[PATCH v1] tee: sandbox: check for buffer size
Add additional check for buffer size when reading out persistent storage value and provide back actual value size.
Signed-off-by: Igor Opaniuk igor.opaniuk@gmail.com ---
drivers/tee/sandbox.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/tee/sandbox.c b/drivers/tee/sandbox.c index 8ad7c09efdd..86b16a3bb8d 100644 --- a/drivers/tee/sandbox.c +++ b/drivers/tee/sandbox.c @@ -174,7 +174,7 @@ static u32 ta_avb_invoke_func(struct udevice *dev, u32 func, uint num_params, uint slot; u64 val; char *value; - u32 value_sz; + u32 value_sz, tmp_sz;
switch (func) { case TA_AVB_CMD_READ_ROLLBACK_INDEX: @@ -267,8 +267,12 @@ static u32 ta_avb_invoke_func(struct udevice *dev, u32 func, uint num_params, if (!ep) return TEE_ERROR_ITEM_NOT_FOUND;
- value_sz = strlen(ep->data) + 1; - memcpy(value, ep->data, value_sz); + tmp_sz = strlen(ep->data) + 1; + if (value_sz < tmp_sz) + return TEE_ERROR_SHORT_BUFFER; + + memcpy(value, ep->data, tmp_sz); + params[1].u.memref.size = tmp_sz;
return TEE_SUCCESS; case TA_AVB_CMD_WRITE_PERSIST_VALUE:
Reviewed-by: Oleksandr Suvorov cryosay@gmail.com
u32 value_sz;
u32 value_sz, tmp_sz; switch (func) { case TA_AVB_CMD_READ_ROLLBACK_INDEX:
params[1].u.memref.size = tmp_sz; return TEE_SUCCESS; case TA_AVB_CMD_WRITE_PERSIST_VALUE:
-- 2.34.1
- u32 value_sz;
-- 2.34.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Igor Opaniuk
Ilias Apalodimas
Oleksandr Suvorov
