IF_TYPE_USB : printf("USB"); break; case IF_TYPE_DOC : printf("DOC"); break; case IF_TYPE_MMC : printf("MMC"); break; - default : printf("Unknown"); + default : printf("Unknown"); break; } - printf("\n Device %d: ",cur_dev->dev); + printf("\n Device %d: ", cur_dev->dev); dev_print(cur_dev); #endif - if(read_bootsectandvi(&bs, &volinfo, &fatsize)) { + if (read_bootsectandvi(&bs, &volinfo, &fatsize)) { printf("\nNo valid FAT fs found\n"); return 1; } - memcpy (vol_label, volinfo.volume_label, 11); + memcpy(vol_label, volinfo.volume_label, 11); vol_label[11] = '\0'; - volinfo.fs_type[5]='\0'; - printf("Partition %d: Filesystem: %s "%s"\n" - ,cur_part,volinfo.fs_type,vol_label); + volinfo.fs_type[5] = '\0'; + printf("Partition %d: Filesystem: %s "%s"\n", cur_part, + volinfo.fs_type, vol_label); return 0; }
- -int -file_fat_ls(const char *dir) +int file_fat_ls(const char *dir) { return do_fat_read(dir, NULL, 0, LS_YES); }
- -long -file_fat_read(const char *filename, void *buffer, unsigned long maxsize) +long file_fat_read(const char *filename, void *buffer, unsigned long maxsize) { - printf("reading %s\n",filename); + printf("reading %s\n", filename); return do_fat_read(filename, buffer, maxsize, LS_NO); } diff --git a/fs/fat/file.c b/fs/fat/file.c index e870734..e300ff7 100644 --- a/fs/fat/file.c +++ b/fs/fat/file.c @@ -34,8 +34,9 @@
/* Supported filesystems */ static const struct filesystem filesystems[] = { - { file_fat_detectfs, file_fat_ls, file_fat_read, "FAT" }, + {file_fat_detectfs, file_fat_ls, file_fat_read, "FAT"}, }; + #define NUM_FILESYS (sizeof(filesystems)/sizeof(struct filesystem))
/* The filesystem which was last detected */ @@ -43,56 +44,54 @@ static int current_filesystem = FSTYPE_NONE;
/* The current working directory */ #define CWD_LEN 511 -char file_cwd[CWD_LEN+1] = "/"; +char file_cwd[CWD_LEN + 1] = "/";
-const char * -file_getfsname(int idx) +const char *file_getfsname(int idx) { - if (idx < 0 || idx >= NUM_FILESYS) return NULL; + if (idx < 0 || idx >= NUM_FILESYS) + return NULL;
return filesystems[idx].name; }
- -static void -pathcpy(char *dest, const char *src) +static void pathcpy(char *dest, const char *src) { char *origdest = dest;
- do { - if (dest-file_cwd >= CWD_LEN) { + for (;;) { + if (dest - file_cwd >= CWD_LEN) { *dest = '\0'; return; } *(dest) = *(src); if (*src == '\0') { - if (dest-- != origdest && ISDIRDELIM(*dest)) { + if (dest-- != origdest && ISDIRDELIM(*dest)) *dest = '\0'; - } + return; } ++dest; - if (ISDIRDELIM(*src)) { - while (ISDIRDELIM(*src)) src++; - } else { + if (ISDIRDELIM(*src)) + while (ISDIRDELIM(*src)) + src++; + else src++; - } - } while (1); + } }
- -int -file_cd(const char *path) +int file_cd(const char *path) { if (ISDIRDELIM(*path)) { - while (ISDIRDELIM(*path)) path++; - strncpy(file_cwd+1, path, CWD_LEN-1); + while (ISDIRDELIM(*path)) + path++; + strncpy(file_cwd + 1, path, CWD_LEN - 1); } else { const char *origpath = path; char *tmpstr = file_cwd; int back = 0;
- while (*tmpstr != '\0') tmpstr++; + while (*tmpstr != '\0') + tmpstr++; do { tmpstr--; } while (ISDIRDELIM(*tmpstr)); @@ -108,7 +107,8 @@ file_cd(const char *path) back = 0; break; } - while (ISDIRDELIM(*path)) path++; + while (ISDIRDELIM(*path)) + path++; origpath = path; }
@@ -123,7 +123,8 @@ file_cd(const char *path) break; } /* Skip delimiters */ - while (ISDIRDELIM(*tmpstr)) tmpstr--; + while (ISDIRDELIM(*tmpstr)) + tmpstr--; } tmpstr++; if (*path == '\0') { @@ -135,15 +136,13 @@ file_cd(const char *path) return 0; } *tmpstr = '/'; - pathcpy(tmpstr+1, path); + pathcpy(tmpstr + 1, path); }
