[U-Boot] [RFC PATCH] Allow providing default environment from file
It is sometimes useful to be able to define the entire default environment in an external file. This implements a Kconfig option for allowing that.
It is somewhat annoying to have two visible Kconfig options; it would probably be more user-friendly to just have the string option (with empty string obviously meaning not to use this feature). But then we'd also need a hidden CONFIG that we can use in the #ifdef in env_default.h, and I don't think one can set a def_bool based on whether a string-valued config is empty or not.
I've tried to make the accepted format the same as the one the mkenvimage tool accepts. I have no idea how portable the sed script implementing the "allow embedded newlines in values" is. Nor do I know if one can expect xxd to be available.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- Makefile | 16 ++++++++++++++++ env/Kconfig | 18 ++++++++++++++++++ include/env_default.h | 4 ++++ 3 files changed, 38 insertions(+)
diff --git a/Makefile b/Makefile index 4981a2ed6f..e5ba5213fd 100644 --- a/Makefile +++ b/Makefile @@ -423,6 +423,7 @@ endif
version_h := include/generated/version_autogenerated.h timestamp_h := include/generated/timestamp_autogenerated.h +defaultenv_h := include/generated/defaultenv_autogenerated.h
no-dot-config-targets := clean clobber mrproper distclean \ help %docs check% coccicheck \ @@ -1366,6 +1367,10 @@ ifeq ($(wildcard $(LDSCRIPT)),) @/bin/false endif
+ifeq ($(CONFIG_DEFAULT_ENV_FROM_FILE),y) +prepare1: $(defaultenv_h) +endif + archprepare: prepare1 scripts_basic
prepare0: archprepare FORCE @@ -1413,12 +1418,23 @@ define filechk_timestamp.h fi) endef
+define filechk_defaultenv.h + (grep -v '^#' | \ + grep -v '^$$' | \ + tr '\n' '\0' | \ + sed -e 's/\\x0/\n/' | \ + xxd -i ; echo ", 0x00" ; ) +endef + $(version_h): include/config/uboot.release FORCE $(call filechk,version.h)
$(timestamp_h): $(srctree)/Makefile FORCE $(call filechk,timestamp.h)
+$(defaultenv_h): $(CONFIG_DEFAULT_ENV_FILE:"%"=%) FORCE + $(call filechk,defaultenv.h) + # --------------------------------------------------------------------------- quiet_cmd_cpp_lds = LDS $@ cmd_cpp_lds = $(CPP) -Wp,-MD,$(depfile) $(cpp_flags) $(LDPPFLAGS) \ diff --git a/env/Kconfig b/env/Kconfig index a24370786b..1baebd743b 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -482,4 +482,22 @@ config ENV_SIZE
endif
+config DEFAULT_ENV_FROM_FILE + bool "Create default environment from file" + help + Normally, the default environment is automatically generated + based on the settings of various CONFIG_* options, as well + as the CONFIG_EXTRA_ENV_SETTINGS. By selecting this option, + you can instead define the entire default environment in an + external file. + +config DEFAULT_ENV_FILE + string "Path to default environment file" + depends on DEFAULT_ENV_FROM_FILE + help + The path containing the default environment. The format is + the same as accepted by the mkenvimage tool: lines + containing key=value pairs, blank lines and lines beginning + with # are ignored. + endmenu diff --git a/include/env_default.h b/include/env_default.h index b574345af2..656d202cc7 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -22,6 +22,7 @@ static char default_environment[] = { #else const uchar default_environment[] = { #endif +#ifndef CONFIG_DEFAULT_ENV_FROM_FILE #ifdef CONFIG_ENV_CALLBACK_LIST_DEFAULT ENV_CALLBACK_VAR "=" CONFIG_ENV_CALLBACK_LIST_DEFAULT "\0" #endif @@ -108,6 +109,9 @@ const uchar default_environment[] = { CONFIG_EXTRA_ENV_SETTINGS #endif "\0" +#else /* CONFIG_DEFAULT_ENV_FROM_FILE */ +#include "generated/defaultenv_autogenerated.h" +#endif #ifdef DEFAULT_ENV_INSTANCE_EMBEDDED } #endif
Hi Rasmus,
There is already available script for extracting the environment.
