[U-Boot] Question about board-specific Makefile actions
I have a custom board in a git workspace for U-Boot 2014.07. I've copied most of this from the .../board/ti/beagle. My board directory Makefile looks like
8<--- obj-y := board.o 8<---
I'd like to add a few files to this directory that are processed during "make all" and have any newly derived files deleted during "make clean".
I've experimented with various Makefile contents but I can't get the new files processed or any newly derived files deleted. U-Boot's makefile system is quite large for my experience level and it seems I don't have enough understanding.
A new file might contain some hush commands that are to be executed from the U-Boot command line. I'd like to use "source" to process these commands. The "source" command requires that its argument be an image (I get this into memory via TFTP), so I'd like "make all" to transform the text file containing the hush commands into the image file. I'd also like "make clean" to delete the derived image file.
So, if my hush commands are in a text file called test.txt, I'd like "make all" to apply mkimage so that a test.img is generated. I'd also like "make clean" to delete test.img.
I tried various changes to my Makefile, but the most likely seeming changes are
8<--- IMG = test.img
obj-y := board.o
board.o : $(IMG)
%.img : %.txt $(srctree)/tools/mkimage -T script -n $* -C none -d $< $@
CLEAN_FILES += $(IMG) CLEAN_DIRS += . 8<---
This doesn't work, nor has any other approach I've taken. mkimage is never run for "make all" and test.img doesn't get deleted if I create a fake one and run "make clean"
Could someone offer a solution, either directly, or by pointing at an existing board that does something similar?
Thanks Jim
So, is no one willing to offer a hint?
Thanks, Jim
obj-y := board.o
board.o : $(IMG)
Thanks Jim
I could still use some help with this from someone who really knows how the make system works.
Tom and Simon provided hints that were helpful, as I note below.
Thanks, Jim
obj-y := board.o
board.o : $(IMG)
On 03/09/2015 08:54 AM, Tom Rini wrote:
Off the top of my head, try throwing test.img into obj-y ?
Adding text.img to obj-y did cause the .img file to get generated, but it also added text.img to the list of files supplied to ld, causing the final u-boot link to fail
On 03/09/2015 11:49 AM, Simon Glass wrote:
Also you may want to add a command like cmd_img_txt (see Makefile.lib for examples). Did you need to add anything to ALL-y?
Your mention of Makefile.lib prompted my to look there for other targets I might use. I discovered extra-y and adding
extra-y := test.img
to my board's Makefile caused the correct operations.
As you suggest, I added cmd_my_mkimage, which while not actually needed, is a very nice way to have a non-verbose progress report in the make output.
Another option is to put this outside the U-Boot build system, and just run mkimage later.
I really want these steps to be part of the normal board make. Requiring a separate manual build step will inevitably result in that separate step being forgotten (most probably by me).
Is there any documentation you could point me at that might explain the way these Makefiles interact? I know most of this was derived from somewhere else (Linux kernel?) as part of the move to KConfig. But I have no experience with the kernel build system and following make's debug output is difficult, at best. Some overview of how makes are done would be quite helpful to me and maybe to other non-U-Boot-developers.
Remaining problems:
1) I can't figure out how to clean my newly created derived .img file. I've tried each of the following four lines (one at a time), but none worked CLEAN_FILES += board/aja/helo/helo_setupdeveloper.img CLEAN_FILES += test.img CLEAN_FILES := test.img clean-files += test.img clean-files := test.img
2) More generally, I'd like to be able to add some arbitrary make steps that are peculiar to my boards Makefile, but I can't figure this out either, so far.
I've tried adding my_all to extra-y and then adding steps for my_all, similar to the following.
8<--- extra-y := test.img my_all
.PHONY my_all my_all : test1.txt # some arbitrary commands to be executed if test1.txt isn't present cp -f test.txt test1.txt 8<---
In this case, make reports an error
make[1]: *** No rule to make target `board/my_board/my_all', needed by `__build'. Stop. make: *** [board/my_board] Error 2
Any help would be appreciated.
Thanks, Jim
+Masahiro
Hi James,
Thanks, Jim
obj-y := board.o
board.o : $(IMG)
extra-y := test.img
Yes it is called Kbuild. You could try this:
https://www.kernel.org/doc/Documentation/kbuild/makefiles.txt
Remaining problems:
- I can't figure out how to clean my newly created derived .img file. I've
You could try adding
$(warning CLEAN_FILES is $(CLEAN_FILES))
in a few places in the Makefile.
- More generally, I'd like to be able to add some arbitrary make steps that
Maybe:
targets += test1.txt
Masahiro may know about this one.
Hi Simon,
2015-03-13 3:55 GMT+09:00 Simon Glass sjg@chromium.org:
Maybe:
"targets" is necessary for including ".*.cmd" files, so it has nothing to do with the error here.
