[Regression] rk3588 failed to boot linux
When test with current main branch on rk3588 based coolpi 4b, the board failed to boot linux os[0]: I do the same test on another board that is preparing to send patches upstream, and it also failed.
The two boards boots fine with v2024.10. With some bisect, it seems that this issue is caused by:
commit 360aaddd9cea8c256f50c576794415cadfb61819 Merge: 2c832abc732 f8ffc6f3cc4 Author: Tom Rini trini@konsulko.com Date: Tue Sep 3 14:09:30 2024 -0600
Merge patch series "Make LMB memory map global and persistent"
Sughosh Ganu sughosh.ganu@linaro.org says:
My boards boot fine before this merge on u-boot/next, and all failed to boot linux after this merge.
I am not familiar with the LMB mechanism, so i don't know how to find the root case now.
I dump the bdinfo for both good case[1] and gegression case[2], not sure if they are usefull for debug this issue.
[0] Synchronous Abort when starting kernel: Scanning bootdev 'mmc@fe2c0000.bootdev': Card did not respond to voltage select! : -110 Scanning bootdev 'mmc@fe2e0000.bootdev': 1 script ready mmc 1 mmc@fe2e0000.bootdev.part /boot/boot.scr ** Booting bootflow 'mmc@fe2e0000.bootdev.part_1' with script Boot script loaded from mmc 0:1 224 bytes read in 7 ms (31.3 KiB/s) 26510301 bytes read in 97 ms (260.6 MiB/s) 32883200 bytes read in 122 ms (257 MiB/s) 148323 bytes read in 30 ms (4.7 MiB/s) Working FDT set to 12000000 Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' ## Loading init Ramdisk from Legacy Image at 12180000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 26510237 Bytes = 25.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 12000000 Booting using the fdt blob at 0x12000000 Working FDT set to 12000000 Loading Ramdisk to eb58f000, end eced739d ... OK Loading Device Tree to 00000000eb502000, end 00000000eb58efff ... OK Working FDT set to eb502000
Starting kernel ...
"Synchronous Abort" handler, esr 0x96000004, far 0x96142b896930b907 elr: 0000000000a8d3b8 lr : 0000000000a77450 (reloc) elr: 00000000effa13b8 lr : 00000000eff8b450 x0 : 96142b896930b907 x1 : 00000000effab870 x2 : 0000000000000010 x3 : 00000000edf47310 x4 : 0000000000000000 x5 : 96142b896930b907 x6 : 0000000000000007 x7 : 0000000000000004 x8 : 0000000000000040 x9 : fffffffffffffff0 x10: 00000000eb526fff x11: 00000000edf3a808 x12: 0000000000000006 x13: 00000000eb502000 x14: 00000000ffffffff x15: 00000000ededb588 x16: 00000000eff68738 x17: 0000000000000000 x18: 00000000edef4d70 x19: 00000000eceb4040 x20: 00000000eff14f50 x21: 00000000eceac000 x22: 00000000effcc000 x23: 0000000000000001 x24: 0000000000000001 x25: 0000000000200000 x26: 00000000edf385c0 x27: 00000000eced8000 x28: 00000000eced9000 x29: 00000000ededb3c0
Code: eb04005f 54000061 52800000 14000006 (386468a3) Resetting CPU ...
