[RFC PATCH] doc: arch: Add document for RISC-V architecture
This patch adds a brief introduction to the RISC-V architecture and the typical boot process used on a variety of RISC-V platforms.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com --- Hi RISC-V community,
Please leave a comment if there is anything I've missed that should be mentioned in the document. Thanks. --- doc/arch/index.rst | 1 + doc/arch/riscv.rst | 43 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 44 insertions(+) create mode 100644 doc/arch/riscv.rst
diff --git a/doc/arch/index.rst b/doc/arch/index.rst index b3e85f9bf3..b8da4b8c8e 100644 --- a/doc/arch/index.rst +++ b/doc/arch/index.rst @@ -11,6 +11,7 @@ Architecture-specific doc m68k mips nios2 + riscv sandbox/index sh x86 diff --git a/doc/arch/riscv.rst b/doc/arch/riscv.rst new file mode 100644 index 0000000000..243e7e7e2e --- /dev/null +++ b/doc/arch/riscv.rst @@ -0,0 +1,43 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2023, Yu Chien Peter Lin peterlin@andestech.com + +RISC-V +====== + +Overview +-------- + +This document outlines the U-Boot boot process for the RISC-V architecture. +RISC-V is an open-source instruction set architecture (ISA) based on the +principles of reduced instruction set computing (RISC). It has been designed +to be flexible and customizable, allowing it to be adapted to different use +cases, from embedded systems to high performance servers. + +Typical Boot Process +-------------------- + +RISC-V production boot images typically include a U-Boot SPL for platform-specific +initialization. The U-Boot SPL then loads a FIT image (u-boot.itb), which contains +an SBI (Supervisor Binary Interface) firmware such as `OpenSBI https://github.com/riscv-software-src/opensbi`_, as well as a regular +U-Boot (or U-Boot proper) running in S-mode. Finally, the S-mode Operating System +is loaded. + +In between the boot stages, the hartid is passed through the a0 register, and the +start address of the devicetree is passed through the a1 register. + +The following diagram illustrates the boot process:: + + <----------( M-mode )--------><-------( S-mode )------> + +------------+ +---------+ +--------+ +--------+ + | U-Boot SPL |-->| SBI |--->| U-Boot |-->| OS | + +------------+ +---------+ +--------+ +--------+ + +To examine the boot process with the QEMU virt machine, you can follow the steps +in the following document: +:doc:`../board/emulation/qemu-riscv.rst` + +Toolchain +--------- + +You can build the `RISC-V GNU toolchain https://github.com/riscv-collab/riscv-gnu-toolchain`_ from scratch, or download a +pre-built toolchain from the `releases page https://github.com/riscv-collab/riscv-gnu-toolchain/releases`_.
Reviewed-by: Samuel Holland samuel@sholland.org
On Sun, 12 Feb 2023 at 00:01, Yu Chien Peter Lin peterlin@andestech.com wrote:
Looks good. One nit is that we try to talk in terms of boot 'phases' rather than stages.
Hi Simon,
Thanks for the review, I'll update in the next patch.
Best regards, Peter Lin
- riscv sandbox/index sh x86
+RISC-V +======
+Overview +--------
%s/typically include/may include/
Many boards don't use SPL:
ae350_rv32_defconfig ae350_rv64_defconfig sipeed_maix_bitm_defconfig sipeed_maix_smode_defconfig openpiton_riscv64_defconfig qemu-riscv64_defconfig
Please provide a description of those boot processes too.
Please, try to stay within 80 columns.
%s/an SBI (Supervisor Binary Interface) firmware/a firmware providing the SBI (Supervisor Binary Interface)/
- <----------( M-mode )--------><-------( S-mode )------>
- | U-Boot SPL |-->| SBI |--->| U-Boot |-->| OS |
SBI (Supervisory Binary Interface) is an interface not a software. So it does not fit into this diagram.
Best regards
Heinrich
Hi Heinrich,
+RISC-V +======
+Overview +--------
Sure, I will add a description for these defconfigs.
OK, will fix.
OK.
Sure, I will rename the block to SBI firmware.
Best regards
Heinrich
participants (5)
Samuel Holland
Yu Chien Peter Lin
Yu-Chien Peter Lin
