[U-Boot] [PATCH] drivers/net/vsc9953: Initialize action RAM in VCAP complex
VCAP tables must be initialized even if no advanced classification is used. If no initialization is performed, then ECC error will be observed by the user when the first packet enters the l2switch. The error is marked in MPIC_EISR0 -bit 29 which means - Internal RAM multi-bit ECC error. This patch fixes the aforementioned ECC error by performing the initialization of VCAP tables.
Signed-off-by: Radu Bulie radu-andrei.bulie@nxp.com --- drivers/net/vsc9953.c | 134 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/vsc9953.h | 58 ++++++++++++++++++++++ 2 files changed, 192 insertions(+)
diff --git a/drivers/net/vsc9953.c b/drivers/net/vsc9953.c index 2388438..f90181d 100644 --- a/drivers/net/vsc9953.c +++ b/drivers/net/vsc9953.c @@ -2469,6 +2469,139 @@ void vsc9953_default_configuration(void) debug("VSC9953: failed to set default aggregation code mode\n"); }
+static void vcap_entry2cache_init(u32 target, u32 entry_words) +{ + int i; + + for (i = 0; i < entry_words; i++) { + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_ENTRY_DAT(target, i)), 0x00); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_MASK_DAT(target, i)), 0xFF); + } + + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_TG_DAT(target)), 0x00); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_MV_CFG(target)), + VSC9953_VCAP_CFG_MV_CFG_SIZE(entry_words)); +} + +static void vcap_action2cache_init(u32 target, u32 action_words, + u32 counter_words) +{ + int i; + + for (i = 0; i < action_words; i++) + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_ACTION_DAT(target, i)), 0x00); + + for (i = 0; i < counter_words; i++) + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_CNT_DAT(target, i)), 0x00); +} + +static int vcap_cmd(u32 target, u16 ix, int cmd, int sel, int entry_count) +{ + u32 tgt = target; + u32 value = (VSC9953_VCAP_UPDATE_CTRL_UPDATE_CMD(cmd) | + VSC9953_VCAP_UPDATE_CTRL_UPDATE_ADDR(ix) | + VSC9953_VCAP_UPDATE_CTRL_UPDATE_SHOT); + + if ((sel & TCAM_SEL_ENTRY) && ix >= entry_count) + return CMD_RET_FAILURE; + + if (!(sel & TCAM_SEL_ENTRY)) + value |= VSC9953_VCAP_UPDATE_CTRL_UPDATE_ENTRY_DIS; + + if (!(sel & TCAM_SEL_ACTION)) + value |= VSC9953_VCAP_UPDATE_CTRL_UPDATE_ACTION_DIS; + + if (!(sel & TCAM_SEL_COUNTER)) + value |= VSC9953_VCAP_UPDATE_CTRL_UPDATE_CNT_DIS; + + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_UPDATE_CTRL(tgt)), value); + + do { + value = in_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_UPDATE_CTRL(tgt))); + + } while (value & VSC9953_VCAP_UPDATE_CTRL_UPDATE_SHOT); + + return CMD_RET_SUCCESS; +} + +static void vsc9953_vcap_init(void) +{ + u32 tgt = VSC9953_ES0; + int cmd_ret; + + /* write entries */ + vcap_entry2cache_init(tgt, ENTRY_WORDS_ES0); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, TCAM_SEL_ENTRY, + ENTRY_WORDS_ES0); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ENTRY\n", + __LINE__); + + /* write actions and counters */ + vcap_action2cache_init(tgt, BITS_TO_DWORD(91), BITS_TO_DWORD(1)); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_MV_CFG(tgt)), + VSC9953_VCAP_CFG_MV_CFG_SIZE(VSC9953_ES0_CNT + VSC9953_PORTS)); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, + TCAM_SEL_ACTION | TCAM_SEL_COUNTER, ENTRY_WORDS_ES0); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ACTION | TCAM_SEL_COUNTER\n", + __LINE__); + + tgt = VSC9953_IS1; + + /* write entries */ + vcap_entry2cache_init(tgt, ENTRY_WORDS_IS1); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, TCAM_SEL_ENTRY, + ENTRY_WORDS_IS1); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ENTRY\n", + __LINE__); + + /* write actions and counters */ + vcap_action2cache_init(tgt, BITS_TO_DWORD(320), BITS_TO_DWORD(4)); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_MV_CFG(tgt)), + VSC9953_VCAP_CFG_MV_CFG_SIZE(VSC9953_IS1_CNT + 1)); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, + TCAM_SEL_ACTION | TCAM_SEL_COUNTER, ENTRY_WORDS_IS1); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ACTION | TCAM_SEL_COUNTER\n", + __LINE__); + + tgt = VSC9953_IS2; + + /* write entries */ + vcap_entry2cache_init(tgt, ENTRY_WORDS_IS2); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, TCAM_SEL_ENTRY, + ENTRY_WORDS_IS2); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid selection: TCAM_SEL_ENTRY\n", + __LINE__); + + /* write actions and counters */ + vcap_action2cache_init(tgt, BITS_TO_DWORD(103 - 2 * + VSC9953_PORT_OFFSET), + BITS_TO_DWORD(4 * 32)); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_MV_CFG(tgt)), + VSC9953_VCAP_CFG_MV_CFG_SIZE(VSC9953_IS2_CNT + + VSC9953_PORTS + 2)); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, + TCAM_SEL_ACTION | TCAM_SEL_COUNTER, ENTRY_WORDS_IS2); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ACTION | TCAM_SEL_COUNTER\n", + __LINE__); +} + void vsc9953_init(bd_t *bis) { u32 i; @@ -2605,6 +2738,7 @@ void vsc9953_init(bd_t *bis) } }
+ vsc9953_vcap_init(); vsc9953_default_configuration();
#ifdef CONFIG_CMD_ETHSW diff --git a/include/vsc9953.h b/include/vsc9953.h index a2d4554..a1c31ce 100644 --- a/include/vsc9953.h +++ b/include/vsc9953.h @@ -187,6 +187,64 @@
#define MIIMIND_OPR_PEND 0x00000004
+#define VSC9953_BIT(x) (1U << (x)) +#define VSC9953_IO_BASE_OFFSET 0x00000000 +#define VSC9953_IO_OFFSET(offset) (VSC9953_IO_BASE_OFFSET + offset) +#define VSC9953_BITMASK(x) ((1U << (x)) - 1) +#define VSC9953_ENC_BITFIELD(x, o, w) (((x) & VSC9953_BITMASK(w)) << (o)) +#define VSC9953_IO_ADDR(t, o) ((((t) - VSC9953_IO_BASE_OFFSET)) + \ + (o << 2)) + +#define VSC9953_IO_REG(t, o) (VSC9953_IO_ADDR(t, o)) +#define VSC9953_VCAP_CACHE_ENTRY_DAT(target, ri) \ + VSC9953_IO_REG(target, (0x2 + (ri))) + +#define VSC9953_VCAP_CACHE_MASK_DAT(target, ri) \ + VSC9953_IO_REG(target, (0x42 + (ri))) + +#define VSC9953_VCAP_CACHE_TG_DAT(target) VSC9953_IO_REG(target, 0xe2) +#define VSC9953_VCAP_CFG_MV_CFG(target) VSC9953_IO_REG(target, 0x1) +#define VSC9953_VCAP_CFG_MV_CFG_SIZE(x) VSC9953_ENC_BITFIELD(x, 0, 16) +#define VSC9953_VCAP_CFG_UPDATE_CTRL(target) VSC9953_IO_REG(target, 0x0) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_CMD(x) VSC9953_ENC_BITFIELD(x, 22, 3) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_ADDR(x) VSC9953_ENC_BITFIELD(x, 3, 16) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_SHOT