[PATCH v7 0/7] fpga: zynqmp: Adding support of loading authenticated images
This patchset introduces support for the authenticated FPGA images on ZynqMP boards, besides that introducing common way to pass the compatible property to any fpga driver.
It bases on the initial work by Jorge Ramirez-Ortiz jorge@foundries.io https://patchwork.ozlabs.org/project/uboot/patch/20211015091506.2602-1-jorge... https://patchwork.ozlabs.org/project/uboot/patch/20211005111324.19749-3-jorg...
Changed in v7: - apply Michal Simek's suggestions As I applied changes on Oleksandr's patches, I indicated it by specifying myself as co-author in the commits logs. I am not sure if that is the convention of marking it.
Changed in v6: - add support for the encrypted bitfiles
Changes in v5: - replace ifdef with if() where it's possible
Changes in v4: - change interface to xilinx_desc->operations->open() callback. - fix a bug from previous version of the patchset in dereferencing of a parent fpga_desc structure.
Changes in v3: - remove the patch which introduced CMD_SPL_FPGA_LOAD_SECURE. - fix mixing definitions/declarations. - replace strcmp() calls with more secure strncmp(). - document the "u-boot,zynqmp-fpga-ddrauth" compatible string. - fix code style by check-patch recommendations.
Changes in v2: - add function fit_fpga_load() to simplify calls of fpga_load() from contexts without a compatible attribute. - move all ZynqMP-specific logic to drivers/fpga/zynqmppl.c - prepare for passing a "compatible" FDT property to any fpga driver.
Oleksandr Suvorov (6): fpga: add option for loading FPGA secure bitstreams fpga: add fit_fpga_load function fpga: xilinx: pass an address of xilinx_desc in fpga_desc fpga: xilinx: add missed identifier names fpga: xilinx: pass xilinx_desc pointer address into load() ops fpga: zynqmp: support loading authenticated images
Adrian Fiergolski (1): fpga: zynqmp: support loading encrypted bitfiles
boot/Kconfig | 4 +-- cmd/Kconfig | 3 ++- common/spl/spl_fit.c | 6 ++--- doc/uImage.FIT/source_file_format.txt | 7 +++++- drivers/fpga/Kconfig | 14 +++++++++++ drivers/fpga/fpga.c | 29 ++++++++++++++++++--- drivers/fpga/spartan2.c | 3 ++- drivers/fpga/spartan3.c | 3 ++- drivers/fpga/versalpl.c | 2 +- drivers/fpga/virtex2.c | 3 ++- drivers/fpga/xilinx.c | 8 +++--- drivers/fpga/zynqmppl.c | 36 ++++++++++++++++++++++++--- drivers/fpga/zynqpl.c | 3 ++- include/fpga.h | 5 ++++ include/xilinx.h | 12 +++++---- 15 files changed, 109 insertions(+), 29 deletions(-)
From: Oleksandr Suvorov oleksandr.suvorov@foundries.io
It allows using this feature without enabling the "fpga loads" command.
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Tested-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com Signed-off-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com --- cmd/Kconfig | 3 ++- drivers/fpga/Kconfig | 14 ++++++++++++++ drivers/fpga/fpga.c | 2 +- drivers/fpga/xilinx.c | 2 +- drivers/fpga/zynqmppl.c | 4 ++-- 5 files changed, 20 insertions(+), 5 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 5e25e45fd2..604ab37f3b 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -949,8 +949,9 @@ config CMD_FPGA_LOADP a partial bitstream.
config CMD_FPGA_LOAD_SECURE - bool "fpga loads - loads secure bitstreams (Xilinx only)" + bool "fpga loads - loads secure bitstreams" depends on CMD_FPGA + select FPGA_LOAD_SECURE help Enables the fpga loads command which is used to load secure (authenticated or encrypted or both) bitstreams on to FPGA. diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index dc0b3dd31b..6f8ef7b8db 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -85,4 +85,18 @@ config FPGA_ZYNQPL Enable FPGA driver for loading bitstream in BIT and BIN format on Xilinx Zynq devices.
+config FPGA_LOAD_SECURE + bool "Enable loading secure bitstreams" + depends on FPGA + help + Enables the fpga loads() functions that are used to load secure + (authenticated or encrypted or both) bitstreams on to FPGA. + +config SPL_FPGA_LOAD_SECURE + bool "Enable loading secure bitstreams for SPL" + depends on SPL_FPGA + help + Enables the fpga loads() functions that are used to load secure + (authenticated or encrypted or both) bitstreams on to FPGA. + endmenu diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c index fe3dfa1233..3b0a44b242 100644 --- a/drivers/fpga/fpga.c +++ b/drivers/fpga/fpga.c @@ -220,7 +220,7 @@ int fpga_fsload(int devnum, const void *buf, size_t size, } #endif
-#if defined(CONFIG_CMD_FPGA_LOAD_SECURE) +#if CONFIG_IS_ENABLED(FPGA_LOAD_SECURE) int fpga_loads(int devnum, const void *buf, size_t size, struct fpga_secure_info *fpga_sec_info) { diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index cbebefb55f..6bc1bc491f 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -172,7 +172,7 @@ int xilinx_loadfs(xilinx_desc *desc, const void *buf, size_t bsize, } #endif
-#if defined(CONFIG_CMD_FPGA_LOAD_SECURE) +#if CONFIG_IS_ENABLED(FPGA_LOAD_SECURE) int xilinx_loads(xilinx_desc *desc, const void *buf, size_t bsize, struct fpga_secure_info *fpga_sec_info) { diff --git a/drivers/fpga/zynqmppl.c b/drivers/fpga/zynqmppl.c index 6b394869db..8ff12bf50a 100644 --- a/drivers/fpga/zynqmppl.c +++ b/drivers/fpga/zynqmppl.c @@ -245,7 +245,7 @@ static int zynqmp_load(xilinx_desc *desc, const void *buf, size_t bsize, return ret; }
-#if defined(CONFIG_CMD_FPGA_LOAD_SECURE) && !defined(CONFIG_SPL_BUILD) +#if CONFIG_IS_ENABLED(FPGA_LOAD_SECURE) static int zynqmp_loads(xilinx_desc *desc, const void *buf, size_t bsize, struct fpga_secure_info *fpga_sec_info) { @@ -306,7 +306,7 @@ static int zynqmp_pcap_info(xilinx_desc *desc)
struct xilinx_fpga_op zynqmp_op = { .load = zynqmp_load, -#if defined(CONFIG_CMD_FPGA_LOAD_SECURE) && !defined(CONFIG_SPL_BUILD) +#if CONFIG_IS_ENABLED(FPGA_LOAD_SECURE) .loads = zynqmp_loads, #endif .info = zynqmp_pcap_info,
Introduce a function which passes an fpga compatible string from FIT images to FPGA drivers. This lets the different implementations decide how to handle it.
