[U-Boot] is the sandbox FIT image demo broken?
i'm following along the instructions to use the sandbox to demo a FIT image:
$ make O=sandbox sandbox_config $ make O=sandbox $ ./test/image/test-fit.py -u sandbox/u-boot
but running that last command produces only:
FIT Tests ========= Warning (unit_address_vs_reg): Node /reset@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/kernel@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/kernel@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/fdt@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/fdt@1/signature@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/ramdisk@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/ramdisk@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /configurations/conf@1 has a unit name, but no reg property Kernel load Traceback (most recent call last): File "./test/image/test-fit.py", line 481, in <module> run_tests() File "./test/image/test-fit.py", line 470, in run_tests run_fit_test(mkimage, options.u_boot) File "./test/image/test-fit.py", line 385, in run_fit_test stdout = command.Output(u_boot, '-d', control_dtb, '-c', cmd) File "./test/image/../../tools/patman/command.py", line 109, in Output return RunPipe([cmd], capture=True, raise_on_error=raise_on_error).stdout File "./test/image/../../tools/patman/command.py", line 91, in RunPipe raise Exception("Error running '%s': %s" % (user_pipestr, str)) Exception: Error running 'sandbox/u_boot -d /tmp/tmp7Cs2dr/u-boot.dtb -c sb load hostfs 0 1000 /tmp/tmp7Cs2dr/test.fit fdt addr 1000 bootm start 1000 bootm loados sb save hostfs 0 40000 /tmp/tmp7Cs2dr/kernel-out.bin da3 sb save hostfs 0 80000 /tmp/tmp7Cs2dr/fdt-out.dtb c1 sb save hostfs 0 c0000 /tmp/tmp7Cs2dr/ramdisk-out.bin 11ef sb save hostfs 0 100000 /tmp/tmp7Cs2dr/loadables1-out.bin da3 sb save hostfs 0 140000 /tmp/tmp7Cs2dr/loadables2-out.bin 11ef reset ': <type 'str'> $
i could have sworn that, once upon a time, there was more output than this. am i misremembering? is this what i should expect?
rday
Robert P. J. Day
