[U-Boot] [PATCH 1/2] arm64: versal: Enable memory mapping via DT
Code reads DT and setup MMU table based on memory node. This will ensure that only DT needs to be changed.
arch/arm/mach-versal/cpu.c | 36 +++++++++++++------ arch/arm/mach-versal/include/mach/sys_proto.h | 1 + board/xilinx/versal/board.c | 9 ++++- 3 files changed, 35 insertions(+), 11 deletions(-)
diff --git a/arch/arm/mach-versal/cpu.c b/arch/arm/mach-versal/cpu.c index 70c1908ec4b2..dc6a9205be0e 100644 --- a/arch/arm/mach-versal/cpu.c +++ b/arch/arm/mach-versal/cpu.c @@ -12,14 +12,15 @@
DECLARE_GLOBAL_DATA_PTR;
-static struct mm_region versal_mem_map[] = { +#define VERSAL_MEM_MAP_USED 6 + +#define DRAM_BANKS CONFIG_NR_DRAM_BANKS + +/* +1 is end of list which needs to be empty */ +#define VERSAL_MEM_MAP_MAX (VERSAL_MEM_MAP_USED + DRAM_BANKS + 1) + +static struct mm_region versal_mem_map[VERSAL_MEM_MAP_MAX] = { { - .virt = 0x0UL, - .phys = 0x0UL, - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { .virt = 0x80000000UL, .phys = 0x80000000UL, .size = 0x70000000UL, @@ -59,12 +60,27 @@ static struct mm_region versal_mem_map[] = { .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, } };
+void mem_map_fill(void) +{ + int banks = VERSAL_MEM_MAP_USED; + + for (int i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + /* Zero size means no more DDR that's this is end */ + if (!gd->bd->bi_dram[i].size) + break; + + versal_mem_map[banks].virt = gd->bd->bi_dram[i].start; + versal_mem_map[banks].phys = gd->bd->bi_dram[i].start; + versal_mem_map[banks].size = gd->bd->bi_dram[i].size; + versal_mem_map[banks].attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE; + banks = banks + 1; + } +} + struct mm_region *mem_map = versal_mem_map;
u64 get_page_table_size(void) diff --git a/arch/arm/mach-versal/include/mach/sys_proto.h b/arch/arm/mach-versal/include/mach/sys_proto.h index 1dc7bf665690..05934c28d67f 100644 --- a/arch/arm/mach-versal/include/mach/sys_proto.h +++ b/arch/arm/mach-versal/include/mach/sys_proto.h @@ -9,3 +9,4 @@ enum { };
void tcm_init(u8 mode); +void mem_map_fill(void); diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index 2b4edd8738b4..5718e1aa7e47 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <asm/io.h> #include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> #include <dm/device.h> #include <dm/uclass.h> #include <versalpl.h> @@ -194,7 +195,13 @@ int board_late_init(void)
int dram_init_banksize(void) { - fdtdec_setup_memory_banksize(); + int ret; + + ret = fdtdec_setup_memory_banksize(); + if (ret) + return ret; + + mem_map_fill();
return 0; }
This patch provides an option to enable/disable OCM and TCM memory into MMU table with corresponding memory attributes.
The same change was done for ZynqMP by commit 189bec47ab1f ("arm64: zynqmp: Provide a Kconfig option to define OCM and TCM in MMU")
arch/arm/mach-versal/Kconfig | 7 +++++++ arch/arm/mach-versal/cpu.c | 25 +++++++++++++++++-------- 2 files changed, 24 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-versal/Kconfig b/arch/arm/mach-versal/Kconfig index 26d175637101..06a035292464 100644 --- a/arch/arm/mach-versal/Kconfig +++ b/arch/arm/mach-versal/Kconfig @@ -54,4 +54,11 @@ config SYS_MEM_RSVD_FOR_MMU MMU table than the one which will be allocated during relocation.
+config DEFINE_TCM_OCM_MMAP + bool "Define TCM and OCM memory in MMU Table" + default y if MP + help + This option if enabled defines the TCM and OCM memory and its + memory attributes in MMU table entry. + endif diff --git a/arch/arm/mach-versal/cpu.c b/arch/arm/mach-versal/cpu.c index dc6a9205be0e..f0d047d3232f 100644 --- a/arch/arm/mach-versal/cpu.c +++ b/arch/arm/mach-versal/cpu.c @@ -12,12 +12,18 @@
-#define VERSAL_MEM_MAP_USED 6 +#define VERSAL_MEM_MAP_USED 5
+#if defined(CONFIG_DEFINE_TCM_OCM_MMAP) +#define TCM_MAP 1 +#else +#define TCM_MAP 0 +#endif + /* +1 is end of list which needs to be empty */ -#define VERSAL_MEM_MAP_MAX (VERSAL_MEM_MAP_USED + DRAM_BANKS + 1) +#define VERSAL_MEM_MAP_MAX (VERSAL_MEM_MAP_USED + DRAM_BANKS + TCM_MAP + 1)
static struct mm_region versal_mem_map[VERSAL_MEM_MAP_MAX] = { { @@ -34,12 +40,6 @@ static struct mm_region versal_mem_map[VERSAL_MEM_MAP_MAX] = { .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0xffe00000UL, - .phys = 0xffe00000UL, - .size = 0x00200000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE }, { .virt = 0x400000000UL, .phys = 0x400000000UL, @@ -67,6 +67,15 @@ void mem_map_fill(void) { int banks = VERSAL_MEM_MAP_USED;
+#if defined(CONFIG_DEFINE_TCM_OCM_MMAP) + versal_mem_map[banks].virt = 0xffe00000UL; + versal_mem_map[banks].phys = 0xffe00000UL; + versal_mem_map[banks].size = 0x00200000UL; + versal_mem_map[banks].attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE; + banks = banks + 1; +#endif + for (int i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { /* Zero size means no more DDR that's this is end */ if (!gd->bd->bi_dram[i].size)
st 11. 9. 2019 v 9:43 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
default y if MP
help
banks = banks + 1;
-- 2.17.1
Applied both. M
Michal Simek
Michal Simek
