[U-Boot] [PATCH] mx6sxsabresd: Fix Ethernet PHY reset sequence
Since commit 59370f3fcd1350 ("net: phy: delay only if reset handler is registered") Ethernet is no longer functional.
This commit does not have an issue in itself, but it revelead a problem with the Ethernet initialization.
Fix this by calling enable_fec_anatop_clock() earlier and also by adding a 10ms reset delay as recommended in the AR8031 datasheet.
Suggested-by: Jörg Krause joerg.krause@embedded.rock Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 3ee4662..56dc020 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -150,11 +150,15 @@ static int setup_fec(void) { struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; - int reg; + int reg, ret;
/* Use 125MHz anatop loopback REF_CLK1 for ENET1 */ clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK, 0);
+ ret = enable_fec_anatop_clock(0, ENET_125MHZ); + if (ret) + return ret; + imx_iomux_v3_setup_multiple_pads(phy_control_pads, ARRAY_SIZE(phy_control_pads));
@@ -163,14 +167,14 @@ static int setup_fec(void)
/* Reset AR8031 PHY */ gpio_direction_output(IMX_GPIO_NR(2, 7) , 0); - udelay(500); + mdelay(10); gpio_set_value(IMX_GPIO_NR(2, 7), 1);
reg = readl(&anatop->pll_enet); reg |= BM_ANADIG_PLL_ENET_REF_25M_ENABLE; writel(reg, &anatop->pll_enet);
- return enable_fec_anatop_clock(0, ENET_125MHZ); + return 0; }
int board_eth_init(bd_t *bis)
Fabio Estevam
