[U-Boot] [PATCH] omap3: Fixed a problem with hwecc
In commit 187af954cf7958c24efcf0fd62289bbdb4f1f24e there was a typo that offset all the ecc registers by 4 bytes, fixed that.
Signed-off-by: Ben Goska goskab@onid.oregonstate.edu --- include/asm-arm/arch-omap3/cpu.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/asm-arm/arch-omap3/cpu.h b/include/asm-arm/arch-omap3/cpu.h index 7a032b8..8ab2e39 100644 --- a/include/asm-arm/arch-omap3/cpu.h +++ b/include/asm-arm/arch-omap3/cpu.h @@ -120,9 +120,9 @@ struct gpmc { u8 res4[0xC]; u32 config; /* 0x50 */ u32 status; /* 0x54 */ - u8 res5[0x8]; + u8 res5[0x8]; /* 0x58 */ struct gpmc_cs cs[8]; /* 0x60, 0x90, .. */ - u8 res6[0x18]; + u8 res6[0x14]; /* 0x1E0 */ u32 ecc_config; /* 0x1F4 */ u32 ecc_control; /* 0x1F8 */ u32 ecc_size_config; /* 0x1FC */
Acked-by: Dirk Behme dirk.behme@googlemail.com
Should be applied as bugfix to -rc.
Thanks
Dirk
- u8 res5[0x8];
- u8 res5[0x8]; /* 0x58 */ struct gpmc_cs cs[8]; /* 0x60, 0x90, .. */
- u8 res6[0x18];
- u8 res6[0x14]; /* 0x1E0 */ u32 ecc_config; /* 0x1F4 */ u32 ecc_control; /* 0x1F8 */ u32 ecc_size_config; /* 0x1FC */
apply to u-boot-arm
Best Regards, J.
Ben Goska
Dirk Behme
Jean-Christophe PLAGNIOL-VILLARD