Some code of Jorge Ramirez-Ortiz jorge@foundries.io is reused.
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Tested-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com Signed-off-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com --- common/spl/spl_fit.c | 6 ++---- drivers/fpga/fpga.c | 23 ++++++++++++++++++++++- include/fpga.h | 4 ++++ 3 files changed, 28 insertions(+), 5 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 1bbf824684..0e3c2a94b6 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -588,11 +588,9 @@ static int spl_fit_upload_fpga(struct spl_fit_info *ctx, int node, compatible = fdt_getprop(ctx->fit, node, "compatible", NULL); if (!compatible) warn_deprecated("'fpga' image without 'compatible' property"); - else if (strcmp(compatible, "u-boot,fpga-legacy")) - printf("Ignoring compatible = %s property\n", compatible);
- ret = fpga_load(0, (void *)fpga_image->load_addr, fpga_image->size, - BIT_FULL); + ret = fit_fpga_load(0, (void *)fpga_image->load_addr, fpga_image->size, + BIT_FULL, compatible); if (ret) { printf("%s: Cannot load the image to the FPGA\n", __func__); return ret; diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c index 3b0a44b242..a306dd81f9 100644 --- a/drivers/fpga/fpga.c +++ b/drivers/fpga/fpga.c @@ -249,8 +249,23 @@ int fpga_loads(int devnum, const void *buf, size_t size, } #endif
+int fit_fpga_load(int devnum, const void *buf, size_t bsize, + bitstream_type bstype, const char *compatible) +{ + fpga_desc *desc = fpga_get_desc(devnum); + + /* + * Store the compatible string to proceed it in underlying + * functions + */ + desc->compatible = (char *)compatible; + + return fpga_load(devnum, buf, bsize, bstype); +} + /* - * Generic multiplexing code + * Generic multiplexing code: + * Each architecture must handle the mandatory FPGA DT compatible property. */ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) { @@ -270,6 +285,9 @@ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) break; case fpga_altera: #if defined(CONFIG_FPGA_ALTERA) + if (strncmp(desc->compatible, "u-boot,fpga-legacy", 18)) + printf("Ignoring compatible = %s property\n", + desc->compatible); ret_val = altera_load(desc->devdesc, buf, bsize); #else fpga_no_sup((char *)__func__, "Altera devices"); @@ -277,6 +295,9 @@ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) break; case fpga_lattice: #if defined(CONFIG_FPGA_LATTICE) + if (strncmp(desc->compatible, "u-boot,fpga-legacy", 18)) + printf("Ignoring compatible = %s property\n", + desc->compatible); ret_val = lattice_load(desc->devdesc, buf, bsize); #else fpga_no_sup((char *)__func__, "Lattice devices"); diff --git a/include/fpga.h b/include/fpga.h index ec5144334d..2891f32106 100644 --- a/include/fpga.h +++ b/include/fpga.h @@ -35,6 +35,7 @@ typedef enum { /* typedef fpga_type */ typedef struct { /* typedef fpga_desc */ fpga_type devtype; /* switch value to select sub-functions */ void *devdesc; /* real device descriptor */ + char *compatible; /* device compatible string */ } fpga_desc; /* end, typedef fpga_desc */
typedef struct { /* typedef fpga_desc */ @@ -63,6 +64,9 @@ int fpga_add(fpga_type devtype, void *desc); int fpga_count(void); const fpga_desc *const fpga_get_desc(int devnum); int fpga_is_partial_data(int devnum, size_t img_len); +/* the DT compatible property must be handled by the different FPGA archs */ +int fit_fpga_load(int devnum, const void *buf, size_t bsize, + bitstream_type bstype, const char *compatible); int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype); int fpga_fsload(int devnum, const void *buf, size_t size,
BIT_FULL);
- ret = fit_fpga_load(0, (void *)fpga_image->load_addr, fpga_image->size,
if (ret) { printf("%s: Cannot load the image to the FPGA\n", __func__); return ret;BIT_FULL, compatible);
- fpga_desc *desc = fpga_get_desc(devnum);
this generates warning which you should fix.
+ fpga_desc *desc = fpga_get_desc(devnum); + ^~~~~~~~~~~~~ w+../drivers/fpga/fpga.c: In function ‘fit_fpga_load’: w+../drivers/fpga/fpga.c:255:20: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
* functions
- desc->compatible = (char *)compatible;
- return fpga_load(devnum, buf, bsize, bstype);
- Generic multiplexing code
- Generic multiplexing code:
- Each architecture must handle the mandatory FPGA DT compatible property.