VSC9953_BIT(2) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_ENTRY_DIS VSC9953_BIT(21) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_ACTION_DIS VSC9953_BIT(20) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_CNT_DIS VSC9953_BIT(19) +#define VSC9953_VCAP_CACHE_ACTION_DAT(target, ri) \ + VSC9953_IO_REG(target, (0x82 + (ri))) + +#define VSC9953_VCAP_CACHE_CNT_DAT(target, ri) \ + VSC9953_IO_REG(target, (0xc2 + (ri))) + +#define VSC9953_PORT_OFFSET 1 +#define VSC9953_IS1_CNT 256 +#define VSC9953_IS2_CNT 1024 +#define VSC9953_ES0_CNT 1024 + +#define BITS_TO_DWORD(x) (1 + (((x) - 1) / 32)) +#define ENTRY_WORDS_ES0 BITS_TO_DWORD(29) +#define ENTRY_WORDS_IS1 BITS_TO_DWORD(376) +#define ENTRY_WORDS_IS2 BITS_TO_DWORD(376) +#define VSC9953_PORTS VSC9953_MAX_PORTS + +/* TCAM entries */ +enum tcam_sel { + TCAM_SEL_ENTRY = VSC9953_BIT(0), + TCAM_SEL_ACTION = VSC9953_BIT(1), + TCAM_SEL_COUNTER = VSC9953_BIT(2), + TCAM_SEL_ALL = VSC9953_BITMASK(3), +}; + +enum tcam_cmd { + TCAM_CMD_WRITE = 0, + TCAM_CMD_READ = 1, + TCAM_CMD_MOVE_UP = 2, + TCAM_CMD_MOVE_DOWN = 3, + TCAM_CMD_INITIALIZE = 4, +}; + struct vsc9953_mdio_info { struct vsc9953_mii_mng *regs; char *name;
int i;
u32 counter_words)
int i;
u32 tgt = target;
do {
int cmd_ret;
/* write entries */
ENTRY_WORDS_ES0);
__LINE__);
__LINE__);
tgt = VSC9953_IS1;
/* write entries */
ENTRY_WORDS_IS1);
__LINE__);
__LINE__);
tgt = VSC9953_IS2;
/* write entries */
ENTRY_WORDS_IS2);
__LINE__);
Please don't use magic numbers.
Why plus 2? Comment at least, but probably a define.
__LINE__);
Please use the standard macros for all.
This doesn't seem to add anything (literally).
(o << 2))
Please use descriptive parameters, not single letters. Also, whatever "o" is, should be "(o)".
Why do we need another name for this?
+enum tcam_cmd {
TCAM_CMD_WRITE = 0,
TCAM_CMD_READ = 1,
struct vsc9953_mdio_info { struct vsc9953_mii_mng *regs; char *name; -- 1.9.1
Signed-off-by: Radu Bulie radu-andrei.bulie@nxp.com --- Changes for v2: - removed magic numbers - added standard BIT macro - added descriptive params in macros instead of letters - removed redundant macro for port numbers
drivers/net/vsc9953.c | 134 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/vsc9953.h | 72 +++++++++++++++++++++++++++ 2 files changed, 206 insertions(+)
diff --git a/drivers/net/vsc9953.c b/drivers/net/vsc9953.c index 2388438..64a2f1e 100644 --- a/drivers/net/vsc9953.c +++ b/drivers/net/vsc9953.c @@ -2469,6 +2469,139 @@ void vsc9953_default_configuration(void) debug("VSC9953: failed to set default aggregation code mode\n"); }
+static void vcap_entry2cache_init(u32 target, u32 entry_words) +{ + int i; + + for (i = 0; i < entry_words; i++) { + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_ENTRY_DAT(target, i)), 0x00); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_MASK_DAT(target, i)), 0xFF); + } + + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_TG_DAT(target)), 0x00); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_MV_CFG(target)), + VSC9953_VCAP_CFG_MV_CFG_SIZE(entry_words)); +} + +static void vcap_action2cache_init(u32 target, u32 action_words, + u32 counter_words) +{ + int i; + + for (i = 0; i < action_words; i++) + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_ACTION_DAT(target, i)), 0x00); + + for (i = 0; i < counter_words; i++) + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CACHE_CNT_DAT(target, i)), 0x00); +} + +static int vcap_cmd(u32 target, u16 ix, int cmd, int sel, int entry_count) +{ + u32 tgt = target; + u32 value = (VSC9953_VCAP_UPDATE_CTRL_UPDATE_CMD(cmd) | + VSC9953_VCAP_UPDATE_CTRL_UPDATE_ADDR(ix) | + VSC9953_VCAP_UPDATE_CTRL_UPDATE_SHOT); + + if ((sel & TCAM_SEL_ENTRY) && ix >= entry_count) + return CMD_RET_FAILURE; + + if (!(sel & TCAM_SEL_ENTRY)) + value |= VSC9953_VCAP_UPDATE_CTRL_UPDATE_ENTRY_DIS; + + if (!(sel & TCAM_SEL_ACTION)) + value |= VSC9953_VCAP_UPDATE_CTRL_UPDATE_ACTION_DIS; + + if (!(sel & TCAM_SEL_COUNTER)) + value |= VSC9953_VCAP_UPDATE_CTRL_UPDATE_CNT_DIS; + + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_UPDATE_CTRL(tgt)), value); + + do { + value = in_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_UPDATE_CTRL(tgt))); + + } while (value & VSC9953_VCAP_UPDATE_CTRL_UPDATE_SHOT); + + return CMD_RET_SUCCESS; +} + +static void vsc9953_vcap_init(void) +{ + u32 tgt = VSC9953_ES0; + int cmd_ret; + + /* write entries */ + vcap_entry2cache_init(tgt, ENTRY_WORDS_ES0); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, TCAM_SEL_ENTRY, + ENTRY_WORDS_ES0); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ENTRY\n", + __LINE__); + + /* write actions and counters */ + vcap_action2cache_init(tgt, BITS_TO_DWORD(ES0_ACT_WIDTH), + BITS_TO_DWORD(ES0_CNT_WIDTH)); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_MV_CFG(tgt)), + VSC9953_VCAP_CFG_MV_CFG_SIZE(ES0_ACT_COUNT)); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, + TCAM_SEL_ACTION | TCAM_SEL_COUNTER, ENTRY_WORDS_ES0); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ACTION | TCAM_SEL_COUNTER\n", + __LINE__); + + tgt = VSC9953_IS1; + + /* write entries */ + vcap_entry2cache_init(tgt, ENTRY_WORDS_IS1); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, TCAM_SEL_ENTRY, + ENTRY_WORDS_IS1); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ENTRY\n", + __LINE__); + + /* write actions and counters */ + vcap_action2cache_init(tgt, BITS_TO_DWORD(IS1_ACT_WIDTH), + BITS_TO_DWORD(IS1_CNT_WIDTH)); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_MV_CFG(tgt)), + VSC9953_VCAP_CFG_MV_CFG_SIZE(IS1_ACT_COUNT)); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, + TCAM_SEL_ACTION | TCAM_SEL_COUNTER, ENTRY_WORDS_IS1); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ACTION | TCAM_SEL_COUNTER\n", + __LINE__); + + tgt = VSC9953_IS2; + + /* write entries */ + vcap_entry2cache_init(tgt, ENTRY_WORDS_IS2); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, TCAM_SEL_ENTRY, + ENTRY_WORDS_IS2); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid selection: TCAM_SEL_ENTRY\n", + __LINE__); + + /* write actions and counters */ + vcap_action2cache_init(tgt, BITS_TO_DWORD(IS2_ACT_WIDTH), + BITS_TO_DWORD(IS2_CNT_WIDTH)); + out_le32((unsigned int *)(VSC9953_OFFSET + + VSC9953_VCAP_CFG_MV_CFG(tgt)), + VSC9953_VCAP_CFG_MV_CFG_SIZE(IS2_ACT_COUNT)); + cmd_ret = vcap_cmd(tgt, 0, TCAM_CMD_INITIALIZE, + TCAM_SEL_ACTION | TCAM_SEL_COUNTER, ENTRY_WORDS_IS2); + if (cmd_ret != CMD_RET_SUCCESS) + debug("VSC9953:%d invalid TCAM_SEL_ACTION | TCAM_SEL_COUNTER\n", + __LINE__); +} + void vsc9953_init(bd_t *bis) { u32 i; @@ -2605,6 +2738,7 @@ void vsc9953_init(bd_t *bis) } }
