[U-Boot] [PATCH] dfu: mmc: call fs functions instead of run_command
This unbreaks dfu mmc_file_op which is currently broken since using the load cmd on a buffer from heap is not allowed - added with commit aa3c609e2be5 ("fs: prevent overwriting reserved memory")
Fixes: commit aa3c609e2be5 ("fs: prevent overwriting reserved memory") Reported-by: Stephen Warren swarren@wwwdotorg.org Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Tested-by: Stephen Warren swarren@nvidia.com ---
Changes since RFC: - decreased size of 'dev_part_str' to hold 'xxx:yyy' string - removed now unused define 'DFU_CMD_BUF_SIZE'
--- drivers/dfu/dfu_mmc.c | 67 ++++++++++++++++++++----------------------- include/dfu.h | 1 - 2 files changed, 31 insertions(+), 37 deletions(-)
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index b45e6dc54c..403fd5351d 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -108,17 +108,17 @@ static int mmc_file_buffer(struct dfu_entity *dfu, void *buf, long *len) static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, void *buf, u64 *len) { - const char *fsname, *opname; - char cmd_buf[DFU_CMD_BUF_SIZE]; - char *str_env; + char dev_part_str[8]; int ret; + int fstype; + loff_t size = 0;
switch (dfu->layout) { case DFU_FS_FAT: - fsname = "fat"; + fstype = FS_TYPE_FAT; break; case DFU_FS_EXT4: - fsname = "ext4"; + fstype = FS_TYPE_EXT; break; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, @@ -126,48 +126,43 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, return -1; }
+ snprintf(dev_part_str, sizeof(dev_part_str), "%d:%d", + dfu->data.mmc.dev, dfu->data.mmc.part); + + ret = fs_set_blk_dev("mmc", dev_part_str, fstype); + if (ret) { + puts("dfu: fs_set_blk_dev error!\n"); + return ret; + } + switch (op) { case DFU_OP_READ: - opname = "load"; + ret = fs_read(dfu->name, (size_t)buf, 0, 0, &size); + if (ret) { + puts("dfu: fs_read error!\n"); + return ret; + } + *len = size; break; case DFU_OP_WRITE: - opname = "write"; + ret = fs_write(dfu->name, (size_t)buf, 0, *len, &size); + if (ret) { + puts("dfu: fs_write error!\n"); + return ret; + } break; case DFU_OP_SIZE: - opname = "size"; + ret = fs_size(dfu->name, &size); + if (ret) { + puts("dfu: fs_size error!\n"); + return ret; + } + *len = size; break; default: return -1; }
- sprintf(cmd_buf, "%s%s mmc %d:%d", fsname, opname, - dfu->data.mmc.dev, dfu->data.mmc.part); - - if (op != DFU_OP_SIZE) - sprintf(cmd_buf + strlen(cmd_buf), " %p", buf); - - sprintf(cmd_buf + strlen(cmd_buf), " %s", dfu->name); - - if (op == DFU_OP_WRITE) - sprintf(cmd_buf + strlen(cmd_buf), " %llx", *len); - - debug("%s: %s 0x%p\n", __func__, cmd_buf, cmd_buf); - - ret = run_command(cmd_buf, 0); - if (ret) { - puts("dfu: Read error!\n"); - return ret; - } - - if (op != DFU_OP_WRITE) { - str_env = env_get("filesize"); - if (str_env == NULL) { - puts("dfu: Wrong file size!\n"); - return -1; - } - *len = simple_strtoul(str_env, NULL, 16); - } - return ret; }
diff --git a/include/dfu.h b/include/dfu.h index fbe978abdc..c671d8b04d 100644 --- a/include/dfu.h +++ b/include/dfu.h @@ -80,7 +80,6 @@ struct sf_internal_data { };
#define DFU_NAME_SIZE 32 -#define DFU_CMD_BUF_SIZE 128 #ifndef CONFIG_SYS_DFU_DATA_BUF_SIZE #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1024*1024*8) /* 8 MiB */ #endif
Any chance we could get this applied (directly to u-boot/master) to fix the rampant test failures? Thanks.
Hi Stephen, Tom,
Tom, I've acked this patch (in other mail). Please feel free to apply it to -master branch.
Thanks for fixing it :-) (the code was really old and I'm glad that it was updated to fs_* functions).
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Acked-by: Lukasz Majewski lukma@denx.de
Changes since RFC:
- char *str_env;
int fstype;
loff_t size = 0;
fsname = "fat";
break; case DFU_FS_EXT4:fstype = FS_TYPE_FAT;
fsname = "ext4";
break; default: printf("%s: Layout (%s) not (yet) supported!\n",fstype = FS_TYPE_EXT;
- snprintf(dev_part_str, sizeof(dev_part_str), "%d:%d",
- ret = fs_set_blk_dev("mmc", dev_part_str, fstype);
- if (ret) {
return ret;
- switch (op) { case DFU_OP_READ:
opname = "load";
if (ret) {
return ret;
break; case DFU_OP_WRITE:*len = size;
opname = "write";
&size);
if (ret) {
return ret;
break; case DFU_OP_SIZE:}
opname = "size";
if (ret) {
return ret;
break; default: return -1; }*len = size;
- if (ret) {
return ret;
return -1;
- return ret;
Lukasz Majewski
Fixes: commit aa3c609e2be5 ("fs: prevent overwriting reserved memory") Reported-by: Stephen Warren swarren@wwwdotorg.org Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Tested-by: Stephen Warren swarren@nvidia.com Acked-by: Lukasz Majewski lukma@denx.de
Great, the testing is green again:-) Thanks. (Now we just need -video, -dm, and -net to rebase on u-boot/master so they go green again too).
Lukasz Majewski
Simon Goldschmidt
Stephen Warren