#else fpga_no_sup((char *)__func__, "Altera devices");desc->compatible); ret_val = altera_load(desc->devdesc, buf, bsize);
#else fpga_no_sup((char *)__func__, "Lattice devices");desc->compatible); ret_val = lattice_load(desc->devdesc, buf, bsize);
int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype); int fpga_fsload(int devnum, const void *buf, size_t size,bitstream_type bstype, const char *compatible);
M
Hi Oleksandr,
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 1bbf824684..0e3c2a94b6 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -588,11 +588,9 @@ static int spl_fit_upload_fpga(struct spl_fit_info *ctx, int node, compatible = fdt_getprop(ctx->fit, node, "compatible", NULL); if (!compatible) warn_deprecated("'fpga' image without 'compatible' property"); - else if (strcmp(compatible, "u-boot,fpga-legacy")) - printf("Ignoring compatible = %s property\n", compatible); - ret = fpga_load(0, (void *)fpga_image->load_addr, fpga_image->size, - BIT_FULL); + ret = fit_fpga_load(0, (void *)fpga_image->load_addr, fpga_image->size, + BIT_FULL, compatible); if (ret) { printf("%s: Cannot load the image to the FPGA\n", __func__); return ret; diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c index 3b0a44b242..a306dd81f9 100644 --- a/drivers/fpga/fpga.c +++ b/drivers/fpga/fpga.c @@ -249,8 +249,23 @@ int fpga_loads(int devnum, const void *buf, size_t size, } #endif +int fit_fpga_load(int devnum, const void *buf, size_t bsize, + bitstream_type bstype, const char *compatible) +{ + fpga_desc *desc = fpga_get_desc(devnum);
As it's your patch, could you address it?
The 'compatible' field can't be set here, as fpga_get_desc returns 'const fpga_desc * const'. The descriptors table is populated (fpga_add) in board_init. At that stage, I am afraid, we don't have access to the fit image information yet to set a proper 'compatible' (would need to check the code more carefully). Moreover, IMHO it's not the cleanest way to change the 'compatible' field after the driver's initialisation.
property. */ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) { @@ -270,6 +285,9 @@ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) break; case fpga_altera: #if defined(CONFIG_FPGA_ALTERA) + if (strncmp(desc->compatible, "u-boot,fpga-legacy", 18)) + printf("Ignoring compatible = %s property\n", + desc->compatible); ret_val = altera_load(desc->devdesc, buf, bsize); #else fpga_no_sup((char *)__func__, "Altera devices"); @@ -277,6 +295,9 @@ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) break; case fpga_lattice: #if defined(CONFIG_FPGA_LATTICE) + if (strncmp(desc->compatible, "u-boot,fpga-legacy", 18)) + printf("Ignoring compatible = %s property\n", + desc->compatible); ret_val = lattice_load(desc->devdesc, buf, bsize); #else fpga_no_sup((char *)__func__, "Lattice devices"); diff --git a/include/fpga.h b/include/fpga.h index ec5144334d..2891f32106 100644 --- a/include/fpga.h +++ b/include/fpga.h @@ -35,6 +35,7 @@ typedef enum { /* typedef fpga_type */ typedef struct { /* typedef fpga_desc */ fpga_type devtype; /* switch value to select sub-functions */ void *devdesc; /* real device descriptor */ + char *compatible; /* device compatible string */ } fpga_desc; /* end, typedef fpga_desc */ typedef struct { /* typedef fpga_desc */ @@ -63,6 +64,9 @@ int fpga_add(fpga_type devtype, void *desc); int fpga_count(void); const fpga_desc *const fpga_get_desc(int devnum); int fpga_is_partial_data(int devnum, size_t img_len); +/* the DT compatible property must be handled by the different FPGA archs */ +int fit_fpga_load(int devnum, const void *buf, size_t bsize, + bitstream_type bstype, const char *compatible); int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype); int fpga_fsload(int devnum, const void *buf, size_t size,
M
Adrian
Hi Adrian,
On Wed, May 4, 2022 at 5:28 PM Adrian Fiergolski adrian.fiergolski@fastree3d.com wrote:
Hi Oleksandr,
fpga_image->size,
BIT_FULL);
fpga_image->size,
Thanks for catching this. I'm addressing the issue this Friday.
* functions
- char *compatible; /* device compatible string */ } fpga_desc; /* end, typedef fpga_desc */ typedef struct { /* typedef fpga_desc */
M
Adrian
Hi Oleksandr,
On 04.05.2022 20:26, Oleksandr Suvorov wrote:
Hi Adrian,
Hi Oleksandr,
fpga_image->size,
BIT_FULL);
fpga_image->size,
Perfect. I understand you will address all Michal's comments, including those with my SOB missing, and you will release the new version of the patches, right?
Thanks, Adrian
Hi Adrian,
On Mon, May 9, 2022 at 1:30 PM Adrian Fiergolski adrian.fiergolski@fastree3d.com wrote:
Hi Oleksandr,
Hi Adrian,
Hi Oleksandr,
fpga_image->size,
BIT_FULL);
fpga_image->size,
Yes, I've already addressed Michal's comments and going to release the new patchset version in 1-2 hours after finishing tests.
Thanks, Adrian
Hi Adrian,
Hi Oleksandr,
fpga_image->size,
BIT_FULL);
fpga_image->size,
Obviously, the "compatible" attribute belongs to an image, not to an FPGA driver. Unfortunately, I don't see an easy way to stick this attribute to an image in the current architecture. Maybe I missed that way, so I'd appreciate any help with this.
Anyway, we could come back to the FPGA driver subsystem later and rework it better and deeper.