#ifdef CONFIG_CMD_ETHSW diff --git a/include/vsc9953.h b/include/vsc9953.h index a2d4554..78bb977 100644 --- a/include/vsc9953.h +++ b/include/vsc9953.h @@ -187,6 +187,78 @@
+#define VSC9953_IO_OFFSET(offset) (0x00000000 + offset) +#define VSC9953_BITMASK(offset) ((BIT(offset)) - 1) +#define VSC9953_ENC_BITFIELD(target, offset, width) \ + (((target) & VSC9953_BITMASK(width)) << (offset)) + +#define VSC9953_IO_ADDR(target, offset) ((((target) - 0x00000000)) + \ + (offset << 2)) + +#define VSC9953_IO_REG(target, offset) (VSC9953_IO_ADDR(target, offset)) +#define VSC9953_VCAP_CACHE_ENTRY_DAT(target, ri) \ + VSC9953_IO_REG(target, (0x2 + (ri))) + +#define VSC9953_VCAP_CACHE_MASK_DAT(target, ri) \ + VSC9953_IO_REG(target, (0x42 + (ri))) + +#define VSC9953_VCAP_CACHE_TG_DAT(target) VSC9953_IO_REG(target, 0xe2) +#define VSC9953_VCAP_CFG_MV_CFG(target) VSC9953_IO_REG(target, 0x1) +#define VSC9953_VCAP_CFG_MV_CFG_SIZE(target) \ + VSC9953_ENC_BITFIELD(target, 0, 16) + +#define VSC9953_VCAP_CFG_UPDATE_CTRL(target) VSC9953_IO_REG(target, 0x0) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_CMD(target) \ + VSC9953_ENC_BITFIELD(target, 22, 3) + +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_ADDR(target) \ + VSC9953_ENC_BITFIELD(target, 3, 16) + +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_SHOT BIT(2) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_ENTRY_DIS BIT(21) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_ACTION_DIS BIT(20) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_CNT_DIS BIT(19) +#define VSC9953_VCAP_CACHE_ACTION_DAT(target, ri) \ + VSC9953_IO_REG(target, (0x82 + (ri))) + +#define VSC9953_VCAP_CACHE_CNT_DAT(target, ri) \ + VSC9953_IO_REG(target, (0xc2 + (ri))) + +#define VSC9953_PORT_OFFSET 1 +#define VSC9953_IS1_CNT 256 +#define VSC9953_IS2_CNT 1024 +#define VSC9953_ES0_CNT 1024 + +#define BITS_TO_DWORD(x) (1 + (((x) - 1) / 32)) +#define ENTRY_WORDS_ES0 BITS_TO_DWORD(29) +#define ENTRY_WORDS_IS1 BITS_TO_DWORD(376) +#define ENTRY_WORDS_IS2 BITS_TO_DWORD(376) +#define ES0_ACT_WIDTH BITS_TO_DWORD(91) +#define ES0_CNT_WIDTH BITS_TO_DWORD(1) +#define IS1_ACT_WIDTH BITS_TO_DWORD(320) +#define IS1_CNT_WIDTH BITS_TO_DWORD(4) +#define IS2_ACT_WIDTH BITS_TO_DWORD(103 - 2 * VSC9953_PORT_OFFSET) +#define IS2_CNT_WIDTH BITS_TO_DWORD(4 * 32) +#define ES0_ACT_COUNT (VSC9953_ES0_CNT + VSC9953_MAX_PORTS) +#define IS1_ACT_COUNT (VSC9953_IS1_CNT + 1) +#define IS2_ACT_COUNT (VSC9953_IS2_CNT + VSC9953_MAX_PORTS + 2) + +/* TCAM entries */ +enum tcam_sel { + TCAM_SEL_ENTRY = BIT(0), + TCAM_SEL_ACTION = BIT(1), + TCAM_SEL_COUNTER = BIT(2), + TCAM_SEL_ALL = VSC9953_BITMASK(3), +}; + +enum tcam_cmd { + TCAM_CMD_WRITE = 0, + TCAM_CMD_READ = 1, + TCAM_CMD_MOVE_UP = 2, + TCAM_CMD_MOVE_DOWN = 3, + TCAM_CMD_INITIALIZE = 4, +}; + struct vsc9953_mdio_info { struct vsc9953_mii_mng *regs; char *name;
Changes for v3: - removed unused macro VSC9953_IO_OFFSET - removed redundant offset from macro VSC9953_IO_ADDR - added descriptive param for BITS_TO_DWORD
