[U-Boot] [PATCH v2] tools: env: support skip leading zero of env
Signed-off-by: zqb-all zhuangqiubin@gmail.com --- v2: fix all "env = environment.data" and "env = default_environment"
tools/env/fw_env.c | 46 ++++++++++++++++++++++++++++++++++++++++------ 1 file changed, 40 insertions(+), 6 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index a5d7595..60742b6 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -398,7 +398,14 @@ char *fw_getenv(char *name) { char *env, *nxt;
- for (env = environment.data; *env; env = nxt + 1) { + for (nxt = environment.data; !(*nxt); ++nxt) { + if (nxt >= &environment.data[ENV_SIZE]) { + fprintf (stderr, "## Error: " + "environment is empty\n"); + return NULL; + } + } + for (env = nxt; *env; env = nxt + 1) { char *val;
for (nxt = env; *nxt; ++nxt) { @@ -423,8 +430,14 @@ char *fw_getenv(char *name) char *fw_getdefenv(char *name) { char *env, *nxt; - - for (env = default_environment; *env; env = nxt + 1) { + for (nxt = default_environment; !(*nxt); ++nxt) { + if (nxt >= &default_environment[ENV_SIZE]) { + fprintf (stderr, "## Error: " + "default environment is empty\n"); + return NULL; + } + } + for (env = nxt; *env; env = nxt + 1) { char *val;
for (nxt = env; *nxt; ++nxt) { @@ -464,7 +477,14 @@ int fw_printenv(int argc, char *argv[], int value_only, struct env_opts *opts)
if (argc == 0) { /* Print all env variables */ char *env, *nxt; - for (env = environment.data; *env; env = nxt + 1) { + for (nxt = environment.data; !(*nxt); ++nxt) { + if (nxt >= &environment.data[ENV_SIZE]) { + fprintf (stderr, "## Error: " + "environment is empty\n"); + return -1; + } + } + for (env = nxt; *env; env = nxt + 1) { for (nxt = env; *nxt; ++nxt) { if (nxt >= &environment.data[ENV_SIZE]) { fprintf(stderr, "## Error: " @@ -537,7 +557,14 @@ int fw_env_write(char *name, char *value) /* * search if variable with this name already exists */ - for (nxt = env = environment.data; *env; env = nxt + 1) { + for (nxt = environment.data; !(*nxt); ++nxt) { + if (nxt >= &environment.data[ENV_SIZE]) { + fprintf (stderr, "## Error: " + "environment is empty\n"); + return -1; + } + } + for (env = nxt; *env; env = nxt + 1) { for (nxt = env; *nxt; ++nxt) { if (nxt >= &environment.data[ENV_SIZE]) { fprintf(stderr, "## Error: " @@ -614,7 +641,14 @@ int fw_env_write(char *name, char *value) /* * Append new definition at the end */ - for (env = environment.data; *env || *(env + 1); ++env) + for (nxt = environment.data; !(*nxt); ++nxt) { + if (nxt >= &environment.data[ENV_SIZE]) { + fprintf (stderr, "## Error: " + "environment is empty\n"); + return -1; + } + } + for (env = nxt; *env || *(env + 1); ++env) ; if (env > environment.data) ++env;
Maybe I miss something, but why is this needed exactly?
Stefan
return NULL;
return NULL;
return -1;
- for (nxt = environment.data; !(*nxt); ++nxt) {
return -1;
- for (env = nxt; *env; env = nxt + 1) { for (nxt = env; *nxt; ++nxt) { if (nxt >= &environment.data[ENV_SIZE]) { fprintf(stderr, "## Error: "
return -1;
- for (env = nxt; *env || *(env + 1); ++env) ; if (env > environment.data) ++env;
Dear zqb-all,
In message 1543283392-31275-1-git-send-email-zhuangqiubin@gmail.com you wrote:
Umm... please add a commit message that explains which problem you are trying to fix, and why you think your new code helps to address this problem.
Thanks.
Hi Wolfgang , Stefan
I try to use uboot envtools in allwinner's platform, then found that the env in allwinner's SDK have some leading zero, that prevent envtools to parse it. Finally I add these code to fix it.
Wolfgang Denk wd@denx.de 于2018年11月27日周二 下午11:00写道:
Dear zqb-all,
Thanks.
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de One possible reason that things aren't going according to plan is that there never was a plan in the first place.
Stefan Agner
zqb-all