For now, I'd only fix the warning. Are you ok with this?
* functions
M
Adrian
-- Best regards Oleksandr
Oleksandr Suvorov cryosay@gmail.com
Hi Oleksandr,
On 09.05.2022 13:02, Oleksandr Suvorov wrote:
Hi Adrian,
Hi Oleksandr,
fpga_image->size,
BIT_FULL);
fpga_image->size,
I haven't seen straightforward implementation in the current architecture as well. However, it's this series of patches which introduces 'compatible', so IMHO, it should be done properly. Michal, any ideas/opinions?
Adrian
* functions
M
Adrian
Hi Adrian,
On Mon, May 9, 2022 at 2:35 PM Adrian Fiergolski adrian.fiergolski@fastree3d.com wrote:
Hi Oleksandr,
Hi Adrian,
Hi Oleksandr,
fpga_image->size,
BIT_FULL);
fpga_image->size,
I see 2 ways to keep all "compatible"-logic in spl_fit_upload_fpga(): - by extending each vendor-specific *_load() function with another parameter, which will contain a unique type for any supported "compatible" value. - making up a better-fit structure like "fpga_bitstream", more specific for fpga bs only and smaller than spl_image_info, packing there a bs ptr, bs size, bs type, and bs "compatible" members. Both ways require changing the interface for all fpga load()-family functions.
Adrian
* functions
M
Adrian
Michal,
On 09.05.2022 15:28, Oleksandr Suvorov wrote:
Hi Adrian,
Hi Oleksandr,
Hi Adrian,
Hi Oleksandr,
fpga_image->size,
BIT_FULL);
fpga_image->size,
Which option from Oleksandr's proposal do you think will be easier to push upstream?
Regards, Adrian
On 5/9/22 15:34, Adrian Fiergolski wrote:
Michal,
Hi Adrian,
Hi Oleksandr,
Hi Adrian,
Hi Oleksandr,
On 4/11/22 20:00, Adrian Fiergolski wrote: > From: Oleksandr Suvorov oleksandr.suvorov@foundries.io > > Introduce a function which passes an fpga compatible string from > FIT images to FPGA drivers. This lets the different implementations > decide how to handle it. > > Some code of Jorge Ramirez-Ortiz jorge@foundries.io is reused. > > Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io > Tested-by: Ricardo Salveti ricardo@foundries.io > Co-developed-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com > Signed-off-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com > --- > common/spl/spl_fit.c | 6 ++---- > drivers/fpga/fpga.c | 23 ++++++++++++++++++++++- > include/fpga.h | 4 ++++ > 3 files changed, 28 insertions(+), 5 deletions(-) > > diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c > index 1bbf824684..0e3c2a94b6 100644 > --- a/common/spl/spl_fit.c > +++ b/common/spl/spl_fit.c > @@ -588,11 +588,9 @@ static int spl_fit_upload_fpga(struct > spl_fit_info *ctx, int node, > compatible = fdt_getprop(ctx->fit, node, "compatible", NULL); > if (!compatible) > warn_deprecated("'fpga' image without 'compatible' property"); > - else if (strcmp(compatible, "u-boot,fpga-legacy")) > - printf("Ignoring compatible = %s property\n", compatible); > - ret = fpga_load(0, (void *)fpga_image->load_addr, > fpga_image->size, > - BIT_FULL); > + ret = fit_fpga_load(0, (void *)fpga_image->load_addr, > fpga_image->size, > + BIT_FULL, compatible); > if (ret) { > printf("%s: Cannot load the image to the FPGA\n", __func__); > return ret; > diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c > index 3b0a44b242..a306dd81f9 100644 > --- a/drivers/fpga/fpga.c > +++ b/drivers/fpga/fpga.c > @@ -249,8 +249,23 @@ int fpga_loads(int devnum, const void *buf, > size_t size, > } > #endif > +int fit_fpga_load(int devnum, const void *buf, size_t bsize, > + bitstream_type bstype, const char *compatible) > +{ > + fpga_desc *desc = fpga_get_desc(devnum); this generates warning which you should fix.
I think you should convert compatible string from fit image to flags and don't parse any compatible string in the driver but only work with this flag. Maybe make sense also to record in the driver structure all supported flags by driver and let core to check if driver provides that feature or not. With conversion to DM this can allow to enable multiple drivers that one handle only simple unencrypted not authenticated bitstreams and others different types or different transport mechanisms.
