[U-Boot] [PATCH 6/6] NAND: Don't walk past end of oobfree[]
When computing oobavail from the list of free areas in the OOB, don't assume there will always be an unused slot at the end. This syncs up with the kernel NAND driver.
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- This particular issue was found while testing the DaVinci DM3xx with new 4 KB page sized NAND devices. drivers/mtd/nand/nand_base.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 52b0c1a..cf032a6 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2871,7 +2871,8 @@ int nand_scan_tail(struct mtd_info *mtd) * the out of band area */ chip->ecc.layout->oobavail = 0; - for (i = 0; chip->ecc.layout->oobfree[i].length; i++) + for (i = 0; chip->ecc.layout->oobfree[i].length + && i < ARRAY_SIZE(chip->ecc.layout->oobfree); i++) chip->ecc.layout->oobavail += chip->ecc.layout->oobfree[i].length; mtd->oobavail = chip->ecc.layout->oobavail;
s-paulraj@ti.com