[1] bdinfo for success boot => bdinfo boot_params = 0x0000000000000000 DRAM bank = 0x0000000000000000 -> start = 0x0000000000200000 -> size = 0x00000000efe00000 DRAM bank = 0x0000000000000001 -> start = 0x00000001f0000000 -> size = 0x0000000010000000 flashstart = 0x0000000000000000 flashsize = 0x0000000000000000 flashoffset = 0x0000000000000000 baudrate = 1500000 bps relocaddr = 0x00000000eff14000 reloc off = 0x00000000ef514000 Build = 64-bit current eth = unknown eth-1addr = (not set) IP addr = <NULL> fdt_blob = 0x00000000ededcd80 new_fdt = 0x00000000ededcd80 fdt_size = 0x0000000000017fa0 lmb_dump_all: memory.cnt = 0x2 / max = 0x10 memory[0] [0x200000-0xefffffff], 0xefe00000 bytes flags: 0 memory[1] [0x1f0000000-0x1ffffffff], 0x10000000 bytes flags: 0 reserved.cnt = 0x2 / max = 0x10 reserved[0] [0xeced8000-0xefffffff], 0x03128000 bytes flags: 0 reserved[1] [0x1f0000000-0x1ffffffff], 0x10000000 bytes flags: 0 devicetree = separate serial addr = 0x00000000feb50000 width = 0x0000000000000004 shift = 0x0000000000000002 offset = 0x0000000000000000 clock = 0x00000000016e3600 arch_number = 0x0000000000000000 TLB addr = 0x00000000efff0000 irq_sp = 0x00000000ededcd70 sp start = 0x00000000ededcd70 Early malloc usage: 2440 / 10000 =>
[2] bdinfo for boot failed case; => bdinfo boot_params = 0x0000000000000000 DRAM bank = 0x0000000000000000 -> start = 0x0000000000200000 -> size = 0x00000000efe00000 DRAM bank = 0x0000000000000001 -> start = 0x00000001f0000000 -> size = 0x0000000010000000 flashstart = 0x0000000000000000 flashsize = 0x0000000000000000 flashoffset = 0x0000000000000000 baudrate = 1500000 bps relocaddr = 0x00000000eff14000 reloc off = 0x00000000ef514000 Build = 64-bit current eth = unknown eth-1addr = (not set) IP addr = <NULL> fdt_blob = 0x00000000ededc1b0 lmb_dump_all: memory.count = 0x1 memory[0] [0x200000-0xefffffff], 0xefe00000 bytes flags: none reserved.count = 0x1 reserved[0] [0xeced81a0-0xefffffff], 0x03127e60 bytes flags: no-overwrite devicetree = separate serial addr = 0x00000000feb50000 width = 0x0000000000000004 shift = 0x0000000000000002 offset = 0x0000000000000000 clock = 0x00000000016e3600 arch_number = 0x0000000000000000 TLB addr = 0x00000000efff0000 irq_sp = 0x00000000ededc1a0 sp start = 0x00000000ededc1a0 Early malloc usage: 2440 / 10000
Merge patch series "Make LMB memory map global and persistent" Sughosh Ganu <sughosh.ganu@linaro.org> says:
Starting kernel ...
With the LMB series applied, the memory region covered by the DRAM Bank 1 is not getting added to the LMB memory map. And I suspect that the scripts are using addresses in the bank 1 to load and boot the kernel. Can you confirm this ? This seems to be happening because of the value of gd->ram_top that is being set for the rockchip boards. Based on a cursory look at arch/arm/mach-rockchip/sdram.c, the value of gd->ram_top is capped at 0xf0000000 for the rk3588 boards. Can you confirm if this is indeed the case ? If so, the second DRAM bank will not get added to the LMB memory map, and consequently you will not be able to load images to addresses in this bank. To fix this, the value of gd->ram_top will have to be changed for the rockchip boards to reflect the presence of memory above 4GB. Another possible solution is to use addresses in the bank0 for booting the images.
-sughosh
2.34.1
Hi Suqhosh,
Starting kernel ...
According to the bdinfo [1][2], the board have two bank: DRAM bank = 0x0000000000000000 -> start = 0x0000000000200000 -> size = 0x00000000efe00000 DRAM bank = 0x0000000000000001 -> start = 0x00000001f0000000 -> size = 0x0000000010000000
The Armbian scripts boot linux kernel with command:
booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} fdt_addr_r=0x12000000 kernel_addr_r=0x02000000 ramdisk_addr_r=0x12180000
It seems that the are all in bank0 ?
-sughosh
2.34.1
On Mon, 14 Oct 2024 at 16:12, Andy Yan andyshrk@163.com wrote:
Hi Suqhosh,
Starting kernel ...
Yes, they all seem to be booting from bank 0. Can you share the command that you use for trying to boot these images ? I will try to boot on the rockpi-4 that I have with me and see if I hit this issue. It will be much easier for me to understand what is happening if I can reproduce the issue on my end.
-sughosh
-sughosh
2.34.1
Hi Sughosh,
Hi Suqhosh,
Starting kernel ...
The boot scripts is here[3].
U-boot will load the boot script from emmc, then load dtb, ramdisk, kernel Image, then boot it with booti command, see the boot log before.