Thanks, Michal
./ykman-gui/ykman-gui Hi Michal,
Michal,
Hi Adrian,
Hi Oleksandr,
Hi Adrian,
Hi Oleksandr,
On 03.05.2022 09:42, Michal Simek wrote: > On 4/11/22 20:00, Adrian Fiergolski wrote: >> From: Oleksandr Suvorov oleksandr.suvorov@foundries.io >> >> Introduce a function which passes an fpga compatible string from >> FIT images to FPGA drivers. This lets the different implementations >> decide how to handle it. >> >> Some code of Jorge Ramirez-Ortiz jorge@foundries.io is reused. >> >> Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io >> Tested-by: Ricardo Salveti ricardo@foundries.io >> Co-developed-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com >> Signed-off-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com >> --- >> common/spl/spl_fit.c | 6 ++---- >> drivers/fpga/fpga.c | 23 ++++++++++++++++++++++- >> include/fpga.h | 4 ++++ >> 3 files changed, 28 insertions(+), 5 deletions(-) >> >> diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c >> index 1bbf824684..0e3c2a94b6 100644 >> --- a/common/spl/spl_fit.c >> +++ b/common/spl/spl_fit.c >> @@ -588,11 +588,9 @@ static int spl_fit_upload_fpga(struct >> spl_fit_info *ctx, int node, >> compatible = fdt_getprop(ctx->fit, node, "compatible", NULL); >> if (!compatible) >> warn_deprecate./ykman-gui/ykman-gui
>> - else if (strcmp(compatible, "u-boot,fpga-legacy")) >> - printf("Ignoring compatible = %s property\n", compatible); >> - ret = fpga_load(0, (void *)fpga_image->load_addr, >> fpga_image->size, >> - BIT_FULL); >> + ret = fit_fpga_load(0, (void *)fpga_image->load_addr, >> fpga_image->size, >> + BIT_FULL, compatible); >> if (ret) { >> printf("%s: Cannot load the image to the FPGA\n", __func__); >> return ret; >> diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c >> index 3b0a44b242..a306dd81f9 100644 >> --- a/drivers/fpga/fpga.c >> +++ b/drivers/fpga/fpga.c >> @@ -249,8 +249,23 @@ int fpga_loads(int devnum, const void *buf, >> size_t size, >> } >> #endif >> +int fit_fpga_load(int devnum, const void *buf, size_t bsize, >> + bitstream_type bstype, const char *compatible) >> +{ >> + fpga_desc *desc = fpga_get_desc(devnum); > this generates warning which you should fix. > > + fpga_desc *desc = fpga_get_desc(devnum); > + ^~~~~~~~~~~~~ > w+../drivers/fpga/fpga.c: In function ‘fit_fpga_load’: > w+../drivers/fpga/fpga.c:255:20: warning: initialization discards > ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers] As it's your patch, could you address it?
Thanks, Michal, the plan looks perfect. So I'm reworking the patchset this weekend.
Thanks, Michal
Hi Michal,
Michal,
Hi Adrian,
Hi Oleksandr,
Hi Adrian,
Hi Oleksandr,
On 03.05.2022 09:42, Michal Simek wrote: > On 4/11/22 20:00, Adrian Fiergolski wrote: >> From: Oleksandr Suvorov oleksandr.suvorov@foundries.io >> >> Introduce a function which passes an fpga compatible string from >> FIT images to FPGA drivers. This lets the different implementations >> decide how to handle it. >> >> Some code of Jorge Ramirez-Ortiz jorge@foundries.io is reused. >> >> Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io >> Tested-by: Ricardo Salveti ricardo@foundries.io >> Co-developed-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com >> Signed-off-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com >> --- >> common/spl/spl_fit.c | 6 ++---- >> drivers/fpga/fpga.c | 23 ++++++++++++++++++++++- >> include/fpga.h | 4 ++++ >> 3 files changed, 28 insertions(+), 5 deletions(-) >> >> diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c >> index 1bbf824684..0e3c2a94b6 100644 >> --- a/common/spl/spl_fit.c >> +++ b/common/spl/spl_fit.c >> @@ -588,11 +588,9 @@ static int spl_fit_upload_fpga(struct >> spl_fit_info *ctx, int node, >> compatible = fdt_getprop(ctx->fit, node, "compatible", NULL); >> if (!compatible) >> warn_deprecated("'fpga' image without 'compatible' property"); >> - else if (strcmp(compatible, "u-boot,fpga-legacy")) >> - printf("Ignoring compatible = %s property\n", compatible); >> - ret = fpga_load(0, (void *)fpga_image->load_addr, >> fpga_image->size, >> - BIT_FULL); >> + ret = fit_fpga_load(0, (void *)fpga_image->load_addr, >> fpga_image->size, >> + BIT_FULL, compatible); >> if (ret) { >> printf("%s: Cannot load the image to the FPGA\n", __func__); >> return ret; >> diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c >> index 3b0a44b242..a306dd81f9 100644 >> --- a/drivers/fpga/fpga.c >> +++ b/drivers/fpga/fpga.c >> @@ -249,8 +249,23 @@ int fpga_loads(int devnum, const void *buf, >> size_t size, >> } >> #endif >> +int fit_fpga_load(int devnum, const void *buf, size_t bsize, >> + bitstream_type bstype, const char *compatible) >> +{ >> + fpga_desc *desc = fpga_get_desc(devnum); > this generates warning which you should fix. > > + fpga_desc *desc = fpga_get_desc(devnum); > + ^~~~~~~~~~~~~ > w+../drivers/fpga/fpga.c: In function ‘fit_fpga_load’: > w+../drivers/fpga/fpga.c:255:20: warning: initialization discards > ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers] As it's your patch, could you address it?
I've done this in a legacy drive, please look at the next patchset v8. I started adding DM fpga uclass and DM xilinix driver, but this work may take extra time. So could you review the current solution, please?
Thanks, Michal
Pass an address of xilinx_desc pointer in an fpga_desc to use parent fpga_desc structure members inside a xilinx fpga driver.