Please look into: ./scripts/get_default_envs.sh
Maybe you can reuse it in this patch?
- (grep -v '^#' | \
grep -v '^$$' | \
tr '\n' '\0' | \
sed -e 's/\\\x0/\n/' | \
+endef
- $(call filechk,defaultenv.h)
endif
- bool "Create default environment from file"
- help
generated
external file.
- string "Path to default environment file"
- depends on DEFAULT_ENV_FROM_FILE
- help
with # are ignored.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
On 2018-01-25 10:30, Lukasz Majewski wrote:
Hi Rasmus,
I'm sorry, but I don't see what I could use that for. It seems to do the opposite of what I want, namely extract the default environment and store it in a plain-text file. I want to provide a plain-text file to define the default environment.
It's quite likely that that script can be useful for generating a sketch for the external file (i.e., build a U-boot as "usual" with default environment built from various config options etc. etc., then hand-edit that file to remove redundant stuff and add the things one needs). The thing is, having the default environment in an external file makes it much easier to put it under version control than having to maintain a branch inside the U-boot repo just to tweak CONFIG_EXTRA_ENV_SETTINGS.
Rasmus
Hi Rasmus,
Hi Rasmus,
Sorry. I have had misunderstood the patch description.
Ok. Then your patch seems perfectly valid.
Rasmus
Lukasz Majewski
Tested-by: Sean Nyekjaer sean.nyekjaer@prevas.dk
- (grep -v '^#' | \
grep -v '^$$' | \
tr '\n' '\0' | \
+endef
- # --------------------------------------------------------------------------- quiet_cmd_cpp_lds = LDS $@ cmd_cpp_lds = $(CPP) -Wp,-MD,$(depfile) $(cpp_flags) $(LDPPFLAGS) \
endif
- help
external file.
- help
with # are ignored.
- endmenu
ping
ping
Hi Tom Will you please take a look a this? /Sean
Conceptually, this is fine. But can you please re-word the commit message and put some of the commentary below the --- ? Also, in general we do a pair of CONFIG_USE_xxx and CONFIG_xxx, so you might need to re-word the rest of the option name a bit too to match that. Thanks!
Modifying the default environment via CONFIG_EXTRA_ENV_SETTINGS is somewhat inflexible, partly because the cpp language does not allow appending to an existing macro. This prevents reuse of "environment fragments" for different boards, which in turn makes maintaining that environment consistently tedious and error-prone.
This implements a Kconfig option for allowing one to define the entire default environment in an external file, which can then, for example, be generated programmatically as part of a Yocto recipe, or simply be kept in version control separately from the U-boot repository.
Tested-by: Sean Nyekjaer sean.nyekjaer@prevas.dk Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- v2: * rename CONFIG_DEFAULT_ENV_FROM_FILE -> CONFIG_USE_DEFAULT_ENV_FILE * add Tested-by * provide a little more rationale (example use case instead of just "sometimes be useful") * rebase to current master (v2018.03-189-gda773532cd)
This adds xxd as a build-time requirement. Not sure whether that needs mentioning in the Kconfig help text. On my Ubuntu 16.04, it is provided by the vim-common package, while more recent Ubuntu and Debian seem to have split it to a separate package.