Thanks for it. I can also help provide more debug information(such as modify u-boot code and add debug log) if you needed it.
[3] https://github.com/armbian/build/blob/main/config/bootscripts/boot-rockchip6...
-sughosh
-sughosh
2.34.1
On Mon, 14 Oct 2024 at 16:49, Andy Yan andyshrk@163.com wrote:
Hi Sughosh,
Hi Suqhosh,
Starting kernel ...
Thanks for sharing this. Will try this on my rockpi-4 and get back. IIRC, Jonas has tried booting linux on other rockchip based boards, and has been able to do so with the EFI part of the series applied. So I suspect that this is something specific to the memory layout defined for this SoC.
-sughosh
-sughosh
-sughosh
2.34.1
Hi Sughosh,
Hi Sughosh,
Hi Suqhosh,
Starting kernel ...
This has nothing to do with the memory layout defined for the SoC.
Images is loaded in low ram and later moved into LMB ram_top area, however after the series "Make LMB memory map global and persistent" there is an overlap of a EFI pool and where these images are moved.
One or two EFI pools is allocated early during the boot, possible when efi_mgt bootmeth is tested, when this fails and script or extlinux bootmeth is used images is instead loaded and moved into LMB area.
Before jumping to kernel the 1-2 remaining EFI pools is being freed and this cause an crash, or an illegal free, depending on what ramdisk or fdt data happened to overwrite the EFI pool data.
Here is an example:
Scanning global bootmeth 'efi_mgr': EFI: efi_add_memory_map_pg: 0xecedf000 0x1 4 yes EFI: efi_add_memory_map_pg: 0xecede000 0x1 4 yes EFI: BlockIO: part 0, present 1, logical 0, removable 1, last_block 62357503 EFI: efi_add_memory_map_pg: 0xecedd000 0x1 4 yes EFI: efi_add_memory_map_pg: 0xecedc000 0x1 4 yes ... EFI boot manager: Cannot load any image Boot failed (err=-14) Scanning bootdev 'mmc@fe2b0000.bootdev': 1 extlinux ready mmc 1 mmc@fe2b0000.bootdev.part /extlinux/extlinux.conf ** Booting bootflow 'mmc@fe2b0000.bootdev.part_1' with extlinux ... Working FDT set to edee3f90 Loading Ramdisk to ecd42000, end ecedf8f5 ... OK Loading Device Tree to 00000000ecd2d000, end 00000000ecd41dd7 ... OK Working FDT set to ecd2d000
Starting kernel ...
efi_free_pool: illegal free 0x00000000ecedf040 efi_free_pool: illegal free 0x00000000ecedc040
Above 0xecedf000 and 0xecedc000 was mapped early during efi_mgr was tested. However it was not freed until after ramdisk (0xecd42000 - 0xecedf8f5) is loaded into these locations. That time it only resulted in an illegal free instead of a crash.
More examples: https://gist.github.com/Kwiboo/7ed4fd2dea4877672189b0219b25c28b#file-u-boot-...
Regards, Jonas
-sughosh
-sughosh
-sughosh
2.34.1
Helllo,
在 2024-10-14 23:14:04,"Jonas Karlman" jonas@kwiboo.se 写道:
Hi Sughosh,
Hi Sughosh,
Hi Suqhosh,
On Mon, 14 Oct 2024 at 15:12, Andy Yan andyshrk@163.com wrote: > > When test with current main branch on rk3588 based coolpi 4b, > the board failed to boot linux os[0]: > I do the same test on another board that is preparing to send > patches upstream, and it also failed. > > The two boards boots fine with v2024.10. > With some bisect, it seems that this issue is caused by: > > commit 360aaddd9cea8c256f50c576794415cadfb61819 > Merge: 2c832abc732 f8ffc6f3cc4 > Author: Tom Rini trini@konsulko.com > Date: Tue Sep 3 14:09:30 2024 -0600 > > Merge patch series "Make LMB memory map global and persistent" > > Sughosh Ganu sughosh.ganu@linaro.org says: > > My boards boot fine before this merge on u-boot/next, and all failed > to boot linux after this merge. > > I am not familiar with the LMB mechanism, so i don't know how