drivers/net/vsc9953.c | 134 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/vsc9953.h | 70 ++++++++++++++++++++++++++ 2 files changed, 204 insertions(+)
#ifdef CONFIG_CMD_ETHSW diff --git a/include/vsc9953.h b/include/vsc9953.h index a2d4554..fc3497e 100644 --- a/include/vsc9953.h +++ b/include/vsc9953.h @@ -187,6 +187,76 @@
+#define VSC9953_BITMASK(offset) ((BIT(offset)) - 1) +#define VSC9953_ENC_BITFIELD(target, offset, width) \ + (((target) & VSC9953_BITMASK(width)) << (offset)) + +#define VSC9953_IO_ADDR(target, offset) ((target) + (offset << 2)) + +#define VSC9953_IO_REG(target, offset) (VSC9953_IO_ADDR(target, offset)) +#define VSC9953_VCAP_CACHE_ENTRY_DAT(target, ri) \ + VSC9953_IO_REG(target, (0x2 + (ri))) + +#define VSC9953_VCAP_CACHE_MASK_DAT(target, ri) \ + VSC9953_IO_REG(target, (0x42 + (ri))) + +#define VSC9953_VCAP_CACHE_TG_DAT(target) VSC9953_IO_REG(target, 0xe2) +#define VSC9953_VCAP_CFG_MV_CFG(target) VSC9953_IO_REG(target, 0x1) +#define VSC9953_VCAP_CFG_MV_CFG_SIZE(target) \ + VSC9953_ENC_BITFIELD(target, 0, 16) + +#define VSC9953_VCAP_CFG_UPDATE_CTRL(target) VSC9953_IO_REG(target, 0x0) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_CMD(target) \ + VSC9953_ENC_BITFIELD(target, 22, 3) + +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_ADDR(target) \ + VSC9953_ENC_BITFIELD(target, 3, 16) + +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_SHOT BIT(2) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_ENTRY_DIS BIT(21) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_ACTION_DIS BIT(20) +#define VSC9953_VCAP_UPDATE_CTRL_UPDATE_CNT_DIS BIT(19) +#define VSC9953_VCAP_CACHE_ACTION_DAT(target, ri) \ + VSC9953_IO_REG(target, (0x82 + (ri))) + +#define VSC9953_VCAP_CACHE_CNT_DAT(target, ri) \ + VSC9953_IO_REG(target, (0xc2 + (ri))) + +#define VSC9953_PORT_OFFSET 1 +#define VSC9953_IS1_CNT 256 +#define VSC9953_IS2_CNT 1024 +#define VSC9953_ES0_CNT 1024 + +#define BITS_TO_DWORD(in) (1 + (((in) - 1) / 32)) +#define ENTRY_WORDS_ES0 BITS_TO_DWORD(29) +#define ENTRY_WORDS_IS1 BITS_TO_DWORD(376) +#define ENTRY_WORDS_IS2 BITS_TO_DWORD(376) +#define ES0_ACT_WIDTH BITS_TO_DWORD(91) +#define ES0_CNT_WIDTH BITS_TO_DWORD(1) +#define IS1_ACT_WIDTH BITS_TO_DWORD(320) +#define IS1_CNT_WIDTH BITS_TO_DWORD(4) +#define IS2_ACT_WIDTH BITS_TO_DWORD(103 - 2 * VSC9953_PORT_OFFSET) +#define IS2_CNT_WIDTH BITS_TO_DWORD(4 * 32) +#define ES0_ACT_COUNT (VSC9953_ES0_CNT + VSC9953_MAX_PORTS) +#define IS1_ACT_COUNT (VSC9953_IS1_CNT + 1) +#define IS2_ACT_COUNT (VSC9953_IS2_CNT + VSC9953_MAX_PORTS + 2) + +/* TCAM entries */ +enum tcam_sel { + TCAM_SEL_ENTRY = BIT(0), + TCAM_SEL_ACTION = BIT(1), + TCAM_SEL_COUNTER = BIT(2), + TCAM_SEL_ALL = VSC9953_BITMASK(3), +}; + +enum tcam_cmd { + TCAM_CMD_WRITE = 0, + TCAM_CMD_READ = 1, + TCAM_CMD_MOVE_UP = 2, + TCAM_CMD_MOVE_DOWN = 3, + TCAM_CMD_INITIALIZE = 4, +}; + struct vsc9953_mdio_info { struct vsc9953_mii_mng *regs; char *name;
Hi Joe,
As a reminder, is there anything else that should be done to push the patch forward?
Thanks, Radu
Hi Radu,
https://patchwork.ozlabs.org/patch/917806/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Joe Hershberger