return 0; }
- -int -file_detectfs(void) +int file_detectfs(void) { int i;
@@ -160,9 +159,7 @@ file_detectfs(void) return current_filesystem; }
- -int -file_ls(const char *dir) +int file_ls(const char *dir) { char fullpath[1024]; const char *arg; @@ -181,9 +178,7 @@ file_ls(const char *dir) return filesystems[current_filesystem].ls(arg); }
- -long -file_read(const char *filename, void *buffer, unsigned long maxsize) +long file_read(const char *filename, void *buffer, unsigned long maxsize) { char fullpath[1024]; const char *arg; diff --git a/include/fat.h b/include/fat.h index c8b9493..be7023a 100644 --- a/include/fat.h +++ b/include/fat.h @@ -49,7 +49,6 @@ #define FAT16BUFSIZE (FATBUFSIZE/2) #define FAT32BUFSIZE (FATBUFSIZE/4)
- /* Filesystem identifiers */ #define FAT12_SIGN "FAT12 " #define FAT16_SIGN "FAT16 " @@ -140,8 +139,7 @@ typedef struct boot_sector { __u16 reserved2[6]; /* Unused */ } boot_sector;
-typedef struct volume_info -{ +typedef struct volume_info { __u8 drive_number; /* BIOS drive number */ __u8 reserved; /* Unused */ __u8 ext_boot_sign; /* 0x29 if fields below exist (DOS 3.3+) */ @@ -188,7 +186,8 @@ typedef struct { __u16 fat_sect; /* Starting sector of the FAT */ __u16 rootdir_sect; /* Start sector of root directory */ __u16 clust_size; /* Size of clusters in sectors */ - short data_begin; /* The sector of the first cluster, can be negative */ + short data_begin; /* The sector of the first cluster, + * can be negative */ int fatbufnum; /* Used by get_fatent, init to -1 */ } fsdata;
Dear =?utf-8?q?Remy=20B=C3=B6hmer?=,
...but your new code has new issues, too.
Multi-line statements do require the curly braces, and two lines is multi-line.
And this...
- do {
- actsize = bytesperclust;
- endclust = curclust;
- for (;;) { /* search for consecutive clusters */
goto getit;
return -1;
buffer += actsize;
curclust);
return gotsize;
continue;
...looks like a massive code change, not only a coding style cleanup. Please submit as two separate patches.
Hello Wolfgang,
Nothing is perfect... Making this code perfect would require a complete rewrite... ;-) The (original) code is buggy too, because I have discovered a strange bug which is causing me quite some headaches last week... ;-) (I have a usb stick here which shows different contents in U-boot than on Linux/Windows, U-boot shows the contents that was on the stick a long time ago, and what it reads is even valid...)
At least formatting/whitespaces/tabs is better now. Long indentations and similar code has been moved into separate routines and so on.
And this...
endclust=curclust;
do {
goto getit;
return -1;
buffer += actsize;
curclust);
return gotsize;
continue;
No, I just reordered a strange construction, by moved a piece of code that could only be reached by goto to a label to the place where the goto was listed. This made the code more readable. To me this is still just coding style.
There are a few little things that could be put into a separate patch. I will see what I can do...
Kind regards,
Remy
Dear Remy,
In message 3efb10970812090013o2f7dcb3ck6a0e3f9bcf4a4add@mail.gmail.com you wrote:
Maybe - but please let's be strict and keep reformatting, code reorganization and bug fixing all separate.
This is code reorganization, not mere reformatting.
Ok, then let's use clear terminology.
Please split such that reformatting is separate from code reorganization, and any code changes/bug fixes is a third (group of) patch(es).
Thanks.
Remy Bohmer
Remy Böhmer