to find > the root case now. > > I dump the bdinfo for both good case[1] and gegression case[2], not sure > if they are usefull for debug this issue. > > [0] Synchronous Abort when starting kernel: > Scanning bootdev 'mmc@fe2c0000.bootdev': > Card did not respond to voltage select! : -110 > Scanning bootdev 'mmc@fe2e0000.bootdev': > 1 script ready mmc 1 mmc@fe2e0000.bootdev.part > /boot/boot.scr > ** Booting bootflow 'mmc@fe2e0000.bootdev.part_1' with script > Boot script loaded from mmc 0:1 > 224 bytes read in 7 ms (31.3 KiB/s) > 26510301 bytes read in 97 ms (260.6 MiB/s) > 32883200 bytes read in 122 ms (257 MiB/s) > 148323 bytes read in 30 ms (4.7 MiB/s) > Working FDT set to 12000000 > Trying kaslrseed command... Info: Unknown command can be safely ignored > since kaslrseed does not apply to all boards. > Unknown command 'kaslrseed' - try 'help' > ## Loading init Ramdisk from Legacy Image at 12180000 ... > Image Name: uInitrd > Image Type: AArch64 Linux RAMDisk Image (gzip compressed) > Data Size: 26510237 Bytes = 25.3 MiB > Load Address: 00000000 > Entry Point: 00000000 > Verifying Checksum ... OK > ## Flattened Device Tree blob at 12000000 > Booting using the fdt blob at 0x12000000 > Working FDT set to 12000000 > Loading Ramdisk to eb58f000, end eced739d ... OK > Loading Device Tree to 00000000eb502000, end 00000000eb58efff ... OK > Working FDT set to eb502000 > > Starting kernel ... > > "Synchronous Abort" handler, esr 0x96000004, far 0x96142b896930b907 > elr: 0000000000a8d3b8 lr : 0000000000a77450 (reloc) > elr: 00000000effa13b8 lr : 00000000eff8b450 > x0 : 96142b896930b907 x1 : 00000000effab870 > x2 : 0000000000000010 x3 : 00000000edf47310 > x4 : 0000000000000000 x5 : 96142b896930b907 > x6 : 0000000000000007 x7 : 0000000000000004 > x8 : 0000000000000040 x9 : fffffffffffffff0 > x10: 00000000eb526fff x11: 00000000edf3a808 > x12: 0000000000000006 x13: 00000000eb502000 > x14: 00000000ffffffff x15: 00000000ededb588 > x16: 00000000eff68738 x17: 0000000000000000 > x18: 00000000edef4d70 x19: 00000000eceb4040 > x20: 00000000eff14f50 x21: 00000000eceac000 > x22: 00000000effcc000 x23: 0000000000000001 > x24: 0000000000000001 x25: 0000000000200000 > x26: 00000000edf385c0 x27: 00000000eced8000 > x28: 00000000eced9000 x29: 00000000ededb3c0 > > Code: eb04005f 54000061 52800000 14000006 (386468a3) > Resetting CPU ... > > [1] bdinfo for success boot > => bdinfo > boot_params = 0x0000000000000000 > DRAM bank = 0x0000000000000000 > -> start = 0x0000000000200000 > -> size = 0x00000000efe00000 > DRAM bank = 0x0000000000000001 > -> start = 0x00000001f0000000 > -> size = 0x0000000010000000 > flashstart = 0x0000000000000000 > flashsize = 0x0000000000000000 > flashoffset = 0x0000000000000000 > baudrate = 1500000 bps > relocaddr = 0x00000000eff14000 > reloc off = 0x00000000ef514000 > Build = 64-bit > current eth = unknown > eth-1addr = (not set) > IP addr = <NULL> > fdt_blob = 0x00000000ededcd80 > new_fdt = 0x00000000ededcd80 > fdt_size = 0x0000000000017fa0 > lmb_dump_all: > memory.cnt = 0x2 / max = 0x10 > memory[0] [0x200000-0xefffffff], 0xefe00000 bytes flags: 0 > memory[1] [0x1f0000000-0x1ffffffff], 0x10000000 bytes flags: 0 > reserved.cnt = 0x2 / max = 0x10 > reserved[0] [0xeced8000-0xefffffff], 0x03128000 bytes flags: 0 > reserved[1] [0x1f0000000-0x1ffffffff], 0x10000000 bytes flags: 0 > devicetree = separate > serial addr = 0x00000000feb50000 > width = 0x0000000000000004 > shift = 0x0000000000000002 > offset = 0x0000000000000000 > clock = 0x00000000016e3600 > arch_number = 0x0000000000000000 > TLB addr = 0x00000000efff0000 > irq_sp = 0x00000000ededcd70 > sp start = 0x00000000ededcd70 > Early malloc usage: 2440 / 10000 > => > > > [2] bdinfo for boot failed case; > => bdinfo > boot_params = 0x0000000000000000 > DRAM bank = 0x0000000000000000 > -> start = 0x0000000000200000 > -> size = 0x00000000efe00000 > DRAM bank = 0x0000000000000001 > -> start = 0x00000001f0000000 > -> size = 0x0000000010000000 > flashstart = 0x0000000000000000 > flashsize = 0x0000000000000000 > flashoffset = 0x0000000000000000 > baudrate = 1500000 bps > relocaddr = 0x00000000eff14000 > reloc off = 0x00000000ef514000 > Build = 64-bit > current eth = unknown > eth-1addr = (not set) > IP addr = <NULL> > fdt_blob = 0x00000000ededc1b0 > lmb_dump_all: > memory.count = 0x1 > memory[0] [0x200000-0xefffffff], 0xefe00000 bytes flags: none > reserved.count = 0x1 > reserved[0] [0xeced81a0-0xefffffff], 0x03127e60 bytes flags: > no-overwrite > devicetree = separate > serial addr = 0x00000000feb50000 > width = 0x0000000000000004 > shift = 0x0000000000000002 > offset = 0x0000000000000000 > clock = 0x00000000016e3600 > arch_number = 0x0000000000000000 > TLB addr = 0x00000000efff0000 > irq_sp = 0x00000000ededc1a0 > sp start = 0x00000000ededc1a0 > Early malloc usage: 2440 / 10000
Here is an example:
Starting kernel ...
The systen can boot with EFI_LOADER disabled, so it seems that the solution is wating until Sughoshs EFI/LMB sync series or Simons alternative series is merged,
Regards, Jonas
-sughosh
-sughosh
-sughosh
> 2.34.1 >
Hi Suqhosh,
Starting kernel ...
Looks like my prior mail got stuck, trying again.
The issue above is the same that I reported in #u-boot [1] and [2], EFI and ramdisk (or fdt) memory is overlapping, this has been broken since next was merged into master.
The ram_top/ram_size or script has nothing to do with it and is working perfectly fine as is.
The issue is that EFI_LOADER will enable LMB, and because LMB is enabled images/fdt is moved close to ram_top. EFI has however allocated a pool in the same area that images/fdt is moved to, so when EFI tries to free memory before jumping into linux the pool memory has been overwritten and may cause an illegal free or crash.
The only way to avoid this for now is to disable EFI_LOADER Kconfig option until Sughoshs EFI/LMB sync series or Simons alternative series is merged, or possible boot using EFI. Until then having EFI_LOADER enabled (default) and not booting with EFI may cause this type of crash.
[1] https://libera.irclog.whitequark.org/u-boot/2024-10-03#37092785 [2] https://libera.irclog.whitequark.org/u-boot/2024-10-07#37114863
Regards, Jonas
-sughosh
-sughosh
2.34.1
From: Sughosh Ganu sughosh.ganu@linaro.org Date: Mon, 14 Oct 2024 15:43:35 +0530
Starting kernel ...
Hi Sughosh,
Making the memory above 4GB not available to U-Boot is deliberate. The RK3588 has peripherals that can't address memory above 4GB. Since there is enough memory below 4GB, it is easiest to just hide the memory above 4G from U-Boot by capping gd->ram_top.
If you look at the code in lib/efi_loader/efi_memory.c you'll see that all the memory in the dram banks is added to the EFI memory map, but that memory above gd->ram_top is reserved and marked as EFI_BOOT_SERVICES_DATA. This means that U-Boot and EFI applications will not use the memory above 4G, but that memory will be available to the OS once ExitBootServices() has been called.
So the LMB code should probably do the same: add all the memory in the configured memory banks but reserve everything above gd->ram_top.
Cheers,
Mark
Andy Yan
Jonas Karlman
Mark Kettenis
Sughosh Ganu