Moreover, as $(extra-y) is automatically added to "targets", you need not touch "targets" in most cases.
Hi James,
2015-03-13 3:35 GMT+09:00 James Chargin jimccrown@gmail.com:
Thanks, Jim
obj-y := board.o board.o : $(IMG)
I assume you put these lines into your own board/my_board/Makefile.
You cannot use CLEAN_FILES, CLEAN_DIRS in sub-directory Makefiles. They are only available at the top-level Makefile.
Instead, "clean-files" is available in sub Makefiles. but, it is redundant if you are willing to add it to extra-y because files in $(extra-y) are automatically cleaned up.
Right. As you have already noticed, you should use extra-y for your purpose.
extra-y := test.img
Yes, this is correct.
As Simon suggested, Documentation/kbuild/makefiles.txt of Linux Kernel is the best one.
To be precise, you should say Kbuild, not Kconfig. Kbuild and Kconfig should be considered separately.
Kbuild - build system Kconfig - configuration system
They both originate in Linux Kernel.
U-Boot switched to Kbuild at 2014.04-rc1, and to Kconfig at 2014.10-rc1.
You mentioned you are using u-boot v2014.07. So, you are building U-Boot with Kbuild, but using the old, conventional configuration system (mkconfig + boards.cfg).
Your questions in this thread are all about Kbuild.
Remaining problems:
CLEAN_FILES is only available at the top-level Makefile.
Add CLEAN_FILES += board/my_board/test.img to the top-level Makefile, and it should work.
These are correct in sub-directory Makefiles in general, but unfortunately, "make clean" does not descend into board/ directory for some reason.
So, they do not work in board/*/Makefile
If you want to generate board/my_board/test1.txt from board/my_board/test.txt, the board/my_board/Makefile should look like this:
8<----
extra-y := test1.txt
$(obj)/test1.txt: $(src)/test.txt cp -f $< $@ 8<----
If you like the log to look more nicely, you can write like below:
8<---- extra-y := test1.txt
quiet_cmd_copy = COPY $@ cmd_copy = cp -f $< $@
$(obj)/test1.txt: $(src)/test.txt $(call cmd,copy) 8<-----
Add the following to the top-level Makefile 8<---- CLEAN_FILES += board/my_board/test1.txt 8<----
I do not think you need to use PHONY target, but if you really want use it, you can do like this.
8<----
__build: my_all
PHONY += my_all
my_all: echo "Hello, World" 8<----
Dear Masahiro,
Your help has enabled me to make my board Makefile do what I want (except for the clean target, see below).
On 03/12/2015 09:20 PM, Masahiro Yamada wrote:
Hi James,
Thanks, Jim
This document has been very helpful. Thank you both for pointing it out.
I know most of this was derived from somewhere else (Linux kernel?) as part of the move to KConfig. But I have no ...
I appreciate your clear explanation here.
I have watched the Kbuild and KConfig conversion threads in the mailing list for some time. But having been previously working with U-Boot 2010.12, this is my first experience with either. It will be useful to know they are separate in this way.
Remaining problems:
tried each of the following four lines (one at a time), but none worked CLEAN_FILES += test.img CLEAN_FILES := test.img
Should this be considered a bug in the build system? Should make descend into the board directory? Or, at least, should there not be a way for a board directory to indicate which of any locally generated derived objects should be cleaned up?
I hesitate to add to the top level Makefile for my specific board.
8<----
This is actually the fix for many of my problems. Prepending $(obj) and $(src) apparently allows make to see the file dependencies as I intend.
... Add the following to the top-level Makefile 8<---- CLEAN_FILES += board/my_board/test1.txt 8<----
Again, I hesitate to add to the top level Makefile.
8<----
__build: my_all
PHONY += my_all
As you suggest, I did not use .PHONY.
This explanation might be a nice addition to the Kbuild makefile.txt.
Again, thank you very much for your attention.
Jim
Hi James,
2015-03-14 3:08 GMT+09:00 James Chargin jimccrown@gmail.com:
Kind of.
I hope it will be solved in a long run.
In U-Boot, ARCH, VENDOR, BOARD directories are still treated specially for some historical reason.
Board directory is selected like follows: libs-y += $(if $(BOARDDIR),board/$(BOARDDIR)/)
and it has made it difficult to descend into board/ by "make clean" because "make clean" should not expect the existing .config file.
If we could completely switched to "obj-$(CONFIG_FOO)" style in the future, this problem would go away. We need more effort to achieve this.
Yes.
Or, at least, should there not be a way for a board directory to indicate which of any locally generated derived objects should be cleaned up? I hesitate to add to the top level Makefile for my specific board.
Sorry, I cannot suggest a good solution now.
obj-y := board.o
board.o : $(IMG)
obj-y := board.o
board.o : $(IMG)
James Chargin
Masahiro Yamada