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Tested-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com Signed-off-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com --- drivers/fpga/fpga.c | 4 ++-- drivers/fpga/xilinx.c | 4 +++- include/xilinx.h | 2 +- 3 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c index a306dd81f9..5e2288a124 100644 --- a/drivers/fpga/fpga.c +++ b/drivers/fpga/fpga.c @@ -277,8 +277,8 @@ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) switch (desc->devtype) { case fpga_xilinx: #if defined(CONFIG_FPGA_XILINX) - ret_val = xilinx_load(desc->devdesc, buf, bsize, - bstype); + ret_val = xilinx_load((xilinx_desc **)&desc->devdesc, + buf, bsize, bstype); #else fpga_no_sup((char *)__func__, "Xilinx devices"); #endif diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 6bc1bc491f..640baac66e 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -138,9 +138,11 @@ int fpga_loadbitstream(int devnum, char *fpgadata, size_t size, return fpga_load(devnum, dataptr, swapsize, bstype); }
-int xilinx_load(xilinx_desc *desc, const void *buf, size_t bsize, +int xilinx_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, bitstream_type bstype) { + xilinx_desc *desc = *desc_ptr; + if (!xilinx_validate (desc, (char *)__FUNCTION__)) { printf ("%s: Invalid device descriptor\n", __FUNCTION__); return FPGA_FAIL; diff --git a/include/xilinx.h b/include/xilinx.h index ab4537becf..57b0e7be11 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -58,7 +58,7 @@ struct xilinx_fpga_op {
/* Generic Xilinx Functions *********************************************************************/ -int xilinx_load(xilinx_desc *desc, const void *image, size_t size, +int xilinx_load(xilinx_desc **desc_ptr, const void *image, size_t size, bitstream_type bstype); int xilinx_dump(xilinx_desc *desc, const void *buf, size_t bsize); int xilinx_info(xilinx_desc *desc);
Function definition arguments should also have identifier names. Add missed ones to struct xilinx_fpga_op callbacks, unifying code.
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io --- include/xilinx.h | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/include/xilinx.h b/include/xilinx.h index 57b0e7be11..06ecc9a842 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -48,12 +48,14 @@ typedef struct { /* typedef xilinx_desc */ } xilinx_desc; /* end, typedef xilinx_desc */
struct xilinx_fpga_op { - int (*load)(xilinx_desc *, const void *, size_t, bitstream_type); - int (*loadfs)(xilinx_desc *, const void *, size_t, fpga_fs_info *); + int (*load)(xilinx_desc *desc, const void *buf, size_t bsize, + bitstream_type bstype); + int (*loadfs)(xilinx_desc *desc, const void *buf, size_t bsize, + fpga_fs_info *fpga_fsinfo); int (*loads)(xilinx_desc *desc, const void *buf, size_t bsize, struct fpga_secure_info *fpga_sec_info); - int (*dump)(xilinx_desc *, const void *, size_t); - int (*info)(xilinx_desc *); + int (*dump)(xilinx_desc *desc, const void *buf, size_t bsize); + int (*info)(xilinx_desc *desc); };
missing your sob line here.
M
- int (*load)(xilinx_desc *desc, const void *buf, size_t bsize,
- int (*loadfs)(xilinx_desc *desc, const void *buf, size_t bsize,
int (*loads)(xilinx_desc *desc, const void *buf, size_t bsize, struct fpga_secure_info *fpga_sec_info);fpga_fs_info *fpga_fsinfo);
Pass an address of xilinx_desc pointer in an fpga_desc into a load() callback of struct xilinx_fpga_op. It allows getting parent fpga_desc structure members inside xilinx fpga drivers.
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Tested-by: Ricardo Salveti ricardo@foundries.io --- drivers/fpga/spartan2.c | 3 ++- drivers/fpga/spartan3.c | 3 ++- drivers/fpga/versalpl.c | 2 +- drivers/fpga/virtex2.c | 3 ++- drivers/fpga/xilinx.c | 2 +- drivers/fpga/zynqmppl.c | 5 +++-- drivers/fpga/zynqpl.c | 3 ++- include/xilinx.h | 2 +- 8 files changed, 14 insertions(+), 9 deletions(-)
diff --git a/drivers/fpga/spartan2.c b/drivers/fpga/spartan2.c index 3435400e58..f40edb1747 100644 --- a/drivers/fpga/spartan2.c +++ b/drivers/fpga/spartan2.c @@ -40,10 +40,11 @@ static int spartan2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -static int spartan2_load(xilinx_desc *desc, const void *buf, size_t bsize, +static int spartan2_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, bitstream_type bstype) { int ret_val = FPGA_FAIL; + xilinx_desc *desc = *desc_ptr;
switch (desc->iface) { case slave_serial: diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index 4850c99352..b7c1ddd40f 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -44,10 +44,11 @@ static int spartan3_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -static int spartan3_load(xilinx_desc *desc, const void *buf, size_t bsize, +static int spartan3_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, bitstream_type bstype) { int ret_val = FPGA_FAIL; + xilinx_desc *desc = *desc_ptr;
switch (desc->iface) { case slave_serial: diff --git a/drivers/fpga/versalpl.c b/drivers/fpga/versalpl.c index c44a7d3455..9464cae22e 100644 --- a/drivers/fpga/versalpl.c +++ b/drivers/fpga/versalpl.c @@ -26,7 +26,7 @@ static ulong versal_align_dma_buffer(ulong *buf, u32 len) return (ulong)buf; }
-static int versal_load(xilinx_desc *desc, const void *buf, size_t bsize, +static int versal_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, bitstream_type bstype) { ulong bin_buf; diff --git a/drivers/fpga/virtex2.c b/drivers/fpga/virtex2.c index b3e0537bab..d0369d320b 100644 --- a/drivers/fpga/virtex2.c +++ b/drivers/fpga/virtex2.c @@ -93,10 +93,11 @@ static int virtex2_ssm_dump(xilinx_desc *desc, const void *buf, size_t bsize); static int virtex2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize); static int virtex2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
