[U-Boot] [PATCH] xilinx_phy: Pass correct pointer to fdtdec_get_int()
This patch fixes incorrect pointer on offset device in device tree blob. When using with the component "Ethernet 1G/2.5G BASE-X PCS/PMA or SGMII" it does not understand what type is XAE_PHY_TYPE_1000BASE_X and trying to change frequency.
Signed-off-by: Kamensky Ivan kamensky.ivan@mail.ru Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/net/phy/xilinx_phy.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/phy/xilinx_phy.c b/drivers/net/phy/xilinx_phy.c index f3eaf2e97ced..920bfcb380b3 100644 --- a/drivers/net/phy/xilinx_phy.c +++ b/drivers/net/phy/xilinx_phy.c @@ -101,11 +101,11 @@ static int xilinxphy_startup(struct phy_device *phydev)
static int xilinxphy_of_init(struct phy_device *phydev) { - struct udevice *dev = (struct udevice *)&phydev->dev; u32 phytype;
debug("%s\n", __func__); - phytype = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "phy-type", -1); + phytype = fdtdec_get_int(gd->fdt_blob, phydev->dev->of_offset, + "phy-type", -1); if (phytype == XAE_PHY_TYPE_1000BASE_X) phydev->flags |= XAE_PHY_TYPE_1000BASE_X;
Joe Hershberger
Michal Simek