diff --git a/Makefile b/Makefile index 5fa14789d9..867b189c41 100644 --- a/Makefile +++ b/Makefile @@ -423,6 +423,7 @@ endif
no-dot-config-targets := clean clobber mrproper distclean \ help %docs check% coccicheck \ @@ -1387,6 +1388,10 @@ ifeq ($(wildcard $(LDSCRIPT)),) @/bin/false endif
+ifeq ($(CONFIG_USE_DEFAULT_ENV_FILE),y) +prepare1: $(defaultenv_h) +endif + archprepare: prepare1 scripts_basic
prepare0: archprepare FORCE @@ -1434,12 +1439,23 @@ define filechk_timestamp.h fi) endef
+$(defaultenv_h): $(CONFIG_DEFAULT_ENV_FILE:"%"=%) FORCE + $(call filechk,defaultenv.h) + # --------------------------------------------------------------------------- quiet_cmd_cpp_lds = LDS $@ cmd_cpp_lds = $(CPP) -Wp,-MD,$(depfile) $(cpp_flags) $(LDPPFLAGS) \ diff --git a/env/Kconfig b/env/Kconfig index a3c6298273..e8e21dcfc6 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -486,4 +486,22 @@ config ENV_SIZE
endif
+config USE_DEFAULT_ENV_FILE + bool "Create default environment from file" + help + Normally, the default environment is automatically generated + based on the settings of various CONFIG_* options, as well + as the CONFIG_EXTRA_ENV_SETTINGS. By selecting this option, + you can instead define the entire default environment in an + external file. + +config DEFAULT_ENV_FILE + string "Path to default environment file" + depends on USE_DEFAULT_ENV_FILE + help + The path containing the default environment. The format is + the same as accepted by the mkenvimage tool: lines + containing key=value pairs, blank lines and lines beginning + with # are ignored. + endmenu diff --git a/include/env_default.h b/include/env_default.h index b574345af2..1fbeb92f38 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -22,6 +22,7 @@ static char default_environment[] = { #else const uchar default_environment[] = { #endif +#ifndef CONFIG_USE_DEFAULT_ENV_FILE #ifdef CONFIG_ENV_CALLBACK_LIST_DEFAULT ENV_CALLBACK_VAR "=" CONFIG_ENV_CALLBACK_LIST_DEFAULT "\0" #endif @@ -108,6 +109,9 @@ const uchar default_environment[] = { CONFIG_EXTRA_ENV_SETTINGS #endif "\0" +#else /* CONFIG_USE_DEFAULT_ENV_FILE */ +#include "generated/defaultenv_autogenerated.h" +#endif #ifdef DEFAULT_ENV_INSTANCE_EMBEDDED } #endif
Hi Rasmus,
It is also possible to build boot.scr image, which is afterwards read from e.g. vfat, from text file.
As a reference and example please look into ./boards/samsung/common/bootscripts/*.cmd
Is this yocto generation upstreamed? Or this is some kind of internal patch?
v2:
- rename CONFIG_DEFAULT_ENV_FROM_FILE -> CONFIG_USE_DEFAULT_ENV_FILE
- add Tested-by
- provide a little more rationale (example use case instead of just "sometimes be useful")
- rebase to current master (v2018.03-189-gda773532cd)
- (grep -v '^#' | \
grep -v '^$$' | \
tr '\n' '\0' | \
+endef
endif
- help
generated
external file.
- depends on USE_DEFAULT_ENV_FILE
- help
with # are ignored.
The patch looks ok.
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
On 2018-03-20 15:20, Lukasz Majewski wrote:
Hi Rasmus,
Neither, for now, we're just using the "entire environment in file maintained elsewhere" model. But I can easily see us using the ability to amend the environment with a simple "echo ... >> foo.env" in some pre/postfunc, or having foo.env contain some __PLACEHOLDER__ which we fix up with sed using values from .conf files before the U-boot build. Stuff like tftp server ip address is nice to be able to override easily to point at one's own laptop while doing development.
The patch looks ok.
Thanks.
Rasmus
Hi Rasmus,
The patch looks ok.
Any chance this could get picked up, or is there anything more needed on my end?
Thanks, Rasmus
Tested-by: Sean Nyekjaer sean.nyekjaer@prevas.dk Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk Reviewed-by: Lukasz Majewski lukma@denx.de
participants (5)
Lukasz Majewski
Rasmus Villemoes
Sean Nyekjaer
Sean Nyekjær