-static int virtex2_load(xilinx_desc *desc, const void *buf, size_t bsize, +static int virtex2_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, bitstream_type bstype) { int ret_val = FPGA_FAIL; + xilinx_desc *desc = *desc_ptr;
switch (desc->iface) { case slave_serial: diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 640baac66e..f89ae8fe10 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -153,7 +153,7 @@ int xilinx_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, return FPGA_FAIL; }
- return desc->operations->load(desc, buf, bsize, bstype); + return desc->operations->load(desc_ptr, buf, bsize, bstype); }
#if defined(CONFIG_CMD_FPGA_LOADFS) diff --git a/drivers/fpga/zynqmppl.c b/drivers/fpga/zynqmppl.c index 8ff12bf50a..c7f9f4ae84 100644 --- a/drivers/fpga/zynqmppl.c +++ b/drivers/fpga/zynqmppl.c @@ -199,8 +199,8 @@ static int zynqmp_validate_bitstream(xilinx_desc *desc, const void *buf, return 0; }
-static int zynqmp_load(xilinx_desc *desc, const void *buf, size_t bsize, - bitstream_type bstype) +static int zynqmp_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, + bitstream_type bstype) { ALLOC_CACHE_ALIGN_BUFFER(u32, bsizeptr, 1); u32 swap = 0; @@ -209,6 +209,7 @@ static int zynqmp_load(xilinx_desc *desc, const void *buf, size_t bsize, u32 buf_lo, buf_hi; u32 ret_payload[PAYLOAD_ARG_CNT]; bool xilfpga_old = false; + xilinx_desc *desc = *desc_ptr;
if (zynqmp_firmware_version() <= PMUFW_V1_0) { puts("WARN: PMUFW v1.0 or less is detected\n"); diff --git a/drivers/fpga/zynqpl.c b/drivers/fpga/zynqpl.c index 2de40109a8..c5d9dbcedf 100644 --- a/drivers/fpga/zynqpl.c +++ b/drivers/fpga/zynqpl.c @@ -370,11 +370,12 @@ static int zynq_validate_bitstream(xilinx_desc *desc, const void *buf, return 0; }
-static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize, +static int zynq_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, bitstream_type bstype) { unsigned long ts; /* Timestamp */ u32 isr_status, swap; + xilinx_desc *desc = *desc_ptr;
/* * send bsize inplace of blocksize as it was not a bitstream diff --git a/include/xilinx.h b/include/xilinx.h index 06ecc9a842..a7efe0e876 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -48,7 +48,7 @@ typedef struct { /* typedef xilinx_desc */ } xilinx_desc; /* end, typedef xilinx_desc */
struct xilinx_fpga_op { - int (*load)(xilinx_desc *desc, const void *buf, size_t bsize, + int (*load)(xilinx_desc **desc_ptr, const void *buf, size_t bsize, bitstream_type bstype); int (*loadfs)(xilinx_desc *desc, const void *buf, size_t bsize, fpga_fs_info *fpga_fsinfo);
M
Add supporting new compatible string "u-boot,zynqmp-fpga-ddrauth" to handle loading authenticated images (DDR).
Based on solution by Jorge Ramirez-Ortiz jorge@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Co-developed-by: Ricardo Salveti ricardo@foundries.io Signed-off-by: Ricardo Salveti ricardo@foundries.io Tested-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com Signed-off-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com --- boot/Kconfig | 4 ++-- doc/uImage.FIT/source_file_format.txt | 5 ++++- drivers/fpga/zynqmppl.c | 21 +++++++++++++++++++++ 3 files changed, 27 insertions(+), 3 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index b83a4e8400..f7faafb29f 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -209,8 +209,8 @@ config SPL_LOAD_FIT 1. "loadables" images, other than FDTs, which do not have a "load" property will not be loaded. This limitation also applies to FPGA images with the correct "compatible" string. - 2. For FPGA images, only the "compatible" = "u-boot,fpga-legacy" - loading method is supported. + 2. For FPGA images, the supported "compatible" list is in the + doc/uImage.FIT/source_file_format.txt. 3. FDTs are only loaded for images with an "os" property of "u-boot". "linux" images are also supported with Falcon boot mode.
diff --git a/doc/uImage.FIT/source_file_format.txt b/doc/uImage.FIT/source_file_format.txt index f93ac6d1c7..461e2af2a8 100644 --- a/doc/uImage.FIT/source_file_format.txt +++ b/doc/uImage.FIT/source_file_format.txt @@ -184,7 +184,10 @@ the '/images' node should have the following layout: Mandatory for types: "firmware", and "kernel". - compatible : compatible method for loading image. Mandatory for types: "fpga", and images that do not specify a load address. - To use the generic fpga loading routine, use "u-boot,fpga-legacy". + Supported compatible methods: + "u-boot,fpga-legacy" - the generic fpga loading routine. + "u-boot,zynqmp-fpga-ddrauth" - signed non-encrypted FPGA bitstream for + Xilinx Zynq UltraScale+ (ZymqMP) device.
Optional nodes: - hash-1 : Each hash sub-node represents separate hash or checksum diff --git a/drivers/fpga/zynqmppl.c b/drivers/fpga/zynqmppl.c index c7f9f4ae84..0ce641e495 100644 --- a/drivers/fpga/zynqmppl.c +++ b/drivers/fpga/zynqmppl.c @@ -9,6 +9,7 @@ #include <common.h> #include <compiler.h> #include <cpu_func.h> +#include <fpga.h> #include <log.h> #include <zynqmppl.h> #include <zynqmp_firmware.h> @@ -210,6 +211,26 @@ static int zynqmp_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, u32 ret_payload[PAYLOAD_ARG_CNT]; bool xilfpga_old = false; xilinx_desc *desc = *desc_ptr; + fpga_desc *fdesc = container_of((void *)desc_ptr, fpga_desc, devdesc); + + if (fdesc && fdesc->compatible && + !strcmp(fdesc->compatible, "u-boot,zynqmp-fpga-ddrauth")) { + struct fpga_secure_info info = { 0 }; + + if (!CONFIG_IS_ENABLED(FPGA_LOAD_SECURE)) { + printf("No support for %s\n", fdesc->compatible); + return FPGA_FAIL; + } + + if (!desc->operations->loads) { + printf("%s: Missing load operation\n", __func__); + return FPGA_FAIL; + } + /* DDR authentication */ + info.authflag = 1; + info.encflag = 2; + return desc->operations->loads(desc, buf, bsize, &info); + }
- FDTs are only loaded for images with an "os" property of "u-boot". "linux" images are also supported with Falcon boot mode.
