[U-Boot-Users] Xilinx Spartan3 CRC error during FPGA load
does anybody have a CRC problem programming Xilinx Spartan3 in slave serial mode? I'm using u-boot-1.3.0 with Matthias suggested changes in bit swapping and always get the same error. The .bit is ok since it was programmed using JTAG and works fine. The command sequence and u-boot debug messages are below for reference. Any suggestion is appreciated.
Thx, TT
=> tftp 100000 fpganew.bit Using FEC ETHERNET device TFTP from server 192.168.1.100; our IP address is 192.168.1.1 Filename 'fpganew.bit'. Load address: 0x100000 Loading: ######### done Bytes transferred = 131034 (1ffda hex) => fpga loadb 0 100000 ${filesize} do_fpga: fpga_data = 0x100000 do_fpga: device = 0 design filename = "fpga_top.ncd" part number = "3s200tq144" date = "2008/ 3/25" time = "16:37:58" bytes in bitstream = 130952 fpga_get_desc: found fpga descriptor #0 @ 0x01ffad04 Spartan3_load: Launching Slave Serial Load Spartan3_ss_load: start with interface functions @ 0x01ff8c00 Spartan3_ss_load: Function Table: ptr: 0x01bb6a90 struct: 0x01ff8c00 pgm: 0x01febf80 init: 0x01fec000 clk: 0x01fec0e8 wr: 0x01fec118 done: 0x01fec070
Loading FPGA Device 0... fpga_pre_fn:111: FPGA pre-configuration fpga_pgm_fn:122: FPGA PROGRAM asserted fpga_init_fn:145: INIT check... low fpga_pgm_fn:122: FPGA PROGRAM deasserted fpga_init_fn:145: INIT check... high ........................................fpga_init_fn:145: INIT check... high fpga_init_fn:145: INIT check... low ** CRC error during FPGA load. bytecount=130938, bsize=130952
Thx, TT
I am using slave serial mode with a Spartan 3E FPGA on the PMC440 board. Please see board/esd/pmc440/fpga.c.
I have no problem. May I ask how you created the .bit file? You should not use a 'prom' file. prom files can have a swapped bit order.
Matthias
Thx, TT
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Matthias Fuchs
Tales Toledo