Optional nodes:
- fpga_desc *fdesc = container_of((void *)desc_ptr, fpga_desc, devdesc);
- if (fdesc && fdesc->compatible &&
I think you should use directly here what you have in 7/7. It means to check that it is not fpga-legacy.
return FPGA_FAIL;
return FPGA_FAIL;
info.authflag = 1;
info.encflag = 2;
Before you start to deal with secure bitstreams you should also likely check this PMUFW checking before you call loads.
Thanks, Michal
Hi Michal,
Optional nodes:
Thanks, fixed. The fix will be introduced in the next patchset version.
return FPGA_FAIL;
return FPGA_FAIL;
info.authflag = 1;
info.encflag = 2;
} if (zynqmp_firmware_version() <= PMUFW_V1_0) { puts("WARN: PMUFW v1.0 or less is detected\n");
Michal, this code block (for earlier PMUFW) does:
1. Set a flag ZYNQMP_FPGA_BIT_NS. According to a description of the commit 19ed4b697b9732e0a5097bd233fba7e24dfe9146, ZYNQMP_FPGA_BIT_NS bit should be set only for nonsecure bitstream. So not needed for zynqmp_loads().
2. Prepare a pointer to a bitstream size (bsizeptr) instead of value (bsize). For secure bitstream, a key address is already used instead.
3. Validate a bitstream data and placement with zynqmp_validate_bitstream(). I've not found enough information about validating non-secure/secure bitstreams. Could you confirm the function zynqmp_validate_bitstream() can be used to validate both legacy and secure bitstreams?
Thanks, Oleksandr.
Thanks, Michal
Add supporting new compatible string "u-boot,zynqmp-fpga-enc" to handle loading encrypted bitfiles.
This feature requires encrypted FSBL,as according to UG1085: "The CSU automatically locks out the AES key, stored in either BBRAM or eFUSEs, as a key source to the AES engine if the FSBL is not encrypted. This prevents using the BBRAM or eFUSE as the key source to the AES engine during run-time applications."
Signed-off-and-tested-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com --- doc/uImage.FIT/source_file_format.txt | 2 ++ drivers/fpga/zynqmppl.c | 14 ++++++++++---- include/fpga.h | 1 + 3 files changed, 13 insertions(+), 4 deletions(-)
diff --git a/doc/uImage.FIT/source_file_format.txt b/doc/uImage.FIT/source_file_format.txt index 461e2af2a8..6870111840 100644 --- a/doc/uImage.FIT/source_file_format.txt +++ b/doc/uImage.FIT/source_file_format.txt @@ -188,6 +188,8 @@ the '/images' node should have the following layout: "u-boot,fpga-legacy" - the generic fpga loading routine. "u-boot,zynqmp-fpga-ddrauth" - signed non-encrypted FPGA bitstream for Xilinx Zynq UltraScale+ (ZymqMP) device. + "u-boot,zynqmp-fpga-enc" - encrypted FPGA bitstream for Xilinx Zynq + UltraScale+ (ZynqMP) device.
Optional nodes: - hash-1 : Each hash sub-node represents separate hash or checksum diff --git a/drivers/fpga/zynqmppl.c b/drivers/fpga/zynqmppl.c index 0ce641e495..1090734936 100644 --- a/drivers/fpga/zynqmppl.c +++ b/drivers/fpga/zynqmppl.c @@ -214,7 +214,7 @@ static int zynqmp_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, fpga_desc *fdesc = container_of((void *)desc_ptr, fpga_desc, devdesc);
if (fdesc && fdesc->compatible && - !strcmp(fdesc->compatible, "u-boot,zynqmp-fpga-ddrauth")) { + strncmp(fdesc->compatible, "u-boot,fpga-legacy", 18)) { struct fpga_secure_info info = { 0 };
if (!CONFIG_IS_ENABLED(FPGA_LOAD_SECURE)) { @@ -226,9 +226,15 @@ static int zynqmp_load(xilinx_desc **desc_ptr, const void *buf, size_t bsize, printf("%s: Missing load operation\n", __func__); return FPGA_FAIL; } - /* DDR authentication */ - info.authflag = 1; - info.encflag = 2; + if (!strncmp(fdesc->compatible+19, "enc", 3)) { + /* Encryption using device key */ + info.authflag = FPGA_NO_ENC_OR_NO_AUTH; + info.encflag = FPGA_ENC_DEV_KEY; + } else { + /* DDR authentication */ + info.authflag = ZYNQMP_FPGA_AUTH_DDR; + info.encflag = FPGA_NO_ENC_OR_NO_AUTH; + } return desc->operations->loads(desc, buf, bsize, &info); }
diff --git a/include/fpga.h b/include/fpga.h index 2891f32106..cdf80fedf6 100644 --- a/include/fpga.h +++ b/include/fpga.h @@ -20,6 +20,7 @@ /* device numbers must be non-negative */ #define FPGA_INVALID_DEVICE -1
+#define FPGA_ENC_DEV_KEY 0 #define FPGA_ENC_USR_KEY 1 #define FPGA_NO_ENC_OR_NO_AUTH 2
Changed in v7:
Changed in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
Thanks for continuing on this work. We are almost there. Just small things to finish and we are ready to go.
Thanks, Michal
Adrian Fiergolski
Michal Simek
Oleksandr Suvorov
